02-03-2011, 08:25 | #8566 (permalink) |
No Life Poster Join Date: Apr 2009 Location: HM unlock fone mandi bahauddin
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | alcatel ot222 (cuonter block )unlock done module v3.73 Device: Alcatel-222X, 222A Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:6F23:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088BAFFFFFFFF:2088BA00000000 flash: ST Intel std [def 003Fx010000 0008x002000] 4Mb otp offset: 003F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is present rom info detection finished TCL-ID detection... TCL-ID detection done rom info ver: 05 sw version: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28.BIN project-id: MAUI.08A.W08.36.SP1.V28, 00000000 code offset: 00000000 ffs offset/size [01]: 003A0000/00058000 TCL-ID identification version: 168 provider: 222X-2ATLES1 customization: CO16NJ03 customization: XO16NJ03 TCL-ID identification done rom info structure: [standard] type (05) TCL-ID is present ffs/eeprom address assigned: 003A0000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U91X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization: XO16NJ03 customization name adjusted flash: 2088BAFFFFFFFF:2088BA00000000 flash: 2088BAFFFFFFFF:2088BA00000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 2088BAFFFFFFFF:2088BA00000000 flash: 2088BAFFFFFFFF:2088BA00000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 00004AA005E3E6 flash: 2088BAFFFFFFFF:2088BA00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 2088BAFFFFFFFF:2088BA00000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-222X,222A_JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_ 08A_W08_36_SP1_V28__system_log__00000000_20110203-121459.B0X.bin Finished, time used: 2 min 1 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to naveedbutt For This Useful Post: |
02-03-2011, 09:28 | #8568 (permalink) |
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | majoo format ffs complit done COM4 [VCP1] selected module v3.25 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:3C03:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 detecting chip #02 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 detecting chip #03 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 01227E22202200:18A59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: 01227E22202200:18A59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 it's time to stop: 18B09FA518B09FA518B09FA518B09FA518B09FA518B09FA5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (04), 1 record(s) TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.D853AD48.[MT6225_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_08_M P_V27.BIN_B6E129D2].rpl rom info detection finished device-id: D853AD48 rom info ver: 04 sw version: MT6225_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_08_M P_V27.BIN project-id: MAUI.06B.W07.08.MP.V27, D229E1B6 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [protected] type (04), 1 record(s) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF firmware area: 00000000-00DFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: MT6225_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_08_M P_V27__ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\MT6225_06B_PCB01_ GPRS_MT6225_S00.MAUI_06B_W07_08_MP_V27__ffs_201102 03-132239.B0E.bin flash: 01227E22202200:18E59F00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 01227E22202200:18E59F00000000 Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\M T6225_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_08_MP _V27__system_log_D853AD48_B6E129D2_20110203-132402.B0X.bin Finished, time used: 5 min 49 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
02-03-2011, 10:44 | #8569 (permalink) |
No Life Poster Join Date: May 2008
Member: 770503 Status: Offline Thanks Meter: 1,218 | COM3 [VCP0] selected module v3.26 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:EA03:0003 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent ==================== New firmware found (v.3.26, database date: 19.01.2011): TECHAIN25_GEMINI_PCB01_GPRS_MT6225_S00.HE35901_8_1 2_1_0T08M0318_M551A.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info ver: 04 sw version: TECHAIN25_GEMINI_PCB01_GPRS_MT6225_S00.HE35901_8_1 2_1_0T08M0318_M551A.BIN project-id: HE35901.8.12.1.0T08M0318_M551A, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [standard] type (04) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF firmware area: 00000000-00DFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: TECHAIN25_GEMINI_PCB01_GPRS_MT6225_S00.HE35901_8_1 2_1_0T08M0318_M551A__ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\TECHAIN25_GEMINI_ PCB01_GPRS_MT6225_S00.HE35901_8_12_1_0T08M0318_M55 1A__ffs_20110202-062606.B0E.bin flash: 98000300000001:18E59F00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98000300000001:18E59F00000000 Finalization Done Finished, time used: 2 min 9 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to mbiborna For This Useful Post: |
02-03-2011, 12:13 | #8570 (permalink) |
No Life Poster Join Date: Aug 2007 Location: GREAT INDIA
Member: 559113 Status: Offline Sonork: 100.1596477 Thanks Meter: 760 | ZTE s100 SP unlock done ..... COM13 [QCUSB_COM13_1] selected module v1.43 Device: ZTE-S100 operation: SP-unlock mode #2 Phone should be Switched ON ! connecting... ESN(hex) : 8060DBB9 disabling minlock... Done... Phones should be restarting now... Finished, time used: 3 sec |
The Following 2 Users Say Thank You to sonu arya For This Useful Post: |
02-03-2011, 12:21 | #8571 (permalink) |
Freak Poster Join Date: Oct 2007
Member: 619982 Status: Offline Thanks Meter: 6 | COM69 [QCUSB_COM69_1] selected module v1.43 Device: ZTE-C1602 operation: SP-unlock Phone should be Switched ON ! connecting... conecting... ESN(hex) : xxxxxxxxxxx ESN(hex) : xxxxxxxxx Calculating spc based on esn... OFFLINE... ESN(hex) : xxxxxxxxxx ESN(dec) : xxxxxxxxxxx trying to sending spc based on esn method 1... SPC:18256 wrong spc wait reconecting in 10 sec.. trying to sending spc based on esn method 2... SPC:318256 Right spc disabling minlock... done... Phones should be restarting now... Finished, time used: 15 sec |
The Following 2 Users Say Thank You to taturi1 For This Useful Post: |
02-03-2011, 12:30 | #8572 (permalink) |
No Life Poster Join Date: Jan 2008 Location: Uruguay
Member: 679135 Status: Offline Sonork: 100.1606448 Thanks Meter: 436 | TV-Mobile G10 Code: ==== [02/02/2011 08:28:21 p.m.] ==== COM3 [VCP0] selected module v3.26 Device: Autodetect 6228-6253 NAND Checking data, wait... Action: reset settings ("format ffs") NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0058]: 002C:00A100800015 [MICRON] MT29F1G08ABB chip size: 128Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: S_DA_RAM_ERROR done Set baudrate (921600)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 03000000/05000000 firmware size: 48Mb ffs size: 80Mb detect sec ro... detect custom parameters... detect project-id... project-id: E710_PX116NOGPS.01.0 detect NAND info... number of areas/bytes to read: 1:001A0000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... bootloader version: E710_BOOTLOADER_V005_MT6235B_01_1.bin nfi area detection (3 cores) finished: Ok warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: E710_PX116NOGPS_PCB01_GPRS_MT6235B_S01.01_0.BIN project-id: E710_PX116NOGPS.01.0, 00000000 code offset: 00000000 rom info structure: [standard] type (07) TCL-ID is absent ===> done ==================== New firmware found (v.3.26, database date: 19.01.2011): E710_PX116NOGPS_PCB01_GPRS_MT6235B_S01.01_0.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== warning: can not format: HW_STORAGE_NOR is not present Format... Disconnect... done Finished, time used: 1 min 22 sec Firmaware: http://rapidshare.com/files/44589340...192629.B4M.bin Label: Model: G10 TV Mobile GSM850/900/1800/1900MHz |
The Following User Says Thank You to hvalero2001 For This Useful Post: |
02-03-2011, 13:17 | #8573 (permalink) |
No Life Poster Join Date: Aug 2008 Location: brazil Age: 47
Member: 846805 Status: Offline Sonork: alex cavalcante Thanks Meter: 261 | COM1 [Serial0] selected Mَdulo v3.64 Dispositivo: Alcatel-363X, 363A Verificando Dados. Aguarde... Detecçمo Avançada da Flash Habilitada Action: rebuild security area ====> Boot ... Pressione e SEGURE o Botمo de Ligar! 19200 fixed Conectando. Aguarde... Inicializando [6223:8A05:8A00]... CPU: MT6223 chip: 0011:9E78:A00C status: 01 Tamanho do Pacote de Inicializaçمo: 0400 Solte o Botمo de Ligar! Boot Done ====> Inicializar ... detecting chip #00 in region #00... Flash EC240200000000:2BEA0000000000 Flash Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 Nْmero do Chip da Flash/Regiمo Detectada: 01/01 Inicializar Done ====> Determinar Velocidade ... 115200 Determinar Velocidade Done ====> Inicializar Cَdigo de Boot ... Inicializar Cَdigo de Boot Done ====> Verificar Integridade do Firmware ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... Aviso: wrong cs at 0x0001E840, retry... read error recovered search rom info finished rom info structure: [protected] type (05), 1 record(s) TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Arquivos de programas\InfinityBox\MModule\backup_security\id.D 46E38B2.[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V9.BIN_99950412].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: D46E38B2 rom info ver: 05 sw version: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V9.BIN project-id: MAUI.08A.W08.36.SP1.V9, 12049599 code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 TCL-ID identification Versمo: 26F provider: 363X-2AVDES1 Customizaçمo CI26DH35 Customizaçمo XI26DH35 TCL-ID identification done rom info structure: [protected] type (05), 1 record(s) TCL-ID is present ffs/eeprom address assigned: 00C00000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished Estado do Travamento do Cartمo SIM: enabled product id: JRD_COMMUNICATION_U82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected Customizaçمo XI26DH35 customization name adjusted Flash EC240200000000:2BEA0000000000 Flash EC240200000000:2BEA0000000000 Escrever security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... Feito Flash EC240200000000:2BEA0000000000 Flash EC240200000000:2BEA0000000000 Escrever security area (sec info, hash) security area (sec info, hash) calculation done Verificar Integridade do Firmware Done ====> Verificar Conteْdo do Firmware ... Verificar Conteْdo do Firmware Done ====> Salvar Cَpia de Dados ... IMEI Original: FFFFFFFFFFFFFF Flash EC240200000000:2BEA0000000000 Salvar Cَpia de Dados Done ====> Programar Dados Necessلrios ... Programar Dados Necessلrios Done ====> Operaçمo Especial ... Operaçمo Especial Done ====> Escrever ... Escrever Done ====> Finalizaçمo ... FFS formatting... Flash EC240200000000:2BEA0000000000 Finalizaçمo Done Arquivo Salvo: C:\Arquivos de programas\InfinityBox\MModule\backup_security\Alca tel-363X,363A_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08 A_W08_36_SP1_V9__system_log_D46E38B2_99950412_2011 0202-194245.B0X.bin Finalizado. Tempo Gasto: 2 min 45 sec Remova/Recoloque a Bateria! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to Alexandro Monte For This Useful Post: |
02-03-2011, 13:28 | #8574 (permalink) |
No Life Poster Join Date: Dec 2007 Location: INDIA
Member: 665989 Status: Offline Sonork: 100.1597348 Thanks Meter: 552 | c1602 Successful Thanks Infinity Team c1602 Successful Thanks Infinity Team Code: COM93 [QCUSB_COM93_1] selected module v1.43 Device: ZTE-C1602 operation: SP-unlock Phone should be Switched ON ! connecting... conecting... ESN(hex) : 802E4002 ESN(hex) : 802E4002 Calculating spc based on esn... OFFLINE... ESN(hex) : 802E4002 ESN(dec) : 12803031042 trying to sending spc based on esn method 1... SPC:3320 wrong spc wait reconecting in 10 sec.. trying to sending spc based on esn method 2... SPC:523320 Right spc disabling minlock... done... Phones should be restarting now... Finished, time used: 15 sec |
The Following User Says Thank You to ABDUL RAJA For This Useful Post: |
02-03-2011, 13:45 | #8575 (permalink) |
No Life Poster Join Date: May 2008 Location: persian Age: 43
Member: 777729 Status: Offline Sonork: 100.1616470 Thanks Meter: 824 | Nokia 7230 write ppm only done by best Software ver : V 09.83 21-09-10 RM-604 (c) Nokia Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : PPM : rm598__09.83.ppm_meac Flashing phone now... Check files done... -> SWversion check skipped : Custom mode selected Backup CRT308 data... CRT308 Backup Created... Check communication with phone.... ADL req restart Communication verify done... Preparing... Gathering phone info... Check communication with phone... Reboot.... Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000010000022600000001020C192102044100 EM0 ID: 00001040 EM1 ID: 00001030 PUBLIC ID: 0C200219B6825440017CD762F614790FE12555B4 ASIC MODE ID: 00 ROOT KEY HASH: 7B045400E1752022F9EB80B0DEA9C65D ROM ID: 67E82268F29CEA60 Use RAP3Gv40_2nd.fg Rev : 3.0 Ver : 10.43.0 Processing RAWLOADER... FLIC : 00300098 Req : XSR 1.6 Use RAP3Gv40_XSR17_alg.fg Rev : 3.0 Ver : 10.43.0 Boot Done! TIME : Boot time : 00:00:01 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 354832043804341 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Cert Read done! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : F:\BEST-INFINITY\Backup\Cert\354XXXXXXXX1.rpl ===Flashing [PPM]=== Erase : Processing rm598__09.83.ppm_meac Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing rm598__09.83.ppm_meac Total writen 22 blocks TIME : Write time : 00:00:07 PPM Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ADL: Close_Session Content: 000300000000000000000000000000 ADL: Reboot Flashing done! Total flash time : 00:00:08 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 7230 Software Info: V 09.83 21-09-10 RM-604 (c) Nokia IMEI: 354XXXXXXXXXX PPM version : V 09.83 21-09-10 RM-598 (c) Nokia MEC Product code: 0590626 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Checking User Certificates... Total - 34 certs Data exist, skip certificate repair... AfterFlash operations done... Reconnect, wait... Done! Elapsed: 00:00:35 Connect phone on selected interface... |
The Following 2 Users Say Thank You to sirnavid2010 For This Useful Post: |
02-03-2011, 14:46 | #8576 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Marocunlocking™
Member: 248858 Status: Offline Sonork: 100.1608346 Thanks Meter: 216 | COM152 [VCP0] selected module v1.73 Périphérique: Sagem-my220x Contrôle des données, attendre ... Action: "sp-unlock" unlock method-1 Boot ... Appuyez et restez appuiez sur le bouton "Power" dès maintenant! e-gold: 820010 loading... middle part... next part... boot answer: 01 lachez bouton d'alimentation maintenant! Boot Done Ensemble bauds ... slowest Ensemble bauds Done Connecting ... Flash 0001:011A Connecting Done Check hardware ... sw version: 8 EBI_IO_101207_1704 EBI_IO 101207_1704 Thhmm Dddmmmyyyy 0123 Check hardware Done Check parameters ... Check parameters Done backup critical area ... lecture eeprom-static... fichier sauvegardé: C:\Program Files\InfinityBox\Pana01\Sagem-my220x_eeprom-static_20110203-134330.B1E.bin loading data... wrong database file: C:\Program Files\InfinityBox\Pana01\v226_eep65535.cfg erreur: can't load database v.16 lecture eeprom-security... fichier sauvegardé: C:\Program Files\InfinityBox\Pana01\Sagem-my220x_eeprom-security_20110203-134331.B1E.bin lecture eeprom-complete... fichier sauvegardé: C:\Program Files\InfinityBox\Pana01\Sagem-my220x_eeprom-complete_20110203-134336.B1E.bin reading additional data... fichier sauvegardé: C:\Program Files\InfinityBox\Pana01\Sagem-my220x_lock-area_20110203-134403.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found Check memory Done écrire ... Erasing: lock-area Writing: lock-area écrire Done Terminé, temps utilisé: 1 min 23 sec Retirez / remettre la batterie maintenant! |
The Following User Says Thank You to pikiche For This Useful Post: |
02-03-2011, 15:04 | #8577 (permalink) |
No Life Poster Join Date: Jan 2007 Location: Romania
Member: 428861 Status: Offline Sonork: 100.1619141 Thanks Meter: 1,629 | K220i Sonny Ericsson K220i succesfully unlocked. Thank you Infinity Team. BR. COM253 [VCP1] selected module v1.38 Device: Sony-Ericsson-K220i "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! loading... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 01227E22212200:92EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb software version: R1AD001 software version: CXC1251013 version flex: CDA102807/43 imei: 3524340235xxxx Check hardware done Read data ... reading Sony-Ericsson-K220i_3524340235xxxx_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-K220i_35243402358288_eeprom_calibration-1_20110207-155525.80E.bin reading Sony-Ericsson-K220i_3524340235xxxx_eeprom_calibration-2... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-K220i_3524340235xxxx_eeprom_calibration-2_20110207-155535.80E.bin Read data done Check data ... Check data done Write ... flash: 01227E22212200:46237300000000 Write: eeprom flash: 01227E22212200:46237300000000 Write: eeprom ............... locks cleared Write done Finished, time used: 50 sec Remove/Install battery now ! |
The Following User Says Thank You to danrachita For This Useful Post: |
02-03-2011, 15:19 | #8578 (permalink) |
Member: 846805 Status: Offline Sonork: alex cavalcante Thanks Meter: 261 | COM1 [Serial0] selected Mَdulo v3.64 Action: reset settings ("format ffs") Modelo: LG-GX200 Verificando Dados. Aguarde... O Telefone Deverل Estar DESLIGADO! Pressione e SEGURE o Botمo de Ligar! 19200 autodetect Inicializando [6235:8A04:8A01]... CPU: MT6235 chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Solte o Botمo de Ligar! Telefone Encontrado. Aguarde... Hardware: MT6235,E04 Data: 2000.00.00 Versمo: 1.0 Versمo: GX200-00-V10f-724-XX-MAR-26-2010 Versمo: ARIMA6235_GEMINI_09A_HW 82 byte(s) read IMEI: 35405104275098 Conectado building list... Feito items to clear: 274 Aviso: wrong packet cs Aviso: wrong packet cs items cleared: 274 of 274 building list... Feito Itens Restantes: 0 Finalizado. Tempo Gasto: 36 sec Remova/Recoloque a Bateria! |
02-03-2011, 15:19 | #8579 (permalink) |
No Life Poster Join Date: May 2007 Location: uk
Member: 508072 Status: Offline Thanks Meter: 1,621 | COM2 [VCP2] selected module v3.62 Device: Spice-S404N Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard fast Unlock procedure can be faster if you skip ffs/eeprom area backup procedure. Do you want to disable ffs/eeprom backup ? ffs/eeprom backup disabled ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6205:8B00]... CPU: MT6205 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: DA2213DD00DD02:18E59F00000000 flash: DA2213DD00DD02:18E59F00000000 flash: Winbond [T 0008x002000 003Fx010000] 4Mb otp offset: 003F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) > if phone works fine just ignore this warning < ffs/eeprom address can not be detected, value from database assigned: 00300000/00100000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: DA2213DD00DD02:18E59F00000000 flash: DA2213DD00DD02:18E59F00000000 Backup required data Done ====> Patch required data ... ......... lock area found Patch required data Done ====> Special operation ... detecting parameters to apply patch area 1... ..... required data found flash: DA2213DD00DD02:18E59F00000000 flash: DA2213DD00DD02:18E59F00000000 flash: DA2213DD00DD02:18E59F00000000 flash: DA2213DD00DD02:18E59F00000000 Write: area 1 (pass 1) ........... area 1 patch applied Ok detecting parameters to apply patch area 2... ................ error: area 2 can not apply patch detecting parameters to apply patch area 3... ................ error: area 3 can not apply patch detecting parameters to apply patch area 4... ................ error: area 4 can not apply patch Special operation Done ====> Write ... flash: DA2213DD00DD02:18E59F00000000 flash: DA2213DD00DD02:18E59F00000000 flash: DA2213DD00DD02:18E59F00000000 flash: DA2213DD00DD02:18E59F00000000 Write: lock-area-1 Write Done ====> Finalization ... Finalization Done Finished, time used: 1 min 34 sec Remove/Install battery now ! |
The Following User Says Thank You to joni_rajpura For This Useful Post: |
02-03-2011, 15:48 | #8580 (permalink) |
Member: 428861 Status: Offline Sonork: 100.1619141 Thanks Meter: 1,629 | Wx395 Motorola WX395 succesfully unlocked. Thank you Infinity Team. BR. COM2 [VCP0] selected module v3.62 Device: Motorola-WX395 Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:EF03:A00D status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC240200000000:08EA0000000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... usb bootloader (chip) is present: 00020000 searching rom info... search rom info finished rom info structure: [protected] type (05), 1 record(s) TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.5003B DC9.[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN_D5D1415C].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: 5003BDC9 rom info ver: 05 sw version: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN project-id: MAUI.06B.W07.28.SP1.V38, 5C41D1D5 code offset: 00020000 ffs offset/size [01]: 00C00000/00400000 TCL-ID identification version: 27G provider: M395X-2BRGRO1 customization: CJ27YP72 customization: XJ27YP72 TCL-ID identification done rom info structure: [protected] type (05), 1 record(s) TCL-ID is present ffs/eeprom address assigned: 00C00000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRD_COMMUNICATION_B82X_PRODUCTS area1 is valid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished sim-lock status: enabled product id: JRD_COMMUNICATION_B82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is invalid searching sec info#3... search sec info#3 finished sim-lock status: enabled product id: JRD_COMMUNICATION_B82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 security area (sec info, cust) calculation... error: security area (sec info, cust) header is invalid security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: EC240200000000:08EA0000000000 flash: EC240200000000:08EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected customization: XJ27YP72 customization name adjusted flash: EC240200000000:08EA0000000000 flash: EC240200000000:08EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... version is not found in database: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN use default security area (sec info, hash) pattern max address is too big, should be recalculated: 08BF8000->08BF4004 ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: EC240200000000:08EA0000000000 flash: EC240200000000:08EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected customization: XJ27YP72 customization name adjusted flash: EC240200000000:08EA0000000000 flash: EC240200000000:08EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... version is not found in database: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN use default security area (sec info, hash) pattern max address is too big, should be recalculated: 08BF8000->08BF4004 ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: EC240200000000:08EA0000000000 flash: EC240200000000:08EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: FFFFFFFFFFFFFF flash: EC240200000000:08EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: EC240200000000:08EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Motorola-WX395_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07 _28_SP1_V38__system_log_5003BDC9_D5D1415C_20110203-164334.B0X.bin Finished, time used: 3 min 58 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
