11-13-2017, 07:33 | #2491 (permalink) |
Junior Member Join Date: Nov 2017
Member: 2778005 Status: Offline Thanks Meter: 0 | Here is fine === DongleManager [Infinity] v1.70 [11/12/2017 14:14:41] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Generic EMV Smartcard Reader 0 HWID: 000047160E1D4082 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): B7FC4716 Firmware version: 0136.02 === Process started: 11/12/2017 14:14:42 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Last edited by Celle Tester; 11-13-2017 at 07:39. |
11-13-2017, 08:37 | #2492 (permalink) |
No Life Poster Join Date: Nov 2005 Location: Sindhu Desh Age: 36
Member: 199814 Status: Offline Thanks Meter: 1,960 | === DongleManager [Infinity] v1.70 [13/11/2017 12:35:16] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Gemalto e-gate Smart Card 0 HWID: 0001DA1B00001942 === Process started: 13/11/2017 12:35:16 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to http://www.infinity-box.com/support/?r=2 this is error my friend facing can i get help |
11-13-2017, 14:08 | #2493 (permalink) |
Insane Poster Join Date: Nov 2014 Location: PAKISTAN LAHORE Age: 27
Member: 2285351 Status: Offline Sonork: ali sarwar 200 Thanks Meter: 2 | team i need your help Box/Dongle type selected: [BEST] Card-Reader: Generic EMV Smartcard Reader 0 HWID: 0101878220281292 Box/Dongle found: [BEST] Reading... Serial No (S/N): ED8E8782 Firmware version: 0122.02 === Process started: 11/13/2017 18:05:23 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Contact to http://www.infinity-box.com/support/?r=2 |
11-13-2017, 14:30 | #2494 (permalink) |
No Life Poster Join Date: May 2003
Member: 28819 Status: Offline Thanks Meter: 222 | HELLO plz check === DongleManager [Infinity] v1.70 [11/13/2017 15:29:12] === Box/Dongle type selected: [BEST] Card-Reader: FT SCR2000 0 HWID: 0005957918201292 === Process started: 11/13/2017 15:29:13 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to http://www.infinity-box.com/support/?r=2 thx |
11-13-2017, 15:54 | #2495 (permalink) |
Major Poster Join Date: Jun 2004 Age: 43
Member: 70906 Status: Offline Thanks Meter: 4 | hi === DongleManager [Infinity] v1.70 [11/13/2017 16:01:52] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 0000226B11384082 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): A8A7226B Firmware version: 0136.02 === Process started: 11/13/2017 16:01:53 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Contact to http://www.infinity-box.com/support/?r=2 |
11-13-2017, 16:10 | #2496 (permalink) | |
11-13-2017, 16:11 | #2497 (permalink) | |
11-13-2017, 16:13 | #2498 (permalink) | |
11-13-2017, 16:14 | #2499 (permalink) | |
What to do: 1. Install required Card-Reader Drivers: - File with Drivers: CardReader_Fetian_FT2K.7z - File with Instruction: Infinity-Box_How_to_update_FT_SCR2000_CardReader_drivers.pd f Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202 Download files - http://www.infinity-box.com/support/?r=6 OR 1. Insert Smart-Card into another Card-Reader (good result for today is with Alcor Card-Reader) The next steps are: 2. Run DongleManager 3. Update Dongle firmware - DO NOT update Smart-Card many times otherwise your account will be locked automatically after 3 tries for 24 hours - DO NOT use any kind of usb sharing/trace/spy/debug software to avoid problem with Dongle ! | |
