Old 12-20-2021, 07:40   #69046 (permalink)
Akhtar Ali Jatt's Avatar
Member: 953334
Sonork: 100.1614005
Thanks Meter: 15,424
Smile QMobile XLi
Operation : Format FS / Reset Settings [ v2.14 ]
Mode : Reset FRP
BootMode : FLASH
1. Power off device, wait 10-15 seconds
2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- )
3. Insert cable in device!
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : INF : Qmobile : QMobile XLi
Sending Init Boot ...
Boot sent!
Kick FDL ...
BootVersion : Spreadtrum Boot Block version 1.1
Protocol setup ...
Port speed : 921600
Sending Flash Boot ...
Boot sent!
Kick FLASH FDL ...
FDL : 0x0002
FDL : Control transfered!
Boot Done!
Wipe Ok : FRP
Reconnect Power/Cable!
Done!
Elapsed: 00:00:27
Old 12-20-2021, 08:38   #69047 (permalink)
Member: 1537135
Thanks Meter: 1,021
ITEL A33 FRP lock is successfully reseted Infinity Box 🌄
Card found : C1B4DF65 , v0151
Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14
Load IDBase v8331 Ok!
Operation : Identify [ v2.14 ]
BootMode : FLASH
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_RS
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
FDL : 0x0002
Boot Done!
Device info :
Patch Level : OPM2.171019.012
Display ID : W5001P-F3102-8.1-OP-V064-20200611
Ver. Incmt : OP-V064-20200611
Ver. CodeName : REL
Ver. Release : 8.1.0
Sec. Patch : 2020-06-05
Build Time : 11.06.2020
Product Model : itel W5001P
Product Brand : Itel
Product Name : F3102
Product Device : itel-W5001P
Product Manfct : itel
Product Info : F3102
Product Board : itel-W5001P
Board Platform : sp7731e
Platform Version: MOCORTM_17C_W18.31.2_P27_Debug
Project Version: pike2_pub
BASE Version: FM_BASE_17C_W18.31.2_P27
HW Version: sc7731e_modem
CMP_Time : 01-16-2020 20:28:37
MODEM TAG : MOCORTM_17C_W18.31.2_P27_Debug_FM_BASE_17C_W18.31. 2_P27_sc7731e_modem_pike2_pub
USERDATA : FILESYSTEM : F2FS with FDE ( Full Disk Encryption ***)
- > INFO : Remove cable from device to switch it off!
Done!
Elapsed: 00:01:40
Mode : Reset FRP
BootMode : FLASH
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
FDL : 0x0002
Boot Done!
Wipe Ok : FRP
Done!
Elapsed: 00:00:15
The Following 3 Users Say Thank You to naveedullah0044 For This Useful Post:
Old 12-20-2021, 10:31   #69048 (permalink)
Member: 2573997
Thanks Meter: 109
Talking huawei dua l22 imei repair succes flash mode
one click by selecting firefly platform
log:
Operation : Repair Security [ v2.31 ]
Mode : FLASH
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek USB Port_V1632 (COM14)
MODE : BOOTROM
PORT : 14
Waiting BOOT ack ...
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002
CODE : Zion
TYPE : MODERN [RAPHAEL]
BROM : MEID : B425593E50F97C5626C49B3D5B0C0C35
BROM : SecLevel : 0x000000E3
BROM : SecMode : SBC+SLA+EXT
BROM : BROM|BL : 0x05|0xFE
BROM : BOOTROM
BROM : SOCID : A368984F3A5598DB7AB247879D234328D564F43C6671CF0085 95BF4A32ECF04C
BROM : Sending FireFly
FireFly : Starting ...
FireFly : Init Core
FireFly : Core init done!
FireFly : Running : v04.04.04 on MT6739
FireFly : eMMC init passed!
EMMC: CSD : D02701328F5903FFFFFFFFE78A400017
EMMC: CSD : TEMP_WRITE_PROTECT: False
EMMC: CSD : PERM_WRITE_PROTECT: False
EMMC: CID : 90014A484147346132D4008255155737
EMMC: VEN : HYNIX : OEM : 74 : ID : 484147346132
EMMC: VEN : HYNIX : HAG4a2
EMMC: SNN : 8541461 ( 0x00825515) , MF : 5/2020
EMMC: EXTCSD : rev1.8 ( eMMC 5.1 )
EMMC: EXTCSD [BOOT_BUS_WIDTH] : 0x00
EMMC: EXTCSD [PARTITION_CONFIG] : 0x48
EMMC: EXTCSD [SIZE] : Market : 16 GB
EMMC: EXTCSD [SIZE] : Actual : 0x3AB400000 [ 14.68 GB ]
EMMC: EXTCSD [EOL] : EOL status : Normal ( Less than 80% reserved blocks used )
EMMC: EXTCSD [EOL_A] : SLC status : 0% - 10% used
EMMC: EXTCSD [EOL_B] : MLC status : 0% - 10% used
EMMC:
BOOT1 : 0x00400000 [ 4.00 MB ]
BOOT2 : 0x00400000 [ 4.00 MB ]
USER : 0x3AB400000 [ 14.68 GB ]
DA : USB : HIGH-SPEED
Boot done!
NVRAM : 0xB30ABE18
NVRAM : State : Ok!
INFO : WiFi MAC : 10327E6A8DB1
INFO : BlTh MAC : 10327E6E5E41
INFO : IMEI[1] : 86................427
INFO : IMEI[2] : 86................426
INFO : set IMEI[1] : 35...............060
INFO : set IMEI[2] : 35.................21
Update NVRAM ...
Update dependencies ...
Done!
Elapsed: 00:00:54
The Following User Says Thank You to Mudasir Ali For This Useful Post:
Old 12-20-2021, 10:55   #69049 (permalink)
Member: 2125922
Sonork: 1601402
Thanks Meter: 112
Samsung A10s A107f u8 frp remove done cm2
Samsung A10S A107FFrp remove done via cm2 no need test point
                        just plug cable or reset smart extra
PTFN : MediaTek PreLoader USB VCOM (Android) (COM29)
MODE : PRELOADER PORT
PORT : 29
PRELOADER : ACK confirmed!
BROM : Init BROM
BROM init passed!
     CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
     CODE : Cervino
BROM : SecLevel : 0x00000005
BROM : SecMode  : SBC+SDA
BROM : BROM|BL  : 0xFF|0x03
BROM : PRELOADER PORT
AGENT : 0_base : BASE_v2112 | Manual : Disabled
AGENT : Look for suitable BootChain in DA ...
AGENT : MTK_AllInOne_DA.bin
AGENT : Found MT6765
AGENT : MTK_DOWNLOAD_AGENT
     BROM : Sending 1st DA ...
     BROM : Reset Interface!
PTFN : MediaTek USB Port (COM36)
MODE : BOOTROM
PORT : 36
BROM : Init BROM
BROM init passed!
     CODE : Cervino
BROM : MEID : C44EE216EDEB8122F6B42542621653E7
BROM : SecLevel : 0x000000E5
BROM : SecMode  : SBC+SDA+EXT
BROM : BOOTROM
BROM : SOCID : 229F71D6D69143C6FE933BCC4D6F58A4B3BFDC2BC77D3F6BFAD0843DCD2FDB38
BROM : SLA : Local Auth
BROM : SLA : Starting Auth
BROM : FF : Look for EMI
BROM : FF : EMI found!
BROM : SLA : Auth Passed!
BROM : SEC : 0x000000E0
BROM : DA sent
BROM :Transfer control to DA ...
     DA : AGENT started!
DA : SYNC
     DA : MODE : BROM
DA : EXT_RAM NOT initialized!
     EMI : DEV : FireFly
     EMI : SRC : preloader_s96116ra1.bin
     EMI : CNT : 0008
     EMI : Init EMI from INTERNAL DB
     EMI : EXT_RAM CFG Passed!
DA : BOOT to 2nd DA ...
DA : 2ND stage confirmed!
DA : SYNC with DA passed!
DA : Receiving HW info
        SRAM: 0x0003A000 [ 232.00 KB ]
        DRAM: 0x80000000 [ 2.00 GB ]
        EMMC: CID : 150100515836334D42006669D0A857AD
        EMMC: VEN : SAMSUNG : OEM : 0 : ID : 515836334D42
        EMMC: VEN : SAMSUNG : QX63MB
        EMMC: SNN : 1718210728 ( 0x6669D0A8) , MF : 5/2020
        EMMC:
              RPMB   : 0x01000000 [ 16.00 MB ]
              USER   : 0x747C00000 [ 29.12 GB ]
        CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000
        RNID : A7133596CBFC25DA3888C00C15D9252B
Boot done!
Product Brand  : samsung
Product Device : a10s
Product Model  : SM-A107F
Product Name   : a10sxx
Patch Level    : RP1A.200720.012
Display ID     : RP1A.200720.012.A107FXXU8CUI2
Build Time     : 15.09.2021
Ver. CodeName  : REL
Ver. Release   : 11
Sec. Patch     : 2021-09-01
Product Info   : a10s
Product Board  : S96116RA1
Board Platform : mt6765
Product Manfct : samsung
NVRAM : TITAN_S1_Q0MP1_K62V1_64_BSP_MDBIN_PCB01_MT6765_S00.MOLY_LR12A_R3_TC10_PR1_SP_V4_P43
NVRAM : 0xBC0AD96C
NVRAM : State : Ok!
NVRAM : SecLv : Vendor Signed
INFO  : WiFi MAC : 1089FBE4375E
INFO  : BlTh MAC : 1089FBE4375F
INFO  : IMEI[1] : 54C11C6BFA5ABE4
INFO  : IMEI[2] : 76F80CEB1267588
STORAGE : Life Status : eMMC : OK!
STORAGE : OTP Status : NOT Enabled!
Done!
Elapsed: 00:00:39
Operation : Reset Settings/Format FS [ v2.31 ]
Mode : SMART RESET EXTRA
PORT : 29
BROM : Init BROM
BROM init passed!
     CODE : Cervino
MODE : BOOTROM
PORT : 36
BROM : Init BROM
BROM init passed!
     CODE : Cervino
BROM : BOOTROM
BROM : DA sent
     DA : AGENT started!
DA : SYNC
     DA : MODE : BROM
     EMI : DEV : FireFly
     EMI : CNT : 0008
        EMMC:
Boot done!
SmartInfo : 0x835757
Format Ok : RESET PROTECTION
Format Ok : USERDATA
Format Ok : CACHE
Format Ok : Vendor Extra
Done!
Elapsed: 00:00:40
Old 12-20-2021, 11:50   #69050 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,773
Vgotel i515 hang on logo done by cm2
Card found : S/N : 73CA70CC , v0151
Load File
File_Info : FISE61D_11C_PCB01_gprs_MT6261_S00.MAUI_11C_W13_52_ MP_V2_F45.bin
FileVersion : MAUI.11C.W13.52.MP.V2.F45
Load File Ok
Operation : Flash [ v1.58 ]
======= Flash
Files set for flashing :
[ MCU ] : FISE61D_11C_PCB01_GPRS_MT6261_S00.MAUI_11C_W13_52_ MP_V2_F45.BIN.bin
2. Insert USB cable. In some cases require hold BootKey ( '*' )
Wait for phone...
Phone found! [ 6 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CA02
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6261_S0000
BB_CPU_SN : 54FFE30F4AB02070696AAAE82F72DC15
BROM Protocol Version : 05
Setting...
Setting done , result code 0x000E
BROM stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x0112 , [MXIC] MX25L3291FWJI_09
[0] : FLASH_DIE : 00C2 0020 0016 0000
[0] : FLASH_LEN : 0x00400000
SDS_INFO : 0x003FE000 , 0x00002000
INT_RAM : 0x0000D000
EXT_RAM : 0x00400000
Flash now
Erase region , wait ...
Write data , wait ...
Write : FISE61D_11C_PCB01_GPRS_MT6261_S00.MAUI_11C_W13_52_ MP_V2_F45.BIN.bin
Done!
Elapsed: 00:00:45
Old 12-20-2021, 11:53   #69051 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,773
Vivo a11k reset pattern done by cm2
Card found : 73CA70CC , v0151
Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.31
Load IDBase v1121431 Ok!
Update configuration ...
Mode : SMART RESET
PTFN : MediaTek USB Port (COM16)
MODE : BOOTROM
PORT : 16
BROM : Init BROM
BROM init passed!
CODE : Cervino
BROM : MEID : 8616C5029B9C7C6807FBB534197F71B9
BROM : BOOTROM
BROM : SOCID : 7F8BE9CBC013C8A9749BAE368E37E724C0B1781C81FA3C29A3 2A16EF1625982A
BROM : SLA : Auth Started!
BROM : SLA : 0x0000001F
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMI : DEV : FireFly
EMI : SRC : preloader_oppo6765_19451.bin
EMI : CNT : 000A
EMMC: CID : 90014A68423861503E035A52909127DF
EMMC: VEN : HYNIX : OEM : 74 : ID : 68423861503E
EMMC: VEN : HYNIX : hB8aP>
EMMC: SNN : 1515360401 ( 0x5A529091) , MF : 2/2020
EMMC:
RNID : 82F8AA29BA1974566252E1C6D2699C0
Boot done!
SmartInfo : 0x815757
Format Ok : CACHE
Done!
Elapsed: 00:00:33
Old 12-20-2021, 11:54   #69052 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,773
Itel l6502 remove frp done by cm2
Mode : Reset FRP
BootMode : FLASH
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : INF : Itel : L6502
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
FDL : 0x0008
FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False
FDL : RAW : 0x0002
FDL : FLH : 0x400000
FDL : SEC : RSA auth required!
FDL : Process authentification ...
FDL : SEC : RSA auth passed!
Boot Done!
Wipe Ok : FRP
Done!
Elapsed: 00:00:19
Old 12-20-2021, 11:56   #69053 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,773
Qmobile x30 v3 hang on logo done by cm2
Mode : Default [ Reset Settings + FRP ]
BootMode : FLASH
Wait for device ...
Device Connected!
BootVersion : SPRD3
Sedning Init Boot ...
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Sedning Flash Boot ...
Boot sent!
Kick FLASH FDL ...
Boot Done!
Wipe Ok : UserData
Wipe Ok : Cache
Wipe Ok : FRP
Done!
Elapsed: 00:00:39
Old 12-20-2021, 14:03   #69054 (permalink)
Member: 953334
Sonork: 100.1614005
Smile QMobile i8i PRO
BootMode : FLASH
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : INF : Qmobile : QMobile i8i PRO
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
Boot Done!
Wipe Ok : UserData
Wipe Ok : Cache
Wipe Ok : FRP
Done!
Elapsed: 00:00:23
Old 12-20-2021, 17:23   #69055 (permalink)
tayobjoy1's Avatar
Member: 2965136
Sonork: 58846
Thanks Meter: 1,202
Nokia C10 TA-1342 NetworkUnlock Done
Card found : 46828B86 , v0151
Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.13
Operation : Identify [ v2.13 ]
BootMode : SVC
2. Not hold any key on device ( OLD devices -  1 : VOL+ , 2 : VOL- )
Wait for device ...
Device Connected!
Enter SVC ...
Waiting Device ...
Check SVC ...
SVC : DiagChannel opened!
Boot Done!
SOC GEN : UniSoc ( E-family and Modern )
BuildInfo : Mantis_00WW-user 11 RP1A.201005.001 V1.300_B01 release-keys
MemoryInfo : EMMC :  16 GB  ;  DRAM : 1 GB
Platform Version: MOCORTM_17C_W21.11.2_P3_Debug
BASE  Version:    FM_BASE_17C_W21.11.2_P3
CMP_Time : 05-25-2021 21:34:06
MODEM TAG : MOCORTM_17C_W21.11.2_P3_Debug_FM_BASE_17C_W21.11.2_P3_sc7731e_modem_pike2_pub
PSN1 : E645484181101104
PSN1 : E286655860B81303468
NVMng  : SecurityInfo
IMEI[1] : 357735917424483
IMEI[2] : 357735917424491
WIFIMAC : 44917C1A301B
BT_MAC  : 44917C1A301A
SEC : SLS:2, SKS:0, SKV:4
Done!
Elapsed: 00:00:20
Operation : SP Unlock [ v2.13 ]
BootMode : SVC
Wait for device ...
Device Connected!
Enter SVC ...
Waiting Device ...
Check SVC ...
Boot Done!
SLStatus : 2C
Status : Locked! Server unlock required!
Connecting to server...
Connected
Init...
Init: Ok
Authenticating...
Authenticated
Checking Client version...
Client version Ok
Balance: 45,  price:5
Process...
Process : Operation may took 10-15 minutes!
>>>  Repeat unlock/repair procedure after requested time again!
After Time Requested
BootMode : SVC
Wait for device ...
Device Connected!
Enter SVC ...
Waiting Device ...
Check SVC ...
Boot Done!
SLStatus : 2C
Connected
Init...
Init: Ok
Authenticating...
Authenticated
Client version Ok
Balance: 40,  price:5
Process...
Finished
Unlocking device ...
Sync data ...
Device unlocked!
Done!
Elapsed: 00:00:27
The Following 2 Users Say Thank You to tayobjoy1 For This Useful Post:
Old 12-21-2021, 05:34   #69056 (permalink)
Nadeem Waris's Avatar
Member: 1080718
Sonork: 100.1596539 QQ-2710826805
Thanks Meter: 2,247
Qmobile i8i 2020 formate done
BootMode : FLASH
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
FDL : 0x0002
Boot Done!
Wipe Ok : UserData
Wipe Ok : Cache
Wipe Ok : FRP
Done!
Elapsed: 00:00:19
Old 12-21-2021, 06:08   #69057 (permalink)
Member: 1080718
Thanks Meter: 2,247
Qmobile i8i flash done
Open : SPD_PROG.xml
Reading package ...
Read package finished!
Created by Infinity-Box (c) 2020
Chinese Miracle II : Spreadtrum / UniSoc Service Module
Device Info file : _Android_info.txt
Display ID : OPM2.171019.012 release-keys
Ver. Incmt : 1574120907
Ver. CodeName : REL
Sec. Patch : 2019-12-05
Build Time : 21.12.2019
Product Model : i7i 2020
Product Info : i7i_2020
Product Brand : QSmart
Product Name : i7i_2020
Product Device : i7i_2020
Product Model : i7i2020
Product Manfct : QMobile
Product Board : i7i-2020
SECSolution : MODERN [RS/0S/1S/2S]
Operation : Flash Firmware [ v2.14 ]
Setting : Update NVRAM : False
Setting : Force NVRAM : False
Setting : Update PMT : True
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : INF : INFINITY FW PACKAGE
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
FDL : 0x0002
Boot Done!
PMTMng : Load PMT
PMTMng : 0x20
PMTMng : Update PMT Ok!
Prepare target ...
Prepare Ok!
FSIMG : prodnv.img
CODE : recovery.img
CODE : tos.bin
CODE : tos.bin
CODE : sml.bin
CODE : sml.bin
UBOOT : u-boot.bin
UBOOT : u-boot.bin
CODE : boot_logo.bmp
CODE : fastboot_logo.bmp
FSIMG : persist.img
CODE : gnssmodem.bin
CODE : gnssbdmodem.bin
CODE : modem_wcn.img
CODE : modem_w.bin
CODE : deltanv_w.bin
CODE : gdsp_w.bin
CODE : pm_sys.bin
CODE : boot.img
FSIMG : system.img
FSIMG : cache.img
FSIMG : vendor.img
CODE : vbmeta.img
CODE : vbmeta.img
FSIMG : userdata.img
UBOOT : u-boot-spl.bin
ERASE : MISC
ERASE : UBOOT_LOG
ERASE : FLASH_W
Flashing finished!
Done!
Elapsed: 00:03:35
Old 12-21-2021, 07:45   #69058 (permalink)
Member: 32705
Thanks Meter: 66
Nokia C1
Factory Reset
BootMode : SVC
Wait for device ...
Device Connected!
Enter SVC ...
Waiting Device ...
Check SVC ...
Boot Done!
Wipe Ok : UserData
>>> INFO : FRP reset require FlashMode!
Done!
Elapsed: 00:00:35
Old 12-21-2021, 07:47   #69059 (permalink)
Member: 32705
Thanks Meter: 66
iTel A14
Reset and FRP
BootMode : FLASH
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : INF : Itel : itel A14
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
FDL : 0x0002
Boot Done!
Wipe Ok : UserData
Wipe Ok : Cache
Wipe Ok : FRP
Done!
Elapsed: 00:00:50
Old 12-21-2021, 07:50   #69060 (permalink)
Member: 32705
Thanks Meter: 66
iTel A14
Reset and FRP
BootMode : FLASH
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
FDL : 0x0002
Boot Done!
Wipe Ok : UserData
Wipe Ok : Cache
Wipe Ok : FRP
Done!
Elapsed: 00:00:50
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
Page generated in 0.61180 seconds with 10 queries
