12-12-2020, 10:55 | #151 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
Please upload file fault.bin to mega.nz and post link here. File is in /InfinityBox/CM2MT2/ or in /InfinityBox/CM2SP2/ folder | |
12-12-2020, 21:06 | #152 (permalink) |
Freak Poster Join Date: Jan 2010 Location: türkiye
Member: 1207296 Status: Offline Sonork: 100.1609587 Thanks Meter: 74 | === DongleManager [Infinity] v1.80 [12.12.2020 23:06:22] === Box/Dongle type selected: [BEST] Card-Reader: Generic EMV Smartcard Reader 0 HWID: 00053D7901171292 Box/Dongle found: [BEST] Reading... Serial No (S/N): 0A843D79 Firmware version: 0122.02 === Process started: 12.12.2020 23:06:23 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Write to https://www.infinity-box.com/support/?r=2 Thx vey muach |
12-12-2020, 23:04 | #153 (permalink) | |
To avoid software conflicts in future please do not use "Hexframe" at the same time with Infinity software. What to do now: 1. Delete fault.bin file from software folder (if you have it there) 2. Install latest Infinity software updates 3. Run DongleManager 4. Update Dongle firmware Only ONE update try is allowed ! In case of problem DO NOT update card again ! | |
12-13-2020, 07:41 | #154 (permalink) |
Junior Member Join Date: Oct 2014
Member: 2272026 Status: Offline Thanks Meter: 0 | === DongleManager [Infinity] v1.80 [12/12/2020 17:26:46] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Generic EMV Smartcard Reader 0 HWID: 00000AC01BE14082 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): EFF70AC0 Firmware version: 0145.02 === Process started: 12/12/2020 17:26:48 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. |
12-13-2020, 11:00 | #155 (permalink) | |
Reboot PC now Run DongleManager - https://www.infinity-box.com/support/?r=5 Update Dongle firmware now Only ONE update try is allowed ! In case of problem DO NOT update card again ! | |
12-14-2020, 08:01 | #157 (permalink) | |
Member: 1207296 Status: Offline Sonork: 100.1609587 Thanks Meter: 74 | Quote:
12-14-2020, 08:03 | #158 (permalink) | |
12-14-2020, 17:29 | #161 (permalink) |
Junior Member Join Date: Sep 2008
Member: 872306 Status: Offline Thanks Meter: 0 | === DongleManager [Infinity] v1.80 [14/12/2020 17:28:43] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: FT SCR2000 0 HWID: 01099169147D1292 === Process started: 14/12/2020 17:28:43 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Write to https://www.infinity-box.com/support/?r=2 |
12-14-2020, 17:37 | #162 (permalink) | |
- Install REQUIRED Card-Reader Drivers - https://www.infinity-box.com/support/?r=6 File with Drivers: CardReader_Fetian_FT2K.7z File with Instruction: Infinity-Box_How_to_update_FT_SCR2000_CardReader_drivers.pd f Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202 - Run Infinity DongleManager - Update Dongle firmware Alternative method: - Insert Infinity Smart-Card into another Card-Reader (f.e. another dongle or box). Good result for today gives Alcor Card-Reader. - Run Infinity DongleManager - Update Dongle firmware In case of problem DO NOT update card again but contact to support ! More info is here - https://www.infinity-box.com/support/?r=100129 | |
12-15-2020, 11:13 | #163 (permalink) |
Freak Poster Join Date: Jan 2015 Location: Nigeria Rivers State
Member: 2332337 Status: Offline Thanks Meter: 35 | === DongleManager [Infinity] v1.80 [12/15/2020 11:12:17] === Searching... Card-Reader: FT SCR2000 0 HWID: 0203796A147D1292 Box/Dongle found: [BEST] Reading... Serial No (S/N): 45C8796A Firmware version: 0122.02 === Process started: 12/15/2020 11:12:23 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Write to https://www.infinity-box.com/support/?r=2 PLease help |
12-15-2020, 13:16 | #164 (permalink) | |
Probably there is a software conflict with the next application(s): C:\program files (x86)\intel\bluetooth\devmonsrv.exe C:\program files (x86)\intel\intel(r) usb 3.0 extensible host controller driver\application\iusb3mon.exe C:\program files\renesas electronics\usb 3.0 host controller driver\application\nusb3mon.exe C:\program files (x86)\nec electronics\usb 3.0 host controller driver\application\nusb3mon.exe C:\program files\via xhci uasp utility\usb3monitor.exe What to do: - Delete or rename files (see above) - Reboot PC - Delete fault.bn file - Update dongle firmware with DongleManager now - Run Infinity software. | |
12-16-2020, 01:06 | #165 (permalink) |
Member: 872306 Status: Offline Thanks Meter: 0 | Sorry, I have slow internet When updating the update stops in half == DongleManager [Infinity] v1.80 [16/12/2020 00:59:30] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: FT SCR2000 0 HWID: 01099169147D1292 === Process started: 16/12/2020 00:59:31 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Write to https://www.infinity-box.com/support/?r=2 |
