01-13-2023, 10:30 | #73036 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Tecno KG5K SPD FRP/Pattren Reset Done With King Infinity CM2 Code: Card found : A19EC787 , v0153 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14 Load IDBase v8331 Ok! Operation : Format FS / Reset Settings [ v2.14 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... >>> Device not found! >>> Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Format FS / Reset Settings [ v2.14 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... >>> Device not found! >>> Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Format FS / Reset Settings [ v2.14 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : TECNO : KG5k Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0020 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:23 |
01-13-2023, 11:50 | #73037 (permalink) |
No Life Poster Join Date: Jul 2009 Location: SINDH PAKISTAN
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | oppo A5s Smrat Reset DOne With Cm2 Operation: Reset Settings/Format FS [ v2.39a5 ] Platform: MTK SmartPhone - MT65/67/68/81/83/87 | Helio G/P/X Mode: SMART RESET Wait... WARNING! Format FS WILL RESET ALL USER DATA! Make sure about correct format mode selection! Continue? Yes 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port (COM34) MODE: BOOTROM; PORT: 34 Waiting BOOT ack... BROM: Skip ACK verify BROM: Init BROM BROM: Init passed CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: A5F8183B0CD371DDFF6E5FAF68C9421B BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT BROM: BROM|BL : 0x05|0xFE [BOOTROM] BROM: SOCID: DBA6C0C5BBE03198F51C14BFEF4E6C2450376BEE493A0CEB9B 751B1B0FDC8F66 BROM: SLA: Local Auth BROM: SLA: Starting Auth BROM: FF : Look for EMI BROM: FF : EMI found BROM: SLA: Auth Passed BROM: SEC: 0x000000E0 AGENT: 0_base: base_v2216 | Manual: Off [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_A llInOne_DA.bin Looking for suitable BootChain in DA... Found MT6765 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... BROM: DA sent BROM: Transfer control to DA... DA: AGENT started DA: SYNC DA: MODE: BROM DA: EXT_RAM NOT initialized EMMC: CID: 150100514436334D42032ECD9654A65B VEN: Samsung OEM: 0 ID: 514436334D42 [QD63MB] PRV: 0x03 SNN: 785225300 [0x2ECD9654] MF: 10/2019 EMI: FireFly preloader_oppo6765_18511.bin with 9 memory type(s) supported EMI: Init EMI from INTERNAL DB EMI: EXT_RAM CFG Passed DA: BOOT to 2nd DA... DA: 2ND stage confirmed DA: SYNC with DA passed DA: Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: CID: 150100514436334D42032ECD9654A65B VEN: Samsung OEM: 0 ID: 514436334D42 [QD63MB] PRV: 0x03 SNN: 785225300 [0x2ECD9654] MF: 10/2019 BOOT1: 0x00400000 [ 4.00 MB ] BOOT2: 0x00400000 [ 4.00 MB ] RPMB: 0x01000000 [ 16.00 MB ] USER: 0x747C00000 [ 29.12 GB ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: 13D55BD9C800313D8F38598DD2C30A6B MEID: A5F8183B0CD371DDFF6E5FAF68C9421B DA: USB: HIGH-SPEED Boot done [1] Reading... Ok SmartInfo: AndroidVer: 8 UserDataFS: 0x02 CacheFS: 0x02 Strategy: 7 Verify device config... Ok Loaders Ok Backup [20] to C:\InfinityBox\CM2MT2\backup\MT6765__A5F8183B0CD37 1DDFF6E5FAF68C9421B\ [27] Read: NVRAM [11] Read: NVDATA [18] Read: PROINFO [28] Read: LK [10] Read: NVCFG [13] Read: PROTECT1 [1] Read: PGPT [16] Read: PERSIST [0] Read: PRELOADER [7] Read: OPPO_CUSTOM Done 10 files Compress: C:\InfinityBox\CM2MT2\backup\MT6765__A5F8183B0CD37 1DDFF6E5FAF68C9421B\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6765__A5F8183B0CD37 1DDFF6E5FAF68C9421B.7z Verified [1] Process: RESET PROTECTION... Format Ok: RESET PROTECTION [2] Process: USERDATA... Format Ok: USERDATA [3] Process: CACHE... Format Ok: CACHE [4] Verified [5] Verified [6] Process: USERDATA... Format Ok: USERDATA [7] Verified [1] Verified [2] Verified Done: 00:01:29 Reconnect Power/Cable now |
01-13-2023, 16:59 | #73038 (permalink) |
Registered User Join Date: Jul 2013 Location: Harare
Member: 1972271 Status: Offline Sonork: zwanaz Thanks Meter: 164 | Finecomm f11 read usercode done using scr FINECOMM F11 READ USERCODE DONE USING SCR BR TECHBOYSREPAIRS ZWANABOY88 |
The Following User Says Thank You to zwanaboy For This Useful Post: |
01-13-2023, 22:16 | #73039 (permalink) |
No Life Poster Join Date: Nov 2006 Location: DEATH VALLEY
Member: 394869 Status: Offline Sonork: TAKE NO CHANCES Thanks Meter: 500 | SAMSUNG SM-A032F FRP DONE: Operation : Flash Firmware [ v2.14 ] Setting : Update NVRAM : False Setting : Force NVRAM : False Setting : Update PMT : False 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : PAC : A032F_bit2_wipe+frp_by_kamal_singla.pac Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0020 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : True FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! Prepare target ... Prepare Ok! FSIMG : kamal.img FSIMG : kamal1.img Flashing finished! Reconnect Power/Cable! Done! Elapsed: 00:00:37 |
01-14-2023, 05:30 | #73040 (permalink) | |
No Life Poster Join Date: Nov 2008 Location: RVIII
Member: 890926 Status: Offline Thanks Meter: 2,054 | Quote:
Br, xerraco | |
01-14-2023, 06:30 | #73041 (permalink) |
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | vivo y91 smart reset Done With Cm2 Operation: Reset Settings/Format FS [ v2.39a5 ] Platform: MTK SmartPhone - MT65/67/68/81/83/87 | Helio G/P/X Mode: SMART RESET Wait... WARNING! Format FS WILL RESET ALL USER DATA! Make sure about correct format mode selection! Continue? Yes 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek PreLoader USB VCOM (Android) (COM9) MODE: PRELOADER PORT; PORT: 9 Waiting BOOT ack... PRELOADER: ACK confirmed BROM: Init BROM BROM: Init passed CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0200 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005 Mode: SBC+SDA BROM: BROM|BL : 0xFF|0x03 [PRELOADER PORT] AGENT: 0_base: base_v2216 | Manual: Off [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_A llInOne_DA.bin Looking for suitable BootChain in DA... Found MT6761 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... BROM: Reset Interface PTFN: MediaTek USB Port (COM34) MODE: BOOTROM; PORT: 34 Waiting BOOT ack... BROM: Skip ACK verify BROM: Init BROM BROM: Init passed CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0200 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] MEID: 92F420763A83ED62C4EF5237CFEFB98D BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT BROM: BROM|BL : 0x05|0xFE [BOOTROM] BROM: SOCID: 3AEBCBC62A5238CC0E2B2DC05C7C775DF15FC26160EA9C8829 E435DD40C6BD8B BROM: SLA: Local Auth BROM: SLA: Starting Auth BROM: SLA: Auth Passed BROM: SEC: 0x000000E0 AGENT: 0_base: base_v2216 | Manual: Off [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_A llInOne_DA.bin Looking for suitable BootChain in DA... Found MT6761 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... BROM: DA sent BROM: Transfer control to DA... DA: AGENT started DA: SYNC DA: MODE: BROM DA: EXT_RAM NOT initialized EMMC: CID: 150100514436334D42013B846AC656B5 VEN: Samsung OEM: 0 ID: 514436334D42 [QD63MB] PRV: 0x01 SNN: 998533830 [0x3B846AC6] MF: 5/2019 EMI: FireFly preloader_k61v1_64_bsp.bin with 6 memory type(s) supported EMI: Init EMI from INTERNAL DB EMI: EXT_RAM CFG Passed DA: BOOT to 2nd DA... DA: 2ND stage confirmed DA: SYNC with DA passed DA: Receiving HW info SRAM: 0x0003A500 [ 233.25 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: CID: 150100514436334D42013B846AC656B5 VEN: Samsung OEM: 0 ID: 514436334D42 [QD63MB] PRV: 0x01 SNN: 998533830 [0x3B846AC6] MF: 5/2019 BOOT1: 0x00400000 [ 4.00 MB ] BOOT2: 0x00400000 [ 4.00 MB ] RPMB: 0x01000000 [ 16.00 MB ] USER: 0x747C00000 [ 29.12 GB ] CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] RNID: 2056B6E3096E4149AD7405C1A868DC0A MEID: 92F420763A83ED62C4EF5237CFEFB98D DA: USB: HIGH-SPEED Boot done [1] Reading... Ok SmartInfo: AndroidVer: 8 UserDataFS: 0x02 CacheFS: 0x02 Strategy: 7 Verify device config... Ok Loaders Ok Backup [20] to C:\InfinityBox\CM2MT2\backup\MT6761__92F420763A83E D62C4EF5237CFEFB98D\ [29] Read: NVRAM [8] Read: NVDATA [19] Read: PROINFO [30] Read: LK [7] Read: NVCFG [14] Read: PROTECT1 [1] Read: PGPT [17] Read: PERSIST [0] Read: PRELOADER Done 9 files Compress: C:\InfinityBox\CM2MT2\backup\MT6761__92F420763A83E D62C4EF5237CFEFB98D\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6761__92F420763A83E D62C4EF5237CFEFB98D.7z Verified [1] Process: RESET PROTECTION... Format Ok: RESET PROTECTION [2] Process: USERDATA... Format Ok: USERDATA [3] Process: CACHE... Format Ok: CACHE [4] Verified [5] Verified [6] Process: USERDATA... Format Ok: USERDATA [7] Verified [1] Verified [2] Verified Done: 00:01:13 Reconnect Power/Cable now |
01-14-2023, 09:55 | #73042 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Tecno BB4K Sperak 4 Tecno BB4 SPDxxxx FRP/Pattren Reset Done With King Infinity XM2 Code: Card found : A19EC787 , v0153 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14 Load IDBase v8331 Ok! Operation : Format FS / Reset Settings [ v2.14 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : TECNO : BD4_Pop-5-LTE Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0020 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! FDL : Process authentification ... FDL : SEC : RSA auth passed! FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:26 |
01-14-2023, 14:59 | #73043 (permalink) |
No Life Poster Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Qmobile sp1000 reset password done by cm2 Card found : S/N : 73CA70CC , v0153 Chinese Miracle II [MTK module] v 1.58 Operation : Reset UserCode [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 9 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 087CD88939EDF6F71A765D51257CB74C BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV [0] : FLASH_DIE : 00EF 0070 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Backup done Read ExtData Sorting ExtData Sort Ok, Rebuild Ok Restore ExtData All done UserCode request removed UserCode set to default ( 0000 or 1122 ) Done! Elapsed: 00:00:23 Reconnect Power/Cable! |
01-14-2023, 15:00 | #73044 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | E tachi b13 pro reset password done by cm2 Card found : 73CA70CC , v0153 Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.07 SCRD mode : AUTO SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ] SPRD mode : SC6531 : REV : E001 : NOR : [ 4MB-8MB ] Operation : Format FileSystem [ v1.07 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR 6531EFM v2.0 (c)2019 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [GIGADEVICE] : GD25Q32 : 0x00400000 [ 4MiB ] Make backup of sensetive data Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_106 35436E8AA_NVM.nv Executing FormatFFS ... Format FFS Done! Done! Elapsed: 00:00:21 Reconnect Power/Cable! |
01-14-2023, 15:01 | #73045 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Qmobile l1i classic hang on logo done by cm2 Card found : 73CA70CC , v0153 Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.07 SCRD mode : AUTO SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ] Operation : Reset Settings [ v1.07 ] ----- > Powered On : 1. Power On device 2. Connect USB cable 3. When device show StorageMode : Press '0' button for a 5 second! ----- > Powered Off : 1. Insert USB cable 2. Wait when device show Charge icon 3. When device show StorageMode : Press '0' button for a 5 second! Wait for device ... Device Connected! BOOT_PWR0 : 0x00600000 BOOT_INIT : 0x81C0024C BOOT_MODE : DOWNLOAD Setting BOOTROM mode BOOT_MODE : BOOTROM Boot_CPU : 0x88094007 : [RDA] : RDA8851L MEMD for flsh_spi32m Branch: none Boot_CS0 : 0x161660C8 : SPI : [GIGADEVICE] : GD25Q32 : 0x00400000 [ 4MiB ] Performing MemoryInit Selecting RL Sending RL Config : MemoryInit Config : Loader BOOT_MODE : RLOADER Boot IV : 0xFBA2A2E0 Boot done! Preparing PMT Verifying PMT Erasing 1097728 bytes FileSystem format done! Done! Elapsed: 00:01:33 Reconnect Power/Cable! |
01-14-2023, 15:02 | #73046 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Qmobile i6i spd 6531e reset frp done by cm2 Card found : 73CA70CC , v0153 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14 Load IDBase v8331 Ok! Operation : Format FS / Reset Settings [ v2.14 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0002 FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:17 |
01-14-2023, 16:19 | #73047 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Infinix X688B MT6765 FRP/Pattren Reset Done With King Infinity CM2 Code: Operation: Reset Settings/Format FS [ v2.38c9 ] Platform: MTK SmartPhone - MT65/67/68/81/83/87 | Helio G/P/X Mode: SMART RESET Wait... WARNING! Format FS WILL RESET ALL USER DATA! Make sure about correct format mode selection! Continue? Yes 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port_V1632 (COM18) MODE: BOOTROM; PORT: 18 Waiting BOOT ack... BROM: Skip ACK verify BROM: Init BROM BROM: Init passed CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: 173F1A6347CED68A8F8C8A1024A242B2 BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT BROM: BROM|BL : 0x05|0xFE [BOOTROM] BROM: SOCID: E8C99254551A3FD980B3F0D7321FEA2D74F894513634B24C1339604D91527F17 BROM: SLA: Local Auth BROM: SLA: Starting Auth BROM: FF : Look for EMI BROM: FF : EMI found BROM: SLA: Auth Passed BROM: SEC: 0x000000E0 AGENT: 0_base: base_v2216 | Manual: Off [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_AllInOne_DA.bin Looking for suitable BootChain in DA... Found MT6765 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... BROM: DA sent BROM: Transfer control to DA... DA: AGENT started DA: SYNC DA: MODE: BROM DA: EXT_RAM NOT initialized EMMC: CID: 15010044503644414202633ACA187839 VEN: Samsung OEM: 0 ID: 445036444142 [DP6DAB] PRV: 0x02 SNN: 1664797208 [0x633ACA18] MF: 7/2021 EMI: FireFly preloader_x688b_h659.bin with 20 memory type(s) supported EMI: Init EMI from INTERNAL DB EMI: EXT_RAM CFG Passed DA: BOOT to 2nd DA... DA: 2ND stage confirmed DA: SYNC with DA passed DA: Receiving HW info SRAM 0x0003A000 [ 232.00 KB ] DRAM 0x100000000 [ 4.00 GB ] EMMC: CID: 15010044503644414202633ACA187839 VEN: Samsung OEM: 0 ID: 445036444142 [DP6DAB] PRV: 0x02 SNN: 1664797208 [0x633ACA18] MF: 7/2021 BOOT1: 0x00400000 [ 4.00 MB ] BOOT2: 0x00400000 [ 4.00 MB ] RPMB: 0x01000000 [ 16.00 MB ] USER: 0xE8F800000 [ 58.24 GB ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: F03029837993D73C4C13C53904CA2DB8 MEID: 173F1A6347CED68A8F8C8A1024A242B2 DA: USB: HIGH-SPEED Boot done [1] Reading... Ok Reading... Scan memory... Found region: 23680 [12|23680|0] Scan filesystem... SmartInfo: AndroidVer: 11 UserDataFS: 0x03 CacheFS: 0x02 Strategy: 7 Verify device config... Ok Loaders Ok Backup [20] to C:\InfinityBox\CM2MT2\backup\MT6765__173F1A6347CED68A8F8C8A1024A242B2\ [26] Read: NVRAM [10] Read: NVDATA [3] Read: PROINFO [27] Read: LK [9] Read: NVCFG [12] Read: PROTECT1 [1] Read: PGPT [11] Read: PERSIST [0] Read: PRELOADER Done 9 files Compress: C:\InfinityBox\CM2MT2\backup\MT6765__173F1A6347CED68A8F8C8A1024A242B2\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6765__173F1A6347CED68A8F8C8A1024A242B2.7z Verified Process: RESET PROTECTION... Format Ok: RESET PROTECTION Process: USERDATA... Format Ok: USERDATA Process: CACHE... Format Ok: CACHE Process: USERDATA... Format Ok: USERDATA Process: USERDATA... Format Ok: USERDATA Done: 00:01:36 Reconnect Power/Cable now |
01-15-2023, 06:27 | #73048 (permalink) |
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | X652 frp remove done with cm2 Operation: Reset Settings/Format FS [ v2.39a5 ] Platform: MTK SmartPhone - MT65/67/68/81/83/87 | Helio G/P/X Mode: FRP [ RESET PROTECTION ] Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port (COM25) MODE: BOOTROM; PORT: 25 Waiting BOOT ack... BROM: Skip ACK verify BROM: Init BROM BROM: Init passed CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: 83F6ACC3ECB2BFD9FA52E1071B51CC00 BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT BROM: BROM|BL : 0x05|0xFE [BOOTROM] BROM: SOCID: 34BEF4BFD921618033B4EE59B59766C2CF275F59F730FFE6B8 C26F25196BC77A BROM: SLA: Sending Auth BROM: SLA: Auth accepted BROM: SLA: CHALLENGE not used AGENT: Infinix: X652B-S5-Lite | Manual: Off [83b4f7df] C:\InfinityBox\CM2MT2\boot\Infinix\X652B-S5-Lite\MTK_AllInOne_DA.bin [e2e085c1] C:\InfinityBox\CM2MT2\boot\Infinix\X652B-S5-Lite\auth_sv5_MT6761_V1.auth Looking for suitable BootChain in DA... Found MT6765 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... BROM: DA sent BROM: Transfer control to DA... DA: AGENT started DA: SYNC DA: MODE: BROM DA: EXT_RAM NOT initialized EMMC: CID: 90014A68433961503301C3E371F3B65B VEN: Hynix OEM: 74 ID: 684339615033 [hC9aP3] PRV: 0x01 SNN: 3286462963 [0xC3E371F3] MF: 11/2019 EMI: INFINITY PRELOADER_INFINITY_0 with 3 memory type(s) supported EMI: Init EMI from INTERNAL DB EMI: EXT_RAM CFG Passed DA: BOOT to 2nd DA... DA: 2ND stage confirmed DA: SYNC with DA passed DA: Receiving HW info SRAM: 0x00080000 [ 512.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: CID: 90014A68433961503301C3E371F3B65B VEN: Hynix OEM: 74 ID: 684339615033 [hC9aP3] PRV: 0x01 SNN: 3286462963 [0xC3E371F3] MF: 11/2019 BOOT1: 0x00400000 [ 4.00 MB ] BOOT2: 0x00400000 [ 4.00 MB ] RPMB: 0x01000000 [ 16.00 MB ] USER: 0xE8F800000 [ 58.24 GB ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: 8488B83EC0A58C6F0E8EE038858E0614 MEID: 83F6ACC3ECB2BFD9FA52E1071B51CC00 DA: USB: HIGH-SPEED Boot done [1] Reading... Ok Verify device config... Ok Loaders Ok Backup [20] to C:\InfinityBox\CM2MT2\backup\MT6765__83F6ACC3ECB2B FD9FA52E1071B51CC00\ [12] Read: NVRAM [37] Read: NVDATA [29] Read: PROINFO [13] Read: LK [36] Read: NVCFG [24] Read: PROTECT1 [1] Read: PGPT [23] Read: PERSIST [0] Read: PRELOADER Done 9 files Compress: C:\InfinityBox\CM2MT2\backup\MT6765__83F6ACC3ECB2B FD9FA52E1071B51CC00\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6765__83F6ACC3ECB2B FD9FA52E1071B51CC00.7z Verified [1] Process: RESET PROTECTION... Format Ok: RESET PROTECTION [2] Verified [1] Verified [2] Verified Done: 00:00:50 Reconnect Power/Cable now |
01-15-2023, 06:50 | #73049 (permalink) |
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | Mi Redmi 9c Frp remove Done With cm2 Operation: Reset Settings/Format FS [ v2.39a5 ] Platform: MTK SmartPhone - MT65/67/68/81/83/87 | Helio G/P/X Mode: FRP [ RESET PROTECTION ] Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port (COM25) MODE: BOOTROM; PORT: 25 Waiting BOOT ack... BROM: Skip ACK verify BROM: Init BROM BROM: Init passed CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: 7C8AF0BC118FFC69130CF1BE946757D3 BROM: Sec Level: 0x000000E7 Mode: SBC+SLA+SDA+EXT BROM: BROM|BL : 0x05|0xFE [BOOTROM] BROM: SOCID: 1BFE9744E2B32C67CE54F88EFA0C3DD60B146F79D845B53A7A 9D3E9FEDDA8774 BROM: SLA: Local Auth BROM: SLA: Starting Auth BROM: FF : Look for EMI BROM: FF : EMI found BROM: SLA: Auth Passed BROM: SEC: 0x000000E0 AGENT: 0_base: BASE_v2112 | Manual: Off [0656ff20] C:\InfinityBox\CM2MT2\boot\0_base\BASE_v2112\MTK_A llInOne_DA.bin Looking for suitable BootChain in DA... Found MT6765 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... BROM: DA sent BROM: Transfer control to DA... DA: AGENT started DA: SYNC DA: MODE: BROM DA: EXT_RAM NOT initialized EMMC: CID: 45010044413430363401498B55156799 VEN: Sandisk OEM: 0 ID: 444134303634 [DA4064] PRV: 0x01 SNN: 1233868053 [0x498B5515] MF: 6/2020 EMI: FireFly preloader_k65v1_64_bsp.bin with 10 memory type(s) supported EMI: Init EMI from INTERNAL DB EMI: EXT_RAM CFG Passed DA: BOOT to 2nd DA... DA: 2ND stage confirmed DA: SYNC with DA passed DA: Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: CID: 45010044413430363401498B55156799 VEN: Sandisk OEM: 0 ID: 444134303634 [DA4064] PRV: 0x01 SNN: 1233868053 [0x498B5515] MF: 6/2020 BOOT1: 0x00400000 [ 4.00 MB ] BOOT2: 0x00400000 [ 4.00 MB ] RPMB: 0x01000000 [ 16.00 MB ] USER: 0xE8F800000 [ 58.24 GB ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: 863C9A6E11A9542659E273A0BEEC695D MEID: 7C8AF0BC118FFC69130CF1BE946757D3 DA: USB: HIGH-SPEED Boot done [1] Reading... Ok Verify device config... Ok Loaders Ok Backup [20] to C:\InfinityBox\CM2MT2\backup\MT6765__7C8AF0BC118FF C69130CF1BE946757D3\ [31] Read: NVRAM [13] Read: NVDATA [21] Read: PROINFO [32] Read: LK [12] Read: NVCFG [16] Read: PROTECT1 [1] Read: PGPT [19] Read: PERSIST [0] Read: PRELOADER Done 9 files Compress: C:\InfinityBox\CM2MT2\backup\MT6765__7C8AF0BC118FF C69130CF1BE946757D3\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6765__7C8AF0BC118FF C69130CF1BE946757D3.7z Verified [1] Process: RESET PROTECTION... Format Ok: RESET PROTECTION [2] Verified [1] Verified [2] Verified Done: 00:00:46 Reconnect Power/Cable now |
01-15-2023, 08:15 | #73050 (permalink) |
No Life Poster Join Date: Dec 2009 Location: pakistan
Member: 1189561 Status: Offline Thanks Meter: 743 | INFINX X652B RESET Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM17) MODE : PRELOADER PORT PORT : 17 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT AGENT : Infinix : SECURE_BASE | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA_SWSEC.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: CID : 90014A684339615033016258D85796F3 EMMC: VEN : HYNIX : OEM : 74 : ID : 684339615033 EMMC: VEN : HYNIX : hC9aP3 EMMC: SNN : 1649989719 ( 0x6258D857) , MF : 9/2019 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : C0F65D0ECCBCCB368C73EBC697D54529 DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x815657 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : CACHE Format Ok : USERDATA Done! Elapsed: 00:01:04 Reconnect Power/Cable! |
