Old 11-13-2016, 13:11   #37501 (permalink)
Luckey1's Avatar
Member: 2197212
Sonork: N/A
Thanks Meter: 680
Qmobile L7 Flashing Done .
Operation : Flash [ v1.23 ]
======= Flash
Files set for flashing :
[ MCU ] : SPD6531_00400000_W25Q32_English__Qmobile-L7.bin
1. Remove battery. Insert USB cable
2. Press and hold BootKey ( Skip, if use BootCable )
3. Insert battery
 ====  Wait for phone...
Phone found! [ 47 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending boot ...
Boot Sent , starting...
Boot Ver : Spreadtrum Boot Block version 1.2 ¿B ðBoot Ok
CPU ID : 6531 , FDLStat : 0100
[0] Flash DIE : 00EF 0040 0016 0000
[0] Flash VEN : Winbond , W25Q32
[0] Flash CAP : 00400000
======= Flashing MCU
Mapping file ...
Mapping done
Processing file : SPD6531_00400000_W25Q32_English__Qmobile-L7.bin
Init ok, send data
Flashing Done!
Info : In some cases after flash required make "Format Fs / Reset Phone"
Done!
Elapsed: 00:01:05
Reconnect Power/Cable!
Old 11-13-2016, 13:30   #37502 (permalink)
Luckey1's Avatar
Member: 2197212
Sonork: N/A
Thanks Meter: 680
Qmobile Noie i5 flashing done
Scatter Load Ok , BaseBand : MT6582 , Project : s4700 , Storage : EMMC
Files found : 13 , Set to Flash : 12
Ready to Flash!
Operation : Flash [ v1.58 ]
======= Flash
Wait for phone...
Phone found! [ 62 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BB_CPU_NME : [MediaTek] MT6582_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x87
NAND Flash : NOT INSTALLED
eMMC Flash : 11010030303447393051DA996B77515B
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x11 , OEM : 0100
[eMMC] : FLASH_INF : [TOSHIBA] , 09G40
[eMMC] : FLASH_CID : 11010030303447393051DA996B77515B
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000
[eMMC] : FLASH_LEN : 0x00000000EC000000
[eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB]
DEV RID    : 0xE6C52A7DF36005564C2CE216A034FBC3
INT RAM    : 0x00020000
EXT RAM    : 0x20000000 [512 MiB]
BOOT TYPE  : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6582 , Project : s4700 , Storage : EMMC
Setting : AFF verify :  Disabled
Setting : HW verify :  Enabled
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : BatteryLevel : Unknown (not supported or without battery)
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000001400000-0x0000000000100000
Erase : 0x0000000003100000-0x00000000E5600000
Flash Pre-Erase Done, time used : 00:00:00
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_s4700.bin
Preloader Sent , Init passed
PartCount : 0014
Update PMT by user request
Repartition Done!
Use FLN Mode
Processing : Flash Write
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : EBR2
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash now : FAT
Image Flash Ok
Flash Write Done, time used : 00:03:00
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:03:21
Old 11-13-2016, 13:32   #37503 (permalink)
Luckey1's Avatar
Member: 2197212
Sonork: N/A
Thanks Meter: 680
Samsung g530f flashing done
======= Flash
Wait for phone...
Phone found! [ 55 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x88
eMMC Flash : 90014A483447316404860CA23AD470A7
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , d1G4
[eMMC] : FLASH_CID : 90014A483447316404860CA23AD470A7
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000
[eMMC] : FLASH_LEN : 0x00000000E7000000
[eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB]
DEV RID    : 0xE6C52A7DBCDFF4254D2F4F73A0FA97D0
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6572 , Project : mbk72_wet_jb3 , Storage : EMMC
BL : BatteryLevel : 3951 mV
BL : BatteryLevel Ok
Erase : 0x0000000000C00000-0x0000000000100000
Erase : 0x0000000002900000-0x00000000E2700000
Flash Pre-Erase Done, time used : 00:00:03
Use : preloader_mbk72_wet_jb3.bin
PartCount : 0013
Repartition Done!
Use FLN Mode
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash Write Done, time used : 00:01:52
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:02:11
Old 11-13-2016, 13:50   #37504 (permalink)
syed tuqeer's Avatar
Member: 654997
Sonork: 1613804(Don't Spam Plz)
Thanks Meter: 4,073
QMobile W50 Format / Repair Done :)
Operation : Check/Read Info [ v1.23 ]
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
3. Insert cable
Phone found! [ 10 ]
Port Opened
Sync...
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SC773x Android 5.x eMMC v1.0 Inf
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FLASH : eMMC Flash , Structure : Ok!
Reading extended info ...
Model Name  : sp7731geahdplusoversea
Model Brand : QMobile
Model Device: scx35_sp7731gea_hd
AndrVersion : 5.1
BaseBand CPU: SP7731GEA_HD
CompileDate : 11/2/2015 2:55:57 AM
Project Ver : QMobileW50_MP_10_30
Model Ext   : QMobile W50
ExtraInfo : HWInfo not exists, normal phone
Elapsed: 00:00:25
Operation : Format File System / Reset Settings [ v1.23 ]
Settings : SmartFormat is On
3. Insert cable
Phone found! [ 10 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Boot Ver : SPRD 773x eMMC loader v3 Infinity
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Checking Structure ...
Detected eMMC Flash , Structure detect Ok!
eMMC phone detected! Will use 'Safe Format' mode!
UserData : PART_MOUNT failed! Part Damaged! Will use Repair Mode!
Mount : /cache
State : 0x0001
Prepare Ok! Format Ok!
Don't touch phone, until it fully bootup to "Welcome Screen"!
Done!
Elapsed: 00:00:29
Old 11-13-2016, 17:09   #37505 (permalink)
UMeR3's Avatar
Member: 2451476
Sonork: 100.1669164
Thanks Meter: 345
qmobile a300 hang on logo cruppt files done by cm2
HERE IS LOGS::
======= Flash
[ MCU ] : MTK6572_1403021306.bin
Wait for phone...
Phone found! [ 31 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_EXT : 0xCA01 , 0x8C00 , 0x0000
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 90014A4834473164048600A328A511B7
[eMMC] : FLASH_CID : 90014A4834473164048600A328A511B7
DEV RID    : 0xB4A11DC7D1E7B66F5AFDA1953E79A778
SOC VERIFY : C1
Boot Ok!
Brand     : QMobile
ProdName  : A300
ProdModel : QMobile A300
Device    : QMobile A300
AndroidVer: 4.2.2
MTKxCPU   : MT6572
MTKxPRJ   : ALPS.JB3.MP.V1.P65
ISPFF  ID : 6572 , TARGET ID : 6572
FlashFile is differs from eMMC settings, continue by user request
Flash pre-erase enabled
Erase Flash now ...
Flash pre-erase done
Write Flash now ...
Init Ok , Sending blocks ...
Write done , 2561 blocks sent
Done!
Elapsed: 00:07:42
::GREAT TOOl::
::GREAT POWER::
::GREAT MULTI TOOL::
REGARDS BY
KHOKHARX
Old 11-13-2016, 17:10   #37506 (permalink)
ajmobilesshop's Avatar
Member: 2602390
Thanks Meter: 106
Rivo pz8 ride done ...
RIVO PZ8 RIDE DONE ...
Nice CM2 GRIT.. TEAM.....
Her...
http://i.prntscr.com/738cb83dfc71478...b001e01ad0.png
Ajmobileshop
.................................................. ..KHURRAM AJ..
Old 11-13-2016, 18:41   #37507 (permalink)
Member: 2265797
Sonork: 100.1646791
Thanks Meter: 119
Qmobile w70 frp done by tahir shan
Wait for phone...
Phone found! [ 28 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x94
eMMC Flash : 150100463732324D42007689E4F443DF
[eMMC] : FLASH_INF : [SAMSUNG] , BM227
[eMMC] : FLASH_CID : 150100463732324D42007689E4F443DF
[eMMC] : FLASH_LEN : 0x00000001D2000000
[eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
DEV RID : 0xB6D8A17E73E2A3E24523DA40018A3B3B
EXT RAM : 0x40000000 [1 GiB]
SOC VERIFY : C1
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Done!
Elapsed: 00:00:12
BEST CM2
The Following User Says Thank You to tahirshan77 For This Useful Post:
Old 11-14-2016, 01:53   #37508 (permalink)
Member: 2082450
Thanks Meter: 1,454
Arrow GiONEE P5 Mini {MT6580} FRP DOne
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 7 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 150100463732324D420033C0C20733DF
[eMMC] : FLASH_CID : 150100463732324D420033C0C20733DF
DEV RID : 0xB5B9A19580D240D10B3F28D85D5CEED9
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Done!
Elapsed: 00:00:15
The Following User Says Thank You to chandanps18 For This Useful Post:
Old 11-14-2016, 01:57   #37509 (permalink)
Member: 2082450
Thanks Meter: 1,454
Arrow Sansui U52 {sp7731g} Read Flash done
Operation : Read FullFlash [ v1.24 ]
3. Insert cable
Phone found! [ 12 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
[FW_READER] : Prepare Ok!
- > Wait phone connected ...
Phone found! [ 12 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
Phone found! [ 12 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
Model Name : scx35_sp7731gea_lmcuccspecBplus_UUI_dt
Model Brand : Spreadtrum
Model Device: scx35_sp7731gea_lm
AndrVersion : 4.4.2
BaseBand CPU: SP7731GEA_LM
Project Ver : SANSUI_U52_V0.6_20150630
Model Ext : U52
[Read Mode] : HSUSB : 0x3000
[FW_READER] : Reading Firmware Now ...
[Read Ok] : u-boot-spl-16k.bin
[Read Ok] : u-boot.bin
[Read Ok] : prodnv.img
[Read Ok] : sc7731g_CP0_modem.bin
[Read Ok] : DSP_DM_Gx.bin
[Read Ok] : nvitem_w.bin
[Read Ok] : sc7731g_modem_CP2_WCN_14E_W15.16_Release.bin
[Read Ok] : nvitem_wcn.bin
[Read Ok] : logo_480x854.bin
[Read Ok] : fblogo_480x854.bin
[Read Ok] : boot.img
[Read Ok] : system.img
[Build Ok] : cache.img
[Read Ok] : recovery.img
[Build Ok] : userdata.img
AndroidInfo created
Firmware Size : 1062 MiB
Saved to : C:\Users\Chandan\Desktop\SP7731GEA_LM_scx35_sp7731 gea_lm_4.4.2_SANSUI_U52_V0.6_20150630_U52\
Done!
Elapsed: 00:04:07
Old 11-14-2016, 02:01   #37510 (permalink)
Member: 2082450
Thanks Meter: 1,454
Arrow Micromax Q336 dead, flash done
Operation : Check/Read Info [ v1.24 ]
3. Insert cable
Phone found! [ 12 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Boot Ver : SC7730/7731 eMMC Loader v1.1 Inf
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
Model Name  : Q336
Model Brand : Micromax
Model Device: Q336
AndrVersion : 4.4.2
CompileDate : 5/30/2015 12:21:19 PM
Project Ver : MMX_Q336_SW_V8.0.7_HW_V1.0.0_300515
Model Ext   : Micromax Q336
Elapsed: 00:00:15
Operation : Flash [ v1.24 ]
======= Flash
[ MCU ] : SC77xx Infinity Package
3. Insert cable
Phone found! [ 12 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
PMTManager : Load 0x18 records
PMTManager : PMT Update Ok!
Flashing now
Update BootCode : u-boot-spl-16k.bin
Write Data ...
Write Data Ok!
Update BootCode : u-boot.bin
Erase block ...
Block erase Ok!
Write Data ...
Write Data Ok!
Write FSImage : prodnv.img
Write Data ...
Write Data Ok!
Write CodeData : sc7731g_CP0_modem.bin
Write Data ...
Write Data Ok!
Write CodeData : DSP_DM_Gx.bin
Write Data ...
Write Data Ok!
Erase Block : RuntimeData
Erase block ...
Block erase Ok!
Write CodeData : sc7731g_modem_CP2_WCN_14E_W15.19_Release.bin
Write Data ...
Write Data Ok!
Erase block ...
Block erase Ok!
Write CodeData : logo_480x854.bin
Write Data ...
Write Data Ok!
Write CodeData : boot.img
Write Data ...
Write Data Ok!
Write FSImage : system.img
Write Data ...
Write Data Ok!
Write FSImage : cache.img
Write Data ...
FSImage : Make and Flush SPImage
Write Data Ok!
Write CodeData : recovery.img
Write Data ...
Write Data Ok!
Process : Flush
Flush Ok!
Write FSImage : userdata.img
Write Data ...
Write Data Ok!
Erase Block : INTERNALSD
Erase block ...
Block erase Ok!
Elapsed: 00:13:47
Old 11-14-2016, 02:21   #37511 (permalink)
Member: 2082450
Thanks Meter: 1,454
Arrow Iball Andi format done
Iball Andi hang on logo solved by format by Great tool CM2
3. Insert cable
Phone found! [ 12 ]
Port Opened
Sync...
Sync...
Sending FDL
PickUp loaders from pac
FDL Ready!
Boot Ver : Spreadtrum Boot Block version 1.1
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
Model Name  : v211_ytk_231
Model Brand : iBall
Model Device: v211_ytk_231
AndrVersion : 4.4.2
BaseBand CPU: V211_YTK_231
CompileDate : 9/11/2015 12:27:54 PM
Project Ver : KOT49H 14B_test-keys
Model Ext   : Andi 4.5 O'Buddy
Elapsed: 00:00:25
Operation : Format File System / Reset Settings [ v1.24 ]
3. Insert cable
Phone found! [ 12 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Done!
Elapsed: 00:00:48
Old 11-14-2016, 05:23   #37512 (permalink)
azhergoga007's Avatar
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,368
Dany Tab GIII MT6577 Recover Done OnlyFormate By Infinity CM2
FORMATE..
Stay Tune!
More Developing!!
More coming!!!
Bro
AZHERGOGA007
The Following User Says Thank You to azhergoga007 For This Useful Post:
Old 11-14-2016, 05:35   #37513 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 1,792
Old 11-14-2016, 05:36   #37514 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 1,792
Old 11-14-2016, 05:42   #37515 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,368
Qmobile Barr Phone E9 MT6260 Read Coad Done By Great Infinity CM2
Read Coad ...
Stay Tune!
More Developing!!
More coming!!!
Bro
AZHERGOGA007
The Following 2 Users Say Thank You to azhergoga007 For This Useful Post:
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
Page generated in 0.50877 seconds with 11 queries
