03-26-2024, 04:49 | #76006 (permalink) |
Freak Poster Join Date: Nov 2013 Location: Infinity Team
Member: 2072265 Status: Offline Thanks Meter: 46 | Vgotel s22 code remove done 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 117 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 21BF08D11088AAF1CDB05A53D73672E3 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00EC , [GigaDevice] GD25LQ32 [0] : FLASH_DIE : 00C8 0060 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Backup done Read ExtData Sorting ExtData Sort Ok, Rebuild Ok Restore ExtData All done UserCode request removed UserCode set to default ( 0000 or 1122 ) Done! Elapsed: 00:00:13 Reconnect Power/Cable! Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 117 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 21BF08D11088AAF1CDB05A53D73672E3 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00EC , [GigaDevice] GD25LQ32 [0] : FLASH_DIE : 00C8 0060 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Backup exists , skip Executing FFS FORMAT now... FAT_RANGE : 0x00398000-0x003FDFFF , LEN : 0x00066000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Done! Elapsed: 00:00:08 Reconnect Power/Cable! |
03-26-2024, 06:30 | #76007 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Vivo S1 (V1907) Operation: Reset Settings/Format FS [ v2.55a3 (beta) ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X [-] Wipe [+] Userdata [+] FRP [+] Smart WARNING: Reset may delete ALL USER DATA! Wait... - Power device Off [remember Test-Point] - Connect cable [remember Vol+ | Vol-] Waiting for device... PTFN: MediaTek PreLoader USB VCOM_V1632 (Android) (COM23) MODE [0]: PRELOADER PORT; PORT: 23 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005 Mode: SBC+SDA VER: 0xFF BL: 0x03 [PRELOADER PORT] SOCID: E7172414A8A17FFF80C0FD30F1DFF0F1C835945B36A6B1FB61 99A911F263BB60 AGENT: AUTO: Vivo: SEC_2023 [ecb438fd] C:\InfinityBox\CM2MT2\boot\Vivo\SEC_2023\MTK_AllIn One_DA_v3.fdaaf7f6.bin Looking for suitable bootchain in DA... Found: MT6768; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: PRELOADER EXT_RAM initialized DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x00070000 [ 448.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 150100445636444D42022A23C21B96C9 crc Ok Vendor: Samsung OEM: 256 ID: 445636444D42 [DV6DMB] PRV: 0x02 Serial: 706986523 0x2A23C21B MM/YY: 9/2019 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0x1D1EC00000 [ 116.48 Gb ] CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0001 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] RNID: 570DF1E8FFAFC1DFCAE89147AE3AF038 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Ok PMT: PGPT [0x64] Records: 43 Select info source... [recovery] Ok Product Brand: vivo Product Device: 1907N Product Model: vivo 1907 Product Name: 1907N SW: vivo/1907N/1907N:12/SP1A.210812.003/compiler06021753:user/release-keys Patch Level: SP1A.210812.003 Display ID: SP1A.210812.003 release-keys SW Version: compiler06021753 Ver. CodeName: REL Ver. Release: 12 Sec. Patch: 2022-06-01 Build Time: 02-Jun-22 9:51:34 AM Product Info: k68v1_64 SW: full_k68v1_64-user 12 SP1A.210812.003 compiler06021753 release-keys Product Manfct: vivo Product Board: k68v1_64 Board Platform: mt6768 Device ID: vivo-1907-1907n-k68v1-64 Strategy: [vivo] Firmware ID: MT6768_vivo_vivo_1907_OSv12_SP1A.210812.003_k68v1_ 64 Android ver: 12 UserDataFS: 0x02 [ext4|8+] CacheFS: 0x02 [ext4|8+] EMMC CID: 150100445636444D42022A23C21B96C9 crc Ok Vendor: Samsung OEM: 256 ID: 445636444D42 [DV6DMB] PRV: 0x02 Serial: 706986523 0x2A23C21B MM/YY: 9/2019 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0x1D1EC00000 [ 116.48 Gb ] Verify config values... Ok Stage: Android OS [1] ... Create partition image... Ok Ok [2] ... Create partition image... Ok Ok [4] USERDATA... Ok Stage: FRP... [1] PROTECTION... Ok Ok Done Stage: Smart... Ok Reset port... Trying to reboot... Finished 36 sec Reconnect Power/Cable now |
03-26-2024, 14:21 | #76008 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Madeira Island Age: 47
Member: 85718 Status: Offline Thanks Meter: 449 | Wiko Sunny2 firmware read ok Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14 Load IDBase v8331 Ok! Operation : Identify [ v2.14 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731x_BASE : SC7731C_eMMC_1GB_NS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Device info : Patch Level : MRA58K Display ID : MRA58K release-keys Ver. Incmt : 22 Ver. CodeName : REL Ver. Release : 6.0 Sec. Patch : 2017-08-05 Build Time : 22.09.2017 Product Board : v2510 Board Platform : sc8830 Product Info : v2510 Product Model : SUNNY2 Product Brand : WIKO Product Name : V2510 Product Device : V2510 Product Manfct : WIKO NVMng : SecurityInfo IMEI[1] : 359592089768801 IMEI[2] : 359592089875002 IMEI[3] : 358570010103893 WIFIMAC : BC41017F0FA5 BT_MAC : 21397F0141BC SEC : SLS:0, SKS:0, SKV:3 Platform Version: MOCORTM_W16.28.2_P1_Debug Project Version: sc7731C_CP0_modem BASE Version: TM_BASE_W16.28.2_P1 MMI Version: sc7731C_modem HW Version: sc7731C_CP0_modem CMP_Time : 09-30-2016 11:02:36 MODEM TAG : MOCORTM_W16.28.2_P1_Debug_TM_BASE_W16.28.2_P1_sc77 31C_CP0_modem_sc7731C_CP0_modem_sc7731C_modem UserData : STATE : PLAIN [EXTFS] - > INFO : Remove cable from device to switch it off! Done! Elapsed: 00:00:35 Operation : Read FW [ v2.14 ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... >>> Device not found! >>> Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Read FW [ v2.14 ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731x_BASE : SC7731C_eMMC_1GB_NS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Device info : Patch Level : MRA58K Display ID : MRA58K release-keys Ver. Incmt : 22 Ver. CodeName : REL Ver. Release : 6.0 Sec. Patch : 2017-08-05 Build Time : 22.09.2017 Product Board : v2510 Board Platform : sc8830 Product Info : v2510 Product Model : SUNNY2 Product Brand : WIKO Product Name : V2510 Product Device : V2510 Product Manfct : WIKO AndroidVer : 6 VlnrLevel : 0x01 SC8830__WIKO__SUNNY2__6.0__MRA58K__v2510 Read : prodnv.img ExtSparse : Compression ratio : 9% Read : phase.cfg Read : wmodem.bin Read : wdsp.bin Read : wnvitem.bin Read : modem_wcn.img Read : wcnnvitem.bin Read : boot_logo.bmp Read : fastboot_logo.bmp Read : boot.img Read : system.img ExtSparse : Compression ratio : 82% Make : persist.img Make : cache.img Read : recovery.img Read : sysinfo.bin ExtSparse : Compression ratio : 4% Make : userdata.img Read : u-boot.bin Read : u-boot-spl.bin Firmware size : 0x7DD78040 ( 1,97 GiB ) Android Info saved : _Android_info.txt Reconnect Power/Cable! Done! Elapsed: 00:10:35 |
The Following User Says Thank You to ct3im For This Useful Post: |
03-27-2024, 11:32 | #76009 (permalink) |
No Life Poster Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,773 | S/N: 0073CA70CC v0160 Chinese Miracle II - MT2 Service Tool v2.54 Init log engine... Ok Build directories tree... Ok Backup files: C:\InfinityBox\CM2MT2\backup\ Backup files: 9 dirs: 0 Verify device database... BuiltIn: 28 Custom: 0 Build device list... Ok Scan 89 DA profiles... Ok libusb: v1.2.6.0 Init environment... Ok Load IDBase v915508 Ok Operation: Identify [ v2.54 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Mode: FLASH Port: Both [ B + P ]; High-Speed: On Force BROM: Off; Local SLA: Off; Auto-EMI: On; FireFly-Over-DA: On Wait... - Power device Off [remember Test-Point] - Connect cable [remember Vol+ | Vol-] Waiting for device... PTFN: MTK USB Port (COM7) MODE [0]: BOOTROM; PORT: 7 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0200 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] MEID: 2E0BEFD99D1288C230EA28D5409F4716 BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: BEC83BB239D617F23BFE71284F4EFBABF3A956C1EE91E1CFB3 779B6707E5C37A SLA: Local Auth [Forced mode] Start Auth... Ok Continue Auth... Ok FF: Looking for EMI Found SLA: Start 0x15 Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: 2E0BEFD99D1288C230EA28D5409F4716 AGENT: AUTO: 0_base: base_v2316 [07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_A llInOne_DA.1d5fdec4.bin Looking for suitable bootchain in DA... Found: MT6761; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 15010043555441343205AED3922E5889 crc Ok Vendor: Samsung OEM: 256 ID: 435554413432 [CUTA42] PRV: 0x05 Serial: 2933101102 0xAED3922E MM/YY: 5/2021 EMI: FireFly preloader_x657b_h6117.bin with 11 memory type(s) 1. DRAM LP_DDR4 ID: NOT_DEFINED Unknown 0x0000 RAM: 512.00 Mb 2. DRAM LP_DDR4 ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb 3. DRAM LP_DDR4 ID: NOT_DEFINED Unknown 0x0000 RAM: 2.00 Gb 4. DRAM LP_DDR4 ID: NOT_DEFINED Unknown 0x0000 RAM: 2.00 Gb 5. DRAM LP_DDR4 ID: NOT_DEFINED Unknown 0x0000 RAM: 1.00 Gb 6. DRAM LP_DDR4 ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb 7. DRAM LP_DDR4 ID: NOT_DEFINED Unknown 0x0000 RAM: 2.00 Gb 8. DRAM LP_DDR4 ID: NOT_DEFINED Unknown 0x0000 RAM: 2.00 Gb 9. DRAM LP_DDR4 ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb 10. DRAM LP_DDR4 ID: NOT_DEFINED Unknown 0x0000 RAM: 2.00 Gb 11. DRAM LP_DDR4 ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb Push EMI... EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x0003A600 [ 233.50 Kb ] RAM: DRAM: 0xC0000000 [ 3.00 Gb ] EMMC CID: 15010043555441343205AED3922E5889 crc Ok Vendor: Samsung OEM: 256 ID: 435554413432 [CUTA42] PRV: 0x05 Serial: 2933101102 0xAED3922E MM/YY: 5/2021 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] RNID: 0F94F97FAA442EDF6186ECCC21E9703E MEID: 2E0BEFD99D1288C230EA28D5409F4716 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Ok PMT: PGPT [0x64] Records: 41 Select info source... [recovery] Ok SW: Infinix/X657B-OP-S2/Infinix-X657B:11/RP1A.200720.011/211103V339:user/release-keys Product Brand: Infinix Product Device: Infinix-X657B Product Model: Infinix X657B Product Name: X657B-OP-S2 Patch Level: RP1A.200720.011 Display ID: X657B-H6117K-RGo-OP-S2-211103V339 SW Version: 211103V339 Ver. CodeName: REL Ver. Release: 11 Sec. Patch: 2021-09-05 Build Time: 11/3/2021 1:40:49 PM CPU: armeabi-v7a,armeabi Product Info: x657b_h6117 SW: vnd_x657b_h6117-user 11 RP1A.200720.011 184485 release-keys Product Board: Infinix-X657B Board Platform: mt6761 Product Manfct: INFINIX MOBILITY LIMITED Device ID: infinix-mobility-limited-infinix-x657b-x657b-op-s2 Strategy: [infinix] Firmware ID: MT6761_INFINIX_MOBILITY_LIMITED_Infinix_X657B_OSv1 1_X657B-H6117K-RGo-OP-S2-211103V339_RP1A.200720.011_x657b_h6117 Verify firmware [MT6761_INFINIX_MOBILITY_LIMITED_Infinix_X657B_OSv1 1_X657B-H6117K-RGo-OP-S2-211103V339_RP1A.200720.011_x657b_h6117]... Exist (1) Analyze userdata... userData: fileSystem : [f2fs] with FBE [file based encryption] Analyze modem... TK_MD_BASIC_MDBIN_PCB01_MT6761_S00.MOLY_LR12A_R3_M P_V149_4_P14 Analyze nvram... NVRAM: Items: 0xA3 Size: 0x101B84 State: Ok WiFi MAC: AA006E742F76 BlTh MAC: FC29E3C1BC8A IMEI[1]: IMEI[2]: EMMC CID: 15010043555441343205AED3922E5889 crc Ok Vendor: Samsung OEM: 256 ID: 435554413432 [CUTA42] PRV: 0x05 Serial: 2933101102 0xAED3922E MM/YY: 5/2021 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] Verify config values... Ok Backup to C:\InfinityBox\CM2MT2\backup\MT6761__2E0BEFD99D128 8C230EA28D5409F4716\ Items to check: 22 Read [26] NVRAM Read [10] NVDATA Read [3] PROINFO Read [27] LK Read [9] NVCFG Read [12] PROTECT1 Read [1] PGPT Read [11] PERSIST Read [0] PRELOADER Done 9 files Compress: C:\InfinityBox\CM2MT2\backup\MT6761__2E0BEFD99D128 8C230EA28D5409F4716\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6761__2E0BEFD99D128 8C230EA28D5409F4716.7z Verified STORAGE Life Status: eMMC : OK STORAGE OTP Status: UNLOCKED STORAGE RPMB Status: eMMC : RPMB KEY NOT PROGRAMMED [USABLE] Analyze preloader... EMI: MT6761 preloader_x657b_h6117.bin with 11 memory type(s) 1. DRAM LP_DDR4 ID: NOT_DEFINED Unknown 0x0000 RAM: 512.00 Mb 2. DRAM LP_DDR4 ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb 3. DRAM LP_DDR4 ID: NOT_DEFINED Unknown 0x0000 RAM: 2.00 Gb 4. DRAM LP_DDR4 ID: NOT_DEFINED Unknown 0x0000 RAM: 2.00 Gb 5. DRAM LP_DDR4 ID: NOT_DEFINED Unknown 0x0000 RAM: 1.00 Gb 6. DRAM LP_DDR4 ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb 7. DRAM LP_DDR4 ID: NOT_DEFINED Unknown 0x0000 RAM: 2.00 Gb 8. DRAM LP_DDR4 ID: NOT_DEFINED Unknown 0x0000 RAM: 2.00 Gb 9. DRAM LP_DDR4 ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb 10. DRAM LP_DDR4 ID: NOT_DEFINED Unknown 0x0000 RAM: 2.00 Gb 11. DRAM LP_DDR4 ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb Preloader saved: C:\InfinityBox\CM2MT2\backup\preloader\preloader_x 657b_h6117.bin Verify C:\InfinityBox\CM2MT2\backup\preloader\preloader_x 657b_h6117.bin [1ad083e6]... Exist Probe FRP... Most probably Off Reset port... Trying to reboot... Done: 1 min 13 sec Reconnect Power/Cable now Operation: Reset Settings/Format FS [ v2.54 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X [+] Wipe [+] Userdata [+] FRP [+] Smart WARNING: Reset may delete ALL USER DATA! Wait... - Power device Off [remember Test-Point] - Connect cable [remember Vol+ | Vol-] Waiting for device... PTFN: MTK USB Port (COM7) MODE [0]: BOOTROM; PORT: 7 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0200 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] MEID: 2E0BEFD99D1288C230EA28D5409F4716 BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: BEC83BB239D617F23BFE71284F4EFBABF3A956C1EE91E1CFB3 779B6707E5C37A SLA: Local Auth [Forced mode] Start Auth... Ok Continue Auth... Ok EMI known SLA: Start 0x15 Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: 2E0BEFD99D1288C230EA28D5409F4716 AGENT: AUTO: 0_base: base_v2316 [07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_A llInOne_DA.1d5fdec4.bin Looking for suitable bootchain in DA... Found: MT6761; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 15010043555441343205AED3922E5889 crc Ok Vendor: Samsung OEM: 256 ID: 435554413432 [CUTA42] PRV: 0x05 Serial: 2933101102 0xAED3922E MM/YY: 5/2021 EMI: FireFly preloader_x657b_h6117.bin with 11 memory type(s) 1. DRAM LP_DDR4 ID: NOT_DEFINED Unknown 0x0000 RAM: 512.00 Mb 2. DRAM LP_DDR4 ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb 3. DRAM LP_DDR4 ID: NOT_DEFINED Unknown 0x0000 RAM: 2.00 Gb 4. DRAM LP_DDR4 ID: NOT_DEFINED Unknown 0x0000 RAM: 2.00 Gb 5. DRAM LP_DDR4 ID: NOT_DEFINED Unknown 0x0000 RAM: 1.00 Gb 6. DRAM LP_DDR4 ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb 7. DRAM LP_DDR4 ID: NOT_DEFINED Unknown 0x0000 RAM: 2.00 Gb 8. DRAM LP_DDR4 ID: NOT_DEFINED Unknown 0x0000 RAM: 2.00 Gb 9. DRAM LP_DDR4 ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb 10. DRAM LP_DDR4 ID: NOT_DEFINED Unknown 0x0000 RAM: 2.00 Gb 11. DRAM LP_DDR4 ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb Push EMI... EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x0003A600 [ 233.50 Kb ] RAM: DRAM: 0xC0000000 [ 3.00 Gb ] EMMC CID: 15010043555441343205AED3922E5889 crc Ok Vendor: Samsung OEM: 256 ID: 435554413432 [CUTA42] PRV: 0x05 Serial: 2933101102 0xAED3922E MM/YY: 5/2021 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] RNID: 0F94F97FAA442EDF6186ECCC21E9703E MEID: 2E0BEFD99D1288C230EA28D5409F4716 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Ok PMT: PGPT [0x64] Records: 41 Select info source... [recovery] Ok SW: Infinix/X657B-OP-S2/Infinix-X657B:11/RP1A.200720.011/211103V339:user/release-keys Product Brand: Infinix Product Device: Infinix-X657B Product Model: Infinix X657B Product Name: X657B-OP-S2 Patch Level: RP1A.200720.011 Display ID: X657B-H6117K-RGo-OP-S2-211103V339 SW Version: 211103V339 Ver. CodeName: REL Ver. Release: 11 Sec. Patch: 2021-09-05 Build Time: 11/3/2021 1:40:49 PM CPU: armeabi-v7a,armeabi Product Info: x657b_h6117 SW: vnd_x657b_h6117-user 11 RP1A.200720.011 184485 release-keys Product Board: Infinix-X657B Board Platform: mt6761 Product Manfct: INFINIX MOBILITY LIMITED Device ID: infinix-mobility-limited-infinix-x657b-x657b-op-s2 Strategy: [infinix] Firmware ID: MT6761_INFINIX_MOBILITY_LIMITED_Infinix_X657B_OSv1 1_X657B-H6117K-RGo-OP-S2-211103V339_RP1A.200720.011_x657b_h6117 SmartInfo: Android Ver: 11 UserDataFS: 0x03 [f2fs] CacheFS: 0x02 [ext4|8+] EMMC CID: 15010043555441343205AED3922E5889 crc Ok Vendor: Samsung OEM: 256 ID: 435554413432 [CUTA42] PRV: 0x05 Serial: 2933101102 0xAED3922E MM/YY: 5/2021 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] Verify config values... Ok Backup exist: C:\InfinityBox\CM2MT2\backup\MT6761__2E0BEFD99D128 8C230EA28D5409F4716 Stage: Android OS [2] WIPE... Ok [3] WIPE... Create partition image... Ok Ok [4] WIPE... Create partition image... Ok Ok [6] USERDATA... Ok [7] USERDATA... Ok Stage: FRP... [1] PROTECTION... Ok Ok Done Stage: Smart... Nothing to-do Reset port... Trying to reboot... Done: 36 sec Reconnect Power/Cable now |
03-27-2024, 11:39 | #76010 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | S/N: 0073CA70CC v0160 Chinese Miracle II - MT2 Service Tool v2.54 Init log engine... Ok Build directories tree... Ok Backup files: C:\InfinityBox\CM2MT2\backup\ Backup files: 10 dirs: 0 Verify device database... BuiltIn: 28 Custom: 0 Build device list... Ok Scan 89 DA profiles... Ok libusb: v1.2.6.0 Init environment... Ok Load IDBase v915508 Ok DA selected: Oppo | 2021 | MTK_AllInOne_DA_OP.bin DA selected: Oppo | 2022-10 | MTK_AllInOne_DA.bin Operation: Identify [ v2.54 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Mode: FLASH Port: Both [ B + P ]; High-Speed: On Force BROM: Off; Local SLA: Off; Auto-EMI: On; FireFly-Over-DA: On Wait... - Power device Off [remember Test-Point] - Connect cable [remember Vol+ | Vol-] Waiting for device... PTFN: MediaTek DA USB VCOM Port (COM14) MODE [0]: PRELOADER PORT; PORT: 14 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005 Mode: SBC+SDA VER: 0xFF BL: 0x03 [PRELOADER PORT] SOCID: 2AD1B7143E083127D976185B3582C74F18BA41CEF06AB207A6 CB6A14A67F9ACE AGENT: MANUAL: Oppo: 2022-10 [ab6a11d9] C:\InfinityBox\CM2MT2\boot\Oppo\2022-10\MTK_AllInOne_DA.bin Looking for suitable bootchain in DA... Found: MT6765; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: PRELOADER EXT_RAM initialized DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x00038000 [ 224.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 13014E47314A39533910166DA82C986D crc Ok Vendor: Micron OEM: 334 ID: 47314A395339 [G1J9S9] PRV: 0x10 Serial: 376285228 0x166DA82C MM/YY: 9/2021 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0x1D1F000000 [ 116.48 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: 4BBBFC6B70DD1203572DB7647C7F8875 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Ok PMT: PGPT [0x64] Records: 47 Select info source... [recovery] [boot] Finished Probe core... Mount [erofs] 0x55900000 system Mount [erofs] 0xB106E000 vendor Mount [erofs] 0xC97C4000 product Mount [erofs] 0xCE9EB000 odm Ok Build Time: 12/7/2023 8:49:45 AM Product Brand: OPPO Product Info: CPH2239 Display ID: CPH2239_11_C.01 Display ID: CPH2239_11_C.01_231207 Device ID: oppo-oplus-mssi-64-cn-MT6765_CPH2239_11_A.11_210817_2745cfb0 Strategy: [oppo] Firmware ID: MT6765_CPH2239_11_C.01_231207_CPH2239_OPPO.MT6765_ CPH2239_11_A.11_210817_2745cfb0 Verify firmware [MT6765_CPH2239_11_C.01_231207_CPH2239_OPPO.MT6765_ CPH2239_11_A.11_210817_2745cfb0]... Firmware is unknown Please upload https://infinity-box.com/?r=100020 Analyze userdata... userData: fileSystem [ext4] with FBE [file based encryption] Analyze modem... OPPO6765_20361_MDBIN_PCB01_MT6765_S00.MOLY_LR12A_R 2_TC16_Q_G35_PR1_SP_V6_P33 Analyze nvram... NVRAM: Items: 0xAB Size: 0x105294 State: Ok WiFi MAC: 304F00D6B405 BlTh MAC: 304F00D6B404 EMMC CID: 13014E47314A39533910166DA82C986D crc Ok Vendor: Micron OEM: 334 ID: 47314A395339 [G1J9S9] PRV: 0x10 Serial: 376285228 0x166DA82C MM/YY: 9/2021 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0x1D1F000000 [ 116.48 Gb ] Verify config values... Ok Backup to C:\InfinityBox\CM2MT2\backup\MT6765__CF880B892F87E BB040369DAC68BA2877\ Items to check: 22 Read [31] NVRAM Read [14] NVDATA Read [22] PROINFO Read [36] LK Read [13] NVCFG Read [17] PROTECT1 Read [1] PGPT Read [20] PERSIST Read [0] PRELOADER Read [33] OCDT Read [5] OPPORESERVE1 Read [7] OPPORESERVE3 Read [8] OPPO_CUSTOM Read [32] CDT_ENGINEERING Done 14 files Compress: C:\InfinityBox\CM2MT2\backup\MT6765__CF880B892F87E BB040369DAC68BA2877\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6765__CF880B892F87E BB040369DAC68BA2877.7z Verified STORAGE Life Status: eMMC : OK STORAGE OTP Status: UNLOCKED STORAGE RPMB Status: eMMC : RPMB KEY PROGRAMMED [UNUSABLE] Analyze preloader... EMI: MT6765 preloader_oppo6765.bin with 6 memory type(s) 1. eMMC LP_DDR4X ID: 13014E47314A395238 Micron G1J9R8 RAM: 4.00 Gb 2. eMMC LP_DDR4X ID: 13014E47314A395339 Micron G1J9S9 RAM: 4.00 Gb 3. eMMC LP_DDR4X ID: 90014A684445615033 Hynix hDEaP3 RAM: 6.00 Gb 4. eMMC LP_DDR4X ID: 90014A68433861503E Hynix hC8aP> RAM: 4.00 Gb 5. eMMC LP_DDR4X ID: 150100445636444142 Samsung DV6DAB RAM: 4.00 Gb 6. eMMC LP_DDR4X ID: 13014E53304A394B39 Micron S0J9K9 RAM: 4.00 Gb Preloader saved: C:\InfinityBox\CM2MT2\backup\preloader\preloader_o ppo6765.bin Verify C:\InfinityBox\CM2MT2\backup\preloader\preloader_o ppo6765.bin [a0b901ef]... Exist Probe FRP... Most probably Off Reset port... Trying to reboot... Done: 2 min 2 sec Reconnect Power/Cable now Operation: Reset Settings/Format FS [ v2.54 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X [-] Wipe [-] Userdata [+] FRP [+] Smart WARNING: Reset may delete ALL USER DATA! Reset Userdata is Off If FRP still active after reset make [Userdata] On and repeat operation Wait... - Power device Off [remember Test-Point] - Connect cable [remember Vol+ | Vol-] Waiting for device... PTFN: MediaTek DA USB VCOM Port (COM14) MODE [0]: PRELOADER PORT; PORT: 14 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005 Mode: SBC+SDA VER: 0xFF BL: 0x03 [PRELOADER PORT] SOCID: 2AD1B7143E083127D976185B3582C74F18BA41CEF06AB207A6 CB6A14A67F9ACE AGENT: MANUAL: Oppo: 2022-10 [ab6a11d9] C:\InfinityBox\CM2MT2\boot\Oppo\2022-10\MTK_AllInOne_DA.bin Looking for suitable bootchain in DA... Found: MT6765; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: PRELOADER EXT_RAM initialized DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x00038000 [ 224.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 13014E47314A39533910166DA82C986D crc Ok Vendor: Micron OEM: 334 ID: 47314A395339 [G1J9S9] PRV: 0x10 Serial: 376285228 0x166DA82C MM/YY: 9/2021 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0x1D1F000000 [ 116.48 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: 4BBBFC6B70DD1203572DB7647C7F8875 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Ok PMT: PGPT [0x64] Records: 47 Select info source... [recovery] [boot] Finished Probe core... Mount [erofs] 0x55900000 system Mount [erofs] 0xB106E000 vendor Mount [erofs] 0xC97C4000 product Mount [erofs] 0xCE9EB000 odm Ok Build Time: 12/7/2023 8:49:45 AM Product Brand: OPPO Product Info: CPH2239 Display ID: CPH2239_11_C.01 Display ID: CPH2239_11_C.01_231207 Device ID: oppo-oplus-mssi-64-cn-MT6765_CPH2239_11_A.11_210817_2745cfb0 Strategy: [oppo] Firmware ID: MT6765_CPH2239_11_C.01_231207_CPH2239_OPPO.MT6765_ CPH2239_11_A.11_210817_2745cfb0 SmartInfo: Android Ver: 9 UserDataFS: 0x02 [ext4|8+] CacheFS: 0x02 [ext4|8+] EMMC CID: 13014E47314A39533910166DA82C986D crc Ok Vendor: Micron OEM: 334 ID: 47314A395339 [G1J9S9] PRV: 0x10 Serial: 376285228 0x166DA82C MM/YY: 9/2021 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0x1D1F000000 [ 116.48 Gb ] Verify config values... Ok Backup exist: C:\InfinityBox\CM2MT2\backup\MT6765__CF880B892F87E BB040369DAC68BA2877 Stage: Android OS Off Stage: FRP... [1] PROTECTION... Ok Ok Done Stage: Smart... Reset port... Trying to reboot... Done: 39 sec Reconnect Power/Cable now |
03-27-2024, 17:58 | #76011 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | ITEL P40 4G RESET FRP DONE BY CM2 Card found : 73CA70CC , v0160 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14 Load IDBase v8331 Ok! Operation : Format FS / Reset Settings [ v2.14 ] Mode : Reset FRP BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : iTel : itel-s663l.460f890f.04b4b7c0 Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0020 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:17 |
03-27-2024, 20:18 | #76012 (permalink) |
No Life Poster Join Date: Mar 2015 Location: Islam Age: 35
Member: 2371500 Status: Offline Thanks Meter: 5,806 | Realme C51 RMX3830 factory reset and FRP remove done power of phone press and hold volume keys connect to computer Code: Wait... S/N: 0041DEDF35 v0160 Chinese Miracle II - SP3 Service Tool v2.26 Init log engine... Ok Build directories tree... Backup files: C:\InfinityBox\CM2SP3\backup\ Backup files: 0 dirs: 0 Build device list... SP3 boot-pack v1.07 2024-03-04 Ok Check for updates [boot-pack]... You have latest version [1.07] installed Telegram Channel: @InfinityBox Telegram Chat: @InfinityBoxTalks Sales: https://infinity-box.com/buy/ Account: https://infinity-box.com/service/ Check for updates [CM2SP3]... You have latest version [2.26] installed Telegram Channel: @InfinityBox Telegram Chat: @InfinityBoxTalks Sales: https://infinity-box.com/buy/ Account: https://infinity-box.com/service/ Ready Selected: Realme C11-2021 [Boot FireFly] mmc [FF] protocol may be SLOW, for flash Read/Write use [FDL] Selected: Realme RMX3830 [Boot FireFly] mmc [FF] protocol may be SLOW, for flash Read/Write use [FDL] Operation: Connect [T612 Boot FireFly] [v2.26] Wait... - Power device Off - Connect cable [remember Vol+ | Vol-] [remember Test-Point] Waiting for device... Device found PTFN: SPRD U2S Diag (COM25) vid 0x1782 pid 0x4D00 boot: SPRD3 boot iLoader... Ok start iLoader... Ok Handshake... Ok boot xLoader... Ok start FireFly... Ok Loader exec Ok Dev UID: f79fef7ae9e0de6eb52cdefc7db49029f3edc2dfae8a4138f015e0001d91ee7a get storage info... EMMC CID: 9B01005932503132380040C527695AFD crc Ok Vendor: Hynix OEM: 256 ID: 593250313238 [Y2P128] PRV: 0x00 Serial: 1086662505 0x40C52769 MM/YY: 5/2023 CSD: D04F01328F5903FFFFFFFFEF8A400001 temp_write_protect: False perm_write_protect: False wp_group: 0x10 en 0x01 EXTCSD rev1.8 EMMC 5.1 FW: 0C0D ERASE_GROUP_DEF: 0x0400 BOOT_BUS_WIDTH: 0x00 PARTITION_CONFIG: 0x08 RST_N_FUNCTION: 0x01 PART_S_COMPLETED: False BOOT0/BOOT1 size: 0x400000 4.00 Mb RPMB size: 0x1000000 16.00 Mb WP_GRP_SIZE: 0x800000 8.00 Mb Size: Market 128 Gb Actual 0x1D1EC00000 116.48 Gb EOL: Status: Normal: Less than 80% reserved blocks used EOL_A: SLC status: 0% - 10% used EOL_B: MLC status: 0% - 10% used read extcsd... Ok extcsd stored: C:\InfinityBox\CM2SP3\backup\ext_csd\sc9230_f79fef7ae9e0de6e_extcsd_009B-Hynix_Y2P128_5.1_2024-03-27.bin Verify config values... Ok get partitions... Partitions: 77 Connected get slots... slot: b get sw info... probe boot... [vendor_boot_a] Product Brand: realme Product Device: RE58BC Product Model: ums9230_hulk_Natv Product Name: RMX3830 SW OTA Version: RMX3830export_13.A.37_0370_202312201930 SW: realme/RMX3830/RE58BC:13/TP1A.220624.014/T.R4T2.1703071830:user/release-keys Patch Level: TP1A.220624.014 Display ID: RMX3830export_13_A.37 SW Version: 643 Ver. CodeName: REL Ver. Release: 13 Sec. Patch: 2023-12-05 Build Time: 20/12/2023 12:20:03 م Product Info: ums9230_hulk SW: ums9230_hulk_Natv-user 13 TP1A.220624.014 643 release-keys Product Manfct: realme Board Platform: ums9230 Product Board: ums9230_hulk Android ver: 13 UserDataFS: 0x03 [f2fs] CacheFS: 0x03 [f2fs] Device ID: realme-ums9230-hulk-natv-re58bc-rmx3830 Strategy: [none|generic] Firmware ID: UMS9230_realme_ums9230_hulk_Natv_OSv13_RMX3830export_13_A.37_TP1A.220624.014_ums9230_hulk Read Device-ID... IMEI[0]: 867400020316612 IMEI[1]: 867400020316620 IMEI[2]: 867400020316638 IMEI[3]: 867400020316646 BT MAC: 60:c7:be:c5:75:20 WiFi MAC: 60:c7:be:c5:75:21 Backup 11 items to: C:\InfinityBox\CM2SP3\backup\sc9230_f79fef7ae9e0de6e\ Reading... Read [1/11] prodnv 64.00 Mb Ok Read [2/11] miscdata 1024.00 Kb Ok Read [3/11] uboot_a 3.00 Mb Ok Read [4/11] uboot_b 3.00 Mb Ok Read [5/11] l_fixnv1_a 2.00 Mb Ok Read [6/11] l_fixnv2_a 2.00 Mb Ok Read [7/11] l_fixnv1_b 2.00 Mb Ok Read [8/11] l_fixnv2_b 2.00 Mb Ok Read [9/11] ocdt_a 8.00 Mb Ok Read [10/11] ocdt_b 8.00 Mb Ok Read [11/11] calinv 2.00 Mb Ok ignore zeroes content probe rpmb... RPMB counter 0x000000AD RPMB: C:\InfinityBox\CM2SP3\backup\sc9230_f79fef7ae9e0de6e\rpmb_000000AD.bin RPMB size 0x1000000 Reading... Ok Done 11 files Compress: C:\InfinityBox\CM2SP3\backup\sc9230_f79fef7ae9e0de6e\ Cleanup... Ok Verify C:\InfinityBox\CM2SP3\backup\sc9230_f79fef7ae9e0de6e.7z Verified [272399e3] MemTool load 77 items Finished 6 min 46 sec Operation: Reset Settings / Format FS [T612 Boot FireFly] [v2.26] WARNING: Reset may delete ALL USER DATA! Continue? Yes [-] Wipe [-] Userdata [+] FRP [-] Smart Reset Userdata is Off If FRP still active after reset make Userdata On and repeat operation Wait... Backup exist: C:\InfinityBox\CM2SP3\backup\sc9230_f79fef7ae9e0de6e\ Stage: FRP... Looking for items... 1 items found [1] Writing... Ok Completed Finished 8 sec Operation: Reset Settings / Format FS [T612 Boot FireFly] [v2.26] WARNING: Reset may delete ALL USER DATA! Continue? Yes [+] Wipe [+] Userdata [-] FRP [+] Smart Wait... Backup exist: C:\InfinityBox\CM2SP3\backup\sc9230_f79fef7ae9e0de6e\ Stage: Wipe... Reading... Ok Writing... Ok Stage: Userdata... [1] Format... Ok 8 sec [2] Format... Ok 8 sec [3] Format... Ok 16 sec Completed Stage: Smart... [17] Format... Ok [18] Format... Ok Completed Finished 41 sec |
The Following 2 Users Say Thank You to profkefah For This Useful Post: |
03-28-2024, 05:50 | #76013 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | ViVo 1913 S1 Patter+Frp Reset Done Operation: Reset Settings/Format FS [ v2.55a3 (beta) ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X [-] Wipe [+] Userdata [+] FRP [+] Smart WARNING: Reset may delete ALL USER DATA! Wait... - Power device Off [remember Test-Point] - Connect cable [remember Vol+ | Vol-] Waiting for device... PTFN: MediaTek PreLoader USB VCOM_V1632 (Android) (COM23) MODE [0]: PRELOADER PORT; PORT: 23 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005 Mode: SBC+SDA VER: 0xFF BL: 0x03 [PRELOADER PORT] SOCID: CE45E654399DAEB2EBF4DBFE1F582DD7855378DE94BDFC5CC8 066A0E53D08204 AGENT: AUTO: Vivo: SEC_2023 [ecb438fd] C:\InfinityBox\CM2MT2\boot\Vivo\SEC_2023\MTK_AllIn One_DA_v3.fdaaf7f6.bin Looking for suitable bootchain in DA... Found: MT6768; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: PRELOADER EXT_RAM initialized DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x00070000 [ 448.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 90014A68444561503303CA29C53E56D5 crc Ok Vendor: Hynix OEM: 330 ID: 684445615033 [hDEaP3] PRV: 0x03 Serial: 3391735102 0xCA29C53E MM/YY: 5/2019 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0x1D1F000000 [ 116.48 Gb ] CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0001 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] RNID: 0C783FE58440EFF3BF8A048F68B249E8 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Ok PMT: PGPT [0x64] Records: 43 Select info source... [recovery] Ok Patch Level: P00610 Display ID: P00610 release-keys SW Version: compiler11271503 Ver. CodeName: REL Ver. Release: 9 Sec. Patch: 2019-11-05 Build Time: 27-Nov-19 7:02:18 AM Product Model: vivo Product Brand: vivo Product Name: PD1913 Product Device: PD1913 CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Manfct: vivo Product Info: k68v1_64 SW: full_k68v1_64-user 9 P00610 compiler11271503 release-keys Product Board: k68v1_64 Board Platform: mt6768 Product Name: full_k68v1_64 Product Device: k68v1_64 Device ID: full-k68v1-64-vivo-pd1913-k68v1-64 Strategy: [none|generic] Firmware ID: MT6768_vivo_vivo_OSv9_P00610_k68v1_64 Android ver: 9 UserDataFS: 0x02 [ext4|8+] CacheFS: 0x02 [ext4|8+] EMMC CID: 90014A68444561503303CA29C53E56D5 crc Ok Vendor: Hynix OEM: 330 ID: 684445615033 [hDEaP3] PRV: 0x03 Serial: 3391735102 0xCA29C53E MM/YY: 5/2019 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0x1D1F000000 [ 116.48 Gb ] Verify config values... Ok Stage: Android OS [1] ... Create partition image... Ok Ok [2] ... Create partition image... Ok Ok [4] USERDATA... Ok Stage: FRP... [1] PROTECTION... Ok Ok Done Stage: Smart... Nothing to-do Reset port... Trying to reboot... Finished 1 min 1 sec Reconnect Power/Cable now |
03-28-2024, 08:17 | #76014 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Gfive 3 sim king hang on logo done by cm2 Card found : 73CA70CC , v0160 Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.07 SCRD mode : AUTO SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ] Operation : Format FileSystem [ v1.07 ] 1. Power off device 2. Not hold any key on device! 3. Insert cable and battery in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! Format FFS Done! Done! Elapsed: 00:00:25 Reconnect Power/Cable! |
03-28-2024, 17:10 | #76015 (permalink) |
No Life Poster Join Date: Aug 2020 Location: Mozambique Age: 20
Member: 2965136 Status: Offline Sonork: 58846 Thanks Meter: 1,202 | OPPO R9m Reset Settings/Format FS Done Code: Operation: Reset Settings/Format FS [ v2.54 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X [+] Wipe [-] Userdata [+] FRP [+] Smart WARNING: Reset may delete ALL USER DATA! Reset Userdata is Off If FRP still active after reset make [Userdata] On and repeat operation Wait... - Power device Off [remember Test-Point] - Connect cable [remember Vol+ | Vol-] Waiting for device... PTFN: MediaTek USB Port (COM6) MODE [0]: BOOTROM; PORT: 6 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6755 SBID: 0x8A00 HWVR: 0xCB00 SWVR: 0x0001 EVOL: 0x0000 HWC: 0x0326 TYPE: MODERN [RAPHAEL] MEID: 999B0CA0CD44F79C9E0E371A75030C21 BROM: Sec Level: 0x00000001 Mode: SBC VER: 0x05 BL: 0xFE [BOOTROM] BROM: EMI: Search EMI: Continue libusb exec warn ctrl_msg1 v1.2.6.0 0x0A EMI: Found AGENT: AUTO: 0_base: base_v2316 [07fb00a6] C:\InfinityBox\CM2MT2\boot\0_base\base_v2316\MTK_AllInOne_DA.1d5fdec4.bin Looking for suitable bootchain in DA... Found: MT6755; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMI: FireFly preloader_oppo6755_15111.bin with 6 memory type(s) 1. eMMC DDR3 ID: 150100523231424D42 Samsung R21BMB RAM: 3.00 Gb 2. eMMC DDR3 ID: 150100525831344D42 Samsung RX14MB RAM: 4.00 Gb 3. eMMC DDR3 ID: 150100524331344D42 Samsung RC14MB RAM: 4.00 Gb 4. eMMC DDR3 ID: 150100523331314D42 Samsung R311MB RAM: 2.00 Gb 5. eMMC DDR3 ID: 90014A484347386134 Hynix HCG8a4 RAM: 4.00 Gb 6. DRAM DDR3 ID: NOT_DEFINED Unknown 0x0000 RAM: 4.00 Gb Push EMI... EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x00038000 [ 224.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 150100524331344D42078EBAA8D573BB crc Ok Vendor: Samsung OEM: 256 ID: 524331344D42 [RC14MB] PRV: 0x07 Serial: 2394597589 0x8EBAA8D5 MM/YY: 7/2016 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] CHIP: MT6755 SBID: 0x8A00 HWVR: 0xCB00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x6755 TYPE: LEGACY [MTK] RNID: 5F30CDB022C5D39EA9311282627B112F MEID: 999B0CA0CD44F79C9E0E371A75030C21 USB: FULL-SPEED Set port Speed... PTFN: MediaTek DA USB VCOM (Android) (COM36) MODE: PRELOADER PORT; PORT: 36 Boot done MODERN [RAPHAEL] Analyze PMT... Ok PMT: PGPT [0x64] Records: 33 Select info source... [recovery] Ok Patch Level: LMY47I SW Version: 1576546568 Ver. CodeName: REL Ver. Release: 5.1 Build Time: 17/12/2019 01:38:43 CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Manfct: OPPO Board Platform: mt6755 SW: full_oppo6755_15111-user 5.1 LMY47I 1576546568 dev-keys Product Model: OPPO R9m Product Brand: OPPO Product Name: R9m Product Device: R9 Product Board: full_oppo6755_15111 Product Info: oppo6755_15111 SW Version: A.53 SW OTA Version: R9m_11.A.53_0530_201912170904 SW OTA Name: R9m_11_A.53_191217 Display ID: R9m_11_A.53_191217 Kernel Info: 3.10.72-G201912170904 Device ID: oppo-r9m-r9-full-oppo6755-15111-MT6755_R9m_11_A.42_171222 Strategy: [oppo] Firmware ID: MT6755_OPPO_OPPO_R9m_OSv5.1_R9m_11_A.53_191217_LMY47I_oppo6755_15111.MT6755_R9m_11_A.42_171222 SmartInfo: Android Ver: 5 UserDataFS: 0x01 [ext4|4+] CacheFS: 0x01 [ext4|4+] EMMC CID: 150100524331344D42078EBAA8D573BB crc Ok Vendor: Samsung OEM: 256 ID: 524331344D42 [RC14MB] PRV: 0x07 Serial: 2394597589 0x8EBAA8D5 MM/YY: 7/2016 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] Verify config values... Ok Backup to C:\InfinityBox\CM2MT2\backup\MT6755__999B0CA0CD44F79C9E0E371A75030C21\ Items to check: 22 Read [22] NVRAM Read [11] NVDATA Read [17] PROINFO Read [23] LK Read [13] PROTECT1 Read [1] PGPT Read [0] PRELOADER Read [8] OPPO_CUSTOM Done 8 files Compress: C:\InfinityBox\CM2MT2\backup\MT6755__999B0CA0CD44F79C9E0E371A75030C21\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6755__999B0CA0CD44F79C9E0E371A75030C21.7z Verified Stage: Android OS [2] WIPE... Skip (Smart comes) Stage: FRP... [1] PROTECTION... Ok Ok Done Stage: Smart... Reset port... Trying to reboot... Done: 2 min 19 sec |
The Following 3 Users Say Thank You to tayobjoy1 For This Useful Post: |
03-29-2024, 09:10 | #76016 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Madagascar
Member: 233142 Status: Offline Sonork: 100.1595099 Thanks Meter: 527 | Haimi p8 reset privacy code done Card found : S/N : 3B74B6EB , v0150 Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Device boot not done Check Drivers Try again Boot Error! Operation Failed Elapsed: 00:00:27 Reconnect Power/Cable! Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 510001154D5331334370014245975FBA Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMS13 [eMMC] : FLASH_CID : 150100513331534D42017043BA5FC145 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0x432282F9014374BE9E828FAE4000DEF8 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : HAIMI ProdName : HAIMI P8 ProdModel : HAIMI P8 Device : HAIMI P8 AndroidVer: 5.1 MTKxCPU : MT6735 MTKxPRJ : TDC_1512_20161011_V2.82 Done! Elapsed: 00:00:15 Reconnect Power/Cable! Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 510001154D5331334370014245975FBA Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMS13 [eMMC] : FLASH_CID : 150100513331534D42017043BA5FC145 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0x432282F9014374BE9E828FAE4000DEF8 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... xGPT : Normalize settings Ok! Brand : HAIMI ProdName : HAIMI P8 ProdModel : HAIMI P8 Device : HAIMI P8 AndroidVer: 5.1 MTKxCPU : MT6735 MTKxPRJ : TDC_1512_20161011_V2.82 [Read Ok] : preloader_1512.bin [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : logo.bin [Read Ok] : secro.img [Read Ok] : tz1.img [Read Ok] : tz2.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6735 / V1.1.2 / 1512 / EMMC Android Info saved MAUI Meta DB saved HWConfig Info saved FW Size : 1438 MiB Scatter saved to : C:\Users\JO\Documents\MT6735__HAIMI__HAIMI_P8__HAI MI_P8__5.1__TDC_1512_20161011_V2.82\ All done! Done! Elapsed: 00:03:52 Reconnect Power/Cable! Operation : Read Pattern/DP Lock [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 510001154D5331334370014245975FBA Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2003 EMICFG_NOT_FOUND TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT! Boot Error! Operation Failed Elapsed: 00:00:18 Reconnect Power/Cable! Operation : Read Pattern/DP Lock [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 510001154D5331334370014245975FBA Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2003 EMICFG_NOT_FOUND TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT! Boot Error! Operation Failed Elapsed: 00:00:05 Reconnect Power/Cable! Operation : Read Pattern/DP Lock [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 510001154D5331334370014245975FBA Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMS13 [eMMC] : FLASH_CID : 150100513331534D42017043BA5FC145 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0x432282F9014374BE9E828FAE4000DEF8 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading data ... [Info] : PatternLock Not Set! [Info] : DP Lock not set! Done! Elapsed: 00:00:10 Reconnect Power/Cable! Operation : Reset Privacy Lock [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 510001154D5331334370014245975FBA Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMS13 [eMMC] : FLASH_CID : 150100513331534D42017043BA5FC145 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0x432282F9014374BE9E828FAE4000DEF8 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Checking data ... Process block #1 Process block #2 Privacy Lock reset Ok! Done! Elapsed: 00:00:32 Reconnect Power/Cable! |
03-30-2024, 08:38 | #76017 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Nokia 2660 flip ta1474 reset password done by cm2 Reset [ALL USER DATA] + [Security Code] but NOT FRP! Continue? Yes Wait... 1. Power device Off 2. Connect cable Looking for device... Device found PTFN: SPRD U2S Diag (COM6) vid:1782 pid:4D00 Enter Diag Mode[1]... Reset Interface... Verify... Diag Mode On Reading... Platform Version: MOCOR_20A_MP_W22.04.6_P4_Release Software Version: 11.00.17.01 BASE Version: FM_BASE_20A_THIN_MODEM_MP_W22.04.6_P4 HW Version: UMS9117 buildtime:08-31-2022 23:56:26 CHIP: UMS9117 Done Verify device config Ok [dbee033a] Ok Completed Wipe... Wipe Ok. Device will reboot now... |
The Following User Says Thank You to A.G.Shahid For This Useful Post: |
03-30-2024, 08:49 | #76018 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Calme cl66 reset password done by cm2 Card found : 73CA70CC , v0160 Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.07 SCRD mode : AUTO SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ] Operation : Format FileSystem [ v1.07 ] 1. Power off device 2. Not hold any key on device! 3. Insert cable and battery in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! Format FFS Done! Done! Elapsed: 00:00:18 Reconnect Power/Cable! |
03-30-2024, 11:22 | #76019 (permalink) |
No Life Poster Join Date: Nov 2008 Location: RVIII
Member: 890926 Status: Offline Thanks Meter: 2,054 | Oppo CPH2371 Password Code: Operation: Identify [ v2.55a3 (beta) ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Mode: FLASH Port: Both [ B + P ]; High-Speed: On [-] Force BROM [-] Local SLA [+] Auto-EMI [+] FireFly-Over-DA Wait... - Power device Off [remember Test-Point] - Connect cable [remember Vol+ | Vol-] Waiting for device... PTFN: MediaTek PreLoader USB VCOM_V1633 (Android) (COM4) MODE [0]: PRELOADER PORT; PORT: 4 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6877 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0959 CODE: Montrose TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005 Mode: SBC+SDA VER: 0xFF BL: 0x03 [PRELOADER PORT] SOCID: 7DF4785FC0895D30E4C79CDC42A84CA3E437BF69939A96FD6E4B1363B888DC56 AGENT: AUTO: Oppo: 2022-10 [ab6a11d9] C:\InfinityBox\CM2MT2\boot\Oppo\2022-10\MTK_AllInOne_DA.bin Looking for suitable bootchain in DA... Found: MT6877; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: PRELOADER EXT_RAM initialized DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x00070000 [ 448.00 Kb ] RAM: DRAM: 0x200000000 [ 8.00 Gb ] UFS CID: CE014B4D3846393030314A4D2D423831 Ven: 0x01CE VID: KM8F9001JM-B81 IFW: 0700 LU0: 0x00400000 [ 4.00 Mb ] LU1: 0x00400000 [ 4.00 Mb ] LU2: 0x3B96000000 [ 238.34 Gb ] FSN: 5c3083a0b535 REG: 0x101010000 CHIP: MT6877 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0002 EVOL: 0x0000 HWC: 0x0959 CODE: Montrose TYPE: MODERN [RAPHAEL] RNID: D3E5F07CF79A034D6675021BC477A5BB USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Ok PMT: PGPT [0x64] Records: 58 Select info source... [vendor_boot] [recovery] [boot] Finished Probe core... Mount [erofs] 0x88200000 system Mount [erofs] 0x78800000 system_ext Mount [erofs] 0x54100000 vendor Mount [erofs] 0xE9900000 product Mount [erofs] 0xEAB00000 odm Ok Kernel Info: 4.19.191 Display ID: CPH2371_11_A.01 Display ID: CPH2371_11_A.01_230421 Device ID: MT6877_CPH2371_export_11_A.10_2022012102450499 Strategy: [oppo] Firmware ID: MT6877_CPH2371_11_A.01_230421.MT6877_CPH2371_export_11_A.10_2022012102450499 Verify firmware [MT6877_CPH2371_11_A.01_230421.MT6877_CPH2371_export_11_A.10_2022012102450499]... Firmware is unknown Please upload https://infinity-box.com/?r=100020 Analyze userdata... userData: fileSystem : [f2fs] with FBE [file based encryption] Analyze modem... k6877v1_64_k419_212A1_MDBIN_PCB01_MT6877_S00.MOLY_NR15_R3_TC16_PR6_SP_V8_P41 Analyze nvram... NVRAM: Items: 0xAA Size: 0x7C6E74 State: Ok WiFi MAC: 74EF4B94DE93 BlTh MAC: 74EF4B94DE92 UFS CID: CE014B4D3846393030314A4D2D423831 Ven: 0x01CE VID: KM8F9001JM-B81 IFW: 0700 LU0: 0x00400000 [ 4.00 Mb ] LU1: 0x00400000 [ 4.00 Mb ] LU2: 0x3B96000000 [ 238.34 Gb ] FSN: 5c3083a0b535 REG: 0x101010000 Verify config values... Ok Backup to C:\InfinityBox\CM2MT2\backup\MT6877__B71FDD01AB9ABD5FBD2A4E7502C526A3\ Items to check: 22 Read [24] NVRAM Read [15] NVDATA Read [23] PROINFO Read [48] LK Read [14] NVCFG Read [18] PROTECT1 Read [1] PGPT Read [17] PERSIST Read [0] PRELOADER Read [25] OCDT Read [8] OPLUS_CUSTOM Read [29] CDT_ENGINEERING Done 12 files Compress: C:\InfinityBox\CM2MT2\backup\MT6877__B71FDD01AB9ABD5FBD2A4E7502C526A3\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6877__B71FDD01AB9ABD5FBD2A4E7502C526A3.7z Verified STORAGE Life Status: UFS : OK STORAGE OTP Status: UNLOCKED STORAGE RPMB Status: UFS : RPMB KEY NOT PROGRAMMED [USABLE] Analyze preloader... EMI: MT6752 preloader_k6877v1_64_k419.bin with 24 memory type(s) 1. eUFS LP_DDR4X Dev: H9HQ15AFAMBDAR RAM: 8.00 Gb 2. eUFS LP_DDR4X Dev: H9HQ21AFAMADAR RAM: 8.00 Gb 3. eUFS LP_DDR4X Dev: H9HQ21AFAMADAR RAM: 8.00 Gb 4. eUFS LP_DDR4X Dev: KM8V8001JM-B813 RAM: 8.00 Gb 5. eUFS LP_DDR4X Dev: KM8F8001JM-B813 RAM: 8.00 Gb 6. eUFS LP_DDR4X Dev: KM8F8001MM-B813 RAM: 12.00 Gb 7. eUFS LP_DDR4X Dev: KM8V9001JM-B813 RAM: 8.00 Gb 8. eUFS LP_DDR4X Dev: KM8V9001JM-B813 RAM: 8.00 Gb 9. eUFS LP_DDR4X Dev: H9QT1GGBN6X129 RAM: 12.00 Gb 10. eUFS LP_DDR4PX Dev: KMJS9001RM-BG01 RAM: 12.00 Gb 11. eUFS LP_DDR4X Dev: KM2L9001CM-B518 RAM: 6.00 Gb 12. eUFS LP_DDR4X Dev: KM2H7001CM-B518 RAM: 6.00 Gb 13. eUFS LP_DDR4X Dev: MT128GASAO4U21 RAM: 8.00 Gb 14. eUFS LP_DDR4X Dev: KM8F9001JM-B813 RAM: 8.00 Gb 15. eUFS LP_DDR4X Dev: KM8F9001JM-B813 RAM: 8.00 Gb 16. eUFS LP_DDR4X Dev: H9HQ15AECMBDAR RAM: 6.00 Gb 17. eUFS LP_DDR4X Dev: KM8L9001JM-B624 RAM: 8.00 Gb 18. eUFS LP_DDR4X Dev: H9QT1GGCN6X147 RAM: 12.00 Gb 19. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 8.00 Gb 20. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 6.00 Gb 21. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 8.00 Gb 22. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 12.00 Gb 23. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 12.00 Gb 24. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 6.00 Gb Preloader saved: C:\InfinityBox\CM2MT2\backup\preloader\preloader_k6877v1_64_k419.bin Verify C:\InfinityBox\CM2MT2\backup\preloader\preloader_k6877v1_64_k419.bin [ceff00eb]... Stored Probe FRP... Most probably Off Finished 1 min 15 sec Keep connection Operation: Reset Settings/Format FS [ v2.55a3 (beta) ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X [+] Wipe [+] Userdata [+] FRP [+] Smart WARNING: Reset may delete ALL USER DATA! Wait... - Power device Off [remember Test-Point] - Connect cable [remember Vol+ | Vol-] Waiting for device... PTFN: MediaTek PreLoader USB VCOM_V1633 (Android) (COM4) MODE [0]: PRELOADER PORT; PORT: 4 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6877 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0959 CODE: Montrose TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005 Mode: SBC+SDA VER: 0xFF BL: 0x03 [PRELOADER PORT] SOCID: 7DF4785FC0895D30E4C79CDC42A84CA3E437BF69939A96FD6E4B1363B888DC56 AGENT: AUTO: Oppo: 2022-10 [ab6a11d9] C:\InfinityBox\CM2MT2\boot\Oppo\2022-10\MTK_AllInOne_DA.bin Looking for suitable bootchain in DA... Found: MT6877; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: PRELOADER EXT_RAM initialized DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x00070000 [ 448.00 Kb ] RAM: DRAM: 0x200000000 [ 8.00 Gb ] UFS CID: CE014B4D3846393030314A4D2D423831 Ven: 0x01CE VID: KM8F9001JM-B81 IFW: 0700 LU0: 0x00400000 [ 4.00 Mb ] LU1: 0x00400000 [ 4.00 Mb ] LU2: 0x3B96000000 [ 238.34 Gb ] FSN: 5c3083a0b535 REG: 0x101010000 CHIP: MT6877 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0002 EVOL: 0x0000 HWC: 0x0959 CODE: Montrose TYPE: MODERN [RAPHAEL] RNID: D3E5F07CF79A034D6675021BC477A5BB USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Ok PMT: PGPT [0x64] Records: 58 Select info source... [vendor_boot] [recovery] [boot] Finished Probe core... Mount [erofs] 0x88200000 system Mount [erofs] 0x78800000 system_ext Mount [erofs] 0x54100000 vendor Mount [erofs] 0xE9900000 product Mount [erofs] 0xEAB00000 odm Ok Kernel Info: 4.19.191 Display ID: CPH2371_11_A.01 Display ID: CPH2371_11_A.01_230421 Device ID: MT6877_CPH2371_export_11_A.10_2022012102450499 Strategy: [oppo] Firmware ID: MT6877_CPH2371_11_A.01_230421.MT6877_CPH2371_export_11_A.10_2022012102450499 Android ver: 9 UserDataFS: 0x03 [f2fs] CacheFS: 0x02 [ext4|8+] UFS CID: CE014B4D3846393030314A4D2D423831 Ven: 0x01CE VID: KM8F9001JM-B81 IFW: 0700 LU0: 0x00400000 [ 4.00 Mb ] LU1: 0x00400000 [ 4.00 Mb ] LU2: 0x3B96000000 [ 238.34 Gb ] FSN: 5c3083a0b535 REG: 0x101010000 Verify config values... Ok Backup exist: C:\InfinityBox\CM2MT2\backup\MT6877__B71FDD01AB9ABD5FBD2A4E7502C526A3 Stage: Android OS [1] WIPE... Skip (Smart comes) [2] WIPE... Skip (Smart comes) [3] WIPE... Create partition image... Ok Ok [4] WIPE... Create partition image... Ok Ok [6] USERDATA... Ok Stage: FRP... [1] PROTECTION... Ok Ok Done Stage: Smart... Finished 44 sec Keep connection |
03-30-2024, 17:35 | #76020 (permalink) |
No Life Poster Join Date: Aug 2004 Location: Algeria Age: 47
Member: 78657 Status: Offline Thanks Meter: 71 | Samsung Galaxy Tab A8 10.5 (2021) SM-X200 frp hello. must disassembly the tab and make test point between TX point and GND . Code: Wait... S/N: 00C7xxxxx v0160 Chinese Miracle II - SP3 Service Tool v2.26 Init log engine... Ok Build directories tree... Backup files: C:\InfinityBox\CM2SP3\backup\ Backup files: 0 dirs: 0 Build device list... SP3 boot-pack v1.07 2024-03-04 Ok Check for updates [boot-pack]... You have latest version [1.07] installed Check for updates [CM2SP3]... You have latest version [2.26] installed Telegram Channel: @InfinityBox Telegram Chat: @InfinityBoxTalks Sales: https://infinity-box.com/buy/ Account: https://infinity-box.com/service/ Ready Selected: Samsung A03 [Boot FireFly] mmc [FF] protocol may be SLOW, for flash Read/Write use [FDL] Selected: Samsung X200 [Boot FireFly] mmc [FF] protocol may be SLOW, for flash Read/Write use [FDL] Operation: Connect [T618 Boot FireFly] [v2.26] Wait... - Power device Off - Connect cable [remember Vol+ | Vol-] [remember Test-Point] Waiting for device... Device found PTFN: SPRD U2S Diag (COM13) vid 0x1782 pid 0x4D00 boot: SPRD3 boot iLoader... Ok start iLoader... Ok Handshake... Ok boot xLoader... Ok start FireFly... Ok Loader exec Ok Dev UID: 19c9f84734eb27a5519a5a5508da99c5fdda6da51415a7406e759be7a66fbb69 get storage info... EMMC CID: 150100445036444242002825DC2AB957 crc Ok Vendor: Samsung OEM: 256 ID: 445036444242 [DP6DBB] PRV: 0x00 Serial: 673569834 0x2825DC2A MM/YY: 11/2022 CSD: D02701320F5903FFF6DBFFEF8E404001 temp_write_protect: False perm_write_protect: False wp_group: 0x10 en 0x01 EXTCSD rev1.8 EMMC 5.1 FW: 02 ERASE_GROUP_DEF: 0x0400 BOOT_BUS_WIDTH: 0x00 PARTITION_CONFIG: 0x08 RST_N_FUNCTION: 0x00 PART_S_COMPLETED: False BOOT0/BOOT1 size: 0x400000 4.00 Mb RPMB size: 0x1000000 16.00 Mb WP_GRP_SIZE: 0x800000 8.00 Mb Size: Market 64 Gb Actual 0xE8F800000 58.24 Gb EOL: Status: Normal: Less than 80% reserved blocks used EOL_A: SLC status: 0% - 10% used EOL_B: MLC status: 0% - 10% used read extcsd... Ok extcsd stored: C:\InfinityBox\CM2SP3\backup\ext_csd\T618_19c9f84734eb27a5_extcsd_0015-Samsung_DP6DBB_5.1_2024-03-30.bin Verify config values... Ok get partitions... Partitions: 53 Connected get sw info... probe boot... [recovery] SW: samsung/gta8wifixx/gta8wifi:11/RP1A.200720.012/X200XXS3CWG2:user/release-keys Product Brand: samsung Product Device: gta8wifi Product Model: SM-X200 Product Name: gta8wifixx Patch Level: RP1A.200720.012 Display ID: RP1A.200720.012.X200XXS3CWG2 SW Version: X200XXS3CWG2 Build Time: 06/07/2023 10:22:37 Ver. CodeName: REL Ver. Release: 11 Sec. Patch: 2023-07-01 CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Info: gta8wifi SW: gta8wifixx-user 11 RP1A.200720.012 X200XXS3CWG2 release-keys Product Board: ums512_25c10 Board Platform: ums512 Product Manfct: samsung Android ver: 11 UserDataFS: 0x02 [ext4|8+] CacheFS: 0x02 [ext4|8+] Device ID: samsung-sm-x200-gta8wifi-gta8wifixx-ums512-25c10 Strategy: [samsung] Firmware ID: UMS512_samsung_SM-X200_OSv11_RP1A.200720.012.X200XXS3CWG2_RP1A.200720.012_gta8wifi Read Device-ID... IMEI[0]: 8674000xxxxxxxxxxx IMEI[1]: 86740002xxxxxxxxxx IMEI[2]: 8674000xxxxxxxxxxx IMEI[3]: 8674000xxxxxxxxxxx BT MAC: N/A WiFi MAC: N/A Backup 5 items to: C:\InfinityBox\CM2SP3\backup\T618_19c9f84734eb27a5\ Reading... Read [1/5] prodnv 10.00 Mb Ok Read [2/5] miscdata 1024.00 Kb Ok Read [3/5] l_fixnv1 2.00 Mb Ok Read [4/5] l_fixnv2 2.00 Mb Ok Read [5/5] uboot 5.00 Mb Ok probe rpmb... RPMB counter 0x00001714 RPMB: C:\InfinityBox\CM2SP3\backup\T618_19c9f84734eb27a5\rpmb_00001714.bin RPMB size 0x1000000 Reading... Ok Done 6 files Compress: C:\InfinityBox\CM2SP3\backup\T618_19c9f84734eb27a5\ Cleanup... Ok Verify C:\InfinityBox\CM2SP3\backup\T618_19c9f84734eb27a5.7z Verified [102431c7] MemTool load 53 items Finished 2 min 27 sec Operation: Reset Settings / Format FS [T618 Boot FireFly] [v2.26] WARNING: Reset may delete ALL USER DATA! Continue? Yes [-] Wipe [-] Userdata [+] FRP [+] Smart Reset Userdata is Off If FRP still active after reset make Userdata On and repeat operation Wait... Backup exist: C:\InfinityBox\CM2SP3\backup\T618_19c9f84734eb27a5\ Stage: FRP... Looking for items... 2 items found [1] Writing... Ok [2] Writing... Ok Completed Stage: Smart... [6] Format... Ok [7] Format... Ok Completed Finished 13 sec Operation: Reset Settings / Format FS [T618 Boot FireFly] [v2.26] WARNING: Reset may delete ALL USER DATA! Continue? Yes [-] Wipe [+] Userdata [+] FRP [+] Smart Wait... Backup exist: C:\InfinityBox\CM2SP3\backup\T618_19c9f84734eb27a5\ Stage: FRP... Looking for items... 2 items found [1] Writing... Ok [2] Writing... Ok Completed Stage: Userdata... [1] Format... Ok 516 us [2] Format... Ok 4 sec [3] Format... Ok 4 sec Completed Stage: Smart... [6] Format... Ok [7] Format... Ok Completed Finished 11 sec Reboot... Disconnect cable if it freez fault 0x05 0x8E | BSL_PHONE_WAIT_INPUT_TIMEOUT Bye |
