Old 11-13-2017, 07:33   #2491 (permalink)
Member: 2778005
Originally Posted by YellowBoss View Post
Should we reply in this thread or in your other thread ?
Hi, sorry for that.
Here is fine
=== DongleManager [Infinity] v1.70 [11/12/2017 14:14:41] ===
Box/Dongle type selected: Infinity-Box/Dongle
Card-Reader: Generic EMV Smartcard Reader 0
HWID: 000047160E1D4082
Box/Dongle found: Infinity-Box/Dongle
Reading...
Serial No (S/N): B7FC4716
Firmware version: 0136.02
=== Process started: 11/12/2017 14:14:42 ===
Connecting to server
Server connection successfully established
Checking DongleManager version...
Your DongleManager is up-to-date
Checking Dongle Identification...
Authenticating on server...
Authentication stage error:
Server answer:[0031] Dongle identification data damaged.
Old 11-13-2017, 08:37   #2492 (permalink)
Member: 199814
Thanks Meter: 1,960
=== DongleManager [Infinity] v1.70 [13/11/2017 12:35:16] ===
Card-Reader: Gemalto e-gate Smart Card 0
HWID: 0001DA1B00001942
=== Process started: 13/11/2017 12:35:16 ===
Server answer:[0010] Dongle Authentication fail.
Probably last attempt was interrupted or wrong Smart-Card connected.
Contact to http://www.infinity-box.com/support/?r=2
this is error my friend facing can i get help
Old 11-13-2017, 14:08   #2493 (permalink)
Member: 2285351
Sonork: ali sarwar 200
Thanks Meter: 2
team i need your help
Box/Dongle type selected: [BEST]
HWID: 0101878220281292
Box/Dongle found: [BEST]
Reading...
Serial No (S/N): ED8E8782
Firmware version: 0122.02
=== Process started: 11/13/2017 18:05:23 ===
Old 11-13-2017, 14:30   #2494 (permalink)
hassan1975's Avatar
Member: 28819
Thanks Meter: 222
HELLO
plz check
=== DongleManager [Infinity] v1.70 [11/13/2017 15:29:12] ===
Card-Reader: FT SCR2000 0
HWID: 0005957918201292
=== Process started: 11/13/2017 15:29:13 ===
thx
Old 11-13-2017, 15:54   #2495 (permalink)
Member: 70906
Thanks Meter: 4
hi
=== DongleManager [Infinity] v1.70 [11/13/2017 16:01:52] ===
Card-Reader: Alcor Micro USB Smart Card Reader 0
HWID: 0000226B11384082
Reading...
Serial No (S/N): A8A7226B
=== Process started: 11/13/2017 16:01:53 ===
Old 11-13-2017, 16:10   #2496 (permalink)
Member: 1043909
Thanks Meter: 60,926
Originally Posted by Celle Tester View Post
Hi, sorry for that.
Here is fine
Reading...
What was the reason to trace USB communication ?
Old 11-13-2017, 16:11   #2497 (permalink)
Member: 1043909
Update dongle firmware now.
Old 11-13-2017, 16:13   #2498 (permalink)
Member: 1043909
Reading...
Why do you use debugger and other crack tools with Infinity software ?
Old 11-13-2017, 16:14   #2499 (permalink)
Member: 1043909
Originally Posted by hassan1975 View Post
HELLO
plz check
thx
Hello,
What to do:
1. Install required Card-Reader Drivers:
- File with Drivers: CardReader_Fetian_FT2K.7z
- File with Instruction: Infinity-Box_How_to_update_FT_SCR2000_CardReader_drivers.pd f
Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202
Download files - http://www.infinity-box.com/support/?r=6
OR
1. Insert Smart-Card into another Card-Reader (good result for today is with Alcor Card-Reader)
The next steps are:
2. Run DongleManager
3. Update Dongle firmware
- DO NOT update Smart-Card many times otherwise your account will be locked automatically after 3 tries for 24 hours
- DO NOT use any kind of usb sharing/trace/spy/debug software to avoid problem with Dongle !
The Following User Says Thank You to YellowBoss For This Useful Post:
Old 11-13-2017, 18:17   #2500 (permalink)
Member: 2285351
Thanks Meter: 2
may be cause by pc sharing
may be cause by pc sharing i,m not you any crack
Old 11-13-2017, 18:22   #2501 (permalink)
Member: 2285351
Thanks Meter: 2
i.m not use any crack or debugger may be cause by pc sharing team plz solve my problm
Old 11-13-2017, 19:49   #2502 (permalink)
Member: 148515
Thanks Meter: 19,534
it was not a sharing.
Old 11-13-2017, 22:23   #2503 (permalink)
helpo's Avatar
Member: 2175357
Sonork: QQ:2157039171
Thanks Meter: 453
To avoid this problem
What debugger ,?
And i have crack tools
Should i don't open .It . in the same time
Sent from my SM-G530H using Tapatalk
Old 11-14-2017, 09:44   #2504 (permalink)
Member: 1043909
What debugger ,?
It's always good idea to avoid usage of crack tools to avoid problems for your PC and other software
Old 11-14-2017, 13:30   #2505 (permalink)
Member: 2778005
had no USB trace communication. What is it?
sorry for the dump question.
Page generated in 0.29202 seconds with 9 queries
