05-23-2022, 12:58 | #71056 (permalink) |
No Life Poster Join Date: Jul 2009 Location: SINDH PAKISTAN
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | Qmobile i5i format done Mode : Reset Settings [ Format FS ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0002 FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Reconnect Power/Cable! Done! Elapsed: 00:00:17 |
05-23-2022, 14:17 | #71057 (permalink) |
No Life Poster Join Date: Sep 2021 Location: Germany
Member: 2996196 Status: Offline Thanks Meter: 632 | Itel a16 plus sa332q white screen fixed by cm2 Open : A16Plus-SA332Q-10-OP-V014-20210831.pac VER : BP_R1.0.0 LEN : 2.26 GiB CPU : sp7731e_1h10 VER : A16Plus-SA332Q-10-OP-V014-20210831 Reading package ... Read package finished! Product Brand : Itel Product Device : itel-A16-Plus Product Model : itel A16 Plus Product Name : SA332Q Patch Level : QP1A.190711.020 Display ID : A16Plus-SA332Q-10-OP-V014-20210831 Ver. Incmt : OP-V014-20210831 Ver. CodeName : REL Ver. Release : 10 Sec. Patch : 2021-09-05 Build Time : 31.08.2021 Product Manfct : ITEL MOBILE LIMITED Product Info : SA332Q Product Board : sp7731e_1h10 Board Platform : sp7731e Operation : Flash Firmware [ v2.14 ] Setting : Update NVRAM : True Setting : Force NVRAM : False Setting : SlowSparse Fix : True Setting : Update PMT : True 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : PAC : A16Plus-SA332Q-10-OP-V014-20210831.pac Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! PMTMng : Load PMT PMTMng : 0x26 PMTMng : Update PMT Ok! NVRM : pike2_pubcp_PLD_base_nv_nvitem.bin NVMng : Load 0x17 NVMng : Init SRC NVMng : SecurityInfo IMEI[1] : 353789876298481 IMEI[2] : 353789876298499 IMEI[3] : 867400020316638 WIFIMAC : FFFFFFFFFFFF BT_MAC : FFFFFFFFFFFF SEC : SLS:0, SKS:0, SKV:4 NVMng : Backup Ok , 0x00066B28 NVMng : Init DST NVMng : Rx11 : Wx10 NVMng : NVM block updated! Prepare target ... Prepare Ok! CODE : PM_pike2_cm4_v2.bin CODE : vbmeta-sign.img FSIMG : odmko.img CODE : gnssmodem.bin FSIMG : userdata.img CODE : SC9600_pike2_pubcp_PLD_base_nv_modem.dat UBOOT : u-boot-spl-16k-sign.bin ERASE : SYSDUMPDB CODE : PIKE2_DM_DSP.bin UBOOT : u-boot-sign.bin ERASE : METADATA CODE : logo.bmp(1) CODE : pike2_cm4.bin ERASE : UBOOT_LOG CODE : boot.img CODE : tos-sign.bin FSIMG : super.img ERASE : MISC FSIMG : socko.img CODE : logo.bmp CODE : gnssbdmodem.bin CODE : pike2_pubcp_PLD_base_nv_deltanv.bin CODE : prodnv.img CODE : vbmeta_system.img FSIMG : persist.img FSIMG : cache.img ERASE : W_RUNTIMENV1 CODE : vbmeta_vendor.img CODE : recovery.img CODE : dtbo.img CODE : sml-sign.bin Flashing finished! Reconnect Power/Cable! Done! Elapsed: 00:02:17 |
The Following User Says Thank You to Jacobkamudyariw For This Useful Post: |
05-23-2022, 14:51 | #71058 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,433 | Vivo y20 Frp Reset DOne Operation : Reset Settings/Format FS [ v2.34 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM16) MODE : PRELOADER PORT PORT : 16 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT AGENT : Vivo : SEC_MT6765 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0x30000000 [ 768.00 MB ] EMMC: CID : 90014A684339615033011059B28BC793 EMMC: VEN : HYNIX : OEM : 74 : ID : 684339615033 : PRV : 0x01 EMMC: VEN : HYNIX : hC9aP3 EMMC: SNN : 274313867 ( 0x1059B28B ) , MF : 12/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 1DA7EA9C794CC2806F5000ABF959E6 DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:15 Reconnect Power/Cable! |
05-23-2022, 18:31 | #71059 (permalink) |
No Life Poster Join Date: Aug 2020 Location: Mozambique Age: 20
Member: 2965136 Status: Offline Sonork: 58846 Thanks Meter: 1,211 | Nokia C10 TA-1342 SP Unlock Done Code: Card found : 46828B86 , v0153 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14 Load IDBase v8331 Ok! Operation : SP Unlock [ v2.14 ] BootMode : SVC 1. Power off device, wait 10-15 seconds 2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! SOC GEN : UniSoc ( E-family and Modern ) BuildInfo : Mantis_00WW-user 11 RP1A.201005.001 V1.370_B01 release-keys Platform Version: MOCORTM_17C_W21.11.2_P4_Debug Project Version: pike2_pub BASE Version: FM_BASE_17C_W21.11.2_P4 HW Version: sc7731e_modem CMP_Time : 08-24-2021 17:58:44 MODEM TAG : MOCORTM_17C_W21.11.2_P4_Debug_FM_BASE_17C_W21.11.2_P4_sc7731e_modem_pike2_pub NVMng : SecurityInfo IMEI[1] : 350951863702700 IMEI[2] : 350951863702718 WIFIMAC : 44917C33A003 BT_MAC : 44917C33A002 SEC : SLS:2, SKS:0, SKV:4 SLStatus : 2C Status : Locked! Server unlock required! Connecting to server... Connected Init... Init: Ok Authenticating... Authenticated Checking Client version... Client version Ok Balance: 15, price:5 Process... Finished Unlocking device ... Sync data ... Device unlocked! Done! Elapsed: 00:00:24 |
The Following 2 Users Say Thank You to tayobjoy1 For This Useful Post: |
05-23-2022, 18:32 | #71060 (permalink) |
Member: 2965136 Status: Offline Sonork: 58846 Thanks Meter: 1,211 | Nokia C20 TA-1352 SP Unlock Done Code: Card found : 46828B86 , v0153 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14 Load IDBase v8331 Ok! Operation : SP Unlock [ v2.14 ] BootMode : SVC 1. Power off device, wait 10-15 seconds 2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! SOC GEN : UniSoc ( E-family and Modern ) BuildInfo : Cosmo_00WW-user 11 RP1A.201005.001 V1.380_B01 release-keys Platform Version: MOCORTM_20A_W21.15.3_P13_Debug Project Version: sharkl3_pub BASE Version: 4G_MODEM_20A_W21.15.3_P13 HW Version: sc9863A_modem CMP_Time : 08-09-2021 10:39:43 MODEM TAG : MOCORTM_20A_W21.15.3_P13_Debug_4G_MODEM_20A_W21.15.3_P13_sc9863A_modem_sharkl3_pub NVMng : SecurityInfo IMEI[1] : 350266783238127 IMEI[2] : 350266783238135 WIFIMAC : 44917C351E4F BT_MAC : 44917C351E4E SEC : SLS:2, SKS:0, SKV:4 SLStatus : 2C Status : Locked! Server unlock required! Connecting to server... Connected Init... Init: Ok Authenticating... Authenticated Checking Client version... Client version Ok Balance: 15, price:5 Process... Finished Unlocking device ... Sync data ... Device unlocked! Done! Elapsed: 00:00:35 |
05-23-2022, 19:03 | #71061 (permalink) |
Member: 2965136 Status: Offline Sonork: 58846 Thanks Meter: 1,211 | Nokia 105 4G TA-1385 SP Unlock Done Code: Card found : 46828B86 , v0153 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14 Load IDBase v8331 Ok! Operation : Identify [ v2.14 ] BootMode : SVC 1. Power off device, wait 10-15 seconds 2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! SOC GEN : UniSoc ( E-family and Modern ) BuildInfo : Platform Version: MOCOR_20A_MP_KN4_W21.30.6_Release Software Version: 13.00.17.01 BASE Version: FM_BASE_20A_THIN_MODEM_KN4_W21.30.6 HW Version: UMS9117 buildtime:08-06-2021 03:48:40 Platform Version: MOCOR_20A_MP_KN4_W21.30.6_Release BASE Version: FM_BASE_20A_THIN_MODEM_KN4_W21.30.6 HW Version: UMS9117 MODEM TAG : MOCOR_20A_MP_KN4_W21.30.6_Release_FM_BASE_20A_THIN_MODEM_KN4_W21.30.6_UMS9117 PSN1 : A918D62LU PSN2 : A918D62LU NVMng : SecurityInfo IMEI[1] : 358530925020004 IMEI[2] : 358530925520003 WIFIMAC : FFFFFFFFFFFF BT_MAC : FFFFFFFFFFFF SEC : SLS:2, SKS:0, SKV:4 Done! Elapsed: 00:00:20 Operation : SP Unlock [ v2.14 ] BootMode : SVC 1. Power off device, wait 10-15 seconds 2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! SOC GEN : UniSoc ( E-family and Modern ) BuildInfo : Platform Version: MOCOR_20A_MP_KN4_W21.30.6_Release Software Version: 13.00.17.01 BASE Version: FM_BASE_20A_THIN_MODEM_KN4_W21.30.6 HW Version: UMS9117 buildtime:08-06-2021 03:48:40 Platform Version: MOCOR_20A_MP_KN4_W21.30.6_Release BASE Version: FM_BASE_20A_THIN_MODEM_KN4_W21.30.6 HW Version: UMS9117 MODEM TAG : MOCOR_20A_MP_KN4_W21.30.6_Release_FM_BASE_20A_THIN_MODEM_KN4_W21.30.6_UMS9117 NVMng : SecurityInfo IMEI[1] : 358530925020004 IMEI[2] : 358530925520003 WIFIMAC : FFFFFFFFFFFF BT_MAC : FFFFFFFFFFFF SEC : SLS:2, SKS:0, SKV:4 SLStatus : 2C Status : Locked! Server unlock required! Connecting to server... Connected Init... Init: Ok Authenticating... Authenticated Checking Client version... Client version Ok Balance: 25, price:5 Process... Finished Unlocking device ... Sync data ... Device unlocked! Done! Elapsed: 00:00:28 |
05-24-2022, 07:07 | #71062 (permalink) |
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | y20 frp remove done Operation : Reset Settings/Format FS [ v2.34 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM5) MODE : BOOTROM PORT : 5 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 42C7E3B724E6EAC8694080324AD7BCBF BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 0A898CF55AC7B15C7184C443A36AEBEC0CBAB9E9F83CB9C06A 691C8F5A9424DC BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : FF : Look for EMI BROM : FF : EMI found! BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMMC: CID : 90014A684339615033011010D0D81825 EMMC: VEN : HYNIX : OEM : 74 : ID : 684339615033 : PRV : 0x01 EMMC: VEN : HYNIX : hC9aP3 EMMC: SNN : 269537496 ( 0x1010D0D8 ) , MF : 1/2021 EMI : DEV : FireFly EMI : SRC : preloader_k65v1_64_bsp.bin EMI : CNT : 0009 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: CID : 90014A684339615033011010D0D81825 EMMC: VEN : HYNIX : OEM : 74 : ID : 684339615033 : PRV : 0x01 EMMC: VEN : HYNIX : hC9aP3 EMMC: SNN : 269537496 ( 0x1010D0D8 ) , MF : 1/2021 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : DBFFD63CEA96FE1B293F8AB171C3AB5 DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:22 Reconnect Power/Cable! |
05-24-2022, 07:47 | #71063 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Dany Monstur 4G Tab SPD98xx FRP/Pattren Reset Done With King Infinity CM2 Code: Card found: S/N : A19EC787 , v0153 Chinese Miracle II [SPD module] v 1.27 Set mode to : SP [SC983x] eMMC [Generic Android 7.x] Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 8 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC983x eMMC Loader v5.0 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x0000000310000000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x/6.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:40 Reconnect Power/Cable! |
05-24-2022, 08:43 | #71064 (permalink) |
Freak Poster Join Date: Sep 2011 Location: Sudan
Member: 1648903 Status: Offline Thanks Meter: 161 | WIKO K510 SP Unlock=Mode META done Operation : SP Unlock [ v2.34 ] Mode : META 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM23) MODE : PRELOADER PORT PORT : 23 Waiting BOOT ack ... PRELOADER : ACK confirmed! INIT : META confirmed! Boot done! AP_CHIP : MT6739 AP_SWTM : Thu Mar 7 16:36:11 HKT 2019 AP_SWVR : alps-mp-p0.mp1-V5.20 MD_CHIP : MT6739 MD_SWVR : TK_MD_BASIC_HW IMEI[1] : 355572109237xxx ID0 : Lock : Locked! | MNC : 768 | CNT : 5 | CODE : 12345678 ID1 : Lock : Not Locked | MNC : 0 | CNT : 5 | CODE : 56781234 ID2 : Lock : Not Locked | MNC : 0 | CNT : 5 | CODE : 11112222 ID3 : Lock : Not Locked | MNC : 0 | CNT : 5 | CODE : 33334444 ID4 : Lock : Not Locked | MNC : 0 | CNT : 5 | CODE : 55556666 ID5 : Lock : Not Locked | MNC : 0 | CNT : 5 | CODE : 77778888 ID6 : Lock : Not Locked | MNC : 0 | CNT : 5 | CODE : 99990000 IMEI[2] : 355572109265xxx ID0 : Lock : Locked! | MNC : 768 | CNT : 5 | CODE : 12345678 ID1 : Lock : Not Locked | MNC : 0 | CNT : 5 | CODE : 56781234 ID2 : Lock : Not Locked | MNC : 0 | CNT : 5 | CODE : 11112222 ID3 : Lock : Not Locked | MNC : 0 | CNT : 5 | CODE : 33334444 ID4 : Lock : Not Locked | MNC : 0 | CNT : 5 | CODE : 55556666 ID5 : Lock : Not Locked | MNC : 0 | CNT : 5 | CODE : 77778888 ID6 : Lock : Not Locked | MNC : 0 | CNT : 5 | CODE : 99990000 Done! Elapsed: 00:00:52 |
The Following User Says Thank You to rashidmohamm For This Useful Post: |
05-24-2022, 08:46 | #71065 (permalink) |
Member: 1648903 Status: Offline Thanks Meter: 161 | WIKO K510 SP Unlock Operation : SP Unlock [ v2.34 ] Mode : META 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM23) MODE : PRELOADER PORT PORT : 23 Waiting BOOT ack ... PRELOADER : ACK confirmed! INIT : META confirmed! Boot done! AP_CHIP : MT6739 AP_SWTM : Thu Mar 7 16:36:11 HKT 2019 AP_SWVR : alps-mp-p0.mp1-V5.20 MD_CHIP : MT6739 MD_SWVR : TK_MD_BASIC_HW IMEI[1] : 35557210923xxxx ID0 : Lock : Locked! | MNC : 768 | CNT : 5 | CODE : 12345678 ID1 : Lock : Not Locked | MNC : 0 | CNT : 5 | CODE : 56781234 ID2 : Lock : Not Locked | MNC : 0 | CNT : 5 | CODE : 11112222 ID3 : Lock : Not Locked | MNC : 0 | CNT : 5 | CODE : 33334444 ID4 : Lock : Not Locked | MNC : 0 | CNT : 5 | CODE : 55556666 ID5 : Lock : Not Locked | MNC : 0 | CNT : 5 | CODE : 77778888 ID6 : Lock : Not Locked | MNC : 0 | CNT : 5 | CODE : 99990000 IMEI[2] : 35557210926xxxx ID0 : Lock : Locked! | MNC : 768 | CNT : 5 | CODE : 12345678 ID1 : Lock : Not Locked | MNC : 0 | CNT : 5 | CODE : 56781234 ID2 : Lock : Not Locked | MNC : 0 | CNT : 5 | CODE : 11112222 ID3 : Lock : Not Locked | MNC : 0 | CNT : 5 | CODE : 33334444 ID4 : Lock : Not Locked | MNC : 0 | CNT : 5 | CODE : 55556666 ID5 : Lock : Not Locked | MNC : 0 | CNT : 5 | CODE : 77778888 ID6 : Lock : Not Locked | MNC : 0 | CNT : 5 | CODE : 99990000 Done! Elapsed: 00:00:52 |
05-24-2022, 08:46 | #71066 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Algeria
Member: 574410 Status: Offline Thanks Meter: 93 | realme RMX3231 wipe done Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14 Load IDBase v8331 Ok! Operation : Format FS / Reset Settings [ v2.14 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Realme : RMX3231 Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0020 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : True FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:23 |
05-24-2022, 11:11 | #71067 (permalink) |
Freak Poster Join Date: Jun 2014 Location: Turkiye-Konya
Member: 2199727 Status: Offline Thanks Meter: 217 | Reeder m7 go 2019 format and frp reset ok Set mode to : SP [SC773x] eMMC [Android 7.x] Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 9 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x eMMC Loader v7 InfinityBox Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x00000001372F7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x/6.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:38 Reconnect Power/Cable! |
05-24-2022, 13:15 | #71068 (permalink) |
No Life Poster Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,775 | Card found : 73CA70CC , v0153 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.34 Load IDBase v312457 Ok! Update configuration ... Load IDBase v312457 Ok! Operation : Identify [ v2.34 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM Port (COM15) MODE : PRELOADER PORT PORT : 15 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT AGENT : TECNO : SECURE_v2 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA_SWSEC.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: CID : 90014A6843396150330108B265DAB671 EMMC: VEN : HYNIX : OEM : 74 : ID : 684339615033 : PRV : 0x01 EMMC: VEN : HYNIX : hC9aP3 EMMC: SNN : 145909210 ( 0x08B265DA ) , MF : 11/2019 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 6EB2FA81C28D77632D4ABB8AC5297A9A DA : USB : HIGH-SPEED Boot done! Patch Level : PPR1.180610.011 Display ID : KC3-H627G-P-210722V331 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2021-08-05 Build Time : 22.07.2021 Product Model : TECNO KC3 Product Brand : TECNO Product Name : H627 Product Device : TECNO-KC3 Product Manfct : TECNO MOBILE LIMITED Product Info : kc3_h627mt62 Product Board : TECNO-KC3 Board Platform : mt6765 USERDATA : FILESYSTEM : F2FS with FDE ( Full Disk Encryption *) NVRAM : TK_MD_BASIC_MDBIN_PCB01_MT6765_S00.MOLY_LR12A_R3_M P_V71_11_P24 NVRAM : 0xA108BF71 NVRAM : State : Ok! INFO : WiFi MAC : AA0036004400 INFO : BlTh MAC : 783A6CCE76A2 INFO : IMEI[1] : INFO : IMEI[2] : Backup sensetive data [ 18 ] Backup path : Backup\MT6765__6EB2FA81C28D77632D4ABB8AC5297A9A\ [12] Read : NVRAM [37] Read : NVDATA [29] Read : PROINFO [13] Read : LK [36] Read : NVCFG [24] Read : PROTECT1 [1] Read : PGPT [23] Read : PERSIST [0] Read : PRELOADER Backup done! STORAGE : Life Status : eMMC : NOT implemented in selected DA! STORAGE : OTP Status : UNLOCKED! STORAGE : RPMB Status : eMMC : RPMB KEY NOT PROGRAMMED [USABLE] Done! Elapsed: 00:00:41 Operation : Reset Settings/Format FS [ v2.34 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM Port (COM15) MODE : PRELOADER PORT PORT : 15 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT AGENT : TECNO : SECURE_v2 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA_SWSEC.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: CID : 90014A6843396150330108B265DAB671 EMMC: VEN : HYNIX : OEM : 74 : ID : 684339615033 : PRV : 0x01 EMMC: VEN : HYNIX : hC9aP3 EMMC: SNN : 145909210 ( 0x08B265DA ) , MF : 11/2019 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 6EB2FA81C28D77632D4ABB8AC5297A9A DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:32 Reconnect Power/Cable! |
05-24-2022, 13:39 | #71069 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,775 | Vgotel i255 full flash done by cm2 Card found : S/N : 73CA70CC , v0153 Chinese Miracle II [MTK module] v 1.58 Load File File_Info : FISE61M_11C_PCB01_gsm_MT6261_S00.MAUI_11C_W13_52_M P_V2_F4.bin FileVersion : MAUI.11C.W13.52.MP.V2.F4 Load File Ok Operation : Flash [ v1.58 ] ======= Flash Files set for flashing : [ MCU ] : FISE61M_11C_PCB01_GSM_MT6261_S00.MAUI_11C_W13_52_M P_V2_F4.BIN 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 6 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 152E9970904FAA4148925B2B4F1A4597 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV [0] : FLASH_DIE : 00EF 0070 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 File_Info : FISE61M_11C_PCB01_gsm_MT6261_S00.MAUI_11C_W13_52_M P_V2_F4.bin FileVersion : MAUI.11C.W13.52.MP.V2.F4 Flash now Erase region , wait ... Write data , wait ... Write : FISE61M_11C_PCB01_GSM_MT6261_S00.MAUI_11C_W13_52_M P_V2_F4.BIN Done! Elapsed: 00:00:29 Reconnect Power/Cable! |
05-24-2022, 22:14 | #71070 (permalink) |
Member: 1648903 Status: Offline Thanks Meter: 161 | Frp tab ex7sl4-exceed done Operation : Identify [ v2.14 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_0S Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : True FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! Device info : Patch Level : OPM2.171019.012 Display ID : EX7SL4-EXCEED-20190409 Ver. Incmt : 03410 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2019-01-05 Build Time : 09.04.2019 Product Model : EX7SL4 Product Brand : EXCEED Product Name : EX7SL4 Product Device : EX7SL4 Product Manfct : EXCEED Product Info : EX7SL4 Product Board : sp7731e_1h10 Board Platform : sp7731e NVMng : SecurityInfo IMEI[1] : 354063102036423 IMEI[2] : 354063102036431 IMEI[3] : 867400020316638 WIFIMAC : FFFFFFFFFFFF BT_MAC : FFFFFFFFFFFF SEC : SLS:0, SKS:0, SKV:4 Platform Version: MOCORTM_17C_W18.23.4_P2_Debug Project Version: pike2_pub BASE Version: FM_BASE_17C_W18.23.4_P2 HW Version: sc7731e_modem MODEM TAG : MOCORTM_17C_W18.23.4_P2_Debug_FM_BASE_17C_W18.23.4 _P2_sc7731e_modem_pike2_pub USERDATA : FILESYSTEM : F2FS with FDE ( Full Disk Encryption ***) - > INFO : Remove cable from device to switch it off! Done! Elapsed: 00:00:59 Operation : Format FS / Reset Settings [ v2.14 ] Mode : Reset FRP BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_0S Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : True FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:19 Operation : Read FW [ v2.14 ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_0S Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : True FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! Device info : Patch Level : OPM2.171019.012 Display ID : EX7SL4-EXCEED-20190409 Ver. Incmt : 03410 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2019-01-05 Build Time : 09.04.2019 Product Model : EX7SL4 Product Brand : EXCEED Product Name : EX7SL4 Product Device : EX7SL4 Product Manfct : EXCEED Product Info : EX7SL4 Product Board : sp7731e_1h10 Board Platform : sp7731e AndroidVer : 8 VlnrLevel : 0x00 SP7731E__EXCEED__EX7SL4__8.1.0__EX7SL4-EXCEED-20190409__OPM2.171019.012__EX7SL4 Read : prodnv.img ExtSparse : Compression ratio : 23% Read : phase.cfg Read : recovery.img Read : tos.bin Read : sml.bin Read : u-boot.bin Read : boot_logo.bmp Read : fastboot_logo.bmp Read : nvitem_w.bin Make : persist.img Read : gnssmodem.bin Read : gnssbdmodem.bin Read : modem_wcn.img Read : modem_w.bin Read : deltanv_w.bin Read : gdsp_w.bin Read : pm_sys.bin Read : boot.img Read : system.img ExtSparse : Compression ratio : 79% Make : cache.img Read : vendor.img ExtSparse : Compression ratio : 71% Read : vbmeta.img Make : userdata.img Read : u-boot-spl.bin Firmware size : 0x6003E51C ( 1.50 GiB ) Android Info saved : _Android_info.txt Reconnect Power/Cable! Done! Elapsed: 00:11:16 |
