05-21-2022, 06:05 | #71026 (permalink) |
No Life Poster Join Date: Jul 2009 Location: SINDH PAKISTAN
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | G five g3310 format done 1. Power off device 2. Not hold any key on device! 3. Insert cable and battery in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! Format FFS Done! Done! Elapsed: 00:00:14 Reconnect Power/Cable! |
05-21-2022, 07:19 | #71027 (permalink) |
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | vivo y21 frp done Operation : Reset Settings/Format FS [ v2.34 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM29) MODE : PRELOADER PORT PORT : 29 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT AGENT : Vivo : SEC_MT6765 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0x30000000 [ 768.00 MB ] EMMC: CID : 1501004450364442420253E1E8F7C859 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 445036444242 : PRV : 0x02 EMMC: VEN : SAMSUNG : DP6DBB EMMC: SNN : 1407314167 ( 0x53E1E8F7 ) , MF : 12/2021 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 3C166034E0AA4A3539323AA31977E7 DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:18 Reconnect Power/Cable! |
05-21-2022, 08:58 | #71028 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Opo A57 QLM FRP/Pattren Reset Done With King Infinity CM2 Code: Card found : A19EC787 , v0153 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16 Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 435 [MSM8940] ID_BLOCK_S : AE7F2FC4 ID_BLOCK_L : 7AB0219FB3B1C8D922ACB216B1F8B7D2 ID_BLOCK_L : A59C0502B9E166F8B1CE1F022671FB70 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8937 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : GX6BMB Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:17 Reconnect Power/Cable! |
05-21-2022, 13:16 | #71029 (permalink) |
No Life Poster Join Date: Nov 2016 Location: GUJARAT
Member: 2643730 Status: Offline Thanks Meter: 1,115 | Reno 6 pro frp removed by king cm2 , other tool fail Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.34 Load IDBase v312457 Ok! Update configuration ... Load IDBase v312457 Ok! Operation : Identify [ v2.34 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... Device not found! >>> Check cable, battery, connection and drivers! Reconnect Power/Cable! Operation : Reset Settings/Format FS [ v2.34 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM65) MODE : BOOTROM PORT : 65 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6893 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Petrus_P TYPE : MODERN [RAPHAEL] BROM : MEID : 302E02EF86E37B629738CB2F9DE7DBF7 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 14C44B12A2DEEB381C5B641739FA794B2410347E10A0443E1B 95CD377BEEB80C BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : FF : Look for EMI BROM : FF : EMI found! BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6893 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! UFS: CE014B4C55454738554844432D423045 UFS: VEN : 0x01CE | KLUEG8UHDC-B0E ( 0200 ) EMI : DEV : FireFly EMI : SRC : preloader_oplus6893.bin EMI : CNT : 0006 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00070000 [ 448.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] UFS: CE014B4C55454738554844432D423045 UFS: VEN : 0x01CE VID : KLUEG8UHDC-B0E IFW : 0200 LU0 : 0x00400000 [ 4.00 MB ] LU1 : 0x00400000 [ 4.00 MB ] LU2 : 0x3B96000000 [ 238.34 GB ] FSN : 539a8f54ec20 REG : 0x101010000 CHIP : MT6893 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0001 , EVOL : 0x0000 RNID : 1D31CE52C068F3BFFC7AD550FF709A1 DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:37 Reconnect Power/Cable! |
05-21-2022, 15:32 | #71030 (permalink) |
No Life Poster Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Card found : 73CA70CC , v0153 Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.07 SCRD mode : AUTO SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ] Operation : Identify [ v1.07 ] BootMode : SVC 1. Power off device 2. Not hold any key on device! 3. Insert cable and battery in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! SOC GEN : SPRD ( Legacy ) ModemInfo : Project Version: SC6531EFM_BAR BASE Version: BASE_SVN HW Version: SC6531EFM_BAR CMP_Time : 05-14-2019 19:44:35 SecInfo : IMEI[1] : IMEI[2] : IMEI[3] : 000000000000000 WIFIMAC : FFFFFFFFFFFF BT_MAC : FFFFFFFFFFFF SEC_ID : F97FFFFFD1DD66CB Done! Elapsed: 00:00:13 Reconnect Power/Cable! Operation : Format FileSystem [ v1.07 ] 1. Power off device 2. Not hold any key on device! 3. Insert cable and battery in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! Format FFS Done! Done! Elapsed: 00:00:17 Reconnect Power/Cable! |
05-21-2022, 15:35 | #71031 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Hotwav v10 reset frp done by cm2 Card found : 73CA70CC , v0153 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14 Load IDBase v8331 Ok! Operation : Format FS / Reset Settings [ v2.14 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731x_BASE : SC7731GEA_eMMC_1GB_NS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:48 |
05-21-2022, 15:35 | #71032 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Vivo y21 reset frp done by cm2 Card found : 73CA70CC , v0153 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.34 Load IDBase v312457 Ok! Update configuration ... Load IDBase v312457 Ok! Operation : Reset Settings/Format FS [ v2.34 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (COM29) MODE : PRELOADER PORT PORT : 29 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT AGENT : Vivo : SEC_MT6765 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0x30000000 [ 768.00 MB ] EMMC: CID : 90014A68433861503E03104A2F6A8827 EMMC: VEN : HYNIX : OEM : 74 : ID : 68433861503E : PRV : 0x03 EMMC: VEN : HYNIX : hC8aP> EMMC: SNN : 273297258 ( 0x104A2F6A ) , MF : 8/2021 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : D89BD24A93A880725DF99909DAEFD0B0 DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x835757 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : CACHE Format Ok : USERDATA Done! Elapsed: 00:00:40 Reconnect Power/Cable! |
05-21-2022, 15:37 | #71033 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Oppo a31 reset pattern done by cm2 Card found : 73CA70CC , v0153 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16 Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 1A4161C5 ID_BLOCK_I : 007050E1 ID_BLOCK_L : C22258A6119D8A8562D73926E1B83810 ID_BLOCK_L : 186BD57479E852D3F6C18A4341ACBA81 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Format USER ... Format CACHE ... Format Ok! Done! Elapsed: 00:00:15 Reconnect Power/Cable! |
05-21-2022, 17:15 | #71034 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Infinix x657B MT6761 FRP/Pattren Reset Done With King Infinity CM2 Code: Card found : A19EC787 , v0153 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.34 Load IDBase v312457 Ok! UserName and/or Password not set! Can't continue! Load IDBase v312457 Ok! Operation : Reset Settings/Format FS [ v2.34 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM12) MODE : BOOTROM PORT : 12 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 CODE : Merlot TYPE : MODERN [RAPHAEL] BROM : MEID : D2B5F377A7B61D6032BEC4806637DC8F BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 2429AD57CC3EB65E61925B957560509A61EE2DE23FF9F5797B778E7AA0EF6F03 BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : FF : Look for EMI BROM : FF : EMI found! BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMMC: CID : D6010335384B37323169C221E5249765 EMMC: VEN : UNKNOWN [0xD6] : OEM : 3 : ID : 35384B373231 : PRV : 0x69 EMMC: VEN : UNKNOWN [0xD6] : 58K721 EMMC: SNN : 3257001252 ( 0xC221E524 ) , MF : 9/2020 EMI : DEV : FireFly EMI : SRC : preloader_x657b_h6117.bin EMI : CNT : 000B EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A400 [ 233.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: CID : D6010335384B37323169C221E5249765 EMMC: VEN : UNKNOWN [0xD6] : OEM : 3 : ID : 35384B373231 : PRV : 0x69 EMMC: VEN : UNKNOWN [0xD6] : 58K721 EMMC: SNN : 3257001252 ( 0xC221E524 ) , MF : 9/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0xE67800000 [ 57.62 GB ] CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 906CED44D611656BABA496CD6F2C052E DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x835657 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : CACHE Format Ok : USERDATA Format Ok : USERDATA Done! Elapsed: 00:01:09 Reconnect Power/Cable! |
05-21-2022, 17:33 | #71035 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Infinix X625C MT6757 FRP/Pattren Reset Done With King Infinity CM2 Code: Operation : Identify [ v2.34 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM12) MODE : BOOTROM PORT : 12 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6757 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 CODE : Kibo TYPE : MODERN [RAPHAEL] BROM : MEID : D4437EAFB9B494C5B29F87E1D6BECB0A BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : SLA : Auth Passed! BROM : SEC : 0x000000E1 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6757 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SETUP HW PARAMS FAILED! PROTO_VER is OLD? Error : Fail to init protocol! >>> Check and select CORRECT SETTINGS for your device! Reconnect Power/Cable! Operation : Identify [ v2.34 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM35) MODE : PRELOADER PORT PORT : 35 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6757 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 CODE : Kibo TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x02 BROM : PRELOADER PORT AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6757 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : Reset Interface! PTFN : MediaTek USB Port_V1632 (COM12) MODE : BOOTROM PORT : 12 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6757 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 CODE : Kibo TYPE : MODERN [RAPHAEL] BROM : MEID : D4437EAFB9B494C5B29F87E1D6BECB0A BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : SLA : Auth Passed! BROM : SEC : 0x000000E1 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6757 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_x625c64_h576.bin EMI : CNT : 0004 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x200000000 [ 8.00 GB ] EMMC: CID : 90014A484347386134A2CA884D27A529 EMMC: VEN : HYNIX : OEM : 74 : ID : 484347386134 : PRV : 0xA2 EMMC: VEN : HYNIX : HCG8a4 EMMC: SNN : 3397930279 ( 0xCA884D27 ) , MF : 10/2018 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6757 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 , EVOL : 0x0000 RNID : CB25138A955F13D2D02E88494363F746 DA : USB : FULL-SPEED DA : USB : Change Port Speed PTFN : MediaTek DA USB VCOM (Android) (COM48) MODE : PRELOADER PORT PORT : 48 Boot done! Patch Level : PPR1.180610.011 Display ID : X625C-H576CD-P-200407V124 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2020-04-05 Build Time : 07.04.2020 Product Model : Infinix X625C Product Brand : Infinix Product Name : H576CD Product Device : Infinix-X625C Product Manfct : alps Product Info : x625c64_h576 Product Board : Infinix-X625C Board Platform : mt6757 Product Manfct : INFINIX MOBILITY LIMITED USERDATA : FILESYSTEM : EXT4 with FDE ( Full Disk Encryption **) NVRAM : TK_MD_BASIC_MDBIN_PCB01_MT6757P_S00.MOLY_LR11_W1630_MD_MP_V120_P3 NVRAM : 0x3A01E5677 NVRAM : State : Ok! INFO : WiFi MAC : AA0036004400 INFO : BlTh MAC : 74C17DA860C0 INFO : IMEI[1] : 355184104429744 INFO : IMEI[2] : 355184104429751 Backup sensetive data [ 18 ] Backup path : Backup\MT6757__D4437EAFB9B494C5B29F87E1D6BECB0A\ [8] Read : NVRAM [32] Read : NVDATA [24] Read : PROINFO [9] Read : LK [31] Read : NVCFG [19] Read : PROTECT1 [1] Read : PGPT [18] Read : PERSIST [0] Read : PRELOADER Backup done! STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : NOT Enabled! STORAGE : RPMB Status : eMMC : RPMB KEY NOT PROGRAMMED [USABLE] Done! Elapsed: 00:00:29 Operation : Reset Settings/Format FS [ v2.34 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM35) MODE : PRELOADER PORT PORT : 35 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6757 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 CODE : Kibo TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x02 BROM : PRELOADER PORT AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6757 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : Reset Interface! PTFN : MediaTek USB Port_V1632 (COM12) MODE : BOOTROM PORT : 12 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6757 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 CODE : Kibo TYPE : MODERN [RAPHAEL] BROM : MEID : D4437EAFB9B494C5B29F87E1D6BECB0A BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : SLA : Auth Passed! BROM : SEC : 0x000000E1 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6757 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_x625c64_h576.bin EMI : CNT : 0004 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x200000000 [ 8.00 GB ] EMMC: CID : 90014A484347386134A2CA884D27A529 EMMC: VEN : HYNIX : OEM : 74 : ID : 484347386134 : PRV : 0xA2 EMMC: VEN : HYNIX : HCG8a4 EMMC: SNN : 3397930279 ( 0xCA884D27 ) , MF : 10/2018 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6757 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 , EVOL : 0x0000 RNID : CB25138A955F13D2D02E88494363F746 DA : USB : FULL-SPEED DA : USB : Change Port Speed PTFN : MediaTek DA USB VCOM (Android) (COM48) MODE : PRELOADER PORT PORT : 48 Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:31 Reconnect Power/Cable! |
05-21-2022, 20:16 | #71036 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | coolpad 1825-E0 Frp Code: Patch Level : PPR1.180610.011 Display ID : R09_20190711 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2019-06-05 Build Time : 14.12.2019 Product Model : 1825-E0 Product Brand : coolpad Product Name : 1825-E0 Product Device : 1825-E0 Product Manfct : coolpad Product Info : 1825-E0 Product Board : k61v1_64_bsp Board Platform : mt6761 USERDATA : FILESYSTEM : EXT4 with FDE ( Full Disk Encryption **) NVRAM : TK_MD_BASIC_MDBIN_PCB01_MT6761_S00.MOLY_LR12A_R3_MP_V79_9 NVRAM : 0xB60AC6CC NVRAM : State : Ok! INFO : WiFi MAC : AA0036004400 INFO : BlTh MAC : 00551A19FA78 INFO : IMEI[1] : INFO : IMEI[2] : STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : UNLOCKED! STORAGE : RPMB Status : eMMC : RPMB KEY PROGRAMMED [UNUSABLE] Done! Elapsed: 00:00:20 Operation : Reset Settings/Format FS [ v2.34 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM30) MODE : PRELOADER PORT PORT : 30 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 CODE : Merlot TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A400 [ 233.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: CID : 90014A484147346132A51F03C08354B7 EMMC: VEN : HYNIX : OEM : 74 : ID : 484147346132 : PRV : 0xA5 EMMC: VEN : HYNIX : HAG4a2 EMMC: SNN : 520339587 ( 0x1F03C083 ) , MF : 5/2017 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3AB400000 [ 14.68 GB ] CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : D50BF1FBB246C8F8183534E137873772 DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:17 Reconnect Power/Cable! |
05-21-2022, 20:17 | #71037 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | vivo 1901 Format & Frp Code: Product Brand : vivo Product Device : 1901 Product Model : vivo 1901 Product Name : 1901 Patch Level : RP1A.200720.012 Display ID : RP1A.200720.012 release-keys Product Info : k62v1_64_bsp Ver. CodeName : REL Ver. Release : 11 Sec. Patch : 2022-02-01 Build Time : 18.02.2022 Product Board : k62v1_64_bsp Board Platform : mt6765 Product Manfct : vivo USERDATA : FILESYSTEM : EXT4 with FDE ( Full Disk Encryption **) NVRAM : BBK_R0MP1_K62V1_64_BSP_MDBIN_PCB01_MT6765_S00.MOLY_LR12A_R3_MP_V136_6_P74 NVRAM : 0xB50AF66F NVRAM : State : Ok! INFO : WiFi MAC : AA0036004400 INFO : BlTh MAC : 08B3AFD16A66 INFO : IMEI[1] : INFO : IMEI[2] : STORAGE : Life Status : eMMC : NOT implemented in selected DA! STORAGE : OTP Status : NOT Enabled! STORAGE : RPMB Status : eMMC : RPMB KEY PROGRAMMED [UNUSABLE] Done! Elapsed: 00:00:22 Operation : Reset Settings/Format FS [ v2.34 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM4) MODE : PRELOADER PORT PORT : 4 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT AGENT : Vivo : SEC_MT6765 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0x30000000 [ 768.00 MB ] EMMC: CID : 150100525036344D4201EBD7E4B47683 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 525036344D42 : PRV : 0x01 EMMC: VEN : SAMSUNG : RP64MB EMMC: SNN : 3956794548 ( 0xEBD7E4B4 ) , MF : 7/2019 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : E8A038C526CCF28F69489EF5ACB4AF4B DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x835757 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : CACHE Format Ok : USERDATA Done! Elapsed: 00:00:30 Reconnect Power/Cable! |
05-21-2022, 20:18 | #71038 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | TECNO-KF6p Format & Frp Code: Product Brand : TECNO Product Device : TECNO-KF6p Product Model : TECNO KF6p Product Name : KF6p-GL Patch Level : RP1A.200720.011 Display ID : KF6p-H6218HLQ-R-GL-211012V287 Ver. CodeName : REL Ver. Release : 11 Sec. Patch : 2021-09-05 Build Time : 12.10.2021 Product Info : kf6p_h6218 Product Board : TECNO-KF6p Board Platform : mt6765 Product Manfct : TECNO MOBILE LIMITED USERDATA : FILESYSTEM : F2FS with FBE ( File-Base Encryption ) NVRAM : 0xA3101BCE NVRAM : State : Ok! INFO : WiFi MAC : AA0036004400 INFO : BlTh MAC : 08B49D27BBF2 INFO : IMEI[1] : INFO : IMEI[2] : STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : UNLOCKED! STORAGE : RPMB Status : eMMC : RPMB KEY NOT PROGRAMMED [USABLE] Done! Elapsed: 00:00:32 Operation : Reset Settings/Format FS [ v2.34 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM5) MODE : BOOTROM PORT : 5 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 8B201877713CBA93001B55F39DD9698B BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : D86B1280C2A87531A7DE68ECA599DB78256B8EE201529BA2C68A7B6E73868D4E BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMMC: CID : 15010044503644414203126590F178A3 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 445036444142 : PRV : 0x03 EMMC: VEN : SAMSUNG : DP6DAB EMMC: SNN : 308646129 ( 0x126590F1 ) , MF : 7/2021 EMI : DEV : FireFly EMI : SRC : EMI : CNT : 0006 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: CID : 15010044503644414203126590F178A3 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 445036444142 : PRV : 0x03 EMMC: VEN : SAMSUNG : DP6DAB EMMC: SNN : 308646129 ( 0x126590F1 ) , MF : 7/2021 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 6688DE4686EAD6BBBB572B9175BDBAD5 DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x835657 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : USERDATA Format Ok : USERDATA Done! Elapsed: 00:00:38 Reconnect Power/Cable! |
05-21-2022, 20:19 | #71039 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Nokia 3.1 Frp Code: Product Brand : alps Product Device : ES2 Product Model : Nokia 3.1 Product Name : ES2_00WW_FIH Patch Level : QP1A.190711.020 Display ID : 00WW_4_200 Ver. CodeName : REL Ver. Release : 10 Sec. Patch : 2021-08-05 Build Time : 05.08.2021 Product Info : ES2 Product Board : ES2 Board Platform : mt6750 Product Brand : Nokia Product Manfct : HMD Global Product Name : Essential2_00WW USERDATA : FILESYSTEM : EXT4 with FDE ( Full Disk Encryption *) NVRAM : 0x3B4205B4E NVRAM : State : Ok! INFO : WiFi MAC : 20395698CDF7 INFO : BlTh MAC : 20395698AEB7 INFO : IMEI[1] : INFO : IMEI[2] : STORAGE : Life Status : eMMC : BAD! LIFE CYCLE WARNING! STORAGE : OTP Status : NOT Enabled! STORAGE : RPMB Status : eMMC : RPMB KEY PROGRAMMED [UNUSABLE] Done! Elapsed: 00:00:25 Operation : Reset Settings/Format FS [ v2.34 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM5) MODE : BOOTROM PORT : 5 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 TYPE : MODERN [RAPHAEL] BROM : MEID : 0BC8868C9E4EB97A272FCF577B9713E3 BROM : SecLevel : 0x00000001 BROM : SecMode : SBC BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6755 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_es2.bin EMI : CNT : 0006 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00038000 [ 224.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: CID : 150100514536334D4203D685D4517547 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 514536334D42 : PRV : 0x03 EMMC: VEN : SAMSUNG : QE63MB EMMC: SNN : 3599094865 ( 0xD685D451 ) , MF : 7/2018 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3A3E00000 [ 14.56 GB ] CHIP : MT6750 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 51ADA52F21E2D2C668BC4CFEB9EA56D7 DA : USB : FULL-SPEED DA : USB : Change Port Speed PTFN : MediaTek DA USB VCOM (Android) (COM10) MODE : PRELOADER PORT PORT : 10 Boot done! Format Ok : RESET PROTECTION Format Ok : PRIVACY Done! Elapsed: 00:00:24 Reconnect Power/Cable! |
05-21-2022, 20:22 | #71040 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | vivo V2026 Format & Frp Code: Product Brand : vivo Product Device : 2026 Product Model : V2026 Product Name : 2026 Patch Level : RP1A.200720.012 Display ID : RP1A.200720.012 release-keys Product Info : k65v1_64_bsp Ver. CodeName : REL Ver. Release : 11 Sec. Patch : 2022-03-01 Build Time : 07.03.2022 Product Board : k65v1_64_bsp Board Platform : mt6765 Product Manfct : vivo USERDATA : FILESYSTEM : EXT4 with FBE ( File-Base Encryption ) NVRAM : BBK_R0MP1_K65V1_64_BSP_MDBIN_PCB01_MT6765_S00.MOLY_LR12A_R3_MP_V136_6_P96 NVRAM : 0xB61250C6 NVRAM : State : Ok! INFO : WiFi MAC : AA0036004400 INFO : BlTh MAC : 38384BB89BBB INFO : IMEI[1] : INFO : IMEI[2] : STORAGE : Life Status : eMMC : NOT implemented in selected DA! STORAGE : OTP Status : NOT Enabled! STORAGE : RPMB Status : eMMC : RPMB KEY PROGRAMMED [UNUSABLE] Done! Elapsed: 00:00:35 Operation : Reset Settings/Format FS [ v2.34 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM4) MODE : PRELOADER PORT PORT : 4 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! BROM : Enforcing BootROM BROM : Enforcing Failed! Skip! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT AGENT : Vivo : SEC_MT6765 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0x30000000 [ 768.00 MB ] EMMC: CID : 150100445836384D420979FBF4729731 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 445836384D42 : PRV : 0x09 EMMC: VEN : SAMSUNG : DX68MB EMMC: SNN : 2046555250 ( 0x79FBF472 ) , MF : 9/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 256A4B3CDFB198CA77B0C944A7B92193 DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x835757 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : CACHE Format Ok : USERDATA Format Ok : USERDATA Done! Elapsed: 00:00:32 Reconnect Power/Cable! |
