02-01-2011, 20:44 | #8521 (permalink) |
No Life Poster Join Date: Feb 2007 Location: Mongolia
Member: 444532 Status: Offline Sonork: 100.1576960 Thanks Meter: 215 | COM3 [VCP0] selected module v1.78 Device: ZTE-A36 Checking data, wait... Action: reset settings ("format ffs") Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 460800 Set Baud Done Connecting ... flash: 00EC:22A0 Connecting Done Check hardware ... Check hardware Done Check parameters ... sw version: .00 P108A6 SST V1.0.0B06 P108A6V1.0.0B06 g3dBV2.0 Dec 7 2007 14 Check parameters Done backup critical area ... reading eeprom-static... file saved: D:\Program Files\InfinityBox\Pana01\ZTE-A36_eeprom-static_20110115-130845.B1E.bin loading data... data loaded reading eeprom-security... file saved: D:\Program Files\InfinityBox\Pana01\ZTE-A36_eeprom-security_20110115-130845.B1E.bin reading eeprom-complete... file saved: D:\Program Files\InfinityBox\Pana01\ZTE-A36_eeprom-complete_20110115-130847.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... reset... done Write Done Finished, time used: 20 sec Remove/Install battery now ! |
The Following User Says Thank You to shuric For This Useful Post: |
02-01-2011, 20:44 | #8522 (permalink) |
Member: 444532 Status: Offline Sonork: 100.1576960 Thanks Meter: 215 | Sagem-my150x sp-unlock done. COM3 [VCP0] selected module v1.78 Device: Sagem-my150x Checking data, wait... Action: "sp-unlock" unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820010 loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... Check hardware Done Check parameters ... sw version: 8 EAI_IC_300707_1408 300707_1408 EAI_IC Thhmm Dddmmmyyyy 0123 Check parameters Done backup critical area ... reading eeprom-static... file saved: D:\Program Files\InfinityBox\Pana01\Sagem-my150x_eeprom-static_20101129-160123.B1E.bin loading data... data loaded reading eeprom-security... file saved: D:\Program Files\InfinityBox\Pana01\Sagem-my150x_eeprom-security_20101129-160124.B1E.bin reading eeprom-complete... file saved: D:\Program Files\InfinityBox\Pana01\Sagem-my150x_eeprom-complete_20101129-160125.B1E.bin reading additional data... file saved: D:\Program Files\InfinityBox\Pana01\Sagem-my150x_lock-area_20101129-160129.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 30 sec Remove/Install battery now ! |
02-01-2011, 20:45 | #8523 (permalink) |
Member: 444532 Status: Offline Sonork: 100.1576960 Thanks Meter: 215 | BENQ E61 flashing OK. COM3 [VCP0] selected module v1.33 Device: BenQ E61 Checking data, wait... Action: flash write "smart write" active Write: Firmware Write: Flex Write: Language Pack Skip: Eeprom Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... 812500 Set Baud Done Check Flash... Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0089:881200010001 flash: Intel 128MBit-T Strata T 16Mb Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Write: Firmware Flash: 0089:881200010001 flash: Intel 128MBit-T Strata T 16Mb flash: Intel 128MBit-T Strata T 16Mb Write: Flex Flash: 0089:881200010001 flash: Intel 128MBit-T Strata T 16Mb Write: Language Pack flash: Intel 128MBit-T Strata T 16Mb Writing Done Finished, time used: 48 sec Remove/Install battery now ! |
02-01-2011, 20:46 | #8524 (permalink) |
Member: 444532 Status: Offline Sonork: 100.1576960 Thanks Meter: 215 | LG-KG245 message not opening problem solved OK. COM3 [VCP0] selected module v1.39 Device: LG-KG245 Checking data, wait... advanced flash detection enabled Action: reset Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 01227E223C2200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb id: 0000527A Boot Done Set baud ... 460800 Set baud Done Check flash ... current eeprom imei: 350305260000001 file saved: D:\Program Files\InfinityBox\LGA\eeprom_350305260000001_LG-KG245_20101205-141543.B1E.bin .......... version: XXX-XXV10k07KG245P64 reading XXX-XXV10k07KG245P64_eeprom-ffs_350305260000001... file saved: D:\Program Files\InfinityBox\LGA\XXX-XXV10k07KG245P64_eeprom-ffs_350305260000001_LG-KG245_20101205-142454.B1E.bin Check flash Done Check space ... Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... Write Done Finished, time used: 685 sec Remove/Install battery now ! PS: Vygis can't solved this problem. thanks infinity team. |
02-02-2011, 07:46 | #8525 (permalink) |
No Life Poster Join Date: Dec 2005
Member: 213172 Status: Offline Sonork: 1582799 Thanks Meter: 265 | COM6 [VCP1] selected module v1.78 Device: LG-GB102 Checking data, wait... Action: "sp-unlock" read unlock codes Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 007F:22F6 Connecting Done Check hardware ... Check hardware Done Check parameters ... sw version: .01 ULC2GL 2008-03-17 1.0 TMO_UK GB102 01 FL 44 V10a 234-30 M Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-GB102_eeprom-static_20110202-114246.B1E.bin loading data... data loaded imei: 35761602355201300 reading eeprom-security_35761602355201300... file saved: C:\Program Files\InfinityBox\Pana01\LG-GB102_eeprom-security_35761602355201300_20110202-114247.B1E.bin reading eeprom-complete_35761602355201300... file saved: C:\Program Files\InfinityBox\Pana01\LG-GB102_eeprom-complete_35761602355201300_20110202-114248.B1E.bin backup critical area Done Check memory ... loading data... data loaded code: 90724153 Finished, time used: 18 sec Remove/Install battery now ! |
The Following User Says Thank You to abdulwajid147 For This Useful Post: |
02-02-2011, 07:49 | #8526 (permalink) |
Product Supporter Join Date: Aug 2007 Location: karachi
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | 1800 flash done registered to: saeedullah_khan DLL not found... Connect phone on selected interface... UFS S/N 82121 boot - Ok Connect phone on selected interface... Selected FlashSettings : Manual Files Set for Flashing : MCU : rm653_006.200 PPM : rm653_006.20ia CNT : rm6530_nai06.20ia Infineon flashing... Booting phone now.... Sync Ok , A2 CPU ID : XGOLD , A200341100 Boot Ok , 01 PBL : SE0_091125 F11 Algo Ok , 01 SBL mode Ok SBL : Default_RAM_Bootloader EPP CFG [Bering]... FLASH ID : 00EC000000542200 FLASH ID : Samsung, K8S6415E Boot Done! ===Flashing [MCU]=== File : rm653_006.200 Image : hw_b2_rm653_r06.200.fls Cert block found, sending.... Cert sent Found 3 region(s) Processing Region 1/3 Erase , Start : 0x00800000 , Len : 0x00210000 Erasing, wait ... Erase done Write , Start : 0x00800000 , Len : 0x00210000 Flashing , wait ... Region flash done Processing Region 2/3 Erase , Start : 0x00C60000 , Len : 0x0020A0C0 Erasing, wait ... Erase done Write , Start : 0x00C60000 , Len : 0x0020A0C0 Flashing , wait ... Region flash done Processing Region 3/3 Erase , Start : 0x00FFC000 , Len : 0x00000040 Erasing, wait ... Erase done Write , Start : 0x00FFC000 , Len : 0x00000040 Flashing , wait ... Region flash done Check : 7CCF ===Flashing [PPM]=== File : rm653_006.20ia Image : hw_b2_rm653_006.20ia.fls Cert block found, sending.... Cert sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x00210000 , Len : 0x001F3900 Erasing, wait ... Erase done Write , Start : 0x00210000 , Len : 0x001F3900 Flashing , wait ... Region flash done Check : D0C0 ===Flashing [CNT]=== File : rm6530_nai06.20ia Image : hw_b2_rm6530_nai06.20ia.fls Cert block found, sending.... Cert sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x00EB0000 , Len : 0x00054B00 Erasing, wait ... Erase done Write , Start : 0x00EB0000 , Len : 0x00054B00 Flashing , wait ... Region flash done Check : 19AB Flashing done, rebooting... -> Infineon info : Do FullFactory Sets after flashing Flashing Done! Init Service mode... Wait... Afterflash settings... SW ver : V 06.20 01-12-10 RM-653 (c) Nokia IMEI : 351544043749912 PCode : 0594990 Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! All done! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
The Following 2 Users Say Thank You to saeedullah_khan For This Useful Post: |
02-02-2011, 07:57 | #8527 (permalink) |
Member: 213172 Status: Offline Sonork: 1582799 Thanks Meter: 265 | COM6 [VCP1] selected module v3.63 Action: "sp-unlock" unlock method: smart fast Model: Vodafone-340 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:9103:A009 status: 01 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: BM35A1.V2.22.M00.02.44 Version: FOXLINK25_08B_HW 81 byte(s) read imei: 35592203521869 connection Ok 186 byte(s) read reading data... reading data #2... building new data... writing data... 174 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 14 sec Remove/Install battery now ! |
02-02-2011, 08:26 | #8528 (permalink) |
Freak Poster Join Date: Jun 2010 Location: Denmark
Member: 1329373 Status: Offline Thanks Meter: 87 | NKTEL DEAD OK COM3 [VCP0] selected module v3.25 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") Do you want to make ffs/eeprom backup before format ? ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:F803:000E status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC240200000000:18E59F00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 detecting chip #01 in region #00... flash: EC240200000000:18E59F00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 detecting chip #02 in region #00... flash: EC240200000000:18E59F00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 detecting chip #03 in region #00... flash: EC240200000000:18E59F00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: EC240200000000:18E59F00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 detecting chip #01 in region #00... flash: EC240200000000:18E59F00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (04), 1 record(s) TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.C9A78EE0.[E55_ABROAD_PCB01_GPRS_MT6225_S00.E55_F_ABROAD_33AT A_S5_TM_V1_2_2.BIN_1C9520E0].rpl rom info detection finished device-id: C9A78EE0 rom info ver: 04 sw version: E55_ABROAD_PCB01_GPRS_MT6225_S00.E55_F_ABROAD_33AT A_S5_TM_V1_2_2.BIN project-id: E55_F_ABROAD_33ATA_S5_TM_V1.2.2, E020951C code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [protected] type (04), 1 record(s) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF firmware area: 00000000-00DFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: EC240200000000:18E59F00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: EC240200000000:18E59F00000000 Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\E 55_ABROAD_PCB01_GPRS_MT6225_S00.E55_F_ABROAD_33ATA _S5_TM_V1_2_2__system_log_C9A78EE0_1C9520E0_201102 02-121557.B0X.bin Finished, time used: 1 min 7 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to AL-KARAM MOBILE For This Useful Post: |
02-02-2011, 08:27 | #8529 (permalink) |
No Life Poster Join Date: Oct 2005 Location: georgia tbilisi
Member: 194939 Status: Offline Sonork: 100.168.25.6 Thanks Meter: 623 | vodafone 345 unlocked ok using alcatel s320 cable COM4 [VCP0] selected module v3.73 Device: Vodafone-345 Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:5651:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088BAFFFFFFFF:2088BA00000000 flash: ST Intel std [def 003Fx010000 0008x002000] 4Mb otp offset: 003F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is present rom info detection finished TCL-ID detection... TCL-ID detection done rom info ver: 05 sw version: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28_F1.BIN project-id: MAUI.08A.W08.36.SP1.V28.F1, 00000000 code offset: 00000000 ffs offset/size [01]: 003A0000/00058000 TCL-ID identification version: 865 provider: V345X-2CVDGB1 customization: CM86FE30 customization: XM86FE30 TCL-ID identification done rom info structure: [standard] type (05) TCL-ID is present ffs/eeprom address assigned: 003A0000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: disabled product id: JRD_COMMUNICATION_U91X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization: XM86FE30 customization name adjusted flash: 2088BAFFFFFFFF:2088BA00000000 flash: 2088BAFFFFFFFF:2088BA00000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 2088BAFFFFFFFF:2088BA00000000 flash: 2088BAFFFFFFFF:2088BA00000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 00008A10E3B5A0 flash: 2088BAFFFFFFFF:2088BA00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 2088BAFFFFFFFF:2088BA00000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Vodafone-345_JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W0 8_36_SP1_V28_F1__system_log__00000000_20110202-105431.B0X.bin Finished, time used: 1 min 26 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to laduka For This Useful Post: |
02-02-2011, 08:33 | #8530 (permalink) |
Member: 1329373 Status: Offline Thanks Meter: 87 | S100 CHINA DEAD OK COM3 [VCP0] selected module v3.25 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") Do you want to make ffs/eeprom backup before format ? ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:A6EE:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:2BEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC257E25082501:2BEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #02 in region #00... flash: EC257E25082501:2BEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #03 in region #00... flash: EC257E25082501:2BEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: EC257E25082501:2BEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC257E25082501:2BEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (04), 1 record(s) TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.100FB111.[Z224H_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_28_MP_V4 .BIN_C5134610].rpl ==================== New firmware found (v.3.25, database date: 24.10.2010): Z224H_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_28_MP_V4 .BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished device-id: 100FB111 rom info ver: 04 sw version: Z224H_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_28_MP_V4 .BIN project-id: MAUI.08A.W08.28.MP.V4, 104613C5 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [protected] type (04), 1 record(s) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF firmware area: 00000000-00DFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: EC257E25082501:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: EC257E25082501:2BEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\Z 224H_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_28_MP_V4_ _system_log_100FB111_C5134610_20110202-122820.B0X.bin Finished, time used: 1 min 13 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
02-02-2011, 09:08 | #8531 (permalink) |
No Life Poster Join Date: May 2007 Location: InsidE AndroiD Age: 37
Member: 503161 Status: Offline Sonork: 100.1584069 Thanks Meter: 474 | Vodafone340 unlocked COM47 [VCP0] selected module v3.17 Action: "sp-unlock" unlock method: smart fast Model: Vodafone-340 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:FD03:A00C status: 01 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: BM35A1.V2.22.M00.02.40 Version: FOXLINK25_08B_HW 81 byte(s) read imei: 35592203002416 connection Ok 186 byte(s) read reading data... reading data #2... building new data... writing data... 174 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 12 sec Remove/Install battery now ! |
The Following User Says Thank You to azeem781986 For This Useful Post: |
02-02-2011, 09:21 | #8532 (permalink) |
No Life Poster Join Date: Nov 2004 Age: 45
Member: 93284 Status: Offline Thanks Meter: 202 | WX395 unlock OK Use cable Alcatel S320 Code: COM3 [VCP0] selected module v3.73 Device: Motorola-WX395 Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:E103:A00B status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC240200000000:08EA0000000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... usb bootloader (chip) is present: 00020000 searching rom info... search rom info finished rom info structure: [protected] type (05), 1 record(s) TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.04B314C9.[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP1_V38.BIN_D5D1415C].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: 04B314C9 rom info ver: 05 sw version: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP1_V38.BIN project-id: MAUI.06B.W07.28.SP1.V38, 5C41D1D5 code offset: 00020000 ffs offset/size [01]: 00C00000/00400000 TCL-ID identification version: 27G provider: M395X-2BRGPL1 customization: CJ27YS71 customization: XJ27YS71 TCL-ID identification done rom info structure: [protected] type (05), 1 record(s) TCL-ID is present ffs/eeprom address assigned: 00C00000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRD_COMMUNICATION_B82X_PRODUCTS area1 is invalid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished sim-lock status: enabled product id: JRD_COMMUNICATION_B82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is invalid searching sec info#3... search sec info#3 finished sim-lock status: enabled product id: JRD_COMMUNICATION_B82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 security area (sec info, cust) calculation... error: security area (sec info, cust) header is invalid security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: EC240200000000:08EA0000000000 flash: EC240200000000:08EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected customization: XJ27YS71 customization name adjusted flash: EC240200000000:08EA0000000000 flash: EC240200000000:08EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... version is not found in database: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP1_V38.BIN use default security area (sec info, hash) pattern max address is too big, should be recalculated: 08BF8000->08BF4004 ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: EC240200000000:08EA0000000000 flash: EC240200000000:08EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected customization: XJ27YS71 customization name adjusted flash: EC240200000000:08EA0000000000 flash: EC240200000000:08EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... version is not found in database: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP1_V38.BIN use default security area (sec info, hash) pattern max address is too big, should be recalculated: 08BF8000->08BF4004 ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: EC240200000000:08EA0000000000 flash: EC240200000000:08EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: FFFFFFFFFFFFFF flash: EC240200000000:08EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: EC240200000000:08EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Motorola-WX395_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP1_V38__system_log_04B314C9_D5D1415C_20110202-083724.B0X.bin Finished, time used: 3 min 0 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to owiec77 For This Useful Post: |
02-02-2011, 09:40 | #8533 (permalink) |
No Life Poster Join Date: May 2008 Location: persian Age: 43
Member: 777729 Status: Offline Sonork: 100.1616470 Thanks Meter: 824 | 6500s rm240 flash done by best Connect phone on selected interface... Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm240__10.30.mcusw PPM : rm240__10.30.ppm_c CNT : rm240__10.30_ISM_001.image_c_tr_ctv_tr Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. [BB5 FLASH]: Bootrom Ok! RAP_PUB: 02D001181BE88B56BE14CE9FCDEB59ED457C6714 CMT_ROOT: BAF3A9C3DBFA8454937DB77F2B8852B1 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:00 Reopening the connection... Waiting for response: 30 ADL Server confirm flashmode! ===Flashing [MCU]=== Erase : Processing rm240__10.30.mcusw Found 5 areas to erase Erasing area 0x00000000 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00040000 - 0x000BFFFF, NOR, CMT Result: 0000 Erasing area 0x000C0000 - 0x0013FFFF, NOR, CMT Result: 0000 Erasing area 0x01480000 - 0x015FFFFF, NOR, CMT Result: 0000 Erasing area 0x00140000 - 0x0147FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:01:24 Write : Processing rm240__10.30.mcusw Total 1316 [1316/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] TIME : Write time : 00:02:16 MCU Write done ===Flashing [PPM]=== Erase : Processing rm240__10.30.ppm_c Found 1 areas to erase Erasing area 0x01600000 - 0x01CBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:25 Write : Processing rm240__10.30.ppm_c Total 411 [411/0/0] blocks to write, writing... TIME : Write time : 00:00:43 PPM Write done ===Flashing [CNT]=== Checking content info... Check Image : Content size is 128k, use direct write mode Erase : Processing rm240__10.30_ISM_001.image_c_tr_ctv_tr Found 2 areas to erase Erasing area 0x01FC0000 - 0x03F9FFFF, NOR, CMT Result: 0000 Erasing area 0x01CC0000 - 0x01FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:02:12 Write : Processing rm240__10.30_ISM_001.image_c_tr_ctv_tr Total 736 [736/0/0] blocks to write, writing... TIME : Write time : 00:01:12 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:08:16 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 6500s-1 Software Info: V 10.30 23-04-09 RM-240 (c) Nokia IMEI: 356905031680325 PPM version : V 10.30 23-04-09 RM-240 (c) Nokia C Product code: 0549734 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! AfterFlash operations done... Reconnect, wait... Done! Elapsed: 00:09:01 Connect phone on selected interface... |
The Following 2 Users Say Thank You to sirnavid2010 For This Useful Post: |
02-02-2011, 09:43 | #8534 (permalink) |
Member: 777729 Status: Offline Sonork: 100.1616470 Thanks Meter: 824 | Nokia C5-00 flash done by best Connected phone - Nokia C5-00 Software ver : V ICPR82_10w18.5.2 16-07-10 RM-645 (c) Nokia IMEI : 354330049398798 Ape Ver : 032.010 APE Var : 032.010032.010.10.01032.010.C00.01 APE ADSP: 256 DSP Ver : ICPR82_10w18.5.1 APE Test: rm645_ENO_v_0.ncp71_17_001 PPM : CNT : Product SN : CIS062796 Product code : 0593762 Base Prd.code: 0591907 Module code : 0204492 Long Prod.SN : 0 Hardware info======= HWID : 6001 Retu : 35 Tahvo : 00 Batery: 3865 mV Camera: CMT BT: APE BT: HCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12652. APE HW: 256 LCDVer: RF ic : Lock info =========== IMEI : 354330049398798 IMEI spNet : 3A 45 33 00 94 93 78 09 IMEI svNet : 33 45 33 00 94 93 78 19 F1 Conf key : 0000000000000000 Provider key : 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= CRT308 Backup Created... User code : Crypted UserDataExLevel : Low [Gallery] Done! Reading LifeTimer data... LifeTime is: 37225 seconds Phone works: 10 Hours; 20 minutes; 25 seconds Done BackUp UserData : [PhoneBook] Generation mode : [S60] Check phone mode... Phone in Normal mode Seting Test mode... wait... Test mode set SmartPhone algo initialise... Setup data... StartUp FileSystem... Fsrun OK... Detect Symbian OS Generation... Detected: [Symbian OS 9.3/9.4] Phone! Warning! Many [9.3] and [9.4] phones not supported now Running : APE_TEST_SERVER,w03_09,(c)NMP w0Found! Will read 31 blocks... Sorry, FS error : Phone not answer... Error during read... Error during read... BackUp UserData : [PhoneBook] Generation mode : [S60] Operating mode is OK, no need change... SmartPhone algo initialise... Setup data... StartUp FileSystem... Fsrun OK... Detect Symbian OS Generation... Detected: [Symbian OS 9.3/9.4] Phone! Warning! Many [9.3] and [9.4] phones not supported now Running : APE_TEST_SERVER,w03_09,(c)NMP w0Found! Will read 31 blocks... Sorry, FS error : Phone not answer... Error during read... Error during read... Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm645_032.010_prd.core.fpsx PPM : rm645_032.010_11.01_MEA_C_prd.rofs2.fpsx PPM2 : rm645_032.010_C00.01_DEFAULT_prd.rofs3.fpsx CNT : rm645_ENO_v_0.NCP17_APEONLY.fpsx APE : rm645_032.010_U000.000_prd.uda.fpsx Flashing phone now... Check files done... -> SWversion check skipped : Manual mode selected Backup CRT308 data... CRT308 Backup Created... Check communication with phone.... ADL req restart Communication verify done... Preparing... Gathering phone info... Check communication with phone... Batery valtage : 3790 mV -> Batery voltage less, than 3,8V (3790mV). Continue at user risk Reboot.... Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000030000022600010007600C192102031104 EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: 0660010C88A2034489A03243420E8FC1311FEEF0 ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B Use RAPUv11_2nd.fg Rev : 3.0 Ver : 10.43.0 Processing RAWLOADER... FLIC : 00400020 Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg Rev : 3.0 Ver : 10.43.0 Boot Done! TIME : Boot time : 00:00:01 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 354330049398798 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Cert Read done! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : F:\BEST-INFINITY\Backup\Cert\354330049398798.rpl ===Flashing [MCU]=== Erase : Processing rm645_032.010_prd.core.fpsx Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing rm645_032.010_prd.core.fpsx CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [SOS+PMML] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [SOS*UPDAPP] CMT: Writing Hash CERT [SOS*DSP0] CMT: Writing Hash CERT [LDSP] CMT: Writing Hash CERT [SOS*ISASW] CMT: Writing Hash CERT [SOS+CORE] CMT: Writing Hash CERT [SOS+ROFS1] Total writen 388 blocks TIME : Write time : 00:00:15 MCU Write done ADL: Request programm status NAND status : 00000002 / 00000002 / 00000000 ===Flashing [PPM]=== Erase : Processing rm645_032.010_11.01_MEA_C_prd.rofs2.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm645_032.010_11.01_MEA_C_prd.rofs2.fpsx CMT: Writing Hash CERT [SOS+ROFS2] Total writen 161 blocks TIME : Write time : 00:00:06 PPM Write done ADL: Request programm status NAND status : 00000002 / 00000002 / 00000000 ===Flashing [PPM2]=== Erase : Processing rm645_032.010_C00.01_DEFAULT_prd.rofs3.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm645_032.010_C00.01_DEFAULT_prd.rofs3.fpsx CMT: Writing Hash CERT [SOS+ROFS3] Total writen 2 blocks TIME : Write time : 00:00:00 PPM Write done ADL: Request programm status NAND status : 00000002 / 00000002 / 00000000 ===Flashing [CNT]=== Erase : Processing rm645_ENO_v_0.NCP17_APEONLY.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm645_ENO_v_0.NCP17_APEONLY.fpsx CMT: Writing Hash CERT [SOS*ENO] Total writen 11 blocks TIME : Write time : 00:00:00 CNT Write done ADL: Request programm status NAND status : 00000002 / 00000002 / 00000000 ===Flashing [APE]=== Erase : Processing rm645_032.010_U000.000_prd.uda.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm645_032.010_U000.000_prd.uda.fpsx Total writen 8 blocks TIME : Write time : 00:00:00 APE Write done ADL: Request programm status NAND status : 00000002 / 00000002 / 00000000 ADL: Close_Session Content: 000300000000020000000200000000 ADL: Reboot Flashing done! Total flash time : 00:00:27 Reboot phone now... |
02-02-2011, 11:05 | #8535 (permalink) |
Member: 93284 Status: Offline Thanks Meter: 202 | Vodafone 547 flash OK Use cable GS101 Code: COM3 [VCP0] selected module v3.73 Device: Vodafone-547 Checking data, wait... Action: write flash NAND write: Firmware editor_corrected_editor_corrected_editor_corrected_Vodafone-547_ZTENJ35_09A_PCB01_GPRS_MT6235B_S01.VF_GER_DE_P107A4V1_2_0B05_2010-06-18_En_De.B4M.bin.B4M.bin.B4M.bin.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... nfi scat area detected (3 areas) nfi area detection (3 cores) finished: Ok interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0017]: 00AD:007600AD0076 [HYNIX] HY27XS08121M chip size: 64Mb page/spare size: 0200/0010 pages per block: 0020 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: S_DA_RAM_ERROR done Set baudrate (921600)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/01C00000 firmware size: 32Mb ffs size: 28Mb detect sec ro... detect custom parameters... detect project-id... project-id: VF_GER_DE_P107A4V1.2.0B05 detect NAND info... number of areas/bytes to read: 1:00034000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... bootloader version: ZTENJ35_OG_09A_BOOTLOADER_V005_MT6235B_ORANGE_ENG_EN_P107A3V1_0_ nfi area detection (3 cores) finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: ZTENJ35_09A_PCB01_GPRS_MT6235B_S01.VF_GER_DE_P107A4V1_2_0B05.BIN project-id: VF_GER_DE_P107A4V1.2.0B05, 00000000 code offset: 00000000 ffs offset/size [01]: 02000000/01C00000 rom info structure: [standard] type (07) TCL-ID is absent ===> done nfi area detection... nfi scat area detected (3 areas) nfi area detection (3 cores) finished: Ok startup code area #1 check... done number of cores: 3 loading files... number of areas: 3 done write... write bootloader... . . write core... Disconnect... done Finished, time used: 6 min 56 sec Remove/Install battery now ! BR |
