02-13-2022, 22:44 | #69856 (permalink) |
Freak Poster Join Date: Nov 2011 Location: france
Member: 1690056 Status: Offline Thanks Meter: 103 | Doogee N30 frp done by cm2 Card found : 7E499B65 , v0151 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.31 Load IDBase v1121431 Ok! UserName and/or Password not set! Can't continue! Load IDBase v1121431 Ok! Operation : Reset Settings/Format FS [ v2.31 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM28) MODE : BOOTROM PORT : 28 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 8719DB0A1E4F7FD6EA4997CF67FD632E BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 10B31F41B81C8BFE95732CB0365BFA86F8E98CA8EDBCCA8D78 A22A2F08262114 BROM : Sending FireFly FireFly : Starting ... FireFly : Init Core FireFly : Core init done! FireFly : Running : v04.04.04 on MT6765 FireFly : eMMC init passed! EMMC: CSD : D05F01328F5913FFFFFFFFEF964000A9 EMMC: CSD : TEMP_WRITE_PROTECT: False EMMC: CSD : PERM_WRITE_PROTECT: False EMMC: CID : 13014E53304A394B3910003600DF7551 EMMC: VEN : MICRON : OEM : 78 : ID : 53304A394B39 EMMC: VEN : MICRON : S0J9K9 EMMC: SNN : 3539167 ( 0x003600DF) , MF : 7/2018 EMMC: EXTCSD : rev1.8 ( eMMC 5.1 ) EMMC: EXTCSD [BOOT_BUS_WIDTH] : 0x02 EMMC: EXTCSD [PARTITION_CONFIG] : 0x48 EMMC: EXTCSD [SIZE] : Market : 128 GB EMMC: EXTCSD [SIZE] : Actual : 0x1D1F000000 [ 116.48 GB ] EMMC: EXTCSD [EOL] : EOL status : Normal ( Less than 80% reserved blocks used ) EMMC: EXTCSD [EOL_A] : SLC status : 0% - 10% used EMMC: EXTCSD [EOL_B] : MLC status : 0% - 10% used EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] USER : 0x1D1F000000 [ 116.48 GB ] DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:14 Reconnect Power/Cable! |
The Following User Says Thank You to soltacom For This Useful Post: |
02-13-2022, 23:32 | #69857 (permalink) |
Freak Poster Join Date: Aug 2006 Location: gabon, oyem
Member: 327704 Status: Offline Thanks Meter: 84 | samsung A03s frp A037F Select FireFly mode in Platform settings ! and Mode: SMART RESET EXTRA. other not work after operation you will get system corrupt. just format and it will be ok Operation : Identify [ v2.33 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM19) MODE : PRELOADER PORT PORT : 19 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT PTFN : MediaTek USB Port (COM21) MODE : BOOTROM PORT : 21 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 56908B9B91BDB76BC70CDA5B44317B12 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : A01C13E67C981FF7A29DFAABC0259FAF1AA2516041BAC32252 C9D106A133D7D6 BROM : Sending FireFly FireFly : Starting ... FireFly : Init Core FireFly : Core init done! FireFly : Running : v05.05.05 on MT6765 FireFly : eMMC init passed! EMMC: CSD : D02701320F5903FFF6DBFFEF8E40400D EMMC: CSD : TEMP_WRITE_PROTECT: False EMMC: CSD : PERM_WRITE_PROTECT: False EMMC: CID : 150100475836424142009E9506D8585F EMMC: VEN : SAMSUNG : OEM : 0 : ID : 475836424142 : PRV : 0x00 EMMC: VEN : SAMSUNG : GX6BAB EMMC: SNN : 2660566744 ( 0x9E9506D8 ) , MF : 5/2021 EMMC: EXTCSD : rev1.8 ( eMMC 5.1 ) EMMC: EXTCSD [CONFIG] : 0x48, 0x02, 0x01 EMMC: EXTCSD [PARTITION_CONFIG] : 0x48 EMMC: EXTCSD [BOOT_BUS_WIDTH] : 0x02 EMMC: EXTCSD [RST_N_FUNCTION] : 0x01 EMMC: EXTCSD [PART_S_COMPLETED] : False EMMC: EXTCSD [SIZE] : Market : 32 GB EMMC: EXTCSD [SIZE] : Actual : 0x747C00000 [ 29,12 GB ] EMMC: EXTCSD [EOL] : EOL status : Normal ( Less than 80% reserved blocks used ) EMMC: EXTCSD [EOL_A] : SLC status : 0% - 10% used EMMC: EXTCSD [EOL_B] : MLC status : 0% - 10% used EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] USER : 0x747C00000 [ 29,12 GB ] DA : USB : HIGH-SPEED Boot done! Product Brand : samsung Product Device : a03s Product Model : SM-A037F Product Name : a03snnxx Patch Level : RP1A.200720.012 Display ID : RP1A.200720.012.A037FXXU1AUGA Build Time : 26.07.2021 Ver. CodeName : REL Ver. Release : 11 Sec. Patch : 2021-08-01 Product Info : a03s Product Board : hs03s Board Platform : mt6765 Product Manfct : samsung NVRAM : TITAN_A03S_R0MP1_K65V1_64_BSP_MDBIN_PCB01_MT6765_S 00.MOLY_LR12A_R3_TC10_6M_A03S_GBL_PR_SP_V1_P2 NVRAM : 0xBE0ACBD8 NVRAM : State : Ok! INFO : WiFi MAC : 6C2F8A50D187 INFO : BlTh MAC : 6C2F8A50D186 INFO : IMEI[1] : 3BCC1BAB5CA5DB4 INFO : IMEI[2] : C213A6856E2C076 Backup sensetive data [ 18 ] Backup path : Backup\MT6765__56908B9B91BDB76BC70CDA5B44317B12\ [5] Read : NVRAM [26] Read : NVDATA [32] Read : PROINFO [12] Read : LK [25] Read : NVCFG [16] Read : PROTECT1 [1] Read : PGPT [37] Read : PERSIST [0] Read : PRELOADER [2] Read : EFS [3] Read : SEC_EFS [31] Read : PERSISTENT Backup done! PRELOADER : DEVICE : DEV : MT6765 NME : preloader_hs03s.bin CNT : 0008 EMI : [00] : eMMC : DDR3 : ID : 90014A484247346132 : VEN : HYNIX | DEV : HBG4a2 : RAM : [ 3,00 GB ] EMI : [01] : eMMC : DDR3 : ID : 90014A68423861503E : VEN : HYNIX | DEV : hB8aP> : RAM : [ 3,00 GB ] EMI : [02] : eMMC : DDR3 : ID : 90014A484147346132 : VEN : HYNIX | DEV : HAG4a2 : RAM : [ 2,00 GB ] EMI : [03] : eMMC : DDR3 : ID : 150100475836424142 : VEN : SAMSUNG | DEV : GX6BAB : RAM : [ 3,00 GB ] EMI : [04] : eMMC : DDR3 : ID : 150100475836424D42 : VEN : SAMSUNG | DEV : GX6BMB : RAM : [ 3,00 GB ] EMI : [05] : eMMC : DDR3 : ID : 150100514436334D42 : VEN : SAMSUNG | DEV : QD63MB : RAM : [ 2,00 GB ] EMI : [06] : eMMC : DDR3 : ID : 150100515836334D42 : VEN : SAMSUNG | DEV : QX63MB : RAM : [ 2,00 GB ] EMI : [07] : eMMC : DDR3 : ID : 150100525036344D42 : VEN : SAMSUNG | DEV : RP64MB : RAM : [ 4,00 GB ] PRELOADER saved to : Backup\PRELOADER\preloader_hs03s.bin Done! Elapsed: 00:04:57 Operation : Reset Settings/Format FS [ v2.33 ] Mode : SMART RESET EXTRA 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM19) MODE : PRELOADER PORT PORT : 19 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT PTFN : MediaTek USB Port (COM21) MODE : BOOTROM PORT : 21 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 56908B9B91BDB76BC70CDA5B44317B12 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : A01C13E67C981FF7A29DFAABC0259FAF1AA2516041BAC32252 C9D106A133D7D6 BROM : Sending FireFly FireFly : Starting ... FireFly : Init Core FireFly : Core init done! FireFly : Running : v05.05.05 on MT6765 FireFly : eMMC init passed! EMMC: CSD : D02701320F5903FFF6DBFFEF8E40400D EMMC: CSD : TEMP_WRITE_PROTECT: False EMMC: CSD : PERM_WRITE_PROTECT: False EMMC: CID : 150100475836424142009E9506D8585F EMMC: VEN : SAMSUNG : OEM : 0 : ID : 475836424142 : PRV : 0x00 EMMC: VEN : SAMSUNG : GX6BAB EMMC: SNN : 2660566744 ( 0x9E9506D8 ) , MF : 5/2021 EMMC: EXTCSD : rev1.8 ( eMMC 5.1 ) EMMC: EXTCSD [CONFIG] : 0x48, 0x02, 0x01 EMMC: EXTCSD [PARTITION_CONFIG] : 0x48 EMMC: EXTCSD [BOOT_BUS_WIDTH] : 0x02 EMMC: EXTCSD [RST_N_FUNCTION] : 0x01 EMMC: EXTCSD [PART_S_COMPLETED] : False EMMC: EXTCSD [SIZE] : Market : 32 GB EMMC: EXTCSD [SIZE] : Actual : 0x747C00000 [ 29,12 GB ] EMMC: EXTCSD [EOL] : EOL status : Normal ( Less than 80% reserved blocks used ) EMMC: EXTCSD [EOL_A] : SLC status : 0% - 10% used EMMC: EXTCSD [EOL_B] : MLC status : 0% - 10% used EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] USER : 0x747C00000 [ 29,12 GB ] DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x835757 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : CACHE Format Ok : USERDATA Format Ok : USERDATA Format Ok : Vendor Extra Done! Elapsed: 00:01:32 Reconnect Power/Cable! |
02-13-2022, 23:33 | #69858 (permalink) |
Member: 327704 Status: Offline Thanks Meter: 84 | samsung A03s frp A037F samsung A03s frp A037F Select FireFly mode in Platform settings ! and Mode: SMART RESET EXTRA. other not work after the operation you will get system corrupt. just format and it will be ok Operation : Identify [ v2.33 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM19) MODE : PRELOADER PORT PORT : 19 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT PTFN : MediaTek USB Port (COM21) MODE : BOOTROM PORT : 21 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 56908B9B91BDB76BC70CDA5B44317B12 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : A01C13E67C981FF7A29DFAABC0259FAF1AA2516041BAC32252 C9D106A133D7D6 BROM : Sending FireFly FireFly : Starting ... FireFly : Init Core FireFly : Core init done! FireFly : Running : v05.05.05 on MT6765 FireFly : eMMC init passed! EMMC: CSD : D02701320F5903FFF6DBFFEF8E40400D EMMC: CSD : TEMP_WRITE_PROTECT: False EMMC: CSD : PERM_WRITE_PROTECT: False EMMC: CID : 150100475836424142009E9506D8585F EMMC: VEN : SAMSUNG : OEM : 0 : ID : 475836424142 : PRV : 0x00 EMMC: VEN : SAMSUNG : GX6BAB EMMC: SNN : 2660566744 ( 0x9E9506D8 ) , MF : 5/2021 EMMC: EXTCSD : rev1.8 ( eMMC 5.1 ) EMMC: EXTCSD [CONFIG] : 0x48, 0x02, 0x01 EMMC: EXTCSD [PARTITION_CONFIG] : 0x48 EMMC: EXTCSD [BOOT_BUS_WIDTH] : 0x02 EMMC: EXTCSD [RST_N_FUNCTION] : 0x01 EMMC: EXTCSD [PART_S_COMPLETED] : False EMMC: EXTCSD [SIZE] : Market : 32 GB EMMC: EXTCSD [SIZE] : Actual : 0x747C00000 [ 29,12 GB ] EMMC: EXTCSD [EOL] : EOL status : Normal ( Less than 80% reserved blocks used ) EMMC: EXTCSD [EOL_A] : SLC status : 0% - 10% used EMMC: EXTCSD [EOL_B] : MLC status : 0% - 10% used EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] USER : 0x747C00000 [ 29,12 GB ] DA : USB : HIGH-SPEED Boot done! Product Brand : samsung Product Device : a03s Product Model : SM-A037F Product Name : a03snnxx Patch Level : RP1A.200720.012 Display ID : RP1A.200720.012.A037FXXU1AUGA Build Time : 26.07.2021 Ver. CodeName : REL Ver. Release : 11 Sec. Patch : 2021-08-01 Product Info : a03s Product Board : hs03s Board Platform : mt6765 Product Manfct : samsung NVRAM : TITAN_A03S_R0MP1_K65V1_64_BSP_MDBIN_PCB01_MT6765_S 00.MOLY_LR12A_R3_TC10_6M_A03S_GBL_PR_SP_V1_P2 NVRAM : 0xBE0ACBD8 NVRAM : State : Ok! INFO : WiFi MAC : 6C2F8A50D187 INFO : BlTh MAC : 6C2F8A50D186 INFO : IMEI[1] : 3BCC1BAB5CA5DB4 INFO : IMEI[2] : C213A6856E2C076 Backup sensetive data [ 18 ] Backup path : Backup\MT6765__56908B9B91BDB76BC70CDA5B44317B12\ [5] Read : NVRAM [26] Read : NVDATA [32] Read : PROINFO [12] Read : LK [25] Read : NVCFG [16] Read : PROTECT1 [1] Read : PGPT [37] Read : PERSIST [0] Read : PRELOADER [2] Read : EFS [3] Read : SEC_EFS [31] Read : PERSISTENT Backup done! PRELOADER : DEVICE : DEV : MT6765 NME : preloader_hs03s.bin CNT : 0008 EMI : [00] : eMMC : DDR3 : ID : 90014A484247346132 : VEN : HYNIX | DEV : HBG4a2 : RAM : [ 3,00 GB ] EMI : [01] : eMMC : DDR3 : ID : 90014A68423861503E : VEN : HYNIX | DEV : hB8aP> : RAM : [ 3,00 GB ] EMI : [02] : eMMC : DDR3 : ID : 90014A484147346132 : VEN : HYNIX | DEV : HAG4a2 : RAM : [ 2,00 GB ] EMI : [03] : eMMC : DDR3 : ID : 150100475836424142 : VEN : SAMSUNG | DEV : GX6BAB : RAM : [ 3,00 GB ] EMI : [04] : eMMC : DDR3 : ID : 150100475836424D42 : VEN : SAMSUNG | DEV : GX6BMB : RAM : [ 3,00 GB ] EMI : [05] : eMMC : DDR3 : ID : 150100514436334D42 : VEN : SAMSUNG | DEV : QD63MB : RAM : [ 2,00 GB ] EMI : [06] : eMMC : DDR3 : ID : 150100515836334D42 : VEN : SAMSUNG | DEV : QX63MB : RAM : [ 2,00 GB ] EMI : [07] : eMMC : DDR3 : ID : 150100525036344D42 : VEN : SAMSUNG | DEV : RP64MB : RAM : [ 4,00 GB ] PRELOADER saved to : Backup\PRELOADER\preloader_hs03s.bin Done! Elapsed: 00:04:57 Operation : Reset Settings/Format FS [ v2.33 ] Mode : SMART RESET EXTRA 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM19) MODE : PRELOADER PORT PORT : 19 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT PTFN : MediaTek USB Port (COM21) MODE : BOOTROM PORT : 21 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 56908B9B91BDB76BC70CDA5B44317B12 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : A01C13E67C981FF7A29DFAABC0259FAF1AA2516041BAC32252 C9D106A133D7D6 BROM : Sending FireFly FireFly : Starting ... FireFly : Init Core FireFly : Core init done! FireFly : Running : v05.05.05 on MT6765 FireFly : eMMC init passed! EMMC: CSD : D02701320F5903FFF6DBFFEF8E40400D EMMC: CSD : TEMP_WRITE_PROTECT: False EMMC: CSD : PERM_WRITE_PROTECT: False EMMC: CID : 150100475836424142009E9506D8585F EMMC: VEN : SAMSUNG : OEM : 0 : ID : 475836424142 : PRV : 0x00 EMMC: VEN : SAMSUNG : GX6BAB EMMC: SNN : 2660566744 ( 0x9E9506D8 ) , MF : 5/2021 EMMC: EXTCSD : rev1.8 ( eMMC 5.1 ) EMMC: EXTCSD [CONFIG] : 0x48, 0x02, 0x01 EMMC: EXTCSD [PARTITION_CONFIG] : 0x48 EMMC: EXTCSD [BOOT_BUS_WIDTH] : 0x02 EMMC: EXTCSD [RST_N_FUNCTION] : 0x01 EMMC: EXTCSD [PART_S_COMPLETED] : False EMMC: EXTCSD [SIZE] : Market : 32 GB EMMC: EXTCSD [SIZE] : Actual : 0x747C00000 [ 29,12 GB ] EMMC: EXTCSD [EOL] : EOL status : Normal ( Less than 80% reserved blocks used ) EMMC: EXTCSD [EOL_A] : SLC status : 0% - 10% used EMMC: EXTCSD [EOL_B] : MLC status : 0% - 10% used EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] USER : 0x747C00000 [ 29,12 GB ] DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x835757 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : CACHE Format Ok : USERDATA Format Ok : USERDATA Format Ok : Vendor Extra Done! Elapsed: 00:01:32 Reconnect Power/Cable! |
02-14-2022, 01:24 | #69859 (permalink) |
No Life Poster Join Date: Dec 2020 Location: ph Age: 48
Member: 2974628 Status: Offline Sonork: 11223344 Thanks Meter: 178 | vivo 1726 vivo Y83 Pro PTFN : MediaTek USB Port_V1632 (COM8) MODE : BOOTROM PORT : 8 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : A274F2BEAF2C826C4055496CF8BA0206 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 00B4694B4BD8F0AF22083F4DCBC92AFE488A036508A18BA549 6752FC809D55E0 BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : FF : Look for EMI BROM : FF : EMI found! BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_k62v1_64_bsp.bin EMI : CNT : 0009 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: CID : 150100524436344D42014B0497691519 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 524436344D42 EMMC: VEN : SAMSUNG : RD64MB EMMC: SNN : 1258592105 ( 0x4B049769) , MF : 1/2018 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 325FB3A8ED8E0A8B60775A436F055635 DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x805757 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : CACHE Format Ok : USERDATA Format Ok : Vendor Extra Done! Elapsed: 00:00:32 Reconnect Power/Cable! |
02-14-2022, 09:15 | #69860 (permalink) |
No Life Poster Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Infinix smart hd reset frp done by cm2 Card found : 73CA70CC , v0152 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.33 Load IDBase v1121431 Ok! Update configuration ... Load IDBase v1121431 Ok! Operation : Reset Settings/Format FS [ v2.33 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM10) MODE : PRELOADER PORT PORT : 10 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 CODE : Merlot TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : Reset Interface! PTFN : MediaTek USB Port (COM6) MODE : BOOTROM PORT : 6 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 CODE : Merlot TYPE : MODERN [RAPHAEL] BROM : MEID : A7579E30CF29FAA18C08689D824E56CC BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 9B9EED0A30B427D45E4B9E674E12E05625563845592662C987 BABAAF5D050B70 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_infinix_x612b.bin EMI : CNT : 0009 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A400 [ 233.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: CID : 150100515836334142033F39BA1AC75F EMMC: VEN : SAMSUNG : OEM : 0 : ID : 515836334142 EMMC: VEN : SAMSUNG : QX63AB EMMC: SNN : 1060747802 ( 0x3F39BA1A) , MF : 12/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 3CB7F27098107097DDAFB6BB9CDA376B DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x825657 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : CACHE Format Ok : USERDATA Format Ok : USERDATA Done! Elapsed: 00:00:43 Reconnect Power/Cable! |
02-14-2022, 09:17 | #69861 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Lg k330 reset frp done by cm2 Card found : 73CA70CC , v0152 Infinity-Box LG Service Tool [ LGS ] v1.03 Operation : Reset Settings/Format FS [ v1.03 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD VOLUME UP KEY! 3. Insert USB cable, wait until Download mode screen will appear Wait for phone... Connection opened successfully! Waiting for loader ... Handshake passed! Collect info... Prepare passed, mode 0x01 Boot done! Format UserData Format Cache Format done Erase sFRP#3 Ok! Reconnect Power/Cable! Done! Elapsed: 00:00:30 |
02-14-2022, 09:18 | #69862 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Vivo y65 reset pattern done by cm2 Card found : 73CA70CC , v0152 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16 Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 425 [MSM8917] ID_BLOCK_S : 90F08057 ID_BLOCK_L : C01F04DF4ACD0240DC1C5CBE5A41F58E ID_BLOCK_L : A9EE649B6999D86968E51B2483093C7E Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8917 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : GE6BMB Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:34 Reconnect Power/Cable! |
02-14-2022, 09:19 | #69863 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Oppo a37 reset frp done by cm2 Card found : 73CA70CC , v0152 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16 Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 410 [MSM8916] ID_BLOCK_S : 2687E70E ID_BLOCK_L : 9B6D07FF5EC4F1FCAB80705D9AE17159 ID_BLOCK_L : 42319F2E23B21CA92C8BCC050FE6F0DB Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:19 Reconnect Power/Cable! |
02-14-2022, 09:20 | #69864 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Lenovo a2020a40 reset frp done by cm2 Card found : 73CA70CC , v0152 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16 Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 210 [MSM8x09] ID_BLOCK_S : 092A35CF ID_BLOCK_L : D42C46B01F8BB0B36CC1331CDBA62E1E ID_BLOCK_L : E19C228D8E11B9CACF2E6358AA455378 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:20 Reconnect Power/Cable! |
02-14-2022, 09:21 | #69865 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Qmobile i6 metal one reset frp done by cm2 Card found : 73CA70CC , v0152 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14 Load IDBase v8331 Ok! Operation : Format FS / Reset Settings [ v2.14 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731x_BASE : SC7731C_eMMC_1GB_NS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:53 |
02-14-2022, 09:22 | #69866 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Qmobile i6 metal 2018 7731e reset frp dome by cm2 Card found : 73CA70CC , v0152 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14 Load IDBase v8331 Ok! Operation : Format FS / Reset Settings [ v2.14 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Sedning Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sedning Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:42 |
02-14-2022, 10:09 | #69867 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile I6i MT6580 FRP/Pattren Reset Done With King Infinity CM2 Code: Card found : S/N : A19EC787 , v0152 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 34 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100464A32374D4202CB20968B23B5 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM72J [eMMC] : FLASH_CID : 150100464A32374D4202CB20968B23B5 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xD9C8F395F236F3AE5AF16D55EAF9F28C INT RAM : 0x00020000 EXT RAM : 0x30000000 [768 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:28 Reconnect Power/Cable! |
02-14-2022, 11:24 | #69868 (permalink) |
No Life Poster Join Date: Mar 2016 Location: Ukraine
Member: 2550141 Status: Offline Thanks Meter: 1,115 | LEAGOO M12 Reset FRP Done Code: Operation : Identify [ v2.33 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM72) MODE : BOOTROM PORT : 72 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 CODE : Zion TYPE : MODERN [RAPHAEL] BROM : MEID : C6C56332BC932DD68AF98B1A8F1DA14C BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 4E64B101B2B6F92D58BB466548DDC4A20C369621C8EEA7355356E53F73C307E1 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_bird_k39tv1_bsp.bin EMI : CNT : 0009 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00020000 [ 128,00 KB ] DRAM: 0x80000000 [ 2,00 GB ] EMMC: CID : 150100514531334D420DAD244F6C149D EMMC: VEN : SAMSUNG : OEM : 0 : ID : 514531334D42 : PRV : 0x0D EMMC: VEN : SAMSUNG : QE13MB EMMC: SNN : 2904837996 ( 0xAD244F6C ) , MF : 1/2017 EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x00400000 [ 4,00 MB ] USER : 0x3A3E00000 [ 14,56 GB ] CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 65D77B1A4EE42214A12D72A31A4CAB17 DA : USB : HIGH-SPEED Boot done! Patch Level : PPR1.180610.011 Display ID : LEAGOO_M12_OS5.0_E_20190828 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2019-08-05 Build Time : 28.08.2019 Product Model : M12 Product Brand : LEAGOO Product Name : M12 Product Device : M12 Product Manfct : LEAGOO Product Info : M12 Product Board : 8149TQ Board Platform : mt6739 USERDATA : FILESYSTEM : F2FS with FDE ( Full Disk Encryption **) NVRAM : TK_MD_BASIC_MDBIN_PCB01_MT6739_S00.MOLY_LR12A_R3_MP_V58_5 NVRAM : 0x9E08B6A1 NVRAM : State : Ok! INFO : WiFi MAC : 000CE7940C2A INFO : BlTh MAC : 000CE7940C2B INFO : IMEI[1] : 867838040087830 INFO : IMEI[2] : 867838040087848 Backup sensetive data [ 18 ] Backup path : Backup\MT6739__C6C56332BC932DD68AF98B1A8F1DA14C\ Backup done! STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : NOT Enabled! STORAGE : RPMB Status : eMMC : RPMB KEY PROGRAMMED [UNUSABLE] PRELOADER : DEVICE : DEV : MT6739 NME : preloader_bird_k39tv1_bsp.bin CNT : 0009 EMI : [00] : eMMC : DDR3 : ID : 700100454841434541 : VEN : KINGSTON | DEV : EHACEA : RAM : [ 2,00 GB ] EMI : [01] : eMMC : DDR3 : ID : 450100444634303136 : VEN : SANDISK | DEV : DF4016 : RAM : [ 2,00 GB ] EMI : [02] : eMMC : DDR3 : ID : 1501005145 : VEN : SAMSUNG | DEV : QE : RAM : [ 2,00 GB ] EMI : [03] : eMMC : DDR3 : ID : 1501005138 : VEN : SAMSUNG | DEV : Q8 : RAM : [ 2,00 GB ] EMI : [04] : eMMC : DDR3 : ID : 90014A484147 : VEN : HYNIX | DEV : HAG : RAM : [ 2,00 GB ] EMI : [05] : eMMC : DDR3 : ID : 11010030 : VEN : TOSHIBA | DEV : 0 : RAM : [ 2,00 GB ] EMI : [06] : eMMC : DDR3 : ID : 13014E : VEN : MICRON | DEV : : RAM : [ 2,00 GB ] EMI : [07] : eMMC : DDR3 : ID : 1501005133 : VEN : SAMSUNG | DEV : Q3 : RAM : [ 2,00 GB ] EMI : [08] : eMMC : DDR3 : ID : 90014A484247346132 : VEN : HYNIX | DEV : HBG4a2 : RAM : [ 2,00 GB ] PRELOADER saved to : Backup\PRELOADER\preloader_bird_k39tv1_bsp.bin Done! Elapsed: 00:00:15 Code: Operation : Reset Settings/Format FS [ v2.33 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM72) MODE : BOOTROM PORT : 72 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 CODE : Zion TYPE : MODERN [RAPHAEL] BROM : MEID : C6C56332BC932DD68AF98B1A8F1DA14C BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 4E64B101B2B6F92D58BB466548DDC4A20C369621C8EEA7355356E53F73C307E1 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_bird_k39tv1_bsp.bin EMI : CNT : 0009 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00020000 [ 128,00 KB ] DRAM: 0x80000000 [ 2,00 GB ] EMMC: CID : 150100514531334D420DAD244F6C149D EMMC: VEN : SAMSUNG : OEM : 0 : ID : 514531334D42 : PRV : 0x0D EMMC: VEN : SAMSUNG : QE13MB EMMC: SNN : 2904837996 ( 0xAD244F6C ) , MF : 1/2017 EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x00400000 [ 4,00 MB ] USER : 0x3A3E00000 [ 14,56 GB ] CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 65D77B1A4EE42214A12D72A31A4CAB17 DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x815657 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : CACHE Format Ok : USERDATA Done! Elapsed: 00:00:22 |
02-14-2022, 11:37 | #69869 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Infinix X612B MT6761 FRP/Pattren Reset Done With King Infinity CM2 Code: Card found : A19EC787 , v0152 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.33 Load IDBase v1121431 Ok! UserName and/or Password not set! Can't continue! Load IDBase v1121431 Ok! Operation : Reset Settings/Format FS [ v2.33 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM32) MODE : BOOTROM PORT : 32 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 CODE : Merlot TYPE : MODERN [RAPHAEL] BROM : MEID : 25D87818DFFAE3E1FD904D52EEB93023 BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 10AE3C972E0C96E34EE4B17813679D6AA066B53E12E039B644029D94459734CA BROM : EMI : Search BROM : EMI : Found! AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMMC: CID : 1501005158363341420301F007B8A773 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 515836334142 : PRV : 0x03 EMMC: VEN : SAMSUNG : QX63AB EMMC: SNN : 32507832 ( 0x01F007B8 ) , MF : 10/2020 EMI : DEV : FireFly EMI : SRC : preloader_infinix_x612b.bin EMI : CNT : 0009 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A400 [ 233.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: CID : 1501005158363341420301F007B8A773 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 515836334142 : PRV : 0x03 EMMC: VEN : SAMSUNG : QX63AB EMMC: SNN : 32507832 ( 0x01F007B8 ) , MF : 10/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 2D0B40E22F7ED128FA3929575878ADD9 DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x825657 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : CACHE Format Ok : USERDATA Format Ok : USERDATA Done! Elapsed: 00:00:59 Reconnect Power/Cable! |
02-14-2022, 12:09 | #69870 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | KGTEL K2 Format Code: 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR 6531EFM v2.0 (c)2019 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ] Make backup of sensetive data Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_1B74F06DD7DD_NVM.nv Executing FormatFFS ... Format FFS Done! Done! Elapsed: 00:00:28 Reconnect Power/Cable! |
