08-15-2018, 15:46 | #52306 (permalink) |
Freak Poster Join Date: Feb 2014
Member: 2125922 Status: Offline Sonork: 1601402 Thanks Meter: 112 | qmobile z12 pro flash done with cm2 mtk Code: Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 14 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 520001154D423158AB0207428F279FD4 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMB1X [eMMC] : FLASH_CID : 150100525831424D420702ABD49F738F [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000747C00000 [eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB] DEV RID : 0xA951A0A918FACA9BC46CB7B1E6B32762 INT RAM : 0x00020000 EXT RAM : 0xC0000000 [3 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6753 , Project : gionee6753_65u_m0 , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Skip checking by User request! BL : BatteryLevel : 3556 mV BL : [WARNING] : BatteryLevel LOW!!! BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000001C80000-0x0000000004D80000 Erase : 0x0000000006B00000-0x0000000740080000 Flash Pre-Erase Done, time used : 00:00:01 SecCfg Passed , 1799 BMT remark not need. Will skip Preloader Download skipped by user request! PartCount : 0016 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : LK Image Flash Ok Flash now : BOOT Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : SECRO Image Flash Ok Flash now : TEE1 Image Flash Ok Flash now : TEE2 Image Flash Ok Flash now : SYSTEM Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USERDATA Image Flash Ok Flash Write Done, time used : 00:06:47 Processing : Verify Verify Passed : LK Verify Passed : BOOT Verify Passed : RECOVERY Verify Passed : LOGO Verify Passed : SECRO Verify Passed : TEE1 Verify Passed : TEE2 Verify Passed : SYSTEM Verify Passed : CACHE Verify Passed : USERDATA Data Verify Done, time used : 00:00:23 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:07:28 Reconnect Power/Cable! |
08-15-2018, 15:46 | #52307 (permalink) |
Product Supporter Join Date: Mar 2016 Location: Bangladesh
Member: 2548908 Status: Offline Sonork: 100.1672479 Thanks Meter: 761 | We A3 SPD 7731 Firmware Read Done By CM2 [Read Mode] : HSUSB : 0x3000 [FW_READER] : Reading Firmware Now ... [Read Ok] : u-boot-spl-16k.bin [Read Ok] : u-boot.bin [Read Ok] : prodnv.img [Read Ok] : sc7731C_CP0_modem.bin [Read Ok] : DSP_DM_Gx.bin [Read Ok] : nvitem_w.bin [Read Ok] : sc8830g_modem_CP2_WCN_Trunk_W17.27.4_Release.bin [Read Ok] : nvitem_wcn.bin [Read Ok] : logo_480x854.bin [Read Ok] : fblogo_480x854.bin [Read Ok] : logo3.bin [Read Ok] : logo4.bin [Read Ok] : logo5.bin [Read Ok] : boot.img [Read Ok] : system.img [Build Ok] : cache.img [Read Ok] : recovery.img [Read Ok] : sysinfo.img [Build Ok] : userdata.img AndroidInfo created Firmware Size : 1580 MiB Saved to : D:\SP7731C_1H10_32V4_DF_DF019_C_WE_A3_GPS_sp7731c_ 1h10_32v4_df_df019_c_we_a3_gps_6.0_MRA58K_release-keys_WE_A3\ Done! Elapsed: 00:08:03 |
08-15-2018, 15:46 | #52308 (permalink) |
Member: 2125922 Status: Offline Sonork: 1601402 Thanks Meter: 112 | lenovo a328 formate done with cm2 mtk Code: Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164040503A2F96C2263 Initialize Memory ... DRAM configured from IDB! DRAM initialize passed! DRAM size : 0x40000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164040503A2F96C2263 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xA951A0A907804531647F605CB0C8148C INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:32 Reconnect Power/Cable! |
08-15-2018, 15:47 | #52309 (permalink) |
Member: 2125922 Status: Offline Sonork: 1601402 Thanks Meter: 112 | infinik x559c frp rest done with cm2 mtk Code: Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164040503A2F96C2263 Initialize Memory ... DRAM configured from IDB! DRAM initialize passed! DRAM size : 0x40000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164040503A2F96C2263 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xA951A0A907804531647F605CB0C8148C INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:32 Reconnect Power/Cable! |
08-15-2018, 15:48 | #52310 (permalink) |
Member: 2548908 Status: Offline Sonork: 100.1672479 Thanks Meter: 761 | WE L3 Firmware Read Done By CM2 Brand : WE ProdName : WE L3 ProdModel : WE L3 Device : t223_s45_wh_wel3 AndroidVer: 6.0 MTKxCPU : MT6580 MTKxPRJ : alps-mp-m0.mp1-V2.39_along6580.we.m_P7 [Read Ok] : preloader_t223_s45_wh_wel3.bin [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : logo.bin [Read Ok] : secro.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6580 / V1.1.2 / t223_s45_wh_wel3 / EMMC Android Info saved MAUI Meta DB saved HWConfig Info saved FW Size : 1628 MiB Scatter saved to : C:\Users\acer\Desktop\WE L3\MT6580__WE__WE_L3__t223_s45_wh_wel3__6.0__alps-mp-m0.mp1-V2.39_along6580.we.m_P7\ All done! |
08-15-2018, 15:50 | #52311 (permalink) |
Member: 2548908 Status: Offline Sonork: 100.1672479 Thanks Meter: 761 | Smile Z9 6572 Nand Firmware Read Done By CM2 Boot Ok! Reading Flash Content now ... [Read Ok] : preloader_yuanda72_cwet_lca.bin [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : usrdata.img [ScatCFG] : MT6572 / V1.1.1 / yuanda72_cwet_lca / NAND FW Size : 245 MiB Brand : SMILE ProdName : Z9 ProdModel : Z9 Device : SMILE AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.KK1.MP7.V1 Android Info saved Scatter saved to : H:\primo\MT6572_NAND_SMILE__Z9__SMILE__4.4.2__ALPS .KK1.MP7.V1 Done! |
08-15-2018, 15:53 | #52312 (permalink) |
Member: 2548908 Status: Offline Sonork: 100.1672479 Thanks Meter: 761 | Smile Z7 6572 Nand Firmware Read Done By CM2 [Read Ok] : preloader_yuanda72_cwet_lca.bin [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : usrdata.img [ScatCFG] : MT6572 / V1.1.1 / yuanda72_cwet_lca / NAND FW Size : 243 MiB Brand : SMILE ProdName : Z7 ProdModel : Z7 Device : SMILE AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.KK1.MP7.V1 Android Info saved Scatter saved to : C:\Users\hasina telecom\Desktop\CM2\MT6572_NAND_SMILE__Z7__SMILE__ 4.4.2__ALPS.KK1.MP7.V1 Done! |
08-15-2018, 15:55 | #52313 (permalink) |
Member: 2548908 Status: Offline Sonork: 100.1672479 Thanks Meter: 761 | Smile Z3 MTK 6580 5.1 Firmware Read Done By CM2 Brand : SMILE ProdName : Z3 ProdModel : Z3 Device : Z3 AndroidVer: 5.1 MTKxCPU : MT6580 MTKxPRJ : ALPS.L1.MP6.V2_YUANDA6580.WEG.L_P2 [Read Ok] : preloader_yuanda6580_weg_l.bin [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : logo.bin [Read Ok] : secro.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6580 / V1.1.2 / yuanda6580_weg_l / EMMC Android Info saved MAUI Meta DB saved HWConfig Info saved FW Size : 1318 MiB Scatter saved to : \Users\ alhamdulillah telecom\Desktop MT6580__SMILE__Z3__Z3__5.1__ALPS.L1.MP6.V2_YUANDA6 580.WEG.L_P2\ All done! |
08-15-2018, 15:57 | #52314 (permalink) |
Member: 2548908 Status: Offline Sonork: 100.1672479 Thanks Meter: 761 | Zelta Q70 SPD7731 6.0 Firmware Read Done By CM2 Boot Ok! Model Name : sp7731ceb_dt_oversea Model Brand : Zelta Model Device: scx20_sp7731ceb AndrVersion : 5.1 BaseBand CPU: SP7731CEB Project Ver : Q70_2_XXX_1.0_1.0_01072016 Model Ext : Q70 [Read Mode] : HSUSB : 0x3000 [FW_READER] : Reading Firmware Now ... [Read Ok] : u-boot-spl-16k.bin [Read Ok] : u-boot.bin [Read Ok] : prodnv.img [Read Ok] : sc7731C_CP0_modem.bin [Read Ok] : DSP_DM_Gx.bin [Read Ok] : nvitem_w.bin [Read Ok] : sc8830g_modem_CP2_Trunk_W15.49.3_Release.bin [Read Ok] : nvitem_wcn.bin [Read Ok] : logo_480x854.bin [Read Ok] : fblogo_480x854.bin [Read Ok] : boot.img [Read Ok] : system.img [Read Ok] : oem.img [Read Ok] : sysinfo.img [Build Ok] : cache.img [Read Ok] : recovery.img [Build Ok] : userdata.img AndroidInfo created Firmware Size : 1743 MiB Saved to : I:\Backup\New folder (2)\SP7731CEB_scx20_sp7731ceb_5.1_Q70_2_XXX_1.0_1. 0_01072016_Q70\ Done! |
08-15-2018, 15:58 | #52315 (permalink) |
Member: 2548908 Status: Offline Sonork: 100.1672479 Thanks Meter: 761 | G Five M3 Firmware Read Done By CM2 Reading Flash Content now ... Brand : GFIVE ProdName : GFIVE M3 ProdModel : GFIVE_M3 Device : M3 AndroidVer: 4.2.2 MTKxCPU : MT6582 MTKxPRJ : ALPS.JB5.MP.V1.27 [Read Ok] : preloader_t830_jb5.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : EBR2 [Read Ok] : system.img [Make Ok] : cache.img [Make Ok] : userdata.img [ScatCFG] : MT6582 / V1.1.1 / t830_jb5 / EMMC Android Info saved MAUI Meta DB saved HWConfig Info saved FW Size : 674 MiB Scatter saved to : MT6582_GFIVE_GFIVE_M3_M3_4.2.2_ALPS.JB5.MP.V1.27 All done! |
08-15-2018, 15:59 | #52316 (permalink) |
Member: 2548908 Status: Offline Sonork: 100.1672479 Thanks Meter: 761 | GFIVE EA70 Mtk6571 Firmware Read Done By CM2 ProdName : G-five EA70 ProdModel : G-five EA70 Device : G-five EA70 AndroidVer: 4.4.2 MTKxCPU : MT6571 MTKxPRJ : ALPS.KK1.MP7.V1.7 [Image Ok] : preloader_leatek71_cwet_kk.bin [Image Ok] : DSP_BL [Image Ok] : MBR [Image Ok] : EBR1 [Image Ok] : lk.bin [Image Ok] : boot.img [Image Ok] : recovery.img [Image Ok] : secro.img [Image Ok] : logo.bin [Image Ok] : EBR2 [Image Ok] : system.img [Image Ok] : cache.img [Image Ok] : userdata.img [ScatCFG] : MT6571 / V1.0.0 / leatek71_cwet_kk / EMMC FW Size : 709 MB |
08-15-2018, 16:01 | #52317 (permalink) |
Member: 2548908 Status: Offline Sonork: 100.1672479 Thanks Meter: 761 | Kingstar i15 SPD 7731 Pac Firmware Read Done By CM2 Boot Ok! Model Name : KINGSTAR i15 Model Brand : SPRD Model Device: scx20_c7359_fwvga_lm AndrVersion : 5.1 BaseBand CPU: C7359_FWVGA_LM Project Ver : KINGSTAR_i15_user_V08A_20160922 Model Ext : KINGSTAR i15 [Read Mode] : HSUSB : 0x3000 [FW_READER] : Reading Firmware Now ... [Read Ok] : u-boot-spl-16k.bin [Read Ok] : u-boot.bin [Read Ok] : prodnv.img [Read Ok] : sc7731C_CP0_modem.bin [Read Ok] : DSP_DM_Gx.bin [Read Ok] : nvitem_w.bin [Read Ok] : sc8830g_modem_CP2_WCN_Trunk_W16.28.5_Release.bin [Read Ok] : nvitem_wcn.bin [Read Ok] : logo_480x854.bin [Read Ok] : fblogo_480x854.bin [Read Ok] : boot.img [Read Ok] : system.img [Read Ok] : oem.img [Read Ok] : sysinfo.img [Build Ok] : cache.img [Read Ok] : recovery.img [Build Ok] : userdata.img AndroidInfo created Firmware Size : 1881 MiB Saved to : I:\Backup\New folder (4)\C7359_FWVGA_LM_scx20_c7359_fwvga_lm_5.1_KINGST AR_i15_user_V08A_20160922_KINGSTAR_i15\ Done! |
08-15-2018, 16:03 | #52318 (permalink) |
Member: 2548908 Status: Offline Sonork: 100.1672479 Thanks Meter: 761 | ALCATEL ONETOUCH T5045T PIXI4 Firmware Read Done By CM2 Boot Ok! Reading Flash Content now ... xGPT : Normalize settings Ok! Brand : TCL ProdName : 5045T ProdModel : 5045T Device : PIXI4_5_4G AndroidVer: 6.0 MTKxCPU : MT6735 MTKxPRJ : alps-mp-m0.mp1-V2.39.1_jhz6735m.35u.m_P114 [Read Ok] : preloader_jhz6735m_35u_m.bin [Read Ok] : simlock.img [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : logo.bin [Read Ok] : secro.img [Read Ok] : tz1.img [Read Ok] : tz2.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6737M / V1.1.2 / jhz6735m_35u_m / EMMC Android Info saved MAUI Meta DB saved HWConfig Info saved FW Size : 2095 MiB Scatter saved to : J:\skype-Roni2000 Whatsapp+8801911954639\New folder\MT6735__TCL__5045T__PIXI4_5_4G__6.0__alps-mp-m0.mp1-V2.39.1_jhz6735m.35u.m_P114\ All done! |
08-15-2018, 16:07 | #52319 (permalink) |
Member: 2548908 Status: Offline Sonork: 100.1672479 Thanks Meter: 761 | BY2 N360 MTK6572 Firmware Read Done By CM2 Reading Flash Content now ... Brand : BY2 ProdName : N360 ProdModel : N360 Device : BY2 AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.KK1.MP7.V1 [Read Ok] : preloader_yuanda72_cwet_kk.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6572 / V1.1.1 / yuanda72_cwet_kk / EMMC Android Info saved MAUI Meta DB saved HWConfig Info saved FW Size : 661 MiB Scatter saved to : I:\Backup\New folder (4)\MT6572__BY2__N360__BY2__4.4.2__ALPS.KK1.MP7.V1 \ All done! |
08-15-2018, 16:08 | #52320 (permalink) |
Member: 2548908 Status: Offline Sonork: 100.1672479 Thanks Meter: 761 | V75 HW2_V20 Pac Symphony SPD7731 Firmware Read Done By CM2 Boot Ok! Model Name : V75 Model Brand : Symphony Model Device: V75 AndrVersion : 6.0 BaseBand CPU: V75 Project Ver : MRA58K release-keys Model Ext : V75 [Read Mode] : HSUSB : 0x3000 [FW_READER] : Reading Firmware Now ... [Read Ok] : u-boot-spl-16k.bin [Read Ok] : u-boot.bin [Read Ok] : prodnv.img [Read Ok] : sc7731C_CP0_modem.bin [Read Ok] : DSP_DM_Gx.bin [Read Ok] : nvitem_w.bin [Read Ok] : sc8830g_modem_CP2_WCN_Trunk_W16.28.5_Release.bin [Read Ok] : nvitem_wcn.bin [Read Ok] : logo_480x854.bin [Read Ok] : fblogo_480x854.bin [Read Ok] : boot.img [Read Ok] : system.img [Read Ok] : sysinfo.img [Build Ok] : cache.img [Read Ok] : recovery.img [Build Ok] : userdata.img AndroidInfo created Firmware Size : 2087 MiB Saved to : J:\New folder\New folder (17)\V75_V75_6.0_MRA58K_release-keys_V75\ Done! |
