![]() | #16981 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2007 Location: Buy Buy Thank U GsmHostig .... Age: 41
Member: 462292 Status: Offline Thanks Meter: 397 | C2010 module v1.83 Device: Haier-C2000, C2010, C3000, C3010, C5000 old operation: SP-unlock Phone should be Switched ON ! connecting... OFFLINE... disabling minlock... Done... Phones should be restarting now... Finished, time used: 5 sec |
The Following User Says Thank You to kalpeshoza For This Useful Post: |
![]() | #16982 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2008 Location: MANSEHRA
Member: 921094 Status: Offline Sonork: 100.1603246 Thanks Meter: 326 | Nokia 110 rm_827 flash done NOKIA 110 RM827 FLASH DONE registered to: NASEERConnect phone on selected interface... Core : v1.48 , FlashEngine : v1.7 Selected FlashSettings : FullFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm827__03.04.mcusw PPM : rm827__03.04.ppm_s1 CNT : rm827__03.04.image_s1_059N3Q0 Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" - just reinsert battery -> If flashing freeze - reinsert cable and try again --- Press phone's power button or insert charger! --- Connection opened successfully DBG : F00A1FB300020303010100FF CPUID : XGOLD 213 2nd boot Ok, 01 2nd ready, AA Sending Algo Algo sent Ok BL : Quantum_Bootloader_10.49_M1S1 Speed accepted, use 6.500.000 FLASHID : 89008289 FLIC conf set, RST set Boot done! Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 353273055178665 IMEI 2 : 353273055178673 PCcode : ¼À€‘N¾™ NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\353273055178665_35 3273055178673_XG213_CRT.rpl ===Flashing [MCU]=== File : rm827__03.04.mcusw Image : rm827__03.04.mcusw_ebl_psi.fls Cert block found, sending.... Cert sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:05 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01940000 Erasing, wait ... Erase done, time : 00:02:16 Write , Start : 0x40280000 , Len : 0x018C0000 Flashing , wait ... Region flash done, time : 00:00:37 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip ===Flashing [PPM]=== File : rm827__03.04.ppm_s1 Image : package_s1.ppm_ebl_psi.fls Cert block found, sending.... Cert sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41BC0000 , Len : 0x00600000 Erasing, wait ... Erase done, time : 00:00:20 Write , Start : 0x41BC0000 , Len : 0x003F1DEC Flashing , wait ... Region flash done, time : 00:00:04 ===Flashing [CNT]=== File : rm827__03.04.image_s1_059N3Q0 Image : package_s1_059N3Q0.image.fls Cert block found, sending.... Cert sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x421C0000 , Len : 0x01C60000 Erasing, wait ... Erase done, time : 00:02:58 Write , Start : 0x421C0000 , Len : 0x01060000 Flashing , wait ... Region flash done, time : 00:00:21 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:05 No write data, skip Flashing done! Total flash time : 00:06:53 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 110 Software Info: V 03.04 20-04-12 RM-827 (c) Nokia IMEI: 353273055178665 PPM version : V 03.04 20-04-12 RM-827 (c) Nokia S1 Product code: 059N416 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! Product code update... Checking User Certificates... Total - 42 certs Data exist, skip certificate repair... Set phone to Normal mode... AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:07:36 Connect phone on selected interface... ![]() |
The Following User Says Thank You to naseer_mansehra For This Useful Post: |
![]() | #16983 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2008 Location: sai baba shirdi Age: 44
Member: 670629 Status: Offline Sonork: 100.1590208 Thanks Meter: 431 | COM21 [VCP0] selected Action: unlock Device: C113(a),C114,C115,C116,C117,C118 Checking data, wait... Connect... Press and HOLD Power button... connection mode: 00 Release Power button ! Connect Done Boot... Boot Done Set Baud... 115200 Set Baud Done Check Flash-1... SW version: 2.5.78.N. HW version: _E88 imei otp: 353618011132364 Check Flash-1 Done Check Flash-2... reading ... file saved: C:\Program Files\Moto01\backup_eeprom_calibration_35361801113 2364_20120908-131112.18E.bin imei eeprom: 353618011132364 extra method pass-1... reading ... extra method pass-2... Check Flash-2 Done Write... Write Done Finished, time used: 51 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to d.jain For This Useful Post: |
![]() | #16984 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2010 Location: INDIA (WEST BENGAL)
Member: 1426012 Status: Offline Sonork: ICQ#618627674 Thanks Meter: 886 | samsung-s189 COM2 [VCP0] selected module v1.89 Device: Samsung-SCH-S189 operation: SP-unlock Phone should be Switched ON ! connecting... Connecting, wait... Phone detected, wait... step-1 done step-2 done step-3 done operation finished Finished, time used: 17 sec |
![]() | #16985 (permalink) |
Member: 1426012 Status: Offline Sonork: ICQ#618627674 Thanks Meter: 886 | lg-3530 COM2 [VCP0] selected module v1.89 Device: LG-3530 operation: Repair "Blink" Phone should be Switched ON ! connecting... file selected: D:\CDMA\RELINCE BLINK REPAIR\relince-extracet file\RD3530_SCR.bin QSC6010-RD3530 QSC6010-RD3530 LG RD3530 selected.. sending boot.. erasing... done.... =======W.A.R.N.I.N.G======= DO NOT REMOVE THE PHONE..!! |
![]() | #16986 (permalink) |
Member: 1426012 Status: Offline Sonork: ICQ#618627674 Thanks Meter: 886 | Samsung-SCH-B139, B189 COM2 [VCP0] selected module v1.89 Device: Samsung-SCH-B139, B189 operation: SP-unlock Phone should be Switched ON ! connecting... Connecting, wait... Phone detected, wait... step-1 done step-2 done step-3 done operation finished Finished, time used: 18 sec |
![]() | #16987 (permalink) |
Member: 1426012 Status: Offline Sonork: ICQ#618627674 Thanks Meter: 886 | Samsung-SCH-S189 COM2 [VCP0] selected module v1.89 Device: Samsung-SCH-S189 operation: SP-unlock Phone should be Switched ON ! connecting... Connecting, wait... Phone detected, wait... step-1 done step-2 done step-3 done operation finished Finished, time used: 18 sec |
![]() | #16988 (permalink) |
Member: 1426012 Status: Offline Sonork: ICQ#618627674 Thanks Meter: 886 | Samsung-SCH-S189 COM2 [VCP0] selected module v1.89 Device: Samsung-SCH-S189 operation: SP-unlock Phone should be Switched ON ! connecting... Connecting, wait... Phone detected, wait... step-1 done step-2 done step-3 done operation finished Finished, time used: 17 sec |
![]() | #16989 (permalink) |
Member: 1426012 Status: Offline Sonork: ICQ#618627674 Thanks Meter: 886 | Haier-C5100 COM28 [QCUSB_COM28_1] selected module v1.89 Device: Haier-C5100 operation: SP-unlock Phone should be Switched ON ! connecting... checking version... C5100-HSP-R00.00.36-MTSAug 07 2009 C5100-HSP-R00.00.36-MTSAug 07 2009 HAIER C5100 Aug 07 2009 selected.. Downloading mode... Sending boot... patching in progress... Done... Phones should be restarting now... Finished, time used: 7 sec |
![]() | #16990 (permalink) |
Member: 1426012 Status: Offline Sonork: ICQ#618627674 Thanks Meter: 886 | Haier-C5100 again COM28 [QCUSB_COM28_1] selected module v1.89 Device: Haier-C5100 operation: SP-unlock Phone should be Switched ON ! connecting... checking version... C5100-HSP-R00.00.36-MTSAug 07 2009 C5100-HSP-R00.00.36-MTSAug 07 2009 HAIER C5100 Aug 07 2009 selected.. Downloading mode... Sending boot... patching in progress... Done... Phones should be restarting now... Finished, time used: 7 sec |
![]() | #16991 (permalink) |
Member: 1426012 Status: Offline Sonork: ICQ#618627674 Thanks Meter: 886 | Haier-C5100 flashing COM28 [QCUSB_COM28_1] selected module v1.89 Device: Haier-C5100 operation: Write Flash Phone should be Switched ON ! connecting... checking conection... emergency download... sending boot... Start flashing... =======W.A.R.N.I.N.G======= DO NOT REMOVE THE PHONE..!! |
![]() | #16992 (permalink) |
Member: 1426012 Status: Offline Sonork: ICQ#618627674 Thanks Meter: 886 | LG-3520 blink COM2 [VCP0] selected module v1.89 Device: LG-3520 operation: Repair "Blink" Phone should be Switched ON ! connecting... file selected: D:\CDMA\RELINCE BLINK REPAIR\relince-extracet file\TS3520_SCR.BIN QSC6010-TS3520 QSC6010-TS3520 LG RD3520 selected.. sending boot.. erasing... done.... =======W.A.R.N.I.N.G======= DO NOT REMOVE THE PHONE..!! ------------------------------------------------------------- |
![]() | #16993 (permalink) |
Member: 1426012 Status: Offline Sonork: ICQ#618627674 Thanks Meter: 886 | LG-3510 blink COM2 [VCP0] selected module v1.89 Device: LG-3510 operation: Repair "Blink" Phone should be Switched ON ! connecting... file selected: D:\CDMA\RELINCE BLINK REPAIR\relince-extracet file\RD3510_SCR.bin QSC6010-RD3510 QSC6010-RD3510 LG RD3510 selected.. sending boot.. erasing... done.... =======W.A.R.N.I.N.G======= DO NOT REMOVE THE PHONE..!! ------------------------------------------------------------- |
![]() | #16994 (permalink) |
Member: 1426012 Status: Offline Sonork: ICQ#618627674 Thanks Meter: 886 | Samsung-SCH-S189 COM7 [VCP0] selected module v1.88 Device: Samsung-SCH-S189 operation: SP-unlock Phone should be Switched ON ! connecting... Connecting, wait... Phone detected, wait... step-1 done step-2 done step-3 done operation finished Finished, time used: 18 sec |
![]() | #16995 (permalink) |
Member: 1426012 Status: Offline Sonork: ICQ#618627674 Thanks Meter: 886 | Rainbow-mts-S189 ==== [8/8/2012 6:36:13 PM] ==== COM7 [VCP0] selected module v1.88 Device: Rainbow-mts-S189 operation: SP-unlock Phone should be Switched ON ! connecting... Connecting, wait... Phone detected, wait... step-1 done step-2 done step-3 done operation finished Finished, time used: 17 sec |
