03-20-2022, 07:26 | #70336 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Oppo CPH2269 FRP/Pattren Reset Done With King Infinity CM2 Code: Operation : Reset Settings/Format FS [ v2.33 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : USB Single Port (COM5) MODE : BOOTROM PORT : 5 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 1281EBD4BC65DB7374A71A35AF076239 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : C975F17AEA8FE80405D21CD66448D887E34366CAD53145BBE0B8424D32A9B55F BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : FF : Look for EMI BROM : FF : EMI found! BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMMC: CID : 90014A68433861503E03100DF7B39815 EMMC: VEN : HYNIX : OEM : 74 : ID : 68433861503E : PRV : 0x03 EMMC: VEN : HYNIX : hC8aP> EMMC: SNN : 269350835 ( 0x100DF7B3 ) , MF : 9/2021 EMI : DEV : FireFly EMI : SRC : preloader_oppo6765.bin EMI : CNT : 0007 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: CID : 90014A68433861503E03100DF7B39815 EMMC: VEN : HYNIX : OEM : 74 : ID : 68433861503E : PRV : 0x03 EMMC: VEN : HYNIX : hC8aP> EMMC: SNN : 269350835 ( 0x100DF7B3 ) , MF : 9/2021 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 2673F37DD452127430968A0B42BCD734 DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:39 Reconnect Power/Cable! |
03-20-2022, 07:52 | #70337 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile I8 SPD77XX FRP/Pattren Reset Done With King Infinity CM2 Code: Card found: S/N : A19EC787 , v0152 Chinese Miracle II [SPD module] v 1.27 Set mode to : SP [SC773x] eMMC [Android 6.x] Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 8 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x0000000133CF7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x/6.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:21 Reconnect Power/Cable! |
03-20-2022, 13:43 | #70338 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Qmobile S2 Format Done Operation : Reset Settings/Format FS [ v2.34 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM16) MODE : PRELOADER PORT PORT : 16 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY [MTK] BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN BROM : BROM|BL : 0xFF|0x01 BROM : PRELOADER PORT AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 484A019065314738A1430705E782B010 DAInf: 4 : 2 : 156 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: CID : 90014A4838473165050743A110B082E7 EMMC: VEN : HYNIX : OEM : 74 : ID : 483847316505 : PRV : 0x07 EMMC: VEN : HYNIX : H8G1e EMMC: SNN : 1134629040 ( 0x43A110B0 ) , MF : 8/2015 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x1D2000000 [ 7.28 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 71D01E424D1C0C4FF6715D1D141D7B16 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x8D5454 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : CACHE Format Ok : USERDATA Done! Elapsed: 00:00:39 Reconnect Power/Cable! |
03-20-2022, 13:50 | #70339 (permalink) |
No Life Poster Join Date: Jul 2009 Location: SINDH PAKISTAN
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | call me musik 500 format done SPRD mode : SC6531 : REV : E000 : NOR : [ 4MB ] Operation : Format FileSystem [ v1.07 ] 1. Power off device 2. Not hold any key on device! 3. Insert cable and battery in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! Format FFS Done! Done! Elapsed: 00:00:15 Reconnect Power/Cable! |
03-20-2022, 15:13 | #70340 (permalink) |
No Life Poster Join Date: Sep 2021 Location: Germany
Member: 2996196 Status: Offline Thanks Meter: 632 | Nokia ta1352 network unlock done by cm2 👋👋👏🙏🙏 Card found : 3FAB1F9D , v0151 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14 Load IDBase v8331 Ok! Operation : SP Unlock [ v2.14 ] BootMode : SVC 1. Power off device, wait 10-15 seconds 2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! SOC GEN : UniSoc ( E-family and Modern ) BuildInfo : Cosmo_00WW-user 11 RP1A.201005.001 V1.27A_B01 release-keys Platform Version: MOCORTM_20A_W21.15.3_P7_Debug Project Version: sharkl3_pub BASE Version: 4G_MODEM_20A_W21.15.3_P7 HW Version: sc9863A_modem CMP_Time : 06-08-2021 11:05:19 MODEM TAG : MOCORTM_20A_W21.15.3_P7_Debug_4G_MODEM_20A_W21.15. 3_P7_sc9863A_modem_sharkl3_pub NVMng : SecurityInfo IMEI[1] : 356748974032009 IMEI[2] : 356748974032017 WIFIMAC : 44917C0B5E42 BT_MAC : 44917C0B5E41 SEC : SLS:2, SKS:0, SKV:4 SLStatus : 2C Status : Locked! Server unlock required! Connecting to server... Connected Init... Init: Ok Authenticating... Authenticated Checking Client version... Client version Ok Balance: 20, price:5 Process... Process : Operation may took 10-15 minutes! >>> Repeat unlock/repair procedure after requested time again! Reconnect Power/Cable! Operation : SP Unlock [ v2.14 ] BootMode : SVC 1. Power off device, wait 10-15 seconds 2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! SOC GEN : UniSoc ( E-family and Modern ) BuildInfo : Cosmo_00WW-user 11 RP1A.201005.001 V1.27A_B01 release-keys Platform Version: MOCORTM_20A_W21.15.3_P7_Debug Project Version: sharkl3_pub BASE Version: 4G_MODEM_20A_W21.15.3_P7 HW Version: sc9863A_modem CMP_Time : 06-08-2021 11:05:19 MODEM TAG : MOCORTM_20A_W21.15.3_P7_Debug_4G_MODEM_20A_W21.15. 3_P7_sc9863A_modem_sharkl3_pub NVMng : SecurityInfo IMEI[1] : 356748974032009 IMEI[2] : 356748974032017 WIFIMAC : 44917C0B5E42 BT_MAC : 44917C0B5E41 SEC : SLS:2, SKS:0, SKV:4 SLStatus : 2C Status : Locked! Server unlock required! Connecting to server... Connected Init... Init: Ok Authenticating... Authenticated Checking Client version... Client version Ok Balance: 15, price:5 Process... Finished Disconnected Unlocking device ... Sync data ... Device unlocked! Done! Elapsed: 00:00:39 |
The Following 3 Users Say Thank You to Jacobkamudyariw For This Useful Post: |
03-20-2022, 15:16 | #70341 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Tecno Spark Go Smart Reset Done Operation : Reset Settings/Format FS [ v2.34 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM16) MODE : PRELOADER PORT PORT : 16 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 CODE : Merlot TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : Reset Interface! PTFN : MediaTek USB Port (COM3) MODE : BOOTROM PORT : 3 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 CODE : Merlot TYPE : MODERN [RAPHAEL] BROM : MEID : CD9D3D48100D80E938BABB4C2EE49CB8 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 9F58679957DB1111378C96E0CFA70575B4871D04B3F053A349 5EFD2D19ADA2AF BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : FF : Look for EMI BROM : FF : EMI found! BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMMC: CID : 90014A484147346132A553002124A58D EMMC: VEN : HYNIX : OEM : 74 : ID : 484147346132 : PRV : 0xA5 EMMC: VEN : HYNIX : HAG4a2 EMMC: SNN : 1392517412 ( 0x53002124 ) , MF : 10/2018 EMI : DEV : FireFly EMI : SRC : preloader_kc1_h6114.bin EMI : CNT : 000A EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A400 [ 233.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: CID : 90014A484147346132A553002124A58D EMMC: VEN : HYNIX : OEM : 74 : ID : 484147346132 : PRV : 0xA5 EMMC: VEN : HYNIX : HAG4a2 EMMC: SNN : 1392517412 ( 0x53002124 ) , MF : 10/2018 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3AB400000 [ 14.68 GB ] CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 96D0A7495077D496830B5095AFB02963 DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x815657 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : CACHE Format Ok : USERDATA Done! Elapsed: 00:00:42 Reconnect Power/Cable! |
03-20-2022, 15:33 | #70342 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Redmi 9A MT6765 FRP/Pattren Reset Done With King Infinity CM2 Code: Card found : A19EC787 , v0153 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.34 Load IDBase v312457 Ok! UserName and/or Password not set! Can't continue! Load IDBase v312457 Ok! Operation : Reset Settings/Format FS [ v2.34 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : USB Single Port (COM23) MODE : BOOTROM PORT : 23 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 6A579C3D6474FB7141DFE3F5204CD2BA BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 5E9E1CE158DED6588B4989A461B37704791C5F4D1BB35130A98FEA7AE3D5D34A BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : FF : Look for EMI BROM : FF : EMI found! BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMMC: CID : 150100424A5444345209E76A8E3E8733 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 424A54443452 : PRV : 0x09 EMMC: VEN : SAMSUNG : BJTD4R EMMC: SNN : 3882520126 ( 0xE76A8E3E ) , MF : 8/2020 EMI : DEV : FireFly EMI : SRC : preloader_k62v1_64_bsp.bin EMI : CNT : 000A EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: CID : 150100424A5444345209E76A8E3E8733 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 424A54443452 : PRV : 0x09 EMMC: VEN : SAMSUNG : BJTD4R EMMC: SNN : 3882520126 ( 0xE76A8E3E ) , MF : 8/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 960403AF8F545194D1A3B6AEFF8623DF DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x825657 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : CACHE Format Ok : USERDATA Format Ok : USERDATA Done! Elapsed: 00:00:33 Reconnect Power/Cable! |
03-21-2022, 06:14 | #70343 (permalink) |
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 76 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 520001154D4231456DC907427F3FFC90 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMB1E [eMMC] : FLASH_CID : 150100524531424D4207C96D90FC937F [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0x033C52179BD89B5A2E34D6B9F8ED3562 INT RAM : 0x00020000 EXT RAM : 0xC0000000 [3 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Done! Elapsed: 00:00:18 Reconnect Power/Cable! |
03-21-2022, 07:38 | #70344 (permalink) |
No Life Poster Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Oppo a12 cph2083 reset frp done by cm2 Card found : 73CA70CC , v0153 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.34 Load IDBase v312457 Ok! Update configuration ... Load IDBase v312457 Ok! Operation : Reset Settings/Format FS [ v2.34 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MTK USB Port (COM28) MODE : BOOTROM PORT : 28 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 32F603F25408A02BE43B05B0C2D5FFD4 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : C280BAFF3B4D8F5FC9167E2F4B866C1514DE83290AEC3B6B96 7014DE33C85C29 BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_oppo6765_19451.bin EMI : CNT : 000A EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: CID : 1501003458364B4D42033A30DCF687E1 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 3458364B4D42 EMMC: VEN : SAMSUNG : 4X6KMB EMMC: SNN : 976280822 ( 0x3A30DCF6) , MF : 8/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 99C65CECA5F5EC9EFBED79BE756F442E DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x815757 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : CACHE Format Ok : USERDATA Done! Elapsed: 00:00:37 Reconnect Power/Cable! |
03-21-2022, 13:07 | #70345 (permalink) |
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | tecno ce7j reset done Operation : Reset Settings/Format FS [ v2.34 ] Mode : FULL FACTORY ( WIPE + FRP ) 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM5) MODE : BOOTROM PORT : 5 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Talbot TYPE : MODERN [RAPHAEL] BROM : MEID : 091556FA0579BC318FFA52787FA46056 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 9A93AA29B19D19A729C832E20868E28F85DA8249AF0EF37F2C 574057CE05FA56 BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : FF : Look for EMI BROM : FF : EMI found! BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6768 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMMC: CID : 90014A6844456150330300ADC50D5765 EMMC: VEN : HYNIX : OEM : 74 : ID : 684445615033 : PRV : 0x03 EMMC: VEN : HYNIX : hDEaP3 EMMC: SNN : 11388173 ( 0x00ADC50D ) , MF : 5/2020 EMI : DEV : FireFly EMI : SRC : preloader_ce7j_h693.bin EMI : CNT : 000E EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00070000 [ 448.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: CID : 90014A6844456150330300ADC50D5765 EMMC: VEN : HYNIX : OEM : 74 : ID : 684445615033 : PRV : 0x03 EMMC: VEN : HYNIX : hDEaP3 EMMC: SNN : 11388173 ( 0x00ADC50D ) , MF : 5/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x1D1F000000 [ 116.48 GB ] CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0001 , EVOL : 0x0000 RNID : 29E11145621C59DBF68C35651FC5BB96 DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : USERDATA Format Ok : USERDATA Done! Elapsed: 00:00:34 Reconnect Power/Cable! |
The Following User Says Thank You to Nadeem Waris For This Useful Post: |
03-21-2022, 13:48 | #70346 (permalink) |
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | itel A25 flash done Open : iTel_A25_L5002-F3210-9.0-OP-V030-20191113[infinityrom.com].pac VER : BP_R1.0.0 LEN : 2.41 GiB CPU : sp9832e_1h10 VER : L5002-F3210-9.0-OP-V030-20191113_1158-user Reading package ... Read package finished! Patch Level : PPR1.180610.011 Display ID : L5002-F3210-9.0-OP-V030-20191113 Ver. Incmt : OP-V030-20191113 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2019-10-05 Build Time : 13.11.2019 Product Model : itel L5002 Product Brand : Itel Product Name : F3210 Product Device : itel-L5002 Product Manfct : itel Product Info : L5002 Product Board : L5002 Board Platform : sp9832e Product Name : L5002 Product Device : L5002 Operation : Flash Firmware [ v2.14 ] Setting : Update NVRAM : False Setting : Force NVRAM : False Setting : Update PMT : True 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : PAC : iTel_A25_L5002-F3210-9.0-OP-V030-20191113[infinityrom.com].pac Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0004 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : Control transfered! Boot Done! PMTMng : Load PMT PMTMng : 0x26 PMTMng : Update PMT Ok! Prepare target ... Prepare Ok! ERASE : L_RUNTIMENV1 CODE : tos-sign.bin UBOOT : u-boot-sign.bin FSIMG : cache.img CODE : prodnv.img CODE : gnssmodem.bin UBOOT : u-boot-spl-16k-sign.bin FSIMG : product.img ERASE : MISC FSIMG : vendor.img FSIMG : userdata.img CODE : PM_sharkle_cm4.bin CODE : recovery.img CODE : sharkle_cm4.bin CODE : logo.bmp CODE : SharkLE_LTEA_DSP_evs_on.bin CODE : logo.bmp(1) CODE : sml-sign.bin FSIMG : system.img CODE : delta_nv.bin CODE : vbmeta-sign.img CODE : SC9600_sharkle_pubcp_customer_Smart_Phone_modem.da t CODE : SHARKLE2_DM_DSP.bin CODE : dtb.img CODE : gnssbdmodem.bin CODE : dtbo.img FSIMG : persist.img CODE : cover.img ERASE : UBOOT_LOG CODE : boot.img Flashing finished! Reconnect Power/Cable! Done! Elapsed: 00:02:59 |
03-21-2022, 14:27 | #70347 (permalink) |
No Life Poster Join Date: Aug 2020 Location: Mozambique Age: 20
Member: 2965136 Status: Offline Sonork: 58846 Thanks Meter: 1,202 | TECNO-PR651H Frp Reset Done Code: Card found : 46828B86 , v0153 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14 Load IDBase v8331 Ok! Operation : Identify [ v2.14 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : MANUAL LDR Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0020 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! FDL : Process authentification ... FDL : SEC : RSA auth passed! FDL : Control transfered! Boot Done! Device info : Product Brand : TECNO Product Device : PR651H Product Model : TECNO PR651H Product Name : PR651H Patch Level : RP1A.201005.001 Display ID : PR651H-F6317-11.0-OP-V043-20210729 Ver. Incmt : OP-V043-20210729 Ver. CodeName : REL Ver. Release : 11 Sec. Patch : 2021-07-05 Build Time : 29.07.2021 Product Name : F6317 Product Device : TECNO-PR651H Product Info : PR651H Product Board : PR651H Board Platform : sp9863a Product Manfct : TECNO Platform Version: MOCORTM_20A_W21.15.3_P5_Debug Project Version: sharkl3_pub BASE Version: 4G_MODEM_20A_W21.15.3_P5 HW Version: sc9863A_modem CMP_Time : 05-11-2021 10:59:41 MODEM TAG : MOCORTM_20A_W21.15.3_P5_Debug_4G_MODEM_20A_W21.15.3_P5_sc9863A_modem_sharkl3_pub USERDATA : FILESYSTEM : F2FS with FBE ( File-Base Encryption ) - > INFO : Remove cable from device to switch it off! Done! Elapsed: 00:01:29 Code: Operation : Format FS / Reset Settings [ v2.14 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : MANUAL LDR Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0020 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! FDL : Process authentification ... FDL : SEC : RSA auth passed! FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Done! Elapsed: 00:01:05 |
The Following 3 Users Say Thank You to tayobjoy1 For This Useful Post: |
03-21-2022, 14:53 | #70348 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Gm 5d hang on logo done by cm2 Card found : 73CA70CC , v0153 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16 Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 410 [MSM8916] ID_BLOCK_S : 2203C074 ID_BLOCK_L : 71F3E915C02E5B563166EEF7300B8BC3 ID_BLOCK_L : DEB51BB2A72E9015A807488183627C5F Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB800000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:44 Reconnect Power/Cable! |
03-21-2022, 14:54 | #70349 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Oppo f3 reset frp done by cm2 Card found : 73CA70CC , v0153 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16 Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 652 [MSM8952] ID_BLOCK_S : 1475B83E ID_BLOCK_L : BC65F42FDB1B3E170EA8237B412BF3F9 ID_BLOCK_L : 506CFA5E774216CF1DDF86C19D5DEE8E Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8976 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000E8F800000 [ eMMC 64 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:19 Reconnect Power/Cable! |
03-21-2022, 14:56 | #70350 (permalink) |
No Life Poster Join Date: Jan 2013 Location: gsmhosting Age: 29
Member: 1876736 Status: Offline Thanks Meter: 735 | nokia 2.4 mdm lock removed by infinity cm2 Code: Operation : Memory Tool Init [ v2.34 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1633 (COM3) MODE : BOOTROM PORT : 3 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : A99C7755A49D34CAAD877EA3A1F489AB BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : CA56EF8082F908C4D9B5DCDB2A5BE68C69F1B88C3B45F4E281C3720EA75B4268 BROM : Sending FireFly FireFly : Starting ... FireFly : Init Core FireFly : Core init done! FireFly : Running : v05.05.05 on MT6765 FireFly : eMMC init passed! EMMC: CSD : D0FFFF329F5903FFFFFFFFEF9640002D EMMC: CSD : TEMP_WRITE_PROTECT: False EMMC: CSD : PERM_WRITE_PROTECT: False EMMC: CID : 880103534C44363447656E1713B1C721 EMMC: VEN : FORESEE : OEM : 3 : ID : 534C44363447 : PRV : 0x65 EMMC: VEN : FORESEE : SLD64G EMMC: SNN : 1847006129 ( 0x6E1713B1 ) , MF : 12/2020 EMMC: EXTCSD : rev1.8 ( eMMC 5.1 ) EMMC: EXTCSD [CONFIG] : 0x48, 0x02, 0x01 EMMC: EXTCSD [PARTITION_CONFIG] : 0x48 EMMC: EXTCSD [BOOT_BUS_WIDTH] : 0x02 EMMC: EXTCSD [RST_N_FUNCTION] : 0x01 EMMC: EXTCSD [PART_S_COMPLETED] : False EMMC: EXTCSD [SIZE] : Market : 64 GB EMMC: EXTCSD [SIZE] : Actual : 0xE67800000 [ 57.62 GB ] EMMC: EXTCSD [EOL] : EOL status : Normal ( Less than 80% reserved blocks used ) EMMC: EXTCSD [EOL_A] : SLC status : 0% - 10% used EMMC: EXTCSD [EOL_B] : MLC status : Not defined EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] USER : 0xE67800000 [ 57.62 GB ] DA : USB : HIGH-SPEED Boot done! Set default path : H:\InfinityBox\CM2MT2\phdata\ Ready! MemoryTool Operation : Read Memory Reading selected partitions [3] NVDATA : Already exists! Skipped! [1] Read partition : PROTECT2 Saved to : H:\InfinityBox\CM2MT2\phdata\PROTECT2.bin NVRAM : Already exists! Skipped! Operation finished! MemoryTool Operation : Read Memory Reading selected partitions [3] [0] Read partition : NVDATA Saved to : H:\InfinityBox\CM2MT2\phdata\NVDATA.bin [1] Read partition : PROTECT2 Saved to : H:\InfinityBox\CM2MT2\phdata\PROTECT2.bin [2] Read partition : NVRAM Saved to : H:\InfinityBox\CM2MT2\phdata\NVRAM.bin Operation finished! MemoryTool Operation : Erase Memory Erase selected partitions [3] [0] Erase partition : NVDATA Erase partition Ok! [1] Erase partition : PROTECT2 Erase partition Ok! [2] Erase partition : NVRAM Erase partition Ok! Operation finished! Close MemoryTool session Done! Elapsed: 00:03:08 Reconnect Power/Cable! Operation : Reset Settings/Format FS [ v2.34 ] Mode : FACTORY RESET ( WIPE ) 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1633 (COM3) MODE : BOOTROM PORT : 3 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : A99C7755A49D34CAAD877EA3A1F489AB BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : CA56EF8082F908C4D9B5DCDB2A5BE68C69F1B88C3B45F4E281C3720EA75B4268 BROM : Sending FireFly FireFly : Starting ... FireFly : Init Core FireFly : Core init done! FireFly : Running : v05.05.05 on MT6765 FireFly : eMMC init passed! EMMC: CSD : D0FFFF329F5903FFFFFFFFEF9640002D EMMC: CSD : TEMP_WRITE_PROTECT: False EMMC: CSD : PERM_WRITE_PROTECT: False EMMC: CID : 880103534C44363447656E1713B1C721 EMMC: VEN : FORESEE : OEM : 3 : ID : 534C44363447 : PRV : 0x65 EMMC: VEN : FORESEE : SLD64G EMMC: SNN : 1847006129 ( 0x6E1713B1 ) , MF : 12/2020 EMMC: EXTCSD : rev1.8 ( eMMC 5.1 ) EMMC: EXTCSD [CONFIG] : 0x48, 0x02, 0x01 EMMC: EXTCSD [PARTITION_CONFIG] : 0x48 EMMC: EXTCSD [BOOT_BUS_WIDTH] : 0x02 EMMC: EXTCSD [RST_N_FUNCTION] : 0x01 EMMC: EXTCSD [PART_S_COMPLETED] : False EMMC: EXTCSD [SIZE] : Market : 64 GB EMMC: EXTCSD [SIZE] : Actual : 0xE67800000 [ 57.62 GB ] EMMC: EXTCSD [EOL] : EOL status : Normal ( Less than 80% reserved blocks used ) EMMC: EXTCSD [EOL_A] : SLC status : 0% - 10% used EMMC: EXTCSD [EOL_B] : MLC status : Not defined EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] USER : 0xE67800000 [ 57.62 GB ] DA : USB : HIGH-SPEED Boot done! Format Ok : USERDATA Done! Elapsed: 00:00:22 after this step boot normaly then write back nvram Operation : Memory Tool Init [ v2.34 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1633 (COM3) MODE : BOOTROM PORT : 3 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : A99C7755A49D34CAAD877EA3A1F489AB BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : CA56EF8082F908C4D9B5DCDB2A5BE68C69F1B88C3B45F4E281C3720EA75B4268 BROM : Sending FireFly FireFly : Starting ... FireFly : Init Core FireFly : Core init done! FireFly : Running : v05.05.05 on MT6765 FireFly : eMMC init passed! EMMC: CSD : D0FFFF329F5903FFFFFFFFEF9640002D EMMC: CSD : TEMP_WRITE_PROTECT: False EMMC: CSD : PERM_WRITE_PROTECT: False EMMC: CID : 880103534C44363447656E1713B1C721 EMMC: VEN : FORESEE : OEM : 3 : ID : 534C44363447 : PRV : 0x65 EMMC: VEN : FORESEE : SLD64G EMMC: SNN : 1847006129 ( 0x6E1713B1 ) , MF : 12/2020 EMMC: EXTCSD : rev1.8 ( eMMC 5.1 ) EMMC: EXTCSD [CONFIG] : 0x48, 0x02, 0x01 EMMC: EXTCSD [PARTITION_CONFIG] : 0x48 EMMC: EXTCSD [BOOT_BUS_WIDTH] : 0x02 EMMC: EXTCSD [RST_N_FUNCTION] : 0x01 EMMC: EXTCSD [PART_S_COMPLETED] : False EMMC: EXTCSD [SIZE] : Market : 64 GB EMMC: EXTCSD [SIZE] : Actual : 0xE67800000 [ 57.62 GB ] EMMC: EXTCSD [EOL] : EOL status : Normal ( Less than 80% reserved blocks used ) EMMC: EXTCSD [EOL_A] : SLC status : 0% - 10% used EMMC: EXTCSD [EOL_B] : MLC status : Not defined EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] USER : 0xE67800000 [ 57.62 GB ] DA : USB : HIGH-SPEED Boot done! Set default path : H:\InfinityBox\CM2MT2\phdata\ Ready! MemoryTool Operation : Write Memory Write selected partitions [1] [0] Write partition : NVRAM Write from : H:\InfinityBox\CM2MT2\phdata\NVRAM.bin Write partition Ok! Operation finished! Close MemoryTool session Done! Elapsed: 00:01:39 Reconnect Power/Cable! |
The Following 6 Users Say Thank You to sky73 For This Useful Post: |
