12-27-2021, 11:11 | #69136 (permalink) |
No Life Poster Join Date: Jul 2009 Location: SINDH PAKISTAN
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | Qmobile i8i format frp done Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 3 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x0000000133CF7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x/6.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:23 Reconnect Power/Cable! |
12-27-2021, 11:13 | #69137 (permalink) |
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | vgotel format done Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 4 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 3C389CCA0E2104DFA4555773EF33A951 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00EC , [GigaDevice] GD25LQ32 [0] : FLASH_DIE : 00C8 0060 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Backup done Executing FFS FORMAT now... FAT_RANGE : 0x00382000-0x003FDFFF , LEN : 0x0007C000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Done! Elapsed: 00:00:14 Reconnect Power/Cable! |
12-27-2021, 11:14 | #69138 (permalink) |
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 110100303034474530019D1004186239 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x11 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 0EG40 [eMMC] : FLASH_CID : 110100303034474530019D1004186239 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB] DEV RID : 0x033C52174724300C8BDBA19A1A7CA5E4 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:25 Reconnect Power/Cable! |
12-27-2021, 11:15 | #69139 (permalink) |
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 4 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 53898F56045DCE3580D56528A4CDFBD2 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0112 , [MXIC] MX25L3291FWJI_09 [0] : FLASH_DIE : 00C2 0020 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Backup exists , skip Executing FFS FORMAT now... FAT_RANGE : 0x00382000-0x003FDFFF , LEN : 0x0007C000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Done! Elapsed: 00:00:09 Reconnect Power/Cable! |
12-27-2021, 11:17 | #69140 (permalink) |
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | Qmobile i8i format done Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 3 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x0000000133CF7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x/6.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:23 Reconnect Power/Cable! |
12-27-2021, 11:47 | #69141 (permalink) |
No Life Poster Join Date: Jun 2014 Location: Infinity Box Team
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | vgotel v3310 read user code done Operation : Read UserCode [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 16 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CA02 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : D8847C3018E7518D4E28FCD7FDC29D7E BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV [0] : FLASH_DIE : 00EF 0070 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Read ExtData Sorting ExtData Reading UserCode Active : Yes , Code : 1236 PLock|MobTrack : Not active Done! Elapsed: 00:00:12 Reconnect Power/Cable! |
12-27-2021, 13:33 | #69142 (permalink) |
No Life Poster Join Date: Nov 2013 Location: pakistan P G L Age: 39
Member: 2067643 Status: Offline Sonork: 1611265 Thanks Meter: 474 | oppo f16 2021 smart reset Operation : Identify [ v2.32 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM38) MODE : BOOTROM PORT : 38 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 19B0244881C6A23FD6F2FE73B4DC6EC9 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 428014DFB0B85F426FEB4959B7204A6D30F77C3C9B3036DE1B 1E58BFE0EFE80F BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : FF : Look for EMI BROM : FF : EMI found! BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_oppo6765.bin EMI : CNT : 0007 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: CID : 13014E47314A3952381012FBC8FD58B7 EMMC: VEN : MICRON : OEM : 78 : ID : 47314A395238 EMMC: VEN : MICRON : G1J9R8 EMMC: SNN : 318490877 ( 0x12FBC8FD) , MF : 5/2021 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 165643B1353E222988E30688B7024139 DA : USB : HIGH-SPEED Boot done! Product Board : oppo6765 Board Platform : mt6765 Product Brand : alps Product Device : oppo6765 Product Manfct : alps Product Model : oppo6765 Product Name : vnd_oppo6765 Device UID : MT6765__CPH2269_export_11_A.05_2021082619440000 USERDATA : FILESYSTEM : F2FS with FBE ( File-Base Encryption ) NVRAM : OPPO6765_20375_MDBIN_PCB01_MT6765_S00.MOLY_LR12A_R 3_TC16_SP_V1_P25 NVRAM : 0xA608C4CA NVRAM : State : Ok! INFO : WiFi MAC : 546706AD3817 INFO : BlTh MAC : 546706AD3816 Backup sensetive data [ 17 ] Backup path : Backup\MT6765__19B0244881C6A23FD6F2FE73B4DC6EC9\ [35] Read : NVRAM [14] Read : NVDATA [22] Read : PROINFO [36] Read : LK [13] Read : NVCFG [17] Read : PROTECT1 [1] Read : PGPT [20] Read : PERSIST [0] Read : PRELOADER [7] Read : OPPORESERVE3 Backup done! STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : UNLOCKED! STORAGE : RPMB Status : eMMC : RPMB KEY PROGRAMMED [UNUSABLE] Done! Elapsed: 00:00:49 Operation : Reset Settings/Format FS [ v2.32 ] Mode : SMART RESET EXTRA 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM38) MODE : BOOTROM PORT : 38 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 19B0244881C6A23FD6F2FE73B4DC6EC9 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 428014DFB0B85F426FEB4959B7204A6D30F77C3C9B3036DE1B 1E58BFE0EFE80F BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_oppo6765.bin EMI : CNT : 0007 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: CID : 13014E47314A3952381012FBC8FD58B7 EMMC: VEN : MICRON : OEM : 78 : ID : 47314A395238 EMMC: VEN : MICRON : G1J9R8 EMMC: SNN : 318490877 ( 0x12FBC8FD) , MF : 5/2021 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 165643B1353E222988E30688B7024139 DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x815657 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : CACHE Format Ok : USERDATA Format Ok : USERDATA Done! Elapsed: 00:00:54 Reconnect Power/Cable! |
The Following User Says Thank You to iftikharrana58 For This Useful Post: |
12-27-2021, 16:22 | #69143 (permalink) |
Freak Poster Join Date: Jan 2016 Location: faisalabad Age: 41
Member: 2518014 Status: Offline Thanks Meter: 43 | vivo y90 security repair ok Operation : Repair Security [ v2.32 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM5) MODE : PRELOADER PORT PORT : 5 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 CODE : Merlot TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : Reset Interface! PTFN : MediaTek USB Port (COM7) MODE : BOOTROM PORT : 7 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 CODE : Merlot TYPE : MODERN [RAPHAEL] BROM : MEID : 11EEC2995289F96C270448F1A4C49E7F BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : D480F881F13325A1CC44DCAFC03B7BA8AF0FFFB0C981E3360C 7152BDF708A5E4 BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_k61v1_64_bsp.bin EMI : CNT : 0006 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A400 [ 233.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: CID : 150100514436334D42018D81E47DA623 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 514436334D42 EMMC: VEN : SAMSUNG : QD63MB EMMC: SNN : 2374100093 ( 0x8D81E47D) , MF : 10/2019 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : FFDDA12357995EA3A55E4AB4B784DC1C DA : USB : HIGH-SPEED Boot done! NVRAM : 0xB50AF625 NVRAM : State : Ok! INFO : WiFi MAC : 20311CD67BDB INFO : BlTh MAC : 20311CD67BDA INFO : IMEI[1] : 8########### INFO : IMEI[2] : 86########## INFO : set IMEI[1] : 86########## INFO : set IMEI[2] : 86########## Update NVRAM ... Update NVRAM Ok! Update dependencies ... Update dependencies Ok! Vendor extra : VIVO security IMEI : 86########### IMEI2 : 86########## PCB : 2996610825@1 New : IMEI[1] 86######## IMEI[2] 86######## Security data updated! Done! Elapsed: 00:00:38 Reconnect Power/Cable! |
The Following 3 Users Say Thank You to Viaraja786 For This Useful Post: |
12-28-2021, 06:23 | #69144 (permalink) |
No Life Poster Join Date: Aug 2011 Location: bagmati pradesh
Member: 1626780 Status: Offline Thanks Meter: 1,275 | jio a23 pro unlock done Operation : SP Unlock [ v2.14 ] BootMode : SVC 1. Power off device, wait 10-15 seconds 2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! SOC GEN : UniSoc ( E-family and Modern ) BuildInfo : 010.01.020 Platform Version: MOCORTM_18A_ITELQ_W21.09.5_Debug Project Version: sharkle_Smart_Phone BASE Version: FM_BASE_18A_ITELQ_W21.09.5 HW Version: sc9832e_modem CMP_Time : 04-01-2021 16:22:52 MODEM TAG : MOCORTM_18A_ITELQ_W21.09.5_Debug_FM_BASE_18A_ITELQ _W21.09.5_sc9832e_modem_sharkle_Smart_Phone NVMng : SecurityInfo IMEI[1] : IMEI[2] : WIFIMAC : BT_MAC : SEC : SLS:2, SKS:0, SKV:E SLStatus : 2C Status : Locked! Server unlock required! Connecting to server... Connected Init... Init: Ok Authenticating... Authenticated Checking Client version... Client version Ok Balance: 5, price:5 Process... Finished Disconnected Unlocking device ... Sync data ... Device unlocked! Done! Elapsed: 00:01:07 |
12-28-2021, 07:54 | #69145 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Oppo A12 MT6765 Dead Set Alive Done With Flashing King Infinity CM2 Code: Card found : A19EC787 , v0151 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.32 Load IDBase v1121431 Ok! UserName and/or Password not set! Can't continue! Load IDBase v1121431 Ok! Operation : Read Firmware [ v2.32 ] ExtSparse : Enabled ForceRead : Disabled 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM16) MODE : BOOTROM PORT : 16 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 0B7273C3C562A187724ECF7100B37C1E BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 62556441BF9419BB80D9FC1EAC9734B2418AF7FC6AA9E511D13CC177CC504C79 BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_oppo6765_19451.bin EMI : CNT : 000A EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: CID : 90014A68423861503E030044DE6197ED EMMC: VEN : HYNIX : OEM : 74 : ID : 68423861503E EMMC: VEN : HYNIX : hB8aP> EMMC: SNN : 4513377 ( 0x0044DE61) , MF : 9/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : FB4681AFD6F49BE14C57B543212341DA DA : USB : HIGH-SPEED Boot done! Patch Level : PPR1.180610.011 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2021-09-05 Product Manfct : OPPO Build Time : 06.09.2021 Product Brand : OPPO Product Model : CPH2083 Product Info : CPH2083 Product Name : CPH2083 Product Device : OP4BFB SW OTA Version : CPH2083PUEX_11.A.63_0630_202109061412 Display ID : CPH2083EX_11_A.63 Display ID : CPH2083EX_11_A.63_210906 Kernel Info : 4.9.117 MT6765__CPH2083_11_A.39_200820_248b7f61 Read : preloader.bin Read : recovery.img Read : opporeserve1.img Read : opporeserve2.img ExtSparse : Compression ratio : 63% Read : opporeserve3.img Read : oppo_custom.img Read : persist.img ExtSparse : Compression ratio : 91% Read : proinfo.img Read : md1rom.img Read : spmfw.img Read : tinysys-scp.bin Read : sspm.img Read : nvram.bin Read : lk.bin Read : boot.img Read : logo.bin Read : dtbo.img Read : tz.img Read : odm.img ExtSparse : Compression ratio : 100% Read : vendor.img ExtSparse : Compression ratio : 28% Read : system.img ExtSparse : Compression ratio : 25% Read : vbmeta.img Read : cache.img Read : userdata.img FW Size : 5.59 GB Android Info saved : _Android_info.txt Scatter : MT6765_Android_scatter.txt Saved to : C:\Users\Azher\Desktop\MT6765__CPH2083_11_A.39_200820_248b7f61\ Done! Elapsed: 00:08:09 Created by Infinity-Box (c) 2021 Chinese Miracle II : MediaTek Service Module Device Info file : _Android_info.txt Patch Level : PPR1.180610.011 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2020-11-05 Product Manfct : OPPO Build Time : 25.11.2020 Product Brand : OPPO Product Model : CPH2083 Product Info : CPH2083 Product Name : CPH2083 Product Device : OP4BFB SW OTA Version : CPH2083PUEX_11.A.49_0490_202011260116 Display ID : CPH2083EX_11_A.49 Display ID : CPH2083EX_11_A.49_201126 Kernel Info : 4.9.117 Preloader [HW DEV] Info : EMI : DEV : MT6765 EMI : SRC : preloader_oppo6765_19451.bin EMI : CNT : 000A EMI : [00] : eMMC : LP_DDR4X : ID : 150100444436384D42 : VEN : SAMSUNG | DEV : DD68MB : RAM : [ 3.00 GB ] EMI : [01] : eMMC : LP_DDR4X : ID : 90014A68423861503E : VEN : HYNIX | DEV : hB8aP> : RAM : [ 3.00 GB ] EMI : [02] : eMMC : LP_DDR4X : ID : 90014A684339615033 : VEN : HYNIX | DEV : hC9aP3 : RAM : [ 4.00 GB ] EMI : [03] : eMMC : LP_DDR4X : ID : 150100444836444142 : VEN : SAMSUNG | DEV : DH6DAB : RAM : [ 4.00 GB ] EMI : [04] : eMMC : DDR3 : ID : 90014A484147346132 : VEN : HYNIX | DEV : HAG4a2 : RAM : [ 2.00 GB ] EMI : [05] : eMMC : DDR3 : ID : 90014A68423861503E : VEN : HYNIX | DEV : hB8aP> : RAM : [ 3.00 GB ] EMI : [06] : eMMC : DDR3 : ID : 90014A484347386134 : VEN : HYNIX | DEV : HCG8a4 : RAM : [ 4.00 GB ] EMI : [07] : eMMC : LP_DDR4X : ID : 13014E47314A395238 : VEN : MICRON | DEV : G1J9R8 : RAM : [ 4.00 GB ] EMI : [08] : eMMC : LP_DDR4X : ID : 1501003458364B4D42 : VEN : SAMSUNG | DEV : 4X6KMB : RAM : [ 2.00 GB ] EMI : [09] : eMMC : LP_DDR4X : ID : 90014A68423861503E : VEN : HYNIX | DEV : hB8aP> : RAM : [ 2.00 GB ] Operation : Write Flash [ v2.32 ] Repartition : Enabled Flash Verify : Disabled Reg.Pre-Erase : Enabled Verify HW/SW : Enabled SData Backup : Disabled Safe UserData : Disabled Flash Format : Disabled Files :21 [FL] : Set : preloader_oppo6765_19451.bin [FL] : Set : recovery.img [FL] : Set : md1rom.img [FL] : Set : spmfw.img [FL] : Set : tinysys-scp.bin [FL] : Set : tinysys-scp.bin [FL] : Set : tinysys-sspm.bin [FL] : Set : tinysys-sspm.bin [FL] : Set : lk.bin [FL] : Set : lk.bin [FL] : Set : boot.img [FL] : Set : logo.bin [FL] : Set : dtbo.img [FL] : Set : tz.img [FL] : Set : tz.img [FL] : Set : odm.img [FL] : Set : vendor.img [FL] : Set : system.img [FL] : Set : vbmeta.img [FL] : Set : cache.img [FL] : Set : userdata.img [FL] : Total size : 0x15FC28900 [ 5.50 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM16) MODE : BOOTROM PORT : 16 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 0B7273C3C562A187724ECF7100B37C1E BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 62556441BF9419BB80D9FC1EAC9734B2418AF7FC6AA9E511D13CC177CC504C79 BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : MT6765 EMI : SRC : preloader_oppo6765_19451.bin EMI : CNT : 000A EMI : [00] : eMMC : LP_DDR4X : ID : 150100444436384D42 : VEN : SAMSUNG | DEV : DD68MB : RAM : [ 3.00 GB ] EMI : [01] : eMMC : LP_DDR4X : ID : 90014A68423861503E : VEN : HYNIX | DEV : hB8aP> : RAM : [ 3.00 GB ] EMI : [02] : eMMC : LP_DDR4X : ID : 90014A684339615033 : VEN : HYNIX | DEV : hC9aP3 : RAM : [ 4.00 GB ] EMI : [03] : eMMC : LP_DDR4X : ID : 150100444836444142 : VEN : SAMSUNG | DEV : DH6DAB : RAM : [ 4.00 GB ] EMI : [04] : eMMC : DDR3 : ID : 90014A484147346132 : VEN : HYNIX | DEV : HAG4a2 : RAM : [ 2.00 GB ] EMI : [05] : eMMC : DDR3 : ID : 90014A68423861503E : VEN : HYNIX | DEV : hB8aP> : RAM : [ 3.00 GB ] EMI : [06] : eMMC : DDR3 : ID : 90014A484347386134 : VEN : HYNIX | DEV : HCG8a4 : RAM : [ 4.00 GB ] EMI : [07] : eMMC : LP_DDR4X : ID : 13014E47314A395238 : VEN : MICRON | DEV : G1J9R8 : RAM : [ 4.00 GB ] EMI : [08] : eMMC : LP_DDR4X : ID : 1501003458364B4D42 : VEN : SAMSUNG | DEV : 4X6KMB : RAM : [ 2.00 GB ] EMI : [09] : eMMC : LP_DDR4X : ID : 90014A68423861503E : VEN : HYNIX | DEV : hB8aP> : RAM : [ 2.00 GB ] EMI : Init EMI from PRELOADER EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: CID : 90014A68423861503E030044DE6197ED EMMC: VEN : HYNIX : OEM : 74 : ID : 68423861503E EMMC: VEN : HYNIX : hB8aP> EMMC: SNN : 4513377 ( 0x0044DE61) , MF : 9/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : FB4681AFD6F49BE14C57B543212341DA DA : USB : HIGH-SPEED Boot done! [FL] : HW verification passed! SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 [FL] : Pre-Erase Erase : 0x0000000000000000 : 0x0000000004188000 Erase : 0x000000000CA88000 : 0x0000000001500000 Erase : 0x000000000FF88000 : 0x0000000006000000 Erase : 0x0000000017000000 : 0x0000000000800000 Erase : 0x000000001A800000 : 0x0000000000200000 Erase : 0x000000001AD00000 : 0x0000000008900000 Erase : 0x0000000027600000 : 0x00000002B7200000 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing now ... Write : PRELOADER Update bootloader backup copy ... Update bootloader backup copy Ok! Write : RECOVERY Write : MD1IMG Write : SPMFW Write : SCP1 Write : SCP2 Write : SSPM_1 Write : SSPM_2 Write : LK Write : LK2 Write : BOOT Write : LOGO Write : DTBO Write : TEE1 Write : TEE2 Write : ODM Write : VENDOR Write : SYSTEM Write : VBMETA Write : CACHE Write : USERDATA UltraFlash : OK! SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing finished! Done! Elapsed: 00:04:46 Reconnect Power/Cable! |
12-28-2021, 09:00 | #69146 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Vivo Y15 MT6765 FRP/Pattren Reset Done With King Infinity CM2 Code: Card found : A19EC787 , v0151 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.32 Load IDBase v1121431 Ok! UserName and/or Password not set! Can't continue! Load IDBase v1121431 Ok! Operation : Reset Settings/Format FS [ v2.32 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM16) MODE : BOOTROM PORT : 16 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 44C3EA4116C971F59152690A31F6AA89 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 6D21C53F89F120E48818EE67A5B2625788978248B1EC76F1F18A6B68E6E6D185 BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : FF : Look for EMI BROM : FF : EMI found! BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_k62v1_64_bsp.bin EMI : CNT : 000F EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: CID : 150100525036344D42012702682837D1 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 525036344D42 EMMC: VEN : SAMSUNG : RP64MB EMMC: SNN : 654469160 ( 0x27026828) , MF : 3/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 36C4840F1BAC7816C2D5858D7B967DA7 DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x835757 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : CACHE Format Ok : USERDATA Done! Elapsed: 00:00:33 Reconnect Power/Cable! |
12-28-2021, 09:04 | #69147 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Vivo V15 MT6771 FRP/Pattren Reset Done With King Infinity CM2 Code: Operation : Reset Settings/Format FS [ v2.32 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM16) MODE : BOOTROM PORT : 16 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Sylvia TYPE : MODERN [RAPHAEL] BROM : MEID : F861498D1B612BA83ACC015ED154678B BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 9409393C6D3D2A0ADBEE76891E533C88ECE8A584052535A68C98D8AC8EF2EF88 BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6771 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_k71v1_64_bsp.bin EMI : CNT : 0011 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00039000 [ 228.00 KB ] DRAM: 0x180000000 [ 6.00 GB ] EMMC: CID : 90014A68433861503E03C064C2FFB507 EMMC: VEN : HYNIX : OEM : 74 : ID : 68433861503E EMMC: VEN : HYNIX : hC8aP> EMMC: SNN : 3227828991 ( 0xC064C2FF) , MF : 11/2018 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 1ED8F7FF81D4E6E0C738DC2DD8413DF8 DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x815757 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : CACHE Format Ok : USERDATA Done! Elapsed: 00:00:28 Reconnect Power/Cable! |
12-28-2021, 09:53 | #69148 (permalink) |
No Life Poster Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Infinix X682B Hot 10 RESET FRP DONE BY CM2 Card found : 73CA70CC , v0151 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.32 Load IDBase v1121431 Ok! UserName and/or Password not set! Can't continue! Load IDBase v1121431 Ok! Operation : Identify [ v2.32 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MTK USB Port (COM8) MODE : BOOTROM PORT : 8 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Talbot TYPE : MODERN [RAPHAEL] BROM : MEID : A58FABEA4EF41489779C662E93AFE235 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 4FAEE7BEA968AAD830E5E17DE271B8744ECAFD518C2D310987 93E125CCD8FECE BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : FF : Look for EMI BROM : FF : EMI found! BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6768 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : pre EMI : CNT : 000C EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00070000 [ 448.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: CID : 90014A684339615033010074B5FF8785 EMMC: VEN : HYNIX : OEM : 74 : ID : 684339615033 EMMC: VEN : HYNIX : hC9aP3 EMMC: SNN : 7648767 ( 0x0074B5FF) , MF : 8/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0001 , EVOL : 0x0000 RNID : B41689D250CFACEB6F8CDC7E69FD9F DA : USB : HIGH-SPEED Boot done! Product Brand : Infinix Product Device : Infinix-X682B Product Model : Infinix X682B Product Name : X682B-GL Patch Level : QP1A.190711.020 Display ID : X682B-H694ABT-Q-GL-200917V236 Ver. CodeName : REL Ver. Release : 10 Sec. Patch : 2020-08-05 Build Time : 17.09.2020 Product Info : x682b_h694 Product Board : Infinix-X682B Board Platform : mt6768 Product Manfct : INFINIX MOBILITY LIMITED USERDATA : FILESYSTEM : F2FS with FBE ( File-Base Encryption ) NVRAM : TK_MD_BASIC_MDBIN_PCB01_MT6768_S00.MOLY_LR12A_R3_M P_V118_11_P1 NVRAM : 0xB80AC7E2 NVRAM : State : Ok! INFO : WiFi MAC : AC2334C257BB INFO : BlTh MAC : AC2334C257BA INFO : IMEI[1] : 356631111132389 INFO : IMEI[2] : 356631111132397 Backup sensetive data [ 17 ] Backup path : Backup\MT6768__A58FABEA4EF41489779C662E93AFE235\ [27] Read : NVRAM [10] Read : NVDATA [3] Read : PROINFO [28] Read : LK [9] Read : NVCFG [12] Read : PROTECT1 [1] Read : PGPT [11] Read : PERSIST [0] Read : PRELOADER Backup done! STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : UNLOCKED! STORAGE : RPMB Status : eMMC : RPMB KEY NOT PROGRAMMED [USABLE] Done! Elapsed: 00:00:38 Operation : Reset Settings/Format FS [ v2.32 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MTK USB Port (COM8) MODE : BOOTROM PORT : 8 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Talbot TYPE : MODERN [RAPHAEL] BROM : MEID : A58FABEA4EF41489779C662E93AFE235 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 4FAEE7BEA968AAD830E5E17DE271B8744ECAFD518C2D310987 93E125CCD8FECE BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6768 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : pre EMI : CNT : 000C EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00070000 [ 448.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: CID : 90014A684339615033010074B5FF8785 EMMC: VEN : HYNIX : OEM : 74 : ID : 684339615033 EMMC: VEN : HYNIX : hC9aP3 EMMC: SNN : 7648767 ( 0x0074B5FF) , MF : 8/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0001 , EVOL : 0x0000 RNID : B41689D250CFACEB6F8CDC7E69FD9F DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x825657 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : CACHE Format Ok : USERDATA Format Ok : USERDATA Done! Elapsed: 00:00:25 Reconnect Power/Cable! |
12-28-2021, 09:55 | #69149 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Qmobile xli reset frp done by cm2 Card found : 73CA70CC , v0151 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14 Load IDBase v8331 Ok! Operation : Format FS / Reset Settings [ v2.14 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : BQru : BQ-5002G Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:59 |
12-28-2021, 09:57 | #69150 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Recno pop 5 remove frp done by cm2 Card found : 73CA70CC , v0151 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14 Load IDBase v8331 Ok! Operation : Format FS / Reset Settings [ v2.14 ] Mode : Reset FRP BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : TECNO : SC7731E_eMMC_AUTH_1GB_1S Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0020 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! FDL : Process authentification ... FDL : SEC : RSA auth passed! FDL : Control transfered! Boot Done! Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:35 |
