Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | -= Z3X JTAG PLUS =- | Search | Today's Posts | Mark Forums Read |
![]() | #66391 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2009 Location: SINDH PAKISTAN
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,185 | Lg-H900 Format Done With King Cm2 2. PRESS and HOLD VOLUME UP KEY! 3. Insert USB cable, wait until Download mode screen will appear Wait for phone... Connection opened successfully! Waiting for loader ... Handshake passed! Collect info... Prepare passed, mode 0x01 Boot done! Format UserData Format Cache Format done Erase sFRP#1 Ok! Reconnect Power/Cable! Done! Elapsed: 00:00:39 |
![]() | #66392 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,517 | Jazz digit g4 remove pattern pin frp one click Card found : 73CA70CC , v0147 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.21 Load IDBase v210169 Ok! Update configuration ... Update Ok! Load IDBase v210169 Ok! Operation : Identify [ v2.21 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM17) MODE : PRELOADER PORT PORT : 17 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! BROM : Enforcing EmergencyBROM BROM : Enforcing passed! PTFN : MediaTek USB Port (COM11) MODE : BOOTROM PORT : 11 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 CODE : Zion TYPE : MODERN RAPHAEL BROM : MEID : 78580C3B673078F0B16236DF06BC69C3 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : 1A530B539423DF470E2321E508089CEBAFE73C8F94F62F334E F224496A860DDF BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0002 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x20000000 [ 512.00 MB ] EMMC: 150100464A32354142027D829AE4C283 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : FJ25AB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00080000 [ 512.00 KB ] USER : 0xE9000000 [ 3.64 GB ] CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 , EVOL : 0x0000 RNID : BFDFB2AD633B73F0CED25A44C7E54AF5 DA : USB : HIGH-SPEED Boot done! Patch Level : KOT49H Display ID : Digit_M42421DG_EF2_SW04_20210203_1019 Ver. CodeName : REL Ver. Release : 4.4.2 Build Time : 03.02.2021 Product Model : Digit4G Product Brand : Digit Product Name : Digit4G Product Device : Digit4G Product Manfct : alps Board Platform : mt6739 Product Info : Digit4G USERDATA : FILESYSTEM : EXT4 with FDE ( Full Disk Encryption ***) NVRAM check : Passed! NVRAM : SEC NORMAL [ No extra security ] Backup sensetive data [ 15 ] Backup path : Backup\MT6739__BFDFB2AD633B73F0CED25A44C7E54AF5\ Backup done! STORAGE : LifeStatus : eMMC : OK! Done! Elapsed: 00:00:32 Operation : Reset Settings/Format FS [ v2.21 ] Mode : FULL FACTORY ( WIPE + FRP ) 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM17) MODE : PRELOADER PORT PORT : 17 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! BROM : Enforcing EmergencyBROM BROM : Enforcing passed! PTFN : MediaTek USB Port (COM11) MODE : BOOTROM PORT : 11 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 CODE : Zion TYPE : MODERN RAPHAEL BROM : MEID : 78580C3B673078F0B16236DF06BC69C3 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : 1A530B539423DF470E2321E508089CEBAFE73C8F94F62F334E F224496A860DDF BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0002 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x20000000 [ 512.00 MB ] EMMC: 150100464A32354142027D829AE4C283 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : FJ25AB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00080000 [ 512.00 KB ] USER : 0xE9000000 [ 3.64 GB ] CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 , EVOL : 0x0000 RNID : BFDFB2AD633B73F0CED25A44C7E54AF5 DA : USB : HIGH-SPEED Boot done! ERR : 0xC002002A ERR : SEC : IMG TYPE MISMATCH ERR : 0x00001000|0x00001000 Error : Failed erase block! >>> Try select another format mode! Reconnect Power/Cable! Operation : Reset Settings/Format FS [ v2.21 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM17) MODE : PRELOADER PORT PORT : 17 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! BROM : Enforcing EmergencyBROM BROM : Enforcing passed! PTFN : MediaTek USB Port (COM11) MODE : BOOTROM PORT : 11 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 CODE : Zion TYPE : MODERN RAPHAEL BROM : MEID : 78580C3B673078F0B16236DF06BC69C3 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : 1A530B539423DF470E2321E508089CEBAFE73C8F94F62F334E F224496A860DDF BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0002 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x20000000 [ 512.00 MB ] EMMC: 150100464A32354142027D829AE4C283 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : FJ25AB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00080000 [ 512.00 KB ] USER : 0xE9000000 [ 3.64 GB ] CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 , EVOL : 0x0000 RNID : BFDFB2AD633B73F0CED25A44C7E54AF5 DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x8C5454 Format Ok : USERDATA Format Ok : CACHE Format Ok : RESET PROTECTION Format Ok : USERDATA Done! Elapsed: 00:00:34 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to A.G.Shahid For This Useful Post: |
![]() | #66393 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,517 | Jazz digit g4 read factory firmware done by cm2 Card found : 73CA70CC , v0147 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.21 Load IDBase v210169 Ok! Update configuration ... Update Ok! Load IDBase v210169 Ok! Operation : Identify [ v2.21 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM17) MODE : PRELOADER PORT PORT : 17 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! BROM : Enforcing EmergencyBROM BROM : Enforcing passed! PTFN : MediaTek USB Port (COM11) MODE : BOOTROM PORT : 11 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 CODE : Zion TYPE : MODERN RAPHAEL BROM : MEID : 78580C3B673078F0B16236DF06BC69C3 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : 1A530B539423DF470E2321E508089CEBAFE73C8F94F62F334E F224496A860DDF BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0002 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x20000000 [ 512.00 MB ] EMMC: 150100464A32354142027D829AE4C283 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : FJ25AB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00080000 [ 512.00 KB ] USER : 0xE9000000 [ 3.64 GB ] CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 , EVOL : 0x0000 RNID : BFDFB2AD633B73F0CED25A44C7E54AF5 DA : USB : HIGH-SPEED Boot done! Patch Level : KOT49H Display ID : Digit_M42421DG_EF2_SW04_20210203_1019 Ver. CodeName : REL Ver. Release : 4.4.2 Build Time : 03.02.2021 Product Model : Digit4G Product Brand : Digit Product Name : Digit4G Product Device : Digit4G Product Manfct : alps Board Platform : mt6739 Product Info : Digit4G USERDATA : FILESYSTEM : EXT4 with FDE ( Full Disk Encryption ***) NVRAM check : Passed! NVRAM : SEC NORMAL [ No extra security ] Backup sensetive data [ 15 ] Backup path : Backup\MT6739__BFDFB2AD633B73F0CED25A44C7E54AF5\ [21] Read : NVRAM [8] Read : NVDATA [14] Read : PROINFO [22] Read : LK [7] Read : NVCFG [10] Read : PROTECT1 [11] Read : PROTECT2 [0] Read : PRELOADER [12] Read : SECCFG Backup done! STORAGE : LifeStatus : eMMC : OK! Done! Elapsed: 00:00:32 Operation : Read Firmware [ v2.21 ] ExtSparse : Enabled ForceRead : Enabled 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM17) MODE : PRELOADER PORT PORT : 17 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! BROM : Enforcing EmergencyBROM BROM : Enforcing passed! PTFN : MediaTek USB Port (COM11) MODE : BOOTROM PORT : 11 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 CODE : Zion TYPE : MODERN RAPHAEL BROM : MEID : 78580C3B673078F0B16236DF06BC69C3 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : 1A530B539423DF470E2321E508089CEBAFE73C8F94F62F334E F224496A860DDF BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0002 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x20000000 [ 512.00 MB ] EMMC: 150100464A32354142027D829AE4C283 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : FJ25AB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00080000 [ 512.00 KB ] USER : 0xE9000000 [ 3.64 GB ] CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 , EVOL : 0x0000 RNID : BFDFB2AD633B73F0CED25A44C7E54AF5 DA : USB : HIGH-SPEED Boot done! Patch Level : KOT49H Display ID : Digit_M42421DG_EF2_SW04_20210203_1019 Ver. CodeName : REL Ver. Release : 4.4.2 Build Time : 03.02.2021 Product Model : Digit4G Product Brand : Digit Product Name : Digit4G Product Device : Digit4G Product Manfct : alps Board Platform : mt6739 Product Info : Digit4G MT6739__alps__Digit4G__4.4.2__Digit_M42421DG_EF2_S W04_20210203_1019__KOT49H__Digit4G Read : preloader.bin Read : recovery.img Read : proinfo.img Read : md1rom.img Read : md1dsp.img Read : spmfw.img Read : mcupmfw.img Read : nvram.bin Read : lk.bin Read : loader_ext.img Read : boot.img Read : logo.bin Read : tz.img Read : system.img ExtSparse : Compression ratio : 60% Read : cache.img Read : userdata.img FW Size : 479.24 MB Android Info saved : _Android_info.txt Scatter : MT6739_Android_scatter.txt Saved to : C:\InfinityBox\CM2MT2\Backup\MT6739__alps__Digit4G __4.4.2__Digit_M42421DG_EF2_SW04_20210203_1019__KO T49H__Digit4G\ Done! Elapsed: 00:01:43 |
![]() | #66394 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,517 | Qtab v100 read factory firmware done by cm2 Card found : 73CA70CC , v0147 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.21 Load IDBase v210169 Ok! Update configuration ... Update Ok! Load IDBase v210169 Ok! Operation : Identify [ v2.21 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM17) MODE : PRELOADER PORT PORT : 17 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BROM|BL : 0xFF|0x01 BROM : PRELOADER PORT MODE : 0_base : BASE_v2044 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 4E0301886472614371EA4320B9C36009 DAInf: 4 : 2 : 156 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 8801034E436172642043EA71960C3B9 EMMC: VEN : FORESEE | OEM : 301 | DEV : NCard EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x39D000000 [ 14.45 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : B58874B7F1565C88FAB6145A4259ED3A STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Patch Level : MRA58K Display ID : QTab_V100_MP_13_09_V06 Ver. CodeName : REL Ver. Release : 6.0 Sec. Patch : 2016-10-05 Build Time : 19.05.2017 Product Model : V100 Product Brand : QTab Product Name : QTab_V100 Product Device : QTab_V100 Product Board : V100 Product Manfct : QTab Board Platform : mt6580 Product Info : qmobile8321_7006 USERDATA : FILESYSTEM : EXT4 with FDE ( Full Disk Encryption *) IMEI[0] : 353581080263850 IMEI[1] : 353581085263855 IMEI[2] : 37562767963656F NVRAM check : Passed! NVRAM : SEC NORMAL [ No extra security ] Backup sensetive data [ 15 ] Backup path : Backup\MT6580__B58874B7F1565C88FAB6145A4259ED3A\ Backup done! Done! Elapsed: 00:00:33 Operation : Read Firmware [ v2.21 ] ExtSparse : Enabled ForceRead : Enabled 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM17) MODE : PRELOADER PORT PORT : 17 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BROM|BL : 0xFF|0x01 BROM : PRELOADER PORT MODE : 0_base : BASE_v2044 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 4E0301886472614371EA4320B9C36009 DAInf: 4 : 2 : 156 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 8801034E436172642043EA71960C3B9 EMMC: VEN : FORESEE | OEM : 301 | DEV : NCard EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x39D000000 [ 14.45 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : B58874B7F1565C88FAB6145A4259ED3A STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Patch Level : MRA58K Display ID : QTab_V100_MP_13_09_V06 Ver. CodeName : REL Ver. Release : 6.0 Sec. Patch : 2016-10-05 Build Time : 19.05.2017 Product Model : V100 Product Brand : QTab Product Name : QTab_V100 Product Device : QTab_V100 Product Board : V100 Product Manfct : QTab Board Platform : mt6580 Product Info : qmobile8321_7006 MT6580__QTab__V100__6.0__QTab_V100_MP_13_09_V06__M RA58K__qmobile8321_7006 Read : preloader.bin Read : proinfo.img Read : nvram.bin Read : lk.bin Read : boot.img Read : recovery.img Read : logo.bin Read : secro.img Read : system.img ExtSparse : Compression ratio : 15% Read : cache.img Read : userdata.img FW Size : 2.62 GB Android Info saved : _Android_info.txt Scatter : MT6580_Android_scatter.txt Saved to : C:\InfinityBox\CM2MT2\Backup\MT6580__QTab__V100__6 .0__QTab_V100_MP_13_09_V06__MRA58K__qmobile8321_70 06\ Done! Elapsed: 00:12:38 |
![]() | #66395 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,517 | Vivo y12s v2026 read factory file done by cm2 Card found : 73CA70CC , v0147 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.21 Load IDBase v210169 Ok! Update configuration ... Update Ok! Load IDBase v210169 Ok! Operation : Identify [ v2.21 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM11) MODE : BOOTROM PORT : 11 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : 045DD03B566AFDA12301BF74A9E6325C BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : 306C49527BDE7211F0F4E777C1DA09E9D25E0C05052B96AC3E 92CAF3AB661440 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0001 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: 150100445836384D4209D91EDCFA6783 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : DX68MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : E241B5F23C3BF5B821D97CA4353A4792 DA : USB : HIGH-SPEED Boot done! Product Brand : vivo Product Device : k65v1_64_bsp Product Model : vivo 2026 Product Name : full_k65v1_64_bsp Patch Level : QP1A.190711.020 Display ID : QP1A.190711.020 release-keys Ver. CodeName : REL Ver. Release : 10 Sec. Patch : 2021-01-01 Build Time : 04.02.2021 Product Info : k65v1_64_bsp Product Board : k65v1_64_bsp Board Platform : mt6765 Product Manfct : vivo USERDATA : FILESYSTEM : EXT4 with FBE ( File-Base Encryption ) NVRAM check : Passed! NVRAM : SEC NORMAL [ No extra security ] Backup sensetive data [ 15 ] Backup path : Backup\MT6765__E241B5F23C3BF5B821D97CA4353A4792\ [35] Read : NVRAM [10] Read : NVDATA [25] Read : PROINFO [36] Read : LK [9] Read : NVCFG [20] Read : PROTECT1 [21] Read : PROTECT2 [23] Read : PERSIST [0] Read : PRELOADER [22] Read : SECCFG Backup done! STORAGE : LifeStatus : eMMC : OK! Done! Elapsed: 00:00:54 Operation : Read Firmware [ v2.21 ] ExtSparse : Enabled ForceRead : Enabled 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM11) MODE : BOOTROM PORT : 11 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : 045DD03B566AFDA12301BF74A9E6325C BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : 306C49527BDE7211F0F4E777C1DA09E9D25E0C05052B96AC3E 92CAF3AB661440 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0001 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: 150100445836384D4209D91EDCFA6783 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : DX68MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : E241B5F23C3BF5B821D97CA4353A4792 DA : USB : HIGH-SPEED Boot done! Product Brand : vivo Product Device : k65v1_64_bsp Product Model : vivo 2026 Product Name : full_k65v1_64_bsp Patch Level : QP1A.190711.020 Display ID : QP1A.190711.020 release-keys Ver. CodeName : REL Ver. Release : 10 Sec. Patch : 2021-01-01 Build Time : 04.02.2021 Product Info : k65v1_64_bsp Product Board : k65v1_64_bsp Board Platform : mt6765 Product Manfct : vivo MT6765__10__QP1A.190711.020__k65v1_64_bsp Read : preloader.bin Read : recovery.img Read : vbmeta_system.img Read : vbmeta_vendor.img Read : backup.img Read : survival.img Read : reserved.img Read : cust.img ExtSparse : Compression ratio : 96% Read : vgc.img ExtSparse : Compression ratio : 99% Read : persist.img ExtSparse : Compression ratio : 77% Read : proinfo.img Read : efuse.img Read : md1rom.img Read : spmfw.img Read : tinysys-scp.bin Read : tinysys-sspm.bin Read : nvram.bin Read : lk.bin Read : boot.img Read : logo.bin Read : dtbo.img Read : tz.img Read : super.img ExtSparse : Compression ratio : 21% Read : vbmeta.img Read : cache.img Read : userdata.img FW Size : 5.23 GB Android Info saved : _Android_info.txt Scatter : MT6765_Android_scatter.txt Saved to : C:\InfinityBox\CM2MT2\Backup\MT6765__10__QP1A.1907 11.020__k65v1_64_bsp\ Done! Elapsed: 00:10:05 |
![]() | #66396 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,517 | Infinix smart4c x653c reaf factory firmware done by cm2 Card found : 73CA70CC , v0147 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.21 Load IDBase v210169 Ok! Update configuration ... Update Ok! Load IDBase v210169 Ok! Operation : Identify [ v2.21 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM11) MODE : BOOTROM PORT : 11 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 CODE : Merlot TYPE : MODERN RAPHAEL BROM : MEID : 96AB7F066621B33CD426010ABBF4866D BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : 4FD2753525D5239A0AC030119B9E8A4D6392A59F5418641C4C E62EA7A328893D BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0001 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: 150100514436334D420165ABD2CD1791 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : QD63MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 2D182D028BA522D430BC0DBA65C7FAD9 DA : USB : HIGH-SPEED Boot done! Patch Level : PPR1.180610.011 Display ID : X653C-H6114GH-PGo-191119V207 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2019-11-05 Build Time : 19.11.2019 Product Model : Infinix X653C Product Brand : Infinix Product Name : H6114 Product Device : Infinix-X653C Product Manfct : INFINIX MOBILITY LIMITED Product Info : x653c_h6114go Product Board : Infinix-X653C Board Platform : mt6761 USERDATA : FILESYSTEM : F2FS with FDE ( Full Disk Encryption **) NVRAM check : Passed! NVRAM : SEC NORMAL [ No extra security ] Backup sensetive data [ 15 ] Backup path : Backup\MT6761__2D182D028BA522D430BC0DBA65C7FAD9\ [12] Read : NVRAM [36] Read : NVDATA [29] Read : PROINFO [13] Read : LK [35] Read : NVCFG [24] Read : PROTECT1 [25] Read : PROTECT2 [23] Read : PERSIST [0] Read : PRELOADER [2] Read : SECCFG Backup done! STORAGE : LifeStatus : eMMC : OK! Done! Elapsed: 00:00:43 Operation : Read Firmware [ v2.21 ] ExtSparse : Enabled ForceRead : Enabled 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM11) MODE : BOOTROM PORT : 11 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 CODE : Merlot TYPE : MODERN RAPHAEL BROM : MEID : 96AB7F066621B33CD426010ABBF4866D BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : 4FD2753525D5239A0AC030119B9E8A4D6392A59F5418641C4C E62EA7A328893D BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0001 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: 150100514436334D420165ABD2CD1791 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : QD63MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 2D182D028BA522D430BC0DBA65C7FAD9 DA : USB : HIGH-SPEED Boot done! Patch Level : PPR1.180610.011 Display ID : X653C-H6114GH-PGo-191119V207 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2019-11-05 Build Time : 19.11.2019 Product Model : Infinix X653C Product Brand : Infinix Product Name : H6114 Product Device : Infinix-X653C Product Manfct : INFINIX MOBILITY LIMITED Product Info : x653c_h6114go Product Board : Infinix-X653C Board Platform : mt6761 MT6761__INFINIX_MOBILITY_LIMITED__Infinix_X653C__9 __X653C-H6114GH-PGo-191119V207__PPR1.180610.011__x653c_h6114go Read : preloader.bin Read : md1rom.img Read : spmfw.img Read : tinysys-scp.bin Read : tinysys-sspm.bin Read : nvram.bin Read : lk.bin Read : boot.img Read : logo.bin Read : dtbo.img Read : tz.img Read : vendor.img ExtSparse : Compression ratio : 43% Read : system.img ExtSparse : Compression ratio : 26% Read : vbmeta.img Read : persist.img ExtSparse : Compression ratio : 92% Read : cache.img Read : recovery.img Read : tkv.img Read : proinfo.img Read : userdata.img FW Size : 2.24 GB Android Info saved : _Android_info.txt Scatter : MT6761_Android_scatter.txt Saved to : C:\InfinityBox\CM2MT2\Backup\MT6761__INFINIX_MOBIL ITY_LIMITED__Infinix_X653C__9__X653C-H6114GH-PGo-191119V207__PPR1.180610.011__x653c_h6114go\ Done! Elapsed: 00:05:03 |
The Following User Says Thank You to A.G.Shahid For This Useful Post: |
![]() | #66397 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,517 | Infinix smart 4c x653c remove pattern pin frp one click Card found : 73CA70CC , v0147 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.21 Load IDBase v210169 Ok! Update configuration ... Update Ok! Load IDBase v210169 Ok! Operation : Identify [ v2.21 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM11) MODE : BOOTROM PORT : 11 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 CODE : Merlot TYPE : MODERN RAPHAEL BROM : MEID : 96AB7F066621B33CD426010ABBF4866D BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : 4FD2753525D5239A0AC030119B9E8A4D6392A59F5418641C4C E62EA7A328893D BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0001 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: 150100514436334D420165ABD2CD1791 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : QD63MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 2D182D028BA522D430BC0DBA65C7FAD9 DA : USB : HIGH-SPEED Boot done! Patch Level : PPR1.180610.011 Display ID : X653C-H6114GH-PGo-191119V207 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2019-11-05 Build Time : 19.11.2019 Product Model : Infinix X653C Product Brand : Infinix Product Name : H6114 Product Device : Infinix-X653C Product Manfct : INFINIX MOBILITY LIMITED Product Info : x653c_h6114go Product Board : Infinix-X653C Board Platform : mt6761 USERDATA : FILESYSTEM : F2FS with FDE ( Full Disk Encryption **) NVRAM check : Passed! NVRAM : SEC NORMAL [ No extra security ] Backup sensetive data [ 15 ] Backup path : Backup\MT6761__2D182D028BA522D430BC0DBA65C7FAD9\ [12] Read : NVRAM [36] Read : NVDATA [29] Read : PROINFO [13] Read : LK [35] Read : NVCFG [24] Read : PROTECT1 [25] Read : PROTECT2 [23] Read : PERSIST [0] Read : PRELOADER [2] Read : SECCFG Backup done! STORAGE : LifeStatus : eMMC : OK! Done! Elapsed: 00:00:47 Operation : Reset Settings/Format FS [ v2.21 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM11) MODE : BOOTROM PORT : 11 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 CODE : Merlot TYPE : MODERN RAPHAEL BROM : MEID : 96AB7F066621B33CD426010ABBF4866D BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : 4FD2753525D5239A0AC030119B9E8A4D6392A59F5418641C4C E62EA7A328893D BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0001 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: 150100514436334D420165ABD2CD1791 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : QD63MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 2D182D028BA522D430BC0DBA65C7FAD9 DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x815657 Format Ok : USERDATA Format Ok : CACHE Format Ok : RESET PROTECTION Format Ok : USERDATA Done! Elapsed: 00:00:35 Reconnect Power/Cable! |
![]() | #66398 (permalink) |
Junior Member Join Date: Nov 2014 Location: Kurunegala,Sri lanka
Member: 2292563 Status: Offline Thanks Meter: 5 | ![]() Operation : Reset Settings/Format FS [ v2.21 ] Mode : FULL FACTORY ( FORCED + FRP ) 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM12) MODE : BOOTROM PORT : 12 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : 4E4104C34496B58998C2254D53EC0359 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : Oppo : A1K-A12-A31-A32 | Manual : Disabled BROM : SOCID : 3A9C6386CE8825DCA6E2255B1882366D44A57078B80A1A8339 5D7156E1456446 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0005 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: 90014A68423861503E030073B282B78D EMMC: VEN : HYNIX | OEM : 4A01 | DEV : hB8aP> EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : D0D481BBA0D65C1E32D4BA4748775344 DA : USB : HIGH-SPEED Boot done! Format Ok : USERDATA Format Ok : CACHE Format Ok : RESET PROTECTION Format Ok : USERDATA Done! Elapsed: 00:00:34 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to Isuru Dilan For This Useful Post: |
![]() | #66399 (permalink) | |
Insane Poster ![]() ![]() ![]() Join Date: Nov 2016 Location: Plumtree, Zimbabwe
Member: 2647569 Status: Offline Thanks Meter: 38 ![]() | Itel S13 Privacy + FRP done Quote:
![]() | #66400 (permalink) | |
Member: 2647569 Status: Offline Thanks Meter: 38 ![]() | Hurricane_Flame_Plus firmware read done Hurricane Flame Plus Quote:
![]() | #66401 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Feb 2016 Location: ZIMBABWE
Member: 2534995 Status: Offline Thanks Meter: 24 ![]() | mobicel pulse 1 network unlock done Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_512MB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0002 FDL : Control transfered! Boot Done! NVMng : SecurityInfo IMEI[1] : 35519000000000 IMEI[2] : 35519000000000 IMEI[3] : 8674000000000 WIFIMAC : FFFFFFFFFFFF BT_MAC : FFFFFFFFFFFF SEC : SLS:0, SKS:0, SKV:2 SLStatus : 31 Unlocking device ... Sync data ... Device unlocked! Done! Elapsed: 00:00:37 Last edited by mapopeemma; 04-08-2021 at 09:40. Reason: ather |
![]() | #66402 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2011 Location: PAKISTAN
Member: 1537135 Status: Offline Thanks Meter: 691 | ![]() Code: Card found : C1B4DF65 , v0147 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.21 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM22) MODE : BOOTROM PORT : 22 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : 5317DC63CCD7BE3E7A501405FDD04E84 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : A48D54F7AE5ABE986C1359048FFF0CA641E5372FD8CF491CDCFC387378099A95 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0003 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: 150100514436334D42034AA89B8817AB EMMC: VEN : SAMSUNG | OEM : 01 | DEV : QD63MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : D20FCAB7BC235E52427382B7A2E98640 DA : USB : HIGH-SPEED Boot done! Patch Level : PPR1.180610.011 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2021-03-05 Product Manfct : OPPO Build Time : 24.02.2021 Product Brand : OPPO Product Model : CPH1923 Product Info : CPH1923 Product Name : CPH1923 Product Device : OP486C SW OTA Version : CPH1923EX_11.A.39_0390_202102241729 Display ID : CPH1923EX_11_A.39 Kernel Info : 4.9.117 USERDATA : FILESYSTEM : EXT4 with FBE ( File-Base Encryption ) NVRAM check : Passed! NVRAM : SEC ENCRYPT [ IMEI ENCRYPTED ] Backup sensetive data [ 15 ] Backup path : Backup\MT6765__D20FCAB7BC235E52427382B7A2E98640\ [29] Read : NVRAM [13] Read : NVDATA [20] Read : PROINFO [30] Read : LK [12] Read : NVCFG [15] Read : PROTECT1 [16] Read : PROTECT2 [18] Read : PERSIST [0] Read : PRELOADER [17] Read : SECCFG [5] Read : OPPORESERVE1 [6] Read : OPPORESERVE2 [7] Read : OPPORESERVE3 Backup done! STORAGE : LifeStatus : eMMC : OK! Done! Elapsed: 00:00:42 Operation : Read Firmware [ v2.21 ] ExtSparse : Enabled ForceRead : Disabled 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM22) MODE : BOOTROM PORT : 22 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : 5317DC63CCD7BE3E7A501405FDD04E84 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : A48D54F7AE5ABE986C1359048FFF0CA641E5372FD8CF491CDCFC387378099A95 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0003 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: 150100514436334D42034AA89B8817AB EMMC: VEN : SAMSUNG | OEM : 01 | DEV : QD63MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : D20FCAB7BC235E52427382B7A2E98640 DA : USB : HIGH-SPEED Boot done! Patch Level : PPR1.180610.011 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2021-03-05 Product Manfct : OPPO Build Time : 24.02.2021 Product Brand : OPPO Product Model : CPH1923 Product Info : CPH1923 Product Name : CPH1923 Product Device : OP486C SW OTA Version : CPH1923EX_11.A.39_0390_202102241729 Display ID : CPH1923EX_11_A.39 Kernel Info : 4.9.117 MT6765__OPPO__CPH1923__9__CPH1923EX_11_A.39__PPR1.180610.011__CPH1923 Read : preloader.bin Read : recovery.img Read : opporeserve.img Read : oppo_custom.img Read : vbmeta.img Read : persist.img ExtSparse : Compression ratio : 62% Read : proinfo.img Read : md1rom.img Read : spmfw.img Read : tinysys-scp.bin Read : tinysys-sspm.bin Read : nvram.bin Read : lk.bin Read : boot.img Read : logo.bin Read : dtbo.img Read : tz.img Read : odm.img ExtSparse : Compression ratio : 100% Read : vendor.img ExtSparse : Compression ratio : 29% Read : system.img ExtSparse : Compression ratio : 25% Read : cache.img Read : userdata.img FW Size : 4.43 GB Android Info saved : _Android_info.txt Scatter : MT6765_Android_scatter.txt Saved to : D:\1\MASTER 123\5\MT6765__OPPO__CPH1923__9__CPH1923EX_11_A.39__PPR1.180610.011__CPH1923\ Done! Elapsed: 00:09:48 Load IDBase v21168 Ok! Operation : Identify [ v2.21 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM22) MODE : BOOTROM PORT : 22 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : 5317DC63CCD7BE3E7A501405FDD04E84 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : A48D54F7AE5ABE986C1359048FFF0CA641E5372FD8CF491CDCFC387378099A95 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0003 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: 150100514436334D42034AA89B8817AB EMMC: VEN : SAMSUNG | OEM : 01 | DEV : QD63MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : D20FCAB7BC235E52427382B7A2E98640 DA : USB : HIGH-SPEED Boot done! Patch Level : PPR1.180610.011 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2021-03-05 Product Manfct : OPPO Build Time : 24.02.2021 Product Brand : OPPO Product Model : CPH1923 Product Info : CPH1923 Product Name : CPH1923 Product Device : OP486C SW OTA Version : CPH1923EX_11.A.39_0390_202102241729 Display ID : CPH1923EX_11_A.39 Kernel Info : 4.9.117 USERDATA : FILESYSTEM : EXT4 with FBE ( File-Base Encryption ) NVRAM check : Passed! NVRAM : SEC ENCRYPT [ IMEI ENCRYPTED ] Backup sensetive data [ 15 ] Backup path : Backup\MT6765__D20FCAB7BC235E52427382B7A2E98640\ Backup done! STORAGE : LifeStatus : eMMC : OK! Done! Elapsed: 00:00:29 Operation : Reset Settings/Format FS [ v2.21 ] Mode : FORCED EXT FORMAT 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM22) MODE : BOOTROM PORT : 22 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : 5317DC63CCD7BE3E7A501405FDD04E84 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : A48D54F7AE5ABE986C1359048FFF0CA641E5372FD8CF491CDCFC387378099A95 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0003 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: 150100514436334D42034AA89B8817AB EMMC: VEN : SAMSUNG | OEM : 01 | DEV : QD63MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : D20FCAB7BC235E52427382B7A2E98640 DA : USB : HIGH-SPEED Boot done! Format Ok : USERDATA Format Ok : CACHE Format Ok : RESET PROTECTION Format Ok : USERDATA Done! Elapsed: 00:00:22 Reconnect Power/Cable! |
The Following 4 Users Say Thank You to naveedullah0044 For This Useful Post: |
![]() | #66403 (permalink) |
Member: 1537135 Status: Offline Thanks Meter: 691 | ![]() Code: Card found : C1B4DF65 , v0147 Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.07 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary ERROR : FDL NOT started! Error : Loader send failed! Wrong model selected! Select correct one! Reconnect Power/Cable! SPRD mode : SC6531 : REV : E001 : NOR : [ 4MB-8MB ] Operation : Format FileSystem [ v1.07 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR 6531EFM v2.0 (c)2019 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [GIGADEVICE] : GD25Q32 : 0x00400000 [ 4MiB ] Make backup of sensetive data Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_057972478E30_NVM.nv Executing FormatFFS ... Format FFS Done! Done! Elapsed: 00:00:13 Reconnect Power/Cable! Operation : Read Flash [ v1.07 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR 6531EFM v2.0 (c)2019 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [GIGADEVICE] : GD25Q32 : 0x00400000 [ 4MiB ] Read Flash Ok, Size : 4.00 MiB Platform Version: MOCOR_16A.W17.43.4_Release Project Version: SC6531EFM_E05 MMI Version: EO5_TYY_B220_GFIVE_COMMANDO_V04_13042018_1735 BASE Version: BASE_SVN HW Version: SC6531EFM_BAR 2018-04-13 17:35:10 LOG Version: V1.0.1 Saved to : D:\1\vedio\NEW AC\YOUTUBE\g five-commando\EO5_TYY_B220_GFIVE_COMMANDO_V04_13042018_1735.bin Done! Elapsed: 00:01:16 Reconnect Power/Cable! |
![]() | #66404 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2008
Member: 740220 Status: Offline Sonork: 100.1654997 Thanks Meter: 246 | ![]() Operation : Repair Security [ v2.21 ] Mode : META 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM11) MODE : BOOTROM PORT : 11 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : MEID : 669AAEDD60FEB88871096A4BE20EDF79 BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BOOTROM BROM : Configuring target for META BROM : META configured! INIT : META confirmed! Boot done! AP_CHIP : MT6580,S01 AP_SWTM : Sat Mar 16 16:28:07 CST 2019 AP_SWVR : alps-mp-m0.mp1-V2.39_ot6580.weg.y33.m_P123 AP_HWVR : S01 MD_CHIP : MT6580B, E00 MD_SWTM : 2000.00.00 MD_DSPV : 1.0 MD_DSPP : MOLY.WR8.W1449.MD.WG.MP.V59.P22 MD_SWVR : OT6580_WE_Y33_M_HSPA_HW MD_HWVR : Unknown IMEI[0] : 86xxxxxxxxxxxxx IMEI[1] : 86xxxxxxxxxxxxx IMEI[0] : 35xxxxxxxxxxxxxx Item : update Ok! IMEI[1] : 35xxxxxxxxxxxxx Item : update Ok! Done! Elapsed: 00:01:14 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to zoiya For This Useful Post: |
