07-19-2023, 08:44 | #74536 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Infinix X657B Smart Reset Done Platform: FireFly SmartPhone - MT6580/67:35|39|52|53|61|65|68|71 Format: SMART RESET Wait... WARNING: Reset may clear ALL USER DATA! Continue? Yes 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port_V1632 (COM4) MODE [0]: BOOTROM; PORT: 4 Waiting for BOOT ACK... BROM: Skip ACK verication BROM: Init... Ok CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0200 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] MEID: 08F63A56F1C87BE2C94FDFFDA09A6806 BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: C1D51FDDE533EBA5F9B2959B89BA86AA9E093214C4A5ECCA8A E8C026B7696379 FireFly: Init FireFly: Start Auth Ok FireFly: Continue Auth Ok FireFly: Start Ok FireFly: Init Core Ok FireFly: Running: v06.05.06 on MT6761 eMMC init passed Stored: C:\InfinityBox\CM2MT2\backup\ext_csd\MT6761__Fores ee_58K721_5.1_extcsd_19072023.bin EMMC CID: D6010335384B37323169B138B2242831 VEN: Foresee OEM: 259 ID: 35384B373231 [58K721] PRV: 0x69 SNN: 2973282852 [0xB138B224] MM/YY: 2/2021 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] USER: 0xE67800000 [ 57.62 Gb ] CSD: D0FFFF329F5903FFFFFFFFEF9640002D TEMP_WRITE_PROTECT: Off PERM_WRITE_PROTECT: Off EXTCSD: rev1.8 eMMC 5.1 [CONFIG]: 0x48 0x02 0x01 [PARTITION_CONFIG]: 0x48 [BOOT_BUS_WIDTH]: 0x02 [RST_N_FUNCTION]: 0x01 [PART_S_COMPLETED]: Off [SIZE]: Market: 64 GB [SIZE]: Actual: 0xE67800000 [ 57.62 GB ] [EOL]: EOL status : Normal (Less than 80% reserved blocks used) [EOL_A]: SLC status : 0% - 10% used [EOL_B]: MLC status : Not defined USB: HIGH-SPEED Boot done FireFly Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 41 Select info source... Ok SW: Infinix/X657B-OP-S2/Infinix-X657B:10/QP1A.190711.020/EI-OP-S2-210302V128:user/release-keys Product Brand: Infinix Product Device: Infinix-X657B Product Model: Infinix X657B Product Name: X657B-OP-S2 Patch Level: QP1A.190711.020 Display ID: X657B-H6117EI-QGo-OP-S2-210302V128 SW Version: EI-OP-S2-210302V128 Ver. CodeName: REL Ver. Release: 10 Sec. Patch: 2021-03-05 Build Time: 02-Mar-21 4:36:30 AM CPU: armeabi-v7a,armeabi Product Info: x657b_h6117 SW: full_x657b_h6117-user 10 QP1A.190711.020 82884 release-keys Product Board: Infinix-X657B Board Platform: mt6761 Product Manfct: INFINIX MOBILITY LIMITED Strategy: [none|generic] SmartInfo: Android Ver: 10 UserDataFS: 0x03 [f2fs] CacheFS: 0x02 [ext4|8+] Verify device config... Ok Loaders Ok Stage : ANDROID OS [1] Process RESET PROTECTION... Ok [2] Process USERDATA... Ok [3] Process CACHE... Ok [4] Verified [5] Verified [6] Process USERDATA... Ok [7] Process USERDATA... Ok Stage : FRP Stage : SMART Done: 00:19:01 Reconnect Power/Cable now |
07-19-2023, 09:26 | #74537 (permalink) |
No Life Poster Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Gamma m10 reset password done by cm2 Card found : 73CA70CC , v0155 Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.07 SCRD mode : AUTO SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ] Operation : Identify [ v1.07 ] BootMode : FLASH 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary ERROR : FDL NOT started! Error : Loader send failed! Wrong model selected! Select correct one! Reconnect Power/Cable! SPRD mode : SC6531 : REV : 0000 : NOR : [ 4MB ] Operation : Identify [ v1.07 ] BootMode : FLASH 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR SC6531 Loader v 1.2 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [GIGADEVICE] : GD25Q32 : 0x00400000 [ 4MiB ] IMEI[1] : IMEI[2] : Done! Elapsed: 00:00:33 Reconnect Power/Cable! Operation : Format FileSystem [ v1.07 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR SC6531 Loader v 1.2 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [GIGADEVICE] : GD25Q32 : 0x00400000 [ 4MiB ] Make backup of sensetive data Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_108 4604C60B0_NVM.nv Executing FormatFFS ... Format FFS Done! Done! Elapsed: 00:00:20 Reconnect Power/Cable! |
07-19-2023, 09:27 | #74538 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Vgotel i251 hang on logo done by cm2 Card found : 73CA70CC , v0155 Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.07 SCRD mode : AUTO SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ] SPRD mode : SC6531 : REV : E001 : NOR : [ 4MB-8MB ] Operation : Format FileSystem [ v1.07 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR 6531EFM v2.0 (c)2019 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ] Make backup of sensetive data Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_036 959A70F24_NVM.nv Executing FormatFFS ... Format FFS Done! Done! Elapsed: 00:00:20 Reconnect Power/Cable! |
07-19-2023, 09:28 | #74539 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Lbtel b1 hang on logo done by cm2 Card found : 73CA70CC , v0155 Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.07 SCRD mode : AUTO SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ] SPRD mode : SC6531 : REV : E001 : NOR : [ 4MB-8MB ] Operation : Format FileSystem [ v1.07 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR 6531EFM v2.0 (c)2019 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ] Make backup of sensetive data Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_0E7 BB69A0299_NVM.nv Executing FormatFFS ... Format FFS Done! Done! Elapsed: 00:00:24 Reconnect Power/Cable! |
07-19-2023, 10:35 | #74540 (permalink) |
Freak Poster Join Date: Nov 2013 Location: Infinity Team
Member: 2072265 Status: Offline Thanks Meter: 46 | itel A571l pattern & frp remove done Operation : Format FS / Reset Settings [ v2.14 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : iTel : A571L_A26 Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! FDL : Process authentification ... FDL : SEC : RSA auth passed! FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:25 |
07-19-2023, 18:00 | #74541 (permalink) |
Freak Poster Join Date: Nov 2006 Location: Karachi
Member: 388703 Status: Offline Sonork: sheerazi Thanks Meter: 183 | Samsung A037W Frp Remove [code]Waiting for device connection... PTFN: MediaTek PreLoader USB VCOM (Android) (COM58) MODE: PRELOADER PORT; PORT: 58 Waiting BOOT ack... PRELOADER: ACK confirmed BROM: Init BROM BROM: Init passed CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005 Mode: SBC+SDA BROM: BROM|BL : 0xFF|0x03 [PRELOADER PORT] AGENT: 0_base: base_v2216 | Manual: Off [3365c4d2] C:\CM2MTK\CM2MT2\boot\0_base\base_v2216\MTK_AllInO ne_DA.bin Looking for suitable BootChain in DA... Found MT6765 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... BROM: Reset Interface PTFN: MediaTek USB Port (COM59) MODE: BOOTROM; PORT: 59 Waiting BOOT ack... BROM: Skip ACK verify BROM: Init BROM BROM: Init passed CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: 3A3584F9782239E8AD5E5B7ADBE8CA86 BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT BROM: BROM|BL : 0x05|0xFE [BOOTROM] BROM: SOCID: 9A995C1D894144EEB3E10E237A57B2A2C68737D6E6EBBFCB1B 51C642EB9060D0 BROM: SLA: Local Auth BROM: SLA: Starting Auth BROM: FF : Look for EMI BROM: FF : EMI found BROM: SLA: Auth Passed BROM: SEC: 0x000000E0 AGENT: 0_base: base_v2216 | Manual: Off [3365c4d2] C:\CM2MTK\CM2MT2\boot\0_base\base_v2216\MTK_AllInO ne_DA.bin Looking for suitable BootChain in DA... Found MT6765 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... BROM: DA sent BROM: Transfer control to DA... DA: AGENT started DA: SYNC DA: MODE: BROM DA: EXT_RAM NOT initialized EMMC: CID: 15010047583642414200DC9DCE586953 VEN: Samsung OEM: 0 ID: 475836424142 [GX6BAB] PRV: 0x00 SNN: 3701329496 [0xDC9DCE58] MF: 6/2022 EMI: FireFly preloader_s96516sa1.bin with 2 memory type(s) supported EMI: Init EMI from INTERNAL DB EMI: EXT_RAM CFG Passed DA: BOOT to 2nd DA... DA: 2ND stage confirmed DA: SYNC with DA passed DA: Receiving HW info SRAM 0x0003A000 [ 232.00 KB ] DRAM 0xC0000000 [ 3.00 GB ] EMMC: CID: 15010047583642414200DC9DCE586953 VEN: Samsung OEM: 0 ID: 475836424142 [GX6BAB] PRV: 0x00 SNN: 3701329496 [0xDC9DCE58] MF: 6/2022 BOOT1: 0x00400000 [ 4.00 MB ] BOOT2: 0x00400000 [ 4.00 MB ] RPMB: 0x01000000 [ 16.00 MB ] USER: 0x747C00000 [ 29.12 GB ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: 3F2F6D2D1D968481AAA72E6B665E4274 MEID: 3A3584F9782239E8AD5E5B7ADBE8CA86 DA: USB: HIGH-SPEED Boot done [1] Reading... Ok Device PMT: Offset 0x000000000000 Size 0x000000400000 preloader Offset 0x000000000000 Size 0x000000400000 pgpt Offset 0x000000400000 Size 0x000000800000 efs Offset 0x000000C00000 Size 0x000000800000 sec_efs Offset 0x000001400000 Size 0x000000400000 steady Offset 0x000001800000 Size 0x000004000000 nvram Offset 0x000005800000 Size 0x000000100000 spmfw Offset 0x000005900000 Size 0x000000100000 scp1 Offset 0x000005A00000 Size 0x000000100000 sspm_1 Offset 0x000005B00000 Size 0x000000200000 tee1 Offset 0x000005D00000 Size 0x000000400000 tzar Offset 0x000006100000 Size 0x000001000000 gz1 Offset 0x000007100000 Size 0x000000200000 lk Offset 0x000007300000 Size 0x000000800000 dtbo Offset 0x000007B00000 Size 0x000000010000 vbmeta Offset 0x000007B10000 Size 0x0000004F0000 btd Offset 0x000008000000 Size 0x000000800000 protect1 Offset 0x000008800000 Size 0x000000800000 protect2 Offset 0x000009000000 Size 0x000000800000 seccfg Offset 0x000009800000 Size 0x000002D00000 bota Offset 0x00000C500000 Size 0x000000100000 boot_para Offset 0x00000C600000 Size 0x000000080000 para Offset 0x00000C680000 Size 0x000000080000 misc Offset 0x00000C700000 Size 0x000001400000 expdb Offset 0x00000DB00000 Size 0x000000100000 frp Offset 0x00000DC00000 Size 0x000002000000 nvcfg Offset 0x00000FC00000 Size 0x000004000000 nvdata Offset 0x000013C00000 Size 0x000002000000 metadata Offset 0x000015C00000 Size 0x000001000000 keyrefuge Offset 0x000016C00000 Size 0x000001000000 keydata Offset 0x000017C00000 Size 0x00000169A000 md_udc Offset 0x00001929A000 Size 0x000000080000 persistent Offset 0x00001931A000 Size 0x000000300000 proinfo Offset 0x00001961A000 Size 0x000006400000 md1img Offset 0x00001FA1A000 Size 0x000000800000 logo Offset 0x00002021A000 Size 0x000000400000 param Offset 0x00002061A000 Size 0x000000400000 up_param Offset 0x000020A1A000 Size 0x000003000000 persist Offset 0x000023A1A000 Size 0x000002000000 boot Offset 0x000025A1A000 Size 0x000002500000 recovery Offset 0x000027F1A000 Size 0x000000010000 vbmeta_system Offset 0x000027F2A000 Size 0x000000010000 vbmeta_vendor Offset 0x000027F3A000 Size 0x000000080000 efuse Offset 0x000027FBA000 Size 0x000000046000 rsv1 Offset 0x000028000000 Size 0x000000800000 sec1 Offset 0x000028800000 Size 0x000162E00000 super Offset 0x00018B600000 Size 0x000020000000 prism Offset 0x0001AB600000 Size 0x000000A00000 optics Offset 0x0001AC000000 Size 0x00001F400000 cache Offset 0x0001CB400000 Size 0x000000F00000 omr Offset 0x0001CC300000 Size 0x000003200000 spu Offset 0x0001CF500000 Size 0x000578300000 userdata Offset 0x000747800000 Size 0x000000400000 sgpt Reading... Scan memory... Found region: 33124 [12|33124|0] Scan filesystem... Product Brand: samsung Product Device: a03su Product Model: SM-A037W Product Name: a03sucs SW : samsung/a03sucs/a03su:12/SP1A.210812.016/A037WVLS3BVJ1:user/release-keys Patch Level: SP1A.210812.016 Display ID: SP1A.210812.016.A037WVLS3BVJ1 SW Version: A037WVLS3BVJ1 Ver. CodeName: REL Ver. Release: 12 Sec. Patch: 2022-10-01 Build Time: 04.10.2022 Product Info: a03su SW : a03sucs-user 12 SP1A.210812.016 A037WVLS3BVJ1 release-keys Product Manfct: samsung Product Board: a03su Board Platform: mt6765 Startegy: 3 Firmware ID: MT6765_samsung_SM-A037W_12_SP1A.210812.016.A037WVLS3BVJ1_SP1A.210812 .016_a03su Verify firmware [MT6765_samsung_SM-A037W_12_SP1A.210812.016.A037WVLS3BVJ1_SP1A.210812 .016_a03su]... Firmware is unknown Please upload https://infinity-box.com/?r=100020 NVRAM: TITAN_A03S_NA_R0MP1_K65V1_64_BSP_MDBIN_PCB01_MT676 5_S00.MOLY_LR12A_R3_TC10_6M_A03S_NA_PR_SP_V2_P24 NVRAM: Items: 0xA7 Size: 0x08C3A1 State: Ok WiFi MAC: AA0036004400 BlTh MAC: 4011C36B9A2F IMEI[1]: 502228AE195B52E IMEI[2]: 8D761B46E3E29F5 Verify device config... Ok Loaders Ok STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : NOT Enabled! STORAGE : RPMB Status : eMMC : RPMB KEY PROGRAMMED [UNUSABLE] Done: 00:00:51 Operation: Reset Settings/Format FS [ v2.38d1 ] Platform: MTK SmartPhone - MT65/67/68/81/83/87 | Helio G/P/X Mode: FRP [ RESET PROTECTION ] Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek PreLoader USB VCOM (Android) (COM58) MODE: PRELOADER PORT; PORT: 58 Waiting BOOT ack... PRELOADER: ACK confirmed BROM: Init BROM BROM: Init passed CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005 Mode: SBC+SDA BROM: BROM|BL : 0xFF|0x03 [PRELOADER PORT] AGENT: 0_base: base_v2216 | Manual: Off [3365c4d2] C:\CM2MTK\CM2MT2\boot\0_base\base_v2216\MTK_AllInO ne_DA.bin Looking for suitable BootChain in DA... Found MT6765 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... BROM: Reset Interface PTFN: MediaTek USB Port (COM59) MODE: BOOTROM; PORT: 59 Waiting BOOT ack... BROM: Skip ACK verify BROM: Init BROM BROM: Init passed CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: 3A3584F9782239E8AD5E5B7ADBE8CA86 BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT BROM: BROM|BL : 0x05|0xFE [BOOTROM] BROM: SOCID: 9A995C1D894144EEB3E10E237A57B2A2C68737D6E6EBBFCB1B 51C642EB9060D0 BROM: SLA: Local Auth BROM: SLA: Starting Auth BROM: SLA: Auth Passed BROM: SEC: 0x000000E0 AGENT: 0_base: base_v2216 | Manual: Off [3365c4d2] C:\CM2MTK\CM2MT2\boot\0_base\base_v2216\MTK_AllInO ne_DA.bin Looking for suitable BootChain in DA... Found MT6765 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... BROM: DA sent BROM: Transfer control to DA... DA: AGENT started DA: SYNC DA: MODE: BROM DA: EXT_RAM NOT initialized EMMC: CID: 15010047583642414200DC9DCE586953 VEN: Samsung OEM: 0 ID: 475836424142 [GX6BAB] PRV: 0x00 SNN: 3701329496 [0xDC9DCE58] MF: 6/2022 EMI: FireFly preloader_s96516sa1.bin with 2 memory type(s) supported EMI: Init EMI from INTERNAL DB EMI: EXT_RAM CFG Passed DA: BOOT to 2nd DA... DA: 2ND stage confirmed DA: SYNC with DA passed DA: Receiving HW info SRAM 0x0003A000 [ 232.00 KB ] DRAM 0xC0000000 [ 3.00 GB ] EMMC: CID: 15010047583642414200DC9DCE586953 VEN: Samsung OEM: 0 ID: 475836424142 [GX6BAB] PRV: 0x00 SNN: 3701329496 [0xDC9DCE58] MF: 6/2022 BOOT1: 0x00400000 [ 4.00 MB ] BOOT2: 0x00400000 [ 4.00 MB ] RPMB: 0x01000000 [ 16.00 MB ] USER: 0x747C00000 [ 29.12 GB ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: 3F2F6D2D1D968481AAA72E6B665E4274 MEID: 3A3584F9782239E8AD5E5B7ADBE8CA86 DA: USB: HIGH-SPEED Boot done [1] Reading... Ok Verify device config... Ok Loaders Ok Process: RESET PROTECTION... Format Ok: RESET PROTECTION Done: 00:00:40 Reconnect Power/Cable now [code] |
07-20-2023, 08:45 | #74542 (permalink) |
Member: 2072265 Status: Offline Thanks Meter: 46 | redmi 9c read info & smart reset done With cm2 Operation: Identify Device [ v2.46 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Mode: FLASH Port: Both [ B + P ] [+] Read Deep info: PRL, HW, DEBUG [+] Auto-EMI [+] FireFly UNI-Proto [+] Vendor-Specific Analyzer [-] Local SLA [-] Force BROM Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port (COM4) MODE [0]: BOOTROM; PORT: 4 Waiting for BOOT ACK... BROM: Skip ACK verication BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: 48E440D350B9AD08D38AC6C060492B35 BROM: Sec Level: 0x000000E7 Mode: SBC+SLA+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: 14B023494EDF520C1B5CFCE3C3747F6B80FACFEEC9772F295D D5F66850F2C4AA SLA: Local Auth SLA: Start Auth Ok SLA: Continue Auth Ok FF: Looking for EMI Found SLA: Start 0x15 SLA: Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: 48E440D350B9AD08D38AC6C060492B35 AGENT: AUTO: 0_base: base_v2216 [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_A llInOne_DA.bin Looking for suitable BootChain in DA... Found MT6765 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok DA: Sync... DA: AGENT started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 150100434A544434520424D24C5CC7F7 VEN: Samsung OEM: 256 ID: 434A54443452 [CJTD4R] PRV: 0x04 SNN: 617761884 [0x24D24C5C] MM/YY: 12/2020 EMI: Init Ok EMI: FireFly preloader_k65v1_64_bsp.bin with 11 memory type(s) 1. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 512.00 Mb 2. eMMC LP_DDR4X ID: 90014A68423861503E Ven: Hynix | Dev: hB8aP> RAM: 3.00 Gb 3. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 2.00 Gb 4. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 2.00 Gb 5. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 4.00 Gb 6. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 4.00 Gb 7. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 3.00 Gb 8. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 4.00 Gb 9. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 6.00 Gb 10. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 2.00 Gb 11. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 3.00 Gb EMI: EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... RAM: SRAM: 0x0003A000 [ 232.00 Kb ] RAM: DRAM: 0xC0000000 [ 3.00 Gb ] EMMC CID: 150100434A544434520424D24C5CC7F7 VEN: Samsung OEM: 256 ID: 434A54443452 [CJTD4R] PRV: 0x04 SNN: 617761884 [0x24D24C5C] MM/YY: 12/2020 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: F027EFB6385443B34099317508B3F7B7 MEID: 48E440D350B9AD08D38AC6C060492B35 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 43 Select info source... Ok SW: Redmi/angelica_global/angelica:10/QP1A.190711.020/V12.0.15.0.QCRMIXM:user/release-keys Product Brand: Redmi Product Device: angelica Product Model: M2006C3MG Product Name: angelica_global Patch Level: QP1A.190711.020 Display ID: QP1A.190711.020 SW Version: V12.0.15.0.QCRMIXM Ver. CodeName: REL Ver. Release: 10 Sec. Patch: 2021-06-01 Build Time: 7/4/2021 3:35:46 PM CPU: armeabi-v7a,armeabi Product Info: angelica SW: angelica-user 10 QP1A.190711.020 V12.0.15.0.QCRMIXM release-keys Product Manfct: Xiaomi Product Board: angelica Board Platform: mt6765 Strategy: [xiaomi] Firmware ID: MT6765_Xiaomi_M2006C3MG_OSv10_V12.0.15.0.QCRMIXM_Q P1A.190711.020_angelica_Redmi Verify firmware [MT6765_Xiaomi_M2006C3MG_OSv10_V12.0.15.0.QCRMIXM_Q P1A.190711.020_angelica_Redmi]... Firmware is unknown Please upload https://infinity-box.com/?r=100020 Analyze userdata... userData: fileSystem : [f2fs] with FBE [file based encryption] Analyze modem... LCSH_Q0MP1_MT6765_SP_MDBIN_PCB01_MT6765_S00.MOLY_L R12A_R3_MP_V107_5_P99 Analyze nvram... NVRAM: Items: 0xB4 Size: 0x0ADDD0 [SecLv: Vendor Signed] State: Ok WiFi MAC: 000000000000 BlTh MAC: A45590E0F1EB IMEI[1]: 865233051874569 IMEI[2]: 865233051874577 Verify device config... Ok Loaders Ok Backup to C:\InfinityBox\CM2MT2\backup\MT6765__48E440D350B9A D08D38AC6C060492B35\ Items to check: 20 Read [31] NVRAM Read [13] NVDATA Read [21] PROINFO Read [32] LK Read [12] NVCFG Read [16] PROTECT1 Read [1] PGPT Read [19] PERSIST Read [0] PRELOADER Done 9 files Compress: C:\InfinityBox\CM2MT2\backup\MT6765__48E440D350B9A D08D38AC6C060492B35\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6765__48E440D350B9A D08D38AC6C060492B35.7z Verified STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : UNLOCKED! STORAGE : RPMB Status : eMMC : RPMB KEY PROGRAMMED [UNUSABLE] Analyze preloader... EMI: MT6765 preloader_k65v1_64_bsp.bin with 11 memory type(s) 1. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 512.00 Mb 2. eMMC LP_DDR4X ID: 90014A68423861503E Ven: Hynix | Dev: hB8aP> RAM: 3.00 Gb 3. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 2.00 Gb 4. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 2.00 Gb 5. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 4.00 Gb 6. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 4.00 Gb 7. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 3.00 Gb 8. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 4.00 Gb 9. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 6.00 Gb 10. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 2.00 Gb 11. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 3.00 Gb Preloader saved: C:\InfinityBox\CM2MT2\backup\preloader\preloader_k 65v1_64_bsp.bin Verify C:\InfinityBox\CM2MT2\backup\preloader\preloader_k 65v1_64_bsp.bin [19a112ca]... Exist Done: 00:00:51 Reconnect Power/Cable now Reset Mode: Safe Reset by device requirements: UserData + FRP + Account(s) Operation: Reset Settings/Format FS [ v2.46 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Format: SMART RESET Wait... WARNING: Reset may clear ALL USER DATA! Continue? Yes 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port (COM4) MODE [0]: BOOTROM; PORT: 4 Waiting for BOOT ACK... BROM: Skip ACK verication BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: 48E440D350B9AD08D38AC6C060492B35 BROM: Sec Level: 0x000000E7 Mode: SBC+SLA+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: 14B023494EDF520C1B5CFCE3C3747F6B80FACFEEC9772F295D D5F66850F2C4AA SLA: Local Auth SLA: Start Auth Ok SLA: Continue Auth Ok EMI known SLA: Start 0x15 SLA: Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: 48E440D350B9AD08D38AC6C060492B35 AGENT: AUTO: 0_base: base_v2216 [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_A llInOne_DA.bin Looking for suitable BootChain in DA... Found MT6765 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok DA: Sync... DA: AGENT started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 150100434A544434520424D24C5CC7F7 VEN: Samsung OEM: 256 ID: 434A54443452 [CJTD4R] PRV: 0x04 SNN: 617761884 [0x24D24C5C] MM/YY: 12/2020 EMI: Init Ok EMI: FireFly preloader_k65v1_64_bsp.bin with 11 memory type(s) 1. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 512.00 Mb 2. eMMC LP_DDR4X ID: 90014A68423861503E Ven: Hynix | Dev: hB8aP> RAM: 3.00 Gb 3. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 2.00 Gb 4. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 2.00 Gb 5. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 4.00 Gb 6. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 4.00 Gb 7. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 3.00 Gb 8. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 4.00 Gb 9. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 6.00 Gb 10. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 2.00 Gb 11. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 3.00 Gb EMI: EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... RAM: SRAM: 0x0003A000 [ 232.00 Kb ] RAM: DRAM: 0xC0000000 [ 3.00 Gb ] EMMC CID: 150100434A544434520424D24C5CC7F7 VEN: Samsung OEM: 256 ID: 434A54443452 [CJTD4R] PRV: 0x04 SNN: 617761884 [0x24D24C5C] MM/YY: 12/2020 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: F027EFB6385443B34099317508B3F7B7 MEID: 48E440D350B9AD08D38AC6C060492B35 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 43 Select info source... Ok SW: Redmi/angelica_global/angelica:10/QP1A.190711.020/V12.0.15.0.QCRMIXM:user/release-keys Product Brand: Redmi Product Device: angelica Product Model: M2006C3MG Product Name: angelica_global Patch Level: QP1A.190711.020 Display ID: QP1A.190711.020 SW Version: V12.0.15.0.QCRMIXM Ver. CodeName: REL Ver. Release: 10 Sec. Patch: 2021-06-01 Build Time: 7/4/2021 3:35:46 PM CPU: armeabi-v7a,armeabi Product Info: angelica SW: angelica-user 10 QP1A.190711.020 V12.0.15.0.QCRMIXM release-keys Product Manfct: Xiaomi Product Board: angelica Board Platform: mt6765 Strategy: [xiaomi] SmartInfo: Android Ver: 10 UserDataFS: 0x03 [f2fs] CacheFS: 0x02 [ext4|8+] Verify device config... Ok Loaders Ok Backup exist: C:\InfinityBox\CM2MT2\backup\MT6765__48E440D350B9A D08D38AC6C060492B35 Stage : ANDROID OS [1] Process RESET PROTECTION... Ok [2] Process USERDATA... Ok [3] Process CACHE... Ok [4] Verified [5] Verified [6] Process USERDATA... Ok [7] Process USERDATA... Ok Stage : FRP Stage : SMART Format Vendor Extra Ok Done: 00:00:35 Reconnect Power/Cable now |
07-20-2023, 09:15 | #74543 (permalink) |
Member: 2072265 Status: Offline Thanks Meter: 46 | vgotel i251 format done Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 4 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 9C8D854291044B818BDA43002528DC2F BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV [0] : FLASH_DIE : 00EF 0070 0016 0000 [0] : FLASH_LEN : 0x00300000 SDS_INFO : 0x002FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Backup done Executing FFS FORMAT now... FAT_RANGE : 0x002A7000-0x002FDFFF , LEN : 0x00057000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Done! Elapsed: 00:00:12 Reconnect Power/Cable! |
07-20-2023, 09:18 | #74544 (permalink) |
Member: 2072265 Status: Offline Thanks Meter: 46 | vgotel i music formate done Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 4 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : EDA8F4ED7D04AF7D3D2D388990CEDC41 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV [0] : FLASH_DIE : 00EF 0070 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Backup done Executing FFS FORMAT now... FAT_RANGE : 0x0039C000-0x003FDFFF , LEN : 0x00062000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Done! Elapsed: 00:00:11 Reconnect Power/Cable! |
07-20-2023, 10:39 | #74545 (permalink) |
Member: 2072265 Status: Offline Thanks Meter: 46 | sl100 lite format done Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 4 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CA02 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 74693BD94A3509E4148FB012B8E05E9C BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV [0] : FLASH_DIE : 00EF 0070 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Backup done Executing FFS FORMAT now... FAT_RANGE : 0x003A5000-0x003FDFFF , LEN : 0x00059000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Done! Elapsed: 00:00:10 Reconnect Power/Cable! |
07-20-2023, 10:57 | #74546 (permalink) |
Member: 2072265 Status: Offline Thanks Meter: 46 | Qsmart 4g plsu format done Operation : Format FS / Reset Settings [ v2.14 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC9820E_BASE : SC9820e_eMMC_512MB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0002 FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:01:16 |
07-20-2023, 11:49 | #74547 (permalink) |
Member: 2072265 Status: Offline Thanks Meter: 46 | tecno bc1s frp remove done with cm2 Operation: Reset Settings/Format FS [ v2.46 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Format: FRP [ RESET PROTECTION ] Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port (COM4) MODE [0]: BOOTROM; PORT: 4 Waiting for BOOT ACK... BROM: Skip ACK verication BROM: Init... Ok CHIP: MT6739 SBID: 0x8A00 HWVR: 0xCB00 SWVR: 0x0002 EVOL: 0x0000 HWC: 0x0699 CODE: Zion TYPE: MODERN [RAPHAEL] MEID: 002D99D745436B653FB77F756616709D BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: EAFB70732BB1E185342386B6D0DD1C4E93205B995B1AB47C6B F5D58C79B80DAF SLA: Local Auth SLA: Start Auth Ok SLA: Continue Auth Ok FF: Looking for EMI Found SLA: Start 0x15 SLA: Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: 002D99D745436B653FB77F756616709D AGENT: AUTO: 0_base: base_v2216 [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_A llInOne_DA.bin Looking for suitable BootChain in DA... Found MT6739 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok DA: Sync... DA: AGENT started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMI: Init Ok EMI: FireFly preloader_k39tv1_bsp.bin with 3 memory type(s) 1. eMMC DDR3 ID: 150100515836334142 Ven: Samsung | Dev: QX63AB RAM: 2.00 Gb 2. eMMC DDR3 ID: 700100474D424D4541 Ven: Kingston | Dev: GMBMEA RAM: 2.00 Gb 3. eMMC DDR3 ID: 150100514436334D42 Ven: Samsung | Dev: QD63MB RAM: 2.00 Gb EMI: EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... RAM: SRAM: 0x00020000 [ 128.00 Kb ] RAM: DRAM: 0x80000000 [ 2.00 Gb ] EMMC CID: 1501005158363341420349C9BE7F18DF VEN: Samsung OEM: 256 ID: 515836334142 [QX63AB] PRV: 0x03 SNN: 1237958271 [0x49C9BE7F] MM/YY: 1/2021 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0x747C00000 [ 29.12 Gb ] CHIP: MT6739 SBID: 0x8A00 HWVR: 0xCB00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0699 CODE: Zion TYPE: MODERN [RAPHAEL] RNID: D005840F53A44F374FBEE3588B83640A MEID: 002D99D745436B653FB77F756616709D USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 38 Select info source... Ok SW: TECNO/BC1s-OP/TECNO-BC1s:10/QP1A.190711.020/AB-OP-220510V016:user/release-keys Product Brand: TECNO Product Model: TECNO BC1s Product Name: BC1s-OP Product Device: TECNO-BC1s Product Board: BC1s Patch Level: QP1A.190711.020 Display ID: BC1s-VQ653AB-QGo-OP-220510V016 SW Version: AB-OP-220510V016 Ver. CodeName: REL Ver. Release: 10 Sec. Patch: 2022-05-05 Build Time: 5/18/2022 9:14:27 AM CPU: armeabi-v7a,armeabi Product Info: k39tv1_bsp SW: full_k39tv1_bsp-user 10 QP1A.190711.020 1652865291 release-keys Product Board: k39tv1_bsp Board Platform: mt6739 Product Manfct: TECNO MOBILE LIMITED Strategy: [none|generic] Verify device config... Ok Loaders Ok Backup to C:\InfinityBox\CM2MT2\backup\MT6739__002D99D745436 B653FB77F756616709D\ Items to check: 20 Read [26] NVRAM Read [11] NVDATA Read [19] PROINFO Read [27] LK Read [10] NVCFG Read [14] PROTECT1 Read [1] PGPT Read [17] PERSIST Read [0] PRELOADER Done 9 files Compress: C:\InfinityBox\CM2MT2\backup\MT6739__002D99D745436 B653FB77F756616709D\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6739__002D99D745436 B653FB77F756616709D.7z Verified Stage : ANDROID OS [1] Process RESET PROTECTION... Ok [2] Verified Stage : FRP Done: 00:00:53 Reconnect Power/Cable now |
07-20-2023, 12:07 | #74548 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Tecno Spark 7 KF6k Smart Reset Done Operation: Reset Settings/Format FS [ v2.46 ] Platform: FireFly SmartPhone - MT6580/67:35|39|52|53|61|65|68|71 Format: SMART RESET Wait... WARNING: Reset may clear ALL USER DATA! Continue? Yes 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port_V1632 (COM6) MODE [0]: BOOTROM; PORT: 6 Waiting for BOOT ACK... BROM: Skip ACK verication BROM: Init... Ok CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] MEID: 5C895A83AC4B86FFABE3E8F5989D4EE5 BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: 8232669F349F503D820BE2D448D9C3CAAAFB8A5A071143BA95 481322202187CF FireFly: Init FireFly: Start Auth Ok FireFly: Continue Auth Ok FireFly: Start Ok FireFly: Init Core Ok FireFly: Running: v06.05.06 on MT6768 eMMC init passed File exist, skip: C:\InfinityBox\CM2MT2\backup\ext_csd\MT6768__Hynix _hC9aP3_5.1_extcsd_20072023.bin EMMC CID: 90014A68433961503301004FDD4538F7 VEN: Hynix OEM: 330 ID: 684339615033 [hC9aP3] PRV: 0x01 SNN: 5233989 [0x004FDD45] MM/YY: 3/2021 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] CSD: D02700328F5903FFFFFFFFEF8E400043 TEMP_WRITE_PROTECT: Off PERM_WRITE_PROTECT: Off EXTCSD: rev1.8 eMMC 5.1 [CONFIG]: 0x48 0x02 0x01 [PARTITION_CONFIG]: 0x48 [BOOT_BUS_WIDTH]: 0x02 [RST_N_FUNCTION]: 0x01 [PART_S_COMPLETED]: Off [SIZE]: Market: 64 GB [SIZE]: Actual: 0xE8F800000 [ 58.24 GB ] [EOL]: EOL status : Normal (Less than 80% reserved blocks used) [EOL_A]: SLC status : Not defined [EOL_B]: MLC status : 0% - 10% used USB: HIGH-SPEED Boot done FireFly Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 51 Select info source... Ok SW: TECNO/KF6k-OP/TECNO-KF6k:11/RP1A.200720.011/210715V278:user/release-keys Product Brand: TECNO Product Device: TECNO-KF6k Product Model: TECNO KF6k Product Name: KF6k-OP Patch Level: RP1A.200720.011 Display ID: KF6k-H696AeAgAfAh-R-OP-210715V278 SW Version: 210715V278 Ver. CodeName: REL Ver. Release: 11 Sec. Patch: 2021-07-05 Build Time: 15-Jul-21 1:13:10 PM CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Info: kf6k_h696 SW: vnd_kf6k_h696-user 11 RP1A.200720.011 130921 release-keys Product Board: TECNO-KF6k Board Platform: mt6768 Product Manfct: TECNO MOBILE LIMITED Strategy: [none|generic] SmartInfo: Android Ver: 11 UserDataFS: 0x03 [f2fs] CacheFS: 0x02 [ext4|8+] Verify device config... Ok Loaders Ok Stage : ANDROID OS [1] Process RESET PROTECTION... Ok [2] Process USERDATA... Ok [3] Verified [4] Verified [5] Verified [6] Process USERDATA... Ok [7] Process USERDATA... Ok Stage : FRP Stage : SMART Done: 00:01:19 Reconnect Power/Cable now |
07-20-2023, 12:22 | #74549 (permalink) |
Member: 2072265 Status: Offline Thanks Meter: 46 | infinix x660 flash done with cm2 Operation: Write Flash [ v2.46 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Wait... [+] Update PMT [re-Part] [-] Checksum Verify [+] Safe Erase [Upgrade] [+] Check compatibility [+] Backup [-] UserData Safe [-] FLASH ERASE Files: 22 [FL]: C:\Users\Ahmed gsm\Downloads\Compressed\X660B-H653DE-Q-OP-201216V546(MobiFirmware.com)\X660B-H653DE-Q-OP-201216V546(MobiFirmware.com)\ tkv.img [ 1.00 Mb ] recovery.img [ 39.00 Mb ] md1img-verified.img [ 48.71 Mb ] spmfw-verified.img [ 62.58 Kb ] scp-verified.img [ 559.28 Kb ] scp-verified.img [ 559.28 Kb ] sspm-verified.img [ 422.72 Kb ] sspm-verified.img [ 422.72 Kb ] lk-verified.img [ 853.14 Kb ] lk-verified.img [ 853.14 Kb ] boot.img [ 32.00 Mb ] logo-verified.bin [ 430.73 Kb ] dtbo-verified.img [ 8.00 Mb ] tee-verified.img [ 2.16 Mb ] tee-verified.img [ 2.16 Mb ] vbmeta.img [ 4.00 Kb ] vbmeta_system.img [ 4.00 Kb ] vbmeta_vendor.img [ 4.00 Kb ] super.img [ 4.01 Gb ] cache.img [ 136.17 Kb ] tranfs.img [ 136.17 Kb ] userdata.img [ 2.23 Mb ] Total size: 0x1095001E0 [ 4.15 Gb ] SW: Infinix/X660B-OP/Infinix-X660B:10/QP1A.190711.020/DE-OP-201216V546:user/release-keys Product Brand: Infinix Product Device: Infinix-X660B Product Model: Infinix X660B Product Name: X660B-OP Patch Level: QP1A.190711.020 Display ID: X660B-H653DE-Q-OP-201216V546 SW Version: DE-OP-201216V546 Ver. CodeName: REL Ver. Release: 10 Sec. Patch: 2020-12-05 Build Time: 12/16/2020 2:20:19 AM CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Info: x660b_h653 SW: full_x660b_h653-user 10 QP1A.190711.020 58836 release-keys Product Board: Infinix-X660B Board Platform: mt6765 Product Manfct: INFINIX MOBILITY LIMITED Firmware ID: MT6765_INFINIX_MOBILITY_LIMITED_Infinix_X660B_OSv1 0_X660B-H653DE-Q-OP-201216V546_QP1A.190711.020_x660b_h653 Verify firmware [X660B-H653DE-Q-OP-201216V546(MobiFirmware.com)]... Verify firmware [MT6765_INFINIX_MOBILITY_LIMITED_Infinix_X660B_OSv1 0_X660B-H653DE-Q-OP-201216V546_QP1A.190711.020_x660b_h653]... Firmware is unknown Please upload https://infinity-box.com/?r=100020 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek PreLoader USB VCOM (Android) (COM23) MODE [0]: PRELOADER PORT; PORT: 23 Waiting for BOOT ACK... PRELOADER ACK Ok BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005 Mode: SBC+SDA VER: 0xFF BL: 0x03 [PRELOADER PORT] AGENT: AUTO: 0_base: base_v2216 [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_A llInOne_DA.bin [4f621218] C:\Users\Ahmed gsm\Downloads\Compressed\X660B-H653DE-Q-OP-201216V546(MobiFirmware.com)\X660B-H653DE-Q-OP-201216V546(MobiFirmware.com)\preloader_x660b_h653. bin Looking for suitable BootChain in DA... Found MT6765 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... Reset Interface PTFN: MediaTek USB Port (COM4) MODE [0]: BOOTROM; PORT: 4 Waiting for BOOT ACK... BROM: Skip ACK verication BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: 04E8E2BFD2D3A6553CE5BE37CC4400F8 BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: 438EEFBAD96C525345F4A360FCC8344E4A723D17981C208A3E 07596217317441 SLA: Local Auth SLA: Start Auth Ok SLA: Continue Auth Ok EMI known SLA: Start 0x15 SLA: Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: 04E8E2BFD2D3A6553CE5BE37CC4400F8 AGENT: AUTO: 0_base: base_v2216 [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_A llInOne_DA.bin [4f621218] C:\Users\Ahmed gsm\Downloads\Compressed\X660B-H653DE-Q-OP-201216V546(MobiFirmware.com)\X660B-H653DE-Q-OP-201216V546(MobiFirmware.com)\preloader_x660b_h653. bin Looking for suitable BootChain in DA... Found MT6765 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok DA: Sync... DA: AGENT started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 90014A684339615033014224180F273B VEN: Hynix OEM: 330 ID: 684339615033 [hC9aP3] PRV: 0x01 SNN: 1109661711 [0x4224180F] MM/YY: 2/2020 EMI: Init Ok EMI: FireFly preloader_x660b_h653.bin with 15 memory type(s) 1. eMMC LP_DDR4X ID: 90014A684445615033 Ven: Hynix | Dev: hDEaP3 RAM: 6.00 Gb 2. eMMC LP_DDR4X ID: 150100444836444D42 Ven: Samsung | Dev: DH6DMB RAM: 4.00 Gb 3. eMMC LP_DDR4X ID: 150100444836444142 Ven: Samsung | Dev: DH6DAB RAM: 4.00 Gb 4. eMMC LP_DDR4X ID: 150100334836434142 Ven: Samsung | Dev: 3H6CAB RAM: 6.00 Gb 5. eMMC LP_DDR4X ID: 150100335636434D42 Ven: Samsung | Dev: 3V6CMB RAM: 6.00 Gb 6. eMMC LP_DDR4X ID: 90014A484347386134 Ven: Hynix | Dev: HCG8a4 RAM: 4.00 Gb 7. eMMC LP_DDR4X ID: 90014A484347386134 Ven: Hynix | Dev: HCG8a4 RAM: 6.00 Gb 8. eMMC LP_DDR4X ID: 90014A68433861503E Ven: Hynix | Dev: hC8aP> RAM: 4.00 Gb 9. eMMC LP_DDR4X ID: 90014A68433861503E Ven: Hynix | Dev: hC8aP> RAM: 6.00 Gb 10. eMMC LP_DDR4X ID: 90014A684339615033 Ven: Hynix | Dev: hC9aP3 RAM: 4.00 Gb 11. eMMC LP_DDR4X ID: 90014A68433861503E Ven: Hynix | Dev: hC8aP> RAM: 3.00 Gb 12. eMMC LP_DDR4X ID: 150100445036384D42 Ven: Samsung | Dev: DP68MB RAM: 3.00 Gb 13. eMMC LP_DDR4X ID: 13014E53304A394B39 Ven: Micron | Dev: S0J9K9 RAM: 4.00 Gb 14. eMMC LP_DDR4X ID: 150100445636444142 Ven: Samsung | Dev: DV6DAB RAM: 4.00 Gb 15. eMMC LP_DDR4X ID: 150100445036444142 Ven: Samsung | Dev: DP6DAB RAM: 4.00 Gb EMI: EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... RAM: SRAM: 0x0003A000 [ 232.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 90014A684339615033014224180F273B VEN: Hynix OEM: 330 ID: 684339615033 [hC9aP3] PRV: 0x01 SNN: 1109661711 [0x4224180F] MM/YY: 2/2020 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: 1E4DD7AB159D05E8BA4244EBEF065AA3 MEID: 04E8E2BFD2D3A6553CE5BE37CC4400F8 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] HW verification... HW verification Pass Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 41 Verify device config... Ok Loaders Ok Pre-Flash backup... Backup exist: C:\InfinityBox\CM2MT2\backup\MT6765__04E8E2BFD2D3A 6553CE5BE37CC4400F8 Verify PMT... Ok Verify SEC DL... Pre-Erase... Erase: 0x0000000000000000 0x0000000000108000 Erase: 0x0000000000408000 0x0000000004C1A000 Erase: 0x0000000007022000 0x00000000047DE000 Erase: 0x000000000F800000 0x000000000BB00000 Erase: 0x000000001F300000 0x00000001F5500000 RePartition... RePartition: Ok Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 41 Flash write... Write: TKV [ 1.00 Mb ] Write: RECOVERY [ 39.00 Mb ] Ok Write: MD1IMG [ 48.71 Mb ] Write: SPMFW [ 62.58 Kb ] Ok Write: SCP1 [ 559.28 Kb ] Ok Write: SCP2 [ 559.28 Kb ] Ok Write: SSPM_1 [ 422.72 Kb ] Ok Write: SSPM_2 [ 422.72 Kb ] Ok Write: LK [ 853.14 Kb ] Ok Write: LK2 [ 853.14 Kb ] Ok Write: BOOT [ 32.00 Mb ] Ok Write: LOGO [ 430.73 Kb ] Ok Write: DTBO [ 8.00 Mb ] Ok Write: TEE1 [ 2.16 Mb ] Ok Write: TEE2 [ 2.16 Mb ] Ok Write: VBMETA [ 4.00 Kb ] Ok Write: VBMETA_SYSTEM [ 4.00 Kb ] Ok Write: VBMETA_VENDOR [ 4.00 Kb ] Ok Write: SUPER [ 4.01 Gb ] Ok Write: CACHE [ 136.17 Kb ] Ok Write: TRANFS [ 136.17 Kb ] Write: USERDATA [ 2.23 Mb ] Ok RePartition... RePartition: Ok Flashing finished Done: 00:04:02 Reconnect Power/Cable now |
07-20-2023, 17:49 | #74550 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Infinix X670 One Click FRP/Pattren Reset Done With King Infinity CM2 Code: S/N: A19EC787 v0155 Chinese Miracle II - MT2 Service Tool v2.46 Init log engine... Ok Build directories tree... Ok Firmware files: G:\Jazz Firmware\JazzDigit4G Bold MT6739\MT6739__alps__t6731__0__t_M42445P_DG_B138_SW02_20210401_2055__58K__git4G-Bold\ Backup files: C:\InfinityBox\CM2MT2\backup\ Backup files: 26 dirs: 0 Verify device database... BuiltIn: 28 Custom: 0 Build device list... Ok Scan 76 profiles... Ok Init environment... Ok Load IDBase v418494 Ok DA selected: Ibrit | Alpha-AF51 | MTK_AllInOne_DA.bin DA selected: Infinix | 2023-05 | MTK_AllInOne_DA.bin Preloader Mode without testpoint/disassembly MT6739, MT6761, MT6763, MT6765, MT6768, MT6781, MT6785, MT6833, MT6877, MT6893 Operation: Reset Settings/Format FS [ v2.46 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Format: SMART RESET Wait... WARNING: Reset may clear ALL USER DATA! Continue? Yes 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek PreLoader USB VCOM (Android) (COM208) MODE [0]: PRELOADER PORT; PORT: 208 Waiting for BOOT ACK... PRELOADER ACK Ok BROM: Init... Ok CHIP: MT6781 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x1066 CODE: Lagrange TYPE: NEXTGEN [LUCI] BROM: Sec Level: 0x00000005 Mode: SBC+SDA VER: 0xFF BL: 0x03 [PRELOADER PORT] AGENT: AUTO: Infinix: 2023-05 [caf6df7e] C:\InfinityBox\CM2MT2\boot\Infinix\2023-05\MTK_AllInOne_DA.bin Looking for suitable BootChain in DA... Found MT6781 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok DA: Sync... DA: AGENT started DA: SYNC MODE: PRELOADER EXT_RAM initialized DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... RAM: SRAM: 0x00060000 [ 384.00 Kb ] RAM: DRAM: 0x200000000 [ 8.00 Gb ] UFS CID: AD014839485131354146414D42444152 VEN: 0x01AD VID: H9HQ15AFAMBDAR IFW: A043 LU0: 0x00400000 [ 4.00 Mb ] LU1: 0x00400000 [ 4.00 Mb ] LU2: 0x1DCB000000 [ 119.17 Gb ] FSN: 2104336B71E0 REG: 0x101010000 CHIP: MT6781 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x1066 CODE: Lagrange TYPE: NEXTGEN [LUCI] RNID: D9B10DFB671C658363CA3987E01813BB USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 51 Select info source... Ok Product Brand: Infinix Product Device: Infinix-X670 Product Model: Infinix X670 Product Name: X670-GL SW: Infinix/X670-GL/Infinix-X670:12/SP1A.210812.016/220922V1140:user/release-keys Patch Level: SP1A.210812.016 Display ID: X670-H814DGHJKL-S-GL-220922V1140 SW Version: 220922V1140 Ver. CodeName: REL Ver. Release: 12 Sec. Patch: 2022-09-05 Build Time: 22/09/2022 5:11:40 pm Product Info: x670_h814 SW: vnd_x670_h814-user 12 SP1A.210812.016 103276 release-keys Product Manfct: INFINIX Product Board: Infinix-X670 Board Platform: mt6781 Strategy: [none|generic] SmartInfo: Android Ver: 12 UserDataFS: 0x03 [f2fs] CacheFS: 0x02 [ext4|8+] Verify device config... Ok Loaders Ok Backup to C:\InfinityBox\CM2MT2\backup\MT6781__D9B10DFB671C658363CA3987E01813BB\ Items to check: 20 Read [36] NVRAM Read [9] NVDATA Read [3] PROINFO Read [8] NVCFG Read [19] PROTECT1 Read [1] PGPT Read [18] PERSIST Read [0] PRELOADER Done 8 files Compress: C:\InfinityBox\CM2MT2\backup\MT6781__D9B10DFB671C658363CA3987E01813BB\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6781__D9B10DFB671C658363CA3987E01813BB.7z Verified Stage : ANDROID OS [1] Process RESET PROTECTION... Ok [2] Process USERDATA... Ok [3] Verified [4] Verified [5] Verified [6] Process USERDATA... Ok [7] Process USERDATA... Ok Stage : FRP Stage : SMART Done: 00:00:49 Reconnect Power/Cable now |
