![]() | #16276 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2007 Location: karachi pakistan
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | registered to: amc_khan Connect phone on selected interface... Core : v1.45 , FlashEngine : v1.40 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : 51DB9C69_rm635__10.65.mcusw PPM : 4673D235_rm635__10.10.ppm_m_c CNT : 4F8751F0_rm635__10.65.image_mr_black Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. BootRom : Verify Error ![]() Try again... -> Error answer from BootRom -> 1. Try make battery charge -> 2. Try insert charger, without pressing poweron -> 3. Try change USB port, if driver hang - restart PC Connect phone on selected interface... -> Error while flashing... ![]() Core : v1.45 , FlashEngine : v1.40 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : 51DB9C69_rm635__10.65.mcusw PPM : 4673D235_rm635__10.10.ppm_m_c CNT : 4F8751F0_rm635__10.65.image_mr_black Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. ASIC ID: 000000010000022600010006030C192101033000 CPU ID : RAP3Gv3 , Features : No any extended features RAP_PUB: 0FD00105D4B58E5666236382A5E88BF3BDC4D86C CMT_ROOT: 9DDBFCFE6E73CED7D8C6268C8EB85723 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:06 Reopening the connection... Waiting for response: 30 Waiting for response: 29 Waiting for response: 28 Waiting for response: 27 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing 51DB9C69_rm635__10.65.mcusw Found 6 areas to erase Erasing area 0x00000000 - 0x000006BF, NOR, CMT Result: 0000 Erasing area 0x000006C0 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00040000 - 0x000BFFFF, NOR, CMT Result: 0000 Erasing area 0x000C0000 - 0x0013FFFF, NOR, CMT Result: 0000 Erasing area 0x00140000 - 0x0137FFFF, NOR, CMT Result: 0000 Erasing area 0x01380000 - 0x0151FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:02:09 Write : Processing 51DB9C69_rm635__10.65.mcusw Total 1165 [1165/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] TIME : Write time : 00:00:56 MCU Write done ===Flashing [PPM]=== Erase : Processing 4673D235_rm635__10.10.ppm_m_c Found 1 areas to erase Erasing area 0x01520000 - 0x01DBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:53 Write : Processing 4673D235_rm635__10.10.ppm_m_c Total 198 [198/0/0] blocks to write, writing... TIME : Write time : 00:00:09 PPM Write done ===Flashing [CNT]=== Erase : Processing 4F8751F0_rm635__10.65.image_mr_black Found 2 areas to erase Erasing area 0x01DC0000 - 0x0215FFFF, NOR, CMT Result: 0000 Erasing area 0x02160000 - 0x03FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:06:13 Checking content info... Check Image : Content size is 128k, use direct write mode Write : Processing 4F8751F0_rm635__10.65.image_mr_black Total 488 [488/0/0] blocks to write, writing... TIME : Write time : 00:00:25 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:10:46 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 2690 Software Info: V 10.65 09-12-10 RM-635 (c) Nokia IMEI: 353411040679666 PPM version : V 10.10 22-04-10 RM-635 (c) Nokia M_C Product code: 0592078 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! AfterFlash operations done ;D Done! Elapsed: 00:12:05 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... |
![]() | #16277 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] PAPUBkeys : 85F252E351E225CAFC4DFBC8041EABD2823E3500 ADL: Preparing for write certificates... Erase CCC... Ok Writing CCC... Ok Erase HWC... Ok Writing HWC... Ok ADL: Writing Flash certs done! ![]() ADL: Close_Session Content: 000300000000010000000100000000 ADL: Reboot All done, disconneting... Done! Elapsed: 00:00:04 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Processing Server SX4 Auth Checking SDD key... Check SD : Key is Ok Operating mode is OK, no need change... Connecting to server... Connection error #1 Server not found... SX4 Auth error ![]() Uploading RF/Battery tune to phone... Using : RM-469.pm Setting to : 0578069 Operating mode is OK, no need change... Check ST_SECURITY now... Security status : ST_SECURITY => DAMAGED ![]() - > Try "Restore CCC/HWC" option, after SX4 again Done! Elapsed: 00:00:00 |
![]() | #16278 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | card found: S/N 252D:0118 registered to: amc_khan Connect phone on selected interface... UFS S/N 102641 boot - Ok Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Resetting selected items... Check phone mode... Phone in Local mode Seting Test mode... wait... Test mode set Settings Full Factory Defaults... Set OK! Settings Software Upgrade Defaults... Set OK! Settings Service Centre Defaults... Set OK! Settings Production Tune Defaults... Set OK! Settings User Data Defaults... Set OK! Settings Leave Factory defaults... Set OK! Elapsed: 00:00:12 Phone disconected! Connect phone on selected interface... card found: S/N 252D:0118 registered to: amc_khan Connect phone on selected interface... Backup Certificates now... Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000030000022600010007600C192102011104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001040 EM1 ID: 00001030 PUBLIC ID: 20900109DA300E49FA1835E9C7E17E74517BDFF9 ASIC MODE ID: 00 ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 ROM ID: 3E273BF637BE26FA Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 00400020 Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! ![]() TIME : Boot time : 00:00:01 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] PAPUBkeys : 85F252E351E225CAFC4DFBC8041EABD2823E3500 ADL: Reading certificates... Reading NPC certificate... IMEI : 359327030416055 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... Cert Read done! ADL: Reading certificates done! ![]() ADL: Close_Session Content: 000300000000010000000100000000 ADL: Reboot Wait, reconneting... SLx Simlock Data read ... ok SL3 Simlock Sign read ... ok WMDRM read ... ok CRT308 Backup Created NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... Swap data collected to 0578069.pc RPL saved : D:\BEST\Backup\Cert\359327030416055.rpl All done, Disconnecting Elapsed: 00:00:21 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok |
![]() | #16279 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Read Uniq key data started... - > Power Off phone, dissconnect it - > Phone was not powered Off Read fail...! Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... Read Uniq key data started... Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... ASIC ID: 000000030000022600010007600C192102011104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB PUBLIC ID: 20900109DA300E49FA1835E9C7E17E74517BDFF9 ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 Fetching data, wait... - > Reinsert cable and battery, press powerOn button again - > For X7, E7 - just waiting, near 1 minute - > When BEST start Search Phone - Press PowerOn if needed Read Uniq key data started... Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : Error on 1st boot Check cable, Battery. Try again -> Error answer from BootRom Fetching failed! Connect phone on selected interface... Read fail...! Connect phone on selected interface... Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000030000022600010007600C192102011104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001040 EM1 ID: 00001030 PUBLIC ID: 20900109DA300E49FA1835E9C7E17E74517BDFF9 ASIC MODE ID: 00 ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 ROM ID: 3E273BF637BE26FA Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 00400020 Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Phone disconected! Connect phone on selected interface... Transmission type request fail [000000] -> Boot error... ![]() Error, phone reboot not done #2 (Phone was not BootUp) rap= hash= key= - > You can insert data in "special.log" manually - > Or repeat procedure again Read fail...! Connect phone on selected interface... Read Uniq key data started... Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... ASIC ID: 000000030000022600010007600C192102011104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB PUBLIC ID: 20900109DA300E49FA1835E9C7E17E74517BDFF9 ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 Fetching data, wait... - > Reinsert cable and battery, press powerOn button again - > For X7, E7 - just waiting, near 1 minute - > When BEST start Search Phone - Press PowerOn if needed Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000030000022600010007600C192102011104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001040 EM1 ID: 00001030 PUBLIC ID: 20900109DA300E49FA1835E9C7E17E74517BDFF9 ASIC MODE ID: 00 ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 ROM ID: 3E273BF637BE26FA Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 00400020 Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! ![]() TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] PAPUBkeys : 85F252E351E225CAFC4DFBC8041EABD2823E3500 ADL: Close_Session Content: 000300000000010000000100000000 ADL: Reboot Wait, reconneting... rap= 20900109DA300E49FA1835E9C7E17E74517BDFF9 hash= 25B977A055BE9B5DEC0C38A2A279C695 key= 8BB052EB667DA13AE3622A02D46D82E3534E2956 Key file updated... Done! |
![]() | #16280 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Repair SD procedure started... Phone Imei: 359327030416055 Key file exists, no need to read... Accepted SdRepReq (on alive SD) by user Operating mode is OK, no need change... Writing Super Dongle Key... Ok! Done! Repair SL procedure started... Phone Imei: 359327030416055 Key file exists, no need to read... Operating mode is OK, no need change... Writing SimLock Data... Error Repair fail...! ( SL3 phone? ) Local SX4 procedure started... Check SD : Key is Ok Phone Imei: 359327030416055 Use custom key... Step 1... Step 2... Step 3... SX4 Auth - Ok |
![]() | #16281 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Upload PM checked Uploading RF/Battery tune to phone... Using : RM-469.pm Setting to : 0578069 Operating mode is OK, no need change... Check ST_SECURITY now... Security status : ST_SECURITY => DAMAGED ![]() - > Try "Restore CCC/HWC" option, after SX4 again Done! Elapsed: 00:00:00 Upload done Uploading RF/Battery tune to phone... Using : RM-469.pm Setting to : 0578069 Operating mode is OK, no need change... Check ST_SECURITY now... Security status : ST_SECURITY => DAMAGED ![]() - > Try "Restore CCC/HWC" option, after SX4 again Done! Elapsed: 00:00:00 Checking StartUp data ... ----------------------- SDD Key status : SDData is Ok SimLock status : SimLock is Ok Security status : Security Damaged!!!!! ![]() - > Do Local SX4 or Server SX4 , Upload Tune ( checkbox or manual ) ----------------------- PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 Done! Uploading RF/Battery tune to phone... Using : RM-469.pm Setting to : 0578069 Operating mode is OK, no need change... Check ST_SECURITY now... Security status : ST_SECURITY => DAMAGED ![]() - > Try "Restore CCC/HWC" option, after SX4 again Done! |
![]() | #16282 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Using : RM-469.rpl CCC Data found! HWC Data found! Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000030000022600010007600C192102011104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001040 EM1 ID: 00001030 PUBLIC ID: 20900109DA300E49FA1835E9C7E17E74517BDFF9 ASIC MODE ID: 00 ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 ROM ID: 3E273BF637BE26FA Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 00400020 Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! ![]() TIME : Boot time : 00:00:01 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] PAPUBkeys : 85F252E351E225CAFC4DFBC8041EABD2823E3500 ADL: Preparing for write certificates... Erase CCC... Ok Writing CCC... Ok Erase HWC... Ok Writing HWC... Ok ADL: Writing Flash certs done! ![]() ADL: Close_Session Content: 000300000000010000000100000000 ADL: Reboot All done, disconneting... Done! |
![]() | #16283 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Elapsed: 00:00:00 Uploading RF/Battery tune to phone... Using : RM-469.pm Setting to : 0578069 Operating mode is OK, no need change... Check ST_SECURITY now... Security status : ST_SECURITY => DAMAGED ![]() - > Try "Restore CCC/HWC" option, after SX4 again Done! Elapsed: 00:00:00 Will Write CCC/HWC keys now... Elapsed: 00:00:04 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Repair SD procedure started... Phone Imei: 359327030416055 Key file exists, no need to read... Accepted SdRepReq (on alive SD) by user Operating mode is OK, no need change... Writing Super Dongle Key... Ok! Done! Repair SL procedure started... Phone Imei: 359327030416055 Key file exists, no need to read... Operating mode is OK, no need change... Writing SimLock Data... Error Repair fail...! ( SL3 phone? ) Local SX4 procedure started... Check SD : Key is Ok Phone Imei: 359327030416055 Use custom key... Step 1... Step 2... Step 3... SX4 Auth - Ok Upload PM checked Uploading RF/Battery tune to phone... Using : RM-469.pm Setting to : 0578069 Operating mode is OK, no need change... Check ST_SECURITY now... Security status : ST_SECURITY => DAMAGED ![]() - > Try "Restore CCC/HWC" option, after SX4 again Done! |
![]() | #16284 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Check ST_SECURITY now... Security status : ST_SECURITY => DAMAGED ![]() - > Try "Restore CCC/HWC" option, after SX4 again Done! Elapsed: 00:00:00 Upload done Will Write CCC/HWC keys now... Using : RM-469.rpl CCC Data found! HWC Data found! Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000030000022600010007600C192102011104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001040 EM1 ID: 00001030 PUBLIC ID: 20900109DA300E49FA1835E9C7E17E74517BDFF9 ASIC MODE ID: 00 ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 ROM ID: 3E273BF637BE26FA Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 00400020 Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! ![]() TIME : Boot time : 00:00:01 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] PAPUBkeys : 85F252E351E225CAFC4DFBC8041EABD2823E3500 ADL: Preparing for write certificates... Erase CCC... Ok Writing CCC... Ok Erase HWC... Ok Writing HWC... Ok ADL: Writing Flash certs done! ![]() ADL: Close_Session Content: 000300000000010000000100000000 ADL: Reboot All done, disconneting... Done! |
![]() | #16285 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Elapsed: 00:00:00 Upload done Uploading RF/Battery tune to phone... Using : RM-469.pm Setting to : 0578069 Operating mode is OK, no need change... Check ST_SECURITY now... Security status : ST_SECURITY => DAMAGED ![]() - > Try "Restore CCC/HWC" option, after SX4 again Done! Elapsed: 00:00:00 Local SX4 procedure started... Check SD : Key is Ok Phone Imei: 359327030416055 Use custom key... Step 1... Step 2... Step 3... SX4 Auth - Ok Upload PM checked Uploading RF/Battery tune to phone... Using : RM-469.pm Setting to : 0578069 Operating mode is OK, no need change... Elapsed: 00:00:04 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Processing Server SX4 Auth Checking SDD key... Check SD : Key is Ok Operating mode is OK, no need change... Connecting to server... Connection error #1 Server not found... SX4 Auth error ![]() Local SX4 procedure started... Check SD : Key is Ok Phone Imei: 359327030416055 Use custom key... Step 1... Step 2... Step 3... SX4 Auth - Ok Upload PM checked Uploading RF/Battery tune to phone... Using : RM-469.pm Setting to : 0578069 Operating mode is OK, no need change... Check ST_SECURITY now... Security status : ST_SECURITY => DAMAGED ![]() - > Try "Restore CCC/HWC" option, after SX4 again Done! |
![]() | #16286 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Elapsed: 00:00:00 Upload done Will Write CCC/HWC keys now... Using : RM-469.rpl CCC Data found! HWC Data found! Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000030000022600010007600C192102011104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001040 EM1 ID: 00001030 PUBLIC ID: 20900109DA300E49FA1835E9C7E17E74517BDFF9 ASIC MODE ID: 00 ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 ROM ID: 3E273BF637BE26FA Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 00400020 Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! ![]() TIME : Boot time : 00:00:01 |
![]() | #16287 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | card found: S/N 252D:0118 registered to: amc_khan Connect phone on selected interface... Core : v1.45 , FlashEngine : v1.40 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm607__03.35.mcusw PPM : 5FC9E6E8_rm607__03.35.ppm_m_c CNT : 262C5BC4_rm607__03.35.image_m_c_059B107 Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" - just reinsert battery -> If flashing freeze - reinsert cable and try again --- Press phone's power button or insert charger! --- Connection opened successfully DBG : F00A1FB300020303010100FF CPUID : XGOLD 213 2nd boot Ok, 01 2nd ready, AA Sending Algo Algo sent Ok BL : Quantum_Bootloader_10.37_M1S1 Speed accepted, use 6.500.000 FLASHID : 89008289 FLIC conf set, RST set Boot done! Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI : 357021045733073 PCcode : 059G896 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : D:\BEST\Backup\Cert\357021045733073_XG213_CRT.rpl ===Flashing [MCU]=== File : rm607__03.35.mcusw Image : rm607__03.35.mcusw_ebl_psi.fls Cert block found, sending.... Cert sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:01 Write , Start : 0x40040000 , Len : 0x00040000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40080000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40080000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 4/5 Erase , Start : 0x400A0000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:04 Write , Start : 0x400A0000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 5/5 Erase , Start : 0x40400000 , Len : 0x01800000 Erasing, wait ... Erase done, time : 00:02:00 Write , Start : 0x40400000 , Len : 0x01780000 Flashing , wait ... Region flash done, time : 00:00:33 ===Flashing [PPM]=== File : 5FC9E6E8_rm607__03.35.ppm_m_c Image : package_m_c.ppm_ebl_psi.fls Cert block found, sending.... Cert sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41C00000 , Len : 0x00600000 Erasing, wait ... Erase done, time : 00:00:16 Write , Start : 0x41C00000 , Len : 0x00319A48 Flashing , wait ... Region flash done, time : 00:00:03 ===Flashing [CNT]=== File : 262C5BC4_rm607__03.35.image_m_c_059B107 Image : package_m_c_059B107.image.fls Cert block found, sending.... Cert sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x42200000 , Len : 0x01C60000 Erasing, wait ... Erase done, time : 00:04:09 Write , Start : 0x42200000 , Len : 0x00B40000 Flashing , wait ... Region flash done, time : 00:00:18 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:07 No write data, skip Flashing done! Total flash time : 00:07:38 Reboot phone now... Reading Phone Info.... Connected phone - C1-01 Software Info: V 03.35 02-12-10 RM-607 (c) Nokia IMEI: 357021045733073 PPM version : V 03.35 02-12-10 RM-607 (c) Nokia M_C Product code: 059G896 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 39 certs Data exist, skip certificate repair... AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:08:48 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
![]() | #16288 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | card found: S/N 252D:0118 registered to: amc_khan Connect phone on selected interface... Core : v1.47 , FlashEngine : v1.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : C5F02102_rm495__07.97.mcusw PPM : rm495__07.90.ppm_mena_b CNT : E24393CE_rm495__07.97.image_mena_a1_red Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. ASIC ID: 000000010000022600010006030C192101033000 CPU ID : RAP3Gv3 , Features : No any extended features RAP_PUB: 1240021393767D56C22643B7F2EB5EFB5BE3F963 CMT_ROOT: 9DDBFCFE6E73CED7D8C6268C8EB85723 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... -> Error while send data to phone! Check battery, connection. Try again Connect phone on selected interface... -> Error while flashing... ![]() Core : v1.47 , FlashEngine : v1.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : C5F02102_rm495__07.97.mcusw PPM : rm495__07.90.ppm_mena_b CNT : E24393CE_rm495__07.97.image_mena_a1_red Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. ASIC ID: 000000010000022600010006030C192101033000 CPU ID : RAP3Gv3 , Features : No any extended features RAP_PUB: 1240021393767D56C22643B7F2EB5EFB5BE3F963 CMT_ROOT: 9DDBFCFE6E73CED7D8C6268C8EB85723 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:06 Reopening the connection... Waiting for response: 30 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing C5F02102_rm495__07.97.mcusw Found 6 areas to erase Erasing area 0x00000000 - 0x000006BF, NOR, CMT Result: 0000 Erasing area 0x000006C0 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00040000 - 0x000BFFFF, NOR, CMT Result: 0000 Erasing area 0x000C0000 - 0x0013FFFF, NOR, CMT Result: 0000 Erasing area 0x00140000 - 0x0137FFFF, NOR, CMT Result: 0000 Erasing area 0x01380000 - 0x0151FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:02:46 Write : Processing C5F02102_rm495__07.97.mcusw Total 1178 [1178/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] TIME : Write time : 00:00:56 MCU Write done ===Flashing [PPM]=== Erase : Processing rm495__07.90.ppm_mena_b Found 1 areas to erase Erasing area 0x01520000 - 0x01DBFFFF, NOR, CMT Erase : ERR1 : connection lost or data missmatch EraseFile: Error: Erasure error, Area: 1 TIME : Erase time : 00:00:31 Connect phone on selected interface... -> Error while flashing... ![]() |
![]() | #16289 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Core : v1.47 , FlashEngine : v1.5 Selected FlashSettings : SafeFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : C5F02102_rm495__07.97.mcusw PPM : rm495__07.90.ppm_mena_b Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. ASIC ID: 000000010000022600010006030C192101033000 CPU ID : RAP3Gv3 , Features : No any extended features RAP_PUB: 1240021393767D56C22643B7F2EB5EFB5BE3F963 CMT_ROOT: 9DDBFCFE6E73CED7D8C6268C8EB85723 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... -> Error while send data to phone! Check battery, connection. Try again Connect phone on selected interface... -> Error while flashing... ![]() Core : v1.47 , FlashEngine : v1.5 Selected FlashSettings : SafeFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : C5F02102_rm495__07.97.mcusw PPM : rm495__07.90.ppm_mena_b Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. ASIC ID: 000000010000022600010006030C192101033000 CPU ID : RAP3Gv3 , Features : No any extended features RAP_PUB: 1240021393767D56C22643B7F2EB5EFB5BE3F963 CMT_ROOT: 9DDBFCFE6E73CED7D8C6268C8EB85723 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... -> Error while send data to phone! Check battery, connection. Try again Connect phone on selected interface... -> Error while flashing... ![]() |
![]() | #16290 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Core : v1.47 , FlashEngine : v1.5 Selected FlashSettings : SafeFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : C5F02102_rm495__07.97.mcusw PPM : rm495__07.90.ppm_mena_b Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. BootRom : Verify Error ![]() Try again... -> Error answer from BootRom -> 1. Try make battery charge -> 2. Try insert charger, without pressing poweron -> 3. Try change USB port, if driver hang - restart PC Connect phone on selected interface... -> Error while flashing... ![]() Core : v1.47 , FlashEngine : v1.5 Selected FlashSettings : SafeFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : C5F02102_rm495__07.97.mcusw PPM : rm495__07.90.ppm_mena_b Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- -> Phone not found.. ![]() -> Error while flashing... ![]() Core : v1.47 , FlashEngine : v1.5 Selected FlashSettings : SafeFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : C5F02102_rm495__07.97.mcusw PPM : rm495__07.90.ppm_mena_b Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. ASIC ID: 000000010000022600010006030C192101033000 CPU ID : RAP3Gv3 , Features : No any extended features RAP_PUB: 1240021393767D56C22643B7F2EB5EFB5BE3F963 CMT_ROOT: 9DDBFCFE6E73CED7D8C6268C8EB85723 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... -> Error while send data to phone! Check battery, connection. Try again Connect phone on selected interface... -> Error while flashing... ![]() |
