12-25-2021, 07:33 | #69106 (permalink) |
Freak Poster Join Date: Jul 2008 Location: PK
Member: 805129 Status: Offline Thanks Meter: 191 | Vivo S1 imei Repair Done With CM2 New Update 😝 All Vivo MTK Models imei Repair Done Vivo S1 imei Repair Done With CM2 New Update 😝 Vivo 1907 imei Repair With CM2 All Vivo MTK Models imei Repair Done With King CM2 https://youtube.com/watch?v=OfnB3DQ7hQ8 |
The Following 4 Users Say Thank You to asad76 For This Useful Post: |
12-25-2021, 07:43 | #69107 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Redmi Note 10 MT6768 FRP/Pattren Reset Done With King Infinity CM2 Code: Card found : A19EC787 , v0151 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.32 Load IDBase v1121431 Ok! UserName and/or Password not set! Can't continue! Load IDBase v1121431 Ok! Operation : Reset Settings/Format FS [ v2.32 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM151) MODE : BOOTROM PORT : 151 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Talbot TYPE : MODERN [RAPHAEL] BROM : MEID : E627B18ED632A96C7A5418FE6E69FEB2 BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 383B02BAB8C8FDA54F53330CC9B01A15D36061FC1F4676088E53AB65F31FD072 BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : FF : Look for EMI BROM : FF : EMI found! BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6768 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_selene.bin EMI : CNT : 000E EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00070000 [ 448.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: CID : 90014A68444561503303103BE63E681B EMMC: VEN : HYNIX : OEM : 74 : ID : 684445615033 EMMC: VEN : HYNIX : hDEaP3 EMMC: SNN : 272361022 ( 0x103BE63E) , MF : 6/2021 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x1D1F000000 [ 116.48 GB ] CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0001 , EVOL : 0x0000 RNID : CFFFEB7860165561C3577835B7736350 DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x835657 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : USERDATA Format Ok : USERDATA Done! Elapsed: 00:00:32 Reconnect Power/Cable! |
12-25-2021, 07:44 | #69108 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Vivo Y12S MT6765 FRP/Pattren Reset Done Wih King Infinity CM2 Code: Operation : Reset Settings/Format FS [ v2.32 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM16) MODE : BOOTROM PORT : 16 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN BROM : BROM|BL : 0xBB|0xBB BROM : BOOTROM BROM : EMI : Search BROM : EMI : Not found AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00000001 : DA SEND ERROR! ERROR : BROM : DL MODE ERROR INFO : Unknown reason : Check cable and battery! Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Reset Settings/Format FS [ v2.32 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM16) MODE : BOOTROM PORT : 16 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 7B62DE297245429320015D9EE58C1D0F BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 593B3A9123618A27A6C921A8C687D6284A358EE7EC57555BE5829CA8AD9A640E BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_k65v1_64_bsp.bin EMI : CNT : 0009 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: CID : 90014A68423861503E03241694163797 EMMC: VEN : HYNIX : OEM : 74 : ID : 68423861503E EMMC: VEN : HYNIX : hB8aP> EMMC: SNN : 605459478 ( 0x24169416) , MF : 3/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 7DC88E73297CB42CF317FFFF9B17BAD8 DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x835757 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : CACHE Format Ok : USERDATA Format Ok : USERDATA Done! Elapsed: 00:00:38 Reconnect Power/Cable! |
12-25-2021, 08:30 | #69109 (permalink) |
Registered User Join Date: Aug 2016 Location: Multan Pakistan
Member: 2608490 Status: Offline Thanks Meter: 921 | Vivo Y53S Pattern / Password / FRP Locks Reset Only 1 Click By CM2 SMART RESET Code: Operation : Reset Settings/Format FS [ v2.32 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM4) MODE : PRELOADER PORT PORT : 4 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Talbot TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6768 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : Reset Interface! PTFN : MediaTek USB Port_V1632 (COM3) MODE : BOOTROM PORT : 3 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Talbot TYPE : MODERN [RAPHAEL] BROM : MEID : 0A13CD02AF235D86390DBDD1FFC8E3C7 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : CEBEBABF6FE0A69728111B18DBD5C8C07CEA1A739F0774B3B13AFDDA6ABB7669 BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6768 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_k69v1_64.bin EMI : CNT : 000B EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00070000 [ 448.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: CID : 13014E47314331324C101254FC844873 EMMC: VEN : MICRON : OEM : 78 : ID : 47314331324C EMMC: VEN : MICRON : G1C12L EMMC: SNN : 307559556 ( 0x1254FC84) , MF : 4/2021 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x1D1F000000 [ 116.48 GB ] CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0001 , EVOL : 0x0000 RNID : 7291CA8B17D5B70EBC45422622AA705E DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x835657 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : CACHE Format Ok : USERDATA Format Ok : USERDATA Done! Elapsed: 00:00:48 Reconnect Power/Cable! Code: Operation : Read Firmware [ v2.32 ] ExtSparse : Enabled ForceRead : Disabled 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM4) MODE : PRELOADER PORT PORT : 4 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Talbot TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6768 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : Reset Interface! PTFN : MediaTek USB Port_V1632 (COM3) MODE : BOOTROM PORT : 3 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Talbot TYPE : MODERN [RAPHAEL] BROM : MEID : 0A13CD02AF235D86390DBDD1FFC8E3C7 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : CEBEBABF6FE0A69728111B18DBD5C8C07CEA1A739F0774B3B13AFDDA6ABB7669 BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : FF : Look for EMI BROM : FF : EMI found! BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6768 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_k69v1_64.bin EMI : CNT : 000B EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00070000 [ 448.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: CID : 13014E47314331324C101254FC844873 EMMC: VEN : MICRON : OEM : 78 : ID : 47314331324C EMMC: VEN : MICRON : G1C12L EMMC: SNN : 307559556 ( 0x1254FC84) , MF : 4/2021 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x1D1F000000 [ 116.48 GB ] CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0001 , EVOL : 0x0000 RNID : 7291CA8B17D5B70EBC45422622AA705E DA : USB : HIGH-SPEED Boot done! Product Brand : vivo Product Device : 2058 Product Model : V2058 Product Name : 2058N Patch Level : RP1A.200720.012 Display ID : RP1A.200720.012 release-keys Product Info : k69v1_64 Ver. CodeName : REL Ver. Release : 11 Sec. Patch : 2021-11-01 Build Time : 01.12.2021 Product Board : k69v1_64 Board Platform : mt6768 Product Manfct : vivo MT6768__vivo__V2058__11__RP1A.200720.012__k69v1_64 Read : preloader.bin Read : recovery.img Read : vbmeta.img Read : vbmeta_system.img Read : backup.img Read : reserved.img Read : vbmeta_oem.img Read : vbmeta_vgc.img Read : storage.img Read : persist.img ExtSparse : Compression ratio : 99% Read : proinfo.img Read : efuse.img Read : nvram.bin Read : logo.bin Read : md1rom.img Read : spmfw.img Read : tinysys-scp.bin Read : sspm.img Read : gz.img Read : lk.bin Read : boot.img Read : dtbo.img Read : tz.img Read : super.img ExtSparse : Compression ratio : 45% Read : cache.img Read : userdata.img FW Size : 5.89 GB Android Info saved : _Android_info.txt Scatter : MT6768_Android_scatter.txt Saved to : C:\Users\AR\Desktop\vivo\MT6768__vivo__V2058__11__RP1A.200720.012__k69v1_64\ Done! Elapsed: 00:13:59 |
12-25-2021, 08:39 | #69110 (permalink) |
Member: 2608490 Status: Offline Thanks Meter: 921 | Tecno Spark 4 KC2 Pattern / Password / FRP Removed in 1 Click By CM2 Identify [ v2.32 ] Code: Operation : Identify [ v2.32 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM5) MODE : PRELOADER PORT PORT : 5 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 CODE : Merlot TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : Reset Interface! PTFN : MediaTek USB Port_V1632 (COM6) MODE : BOOTROM PORT : 6 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 CODE : Merlot TYPE : MODERN [RAPHAEL] BROM : MEID : E3EC05B69314C0263DFAEB15A18847C3 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 77726B6BD4A3AA87D5EF95BAB1B021A18A79055365F333D74E3D90B5DA501982 BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : FF : Look for EMI BROM : FF : EMI found! BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_kc2_h6113.bin EMI : CNT : 000D EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A400 [ 233.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: CID : 150100474436424D4201944007F3A60F EMMC: VEN : SAMSUNG : OEM : 0 : ID : 474436424D42 EMMC: VEN : SAMSUNG : GD6BMB EMMC: SNN : 2487224307 ( 0x944007F3) , MF : 10/2019 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 2E01A36DDACE754C2C54246391607F7 DA : USB : HIGH-SPEED Boot done! Patch Level : PPR1.180610.011 Display ID : KC2-H6113AI-P-200827V278 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2020-09-05 Build Time : 27.08.2020 Product Model : TECNO KC2 Product Brand : TECNO Product Name : H6113 Product Device : TECNO-KC2 Product Manfct : TECNO MOBILE LIMITED Product Info : kc2_h6113 Product Board : TECNO-KC2 Board Platform : mt6761 USERDATA : FILESYSTEM : F2FS with FDE ( Full Disk Encryption **) NVRAM : TK_MD_BASIC_MDBIN_PCB01_MT6761_S00.MOLY_LR12A_R3_MP_V66_11_P30 NVRAM : 0xA2101992 NVRAM : State : Ok! INFO : WiFi MAC : AA0036004400 INFO : BlTh MAC : F03D03F0A4C7 INFO : IMEI[1] : 3590xxxxxxxxxxxx INFO : IMEI[2] : 3590xxxxxxxxxxxx STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : UNLOCKED! STORAGE : RPMB Status : eMMC : RPMB KEY NOT PROGRAMMED [USABLE] Done! Elapsed: 00:00:43 Code: Operation : Reset Settings/Format FS [ v2.32 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM5) MODE : PRELOADER PORT PORT : 5 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 CODE : Merlot TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : Reset Interface! PTFN : MediaTek USB Port_V1632 (COM6) MODE : BOOTROM PORT : 6 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 CODE : Merlot TYPE : MODERN [RAPHAEL] BROM : MEID : E3EC05B69314C0263DFAEB15A18847C3 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 77726B6BD4A3AA87D5EF95BAB1B021A18A79055365F333D74E3D90B5DA501982 BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_kc2_h6113.bin EMI : CNT : 000D EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A400 [ 233.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: CID : 150100474436424D4201944007F3A60F EMMC: VEN : SAMSUNG : OEM : 0 : ID : 474436424D42 EMMC: VEN : SAMSUNG : GD6BMB EMMC: SNN : 2487224307 ( 0x944007F3) , MF : 10/2019 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 2E01A36DDACE754C2C54246391607F7 DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x815657 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : CACHE Format Ok : USERDATA Done! Elapsed: 00:05:06 Reconnect Power/Cable! |
12-25-2021, 08:42 | #69111 (permalink) |
Member: 2608490 Status: Offline Thanks Meter: 921 | Infinix HOT 8 Lite (X650) Reset Settings/Format FS CM2 Code: Operation : Reset Settings/Format FS [ v2.32 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM5) MODE : PRELOADER PORT PORT : 5 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY [MTK] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x01 BROM : PRELOADER PORT AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : Reset Interface! PTFN : MediaTek USB Port_V1632 (COM6) MODE : BOOTROM PORT : 6 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY [MTK] BROM : MEID : 54CD0F50D33AA18F284247494CA57072 BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : FF : Look for EMI BROM : FF : EMI found! BROM : SLA : Auth Passed! BROM : SEC : 0x00000001 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 510001154D33364427D001427B965BD4 DAInf: 4 : 2 : 156 DA : EXT_RAM NOT initialized! eMMC : OK eMMC : 150100514436334D4201D027D45B967B NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 DRAM : 0x0178 EMI : DEV : FireFly EMI : SRC : preloader_x650_h8029.bin EMI : CNT : 0007 EMI : [00] : ID : 150100514536334D42 : VEN : SAMSUNG | DEV : QE63MB : RAM : [ 0 B ] EMI : [01] : ID : 150100464536324D42 : VEN : SAMSUNG | DEV : FE62MB : RAM : [ 0 B ] EMI : [02] : ID : 90014A484247346132 : VEN : HYNIX | DEV : HBG4a2 : RAM : [ 2.00 GB ] EMI : [03] : ID : 700100464D41454538 : VEN : KINGSTON | DEV : FMAEE8 : RAM : [ 1.00 GB ] EMI : [04] : ID : 700100464D42434541 : VEN : KINGSTON | DEV : FMBCEA : RAM : [ 0 B ] EMI : [05] : ID : 90014A68423861503E : VEN : HYNIX | DEV : hB8aP> : RAM : [ 0 B ] EMI : [06] : ID : 150100514436334D42 : VEN : SAMSUNG | DEV : QD63MB : RAM : [ 0 B ] EMI : Init EMI from PRELOADER INIT : 0xBC : DRAM [ 0x00000000 : [ 0 B ] ] DRAM : DRAM: 0x80000000 [ 2.00 GB ] DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: CID : 150100514436334D4201D027D45B967B EMMC: VEN : SAMSUNG : OEM : 0 : ID : 514436334D42 EMMC: VEN : SAMSUNG : QD63MB EMMC: SNN : 3492271195 ( 0xD027D45B) , MF : 9/2019 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 6014DE194C6E7266881EF420FE7CABBF STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : FULL-SPEED DA : USB : Change Port Speed PTFN : MediaTek DA USB VCOM (Android) (COM138) MODE : PRELOADER PORT PORT : 138 Boot done! SmartInfo : 0x805657 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : CACHE Format Ok : USERDATA Done! Elapsed: 00:00:52 Reconnect Power/Cable! |
12-25-2021, 09:03 | #69112 (permalink) |
No Life Poster Join Date: Aug 2020 Location: Mozambique Age: 20
Member: 2965136 Status: Offline Sonork: 58846 Thanks Meter: 1,202 | Itel L5006s Network Unlock Done Code: Card found : 46828B86 , v0151 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14 Load IDBase v8331 Ok! Operation : Identify [ v2.14 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : MANUAL LDR Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! FDL : Process authentification ... FDL : SEC : RSA auth passed! FDL : Control transfered! Boot Done! Device info : Product Brand : Itel Product Device : L5006S Product Model : itel L5006S Product Name : L5006S Patch Level : QP1A.190711.020 Display ID : L5006S-F3212MZ-10.0-MZ-Vodacom-V014-20210901 Ver. Incmt : MZ-Vodacom-V014-20210901 Ver. CodeName : REL Ver. Release : 10 Sec. Patch : 2021-09-05 Build Time : 01.09.2021 Product Name : F3212MZ Product Device : itel-L5006S Product Info : L5006S Product Board : L5006S Board Platform : sp9832e Product Manfct : itel NVMng : SecurityInfo IMEI[1] : 357068261760769 IMEI[2] : 354648020000004 IMEI[3] : 867400020316638 WIFIMAC : FFFFFFFFFFFF BT_MAC : FFFFFFFFFFFF SEC : SLS:0, SKS:0, SKV:4 Platform Version: MOCORTM_18A_W20.23.2_P8_Debug Project Version: sharkle_Smart_Phone BASE Version: FM_BASE_18A_W20.23.2_P8 HW Version: sc9832e_modem CMP_Time : 12-29-2020 18:41:45 MODEM TAG : MOCORTM_18A_W20.23.2_P8_Debug_FM_BASE_18A_W20.23.2_P8_sc9832e_modem_sharkle_Smart_Phone USERDATA : FILESYSTEM : F2FS with FDE ( Full Disk Encryption ***) - > INFO : Remove cable from device to switch it off! Done! Elapsed: 00:00:31 Code: Operation : SP Unlock [ v2.14 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : MANUAL LDR Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! FDL : Process authentification ... FDL : SEC : RSA auth passed! FDL : Control transfered! Boot Done! NVMng : SecurityInfo IMEI[1] : 357068261760769 IMEI[2] : 354648020000004 IMEI[3] : 867400020316638 WIFIMAC : FFFFFFFFFFFF BT_MAC : FFFFFFFFFFFF SEC : SLS:0, SKS:0, SKV:4 SLStatus : 31 Unlocking device ... Sync data ... Device unlocked! Done! Elapsed: 00:00:21 |
The Following 3 Users Say Thank You to tayobjoy1 For This Useful Post: |
12-25-2021, 09:46 | #69113 (permalink) |
Member: 2965136 Status: Offline Sonork: 58846 Thanks Meter: 1,202 | Itel A23 Pro Network Unlock Done Code: Card found : 46828B86 , v0151 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.11 Load IDBase v8331 Ok! Operation : Identify [ v2.11 ] BootMode : SVC 1. Power off device, wait 10-15 seconds 2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! SOC GEN : UniSoc ( E-family and Modern ) BuildInfo : L5006S-F3212MZ-10.0-MZ-Vodacom-V014-20210901 MemoryInfo : EMMC : 16 GB ; DRAM : 1 GB Platform Version: MOCORTM_18A_W20.23.2_P8_Debug Project Version: sharkle_Smart_Phone BASE Version: FM_BASE_18A_W20.23.2_P8 HW Version: sc9832e_modem CMP_Time : 12-29-2020 18:41:45 MODEM TAG : MOCORTM_18A_W20.23.2_P8_Debug_FM_BASE_18A_W20.23.2_P8_sc9832e_modem_sharkle_Smart_Phone PSN1 : 06745351AJ004375 NVMng : SecurityInfo IMEI[1] : 357068261586537 IMEI[2] : 354648020000004 WIFIMAC : 282A879A95A2 BT_MAC : 282A879A95A1 SEC : SLS:0, SKS:0, SKV:4 Done! Elapsed: 00:00:13 Code: Operation : SP Unlock [ v2.11 ] BootMode : SVC 1. Power off device, wait 10-15 seconds 2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! SOC GEN : UniSoc ( E-family and Modern ) BuildInfo : L5006S-F3212MZ-10.0-MZ-Vodacom-V014-20210901 Platform Version: MOCORTM_18A_W20.23.2_P8_Debug Project Version: sharkle_Smart_Phone BASE Version: FM_BASE_18A_W20.23.2_P8 HW Version: sc9832e_modem CMP_Time : 12-29-2020 18:41:45 MODEM TAG : MOCORTM_18A_W20.23.2_P8_Debug_FM_BASE_18A_W20.23.2_P8_sc9832e_modem_sharkle_Smart_Phone NVMng : SecurityInfo IMEI[1] : 357068261586537 IMEI[2] : 354648020000004 WIFIMAC : 282A879A95A2 BT_MAC : 282A879A95A1 SEC : SLS:0, SKS:0, SKV:4 SLStatus : 31 Unlocking device ... Sync data ... Device unlocked! Done! Elapsed: 00:00:19 |
The Following 2 Users Say Thank You to tayobjoy1 For This Useful Post: |
12-25-2021, 09:56 | #69114 (permalink) |
No Life Poster Join Date: Mar 2015 Location: Islam Age: 35
Member: 2371500 Status: Offline Thanks Meter: 5,806 | SQ 7700 SC6531E SPD network issue fix and read flash done original poster dahmani medl DZGSM Code: Operation : Read Flash [ v1.07 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR 6531EFM v2.0 (c)2019 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [GIGADEVICE] : GD25Q32 : 0x00400000 [ 4MiB ] Read Flash Ok, Size : 4,00 MiB Platform Version: MOCOR_16A.W17.43.4_Release Project Version: SC6531EFM_BAR MMI Version: HY220_FYK_Z47_V03_20180702 BASE Version: BASE_SVN HW Version: SC6531EFM_BAR 2018-07-02 13:39:04 LOG Version: V1.0.1 Saved to : D:\HY220_FYK_Z47_V03_2018 Operation : Write NVM [ v1.07 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR 6531EFM v2.0 (c)2019 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [GIGADEVICE] : GD25Q32 : 0x00400000 [ 4MiB ] Restoring NVM ... NVM restored! |
The Following 3 Users Say Thank You to profkefah For This Useful Post: |
12-25-2021, 11:01 | #69115 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | iPhone 12 Pro Max Format Code: Brand : Apple ProdName : iPhone ProdModel : Pro_Max12 Device : iPhone 12 Pro Max AndroidVer: 6.0 MTKxCPU : MT6580 MTKxPRJ : alps-mp-m0.mp1-V2.34_hct6580.weg.c.m_P147 Done! Elapsed: 00:00:19 Reconnect Power/Cable! Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 33 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 90014A48414732650507559955DA4343 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e2GA [eMMC] : FLASH_CID : 90014A48414732650507559955DA4343 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003AB800000 [eMMC] : FLASH_UCP : 15032 MiB [eMMC 16 GiB] DEV RID : 0xD5229C2569A0A8411AE84401C52A0578 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:47 Reconnect Power/Cable! |
12-25-2021, 11:04 | #69116 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Infinix-X650 Frp Code: Patch Level : O11019 Display ID : X650-H8029AB-OGo-200529V345 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2020-06-05 Build Time : 29.05.2020 Product Brand : Infinix Product Name : H8029 Product Device : Infinix-X650 Product Info : Infinix-X650 Product Model : Infinix X650 Product Manfct : INFINIX MOBILITY LIMITED Product Board : Infinix-X650 Board Platform : mt6580 USERDATA : FILESYSTEM : F2FS with FDE ( Full Disk Encryption ***) NVRAM : 0x770297DE NVRAM : State : Ok! INFO : WiFi MAC : AA0037003600 INFO : BlTh MAC : 80795D0D8330 INFO : IMEI[1] : INFO : IMEI[2] : Done! Elapsed: 00:00:31 Operation : Reset Settings/Format FS [ v2.28 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MTK USB Port (COM9) MODE : BOOTROM PORT : 9 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY [MTK] BROM : MEID : 19F33129C196690ECDE60DD32C1C179E BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x000000FE BROM : PreBoot stage #1 BROM : PreBoot stage #2 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 684A0190506138429096033EA9C6F912 DAInf: 4 : 2 : 156 DA : EXT_RAM NOT initialized! eMMC : OK eMMC : 90014A68423861503E03969012F9C6A9 NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 DRAM : 0x0178 EMI : DEV : FireFly EMI : SRC : preloader_x650_h8029.bin EMI : CNT : 0007 EMI : [00] : ID : 150100514536334D42 : VEN : SAMSUNG | DEV : QE63MB : RAM : [ 0 B ] EMI : [01] : ID : 150100464536324D42 : VEN : SAMSUNG | DEV : FE62MB : RAM : [ 0 B ] EMI : [02] : ID : 90014A484247346132 : VEN : HYNIX | DEV : HBG4a2 : RAM : [ 2.00 GB ] EMI : [03] : ID : 700100464D41454538 : VEN : KINGSTON | DEV : FMAEE8 : RAM : [ 1.00 GB ] EMI : [04] : ID : 700100464D42434541 : VEN : KINGSTON | DEV : FMBCEA : RAM : [ 0 B ] EMI : [05] : ID : 90014A68423861503E : VEN : HYNIX | DEV : hB8aP> : RAM : [ 0 B ] EMI : [06] : ID : 150100514436334D42 : VEN : SAMSUNG | DEV : QD63MB : RAM : [ 0 B ] EMI : Init EMI from PRELOADER INIT : 0xBC : DRAM [ 0x00000000 : [ 0 B ] ] DRAM : DRAM: 0x80000000 [ 2.00 GB ] DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: CID : 90014A68423861503E03969012F9C6A9 EMMC: VEN : HYNIX : OEM : 74 : ID : 68423861503E EMMC: VEN : HYNIX : hB8aP> EMMC: SNN : 2526024441 ( 0x969012F9) , MF : 12/2019 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 9D60FE6924355C2C448FF187BA0014C6 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : FULL-SPEED DA : USB : Change Port Speed PTFN : MediaTek DA USB VCOM (Android) (COM38) MODE : PRELOADER PORT PORT : 38 Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:26 Reconnect Power/Cable! |
12-25-2021, 11:05 | #69117 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | GFive Fire Format Code: Operation : Format FileSystem [ v1.07 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR 6531EFM v2.0 (c)2019 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ] Make backup of sensetive data Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_11728F000C8F_NVM.nv Executing FormatFFS ... Format FFS Done! Done! Elapsed: 00:01:00 Reconnect Power/Cable! |
12-25-2021, 11:06 | #69118 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Infinix X663 Format & Frp Code: Product Brand : Infinix Product Device : Infinix-X663 Product Model : Infinix X663 Product Name : X663-GL Patch Level : RP1A.200720.011 Display ID : X663-H6915ABCEFG-R-GL-211102V427 Ver. CodeName : REL Ver. Release : 11 Sec. Patch : 2021-09-05 Build Time : 02.11.2021 Product Info : x663_h6915 Product Board : Infinix-X663 Board Platform : mt6768 Product Manfct : INFINIX MOBILITY LIMITED USERDATA : FILESYSTEM : F2FS with FBE ( File-Base Encryption ) NVRAM : 0xB80AC92A NVRAM : State : Ok! INFO : WiFi MAC : 305696E2391F INFO : BlTh MAC : 305696E2391E INFO : IMEI[1] : INFO : IMEI[2] : STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : UNLOCKED! Done! Elapsed: 00:00:30 Operation : Reset Settings/Format FS [ v2.28 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM26) MODE : BOOTROM PORT : 26 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Talbot TYPE : MODERN [RAPHAEL] BROM : MEID : 2E0AC074E87EC9D9C70B1481F6BDC8CF BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 604D54825914545AFB235F6EEDA49CC89B64B24611DE1800566D639B575D7307 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F BROM : PreBoot stage #1 BROM : PreBoot stage #2 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6768 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_x663_h691 EMI : CNT : 000F EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00070000 [ 448.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: CID : 15010044563644414202BB8DE43D78E3 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 445636444142 EMMC: VEN : SAMSUNG : DV6DAB EMMC: SNN : 3146638397 ( 0xBB8DE43D) , MF : 7/2021 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x1D1EC00000 [ 116.48 GB ] CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0001 , EVOL : 0x0000 RNID : 13FD0E72964AD6D4FCFCE9DDC84847DC DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x835657 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : USERDATA Done! Elapsed: 00:00:34 Reconnect Power/Cable! |
12-25-2021, 11:07 | #69119 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Spice S105 Format Code: Operation : Format FileSystem [ v1.07 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Spreadtrum Boot Block version 1.2 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [GIGADEVICE] : GD25Q32 : 0x00400000 [ 4MiB ] Make backup of sensetive data Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_0E9473DEDC7A_NVM.nv Executing FormatFFS ... Format FFS Done! Done! Elapsed: 00:00:22 Reconnect Power/Cable! |
12-25-2021, 11:08 | #69120 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | OPPO CPH1909 Format & Frp Code: Patch Level : O11019 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2021-04-05 Product Manfct : OPPO Build Time : 19.03.2021 Product Brand : OPPO Product Model : CPH1909 Product Info : CPH1909 Product Device : CPH1909 Product Name : CPH1909 SW OTA Version : CPH1909EX_11.A.46_0460_202103191930 Display ID : CPH1909EX_11_A.46 Kernel Info : 4.9.77 USERDATA : FILESYSTEM : EXT4 with FDE ( Full Disk Encryption *) NVRAM : OPPO6765_18511_MDBIN_PCB01_MT6765_S00.MOLY_LR12A_R2_TC16_SP_V50_5_P97 NVRAM : 0xBC0ACB13 NVRAM : State : Ok! INFO : WiFi MAC : AA0037003600 INFO : BlTh MAC : 9CF5314F832E STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : UNLOCKED! Done! Elapsed: 00:00:32 Operation : Reset Settings/Format FS [ v2.28 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MTK USB Port (COM9) MODE : BOOTROM PORT : 9 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : F7895C6B560CCAFB8A9A5BFAB577144F BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 6933E1D0F7C5A8AFF5D4D57B58265C90F36D2EDB97F683979015DF399BDD1E38 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F BROM : PreBoot stage #1 BROM : PreBoot stage #2 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_oppo6765_18511.bin EMI : CNT : 0009 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: CID : 150100514436334D4203F8EC9A8BA687 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 514436334D42 EMMC: VEN : SAMSUNG : QD63MB EMMC: SNN : 4176255627 ( 0xF8EC9A8B) , MF : 10/2019 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : FB99E6791BD7EBFCF3BD7F21D6F03C4C DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x805757 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : CACHE Format Ok : USERDATA Done! Elapsed: 00:00:42 Reconnect Power/Cable! |
