12-26-2010, 15:18 | #7561 (permalink) |
No Life Poster Join Date: Sep 2007 Location: Jalandhar Age: 39
Member: 580966 Status: Offline Sonork: 100.1590311 Thanks Meter: 725 | Code: ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:8803:000B status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is absent rom info detection finished rom info ver: 05 sw version: JWT_Z101B_001_PCB01_GPRS_MT6225_S00.LB0MM06_8_32_1_1T08M0106_M570.BIN project-id: LB0MM06.8.32.1.1T08M0106_M570, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [standard] type (05) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF firmware area: 00000000-00DFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: JWT_Z101B_001_PCB01_GPRS_MT6225_S00.LB0MM06_8_32_1_1T08M0106_M570__ffs... file saved: C:\Documents and Settings\KK Mobile\Desktop\JWT_Z101B_001_PCB01_GPRS_MT6225_S00.LB0MM06_8_32_1_1T08M0106_M570__ffs_20101223-111422.B0E.bin flash: 98000300000001:18E59F00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98000300000001:18E59F00000000 Finalization Done Finished, time used: 2 min 7 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
12-26-2010, 15:18 | #7562 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Bangladesh
Member: 621121 Status: Offline Thanks Meter: 366 | Dead repair success by format ffs Code: COM2 [VCP0] selected module v3.24 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:FDE0:80D4 status: FF high speed boot Off boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 detecting chip #02 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 detecting chip #03 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent rom info detection finished rom info ver: 04 sw version: HEDY26_05C_PCB01_GPRS_MT6226_S01.MAUI_05C_W06_12_M33A_VM_6_19.BIN project-id: MAUI.05C.W06.12.M33A.VM.6.19, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [standard] type (04) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF firmware area: 00000000-00DFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: HEDY26_05C_PCB01_GPRS_MT6226_S01.MAUI_05C_W06_12_M33A_VM_6_19__ffs... file saved: C:\Users\AlaM\Desktop\HEDY26_05C_PCB01_GPRS_MT6226_S01.MAUI_05C_W06_12_M33A_VM_6_19__ffs_20101018-140914.B0E.bin flash: 01227E22202200:29EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 01227E22202200:29EA0000000000 Finalization Done Finished, time used: 2 min 5 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
12-26-2010, 15:18 | #7563 (permalink) |
Freak Poster Join Date: Sep 2010 Location: searching Age: 39
Member: 1404229 Status: Offline Sonork: 100.1612419 Thanks Meter: 44 | COM6 [VCP4] selected module v3.70 Action: "sp-unlock" unlock method: smart fast Model: ZTE-R221 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:4793:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... warning: wrong packet cs Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: E-PK-T9SM-P109A17V1.0.0B02 Version: ZTENJ23D_09A_HW 86 byte(s) read imei: 35926403084946 connection Ok 192 byte(s) read reading data... reading data #2... building new data... writing data... 180 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 13 sec Remove/Install battery now ! |
The Following User Says Thank You to Bilal1984 For This Useful Post: |
12-26-2010, 15:18 | #7564 (permalink) |
No Life Poster Join Date: Jun 2005 Location: rawalpindi,pakistan.
Member: 155992 Status: Offline Sonork: 1585672 Thanks Meter: 171 | COM3 [VCP4] selected module v1.73 Device: LG-KG270 Checking data, wait... Action: "sp-unlock" direct unlock method #2 (Airtel etc.) Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: .00 ULC2GL KG270 P16 92 V10e XXX-XX Jun 20 2007 +0 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG270_eeprom-static_20101229-031201.B1E.bin loading data... data loaded imei: 35858201283730300 reading eeprom-security_35858201283730300... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG270_eeprom-security_35858201283730300_20101229-031201.B1E.bin reading eeprom-complete_35858201283730300... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG270_eeprom-complete_35858201283730300_20101229-031203.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... Erasing: eeprom-security Writing: eeprom-security probably you need to restore original imei after unlock process Write Done Finished, time used: 17 sec Remove/Install battery now ! |
The Following User Says Thank You to naeem janjua For This Useful Post: |
12-26-2010, 15:18 | #7565 (permalink) |
Member: 621121 Status: Offline Thanks Meter: 366 | Dead repair success by full flash Code: COM17 [VCP1] selected module v3.24 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware backup_flash[AHONG25_06B_PCB01_GPRS_MT6225_S00.A11+_V07_12_52_H23.BIN]_20080530-120611.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:8D03:0005 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 detecting chip #01 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 detecting chip #02 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 detecting chip #03 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 detecting chip #01 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE500908A0400009FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (04), 1 record(s) TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\id.49F08FAF.[AHONG25_06B_PCB01_GPRS_MT6225_S00.A11+_V07_12_52_H23.BIN_BD6390C1].rpl rom info detection finished device-id: 49F08FAF rom info ver: 04 sw version: AHONG25_06B_PCB01_GPRS_MT6225_S00.A11+_V07_12_52_H23.BIN project-id: A11+_V07.12.52.H23, C19063BD code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 rom info structure: [protected] type (04), 1 record(s) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00C00000 standard ffs/eeprom offset confirmed: 00C00000 detecting ffs/eeprom size... ffs/eeprom size: 00400000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00C00000-00FFFFFF firmware area: 00000000-00BFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: AHONG25_06B_PCB01_GPRS_MT6225_S00.A11+_V07_12_52_H23__ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\AHONG25_06B_PCB01_GPRS_MT6225_S00.A11+_V07_12_52_H23__ffs_20101010-172628.B0E.bin flash: 98004900000002:18E59F00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... startup code area #1 calculation... startup code area #1 fixed detecting startup code area #2... startup code area #2 is absent file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\AHONG25_06B_PCB01_GPRS_MT6225_S00.A11+_V07_12_52_H23__system_log_49F08FAF_BD6390C1_20101010-172738.B0X.bin Area: Firmware flash: 98004900000002:18E59F00000000 Write: Firmware usb bootloader (file) is absent sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\AHONG25_06B_PCB01_GPRS_MT6225_S00.A11+_V07_12_52_H23__system_log_49F08FAF_BD6390C1_20101010-173021.B0X.bin Finished, time used: 7 min 0 sec Remove/Install battery now ! |
The Following User Says Thank You to alamgir80 For This Useful Post: |
12-26-2010, 15:18 | #7566 (permalink) |
Member: 621121 Status: Offline Thanks Meter: 366 | Read user code success Code: COM2 [VCP0] selected module v3.24 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: "user code" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:550F:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 detecting chip #02 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 detecting chip #03 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 detecting chip #04 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 detecting chip #05 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 detecting chip #06 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 detecting chip #07 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 number of flash chip/regions detected: 08/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00800000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (07) TCL-ID is absent ==================== New firmware found (v.3.24, database date: 01.10.2010): CRAB_S03_PCB01_GPRS_MT6223_S00.CRAB-S03_2V8_SBTEL_L1EN_103_091020_CAM000_MCP64+32_FM.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info ver: 07 sw version: CRAB_S03_PCB01_GPRS_MT6223_S00.CRAB-S03_2V8_SBTEL_L1EN_103_091020_CAM000_MCP64+32_FM.BIN project-id: CRAB-S03_2V8_SBTEL_L1EN_103_091020_CAM000_MCP64+32_FM, 00000000 code offset: 00000000 ffs offset/size [01]: 00700000/00100000 rom info structure: [standard] type (07) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00700000 standard ffs/eeprom offset confirmed: 00700000 detecting ffs/eeprom size... ffs/eeprom size: 00100000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00700000-007FFFFF firmware area: 00000000-006FFFFF detecting startup code area #2... ................................................................................................................................................................................................................................................................ startup code area #2 is absent detecting ffs/eeprom structure pass 1... ............... ffs/eeprom: detect std location pass #1... ............................ ffs/eeprom: detect ext location pass #1... ...................... ffs/eeprom: detect standard offset pass #1... ffs/eeprom record offset detected ffs/eeprom: detect standard data... ffs/eeprom record size detected ffs/eeprom layout detection complete ffs/eeprom detected ok: element #1 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: CRAB_S03_PCB01_GPRS_MT6223_S00.CRAB-S03_2V8_SBTEL_L1EN_103_091020_CAM000_MCP64+32_FM__ffs... file saved: C:\Users\AlaM\Desktop\CRAB_S03_PCB01_GPRS_MT6223_S00.CRAB-S03_2V8_SBTEL_L1EN_103_091020_CAM000_MCP64+32_FM__ffs_20101017-105014.B0E.bin flash: EC257E25062501:2AEA0000000000 Backup required data Done ====> Patch required data ... detection procedure, wait... detection procedure completed Patch required data Done ====> Special operation ... Special operation Done ====> Write ... flash: EC257E25062501:2AEA0000000000 Write: ffs Write Done ====> Finalization ... Finalization Done Finished, time used: 2 min 28 sec Remove/Install battery now ! |
12-26-2010, 15:25 | #7567 (permalink) |
Junior Member Join Date: Jul 2010
Member: 1336115 Status: Offline Thanks Meter: 7 | ==== [21.12.2010 9:21:40] ==== COM4 [VCP0] selected module v3.25 Action: repair "Bad software" Step 1 of 2 is complete ! Press "Ok" now and then make step 2 ! If phone did not connect: remove/install battery. Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:3C03:0009 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: A90V1.6.1 Version: Single25_06B_HW detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #6 (mode-1)... done 163 byte(s) read writing data... verification... verification Ok Finished, time used: 9 sec Remove/Install battery now ! |
The Following User Says Thank You to nikita1980 For This Useful Post: |
12-26-2010, 15:29 | #7568 (permalink) |
No Life Poster Join Date: Feb 2007 Location: Mongolia
Member: 444532 Status: Offline Sonork: 100.1576960 Thanks Meter: 214 | Alcatel OT380 spunlock: COM3 [VCP0] selected module v3.65 Device: Alcatel-380X Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:B19B:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC240200000000:2BEA0000000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (05), 1 record(s) TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: D:\Program Files\InfinityBox\MModule\backup_security\id.AB57C 6C0.[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V9.BIN_784310C4].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: AB57C6C0 rom info ver: 05 sw version: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V9.BIN project-id: MAUI.08A.W08.36.SP1.V9, C4104378 code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 TCL-ID identification version: 366 provider: 380X-2ARGFR1 customization: CI36BE17 customization: XI36BE17 TCL-ID identification done rom info structure: [protected] type (05), 1 record(s) TCL-ID is present ffs/eeprom address assigned: 00C00000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization: XI36BE17 customization name adjusted flash: EC240200000000:2BEA0000000000 flash: EC240200000000:2BEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: EC240200000000:2BEA0000000000 flash: EC240200000000:2BEA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: FFFFFFFFFFFFFF flash: EC240200000000:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: EC240200000000:2BEA0000000000 Finalization Done file saved: D:\Program Files\InfinityBox\MModule\backup_security\Alcatel-380X_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08 _36_SP1_V9__system_log_AB57C6C0_784310C4_20101125-141951.B0X.bin Finished, time used: 2 min 31 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to shuric For This Useful Post: |
12-26-2010, 15:31 | #7569 (permalink) |
Member: 444532 Status: Offline Sonork: 100.1576960 Thanks Meter: 214 | SE K220i sp-unlock done. COM3 [VCP0] selected module v1.38 Device: Sony-Ericsson-K220i "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! loading... Boot done Check connection ... Check connection done Set baud ... 812500 Set baud done Check hardware ... flash: EC257E25082501:92EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb software version: R1AA008 software version: CXC1250829 version flex: CDA102806/1 imei: 35619701260981 Check hardware done Read data ... reading Sony-Ericsson-K220i_35619701260981_eeprom_calibration-1... file saved: D:\Program Files\InfinityBox\HModule\Sony-Ericsson-K220i_35619701260981_eeprom_calibration-1_20101104-220948.80E.bin reading Sony-Ericsson-K220i_35619701260981_eeprom_calibration-2... file saved: D:\Program Files\InfinityBox\HModule\Sony-Ericsson-K220i_35619701260981_eeprom_calibration-2_20101104-220953.80E.bin Read data done Check data ... Check data done Write ... flash: EC257E25082501:46237300000000 Write: eeprom flash: EC257E25082501:46237300000000 Write: eeprom ..... .......... locks cleared Write done Finished, time used: 26 sec Remove/Install battery now ! |
12-26-2010, 16:31 | #7570 (permalink) |
Freak Poster Join Date: Mar 2006
Member: 249061 Status: Offline Thanks Meter: 19 | Power-off phone by "Power" button (don't remove battery). Action: unlock COM10 [VCP0] selected Phone must be POWERED-ON ! Cable must be in "DATA" mode ! Connecting, wait... Phone connected. Working... file saved: C:\Program Files\InfinityBox\PNModule\backup_sp-unlock_log_20101225-174846.8FX.bin active lock(s) found, working... Finished, time used: 22 sec |
The Following User Says Thank You to gsm_jaja For This Useful Post: |
12-26-2010, 21:34 | #7571 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Where Dreams Comes True...S4U
Member: 755709 Status: Offline Sonork: 100.1592000 Momo... Thanks Meter: 6,635 | successfully flashed dead nokia6555 RM271: Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm271__03.46.mcusw PPM : rm271__03.46.ppm_c CNT : rm271__03.46.image_c_fr Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. [BB5 FLASH]: Bootrom Ok! RAP_PUB: 1790010BC8AA4F503B1E57B8BCF808EC4AA5B98A CMT_ROOT: BAF3A9C3DBFA8454937DB77F2B8852B1 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:00 Reopening the connection... Waiting for response: 30 Waiting for response: 29 Waiting for response: 28 Waiting for response: 27 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm271__03.46.mcusw Found 5 areas to erase Erasing area 0x00000000 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00040000 - 0x000BFFFF, NOR, CMT Result: 0000 Erasing area 0x000C0000 - 0x0013FFFF, NOR, CMT Result: 0000 Erasing area 0x01380000 - 0x014FFFFF, NOR, CMT Result: 0000 Erasing area 0x00140000 - 0x0137FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:54 Write : Processing rm271__03.46.mcusw Total 1120 [1120/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] TIME : Write time : 00:01:59 MCU Write done ===Flashing [PPM]=== Erase : Processing rm271__03.46.ppm_c Found 1 areas to erase Erasing area 0x01500000 - 0x01BBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:15 Write : Processing rm271__03.46.ppm_c Total 381 [381/0/0] blocks to write, writing... TIME : Write time : 00:00:41 PPM Write done ===Flashing [CNT]=== Checking content info... Check Image : Content size is 128k, use direct write mode Erase : Processing rm271__03.46.image_c_fr Found 2 areas to erase Erasing area 0x01FC0000 - 0x03F9FFFF, NOR, CMT Result: 0000 Erasing area 0x01BC0000 - 0x01FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:01:48 Write : Processing rm271__03.46.image_c_fr Total 480 [480/0/0] blocks to write, writing... TIME : Write time : 00:00:47 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:06:25 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 6555 Software Info: V 03.46 30-10-08 RM-271 (c) Nokia IMEI: 356984013101139 PPM version : Vp 03.46 30-10-08 RM-271 (c) Nokia C Product code: 0549711 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! AfterFlash operations done... Reconnect, wait... Done! Elapsed: 00:07:13 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
The Following 2 Users Say Thank You to Momo_Gsm For This Useful Post: |
12-27-2010, 03:39 | #7572 (permalink) |
Freak Poster Join Date: Dec 2006 Location: philippines
Member: 406299 Status: Offline Sonork: none Thanks Meter: 280 | vodafone 543 under test by infinity unlocked success pinout all ok COM8 [VCP1] selected module v3.71 Device: Vodafone-543 Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:1703:A009 status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98006F00000004:09EA0000000000 flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb otp offset: 01FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... usb bootloader (chip) is present: 00020000 searching rom info... search rom info finished rom info structure: [protected] type (07), 1 record(s) TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.10503 CAF.[JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP 1_V32_F3.BIN_35C4274A].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: 10503CAF rom info ver: 07 sw version: JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP 1_V32_F3.BIN project-id: MAUI.08A.W08.40.SP1.V32.F3, 4A27C435 code offset: 00020000 ffs offset/size [01]: 01800000/00800000 TCL-ID identification version: 264 provider: 543X-2AVDGB1 customization: CN26FC01 customization: XN26FC01 TCL-ID identification done rom info structure: [protected] type (07), 1 record(s) TCL-ID is present ffs/eeprom address assigned: 01800000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is invalid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#3... search sec info#3 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 security area (sec info, cust) calculation... error: security area (sec info, cust) header is invalid security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected customization: XN26FC01 customization name adjusted flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected customization: XN26FC01 customization name adjusted flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35982003282672 flash: 98006F00000004:09EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98006F00000004:09EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Vodafone-543_JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_4 0_SP1_V32_F3__system_log_10503CAF_35C4274A_2010122 6-170231.B0X.bin Finished, time used: 4 min 9 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to JMJ ALBERT For This Useful Post: |
12-27-2010, 04:56 | #7573 (permalink) |
Registered User Join Date: Jun 2010 Location: GSM POWERTEAM
Member: 1330543 Status: Offline Thanks Meter: 177 | successful read memory card passwoed Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading MMC password... MMC pass Record found, saving... 1 MMC pwd records are found! Extracting... ------------------------------- We have next Pass: wwwwwt ------------------------------- Done! Phone disconected! Connect phone on selected interface... |
The Following User Says Thank You to shahzad2010 For This Useful Post: |
12-27-2010, 05:12 | #7574 (permalink) |
Insane Poster Join Date: Dec 2010 Location: depok timur
Member: 1458511 Status: Offline Thanks Meter: 24 | SUKSES unlock alcatel OT-708 COM6 [Serial2] selected module v3.63 Device: Alcatel-708X, 708A Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:7003:A005 status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98006F00000004:09EA0000000000 flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb otp offset: 01FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... usb bootloader (chip) is present: 00020000 searching rom info... search rom info finished rom info structure: [protected] type (07), 1 record(s) TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.27CE5 2D3.[JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN_FE304F8D].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: 27CE52D3 rom info ver: 07 sw version: JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN project-id: MAUI.08A.W08.40.SP1.V32, 8D4F30FE code offset: 00020000 ffs offset/size [01]: 01800000/00800000 TCL-ID identification version: 17S provider: 708X-2ATTTP1 customization: CN17EA90 customization: XN17EA90 TCL-ID identification done rom info structure: [protected] type (07), 1 record(s) TCL-ID is present ffs/eeprom address assigned: 01800000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is invalid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#3... search sec info#3 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 security area (sec info, cust) calculation... error: security area (sec info, cust) header is invalid security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected customization: XN17EA90 customization name adjusted flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected customization: XN17EA90 customization name adjusted flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35908103719026 flash: 98006F00000004:09EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98006F00000004:09EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-708X,708A_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_0 8A_W08_40_SP1_V32__system_log_27CE52D3_FE304F8D_20 101226-063732.B0X.bin Finished, time used: 3 min 14 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following 2 Users Say Thank You to ..:SURYA_CKR:.. For This Useful Post: |
12-27-2010, 05:21 | #7575 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Sri Lanka
Member: 576633 Status: Offline Thanks Meter: 392 | Vodafone 225 Unlock done ! COM4 [VCP0] selected module v1.78 Device: Vodafone-225 Checking data, wait... Action: "sp-unlock" unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 00EC:257E Connecting Done Check hardware ... Check hardware Done Check parameters ... sw version: -SA-P108A2 SST V1.0.0B11 Jul 18 2008 12 29 51 VDF-P108A2B07-RoFr Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-225_eeprom-static_20101227-094645.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-225_eeprom-security_20101227-094647.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-225_eeprom-complete_20101227-094653.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-225_lock-area_20101227-094705.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 1 min 15 sec Remove/Install battery now ! |
The Following User Says Thank You to nishue For This Useful Post: |
