04-10-2017, 08:20 | #41463 (permalink) |
No Life Poster Join Date: Aug 2015 Location: Bd+
Member: 2441719 Status: Offline Sonork: uninstall Thanks Meter: 2,073 | Kingstar KS A1Plus Hang on Logo Solve By Cm2 Kingstar KS A1Plus Hang on Logo Solve By Cm2 Code: Operation : Check/Read Info [ v1.24 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 8 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SPRD 773x eMMC loader v3 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : scx35_sp7731geaplus_dt Model Brand : Kingstar Model Device: scx35_sp7731gea AndrVersion : 4.4.2 BaseBand CPU: SP7731GEA CompileDate : 8/24/2015 7:17:58 AM Project Ver : Kingstar KS A1Plus_SW_V4.0_20150820 Model Ext : KS A1Plus ExtraInfo : HWInfo not exists, normal phone Elapsed: 00:00:19 Reconnect Power/Cable! Operation : Format File System / Reset Settings [ v1.24 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 8 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SPRD 773x eMMC loader v3 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x000000005DBFB000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Done! Elapsed: 00:00:27 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to iOS_Shakil For This Useful Post: |
04-10-2017, 08:22 | #41464 (permalink) |
Freak Poster Join Date: Aug 2016 Location: out of world
Member: 2609423 Status: Offline Sonork: 1660954:2007 Thanks Meter: 360 | lg h815 flashing done 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD VOLUME UP KEY! 3. Insert USB cable, wait until Download mode screen will appear Wait for phone... Connection opened successfully! Waiting for loader ... Handshake passed! Collect info... Prepare passed, mode 0x00 Boot done! Format UserData Format Cache Format done Erase FRP1 block Ok! Reconnect Power/Cable! Done! Elapsed: 00:00:18 Loading firmware ... FType : KDZ file Model : LG-H815 Version : LGH815AT-00-V20a-GLOBAL-COM-OCT-21-2015+0 SWInfo : 6.0 user BB_Gen : QLM File [0] : PrimaryGPT_0.bin File [1] : modem_32768.bin File [2] : pmic_229376.bin File [3] : sbl1_230400.bin File [4] : tz_232448.bin File [5] : sdi_234496.bin File [6] : hyp_235520.bin File [7] : rpm_236544.bin File [8] : aboot_237568.bin File [9] : sbl1bak_241664.bin File [10] : pmicbak_243712.bin File [11] : tzbak_244736.bin File [12] : hypbak_246784.bin File [13] : rpmbak_247808.bin File [14] : abootbak_248832.bin File [15] : sdibak_252928.bin File [16] : persist_294912.bin File [17] : sec_376832.bin File [18] : rct_379904.bin File [19] : laf_393216.bin File [20] : boot_491520.bin File [21] : recovery_573440.bin File [22] : factory_753664.bin File [23] : raw_resources_868352.bin File [24] : raw_resourcesbak_876544.bin File [25] : system_884736.bin File [26] : system_1149000.bin File [27] : system_1413056.bin File [28] : system_1673288.bin File [29] : system_1677320.bin File [30] : system_1937344.bin File [31] : system_2197576.bin File [32] : system_2201608.bin File [33] : system_2461632.bin File [34] : system_2721864.bin File [35] : system_2725896.bin File [36] : system_2985920.bin File [37] : system_3246152.bin File [38] : system_3250184.bin File [39] : system_3510208.bin File [40] : system_3772352.bin File [41] : system_4034496.bin File [42] : system_4296640.bin File [43] : system_4558784.bin File [44] : system_4820928.bin File [45] : system_5083072.bin File [46] : system_5345216.bin File [47] : system_5607360.bin File [48] : system_5869504.bin File [49] : system_6131648.bin File [50] : system_6393792.bin File [51] : system_6651904.bin File [52] : system_6914048.bin File [53] : system_7176192.bin File [54] : system_7438336.bin File [55] : system_7440456.bin File [56] : system_7444488.bin File [57] : system_7962624.bin File [58] : system_7964744.bin File [59] : system_7968776.bin File [60] : system_8486912.bin File [61] : system_8749056.bin File [62] : system_9011200.bin File [63] : system_9273344.bin File [64] : system_9276408.bin File [65] : cust_9363456.bin File [66] : cust_9625600.bin File [67] : BackupGPT_61070336.bin Load Ok! Operation : Flash [ v1.02 ] Forced Flash : Disabled Save UserContent : Disabled 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD VOLUME UP KEY! 3. Insert USB cable, wait until Download mode screen will appear Wait for phone... Connection opened successfully! Waiting for loader ... Handshake passed! Collect info... Prepare passed, mode 0x00 Boot done! [INFO] : Low Battery level ignored by user request! Loading firmware Load ok! Checking compatibility Checking passed! Prepare device Prepare Passed! Secure prepare skipped! Start flashing device Flash : PrimaryGPT_0.bin Flash : modem_32768.bin Flash : pmic_229376.bin Flash : sbl1_230400.bin Flash : tz_232448.bin Flash : sdi_234496.bin Flash : hyp_235520.bin Flash : rpm_236544.bin Flash : aboot_237568.bin Flash : sbl1bak_241664.bin Flash : pmicbak_243712.bin Flash : tzbak_244736.bin Flash : hypbak_246784.bin Flash : rpmbak_247808.bin Flash : abootbak_248832.bin Flash : sdibak_252928.bin Flash : persist_294912.bin Flash : sec_376832.bin Flash : rct_379904.bin Flash : laf_393216.bin Flash : boot_491520.bin Flash : recovery_573440.bin Flash : factory_753664.bin Flash : raw_resources_868352.bin Flash : raw_resourcesbak_876544.bin Flash : system_884736.bin Flash : system_1149000.bin Flash : system_1413056.bin Flash : system_1673288.bin Flash : system_1677320.bin Flash : system_1937344.bin Flash : system_2197576.bin Flash : system_2201608.bin Flash : system_2461632.bin Flash : system_2721864.bin Flash : system_2725896.bin Flash : system_2985920.bin Flash : system_3246152.bin Flash : system_3250184.bin Flash : system_3510208.bin Flash : system_3772352.bin Flash : system_4034496.bin Flash : system_4296640.bin Flash : system_4558784.bin Flash : system_4820928.bin Flash : system_5083072.bin Flash : system_5345216.bin Flash : system_5607360.bin Flash : system_5869504.bin Flash : system_6131648.bin Flash : system_6393792.bin Flash : system_6651904.bin Flash : system_6914048.bin Flash : system_7176192.bin Flash : system_7438336.bin Flash : system_7440456.bin Flash : system_7444488.bin Flash : system_7962624.bin Flash : system_7964744.bin Flash : system_7968776.bin Flash : system_8486912.bin Flash : system_8749056.bin Flash : system_9011200.bin Flash : system_9273344.bin Flash : system_9276408.bin Flash : cust_9363456.bin Flash : cust_9625600.bin Flash : BackupGPT_61070336.bin Processing Post-Flashing tune Flash done! Reconnect Power/Cable! Done! Elapsed: 00:04:48 |
The Following User Says Thank You to applebricks For This Useful Post: |
04-10-2017, 08:40 | #41466 (permalink) |
Member: 2441719 Status: Offline Sonork: uninstall Thanks Meter: 2,073 | ALCATEL_ONE_TOUCH_7047E Pattern lock Remove Done ALCATEL_ONE_TOUCH_7047E Pattern lock Remove Done Code: Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 16 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : FE014E50305858585810843E00971187 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0xFE , OEM : 014E [eMMC] : FLASH_INF : [MICRON] , XXXX0 [eMMC] : FLASH_CID : FE014E50305858585810843E00971187 [eMMC] : FLASH_BRT : 0x00100000 , 0x00100000 , 0x00100000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xDA9F1AB755E2CF8CFDFFA6D1CE0911A0 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : TCT ProdName : ALCATEL_ONE_TOUCH_7047E ProdModel : ALCATEL ONE TOUCH 7047E Device : YARIS_55 AndroidVer: 4.2.2 MTKxCPU : MT6582 MTKxPRJ : ALPS.JB5.MP.V1.1 Done! Elapsed: 00:00:39 Reconnect Power/Cable! Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 16 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : FE014E50305858585810843E00971187 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0xFE , OEM : 014E [eMMC] : FLASH_INF : [MICRON] , XXXX0 [eMMC] : FLASH_CID : FE014E50305858585810843E00971187 [eMMC] : FLASH_BRT : 0x00100000 , 0x00100000 , 0x00100000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xDA9F1AB755E2CF8CFDFFA6D1CE0911A0 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:35 Reconnect Power/Cable! |
The Following User Says Thank You to iOS_Shakil For This Useful Post: |
04-10-2017, 10:28 | #41467 (permalink) |
No Life Poster Join Date: Jun 2014 Location: Infinity Box Team
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | Qmobile Spd Format Done Code: Operation : Format File System / Reset Settings [ v1.24 ] Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 26 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00C8 0060 0016 0000 [0] Flash VEN : GigaDevice , GD25LQ32 [0] Flash CAP : 00400000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Done! Elapsed: 00:00:29 Reconnect Power/Cable! |
The Following User Says Thank You to Luckey1 For This Useful Post: |
04-10-2017, 10:39 | #41468 (permalink) |
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | Fix Unknown BaseBand : Samsung j100H Code: Operation : Write NVRAM [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 12 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8B00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 1501004E4A5330304D00B24D79FF70D9 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , M00SJ [eMMC] : FLASH_CID : 1501004E4A5330304D00B24D79FF70D9 [eMMC] : FLASH_BRT : 0x00100000 , 0x00100000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xE6C52A7DED2BB9C61FF609EA90BE9F0F INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [NV] : Data in Binary Format [NVM] : Write Ok! [Info] : NVRAM Repair on erased/damaged phone : 1. Fix Unknown BaseBand 2. Power On phone, check BB state 3. Write NVRAM 4. Repair Security Done! Elapsed: 00:00:18 Reconnect Power/Cable! |
04-10-2017, 10:40 | #41469 (permalink) |
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | Samsung clone j500h format done Code: Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 12 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8B00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 1501004E4A5330304D00B24D79FF70D9 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , M00SJ [eMMC] : FLASH_CID : 1501004E4A5330304D00B24D79FF70D9 [eMMC] : FLASH_BRT : 0x00100000 , 0x00100000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xE6C52A7DED2BB9C61FF609EA90BE9F0F INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:29 Reconnect Power/Cable! |
04-10-2017, 10:41 | #41470 (permalink) |
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | samsung clone j7 security repair Code: Operation : Repair Security [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 12 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8B00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 1501004E4A5330304D00B24D79FF70D9 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , M00SJ [eMMC] : FLASH_CID : 1501004E4A5330304D00B24D79FF70D9 [eMMC] : FLASH_BRT : 0x00100000 , 0x00100000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xE6C52A7DED2BB9C61FF609EA90BE9F0F INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! IMEI [00] : 353881007974328 IMEI [01] : 353881007974328 IMEI [02] : 353881007974328 IMEI [03] : 353881007974328 Set IMEI [00] : 355236030348511 Set IMEI [01] : 355236030348529 Prepare finished. Security check required! Wait for phone... Phone found! [ 12 ] Sync... Repair done! Done! Elapsed: 00:00:47 Reconnect Power/Cable! |
04-10-2017, 11:38 | #41471 (permalink) |
No Life Poster Join Date: May 2008 Location: pakistan pir mahal Age: 53
Member: 779470 Status: Offline Sonork: Waseem mobile Thanks Meter: 101 | alcatel 4013x unlock done with CM2 Operation : SP Unlock [ v1.58 ] Mode : Direct Unlock 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 64 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 150100464A3235414202B05EE50013BF Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BA52J [eMMC] : FLASH_CID : 150100464A3235414202B05EE50013BF [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0x3ACE69A5F9A1BB7AD1363CF3C875CBD5 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SIM Lock Status : Locked! Unlocking now ... Unlock done! Done! Elapsed: 00:00:31 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to waseem pirmahal For This Useful Post: |
04-10-2017, 12:31 | #41472 (permalink) |
No Life Poster Join Date: May 2013 Location: Far From Home..:(
Member: 1948608 Status: Offline Thanks Meter: 1,744 | lenovo A2010-a read pattern Easy CM-2 Code: Brand : Lenovo ProdName : A2010-a ProdModel : Lenovo A2010-a Device : A2010-a AndroidVer: 5.1 MTKxCPU : MT6735M MTKxPRJ : A2010-a-t_USR_S255_1510220930_MP3V1_8G_ROW Operation : Read Pattern/DP Lock [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 460001154D3232370A8300424DBCF2D6 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM227 [eMMC] : FLASH_CID : 150100463732324D4200830AD6F2A24D [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xA8D8407EF125D4B3C0C4C8D80998AD23 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading data ... Get Locks ... PatternLock Sequnce : 25874 Done! Elapsed: 00:00:24 |
04-10-2017, 12:56 | #41473 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Chandpur U.P.West India
Member: 472592 Status: Offline Sonork: 100.1664052 Thanks Meter: 180 | Panasonic p71 format n read flash success Card found : S/N : D3889E80 , v0134 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 125 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 460001154D32323836D30042930106E4 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM228 [eMMC] : FLASH_CID : 150100463832324D4200D336E4069393 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xABDEAA9279CF296B9F0FE79CA82C626A INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Done! Elapsed: 00:00:13 Reconnect Power/Cable! Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 125 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 460001154D32323836D30042930106E4 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM228 [eMMC] : FLASH_CID : 150100463832324D4200D336E4069393 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xABDEAA9279CF296B9F0FE79CA82C626A INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... xGPT : Normalize settings Ok! Brand : Panasonic ProdName : P71 ProdModel : P71 Device : P71 AndroidVer: 6.0 MTKxCPU : MT6737M MTKxPRJ : EB-90S50P71v1008 [Read Ok] : preloader_konka_6737_r5_65_m0.bin [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : logo.bin [Read Ok] : secro.img [Read Ok] : tz1.img [Read Ok] : tz2.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6737M / V1.1.2 / konka_6737_r5_65_m0 / EMMC Android Info saved MAUI Meta DB saved HWConfig Info saved FW Size : 3744 MiB Scatter saved to : E:\Flash files\readed\MT6737M__Panasonic__P71__P71__6.0__EB-90S50P71v1008\ All done! |
04-10-2017, 12:58 | #41474 (permalink) |
Member: 472592 Status: Offline Sonork: 100.1664052 Thanks Meter: 180 | Micromax q413 format and read flash successful 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 125 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 510001154D33323836F000420D0413EC Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM328 [eMMC] : FLASH_CID : 150100513832334D4200F036EC13B20D [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xABDEAA923A0EC355A06DB76849F8C974 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Done! Elapsed: 00:00:33 Reconnect Power/Cable! Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 125 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 510001154D33323836F000420D0413EC Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM328 [eMMC] : FLASH_CID : 150100513832334D4200F036EC13B20D [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xABDEAA923A0EC355A06DB76849F8C974 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... xGPT : Normalize settings Ok! Brand : Micromax ProdName : full_p7511 ProdModel : Micromax Q413 Device : p7511 AndroidVer: 5.1 MTKxCPU : MT6735 MTKxPRJ : ALPS.L1.MP3.V2.21_TOP6735M.35GC.L1_P24 [Read Ok] : preloader_p7511.bin [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : logo.bin [Read Ok] : secro.img [Read Ok] : tz1.img [Read Ok] : tz2.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6735M / V1.1.2 / p7511 / EMMC Android Info saved MAUI Meta DB saved HWConfig Info saved FW Size : 2132 MiB Scatter saved to : E:\Flash files\readed\MT6735__Micromax__Micromax_Q413__p751 1__5.1__ALPS.L1.MP3.V2.21_TOP6735M.35GC.L1_P24\ All done! Done! Elapsed: 00:05:00 Reconnect Power/Cable! |
04-10-2017, 12:59 | #41475 (permalink) |
Member: 472592 Status: Offline Sonork: 100.1664052 Thanks Meter: 180 | Micromax q414 format and read flash successful Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 125 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 484A019065314738C005070583165868 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e1G8 [eMMC] : FLASH_CID : 90014A4838473165050705C068589283 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xABDEAA92EDD70A38F74D29BD4694B8A7 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... xGPT : Normalize settings Ok! Brand : Micromax ProdName : Q414 ProdModel : Micromax Q414 Device : Q414 AndroidVer: 5.1 MTKxCPU : MT6735 MTKxPRJ : ALPS.L1.MP3.V1_BIRD6735M.35GU.A.L [Read Ok] : preloader_bird6735m_35gu_a_l.bin [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : logo.bin [Read Ok] : secro.img [Read Ok] : tz1.img [Read Ok] : tz2.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6735M / V1.1.2 / bird6735m_35gu_a_l / EMMC Android Info saved MAUI Meta DB saved HWConfig Info saved FW Size : 1935 MiB Scatter saved to : E:\Flash files\readed\MT6735__Micromax__Micromax_Q414__Q414 __5.1__ALPS.L1.MP3.V1_BIRD6735M.35GU.A.L\ All done! Done! Elapsed: 00:05:53 Reconnect Power/Cable! |
