02-02-2011, 12:11 | #8536 (permalink) |
No Life Poster Join Date: Feb 2010 Location: e.cameros shop Age: 45
Member: 1229604 Status: Offline Sonork: 100.1602688 Thanks Meter: 4,813 | L600 china invalid sim, done via infinity pinout inside first try via avator box fone not detect via com and cable chip 8pin im deside to try infinitybox pinout change imei result here thanks infinity box team |
The Following 2 Users Say Thank You to ernie78™ For This Useful Post: |
02-02-2011, 12:18 | #8537 (permalink) |
Freak Poster Join Date: Nov 2010 Location: Bangladesh
Member: 1437757 Status: Offline Sonork: 100.1584492 Thanks Meter: 301 | Vodafone 345 unlock done Now Unlock Done Vodafone 345 TexT New Security!! By Mmodule 3.73 http://forum.gsmhosting.com/vbb/f296...0/#post6905757 |
The Following 2 Users Say Thank You to MT-TECHNOLOGY For This Useful Post: |
02-02-2011, 12:51 | #8538 (permalink) |
No Life Poster Join Date: Nov 2007 Location: ☆I-LOVE Pakistan☆
Member: 627475 Status: Offline Sonork: 100.1594828 Thanks Meter: 1,144 | Nokia 1280 Phone Lock done card found: S/N 0******* registered to: ******* Connect phone on selected interface... UFS S/N 1****** boot - Ok Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... SW ver : V 04.20 07-05-10 RM-647 (c) Nokia IMEI : 35*********** PPM : V 04.20 07-05-10 RM-647 (c) Nokia IA PCode : 05**** BPCode : 05**** HWID : 1000 LCDVer : WIN:SERI:90 NT7542 IMEI : 3534190****** Sl Conf : 001-01-00000000000 Sl Prof : 000000000003000-2 Sl Aux : 000B0000 Hw Sig : 7BA39197******** Provider : Default Test Operator Lock info: Block 1 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 2 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 3 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 4 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 5 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 6 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 7 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Done! Resetting selected items... Check phone mode... Phone in Local mode Seting Test mode... wait... Test mode set Settings Full Factory Defaults... Set OK! Elapsed: 00:00:08 Resetting User Code to default (12345)... Phone disconected! |
The Following 2 Users Say Thank You to rafi_5217705 For This Useful Post: |
02-02-2011, 13:44 | #8539 (permalink) |
No Life Poster Join Date: Mar 2007 Location: punjab(india) Age: 45
Member: 467045 Status: Offline Sonork: 100.1603919 Thanks Meter: 1,705 | COM2 [VCP0] selected module v3.73 Device: Spice-S404N Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6205:8B00]... CPU: MT6205 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC22A000000000:18E59F00000000 flash: Samsung AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb otp offset: 003F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) > if phone works fine just ignore this warning < ffs/eeprom address can not be detected, value from database assigned: 00300000/00100000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: Spice-S404N__ffs... file saved: C:\Program Files\InfinityBox\MModule\Spice-S404N__ffs_20110202-181222.B0E.bin flash: EC22A000000000:18E59F00000000 Backup required data Done ====> Patch required data ... detection procedure, wait... detection procedure completed Patch required data Done ====> Special operation ... detecting parameters to apply patch area 1... ................ error: area 1 can not apply patch detecting parameters to apply patch area 2... ................ error: area 2 can not apply patch detecting parameters to apply patch area 3... ................ error: area 3 can not apply patch detecting parameters to apply patch area 4... ..... required data found flash: EC22A000000000:18E59F00000000 flash: EC22A000000000:18E59F00000000 Write: area 4 (pass 1) ........... area 4 patch applied Ok Special operation Done ====> Write ... flash: EC22A000000000:18E59F00000000 Write: ffs Write Done ====> Finalization ... Finalization Done Finished, time used: 3 min 58 sec Remove/Install battery now ! |
The Following User Says Thank You to JINDALGSM™ For This Useful Post: |
02-02-2011, 13:48 | #8540 (permalink) |
Member: 467045 Status: Offline Sonork: 100.1603919 Thanks Meter: 1,705 | COM2 [VCP0] selected module v3.73 Device: Spice-S404N Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6205:8B00]... CPU: MT6205 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: DA2213DD00DD02:18E59F00000000 flash: DA2213DD00DD02:18E59F00000000 flash: Winbond [T 0008x002000 003Fx010000] 4Mb otp offset: 003F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) > if phone works fine just ignore this warning < ffs/eeprom address can not be detected, value from database assigned: 00300000/00100000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: Spice-S404N__ffs... file saved: C:\Program Files\InfinityBox\MModule\Spice-S404N__ffs_20110202-181642.B0E.bin flash: DA2213DD00DD02:18E59F00000000 flash: DA2213DD00DD02:18E59F00000000 Backup required data Done ====> Patch required data ... detection procedure, wait... detection procedure completed Patch required data Done ====> Special operation ... detecting parameters to apply patch area 1... ..... required data found flash: DA2213DD00DD02:18E59F00000000 flash: DA2213DD00DD02:18E59F00000000 flash: DA2213DD00DD02:18E59F00000000 flash: DA2213DD00DD02:18E59F00000000 Write: area 1 (pass 1) ........... area 1 patch applied Ok detecting parameters to apply patch area 2... ................ error: area 2 can not apply patch detecting parameters to apply patch area 3... ................ error: area 3 can not apply patch detecting parameters to apply patch area 4... ................ error: area 4 can not apply patch Special operation Done ====> Write ... flash: DA2213DD00DD02:18E59F00000000 flash: DA2213DD00DD02:18E59F00000000 Write: ffs Write Done ====> Finalization ... Finalization Done Finished, time used: 3 min 43 sec Remove/Install battery now ! |
02-02-2011, 13:56 | #8541 (permalink) |
Member: 467045 Status: Offline Sonork: 100.1603919 Thanks Meter: 1,705 | nokia 3110c flashing done card found: S/N 0390:0118 registered to: jindalgsm4255 Connect phone on selected interface... Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm237__07.21.mcusw PPM : rm237__07.21.ppm_s CNT : rm237__07.21.image_s Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. [BB5 FLASH]: Bootrom Ok! RAP_PUB: 22C000064A7E6E56569EC56F3154E30247CBF812 CMT_ROOT: BAF3A9C3DBFA8454937DB77F2B8852B1 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:05 Reopening the connection... Waiting for response: 30 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm237__07.21.mcusw Found 9 areas to erase Erasing area 0x00000000 - 0x000006BF, NOR, CMT Result: 0000 Erasing area 0x000006C0 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00020000 - 0x0007FFFF, NOR, CMT Result: 0000 Erasing area 0x00080000 - 0x000DFFFF, NOR, CMT Result: 0000 Erasing area 0x00100000 - 0x001FFFFF, NOR, CMT Result: 0000 Erasing area 0x00200000 - 0x0031FFFF, NOR, CMT Result: 0000 Erasing area 0x00320000 - 0x0105FFFF, NOR, CMT Result: 0000 Erasing area 0x01060000 - 0x01067FFF, NOR, CMT Result: 0000 Erasing area 0x01068000 - 0x0107FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:01:28 Write : Processing rm237__07.21.mcusw Total 944 [944/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [PAPUBKEYS] CMT : PAPUBKEYS skip, already sent CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] CMT : Writing Hash CERT [PMM_CONF] CMT : Writing Hash CERT [SBIF_CONF] TIME : Write time : 00:01:07 MCU Write done ===Flashing [PPM]=== Erase : Processing rm237__07.21.ppm_s Found 1 areas to erase Erasing area 0x01080000 - 0x0151FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:26 Write : Processing rm237__07.21.ppm_s Total 278 [278/0/0] blocks to write, writing... TIME : Write time : 00:00:20 PPM Write done ===Flashing [CNT]=== Checking content info... Resetting phone... MMC pwd backup saved Checking CNT sector PN<>FL PN CNT sector : 128 kb Converted content already exist, skip convert and using 128k Loader len: 253888, CHK: 129B ADL -> Sending loader... Reset connection... ADL : Check data ADL : Data accepted ADL : ASIC CMT select Ok Erase : Processing rm237__07.21.image_s_128 Found 1 areas to erase Erasing area 0x01520000 - 0x01FDFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:01:00 Write : Processing rm237__07.21.image_s_128 Total 360 [360/0/0] blocks to write, writing... TIME : Write time : 00:00:25 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:04:47 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 3110c Software Info: V 07.21 05-11-08 RM-237 (c) Nokia. IMEI: 352047020301409 PPM version : V 07.21 05-11-08 RM-237 (c) Nokia. S Product code: 0550573 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! AfterFlash operations done... Reconnect, wait... Done! Elapsed: 00:06:03 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok ; |
The Following 2 Users Say Thank You to JINDALGSM™ For This Useful Post: |
02-02-2011, 14:22 | #8542 (permalink) |
Freak Poster Join Date: Nov 2007 Location: TAMIL NADU
Member: 638789 Status: Offline Sonork: 100.16379331 Thanks Meter: 25 | successful unlock c2803 APP:HWC2803MT02 BOOT:6010P1B103 PRL:10 HW: VER.C BREW VER:2.1.2.5 FEB 26 2008 READ INFORMATION ERROR BUT UNLOCK SUCCESSFUL. COM1 [Serial0] selected module v1.43 Device: Huawei-C2803 operation: SP-unlock Phone should be Switched ON ! connecting... OFFLINE... disable minlock... Phones should be restarting now... Finished, time used: 5 sec THANKS..... |
The Following 2 Users Say Thank You to dazanokia For This Useful Post: |
02-02-2011, 14:28 | #8543 (permalink) |
Member: 467045 Status: Offline Sonork: 100.1603919 Thanks Meter: 1,705 | COM48 [VCP0] selected module v3.73 Device: Fly-Q200 Checking data, wait... Action: reset settings ("format ffs") NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6225:8A05:8A00 status: FF bbchip bl ver: FE NOR flash id[00A4]: 0098:000300000000 [TOSHIBA] TC58FVM7TDD chip size: 16Mb otp status/size: S_DA_NOR_OTP_NOT_SUPPORT/00000000 NAND flash chip: not installed internal RAM size: 0000C000 external RAM: S_DA_RAM_ERROR done Set baudrate (115200)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 00000000/00000000 detect sec ro... detect custom parameters... detect project-id... project-id: E505E_India_V4.8 detect NOR info... number of areas/bytes to read: 1:00040000 reading (HW_STORAGE_NOR)... TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 05 sw version: TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E505E_IND IA_V4_8.BIN project-id: E505E_India_V4.8, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/001F0000 rom info structure: [standard] type (05) TCL-ID is absent ===> done Format... Disconnect... done Finished, time used: 1 min 5 sec Remove/Install battery now ! |
02-02-2011, 14:31 | #8544 (permalink) |
No Life Poster Join Date: May 2006 Location: Sambrial (Sialkot)
Member: 282066 Status: Offline Sonork: 100.1590696 Thanks Meter: 569 | voda 543 unolck done............. COM9 [VCP1] selected module v3.63 Device: Vodafone-543 Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:5B03:A00A status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98006F00000004:09EA0000000000 flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb otp offset: 01FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... usb bootloader (chip) is present: 00020000 searching rom info... search rom info finished rom info structure: [protected] type (07), 1 record(s) TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: E:\InfinityBox\MModule\backup_security\id.28D14CCD .[JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP 1_V32_F3.BIN_814E5441].rpl ==================== New firmware found (v.3.63, database date: 05.06.2010): JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP 1_V32_F3.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished TCL-ID detection... TCL-ID detection done device-id: 28D14CCD rom info ver: 07 sw version: JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP 1_V32_F3.BIN project-id: MAUI.08A.W08.40.SP1.V32.F3, 41544E81 code offset: 00020000 ffs offset/size [01]: 01800000/00800000 TCL-ID identification version: 267 provider: 543X-2AVDES1 customization: CN26FE03 customization: XN26FE03 TCL-ID identification done rom info structure: [protected] type (07), 1 record(s) TCL-ID is present ffs/eeprom address assigned: 01800000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is invalid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#3... search sec info#3 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 security area (sec info, cust) calculation... error: security area (sec info, cust) header is invalid security area (sec info, hash) calculation... version is not found in database: JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP 1_V32_F3.BIN use default security area (sec info, hash) pattern max address is too big, should be recalculated: 00006F50->00006C50 ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected customization: XN26FE03 customization name adjusted flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... version is not found in database: JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP 1_V32_F3.BIN use default security area (sec info, hash) pattern ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected customization: XN26FE03 customization name adjusted flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... version is not found in database: JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP 1_V32_F3.BIN use default security area (sec info, hash) pattern ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35982003592912 flash: 98006F00000004:09EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98006F00000004:09EA0000000000 Finalization Done file saved: E:\InfinityBox\MModule\backup_security\Vodafone-543_JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_4 0_SP1_V32_F3__system_log_28D14CCD_814E5441_2011020 2-052916.B0X.bin Finished, time used: 4 min 8 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to zeerik For This Useful Post: |
02-02-2011, 15:53 | #8545 (permalink) |
Member: 467045 Status: Offline Sonork: 100.1603919 Thanks Meter: 1,705 | nokia 3110c flashing done card found: S/N 0390:0118 registered to: jindalgsm4255 Connect phone on selected interface... Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm237__07.30.mcusw PPM : rm237__07.30.ppm_c CNT : rm237__07.30.image_c_tr Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. [BB5 FLASH]: Bootrom Ok! RAP_PUB: 0B1001091A5C7C56DB24321F41E35BB604449513 CMT_ROOT: BAF3A9C3DBFA8454937DB77F2B8852B1 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:05 Reopening the connection... Waiting for response: 30 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm237__07.30.mcusw Found 9 areas to erase Erasing area 0x00000000 - 0x000006BF, NOR, CMT Result: 0000 Erasing area 0x000006C0 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00020000 - 0x0007FFFF, NOR, CMT Result: 0000 Erasing area 0x00080000 - 0x000DFFFF, NOR, CMT Result: 0000 Erasing area 0x00100000 - 0x001FFFFF, NOR, CMT Result: 0000 Erasing area 0x00200000 - 0x0031FFFF, NOR, CMT Result: 0000 Erasing area 0x00320000 - 0x0105FFFF, NOR, CMT Result: 0000 Erasing area 0x01060000 - 0x01067FFF, NOR, CMT Result: 0000 Erasing area 0x01068000 - 0x0107FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:02:10 Write : Processing rm237__07.30.mcusw Total 945 [945/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [PAPUBKEYS] CMT : PAPUBKEYS skip, already sent CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] CMT : Writing Hash CERT [PMM_CONF] CMT : Writing Hash CERT [SBIF_CONF] TIME : Write time : 00:00:45 MCU Write done ===Flashing [PPM]=== Erase : Processing rm237__07.30.ppm_c Found 1 areas to erase Erasing area 0x01080000 - 0x0151FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:37 Write : Processing rm237__07.30.ppm_c Total 240 [240/0/0] blocks to write, writing... TIME : Write time : 00:00:11 PPM Write done ===Flashing [CNT]=== Checking content info... Resetting phone... Checking CNT sector PN<>FL PN CNT sector : 128 kb Converted content already exist, skip convert and using 128k Loader len: 253888, CHK: 17DB ADL -> Sending loader... Reset connection... ADL : Check data ADL : Data accepted ADL : ASIC CMT select Ok Erase : Processing rm237__07.30.image_c_tr_128 Found 1 areas to erase Erasing area 0x01520000 - 0x01FDFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:01:47 Write : Processing rm237__07.30.image_c_tr_128 Total 240 [240/0/0] blocks to write, writing... TIME : Write time : 00:00:11 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:05:43 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 3110c Software Info: V 07.30 07-05-09 RM-237 (c) Nokia. IMEI: 356789021513062 PPM version : V 07.30 07-05-09 RM-237 (c) Nokia. C Product code: 0566962 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! AfterFlash operations done... Reconnect, wait... Done! Elapsed: 00:06:34 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok ; |
02-02-2011, 15:54 | #8546 (permalink) |
Member: 638789 Status: Offline Sonork: 100.16379331 Thanks Meter: 25 | successful unlock c2803 successful unlock c2803 APP:HWC2803MT02 BOOT:6010P1B103 PRL:10 HW: VER.C BREW VER:2.1.2.5 FEB 26 2008 READ INFORMATION ERROR BUT UNLOCK SUCCESSFUL. COM1 [Serial0] selected module v1.43 Device: Huawei-C2803 operation: SP-unlock Phone should be Switched ON ! connecting... OFFLINE... disable minlock... Phones should be restarting now... Finished, time used: 5 sec THANKS..... |
The Following User Says Thank You to dazanokia For This Useful Post: |
02-02-2011, 18:30 | #8547 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Amoude-syria Age: 49
Member: 98928 Status: Offline Thanks Meter: 467 | secssefully unlock vodafone 226 Code: COM6 [VCP0] selected module v1.78 Device: Vodafone-226 Checking data, wait... Action: "sp-unlock" unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820010 loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... Check hardware Done Check parameters ... sw version: 844 EBI_IH_280607_1844 EBI_IH Thhmm Dddmmmyyyy 0123456789ABCDEF Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-226_eeprom-static_20110202-182204.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-226_eeprom-security_20110202-182206.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-226_eeprom-complete_20110202-182211.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-226_lock-area_20110202-182236.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 1 min 26 sec Remove/Install battery now ! |
The Following User Says Thank You to bavesore For This Useful Post: |
02-02-2011, 20:12 | #8548 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | C1-01, RM-607 Code: Connect phone on selected interface... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert charger! --- Connection opened successfully DBG : F00A1FB300020303010100FF CPUID : XGOLD 213 2nd boot Ok, 01 2nd ready Sending Algo , CC Algo sent Ok BL : Quantum_Bootloader_10.37_M1S1 Speed accepted, use 6.500.000 FLASHID : 89008289 FLIC conf set, RST set Boot done! ===Flashing [MCU]=== File : rm607__03.35.mcusw Image : rm607__03.35.mcusw_ebl_psi.fls Cert block found, sending.... Cert sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00040000 Erasing, wait ... Erase done Write , Start : 0x40040000 , Len : 0x00040000 Flashing , wait ... Region flash done Processing Region 3/5 Erase , Start : 0x40080000 , Len : 0x00020000 Erasing, wait ... Erase done Write , Start : 0x40080000 , Len : 0x00020000 Flashing , wait ... Region flash done Processing Region 4/5 Erase , Start : 0x400A0000 , Len : 0x00100000 Erasing, wait ... Erase done Write , Start : 0x400A0000 , Len : 0x00100000 Flashing , wait ... Region flash done Processing Region 5/5 Erase , Start : 0x40400000 , Len : 0x01800000 Erasing, wait ... Erase done Write , Start : 0x40400000 , Len : 0x01780000 Flashing , wait ... Region flash done ===Flashing [PPM]=== File : rm607__03.35.ppm_i Image : package_i.ppm_ebl_psi.fls Cert block found, sending.... Cert sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41C00000 , Len : 0x00600000 Erasing, wait ... Erase done Write , Start : 0x41C00000 , Len : 0x0038D150 Flashing , wait ... Region flash done ===Flashing [CNT]=== File : rm607__03.35.image_i_0595568 Image : package_i_0595568.image.fls Cert block found, sending.... Cert sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x42200000 , Len : 0x01C60000 Erasing, wait ... Erase done Write , Start : 0x42200000 , Len : 0x00B80000 Flashing , wait ... Region flash done Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done No write data, skip Flashing done, rebooting... -> Infineon info : Do FullFactory Sets after flashing Flashing Done! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... Connected phone - C1-01 Software ver : V 03.35 02-12-10 RM-607 (c) Nokia IMEI : 355962040592869 Ape Ver : APE Var : APE ADSP: DSP Ver : APE Test: PPM : V 03.35 02-12-10 RM-607 (c) Nokia I CNT : Content: i_0595568 V 03.35 02-12-10 RM-607 (c) Nokia Product SN : HUC372416 Product code : 0595568 Base Prd.code: 0585582 Module code : 0204427 Long Prod.SN : 0 Hardware info======= HWID : 1001 Retu : Tahvo : Batery: 3699 mV Camera: CMT BT: 19b5-22012 APE BT: APE HW: LCDVer: TPO RF ic : Lock info =========== IMEI : 355962040592869 IMEI spNet : 3A 55 69 02 04 95 82 06 IMEI svNet : 33 55 69 02 04 95 82 06 F7 Conf key : 8BE700080700797A Provider key : 0040000005F4AC52 Provider : Unknown Provider Counters : Key 0 [3] , Fbus 0 [10] Blocks : 0 ============================= LOCKS : Damaged! ============================= CRT308 Backup Created... :) User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! |
The Following 3 Users Say Thank You to Dzirt For This Useful Post: |
02-03-2011, 01:09 | #8549 (permalink) | |
Junior Member Join Date: Sep 2007
Member: 587940 Status: Offline Thanks Meter: 8 | Quote:
what and why that LOCKS : Damaged! thanks | |
02-03-2011, 06:02 | #8550 (permalink) |
No Life Poster Join Date: Oct 2007 Location: VIZAG,A.P, INDIA
Member: 602547 Status: Offline Sonork: 100.1621466 Thanks Meter: 931 | ZTE C1602 SUCESSFULLY UNLOCKED THANKS FOR INFINITY TEAM COM76 [QCUSB_COM76_1] selected module v1.43 Device: ZTE-C1602 operation: SP-unlock Phone should be Switched ON ! connecting... conecting... ESN(hex) : 80DFDF4A ESN(hex) : 80DFDF4A Calculating spc based on esn... OFFLINE... ESN(hex) : 80DFDF4A ESN(dec) : 12814671690 trying to sending spc based on esn method 1... SPC:889780 Right spc disabling minlock... done... Phones should be restarting now... Finished, time used: 4 sec |
The Following 2 Users Say Thank You to cellcare prasad For This Useful Post: |
