09-09-2012, 08:50 | #17026 (permalink) |
No Life Poster Join Date: Nov 2007 Location: karachi pakistan
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | registered to: amc_khan Connect phone on selected interface... Core : v1.51 , FlashEngine : v1.8 Selected FlashSettings : Manual Check FlashFiles, Please, wait... -> Flash Files are NOT selected! You can Select: S40 : Any, but MCU need present in filelist S60 : Any, but CORE/MCU need present in filelist S60 APE : MCU+PPM, MCU+PPM+CNT Core : v1.51 , FlashEngine : v1.8 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : C5F02102_rm495__07.97.mcusw PPM : rm495__07.90.ppm_mena_b CNT : E24393CE_rm495__07.97.image_mena_a1_red Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. ASIC ID: 000000010000022600010006030C192101033000 CPU ID : RAP3Gv3 , Features : No any extended features RAP_PUB: 14900209F3137E5692767136ABA557EB3FABD71D CMT_ROOT: 9DDBFCFE6E73CED7D8C6268C8EB85723 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:06 Reopening the connection... Waiting for response: 30 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing C5F02102_rm495__07.97.mcusw Found 6 areas to erase Erasing area 0x00000000 - 0x000006BF, NOR, CMT Result: 0000 Erasing area 0x000006C0 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00040000 - 0x000BFFFF, NOR, CMT Result: 0000 Erasing area 0x000C0000 - 0x0013FFFF, NOR, CMT Result: 0000 Erasing area 0x00140000 - 0x0137FFFF, NOR, CMT Result: 0000 Erasing area 0x01380000 - 0x0151FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:02:41 Write : Processing C5F02102_rm495__07.97.mcusw Total 1178 [1178/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] TIME : Write time : 00:01:02 MCU Write done ===Flashing [PPM]=== Erase : Processing rm495__07.90.ppm_mena_b Found 1 areas to erase Erasing area 0x01520000 - 0x01DBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:01:04 Write : Processing rm495__07.90.ppm_mena_b Total 404 [404/0/0] blocks to write, writing... TIME : Write time : 00:00:20 PPM Write done ===Flashing [CNT]=== Erase : Processing E24393CE_rm495__07.97.image_mena_a1_red Found 2 areas to erase Erasing area 0x01DC0000 - 0x0215FFFF, NOR, CMT Result: 0000 Erasing area 0x02160000 - 0x03FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:05:39 Checking content info... Check Image : Content size is 128k, use direct write mode Write : Processing E24393CE_rm495__07.97.image_mena_a1_red Total 656 [656/0/0] blocks to write, writing... TIME : Write time : 00:00:38 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:11:27 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 5130c-2 Software Info: V 07.97 13-09-10 RM-495 (c) Nokia IMEI: 354223032720203 PPM version : V 07.90 23-09-09 RM-495 (c) Nokia MEN Product code: 0581455 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! ===== WARNING ===== Battery voltage is can be not enough for start ===== WARNING ===== AfterFlash operations done ;D Done! Elapsed: 00:12:42 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
09-09-2012, 08:50 | #17027 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | card found: S/N 252D:0118 registered to: amc_khan Connect phone on selected interface... Core : v1.51 , FlashEngine : v1.8 Selected FlashSettings : Manual Check FlashFiles, Please, wait... -> Flash Files are NOT selected! You can Select: S40 : Any, but MCU need present in filelist S60 : Any, but CORE/MCU need present in filelist S60 APE : MCU+PPM, MCU+PPM+CNT Core : v1.51 , FlashEngine : v1.8 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : C5F02102_rm495__07.97.mcusw PPM : rm495__07.90.ppm_mena_b CNT : E24393CE_rm495__07.97.image_mena_a1_red Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. ASIC ID: 000000010000022600010006030C192101033000 CPU ID : RAP3Gv3 , Features : No any extended features RAP_PUB: 14900209F3137E5692767136ABA557EB3FABD71D CMT_ROOT: 9DDBFCFE6E73CED7D8C6268C8EB85723 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:06 Reopening the connection... Waiting for response: 30 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing C5F02102_rm495__07.97.mcusw Found 6 areas to erase Erasing area 0x00000000 - 0x000006BF, NOR, CMT Result: 0000 Erasing area 0x000006C0 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00040000 - 0x000BFFFF, NOR, CMT Result: 0000 Erasing area 0x000C0000 - 0x0013FFFF, NOR, CMT Result: 0000 Erasing area 0x00140000 - 0x0137FFFF, NOR, CMT Result: 0000 Erasing area 0x01380000 - 0x0151FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:02:41 Write : Processing C5F02102_rm495__07.97.mcusw Total 1178 [1178/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] TIME : Write time : 00:01:02 MCU Write done ===Flashing [PPM]=== Erase : Processing rm495__07.90.ppm_mena_b Found 1 areas to erase Erasing area 0x01520000 - 0x01DBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:01:04 Write : Processing rm495__07.90.ppm_mena_b Total 404 [404/0/0] blocks to write, writing... TIME : Write time : 00:00:20 PPM Write done ===Flashing [CNT]=== Erase : Processing E24393CE_rm495__07.97.image_mena_a1_red Found 2 areas to erase Erasing area 0x01DC0000 - 0x0215FFFF, NOR, CMT Result: 0000 Erasing area 0x02160000 - 0x03FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:05:39 Checking content info... Check Image : Content size is 128k, use direct write mode Write : Processing E24393CE_rm495__07.97.image_mena_a1_red Total 656 [656/0/0] blocks to write, writing... TIME : Write time : 00:00:38 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:11:27 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 5130c-2 Software Info: V 07.97 13-09-10 RM-495 (c) Nokia IMEI: 354223032720203 PPM version : V 07.90 23-09-09 RM-495 (c) Nokia MEN Product code: 0581455 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! ===== WARNING ===== Battery voltage is can be not enough for start ===== WARNING ===== AfterFlash operations done ;D Done! Elapsed: 00:12:42 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
09-09-2012, 08:51 | #17028 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | card found: S/N 252D:0118 registered to: amc_khan Connect phone on selected interface... Core : v1.51 , FlashEngine : v1.8 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-484_30.009_prd.core.fpsx PPM : RM-484_30.009_022_prd.language.fpsx PPM2 : RM-484_30.009_54.1_prd.customer.fpsx CNT : RM-484_30.009_003_U001.uda.fpsx APE : rm484_ENO_x_2009wk42v0.a004 Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000010000022600010006400C192101051103 CPU ID : RAPIDOv11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 035001132195005208128E354B980D18EBCCFD9E ASIC MODE ID: 00 ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 ROM ID: 4B9B75103E691FF8 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing RAP3NAND ... Processing PASUBTOC ... Processing PAPUBKEYS... Processing UPDAPP ... Boot Done! TIME : Boot time : 00:00:03 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Auth done... ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing RM-484_30.009_prd.core.fpsx Found 4 areas to erase Erasing area 0x00040000 - 0x00082FFF, NAND, CMT Result: 0000 Erasing area 0x00083400 - 0x003FFFFF, NAND, CMT Result: 0000 Erasing area 0x00800000 - 0x00D5FFFF, NAND, CMT Result: 0000 Erasing area 0x00D60000 - 0x0A27FFFF, NAND, CMT Result: 0000 Erase partition 0x0A Partition erase Ok Partitioning : Ok [5] TIME : Erase time : 00:00:00 Write : Processing RM-484_30.009_prd.core.fpsx Total 494 [494/0/0] blocks to write, writing... CMT : Writing Hash CERT [ADA] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [RAP3NAND] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [SOS*UPDAPP] CMT : Writing Hash CERT [SOS*DSP0] CMT : Writing Hash CERT [SOS*ISASW] CMT : Writing Hash CERT [SOS+CORE] CMT : Writing Hash CERT [SOS+ROFS1] TIME : Write time : 00:01:13 MCU Write done ===Flashing [PPM]=== Erase : Processing RM-484_30.009_022_prd.language.fpsx Found 1 areas to erase Erasing area 0x07A20000 - 0x0957FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-484_30.009_022_prd.language.fpsx Total 70 [70/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFS2] TIME : Write time : 00:00:11 PPM Write done ===Flashing [PPM2]=== Erase : Processing RM-484_30.009_54.1_prd.customer.fpsx Found 1 areas to erase Erasing area 0x09580000 - 0x0A27FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-484_30.009_54.1_prd.customer.fpsx Total 6 [6/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFS3] TIME : Write time : 00:00:00 PPM Write done ===Flashing [CNT]=== Erase : Processing RM-484_30.009_003_U001.uda.fpsx Found 1 areas to erase Erasing area 0x0A280000 - 0x0F47FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-484_30.009_003_U001.uda.fpsx Total 2 [2/0/0] blocks to write, writing... TIME : Write time : 00:00:00 CNT Write done ===Flashing [APE]=== Erase : Processing rm484_ENO_x_2009wk42v0.a004 TIME : Erase time : 00:00:00 Write : Processing rm484_ENO_x_2009wk42v0.a004 Total 18 [18/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS*ENO] TIME : Write time : 00:00:02 APE Write done ================= ADL : End flashing ADL : Finalize... Flashing done! Total flash time : 00:01:29 Reboot phone now... Reading Phone Info.... Connected phone - Nokia N86 8MP Software Info: V ICPR72_09w36.25 18-02-10 RM-484 (c) Nokia IMEI: 358270039915050 Ape Version: 30.009 Product code: 0580494 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! Battery voltage is enough for start AfterFlash operations done ;D Done! Elapsed: 00:02:43 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Backup Certificates now... Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... ok SL3 Simlock Sign read ... ok WMDRM read ... ok Check communication with phone.... Reboot.... Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000010000022600010006400C192101051103 CPU ID : RAPIDOv11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 035001132195005208128E354B980D18EBCCFD9E ASIC MODE ID: 00 ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 ROM ID: 4B9B75103E691FF8 Use URAPIDOv11_2nd.fg , Rev : 2.0 Ver : 12.8.0 Processing RAWLOADER... 2nd boot not accepted... Alive Request not done Boot error... Looks like ASIC not supported, or HW failure Supported : RapuYama, RAP3Gv4, BroadComm, RAPIDO If RAPIDO - use dead mode for read rpl/force local SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : D:\BEST\Backup\Cert\358270039915050_SIM.rpl Phone disconected! Connect phone on selected interface... |
09-09-2012, 08:51 | #17029 (permalink) |
The Following User Says Thank You to amc_khan For This Useful Post: |
09-09-2012, 08:52 | #17030 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | card found: S/N 252D:0118 registered to: amc_khan Connect phone on selected interface... Backup Certificates now... Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000000000000022000509200C0000 CPU ID : BroadCom 21351 , Features : Dead-Test, USBRPL, FullUSB EM0 ID: 00005361 PUBLIC ID: 0000000000450844DF68791EAE9C93A26F1E53C9 ASIC MODE ID: 00 ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E ROM ID: DE56D582BDDE7A3A Use BCM21351_usb2nd.fg , Rev : 2.1 Ver : 12.8.0 Processing RAWLOADER... FLIC : 003000EC Req : XSR 1.6 Use BCM21351_XSR16_usbalg.fg , Rev : 2.1 Ver : 12.8.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : 37955B6FC432998EF0DB240E332228384D19ED09 ADL: Reading certificates... Reading NPC certificate... IMEI : 354843041130035 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... Cert Read done! ADL: Reading certificates done! ADL: Close_Session Content: 000300000000020000000200000000 ADL: Reboot Wait, reconneting... SLx Simlock Data read ... ok SL3 Simlock Sign read ... ok WMDRM read ... ok CRT308 Backup Created NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : D:\BEST\Backup\Cert\354843041130035.rpl All done, Disconnecting Elapsed: 00:00:28 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok card found: S/N 252D:0118 registered to: amc_khan Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Using F-bus count... Sending code #pw+12534874924 Level : 7 to SimLock Server... Simlock Server Answer: Error Done! Using F-bus count... Sending code #pw+58835762198 Level : 7 to SimLock Server... Simlock Server Answer: Error Done! Using F-bus count... Sending code #pw+76175812918 Level : 7 to SimLock Server... Simlock Server Answer: Error Done! Phone disconected! Connect phone on selected interface... |
09-09-2012, 08:53 | #17031 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | card found: S/N 252D:0118 registered to: amc_khan Connect phone on selected interface... UFS S/N 102641 boot - Ok Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Resetting selected items... Check phone mode... Phone in Local mode Seting Test mode... wait... Test mode set Settings Full Factory Defaults... Set OK! Settings Software Upgrade Defaults... Set OK! Settings Service Centre Defaults... Set OK! Settings Production Tune Defaults... Set OK! Settings User Data Defaults... Set OK! Settings Leave Factory defaults... Set OK! Elapsed: 00:00:11 Phone disconected! Connect phone on selected interface... Error open UFS #102641 Error open UFS #102641 card found: S/N 252D:0118 registered to: amc_khan Connect phone on selected interface... Core : v1.51 , FlashEngine : v1.8 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm411__07.23.mcusw PPM : rm411__07.23.ppm_mb CNT : rm411__07.23.image_mb_b_blue Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. ASIC ID: 000000010000022600010006030C192101033000 CPU ID : RAP3Gv3 , Features : No any extended features RAP_PUB: 25300210BBE75550CDDC25B1B2EC4A6CBCE0406F CMT_ROOT: 9DDBFCFE6E73CED7D8C6268C8EB85723 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:06 Reopening the connection... Waiting for response: 30 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm411__07.23.mcusw Found 6 areas to erase Erasing area 0x00000000 - 0x000006BF, NOR, CMT Result: 0000 Erasing area 0x000006C0 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00040000 - 0x000BFFFF, NOR, CMT Result: 0000 Erasing area 0x000C0000 - 0x0013FFFF, NOR, CMT Result: 0000 Erasing area 0x00140000 - 0x0137FFFF, NOR, CMT Result: 0000 Erasing area 0x01380000 - 0x0151FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:02:27 Write : Processing rm411__07.23.mcusw Total 1289 [1289/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] TIME : Write time : 00:01:02 MCU Write done ===Flashing [PPM]=== Erase : Processing rm411__07.23.ppm_mb Found 1 areas to erase Erasing area 0x01520000 - 0x01DBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:58 Write : Processing rm411__07.23.ppm_mb Total 394 [394/0/0] blocks to write, writing... TIME : Write time : 00:00:19 PPM Write done ===Flashing [CNT]=== Erase : Processing rm411__07.23.image_mb_b_blue Found 2 areas to erase Erasing area 0x01DC0000 - 0x0215FFFF, NOR, CMT Result: 0000 Erasing area 0x02160000 - 0x03FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:05:14 Checking content info... Check Image : Content size is 128k, use direct write mode Write : Processing rm411__07.23.image_mb_b_blue Total 520 [520/0/0] blocks to write, writing... TIME : Write time : 00:00:26 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:10:29 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 5220 XpressMusic Software Info: V 07.23 17-07-09 RM-411 (c) Nokia IMEI: 353662013261391 PPM version : V 07.23 17-07-09 RM-411 (c) Nokia MB Product code: Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! Battery voltage is enough for start AfterFlash operations done ;D Done! Elapsed: 00:11:48 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... Core : v1.51 , FlashEngine : v1.8 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm607__06.07.mcusw PPM : rm607__06.07.ppm_l CNT : rm607__06.07.image_l_059B160 Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" - just reinsert battery -> If flashing freeze - reinsert cable and try again --- Press phone's power button or insert charger! --- Connection opened successfully DBG : F00A1FB300020303010100FF CPUID : XGOLD 213 2nd boot Ok, 01 2nd ready, AA Sending Algo Algo sent Ok BL : Quantum_Bootloader_2.5_M1S1 Speed accepted, use 6.500.000 FLASHID : 89008289 FLIC conf set, RST set Boot done! Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI : 357401043122778 PCcode : 059G897 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : D:\BEST\Backup\Cert\357401043122778_XG213_CRT.rpl ===Flashing [MCU]=== File : rm607__06.07.mcusw Image : rm607__06.07.mcusw_ebl_psi.fls Cert block found, sending.... Cert sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:01 Write , Start : 0x40040000 , Len : 0x00040000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40080000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40080000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 4/5 Erase , Start : 0x400A0000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:05 Write , Start : 0x400A0000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 5/5 Erase , Start : 0x40400000 , Len : 0x01800000 Erasing, wait ... Erase done, time : 00:01:58 Write , Start : 0x40400000 , Len : 0x01780000 Flashing , wait ... Region flash done, time : 00:00:33 ===Flashing [PPM]=== File : rm607__06.07.ppm_l Image : package_l.ppm_ebl_psi.fls Cert block found, sending.... Cert sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41C00000 , Len : 0x00600000 Erasing, wait ... Erase done, time : 00:00:15 Write , Start : 0x41C00000 , Len : 0x00337044 Flashing , wait ... Region flash done, time : 00:00:03 ===Flashing [CNT]=== File : rm607__06.07.image_l_059B160 Image : package_l_059B160.image.fls Cert block found, sending.... Cert sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x42200000 , Len : 0x01C60000 Erasing, wait ... Erase done, time : 00:04:12 Write , Start : 0x42200000 , Len : 0x00B00000 Flashing , wait ... Region flash done, time : 00:00:19 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:07 No write data, skip Flashing done! Total flash time : 00:07:41 Reboot phone now... Reading Phone Info.... Connected phone - C1-01 Software Info: V 06.07 13-10-11 RM-607 (c) Nokia IMEI: 357401043122778 PPM version : V 06.07 13-10-11 RM-607 (c) Nokia L Product code: 059G897 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 39 certs Data exist, skip certificate repair... Battery voltage is enough for start AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:08:22 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
09-09-2012, 11:48 | #17032 (permalink) |
No Life Poster Join Date: May 2005 Location: Pakistan,Peshawar
Member: 144708 Status: Offline Sonork: 100.1615125 Thanks Meter: 387 | X2-02 flashing Done Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... Connected phone - X2-02 Software ver : V 11.57 31-03-12 RM-694 (c) Nokia IMEI 1 : 352440055303244 IMEI 2 : 352440055303251 PPM : V 11.57 31-03-12 RM-694 (c) Nokia M_A CNT : Content: ctv PK v1 V 10.91 08-02-12 RM-694 (c) Nokia Product SN : 9346D3BAH Product code : 059P1X1 Base Prd.code: 059C943 Module code : 0204922 Long Prod.SN : 0 Hardware info======= HWID : 1000 Batery: 3979 mV CMT BT: 19e2-47026 LCDVer: TPO Lock info =========== IMEI : 352440055303244 IMEI spNet : 3A 25 44 00 55 03 23 04 IMEI svNet : 33 25 44 00 55 03 23 04 F5 Sl Conf : 001-01-00000000000 Sl Prof : 800000000003000-B Sl Aux : 000B0000 Hw Sig : A5762C19C4B49B0E Country : Test SIM (Open) Operator : NOKIA (Open) Lock info: Block 1 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 2 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 3 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 4 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 5 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 6 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 7 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; CRT308 Backup Created INFINEON : SuperDongle not exist (It is Ok) CMLA Key status : Not Present SimLock status : Ok Security status : Ok PA_SL3 phone , SP_CODE_LEN : 15 User Code : 22222 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Phone disconected! GSM007 |
09-09-2012, 12:37 | #17033 (permalink) |
Member: 144708 Status: Offline Sonork: 100.1615125 Thanks Meter: 387 | 6300 unlock Done with infinity best tool thanks Connect phone on selected interface... UFS S/N 73225 boot - Ok Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia 6300 Software ver : V 05.00 27-04-07 RM-217 (c) Nokia. IMEI : 358648015296704 DSP Ver : pb06w14v51 PPM : V 05.00 27-04-07 RM-217 (c) Nokia. O CNT : Content: ora_uk2 V 05.00 27-04-07 RM-217 (c) Nokia. Product SN : KEQ856460 Product code : 0554371 Base Prd.code: 0537040 Module code : 0203166 Hardware info======= HWID : 3007 Retu : 32 Tahvo : 53 Batery: 4870 mV CMT BT: Error APE BT: 06cc-P9.1 LCDVer: Error RF ic : Error Lock info =========== IMEI : 358648015296704 IMEI spNet : IMEI svNet : Conf key : 8000000000000006 Provider key : 2343300000000000 Country : United Kingdom Operator : Orange Counters : Key 0 [3] , Fbus 0 [10] Blocks : 2 LOCK STATUS : ============================= BLK : 1 Lock1:Close BLK : 2 Lock1:Close ============================= LOCKS : Closed ============================= User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Unlock procedure started... Phone Imei: 358648015296704 Checking locks... Conf key : 8000000000000006 Provider key : 2343300000000000 Country : United Kingdom Operator : Orange Counters : Key 0 [3] , Fbus 0 [10] Blocks : 2 LOCK STATUS : ============================= BLK : 1 Lock1:Close BLK : 2 Lock1:Close ============================= LOCKS : Closed ============================= PA_SL phone detected... Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006010C192101001101 CMT EM0 ID : 00000232 CMT EM1 ID : 00000353 CMT PUB ID : 2EE0010591416D5613A49110283C3203CDB63F3B CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 191EC665DFAAF68F CMT : Sending 2nd loader... CMT Loader sent, Boot Ok rap= 2EE0010591416D5613A49110283C3203CDB63F3B hash= BAF3A9C3DBFA8454937DB77F2B8852B1 key= E418356815F8549C5DDFF5FB6084987B98C8E082 Init Service mode... Wait... Key file updated... Using F-bus count... Sending code 353442205771192 Level : 7 to SimLock Server... Simlock Server Answer: Unlock code Accepted! Unlock Done! Reading Phone Info.... Connected phone - Nokia 6300 Software ver : V 05.00 27-04-07 RM-217 (c) Nokia. IMEI : 358648015296704 DSP Ver : pb06w14v51 PPM : V 05.00 27-04-07 RM-217 (c) Nokia. O CNT : Content: ora_uk2 V 05.00 27-04-07 RM-217 (c) Nokia. Product SN : KEQ856460 Product code : 0554371 Base Prd.code: 0537040 Module code : 0203166 Hardware info======= HWID : 3007 Retu : 32 Tahvo : 53 Batery: 4778 mV CMT BT: Error APE BT: Error APE HW: Error RF ic : 17211721 Lock info =========== IMEI : 358648015296704 IMEI spNet : IMEI svNet : Conf key : 8000000000000006 Provider key : 2343300000000000 Country : United Kingdom Operator : Orange Counters : Key 0 [3] , Fbus 0 [10] Blocks : 2 LOCK STATUS : ============================= BLK : 1 Lock1:Open BLK : 2 Lock1:Open ============================= LOCKS : All Open ============================= User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Phone disconected! Connect phone on selected interface... GSM007 |
09-09-2012, 12:52 | #17034 (permalink) |
Member: 144708 Status: Offline Sonork: 100.1615125 Thanks Meter: 387 | X2-02 user lock done Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... SW ver : V 05.29 10-06-11 RM-713 (c) Nokia IMEI : V 05.29 10-06-11 RM-713 (c) Nokia PPM : CNT : V 05.29 10-06-11 RM-713 (c) Nokia IC DSP Ver : 9G439 PCode : 358290040926409 BPCode : HWID : 0204758 LCDVer : 3051 IMEI : V 05.29 10-06-11 RM-713 (c) Nokia Sl Conf : 424-15-241434F4176 Sl Prof : 38300A4E5433393-1 Sl Aux : 32310000 Hw Sig : Country : United Arab Emirates Operator : Unknown Lock info: Done! Resetting selected items... Check phone mode... Phone in Local mode Seting Test mode... wait... Test mode set Settings Full Factory Defaults... Set OK! Elapsed: 00:00:11 Phone disconected! Connect phone on selected interface... GSM007 |
09-09-2012, 14:44 | #17035 (permalink) |
Member: 144708 Status: Offline Sonork: 100.1615125 Thanks Meter: 387 | X2-02 flashing done Connect phone on selected interface... UFS S/N 73225 boot - Ok Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... SW ver : V 05.44 21-09-11 RM-713 (c) Nokia IMEI : 359732042684162 PPM : V 05.44 21-09-11 RM-713 (c) Nokia IJ PCode : 059G444 BPCode : 059L8X6 HWID : 1000 LCDVer : UNKWN: IDs: ff:ff:ff IMEI : 359732042684162 Sl Conf : 001-01-00000000000 Sl Prof : 000000000003000-2 Sl Aux : 000B0000 Hw Sig : 1735489FAAF28E7A Country : Test SIM (Open) Operator : NOKIA (Open) Lock info: Block 1 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 2 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 3 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 4 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 5 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 6 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 7 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Done! Core : v1.51 , FlashEngine : v1.8 Selected FlashSettings : FullFlash Files Set for Flashing : MCU : rm713_007.510 PPM : rm713_007.51ba CNT : rm7130_nai07.51ba_mdl Infineon flashing... -> Infineon XG110 : IMEI Backup Created Booting phone now.... Sync Ok , A2 CPU ID : XGOLD , A200341100 PBL : Dynamic Boot Ok , 01AB SBL : Dynamic Algo Ok , 01 SBL mode Ok SBL : Default_RAM_Bootloader EPP CFG [Bering]... FLASH ID : 00EC000000042400 FLASH ID : UNKNOW [Not In Base] Boot Done! ===Flashing [MCU]=== File : rm713_007.510 Image : hw_b1_rm713_r07.510.fls Cert block found, sending.... Cert sent Found 3 region(s) Processing Region 1/3 Erase , Start : 0x00000000 , Len : 0x00020000 Erasing, wait ... Erase done Write , Start : 0x00000000 , Len : 0x00006000 Flashing , wait ... Region flash done Processing Region 2/3 Erase , Start : 0x00800000 , Len : 0x00400000 Erasing, wait ... Erase done Write , Start : 0x00800000 , Len : 0x003F0000 Flashing , wait ... Region flash done Processing Region 3/3 Erase , Start : 0x00C5D000 , Len : 0x00203000 Erasing, wait ... Erase done Write , Start : 0x00C5D000 , Len : 0x0019E700 Flashing , wait ... Region flash done Check : 6AB2 ===Flashing [PPM]=== File : rm713_007.51ba Image : hw_b1_rm713_007.51ba.fls Cert block found, sending.... Cert sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x00100000 , Len : 0x00700000 Erasing, wait ... Erase done Write , Start : 0x00100000 , Len : 0x004A8B80 Flashing , wait ... Region flash done Check : E7BA ===Flashing [CNT]=== File : rm7130_nai07.51ba_mdl Image : hw_b1_rm7130_nai07.51ba_mdl.fls Cert block found, sending.... Cert sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x00E60000 , Len : 0x00100000 Erasing, wait ... Erase done Write , Start : 0x00E60000 , Len : 0x000E65C0 Flashing , wait ... Region flash done Check : 722D Flashing done, rebooting... -> Infineon info : Do FullFactory Sets after flashing Flashing Done! Init Service mode... Wait... Error open UFS #73225 Error open UFS #73225 Afterflash settings... SW ver : V 07.51 12-12-11 RM-713 (c) Nokia IMEI : 359732042684162 PCode : 059G444 Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! All done! Connect phone on selected interface... GSM007 |
09-09-2012, 15:15 | #17036 (permalink) |
No Life Poster Join Date: Jun 2008 Location: Infront Of My Laptop Age: 34
Member: 799558 Status: Offline Thanks Meter: 430 | E63 RM-437 flashing done Core : v1.51 , FlashEngine : v1.8Core : v1.51 , FlashEngine : v1.8 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm437_510.21.010_prd.c00 PPM : rm437_510.21.010_prd.v328_30 CNT : rm437_510.21.010_30.328U APE : RM437_ENO_008.07.45_100.71.920.a01.fpsx CNT3 : sofie_erase_y_drive.fpsx Flashing phone now... Check files done... -> SWversion check skipped : Manual mode selected Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... ok SL3 Simlock Sign read ... ok WMDRM read ... ok SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\351502048820187_SI M_2nd.rpl Check communication with phone.... ADL req restart Communication verify done... Preparing... Gathering phone info... Check communication with phone... Reboot.... Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000010000022600010006400C192101031103 CPU ID : RAPIDOv11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 1C10010C8AFD8D52115AFC2517950C24721E1811 ASIC MODE ID: 00 ROOT KEY HASH: 9A28E119033B91D14D22838C86D0D53C ROM ID: 4B9B75103E691FF8 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP ... Processing PASUBTOC ... Boot Done! TIME : Boot time : 00:00:04 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL Server confirm flashmode! ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm437_510.21.010_prd.c00 Found 3 areas to erase Erasing area 0x00040000 - 0x007FFFFF, NAND, CMT Result: 0000 Erasing area 0x00A00000 - 0x0759FFFF, NAND, CMT Result: 0000 Erasing area 0x0F1C0000 - 0x0F8BFFFF, NAND, CMT Result: 0000 Partition erase not allowed by loader Partition erase not allowed by loader Partition erase not allowed by loader Partitioning : Ok [7] TIME : Erase time : 00:00:00 Write : Processing rm437_510.21.010_prd.c00 Total 533 [533/0/0] blocks to write, writing... CMT : Writing Hash CERT [ADA] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [RAP3NAND] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [SOS*UPDAPP] CMT : Writing Hash CERT [SOS*DSP0] CMT : Writing Hash CERT [SOS*ISASW] CMT : Writing Hash CERT [SOS*CORE] CMT : Writing Hash CERT [SOS+ROFS] TIME : Write time : 00:01:33 MCU Write done ===Flashing [PPM]=== Erase : Processing rm437_510.21.010_prd.v328_30 Found 1 areas to erase Erasing area 0x05420000 - 0x0759FFFF, NAND, CMT Result: 0000 Partition erase not allowed by loader TIME : Erase time : 00:00:00 Write : Processing rm437_510.21.010_prd.v328_30 Total 196 [196/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFX] TIME : Write time : 00:00:36 PPM Write done ===Flashing [CNT]=== Erase : Processing rm437_510.21.010_30.328U Partition erase not allowed by loader TIME : Erase time : 00:00:00 Write : Processing rm437_510.21.010_30.328U Total 162 [162/0/0] blocks to write, writing... TIME : Write time : 00:00:31 CNT Write done ===Flashing [APE]=== Erase : Processing RM437_ENO_008.07.45_100.71.920.a01.fpsx TIME : Erase time : 00:00:00 Write : Processing RM437_ENO_008.07.45_100.71.920.a01.fpsx Total 16 [16/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS*ENO] TIME : Write time : 00:00:02 APE Write done ===Flashing [CNT3]=== Erase : Processing sofie_erase_y_drive.fpsx Found 1 areas to erase Erasing area 0x0F020000 - 0x0F1BFFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing sofie_erase_y_drive.fpsx No any data for write, skip write CNT Write done ================= ADL : End flashing ADL : Finalize... Flashing done! Total flash time : 00:02:44 Reboot phone now... Reading Phone Info.... Connected phone - Nokia E63 Software Info: V ICPR71_09w47.11 14-02-11 RM-437 (c) Nokia IMEI: 351xxxxxxxxxxx Ape Version: 510.21.010 Product code: 0598025 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! Battery voltage is enough for start AfterFlash operations done ;D Done! Elapsed: 00:03:07 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok |
09-09-2012, 15:18 | #17037 (permalink) |
No Life Poster Join Date: Sep 2008 Location: Barcelona Spain
Member: 862582 Status: Offline Sonork: 100.1604840 Thanks Meter: 71 | Nokia C5-00 user code Code: card found: S/N --------- registered to:-------- Connect phone on selected interface... Reading Phone Info.... Connected phone - Nokia C5-00 Software ver : V ICPR82_11w16.3.10 13-03-12 RM-745 (c) Nokia IMEI : 35------------- Ape Ver : 091.002 APE Var : 091.002091.002.11.01091.002.C00.01 APE ADSP: 256 DSP Ver : 11w52 APE Test: rm745_APE_ONLY_ENO_11wk02v0 PPM : CNT : Product SN : 3CA337BAA Product code : 059G750 Base Prd.code: 059F026 Module code : 0204821 Long Prod.SN : 0 Hardware info======= HWID : 6000 Retu : 35 Tahvo : 00 Batery: 3916 mV Camera: CMT BT: APE BT: HCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12652. APE HW: 256 LCDVer: RF ic : Lock info =========== IMEI : 35------------- IMEI spNet : 3A 15 86 05 35 51 38 06 IMEI svNet : 33 15 86 05 35 51 38 16 F9 Conf key : 0000000000000000 Provider key : 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= CRT308 Backup Created SDD key status : Ok SimLock status : Ok Security status : Ok PA_SL3 phone , SP_CODE_LEN : 15 User code : Crypted UserDataExLevel : Low [Gallery] , FullFlash method Done! card found: S/N -------- registered to: ------- Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia C5-00 Software ver : V ICPR82_11w16.3.10 13-03-12 RM-745 (c) Nokia IMEI : 351------------- Ape Ver : 091.002 APE Var : 091.002091.002.11.01091.002.C00.01 APE ADSP: 256 DSP Ver : 11w52 APE Test: rm745_APE_ONLY_ENO_11wk02v0 PPM : CNT : Product SN : 3CA337BAA Product code : 059G750 Base Prd.code: 059F026 Module code : 0204821 Long Prod.SN : 0 Hardware info======= HWID : 6000 Retu : 35 Tahvo : 00 Batery: 3905 mV Camera: CMT BT: APE BT: HCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12652. APE HW: 256 LCDVer: RF ic : Lock info =========== IMEI : 35------------- IMEI spNet : 3A 15 86 05 35 51 38 06 IMEI svNet : 33 15 86 05 35 51 38 16 F9 Conf key : 0000000000000000 Provider key : 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= CRT308 Backup Created SDD key status : Ok SimLock status : Ok Security status : Ok PA_SL3 phone , SP_CODE_LEN : 15 User code : Crypted UserDataExLevel : Low [Gallery] , FullFlash method Done! Searching for MMC pwd... Generation : [S60] Check phone mode... Phone in RfInactive mode Seting Test mode... wait... Test mode set SmartPhone algo initialise... Setup data... StartUp FileSystem... FS run fail, please, remove SD card first Change phone mode manualy to local/test and try again If still no luck - phone have damaged FS/SD-MMC part.. Done with major error... :( Searching for MMC pwd... Generation : [S60] Operating mode is OK, no need change... SmartPhone algo initialise... Setup data... StartUp FileSystem... FS run fail, please, remove SD card first Change phone mode manualy to local/test and try again If still no luck - phone have damaged FS/SD-MMC part.. Done with major error... :( Phone disconected! |
09-09-2012, 15:23 | #17038 (permalink) |
Member: 862582 Status: Offline Sonork: 100.1604840 Thanks Meter: 71 | Nokia 5233 Read Key Code: card found: S/N ------------ registered to: -------- Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia 5233 Software ver : V ICPR72_10w21.2.1 06-07-10 RM-684 (c) Nokia IMEI : 35-------------- Ape Ver : V 10.0.011 APE Var : V 10.0.011???10.0.011.218.01 APE ADSP: 256 DSP Ver : fox_ICPR72_10w16_p2 APE Test: eno_version PPM : CNT : Product SN : 07210F8AA Product code : 059D078 Base Prd.code: 0595902 Module code : 0204597 Long Prod.SN : 0 Hardware info======= HWID : 1000 Retu : 16 Tahvo : 22 Batery: 3753 mV Camera: CMT BT: APE BT: HCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12708. APE HW: 256 LCDVer: RF ic : Lock info =========== IMEI : 35-------------- IMEI spNet : 3A 35 77 02 54 14 87 07 IMEI svNet : 33 35 77 02 54 14 87 07 F1 Conf key : 8000000000000000 Provider key : 2680300000000000 Provider : Optimus;Portugal Counters : Key 0 [3] , Fbus 2 [10] Blocks : 1 LOCK STATUS : ============================= BLK : 1 Lock1:Close ============================= LOCKS : Closed ============================= CRT308 Backup Created SDD key status : Ok SimLock status : Ok Security status : Ok PA_SL3 phone , SP_CODE_LEN : 15 User code : Crypted UserDataExLevel : Low [Gallery] , FullFlash method Done! Phone Imei: 35-------------- Checking locks... Conf key : 8000000000000000 Provider key : 2680300000000000 Provider : Optimus;Portugal Counters : Key 0 [3] , Fbus 2 [10] Blocks : 1 LOCK STATUS : ============================= BLK : 1 Lock1:Close ============================= LOCKS : Closed ============================= PA_SL3 (15 digit) phone detected... - > Power Off phone, dissconnect it and connect Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... ASIC ID: 000000010000022600010006400C192101051105 CPU ID : RAPIDOv11 , Features : Dead-Test, USBRPL, WR/ER-USB PUBLIC ID: 1850001586A00052127D85685B5838546B2C226D ROOT KEY HASH: B8C3ADECFC997FCD8081D3DEAF870B8C Fetching data, wait... - > Reinsert cable and battery, press powerOn button again - > For X7, E7 - just waiting, near 1 minute - > When BEST start Search Phone - Press PowerOn if needed Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000010000022600010006400C192101051105 CPU ID : RAPIDOv11 , Features : Dead-Test, USBRPL, WR/ER-USB EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 1850001586A00052127D85685B5838546B2C226D ASIC MODE ID: 00 ROOT KEY HASH: B8C3ADECFC997FCD8081D3DEAF870B8C ROM ID: 4B9B75103E691FF8 Use URAPIDOv11_2nd.fg , Rev : 2.0 Ver : 11.50.0 Processing RAWLOADER... FLIC : 004000EC Req : XSR 1.6 Use URAPIDOv11_XSR17_alg.fg , Rev : 2.0 Ver : 11.50.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:00 CFL: Wait for Loader take control ... CFL: Check mode Phone ready, boot Ok TransReq set Ok PAPUBkeys : CA158EAEE7D8D7A5B2E4907CB6BD0A9C2794D992 CFL: Close_Session Content: 000300000000030000000300000000 CFL: Reboot Wait, reconneting... rap= 1850001586A00052127D85685B5838546B2C226D hash= B8C3ADECFC997FCD8081D3DEAF870B8C key= A54437C8966BA7226E64E29D0335F9FD3CC981ED Key file updated... Check RSA started... Check RSA skiped, unknown hash or keys... Create Log file for local calculation... File c:\InfinityBox\BEST\Local_calc\35------------7.bcl created - Ok File c:\InfinityBox\BEST\Local_calc\ighashgpu_35-------------.bat created - Ok File c:\InfinityBox\BEST\Local_calc\oclHashcat_353---------------_32.bat created - Ok File c:\InfinityBox\BEST\Local_calc\oclHashcat_35--------------_64.bat created - Ok Done! Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... |
09-09-2012, 15:25 | #17039 (permalink) |
Member: 862582 Status: Offline Sonork: 100.1604840 Thanks Meter: 71 | Nokia 6300 Use code Code: card found: S/N ---------- registered to: --------- Connect phone on selected interface... UFS S/N ------------ boot - Ok Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Resetting selected items... Check phone mode... Phone in Local mode Seting Test mode... wait... Test mode set Settings Full Factory Defaults... Set OK! Settings Software Upgrade Defaults... Set OK! Settings Service Centre Defaults... Set OK! Settings Production Tune Defaults... Set OK! Settings User Data Defaults... Set OK! Settings Leave Factory defaults... Set OK! Elapsed: 00:00:12 Phone disconected! Connect phone on selected interface... |
09-09-2012, 15:31 | #17040 (permalink) |
Member: 862582 Status: Offline Sonork: 100.1604840 Thanks Meter: 71 | Nokia 6303i Reading PM Code: Using F-bus count... Sending code 538820669242757 Level : 7 to SimLock Server... Simlock Server Answer: Unlock code Accepted! :) Done! Reading PM from field 0 to 400 Field [1] 12 Record(s) Record 0: 48 byte(s) readed - Ok Record 2: 86 byte(s) readed - Ok Record 4: 48 byte(s) readed - Ok Record 6: 86 byte(s) readed - Ok Record 8: 48 byte(s) readed - Ok Record 11: 12 byte(s) readed - Ok Record 12: 24 byte(s) readed - Ok Record 13: 86 byte(s) readed - Ok Record 16: 24 byte(s) readed - Ok Record 18: 24 byte(s) readed - Ok Record 21: 24 byte(s) readed - Ok Record 29: 4 byte(s) readed - Ok Field [2] 1 Record(s) Record 0: 764 byte(s) readed - Ok Field [3] 1 Record(s) Record 0: 2 byte(s) readed - Ok Field [4] 9 Record(s) Record 1: 800 byte(s) readed - Ok Record 3: 10 byte(s) readed - Ok Record 4: 8 byte(s) readed - Ok Record 5: 8 byte(s) readed - Ok Record 6: 8 byte(s) readed - Ok Record 9: 5 byte(s) readed - Ok Record 18: 80 byte(s) readed - Ok Record 19: 4 byte(s) readed - Ok Record 28: 2 byte(s) readed - Ok Field [8] 9 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 16 byte(s) readed - Ok Record 2: 16 byte(s) readed - Ok Record 3: 128 byte(s) readed - Ok Record 4: 128 byte(s) readed - Ok Record 7: 4 byte(s) readed - Ok Record 8: 8 byte(s) readed - Ok Record 9: 8 byte(s) readed - Ok Record 10: 24 byte(s) readed - Ok Field [11] 70 Record(s) Record 0: 4 byte(s) readed - Ok Record 1: 4 byte(s) readed - Ok Record 2: 4 byte(s) readed - Ok Record 3: 4 byte(s) readed - Ok Record 4: 1 byte(s) readed - Ok Record 5: 6 byte(s) readed - Ok Record 6: 2 byte(s) readed - Ok Record 7: 1 byte(s) readed - Ok Record 8: 1 byte(s) readed - Ok Record 9: 1 byte(s) readed - Ok Record 10: 2 byte(s) readed - Ok Record 11: 2 byte(s) readed - Ok Record 12: 2 byte(s) readed - Ok Record 13: 2 byte(s) readed - Ok Record 14: 16 byte(s) readed - Ok Record 15: 32 byte(s) readed - Ok Record 16: 32 byte(s) readed - Ok Record 17: 2 byte(s) readed - Ok Record 18: 2 byte(s) readed - Ok Record 19: 2 byte(s) readed - Ok Record 20: 2 byte(s) readed - Ok Record 21: 2 byte(s) readed - Ok Record 22: 2 byte(s) readed - Ok Record 23: 2 byte(s) readed - Ok Record 24: 2 byte(s) readed - Ok Record 25: 2 byte(s) readed - Ok Record 26: 2 byte(s) readed - Ok Record 27: 2 byte(s) readed - Ok Record 28: 2 byte(s) readed - Ok Record 29: 2 byte(s) readed - Ok Record 30: 2 byte(s) readed - Ok Record 31: 2 byte(s) readed - Ok Record 32: 2 byte(s) readed - Ok Record 33: 2 byte(s) readed - Ok Record 34: 2 byte(s) readed - Ok Record 35: 2 byte(s) readed - Ok Record 36: 2 byte(s) readed - Ok Record 37: 2 byte(s) readed - Ok Record 38: 2 byte(s) readed - Ok Record 39: 2 byte(s) readed - Ok Record 40: 2 byte(s) readed - Ok Record 41: 2 byte(s) readed - Ok Record 42: 2 byte(s) readed - Ok Record 43: 2 byte(s) readed - Ok Record 44: 2 byte(s) readed - Ok Record 45: 2 byte(s) readed - Ok Record 46: 2 byte(s) readed - Ok Record 47: 2 byte(s) readed - Ok Record 48: 2 byte(s) readed - Ok Record 49: 2 byte(s) readed - Ok Record 50: 2 byte(s) readed - Ok Record 51: 2 byte(s) readed - Ok Record 52: 2 byte(s) readed - Ok Record 53: 2 byte(s) readed - Ok Record 54: 2 byte(s) readed - Ok Record 55: 2 byte(s) readed - Ok Record 56: 2 byte(s) readed - Ok Record 57: 2 byte(s) readed - Ok Record 58: 2 byte(s) readed - Ok Record 59: 2 byte(s) readed - Ok Record 60: 2 byte(s) readed - Ok Record 61: 2 byte(s) readed - Ok Record 62: 4 byte(s) readed - Ok Record 63: 4 byte(s) readed - Ok Record 64: 4 byte(s) readed - Ok Record 65: 4 byte(s) readed - Ok Record 66: 16 byte(s) readed - Ok Record 67: 4 byte(s) readed - Ok Record 68: 2 byte(s) readed - Ok Record 69: 242 byte(s) readed - Ok Field [12] 1 Record(s) Record 0: 102 byte(s) readed - Ok Field [13] 197 Record(s) Record 0: 1 byte(s) readed - Ok Record 1: 2 byte(s) readed - Ok Record 2: 1 byte(s) readed - Ok Record 3: 2 byte(s) readed - Ok Record 4: 1 byte(s) readed - Ok Record 5: 1 byte(s) readed - Ok Record 6: 1 byte(s) readed - Ok Record 7: 1 byte(s) readed - Ok Record 8: 2 byte(s) readed - Ok Record 9: 1 byte(s) readed - Ok Record 10: 1 byte(s) readed - Ok Record 11: 48 byte(s) readed - Ok Record 12: 4 byte(s) readed - Ok Record 13: 1 byte(s) readed - Ok Record 14: 1 byte(s) readed - Ok Record 15: 886 byte(s) readed - Ok Record 16: 2 byte(s) readed - Ok Record 17: 1 byte(s) readed - Ok Record 18: 1 byte(s) readed - Ok Record 19: 8 byte(s) readed - Ok Record 20: 1 byte(s) readed - Ok Record 21: 1 byte(s) readed - Ok Record 22: 1 byte(s) readed - Ok Record 23: 1 byte(s) readed - Ok Record 24: 1 byte(s) readed - Ok Record 25: 2 byte(s) readed - Ok Record 26: 1 byte(s) readed - Ok Record 27: 1 byte(s) readed - Ok Record 28: 1 byte(s) readed - Ok Record 29: 1 byte(s) readed - Ok Record 30: 1 byte(s) readed - Ok Record 31: 1 byte(s) readed - Ok Record 32: 1 byte(s) readed - Ok Record 33: 1 byte(s) readed - Ok Record 34: 1 byte(s) readed - Ok Record 35: 1 byte(s) readed - Ok Record 36: 1 byte(s) readed - Ok Record 37: 4 byte(s) readed - Ok Record 38: 1 byte(s) readed - Ok Record 39: 1 byte(s) readed - Ok Record 40: 1 byte(s) readed - Ok Record 41: 1 byte(s) readed - Ok Record 42: 4 byte(s) readed - Ok Record 43: 4 byte(s) readed - Ok Record 44: 1 byte(s) readed - Ok Record 45: 4 byte(s) readed - Ok Record 46: 4 byte(s) readed - Ok Record 47: 1 byte(s) readed - Ok Record 48: 4 byte(s) readed - Ok Record 49: 1 byte(s) readed - Ok Record 50: 1 byte(s) readed - Ok Record 51: 1 byte(s) readed - Ok Record 52: 2 byte(s) readed - Ok Record 53: 4 byte(s) readed - Ok Record 54: 4 byte(s) readed - Ok Record 55: 1 byte(s) readed - Ok Record 56: 1 byte(s) readed - Ok Record 57: 1 byte(s) readed - Ok Record 58: 2 byte(s) readed - Ok Record 59: 1 byte(s) readed - Ok Record 60: 4 byte(s) readed - Ok Record 61: 4 byte(s) readed - Ok Record 62: 1 byte(s) readed - Ok Record 63: 4 byte(s) readed - Ok Record 64: 4 byte(s) readed - Ok Record 65: 1 byte(s) readed - Ok Record 66: 4 byte(s) readed - Ok Record 67: 4 byte(s) readed - Ok Record 68: 1 byte(s) readed - Ok Record 69: 1 byte(s) readed - Ok Record 70: 1 byte(s) readed - Ok Record 71: 4 byte(s) readed - Ok Record 72: 4 byte(s) readed - Ok Record 73: 1 byte(s) readed - Ok Record 74: 4 byte(s) readed - Ok Record 75: 2 byte(s) readed - Ok Record 76: 2 byte(s) readed - Ok Record 77: 2 byte(s) readed - Ok Record 78: 1 byte(s) readed - Ok Record 79: 1 byte(s) readed - Ok Record 80: 1 byte(s) readed - Ok Record 81: 1 byte(s) readed - Ok Record 82: 1 byte(s) readed - Ok Record 83: 2 byte(s) readed - Ok Record 84: 1 byte(s) readed - Ok Record 85: 4 byte(s) readed - Ok Record 86: 4 byte(s) readed - Ok Record 87: 2 byte(s) readed - Ok Record 88: 1 byte(s) readed - Ok Record 89: 4 byte(s) readed - Ok Record 90: 4 byte(s) readed - Ok Record 91: 2 byte(s) readed - Ok Record 92: 1 byte(s) readed - Ok Record 93: 4 byte(s) readed - Ok Record 94: 4 byte(s) readed - Ok Record 95: 2 byte(s) readed - Ok Record 96: 1 byte(s) readed - Ok Record 97: 4 byte(s) readed - Ok Record 98: 4 byte(s) readed - Ok Record 99: 2 byte(s) readed - Ok Record 100: 4 byte(s) readed - Ok Record 101: 2 byte(s) readed - Ok Record 102: 1 byte(s) readed - Ok Record 103: 4 byte(s) readed - Ok Record 104: 4 byte(s) readed - Ok Record 105: 4 byte(s) readed - Ok Record 106: 4 byte(s) readed - Ok Record 107: 4 byte(s) readed - Ok Record 108: 2 byte(s) readed - Ok Record 109: 4 byte(s) readed - Ok Record 110: 4 byte(s) readed - Ok Record 111: 4 byte(s) readed - Ok Record 112: 2 byte(s) readed - Ok Record 113: 4 byte(s) readed - Ok Record 114: 4 byte(s) readed - Ok Record 115: 1 byte(s) readed - Ok Record 116: 1 byte(s) readed - Ok Record 117: 1 byte(s) readed - Ok Record 118: 4 byte(s) readed - Ok Record 119: 4 byte(s) readed - Ok Record 120: 1 byte(s) readed - Ok Record 121: 1 byte(s) readed - Ok Record 122: 1 byte(s) readed - Ok Record 123: 8 byte(s) readed - Ok Record 124: 1 byte(s) readed - Ok Record 125: 1 byte(s) readed - Ok Record 126: 1 byte(s) readed - Ok Record 127: 1 byte(s) readed - Ok Record 128: 1 byte(s) readed - Ok Record 129: 4 byte(s) readed - Ok Record 130: 4 byte(s) readed - Ok Record 131: 1 byte(s) readed - Ok Record 132: 1 byte(s) readed - Ok Record 133: 2 byte(s) readed - Ok Record 134: 1 byte(s) readed - Ok Record 135: 2 byte(s) readed - Ok Record 136: 1 byte(s) readed - Ok Record 137: 1 byte(s) readed - Ok Record 138: 4 byte(s) readed - Ok Record 139: 4 byte(s) readed - Ok Record 140: 1 byte(s) readed - Ok Record 141: 1 byte(s) readed - Ok Record 142: 1 byte(s) readed - Ok Record 143: 1 byte(s) readed - Ok Record 144: 4 byte(s) readed - Ok Record 145: 8 byte(s) readed - Ok Record 146: 4 byte(s) readed - Ok Record 147: 4 byte(s) readed - Ok Record 148: 1 byte(s) readed - Ok Record 149: 1 byte(s) readed - Ok Record 150: 1 byte(s) readed - Ok Record 151: 1 byte(s) readed - Ok Record 152: 1 byte(s) readed - Ok Record 153: 1 byte(s) readed - Ok Record 154: 1 byte(s) readed - Ok Record 155: 1 byte(s) readed - Ok Record 156: 1 byte(s) readed - Ok Record 157: 1 byte(s) readed - Ok Record 158: 1 byte(s) readed - Ok Record 159: 2 byte(s) readed - Ok Record 160: 2 byte(s) readed - Ok Record 161: 1 byte(s) readed - Ok Record 162: 1 byte(s) readed - Ok Record 163: 1 byte(s) readed - Ok Record 164: 1 byte(s) readed - Ok Record 165: 1 byte(s) readed - Ok Record 166: 1 byte(s) readed - Ok Record 167: 8 byte(s) readed - Ok Record 168: 4 byte(s) readed - Ok Record 169: 1 byte(s) readed - Ok Record 170: 1 byte(s) readed - Ok Record 171: 1 byte(s) readed - Ok Record 172: 1 byte(s) readed - Ok Record 173: 1 byte(s) readed - Ok Record 174: 1 byte(s) readed - Ok Record 175: 1 byte(s) readed - Ok Record 176: 1 byte(s) readed - Ok Record 177: 4 byte(s) readed - Ok Record 178: 2 byte(s) readed - Ok Record 179: 1 byte(s) readed - Ok Record 180: 1 byte(s) readed - Ok Record 181: 1 byte(s) readed - Ok Record 182: 1 byte(s) readed - Ok Record 183: 1 byte(s) readed - Ok Record 184: 1 byte(s) readed - Ok Record 185: 1 byte(s) readed - Ok Record 186: 1 byte(s) readed - Ok Record 187: 1 byte(s) readed - Ok Record 188: 1 byte(s) readed - Ok Record 189: 1 byte(s) readed - Ok Record 190: 4 byte(s) readed - Ok Record 191: 2 byte(s) readed - Ok Record 192: 1 byte(s) readed - Ok Record 193: 4 byte(s) readed - Ok Record 194: 1 byte(s) readed - Ok Record 195: 1 byte(s) readed - Ok Record 196: 10 byte(s) readed - Ok Field [24] 1 Record(s) Record 0: 1 byte(s) readed - Ok Field [31] 1 Record(s) Record 4: 18 byte(s) readed - Ok Field [42] 27 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 12 byte(s) readed - Ok Record 2: 36 byte(s) readed - Ok Record 3: 36 byte(s) readed - Ok Record 4: 36 byte(s) readed - Ok Record 5: 36 byte(s) readed - Ok Record 6: 36 byte(s) readed - Ok Record 7: 40 byte(s) readed - Ok Record 8: 40 byte(s) readed - Ok Record 9: 40 byte(s) readed - Ok Record 10: 40 byte(s) readed - Ok Record 11: 40 byte(s) readed - Ok Record 12: 40 byte(s) readed - Ok Record 13: 40 byte(s) readed - Ok Record 14: 40 byte(s) readed - Ok Record 15: 40 byte(s) readed - Ok Record 16: 40 byte(s) readed - Ok Record 17: 40 byte(s) readed - Ok Record 18: 40 byte(s) readed - Ok Record 19: 40 byte(s) readed - Ok Record 20: 40 byte(s) readed - Ok Record 21: 40 byte(s) readed - Ok Record 22: 40 byte(s) readed - Ok Record 23: 40 byte(s) readed - Ok Record 24: 40 byte(s) readed - Ok Record 25: 40 byte(s) readed - Ok Record 26: 40 byte(s) readed - Ok Field [44] 1 Record(s) Record 0: 1 byte(s) readed - Ok Field [49] 2 Record(s) Record 1: 4 byte(s) readed - Ok Record 2: 1 byte(s) readed - Ok Field [50] 1 Record(s) Record 0: 2 byte(s) readed - Ok Field [54] 2 Record(s) Record 0: 2 byte(s) readed - Ok Record 2: 24 byte(s) readed - Ok Field [59] 20 Record(s) Record 0: 35 byte(s) readed - Ok Record 1: 61 byte(s) readed - Ok Record 2: 35 byte(s) readed - Ok Record 3: 119 byte(s) readed - Ok Record 4: 56 byte(s) readed - Ok Record 5: 35 byte(s) readed - Ok Record 6: 72 byte(s) readed - Ok Record 7: 35 byte(s) readed - Ok Record 8: 119 byte(s) readed - Ok Record 9: 35 byte(s) readed - Ok Record 10: 98 byte(s) readed - Ok Record 11: 77 byte(s) readed - Ok Record 12: 68 byte(s) readed - Ok Record 13: 51 byte(s) readed - Ok Record 14: 139 byte(s) readed - Ok Record 15: 56 byte(s) readed - Ok Record 16: 56 byte(s) readed - Ok Record 17: 78 byte(s) readed - Ok Record 18: 56 byte(s) readed - Ok Record 19: 98 byte(s) readed - Ok Field [60] 20 Record(s) Record 0: 26 byte(s) readed - Ok Record 1: 94 byte(s) readed - Ok Record 2: 38 byte(s) readed - Ok Record 3: 26 byte(s) readed - Ok Record 4: 66 byte(s) readed - Ok Record 5: 13 byte(s) readed - Ok Record 6: 52 byte(s) readed - Ok Record 7: 26 byte(s) readed - Ok Record 8: 26 byte(s) readed - Ok Record 9: 51 byte(s) readed - Ok Record 10: 26 byte(s) readed - Ok Record 11: 99 byte(s) readed - Ok Record 12: 115 byte(s) readed - Ok Record 13: 26 byte(s) readed - Ok Record 14: 26 byte(s) readed - Ok Record 15: 38 byte(s) readed - Ok Record 16: 90 byte(s) readed - Ok Record 17: 26 byte(s) readed - Ok Record 18: 50 byte(s) readed - Ok Record 19: 26 byte(s) readed - Ok Field [61] 20 Record(s) Record 0: 35 byte(s) readed - Ok Record 1: 119 byte(s) readed - Ok Record 2: 36 byte(s) readed - Ok Record 3: 35 byte(s) readed - Ok Record 4: 35 byte(s) readed - Ok Record 5: 77 byte(s) readed - Ok Record 6: 56 byte(s) readed - Ok Record 7: 144 byte(s) readed - Ok Record 8: 35 byte(s) readed - Ok Record 9: 135 byte(s) readed - Ok Record 10: 119 byte(s) readed - Ok Record 11: 35 byte(s) readed - Ok Record 12: 35 byte(s) readed - Ok Record 13: 35 byte(s) readed - Ok Record 14: 35 byte(s) readed - Ok Record 15: 35 byte(s) readed - Ok Record 16: 35 byte(s) readed - Ok Record 17: 76 byte(s) readed - Ok Record 18: 35 byte(s) readed - Ok Record 19: 35 byte(s) readed - Ok Field [66] 83 Record(s) Record 0: 509 byte(s) readed - Ok Record 1: 240 byte(s) readed - Ok Record 2: 240 byte(s) readed - Ok Record 3: 1 byte(s) readed - Ok Record 4: 1 byte(s) readed - Ok Record 5: 240 byte(s) readed - Ok Record 6: 4 byte(s) readed - Ok Record 7: 4 byte(s) readed - Ok Record 8: 4 byte(s) readed - Ok Record 9: 4 byte(s) readed - Ok Record 10: 240 byte(s) readed - Ok Record 11: 240 byte(s) readed - Ok Record 12: 1 byte(s) readed - Ok Record 17: 4 byte(s) readed - Ok Record 19: 4 byte(s) readed - Ok Record 21: 4 byte(s) readed - Ok Record 23: 4 byte(s) readed - Ok Record 25: 4 byte(s) readed - Ok Record 27: 4 byte(s) readed - Ok Record 29: 4 byte(s) readed - Ok Record 31: 4 byte(s) readed - Ok Record 33: 4 byte(s) readed - Ok Record 40: 251 byte(s) readed - Ok Record 41: 4 byte(s) readed - Ok Record 44: 2 byte(s) readed - Ok Record 55: 8 byte(s) readed - Ok Record 56: 8 byte(s) readed - Ok Record 57: 8 byte(s) readed - Ok Record 58: 52 byte(s) readed - Ok Record 59: 8 byte(s) readed - Ok Record 60: 8 byte(s) readed - Ok Record 61: 8 byte(s) readed - Ok Record 62: 8 byte(s) readed - Ok Record 63: 8 byte(s) readed - Ok Record 64: 8 byte(s) readed - Ok Record 65: 8 byte(s) readed - Ok Record 66: 8 byte(s) readed - Ok Record 67: 8 byte(s) readed - Ok Record 68: 8 byte(s) readed - Ok Record 69: 8 byte(s) readed - Ok Record 70: 8 byte(s) readed - Ok Record 72: 8 byte(s) readed - Ok Record 73: 8 byte(s) readed - Ok Record 74: 20016 byte(s) readed - Ok Record 75: 6144 byte(s) readed - Ok Record 76: 300 byte(s) readed - Ok Record 77: 60 byte(s) readed - Ok Record 80: 50000 byte(s) readed - Ok Record 81: 49 byte(s) readed - Ok Record 82: 3 byte(s) readed - Ok Record 83: 3 byte(s) readed - Ok Record 84: 3 byte(s) readed - Ok Record 86: 3 byte(s) readed - Ok Record 87: 3 byte(s) readed - Ok Record 88: 3 byte(s) readed - Ok Record 89: 2 byte(s) readed - Ok Record 90: 4 byte(s) readed - Ok Record 95: 8 byte(s) readed - Ok Record 98: 4 byte(s) readed - Ok Record 99: 4 byte(s) readed - Ok Record 100: 4 byte(s) readed - Ok Record 101: 4 byte(s) readed - Ok Record 102: 4 byte(s) readed - Ok Record 103: 6 byte(s) readed - Ok Record 104: 4 byte(s) readed - Ok Record 105: 4 byte(s) readed - Ok Record 106: 379 byte(s) readed - Ok Record 107: 379 byte(s) readed - Ok Record 108: 379 byte(s) readed - Ok Record 110: 379 byte(s) readed - Ok Record 112: 120 byte(s) readed - Ok Record 113: 2 byte(s) readed - Ok Record 115: 30 byte(s) readed - Ok Record 116: 1 byte(s) readed - Ok Record 117: 20 byte(s) readed - Ok Record 119: 8 byte(s) readed - Ok Record 120: 8 byte(s) readed - Ok Record 121: 8 byte(s) readed - Ok Record 123: 7 byte(s) readed - Ok Record 127: 20246 byte(s) readed - Ok Record 129: 20206 byte(s) readed - Ok Record 131: 16246 byte(s) readed - Ok Record 139: 7 byte(s) readed - Ok Field [88] 1 Record(s) Record 0: 36 byte(s) readed - Ok Field [96] 2 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 20 byte(s) readed - Ok Field [107] 7 Record(s) Record 0: 21 byte(s) readed - Ok Record 1: 89 byte(s) readed - Ok Record 2: 69 byte(s) readed - Ok Record 3: 70 byte(s) readed - Ok Record 24: 88 byte(s) readed - Ok Record 25: 132 byte(s) readed - Ok Record 26: 12 byte(s) readed - Ok Field [111] 1 Record(s) Record 1: 4 byte(s) readed - Ok Field [116] 17 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 12 byte(s) readed - Ok Record 2: 36 byte(s) readed - Ok Record 3: 36 byte(s) readed - Ok Record 4: 36 byte(s) readed - Ok Record 5: 36 byte(s) readed - Ok Record 6: 36 byte(s) readed - Ok Record 7: 40 byte(s) readed - Ok Record 8: 40 byte(s) readed - Ok Record 9: 40 byte(s) readed - Ok Record 10: 40 byte(s) readed - Ok Record 11: 40 byte(s) readed - Ok Record 12: 40 byte(s) readed - Ok Record 13: 40 byte(s) readed - Ok Record 14: 40 byte(s) readed - Ok Record 15: 40 byte(s) readed - Ok Record 16: 40 byte(s) readed - Ok Field [117] 10 Record(s) Record 0: 4 byte(s) readed - Ok Record 1: 3 byte(s) readed - Ok Record 2: 6 byte(s) readed - Ok Record 3: 1 byte(s) readed - Ok Record 5: 10 byte(s) readed - Ok Record 6: 8 byte(s) readed - Ok Record 8: 42 byte(s) readed - Ok Record 13: 3 byte(s) readed - Ok Record 14: 3 byte(s) readed - Ok Record 16: 40 byte(s) readed - Ok Field [120] 4 Record(s) Record 0: 80 byte(s) readed - Ok Record 1: 160 byte(s) readed - Ok Record 2: 130 byte(s) readed - Ok Record 3: 112 byte(s) readed - Ok Field [153] 6 Record(s) Record 0: 68 byte(s) readed - Ok Record 1: 68 byte(s) readed - Ok Record 2: 68 byte(s) readed - Ok Record 3: 68 byte(s) readed - Ok Record 4: 68 byte(s) readed - Ok Record 5: 68 byte(s) readed - Ok Field [163] 1 Record(s) Record 0: 8 byte(s) readed - Ok Field [193] 4 Record(s) Record 2: 8 byte(s) readed - Ok Record 3: 32 byte(s) readed - Ok Record 4: 32 byte(s) readed - Ok Record 9: 64 byte(s) readed - Ok Field [202] 1 Record(s) Record 0: 1 byte(s) readed - Ok Field [217] 1 Record(s) Record 0: 32 byte(s) readed - Ok Field [218] 1 Record(s) Record 0: 2 byte(s) readed - Ok Field [232] 3 Record(s) Record 0: 20 byte(s) readed - Ok Record 2: 1 byte(s) readed - Ok Record 3: 1 byte(s) readed - Ok Field [238] 1 Record(s) Record 1: 1 byte(s) readed - Ok Field [239] 10 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 3072 byte(s) readed - Ok Record 2: 3072 byte(s) readed - Ok Record 3: 3072 byte(s) readed - Ok Record 4: 3072 byte(s) readed - Ok Record 5: 3072 byte(s) readed - Ok Record 6: 3072 byte(s) readed - Ok Record 7: 3072 byte(s) readed - Ok Record 8: 3072 byte(s) readed - Ok Record 9: 3072 byte(s) readed - Ok Field [250] 4 Record(s) Record 1: 2172 byte(s) readed - Ok Record 2: 128 byte(s) readed - Ok Record 3: 742 byte(s) readed - Ok Record 4: 40 byte(s) readed - Ok Field [301] 17 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 12 byte(s) readed - Ok Record 2: 36 byte(s) readed - Ok Record 3: 36 byte(s) readed - Ok Record 4: 36 byte(s) readed - Ok Record 5: 36 byte(s) readed - Ok Record 6: 36 byte(s) readed - Ok Record 7: 40 byte(s) readed - Ok Record 8: 40 byte(s) readed - Ok Record 9: 40 byte(s) readed - Ok Record 10: 40 byte(s) readed - Ok Record 11: 40 byte(s) readed - Ok Record 12: 40 byte(s) readed - Ok Record 13: 40 byte(s) readed - Ok Record 14: 40 byte(s) readed - Ok Record 15: 40 byte(s) readed - Ok Record 16: 40 byte(s) readed - Ok Field [308] 9 Record(s) Record 0: 1 byte(s) readed - Ok Record 1: 8192 byte(s) readed - Ok Record 3: 1 byte(s) readed - Ok Record 4: 1 byte(s) readed - Ok Record 5: 10 byte(s) readed - Ok Record 6: 1 byte(s) readed - Ok Record 7: 1 byte(s) readed - Ok Record 8: 1 byte(s) readed - Ok Record 9: 40 byte(s) readed - Ok Field [309] 6 Record(s) Record 0: 4 byte(s) readed - Ok Record 1: 2 byte(s) readed - Ok Record 2: 12 byte(s) readed - Ok Record 4: 12 byte(s) readed - Ok Record 7: 12 byte(s) readed - Ok Record 17: 12 byte(s) readed - Ok Field [320] 39 Record(s) Record 0: 148 byte(s) readed - Ok Record 1: 148 byte(s) readed - Ok Record 2: 148 byte(s) readed - Ok Record 3: 148 byte(s) readed - Ok Record 4: 148 byte(s) readed - Ok Record 5: 148 byte(s) readed - Ok Record 6: 148 byte(s) readed - Ok Record 7: 148 byte(s) readed - Ok Record 8: 148 byte(s) readed - Ok Record 9: 148 byte(s) readed - Ok Record 10: 148 byte(s) readed - Ok Record 11: 148 byte(s) readed - Ok Record 12: 148 byte(s) readed - Ok Record 13: 148 byte(s) readed - Ok Record 14: 148 byte(s) readed - Ok Record 15: 148 byte(s) readed - Ok Record 16: 148 byte(s) readed - Ok Record 17: 148 byte(s) readed - Ok Record 18: 148 byte(s) readed - Ok Record 19: 148 byte(s) readed - Ok Record 20: 148 byte(s) readed - Ok Record 21: 148 byte(s) readed - Ok Record 22: 148 byte(s) readed - Ok Record 23: 148 byte(s) readed - Ok Record 24: 148 byte(s) readed - Ok Record 25: 148 byte(s) readed - Ok Record 26: 148 byte(s) readed - Ok Record 27: 148 byte(s) readed - Ok Record 28: 148 byte(s) readed - Ok Record 29: 148 byte(s) readed - Ok Record 30: 148 byte(s) readed - Ok Record 31: 148 byte(s) readed - Ok Record 32: 148 byte(s) readed - Ok Record 33: 148 byte(s) readed - Ok Record 34: 148 byte(s) readed - Ok Record 35: 148 byte(s) readed - Ok Record 36: 148 byte(s) readed - Ok Record 37: 148 byte(s) readed - Ok Record 38: 148 byte(s) readed - Ok Field [322] 1 Record(s) Record 0: 1 byte(s) readed - Ok Field [325] 20 Record(s) Record 0: 38 byte(s) readed - Ok Record 1: 26 byte(s) readed - Ok Record 2: 26 byte(s) readed - Ok Record 3: 39 byte(s) readed - Ok Record 4: 26 byte(s) readed - Ok Record 5: 27 byte(s) readed - Ok Record 6: 39 byte(s) readed - Ok Record 7: 26 byte(s) readed - Ok Record 8: 67 byte(s) readed - Ok Record 9: 26 byte(s) readed - Ok Record 10: 125 byte(s) readed - Ok Record 11: 26 byte(s) readed - Ok Record 12: 112 byte(s) readed - Ok Record 13: 53 byte(s) readed - Ok Record 14: 25 byte(s) readed - Ok Record 15: 26 byte(s) readed - Ok Record 16: 26 byte(s) readed - Ok Record 17: 68 byte(s) readed - Ok Record 18: 46 byte(s) readed - Ok Record 19: 26 byte(s) readed - Ok Field [334] 1 Record(s) Record 0: 1 byte(s) readed - Ok Field [339] 2 Record(s) Record 0: 511 byte(s) readed - Ok Record 1: 511 byte(s) readed - Ok Field [341] 3 Record(s) Record 0: 1 byte(s) readed - Ok Record 3: 4 byte(s) readed - Ok Record 4: 4408 byte(s) readed - Ok Field [345] 1 Record(s) Record 0: 12 byte(s) readed - Ok Field [354] 1 Record(s) Record 0: 3 byte(s) readed - Ok Field [356] 2 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 8 byte(s) readed - Ok Field [362] 2 Record(s) Record 0: 1 byte(s) readed - Ok Record 1: 120 byte(s) readed - Ok Field [364] 27 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 12 byte(s) readed - Ok Record 2: 36 byte(s) readed - Ok Record 3: 36 byte(s) readed - Ok Record 4: 36 byte(s) readed - Ok Record 5: 36 byte(s) readed - Ok Record 6: 36 byte(s) readed - Ok Record 7: 40 byte(s) readed - Ok Record 8: 40 byte(s) readed - Ok Record 9: 40 byte(s) readed - Ok Record 10: 40 byte(s) readed - Ok Record 11: 40 byte(s) readed - Ok Record 12: 40 byte(s) readed - Ok Record 13: 40 byte(s) readed - Ok Record 14: 40 byte(s) readed - Ok Record 15: 40 byte(s) readed - Ok Record 16: 40 byte(s) readed - Ok Record 17: 40 byte(s) readed - Ok Record 18: 40 byte(s) readed - Ok Record 19: 40 byte(s) readed - Ok Record 20: 40 byte(s) readed - Ok Record 21: 40 byte(s) readed - Ok Record 22: 40 byte(s) readed - Ok Record 23: 40 byte(s) readed - Ok Record 24: 40 byte(s) readed - Ok Record 25: 40 byte(s) readed - Ok Record 26: 40 byte(s) readed - Ok Field [365] 17 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 12 byte(s) readed - Ok Record 2: 36 byte(s) readed - Ok Record 3: 36 byte(s) readed - Ok Record 4: 36 byte(s) readed - Ok Record 5: 36 byte(s) readed - Ok Record 6: 36 byte(s) readed - Ok Record 7: 40 byte(s) readed - Ok Record 8: 40 byte(s) readed - Ok Record 9: 40 byte(s) readed - Ok Record 10: 40 byte(s) readed - Ok Record 11: 40 byte(s) readed - Ok Record 12: 40 byte(s) readed - Ok Record 13: 40 byte(s) readed - Ok Record 14: 40 byte(s) readed - Ok Record 15: 40 byte(s) readed - Ok Record 16: 40 byte(s) readed - Ok Saved as C:\InfinityBox\BEST\Backup\RM-443 Nokia 6303 classic_35---------------_0_400.pm Done! Elapsed: 00:00:06 |
