![]() | #24527 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2005 Location: Pakistan
Member: 192810 Status: Offline Sonork: Some people NEED change Thanks Meter: 860 | Nokia 210 Flashing Done. Code: Core : v2.10 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm924__06.09.mcusw PPM : rm924__06.09.ppm_ma3 CNT : rm924__06.09.image_ma3_059R775 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.56_M1S1 Speed accepted, use 6.500.000 FLASHID : EC001230 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 357897055519365 IMEI 2 : 357897055519373 PCcode : 059R775 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : E:\InfinityBox\BEST\Backup\Cert\357897055519365_XG213_CRT.rpl Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm924__06.09.mcusw Image : rm924__06.09.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:02 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01A40000 Erasing, wait ... Erase done, time : 00:00:54 Write , Start : 0x40280000 , Len : 0x01A40000 Flashing , wait ... Region flash done, time : 00:00:37 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip [Minor Error] : CRC returned by phone is wrong! [CHK] : 0100E361 ===Flashing [PPM]=== File : rm924__06.09.ppm_ma3 Image : package_ma3.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41CC0000 , Len : 0x00640000 Erasing, wait ... Erase done, time : 00:00:08 Write , Start : 0x41CC0000 , Len : 0x003EFB64 Flashing , wait ... Region flash done, time : 00:00:04 CRC check passed , 0x44C0 ===Flashing [CNT]=== File : rm924__06.09.image_ma3_059R775 Image : package_ma3_059R775.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x42300000 , Len : 0x01B20000 Erasing, wait ... Erase done, time : 00:01:09 Write , Start : 0x42300000 , Len : 0x00C60000 Flashing , wait ... Region flash done, time : 00:00:17 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:02 No write data, skip CRC check passed , 0x2A28 Flashing done! Total flash time : 00:03:19 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 210 Software Info: V 06.09 14-10-13 RM-924 (c) Nokia IMEI: 357897055519365 PPM version : V 06.09 14-10-13 RM-924 (c) Nokia MA3 Product code: 059R775 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 58 certs Certificates found, skip upload ... Battery voltage is enough for start AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:05:33 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
![]() | #24530 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2007
Member: 433097 Status: Offline Sonork: 100.1661890 Thanks Meter: 8,074 | Q Mobile_i5_ Dead Recovery Successful, Done .:: BY-V1.26::. ..::: Chinese Miracle-2 MTK:::.. Code:
The Following User Says Thank You to kabul For This Useful Post: |
![]() | #24531 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2006 Location: Pakistan karachi
Member: 314003 Status: Offline Thanks Meter: 3,003 | G five glory A86 format done Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 13 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575|MT6577_S00 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : M00SJ [eMMC] : FLASH_CID : 1501004E4A5330304D00D7C45B899FEB [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Backup : Skipped by user request FMT Mode set to : 0 Format : UserData Only (Factory Reset) Format UDA block Format block Ok! Done! Elapsed: 00:00:16 |
![]() | #24532 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2007 Location: PAKISTAN
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | NOkia 110 Flash Done :) Code: Phone found! Series 40 Device detected! read info... - Ok Core : v2.10 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm827__03.51.mcusw PPM : rm827__03.51.ppm_m4 CNT : rm827__03.51.image_m4_059N407 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> Check SW version... FlashFile version : 03.51 Phone version : 03.04 20-04-12 RM-827 (c) Nokia -> Check SW version : Upgrade Backup CRT308 data... CRT308 Backup Created Check communication with phone.... ADL req restart Communication verify done... Preparing... Check communication with phone... SL3 Simlock read (XGOLD) ... Ok WMDRM Key read ... Ok CMLA Key read ... Ok Reboot.... -> If Phone start charge - just reinsert battery fast Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.49_M1S1 Speed accepted, use 6.500.000 FLASHID : 89008289 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 355493051751400 IMEI 2 : 355493051751418 PCcode : 059N412 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... CMLA_KEY Data saved... RPL saved : F:\1+Flashing Software\1+BEST\InfinityBox\BEST\Backup\Cert\355493051751400_2nd_XG213.rpl Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm827__03.51.mcusw Image : rm827__03.51.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:01 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:05 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01940000 Erasing, wait ... Erase done, time : 00:02:08 Write , Start : 0x40280000 , Len : 0x018C0000 Flashing , wait ... Region flash done, time : 00:00:35 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0xA3D6 ===Flashing [PPM]=== File : rm827__03.51.ppm_m4 Image : package_m4.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41BC0000 , Len : 0x00600000 Erasing, wait ... Erase done, time : 00:00:16 Write , Start : 0x41BC0000 , Len : 0x0038DDEC Flashing , wait ... Region flash done, time : 00:00:04 CRC check passed , 0xD10F ===Flashing [CNT]=== File : rm827__03.51.image_m4_059N407 Image : package_m4_059N407.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x421C0000 , Len : 0x01C60000 Erasing, wait ... Erase done, time : 00:04:17 Write , Start : 0x421C0000 , Len : 0x00F60000 Flashing , wait ... Region flash done, time : 00:00:27 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:08 No write data, skip CRC check passed , 0x78A1 Flashing done! Total flash time : 00:08:07 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 110 Software Info: V 03.51 06-08-13 RM-827 (c) Nokia IMEI: 355493051751400 PPM version : V 03.51 06-08-13 RM-827 (c) Nokia M4 Product code: 059N2R0 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:08:53 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... |
![]() | #24533 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Nokia 701 Factory Reset DOne :) Code: Backup Certificates now... Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000030000022600010007400C192103032108 CPU ID : RAPU v21 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001040 EM1 ID: 00001030 PUBLIC ID: 161C0000FFFB7C405A9167C397A30618155FE6D9 ASIC MODE ID: 00 ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706 ROM ID: 2CAC45E23BC33C8B Use RAPUv21_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 006000EC Req : XSR 1.6 Use RAPUv21_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : FEB3BB7481D3E5D0EAC907335A4402A071493D53 ADL: Reading certificates... Reading NPC certificate... IMEI : 358272045063040 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... ADL: Reading certificates done! :) ADL: Close_Session Content: 000300000000030000000300000000 ADL: Reboot Wait, reconneting... SLx Simlock Data read ... Ok SL3 Simlock Sign read ... Ok WMDRM read ... Ok CRT308 Backup Created NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : F:\1+Flashing Software\1+BEST\InfinityBox\BEST\Backup\Cert\358272045063040.rpl All done, Disconnecting Elapsed: 00:01:29 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia 701 Software ver : V 79u_sr2_12w20.8 20-08-12 RM-774 (c) Nokia IMEI : 358272045063040 XappVer : 00000834 Ape Ver : 113.010.1506 APE Var : 113.010.1506113.010.1506.11.01113.010.1506.C00.01 APE ADSP: 256 DSP Ver : 79u_sr2_12w20_2 APE Test: 0.037 PPM : CNT : Product SN : M1L585111 Product code : 059H226 Base Prd.code: 059G8T9 Long Prod.SN : 0 Hardware info======= HWID : 2011 Retu : 40 Tahvo : 00 Batery: 3751 mV APE BT: HCI Version 4 (rev. 0). LMP Version 4 (rev. 7455). Manufacturer 13. APE HW: 256 Lock info =========== IMEI : 358272045063040 IMEI spNet : 3A 85 72 02 54 60 03 04 IMEI svNet : 33 85 72 02 54 60 03 34 F0 Conf key : 0000000000000000 Provider key : 2440700000000000 Country : Finland Operator : NOKIA (Open) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= CRT308 Backup Created SDD key status : Ok CMLA Key status : Ok SimLock status : Ok Security status : Ok PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 User code : Crypted UserDataExLevel : Low [Gallery] , FullFlash method Done! Resetting selected items... Check phone mode... Phone in Local mode Seting Test mode... wait... Test mode set Settings Full Factory Defaults... Set OK! Settings Software Upgrade Defaults... Set OK! Settings Service Centre Defaults... Set OK! Settings Production Tune Defaults... Set OK! Settings User Data Defaults... Set OK! Settings Leave Factory defaults... Set OK! Elapsed: 00:00:07 |
![]() | #24534 (permalink) |
Member: 192810 Status: Offline Sonork: Some people NEED change Thanks Meter: 860 | Qmobile R750 Read User Code Done ![]() Code: Operation : Read UserCode [ v1.26 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 166 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 31AF0AFA92B55F28F9804DB384DC438C BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0x02 , Ver : 142.0 , BBID : 0x00 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00EC , [GigaDevice] GD25LQ32 [0] : FLASH_DIE : 00C8 0060 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS : 0x003FE000 , 0x00002000 Read ExtData Sorting ExtData Reading UserCode Active : Yes , Code : 7866 PLock|MobTrack : Not active Done! Elapsed: 00:00:17 Reconnect Power/Cable! |
![]() | #24535 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: May 2013 Location: TkinterPy,Hex Cal,Ext2,Ext4,
Member: 1937038 Status: Offline Sonork: QQ 2045657399 Thanks Meter: 4,492 | Nokia 210 flash done. Connect phone on selected interface... Core : v2.10 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm925__04.12.mcusw PPM : rm925__04.12.ppm_t CNT : rm925__04.12.image_t_059S8T1 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.56_M1S1 Speed accepted, use 6.500.000 FLASHID : EC001230 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI : 355513051796749 PCcode : 059T2M4 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\355513051796749_XG 213_CRT.rpl Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm925__04.12.mcusw Image : rm925__04.12.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:02 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01A40000 Erasing, wait ... Erase done, time : 00:00:54 Write , Start : 0x40280000 , Len : 0x01A40000 Flashing , wait ... Region flash done, time : 00:00:41 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0xDDFF ===Flashing [PPM]=== File : rm925__04.12.ppm_t Image : package_t.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41CC0000 , Len : 0x00640000 Erasing, wait ... Erase done, time : 00:00:08 Write , Start : 0x41CC0000 , Len : 0x0055E70C Flashing , wait ... Region flash done, time : 00:00:07 CRC check passed , 0xC889 ===Flashing [CNT]=== File : rm925__04.12.image_t_059S8T1 Image : package_t_059S8T1.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x42300000 , Len : 0x01B20000 Erasing, wait ... Erase done, time : 00:01:03 Write , Start : 0x42300000 , Len : 0x00AC0000 Flashing , wait ... Region flash done, time : 00:00:14 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:02 No write data, skip CRC check passed , 0xF83C Flashing done! Total flash time : 00:03:17 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 210 Software Info: V 04.12 21-05-13 RM-925 (c) Nokia IMEI: 355513051796749 PPM version : V 04.12 21-05-13 RM-925 (c) Nokia T Product code: 059T2M4 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 58 certs Certificates found, skip upload ... ===== WARNING ===== Battery voltage is NOT enough for start ===== WARNING ===== AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:04:14 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
![]() | #24536 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2005 Location: TITI 2002 SERVIS CELULAR PG/AL
Member: 193804 Status: Offline Sonork: 100.1684818 Thanks Meter: 1,707 | ![]() Operation : Repair Security [ v1.24 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 59 ] Sync... Init Ok, waiting for phone ... Reading initial info, wait... Phone Info : BB : MT6572, E01 HW : MBK72_WET_JB3_HSPA_HW SW : MOLY.WR8.W1315.MD.WG.MP.V1.P14 MM : 2000.00.00 VR : 1.0 SN : 062701MT012345678901269960_081805 10 Security Info : IMEI [1] : Damaged! IMEI [2] : Damaged or not exists Read Ok! Update IMEI[1] to : 352072064849345 done! Done! Elapsed: 00:01:10 Reconnect Power/Cable! |
![]() | #24537 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Dec 2005 Location: KOLKATA INDIA
Member: 207734 Status: Offline Sonork: 100.1612198 Thanks Meter: 141 | Zte Blade G2 Hang on LOgo solved Operation : Check / Read Info [ v1.25 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 20 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6583 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6583|6589_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 484A0190643147340B01860481501B00 DA Stat : v3.2 on BBID : 0x86 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d1G4 [eMMC] : FLASH_CID : 90014A48344731640486010B001B5081 [eMMC] : FLASH_LEN : 0x00000000E7000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : ZTE ProdName : P188F03 ProdModel : ZTE Blade G2 Device : P188F03 AndroidVer: 4.2.1 MTKxCPU : MT6589 MTKxPRJ : DIS-IN-TB18D-P188F03V1.0.0 Done! Elapsed: 00:00:23 Reconnect Power/Cable! Operation : Format FileSystem [ v1.25 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 20 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6583 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6583|6589_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 484A0190643147340B01860481501B00 DA Stat : v3.2 on BBID : 0x86 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d1G4 [eMMC] : FLASH_CID : 90014A48344731640486010B001B5081 [eMMC] : FLASH_LEN : 0x00000000E7000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Backup : Skipped by user request FMT Mode set to : 0 Format : UserData Only (Factory Reset) Format UDA block Format block Ok! Done! Elapsed: 00:00:22 Reconnect Power/Cable! |
![]() | #24538 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,003 | QMOBILE A20 wirte scatter dead recaver Code: ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 31 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6583 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6583|6589_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 4B0001153030534ACD1A034DDD601949 DA Stat : v3.2 on BBID : 0x86 DRAM not initialized , configure DRAM Settings DRAM EmiReq Ok , 0x00B8 DRAM Init Ok , 0x40000000 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : M00SJ [eMMC] : FLASH_CID : 1501004B4A5330304D031ACD491960DD [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6589 , Project : MTK6589 , Storage : eMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Switching to HSUSB HSUSB Init Ok BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000600000-0x0000000000100000 Erase : 0x0000000002720000-0x0000000075A60000 Flash Pre-Erase Done, time used : 00:00:06 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0015 Update PMT by user request Repartition Done! Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : EBR2 Image Flash Ok Flash now : ANDROID Image Flash Ok Flash Write Done, time used : 00:01:49 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : EBR2 Verify Passed : ANDROID Data Verify Done, time used : 00:00:30 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:02:48 |
![]() | #24539 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2008 Location: PAKISTAN KARACHI Age: 44
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | Samsung SM-N900 remove gmai INFO Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 23 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 45010053454D3034472834BDB0BDD117 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0045 , OEM : 0100 [eMMC] : FLASH_INF : G40ME [eMMC] : FLASH_CID : 45010053454D3034472834BDB0BDD117 [eMMC] : FLASH_LEN : 0x00000000EC000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : samsung ProdName : ja3gxx ProdModel : SM-N900 Device : ja3g AndroidVer: 4.2.2 MTKxCPU : MT6589 MTKxPRJ : ALPS.JB3.MP.V1 Done! Elapsed: 00:00:13 Reconnect Power/Cable! Code: Wait for phone... Phone found! [ 23 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 45010053454D3034472834BDB0BDD117 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0045 , OEM : 0100 [eMMC] : FLASH_INF : G40ME [eMMC] : FLASH_CID : 45010053454D3034472834BDB0BDD117 [eMMC] : FLASH_LEN : 0x00000000EC000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! LSSA Ok! LSSW Ok! LSSS Ok! LSSK Ok! LSSG Ok! Security Settings : Clear Ok! [Info] : Android 5.x / MT67xx : If phone stuck on "Logo" 1. Wait 2-3 minutes. Power Off phone by long press "Power" button 2. Power On phone again 3. Or wait up to 3-7 minutes, until phone start by itself 4. Also recommended reboot phone twice before start use it |
![]() | #24540 (permalink) |
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | Nokia 210 write flash Code: Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm924__04.12.mcusw PPM : rm924__04.12.ppm_ma3 CNT : rm924__04.12.image_ma3_059T632 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.56_M1S1 Speed accepted, use 6.500.000 FLASHID : EC001230 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 358366054064384 IMEI 2 : 358366054064392 PCcode : 059R9P0 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\358366054064384_XG213_CRT.rpl Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm924__04.12.mcusw Image : rm924__04.12.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:01 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01A40000 Erasing, wait ... Erase done, time : 00:00:53 Write , Start : 0x40280000 , Len : 0x01A40000 Flashing , wait ... Region flash done, time : 00:00:41 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0x7DFD ===Flashing [PPM]=== File : rm924__04.12.ppm_ma3 Image : package_ma3.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41CC0000 , Len : 0x00640000 Erasing, wait ... Erase done, time : 00:00:08 Write , Start : 0x41CC0000 , Len : 0x003EE5C4 Flashing , wait ... Region flash done, time : 00:00:05 CRC check passed , 0x86E8 ===Flashing [CNT]=== File : rm924__04.12.image_ma3_059T632 Image : package_ma3_059T632.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x42300000 , Len : 0x01B20000 Erasing, wait ... Erase done, time : 00:01:14 Write , Start : 0x42300000 , Len : 0x00C20000 Flashing , wait ... Region flash done, time : 00:00:17 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:02 No write data, skip CRC check passed , 0xB2C0 Flashing done! Total flash time : 00:03:27 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 210 Software Info: V 04.12 21-05-13 RM-924 (c) Nokia IMEI: 358366054064384 PPM version : V 04.12 21-05-13 RM-924 (c) Nokia MA3 Product code: 059R774 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 58 certs Certificates found, skip upload ... Battery voltage is enough for start AfterFlash operations done ;D |
