12-20-2020, 12:22 | #181 (permalink) | |
Read NOTE here - https://www.infinity-box.com/support/?s=2 Uninstall/disable Eltima/Flexihub and other usb sharing tools and do not use it at the same time with Infinity software. Next steps: - Delete fault.bin file from software folder (if you have it there) - Run DongleManager - Update Dongle firmware | |
12-21-2020, 11:49 | #182 (permalink) |
Junior Member Join Date: Jul 2010 Location: A
Member: 1342491 Status: Offline Sonork: 100.1651759 Thanks Meter: 2 | === DongleManager [Infinity] v1.80 [21/12/2020 13:48:06] === Box/Dongle type selected: [BEST] Card-Reader: Generic EMV Smartcard Reader 0 HWID: 00000B1912534082 Box/Dongle found: [BEST] Reading... Serial No (S/N): 49AC0B19 Firmware version: 0122.02 === Process started: 21/12/2020 13:48:07 === Connecting to server... Server connection successfully established Checking upgrade client version... Your upgrade client is up-to-date Checking Box/Dongle Identification... Authenticating on server... Authentication stage error: Server reported error: [0007] Not translated! |
12-21-2020, 15:27 | #183 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
Your dongle already updated well. Why do you want to update again ? | |
12-22-2020, 11:16 | #184 (permalink) |
Member: 1342491 Status: Offline Sonork: 100.1651759 Thanks Meter: 2 | Infinity BB5 Easy Service Tool [BEST] software activation for Infinity-Box/Dongle [CM2] Price: 150 Balance: 189 Quantity: 0 of 15 done Average time: instant Instruction: After order become COMPLETED you should update Smart-Card firmware Status: 49AC0B19 Not Found To Validate Serial Number and check Dongle type click here ---------------------------------------------------------------------------------- WHEN I CHECK ----------------------------------------------------------------------------------- Infinity Products Serial Number check Detect Box/Dongle Type, validate S/N etc. Price: 0 Balance: 189 Quantity: 0 of 105 done Average time: instant Serial Number: 49AC0B19 Username: 0349AC0B19 Token Type: Infinity [BEST] Registered: 2017-02-22 Expired: 2020-07-01 Account Status: Active Firmware Version: 0123 Hardware Status: Ok |
12-22-2020, 11:49 | #185 (permalink) | |
If you want to activate CM2 for your dongle please select: Infinity-Box/Dongle [CM2] software activation for Infinity [BEST] | |
12-22-2020, 15:21 | #186 (permalink) |
Freak Poster Join Date: Dec 2011 Location: Chittagong, Bangladesh
Member: 1706809 Status: Offline Thanks Meter: 63 | === DongleManager [Infinity] v1.80 [2020-12-22 20:18:24] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 0000238711384082 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): A64B2387 Firmware version: 0146.02 === Process started: 2020-12-22 20:18:25 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Write to https://www.infinity-box.com/support/?r=2 plz sir fix my problem |
12-22-2020, 16:07 | #187 (permalink) | |
Make step-by-step now: Reboot PC then update dongle firmware then delete fault.bin file from CM2 folder (if any) | |
12-23-2020, 08:55 | #188 (permalink) |
Junior Member Join Date: May 2006 Location: russia
Member: 279194 Status: Offline Thanks Meter: 3 | please help === DongleManager [Infinity] v1.80 [23.12.2020 10:52:47] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: FT SCR2000 0 HWID: 0008607224A11292 === Process started: 23.12.2020 10:52:47 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Write to https://www.infinity-box.com/support/?r=2 |
12-23-2020, 09:42 | #189 (permalink) |
Member: 1342491 Status: Offline Sonork: 100.1651759 Thanks Meter: 2 | Infinity-Box/Dongle [CM2] 2 years Updates/Support Renew Price: 180 Balance: 189 Quantity: 0 of 40 done Average time: instant Instruction: Your dongle should have Infinity-Box/Dongle activation before order Renew ! After order become COMPLETED you should update Box/Dongle firmware Support area access will be activated in several hours Infinity-Box/Dongle [CM2] S/N: 49AC0B19 Status: 49AC0B19 Not Found or is not active To Validate Serial Number and check Dongle type click here |
12-23-2020, 11:04 | #190 (permalink) |
No Life Poster Join Date: Jan 2004 Location: India Age: 43
Member: 50805 Status: Offline Thanks Meter: 101 | === DongleManager [Infinity] v1.80 [23-12-2020 15:31:54] === Box/Dongle type selected: [BEST] Card-Reader: FT SCR2000 0 HWID: 0102A6621C6A1292 === Process started: 23-12-2020 15:31:55 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Write to https://www.infinity-box.com/support/?r=2 |
12-23-2020, 12:40 | #191 (permalink) | |
This Smart-Card is not an Infinity Smart-Card 1. Disconnect all other Boxes and Dongles from PC 2. Connect ONLY one Infinity Box/Dongle to PC | |
12-23-2020, 12:41 | #192 (permalink) | |
12-23-2020, 12:42 | #193 (permalink) | |
- Install REQUIRED Card-Reader Drivers - https://www.infinity-box.com/support/?r=6 File with Drivers: CardReader_Fetian_FT2K.7z File with Instruction: Infinity-Box_How_to_update_FT_SCR2000_CardReader_drivers.pd f Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202 - Run Infinity DongleManager - Update Dongle firmware Alternative method: - Insert Infinity Smart-Card into another Card-Reader (f.e. another dongle or box). Good result for today gives Alcor Card-Reader. - Run Infinity DongleManager - Update Dongle firmware In case of problem DO NOT update card again but contact to support ! More info is here - https://www.infinity-box.com/support/?r=100129 | |
12-23-2020, 15:58 | #194 (permalink) | |
Member: 50805 Status: Offline Thanks Meter: 101 | Quote:
driver version 2.5.9.1202 === DongleManager [Infinity] v1.80 [23-12-2020 20:26:51] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: FT SCR2000 0 HWID: 0102A6621C6A1292 === Process started: 23-12-2020 20:26:51 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Write to https://www.infinity-box.com/support/?r=2 | |
