![]() | #7021 (permalink) |
Temporary banned !! ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2009 Location: P.H Age: 38
Member: 1151970 Status: Offline Sonork: 100.1597000 Thanks Meter: 378 | motorola wx180 unlock via Infinity Box done ![]() ![]() COM13 [VCP0] selected module v3.70 Device: Motorola-WX180 Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:68A1:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E221A2201:2BEA0000000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb otp offset: 003F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is present rom info detection finished TCL-ID detection... TCL-ID detection done rom info ver: 05 sw version: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28_F1.BIN project-id: MAUI.08A.W08.36.SP1.V28.F1, 00000000 code offset: 00000000 ffs offset/size [01]: 003A0000/00058000 TCL-ID identification version: 33D provider: M180X-2AVRGB1 customization: CS33JI32 customization: XS33JI32 TCL-ID identification done rom info structure: [standard] type (05) TCL-ID is present ffs/eeprom address assigned: 003A0000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U91X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization: XS33JI32 customization name adjusted flash: 01227E221A2201:2BEA0000000000 flash: 01227E221A2201:2BEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... max address is too big, should be recalculated: 0827D124->08267590 ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 01227E221A2201:2BEA0000000000 flash: 01227E221A2201:2BEA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35668103247886 flash: 01227E221A2201:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 01227E221A2201:2BEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Motorola-WX180_JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_ W08_36_SP1_V28_F1__system_log__00000000_20101205-223114.B0X.bin Finished, time used: 1 min 55 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! ![]() |
The Following User Says Thank You to KIKO_GSM For This Useful Post: |
![]() | #7022 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2007 Location: punjab(india) Age: 45
Member: 467045 Status: Offline Sonork: 100.1603919 Thanks Meter: 1,705 | nokia 6270 flashing done card found: S/N 0390:0118 registered to: jindalgsm DLL not found... Connect phone on selected interface... Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm56b5003.90.mcusw.bin PPM : rm56b5003.90.ppm_c CNT : rm56b5003.90.image_c Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. [BB5 FLASH]: Bootrom Ok! RAP_PUB: 1470010EDCC9515621B9EDB0AC3B0283B0A5CF24 CMT_ROOT: BAF3A9C3DBFA8454937DB77F2B8852B1 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:05 Reopening the connection... Waiting for response: 30 Wait for device bootup ADL Server confirm flashmode! ===Flashing [MCU]=== Erase : Processing rm56b5003.90.mcusw.bin Found 4 areas to erase Erasing area 0x00180000 - 0x00B69DB5, NOR, CMT Result: 0000 Erasing area 0x00000000 - 0x000FFFFF, NOR, CMT Result: 0000 Erasing area 0x00120000 - 0x0017FFFF, NOR, CMT Result: 0000 Erasing area 0x00C00000 - 0x0117FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:02:09 Write : Processing rm56b5003.90.mcusw.bin Total 725 [725/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [PAPUBKEYS] CMT : PAPUBKEYS skip, already sent CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [PMM_CONF] CMT : Writing Hash CERT [SBIF_CONF] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [MCUSW] TIME : Write time : 00:01:26 MCU Write done ===Flashing [PPM]=== Erase : Processing rm56b5003.90.ppm_c Found 1 areas to erase Erasing area 0x00C00000 - 0x0117FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing rm56b5003.90.ppm_c Total 297 [297/0/0] blocks to write, writing... TIME : Write time : 00:00:36 PPM Write done ===Flashing [CNT]=== Checking content info... Resetting phone... MMC pwd backup saved Checking CNT sector PN<>FL PN CNT sector : 64 kb Loader len: 241984, CHK: A4C9 ADL -> Sending loader... Reset connection... Erase : Processing rm56b5003.90.image_c Found 1 areas to erase Erasing area 0x01180000 - 0x01FDFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:01:52 Write : Processing rm56b5003.90.image_c Total 300 [300/0/0] blocks to write, writing... TIME : Write time : 00:00:34 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:06:40 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 6270 Software Info: V 03.90 09-02-07 RM-56 (c) Nokia. IMEI: 353259012208786 PPM version : V 03.90 09-02-07 RM-56 (c) Nokia. C Product code: 0529956 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 0 certs Uploading certificates... Invalid CSkey! Can't write file! No data, delete skipped Writen 21 certs! AfterFlash operations done... Reconnect, wait... Done! Elapsed: 00:07:51 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok ![]() ![]() ![]() |
The Following 3 Users Say Thank You to JINDALGSM For This Useful Post: |
![]() | #7023 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2005 Location: Georgia GE
Member: 162473 Status: Offline Sonork: Not have Thanks Meter: 592 ![]() | read flash for add russian language Code: COM8 [VCP0] selected module v3.25 Device: Autodetect 6228-6253 NAND Checking data, wait... Action: read firmware NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0043]: 0098:00D000000015 [TOSHIBA] TC58NWM9S3B chip size: 64Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: S_DA_RAM_ERROR done Set baudrate (921600)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/02000000 firmware size: 32Mb ffs size: 32Mb detect sec ro... detect custom parameters... detect project-id... project-id: MAUI_08B_W09_16_MP_V141 detect NAND info... number of areas/bytes to read: 1:001A0000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... bootloader version: HEXING35_08B_GEMINI_BOOTLOADER_V005_MT6235B_MAUI_08B_W09_16_MP_V nfi area detection (3 cores) finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: HEXING35_08B_GEMINI_PCB01_GPRS_MT6235B_S01.MAUI_08B_W09_16_MP_V141.BIN project-id: MAUI_08B_W09_16_MP_V141, 00000000 code offset: 00000000 ffs offset/size [01]: 02000000/02000000 rom info structure: [standard] type (07) TCL-ID is absent ===> done ==================== New firmware found (v.3.25, database date: 30.11.2010): HEXING35_08B_GEMINI_PCB01_GPRS_MT6235B_S01.MAUI_08B_W09_16_MP_V141.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== area size: 32Mb number of areas/bytes to read: 1:02000000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... file saved: C:\Documents and Settings\Administrator\Desktop\bb777\HEXING35_08B_GEMINI_PCB01_GPRS_MT6235B_S01.MAUI_08B_W09_16_MP_V141__firmware_20101206-123532.B4M.bin Disconnect... done Finished, time used: 13 min 12 sec Remove/Install battery now ! HEXING35_08B_GEMINI_PCB01_GPRS_MT6235B_S01.MAUI_08 B_W09_16_MP_V141.BIN Same as BB but no more info or label Please down & up http://rapidshare.com/files/43520960...123532.B4M.bin |
The Following User Says Thank You to IkaMazini For This Useful Post: |
![]() | #7024 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2010 Location: INDIA (WEST BENGAL)
Member: 1426012 Status: Offline Sonork: ICQ#618627674 Thanks Meter: 886 | 7210 success full flash by best card found: S/N -----:------ registered to: NILOY Connect phone on selected interface... UFS S/N ------ boot - Ok Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia 7210 Supernova Software ver : V 04.86 08-08-08 RM-436 (c) Nokia IMEI : 351962034657177 Ape Ver : APE Var : APE ADSP: DSP Ver : ICPR72_08w30 APE Test: PPM : V 04.86 08-08-08 RM-436 (c) Nokia MR CNT : ˜g XD{ >b(_ASX~8ti„t—00U Product SN : DAP108108 Product code : 0572571 Base Prd.code: 0563951 Module code : 0203868 Long Prod.SN : 0 Hardware info======= HWID : 1001 Retu : 15 Tahvo : 22 Batery: 4725 mV Camera: CMT BT: Error APE BT: Error APE HW: Error LCDVer: Error RF ic : Error Lock info =========== IMEI : 351962034657177 IMEI spNet : IMEI svNet : Conf key : 0000000000000000 Provider key : 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= User Code : 5555555555 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Selected FlashSettings : FullFlash Files Set for Flashing : MCU : rm436__07.23.mcusw PPM : rm436__07.23.ppm_mr CNT : rm436__07.23.image_mr Check FlashFiles, Please, wait... Backup enabled, Will read Certificates now... Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B22 CMT PUB ID : 139000165FA87D56A9B15F0505269AB80D1C49A0 CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg CMT Loader sent, Boot Ok CMT Flash ID: 89820089 < INTEL => 0046L0Y1GG FLASHID : 89820089 , CMT , NOR FLCNT : 00000000000000000000000000000000 FLMCID : FFFF000000000000 Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg CMT Algo sent CMT PAPUB : DCA5EA5203CD30A64D4D95ABCD621F4AB23026F100 Transmission mode : Dual (Ddr, TX2) Boot Done! CMT : Read NPC certificate... Cert size : 20480 byte(s) IMEI : 351962034657177 CMT : Read CCC certificate... Cert size : 30600 byte(s) CMT : Read HWC certificate... Cert size : 20480 byte(s) CMT : Read VARIANT certificate... Cert size : 0 byte(s) Cert Read done! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : C:\Program Files\Best_v1.10.1\Best\Backup\Cert\35196203465717 7.rpl Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B22 CMT PUB ID : 139000165FA87D56A9B15F0505269AB80D1C49A0 CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg CMT Loader sent, Boot Ok CMT Flash ID: 89820089 < INTEL => 0046L0Y1GG FLASHID : 89820089 , CMT , NOR FLCNT : 00000000000000000000000000000000 FLMCID : FFFF000000000000 Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg CMT Algo sent CMT PAPUB : DCA5EA5203CD30A64D4D95ABCD621F4AB23026F100 Transmission mode : Dual (Ddr, TX2) Boot Done! Transmission mode : Dual (Ddr, TX2) Erase : Processing rm436__07.23.mcusw Found 6 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x00000000 - 0x000006BF CMT , NOR , Area : 0x000006C0 - 0x0001FFFF CMT , NOR , Area : 0x00040000 - 0x000BFFFF CMT , NOR , Area : 0x000C0000 - 0x0013FFFF CMT , NOR , Area : 0x00140000 - 0x0119FFFF CMT , NOR , Area : 0x011A0000 - 0x0133FFFF Using TimeOut : 5 min ( 300 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:01:25 Transmission mode : Dual (Ddr, TX2) Write : Processing rm436__07.23.mcusw CMT: Writing Hash CERT [NOLO] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] Total writen 1161 blocks TIME : Write time : 00:02:30 Transmission mode : Dual (Ddr, TX2) Erase : Processing rm436__07.23.ppm_mr Found 1 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01340000 - 0x01BDFFFF Using TimeOut : 5 min ( 300 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:33 Transmission mode : Dual (Ddr, TX2) Write : Processing rm436__07.23.ppm_mr Total writen 454 blocks TIME : Write time : 00:00:57 CNT : Converted to 128k page data exist Transmission mode : Dual (Ddr, TX2) Erase : Processing rm436__07.23.image_mr_128 Found 2 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01BE0000 - 0x01F7FFFF CMT , NOR , Area : 0x01F80000 - 0x03FBFFFF Using TimeOut : 5 min ( 300 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:04:09 Transmission mode : Dual (Ddr, TX2) Write : Processing rm436__07.23.image_mr_128 Total writen 532 blocks TIME : Write time : 00:01:06 Init Service mode... Wait... Reading Phone Info.... Connected phone - Nokia 7210 Supernova Software Info: V 07.23 17-07-09 RM-436 (c) Nokia IMEI: 351962034657177 Product code: 0572571 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Product code update... Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! AfterFlash operations done... Reconnect, wait... Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Connect phone on selected interface... |
The Following 3 Users Say Thank You to niloy2007 For This Useful Post: |
![]() | #7025 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: May 2007 Location: uk
Member: 508072 Status: Offline Thanks Meter: 1,621 | haire c2030 unlock checking version... HA2030MT04 Haier C2030 version 04 selected.. Sending command... pacthing in progress... Finished, time used: 18 sec |
The Following User Says Thank You to joni_rajpura For This Useful Post: |
![]() | #7026 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2006 Location: TUNIS Age: 45
Member: 287132 Status: Offline Sonork: 1236544 Thanks Meter: 96 ![]() | K200i unlocked succefully Device: Sony-Ericsson-K200i "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! loading... Boot done Check connection ... Check connection done Set baud ... 812500 Set baud done Check hardware ... flash: 01227E22212200:92EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb software version: R1AA003 software version: CXC1250827 version flex: CDA102772/1 imei: 35617701470866 Check hardware done Read data ... reading Sony-Ericsson-K200i_35617701470866_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-K200i_35617701470866_eeprom_calibration-1_20101206-103354.80E.bin reading Sony-Ericsson-K200i_35617701470866_eeprom_calibration-2... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-K200i_35617701470866_eeprom_calibration-2_20101206-103357.80E.bin Read data done Check data ... Check data done Write ... flash: 01227E22212200:46237300000000 Write: eeprom flash: 01227E22212200:46237300000000 Write: eeprom .... .... .......... locks cleared Write done Finished, time used: 22 sec Remove/Install battery now ! |
The Following User Says Thank You to medgsm1 For This Useful Post: |
![]() | #7027 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: May 2007
Member: 511801 Status: Offline Sonork: 100.1590673 Thanks Meter: 46 | zong ZTE R221 unlock done COM6 [VCP1] selected module v3.70 Action: "sp-unlock" unlock method: smart fast Model: ZTE-R221 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:413D:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: E-PK-T9SM-P109A17V1.0.0B02 Version: ZTENJ23D_09A_HW 86 byte(s) read imei: 35926403109553 connection Ok 192 byte(s) read reading data... reading data #2... building new data... writing data... 180 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 17 sec Remove/Install battery now ! |
The Following User Says Thank You to Afzaal Aslam For This Useful Post: |
![]() | #7028 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Aug 2007 Location: GREAT INDIA
Member: 559113 Status: Offline Sonork: 100.1596477 Thanks Meter: 760 | Huawei c-2906 done COM24 [VCP0] selected module v1.41 Device: Huawei-C2906 operation: SP-unlock Phone should be Switched ON ! connecting... checking version... C2906C53B108 C2906C53B108 Huawei C2906 version B108 selected.. OFFLINE... downloading mode... erasing... patching in progress... patching in progress 20%... patching in progress 40%... patching in progress 60%... patching in progress 80%... patching in progress 100%... DONE... Phones should be restarting now... Finished, time used: 56 sec |
The Following 2 Users Say Thank You to sonu arya For This Useful Post: |
![]() | #7029 (permalink) |
Member: 1426012 Status: Offline Sonork: ICQ#618627674 Thanks Meter: 886 | HAIER C5100 version 37 success full unlock COM50 [QCUSB_COM50_1] selected module v1.41 Device: Haier-C5100 operation: SP-unlock Phone should be Switched ON ! connecting... checking version... C5100-HSP-R00.00.37 HAIER C5100 version 37 selected.. Sending command... patching in progress... patching in progress 50%... patching in progress 100%... Done... Phones should be restarting now... Finished, time used: 20 sec |
The Following 2 Users Say Thank You to niloy2007 For This Useful Post: |
![]() | #7030 (permalink) |
Registered User ![]() ![]() ![]() ![]() Join Date: Jun 2006
Member: 291029 Status: Offline Thanks Meter: 97 | successfull fullflash beyonf B555 restart with card COM7 [VCP2] selected module v1.78 Device: Beyond-B555 Checking data, wait... Action: write flash write: Firmware Beyond-B555_2007-Dec-27_fw_lp.B1M.bin skip: FFS-1/Customization skip: Language Pack skip: Graphics Pack skip: FFS-2/File system skip: Eeprom Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... Check hardware Done Check parameters ... sw version: .00 ULC2GL ^ g 0 A h 0 q Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Beyond-B555_eeprom-static_20101206-070707.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Beyond-B555_eeprom-security_20101206-070708.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Beyond-B555_eeprom-complete_20101206-070714.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... reset... done Erasing: Firmware Writing: Firmware Erasing: Firmware Writing: Firmware Write Done Finished, time used: 7 min 44 sec Remove/Install battery now ! |
The Following User Says Thank You to raditya For This Useful Post: |
![]() | #7031 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2008 Location: some were in my head Age: 42
Member: 922273 Status: Offline Sonork: 100.1583612 Thanks Meter: 119 | COM3 [VCP0] selected module v1.38 Device: Alcatel-E101 "advanced chip detection" active Action: flash write "smart write" active skip: Firmware skip: Flex/Customization skip: Language Pack write: FFS/File system E101_repair_ffs_05[1].80E.bin skip: Images skip: Melody skip: Eeprom Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 812500 Set baud done Check hardware ... flash: 012A7E2A242A00:54000000000000 flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb Check hardware done Read data ... reading Alcatel-E101_eeprom_calibration-1... file saved: D:\InfinityBox\HModule\Alcatel-E101_eeprom_calibration-1_20101202-152212.80E.bin Read data done Check data ... Check data done Write ... Area: FFS/File system flash: 012A7E2A242A00:54000000000000 Write: FFS/File system Write done Finished, time used: 1 min 12 sec Remove/Install battery now ! |
The Following User Says Thank You to GFTELECOM For This Useful Post: |
![]() | #7032 (permalink) |
Member: 922273 Status: Offline Sonork: 100.1583612 Thanks Meter: 119 | COM3 [VCP0] selected module v1.38 Device: Alcatel-E101 "advanced chip detection" active Action: flash write "smart write" active write: Firmware E101A_firmware_U71A_300_NOSAW_Orange[1].80M.bin skip: Flex/Customization skip: Language Pack skip: FFS/File system skip: Images skip: Melody skip: Eeprom Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... rom version: 0502 booting... Boot fail error: operation failed Finished, time used: 5 sec Remove/Install battery now ! Loading file v.02... E101A_firmware_U71A_300_NOSAW_Orange[1].80M.bin loaded ==== log: [02/12/2010 15:28:31] ==== COM3 [VCP0] selected module v1.38 Device: Alcatel-E101 "advanced chip detection" active Action: flash write "smart write" active write: Firmware E101A_firmware_U71A_300_NOSAW_Orange[1].80M.bin skip: Flex/Customization skip: Language Pack skip: FFS/File system skip: Images skip: Melody skip: Eeprom Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 812500 Set baud done Check hardware ... flash: 012A7E2A242A00:54000000000000 flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb Check hardware done Read data ... reading Alcatel-E101_eeprom_calibration-1... file saved: D:\InfinityBox\HModule\Alcatel-E101_eeprom_calibration-1_20101202-152926.80E.bin Read data done Check data ... Check data done Write ... Area: Firmware flash: 012A7E2A242A00:54000000000000 Write: Firmware Write done Finished, time used: 1 min 49 sec Remove/Install battery now ! |
![]() | #7033 (permalink) |
Member: 922273 Status: Offline Sonork: 100.1583612 Thanks Meter: 119 | COM3 [VCP0] selected module v3.25 Action: reset settings ("format ffs") Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:4D05:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: D386.SW.V00.03.YIDALONG Version: D386_V01_HW detecting structure #2... 1 2 5 7 8 9 11 13 18 19 22 24 25 26 28 30error: detection failed (16 tries), read flash and send to support connection Ok building list... done items to clear: 109 warning: wrong packet cs items cleared: 109 of 109 building list... done items remains: 0 Finished, time used: 37 sec Remove/Install battery now ! |
![]() | #7034 (permalink) |
Member: 922273 Status: Offline Sonork: 100.1583612 Thanks Meter: 119 | COM3 [VCP0] selected module v3.70 Device: Alcatel-108X Checking data, wait... advanced flash detection enabled Action: read ffs/eeprom ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:75B3:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 8C22F60000000D:2BEA0000000000 flash: AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb otp offset: 003F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is present rom info detection finished TCL-ID detection... TCL-ID detection done rom info ver: 05 sw version: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28_F1.BIN project-id: MAUI.08A.W08.36.SP1.V28.F1, 00000000 code offset: 00000000 ffs offset/size [01]: 003A0000/00058000 TCL-ID identification version: 66H provider: 108X-2BM1TE1 customization: CM66CN41 customization: XM66CN41 TCL-ID identification done rom info structure: [standard] type (05) TCL-ID is present ffs/eeprom address assigned: 003A0000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: disabled product id: JRD_COMMUNICATION_U91X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: Alcatel-108X_JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W 08_36_SP1_V28_F1__ffs... file saved: C:\Documents and Settings\Administrateur\Bureau\maj ifinity\flash\ot108\Alcatel-108X_JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W 08_36_SP1_V28_F1__ffs_20101203-100139.B0E.bin original imei: FFFFFFFFFFFFFF file saved: D:\InfinityBox\MModule\backup_security\Alcatel-108X_JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W 08_36_SP1_V28_F1__system_log__00000000_20101203-100157.B0X.bin Finished, time used: 1 min 59 sec Remove/Install battery now ! |
![]() | #7035 (permalink) |
Member: 1426012 Status: Offline Sonork: ICQ#618627674 Thanks Meter: 886 | Huawei C2807 Jul 15 success full unlock checking version... Jul 15 2009C2807C0HB102 Jul 15 2009C2807C0HB102 Huawei C2807 Jul 15 selected.. OFFLINE... downloading mode... erasing... patching in progress... patching in progress 30%... patching in progress 40%... patching in progress 50%... patching in progress 60%... patching in progress 70%... patching in progress 80%... patching in progress 100%... DONE... Phones should be restarting now... Finished, time used: 1 min 33 sec |
