03-11-2011, 07:05 | #9752 (permalink) |
No Life Poster Join Date: May 2008 Location: NC, USA Age: 36
Member: 779665 Status: Offline Sonork: 100.1581784 Thanks Meter: 492 | Code: Selected FlashSettings : FullFlash Files Set for Flashing : MCU : rm561__09.80.mcusw PPM : rm561__09.80.ppm_el CNT : rm561__09.80.image_el_red Check FlashFiles, Please, wait... -> SWversion check skipped : Manual mode selected Backup enabled, Will read Certificates now... CRT308 Backup Created... :) Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000296 CMT EM1 ID : 00000B22 CMT PUB ID : 12200108C5798C56951540E5BBB30C07FCC9C15A CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration FLASHID : 89820089 , CMT , NOR CMT Flash ID : 89820089 < INTEL => 0046L0Y1GG/NU48F512 FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg , Rev : 0.0 Ver : 1.33.1 CMT Algo sent CMT PAPUB : A22A1DDA660002E56108DB5072A10F8709443FA800 Transmission mode : Dual (Ddr, TX2) Boot Done! CMT : Read NPC certificate... Cert size : 20480 byte(s) IMEI : 358324036040246 CMT : Read CCC certificate... Cert size : 30600 byte(s) CMT : Read HWC certificate... Cert size : 20480 byte(s) CMT : Read VARIANT certificate... Cert size : 0 byte(s) Cert Read done! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\358324036040246.rpl Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000296 CMT EM1 ID : 00000B22 CMT PUB ID : 12200108C5798C56951540E5BBB30C07FCC9C15A CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration FLASHID : 89820089 , CMT , NOR CMT Flash ID : 89820089 < INTEL => 0046L0Y1GG/NU48F512 FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg , Rev : 0.0 Ver : 1.33.1 CMT Algo sent CMT PAPUB : A22A1DDA660002E56108DB5072A10F8709443FA800 Transmission mode : Dual (Ddr, TX2) Boot Done! Transmission mode : Dual (Ddr, TX2) Erase : Processing rm561__09.80.mcusw Found 6 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x00000000 - 0x000006BF CMT , NOR , Area : 0x000006C0 - 0x0001FFFF CMT , NOR , Area : 0x00040000 - 0x000BFFFF CMT , NOR , Area : 0x000C0000 - 0x0013FFFF CMT , NOR , Area : 0x00140000 - 0x0137FFFF CMT , NOR , Area : 0x01380000 - 0x0151FFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:01:32 Transmission mode : Dual (Ddr, TX2) Write : Processing rm561__09.80.mcusw CMT: Writing Hash CERT [NOLO] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] Total writen 1247 blocks TIME : Write time : 00:02:40 Transmission mode : Dual (Ddr, TX2) Erase : Processing rm561__09.80.ppm_el Found 1 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01520000 - 0x01DBFFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:28 Transmission mode : Dual (Ddr, TX2) Write : Processing rm561__09.80.ppm_el Total writen 327 blocks TIME : Write time : 00:00:40 CNT : Converted to 128k page data exist Transmission mode : Dual (Ddr, TX2) Erase : Processing rm561__09.80.image_el_red_128 Found 2 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01DC0000 - 0x0215FFFF CMT , NOR , Area : 0x02160000 - 0x03FBFFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:04:03 Transmission mode : Dual (Ddr, TX2) Write : Processing rm561__09.80.image_el_red_128 Total writen 692 blocks TIME : Write time : 00:01:24 Init Service mode... Wait... Reading Phone Info.... Connected phone - Nokia 2700 classic Software Info: V 09.80 02-12-09 RM-561 (c) Nokia IMEI: 358324036040246 Product code: 0579325 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Product code update... Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! AfterFlash operations done... Reconnect, wait... |
The Following 3 Users Say Thank You to nadirghazi For This Useful Post: |
03-11-2011, 07:34 | #9753 (permalink) |
No Life Poster Join Date: Nov 2008 Location: Pakistan
Member: 897524 Status: Offline Sonork: 100,1609543 Thanks Meter: 172 | Successfully unlock LG-KP100 COM3 [VCP1] selected module v1.78 Device: LG-KP100 Checking data, wait... Action: "sp-unlock" read unlock codes Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... Check hardware Done Check parameters ... sw version: .01 ULC2GL 2008-03-06 1.0 TMO_UK KP100 01 FL 44 V10a 234-30 M Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-static_20110310-142336.B1E.bin loading data... data loaded imei: 35588202517552400 reading eeprom-security_35588202517552400... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-security_35588202517552400_20110310-142337.B1E.bin reading eeprom-complete_35588202517552400... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-complete_35588202517552400_20110310-142344.B1E.bin backup critical area Done Check memory ... loading data... data loaded code: 48283887 Finished, time used: 24 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to gsmcrazy1 For This Useful Post: |
03-11-2011, 07:57 | #9754 (permalink) |
No Life Poster Join Date: Oct 2010 Location: INDIA (WEST BENGAL)
Member: 1426012 Status: Offline Sonork: ICQ#618627674 Thanks Meter: 886 | nokia 2690 successfull flash by best card found: S/N 00000:00000 registered to: PAUL-TELECOME Connect phone on selected interface... UFS S/N 0000000 boot - Ok Connect phone on selected interface... Read and Check phone data... BB5 bus checking... Setting FlashMode FlashMode set Ok No answer from phone... 1. Check cable/connection, try again 2. Maybe HW fault or bad cable Read and Check phone data... BB5 bus checking... Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000296 CMT EM1 ID : 00000B22 CMT PUB ID : 0D90000311B68E56E64E3313DF2FC1A87DA1BBCA CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration FLASHID : 89820089 , CMT , NOR CMT Flash ID : 89820089 < INTEL => 0046L0Y1GG/NU48F512 FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg , Rev : 0.0 Ver : 1.33.1 CMT Algo sent CMT PAPUB : B9354E81AC464DED33FC7B90295086150F45393500 Transmission mode : Dual (Ddr, TX2) Boot Done! Init Service mode... Wait... SimLock status : SimLock is Ok Security status : Security is Ok SDD Key status : SD Data is Ok PA_SimLock Version : PA_SL3 phone detected Done! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Core version : 1.17 , Rev : 2.3 Selected FlashSettings : Files Set for Flashing : MCU : rm635__10.10.mcusw PPM : rm635__10.10.ppm_mh CNT : rm635__10.10.image_mh_silver Check FlashFiles, Please, wait... -> Check SW version... FlashFile version : 10.10 Phone version : 10.10 22-04-10 RM-635 (c) Nokia -> Check SW version : Reflash Backup enabled, Will read Certificates now... CRT308 Backup Created... Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000296 CMT EM1 ID : 00000B22 CMT PUB ID : 0D90000311B68E56E64E3313DF2FC1A87DA1BBCA CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration FLASHID : 89820089 , CMT , NOR CMT Flash ID : 89820089 < INTEL => 0046L0Y1GG/NU48F512 FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg , Rev : 0.0 Ver : 1.33.1 CMT Algo sent CMT PAPUB : B9354E81AC464DED33FC7B90295086150F45393500 Transmission mode : Dual (Ddr, TX2) Boot Done! CMT : Read NPC certificate... Cert size : 20480 byte(s) IMEI : 352687044402855 CMT : Read CCC certificate... Cert size : 30600 byte(s) CMT : Read HWC certificate... Cert size : 20480 byte(s) CMT : Read VARIANT certificate... Cert size : 0 byte(s) Cert Read done! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\352687044402855.rp l Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000296 CMT EM1 ID : 00000B22 CMT PUB ID : 0D90000311B68E56E64E3313DF2FC1A87DA1BBCA CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration FLASHID : 89820089 , CMT , NOR CMT Flash ID : 89820089 < INTEL => 0046L0Y1GG/NU48F512 FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg , Rev : 0.0 Ver : 1.33.1 CMT Algo sent CMT PAPUB : B9354E81AC464DED33FC7B90295086150F45393500 Transmission mode : Dual (Ddr, TX2) Boot Done! Transmission mode : Dual (Ddr, TX2) Erase : Processing rm635__10.10.mcusw Found 6 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x00000000 - 0x000006BF CMT , NOR , Area : 0x000006C0 - 0x0001FFFF CMT , NOR , Area : 0x00040000 - 0x000BFFFF CMT , NOR , Area : 0x000C0000 - 0x0013FFFF CMT , NOR , Area : 0x00140000 - 0x0137FFFF CMT , NOR , Area : 0x01380000 - 0x0151FFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:01:40 Transmission mode : Dual (Ddr, TX2) Write : Processing rm635__10.10.mcusw CMT: Writing Hash CERT [NOLO] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] Total writen 1156 blocks TIME : Write time : 00:02:29 Transmission mode : Dual (Ddr, TX2) Erase : Processing rm635__10.10.ppm_mh Found 1 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01520000 - 0x01DBFFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:17 Transmission mode : Dual (Ddr, TX2) Write : Processing rm635__10.10.ppm_mh Total writen 187 blocks TIME : Write time : 00:00:23 ConvertImage: Processing rm635__10.10.image_mh_silver ConvertImage: Page Size is 128K, no need convert Transmission mode : Dual (Ddr, TX2) Erase : Processing rm635__10.10.image_mh_silver Found 2 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01DC0000 - 0x0215FFFF CMT , NOR , Area : 0x02160000 - 0x03FBFFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:04:12 Transmission mode : Dual (Ddr, TX2) Write : Processing rm635__10.10.image_mh_silver Total writen 408 blocks TIME : Write time : 00:00:50 Init Service mode... Wait... Reading Phone Info.... Connected phone - Nokia 2690 Software Info: V 10.10 22-04-10 RM-635 (c) Nokia IMEI: 352687044402855 Product code: 0592524 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! AfterFlash operations done... Reconnect, wait... Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
The Following 5 Users Say Thank You to niloy2007 For This Useful Post: |
03-11-2011, 09:00 | #9755 (permalink) |
Member: 1426012 Status: Offline Sonork: ICQ#618627674 Thanks Meter: 886 | Lg-3530 ==== [3/11/2011 1:01:15 PM] ==== COM25 [LGSIDIAG1] selected module v1.48 Device: LG-3530 operation: SP-unlock Phone should be Switched ON ! connecting... OFFLINE... sending boot... sending command... patching in progress... patching in progress 50%... patching in progress 100%... Done... Phones should be restarting now... Finished, time used: 23 sec |
The Following 3 Users Say Thank You to niloy2007 For This Useful Post: |
03-11-2011, 09:09 | #9756 (permalink) |
No Life Poster Join Date: Apr 2009 Location: The Great India
Member: 1004995 Status: Offline Thanks Meter: 230 | 3120 successfully flashed card found: registered to: narendrasingh Connect phone on selected interface... Core version : 1.17 , Rev : 2.3 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm364__09.41.mcusw PPM : rm364__09.41.ppm_w CNT : rm364__09.41_ISM_010.image_w_in_graphite Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. [BB5 FLASH]: Bootrom Ok! RAP_PUB: 0900020812567C56CE9F0440F67700A15ADDEEAE CMT_ROOT: BAF3A9C3DBFA8454937DB77F2B8852B1 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:06 Reopening the connection... Waiting for response: 30 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm364__09.41.mcusw Found 5 areas to erase Erasing area 0x00000000 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00040000 - 0x000BFFFF, NOR, CMT Result: 0000 Erasing area 0x000C0000 - 0x0013FFFF, NOR, CMT Result: 0000 Erasing area 0x01480000 - 0x015FFFFF, NOR, CMT Result: 0000 Erasing area 0x00140000 - 0x0147FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:01:29 Write : Processing rm364__09.41.mcusw Total 112 [112/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] TIME : Write time : 00:01:39 MCU Write done ===Flashing [PPM]=== Erase : Processing rm364__09.41.ppm_w Found 1 areas to erase Erasing area 0x01600000 - 0x01CBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:28 Write : Processing rm364__09.41.ppm_w Total 24 [24/0/0] blocks to write, writing... TIME : Write time : 00:00:31 PPM Write done ===Flashing [CNT]=== Erase : Processing rm364__09.41_ISM_010.image_w_in_graphite Found 2 areas to erase Erasing area 0x01FC0000 - 0x03F9FFFF, NOR, CMT Result: 0000 Erasing area 0x01CC0000 - 0x01FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:02:41 Checking content info... Check Image : Content size is 128k, use direct write mode Write : Processing rm364__09.41_ISM_010.image_w_in_graphite Total 34 [34/0/0] blocks to write, writing... TIME : Write time : 00:00:39 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:07:30 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 3120 classic Software Info: V 09.41 06-11-08 RM-364 (c) Nokia IMEI: 356851020968455 PPM version : V 09.41 06-11-08 RM-364 (c) Nokia W Product code: 0560873 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! AfterFlash operations done... Reconnect, wait... Done! Elapsed: 00:08:32 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... |
The Following 3 Users Say Thank You to narendrasingh For This Useful Post: |
03-11-2011, 09:25 | #9757 (permalink) |
Member: 1004995 Status: Offline Thanks Meter: 230 | Nokia 5130 successfullt flashed. card found: registered to: narendrasingh Connect phone on selected interface... Core version : 1.17 , Rev : 2.3 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm364__09.41.mcusw PPM : rm364__09.41.ppm_w CNT : rm364__09.41_ISM_010.image_w_in_graphite Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. [BB5 FLASH]: Bootrom Ok! RAP_PUB: 0900020812567C56CE9F0440F67700A15ADDEEAE CMT_ROOT: BAF3A9C3DBFA8454937DB77F2B8852B1 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:06 Reopening the connection... Waiting for response: 30 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm364__09.41.mcusw Found 5 areas to erase Erasing area 0x00000000 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00040000 - 0x000BFFFF, NOR, CMT Result: 0000 Erasing area 0x000C0000 - 0x0013FFFF, NOR, CMT Result: 0000 Erasing area 0x01480000 - 0x015FFFFF, NOR, CMT Result: 0000 Erasing area 0x00140000 - 0x0147FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:01:29 Write : Processing rm364__09.41.mcusw Total 112 [112/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] TIME : Write time : 00:01:39 MCU Write done ===Flashing [PPM]=== Erase : Processing rm364__09.41.ppm_w Found 1 areas to erase Erasing area 0x01600000 - 0x01CBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:28 Write : Processing rm364__09.41.ppm_w Total 24 [24/0/0] blocks to write, writing... TIME : Write time : 00:00:31 PPM Write done ===Flashing [CNT]=== Erase : Processing rm364__09.41_ISM_010.image_w_in_graphite Found 2 areas to erase Erasing area 0x01FC0000 - 0x03F9FFFF, NOR, CMT Result: 0000 Erasing area 0x01CC0000 - 0x01FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:02:41 Checking content info... Check Image : Content size is 128k, use direct write mode Write : Processing rm364__09.41_ISM_010.image_w_in_graphite Total 34 [34/0/0] blocks to write, writing... TIME : Write time : 00:00:39 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:07:30 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 3120 classic Software Info: V 09.41 06-11-08 RM-364 (c) Nokia IMEI: 356851020968455 PPM version : V 09.41 06-11-08 RM-364 (c) Nokia W Product code: 0560873 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! AfterFlash operations done... Reconnect, wait... Done! Elapsed: 00:08:32 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Core version : 1.17 , Rev : 2.3 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm495__07.97.mcusw PPM : rm495__07.97.ppm_mh CNT : rm495__07.97_v2.image_mh_blu Flashing phone now... Check files done... -> SWversion check skipped : Manual mode selected Backup CRT308 data... CRT308 Backup Created... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\355212039676996_SI M.rpl Getting product info... RAP_BOOT: 0803000302010000 RAP_PUBLIC: 1DA000178E2D7F5699C6E1C4C6F8A680404ACCB1 CMT_ROOTKEY: 9DDBFCFE6E73CED7D8C6268C8EB85723 RAP_PAPUBKEY: 0C917F11196FDB7378C18EF7260698CA4489DCA0 Checking CNT sector PN<>FL PN CNT sector : 128 kb ConvertImage: Processing rm495__07.97_v2.image_mh_blu ConvertImage: Page Size is 128K, no need convert Loader len: 308032, CHK: 048B ADL -> Sending loader... Update Server code succesfully sent to phone! TIME : Boot time : 00:00:04 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm495__07.97.mcusw Found 6 areas to erase Erasing area 0x00000000 - 0x000006BF, NOR, CMT Result: 0000 Erasing area 0x000006C0 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00040000 - 0x000BFFFF, NOR, CMT Result: 0000 Erasing area 0x000C0000 - 0x0013FFFF, NOR, CMT Result: 0000 Erasing area 0x00140000 - 0x0137FFFF, NOR, CMT Result: 0000 Erasing area 0x01380000 - 0x0151FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:02:12 Write : Processing rm495__07.97.mcusw Total 1178 [1178/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] TIME : Write time : 00:00:57 MCU Write done ===Flashing [PPM]=== Erase : Processing rm495__07.97.ppm_mh Found 1 areas to erase Erasing area 0x01520000 - 0x01DBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:56 Write : Processing rm495__07.97.ppm_mh Total 450 [450/0/0] blocks to write, writing... TIME : Write time : 00:00:22 PPM Write done ===Flashing [CNT]=== Erase : Processing rm495__07.97_v2.image_mh_blu Found 2 areas to erase Erasing area 0x01DC0000 - 0x0215FFFF, NOR, CMT Result: 0000 Erasing area 0x02160000 - 0x03FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:05:13 Write : Processing rm495__07.97_v2.image_mh_blu Total 536 [536/0/0] blocks to write, writing... TIME : Write time : 00:00:26 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:10:08 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 5130 Software Info: V 07.97 13-09-10 RM-495 (c) Nokia IMEI: 355212039676996 PPM version : V 07.97 13-09-10 RM-495 (c) Nokia MH Product code: 0577794 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! AfterFlash operations done... Reconnect, wait... Done! Elapsed: 00:10:58 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
03-11-2011, 09:48 | #9758 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: SL3 LBF IN Kamoke(Gujranwala)
Member: 481915 Status: Offline Sonork: 100.1604233 Thanks Meter: 476 | Vodafone 340 unlocked log: Quote:
mianlinks | |
The Following 2 Users Say Thank You to mianjabbar For This Useful Post: |
03-11-2011, 09:55 | #9759 (permalink) |
Member: 1004995 Status: Offline Thanks Meter: 230 | 3110 successfully flashed. card found: registered to: narendrasingh Connect phone on selected interface... Core version : 1.17 , Rev : 2.3 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm237__07.30.mcusw PPM : rm237__07.30.ppm_c CNT : rm237__07.30.image_c_tr Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. [BB5 FLASH]: Bootrom Ok! RAP_PUB: 07F00103EBB77B56F789D1FA404271D6A6656284 CMT_ROOT: BAF3A9C3DBFA8454937DB77F2B8852B1 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:00 Reopening the connection... Waiting for response: 30 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm237__07.30.mcusw Found 9 areas to erase Erasing area 0x00000000 - 0x000006BF, NOR, CMT Result: 0000 Erasing area 0x000006C0 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00020000 - 0x0007FFFF, NOR, CMT Result: 0000 Erasing area 0x00080000 - 0x000DFFFF, NOR, CMT Result: 0000 Erasing area 0x00100000 - 0x001FFFFF, NOR, CMT Result: 0000 Erasing area 0x00200000 - 0x0031FFFF, NOR, CMT Result: 0000 Erasing area 0x00320000 - 0x0105FFFF, NOR, CMT Result: 0000 Erasing area 0x01060000 - 0x01067FFF, NOR, CMT Result: 0000 Erasing area 0x01068000 - 0x0107FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:01:37 Write : Processing rm237__07.30.mcusw Total 945 [945/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [PAPUBKEYS] CMT : PAPUBKEYS skip, already sent CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] CMT : Writing Hash CERT [PMM_CONF] CMT : Writing Hash CERT [SBIF_CONF] TIME : Write time : 00:01:14 MCU Write done ===Flashing [PPM]=== Erase : Processing rm237__07.30.ppm_c Found 1 areas to erase Erasing area 0x01080000 - 0x0151FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:28 Write : Processing rm237__07.30.ppm_c Total 240 [240/0/0] blocks to write, writing... TIME : Write time : 00:00:19 PPM Write done ===Flashing [CNT]=== Erase : Processing rm237__07.30.image_c_tr Found 1 areas to erase Erasing area 0x01520000 - 0x01FDFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:01:09 Checking content info... Resetting phone... Checking CNT sector PN<>FL PN CNT sector : 128 kb ConvertImage: Processing rm237__07.30.image_c_tr ConvertImage: Page Size is 64K, converting... ConvertImage: File converted Loader len: 253888, CHK: 17DB ADL -> Sending loader... Reset connection... ADL : Check data ADL : Data accepted ADL : ASIC CMT select Ok Write : Processing rm237__07.30.image_c_tr_128 Total 240 [240/0/0] blocks to write, writing... TIME : Write time : 00:00:19 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:05:09 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 3110c Software Info: V 07.30 07-05-09 RM-237 (c) Nokia. IMEI: PPM version : V 07.30 07-05-09 RM-237 (c) Nokia. C Product code: 0550573 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! AfterFlash operations done... Reconnect, wait... Done! Elapsed: 00:06:12 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
03-11-2011, 10:10 | #9760 (permalink) |
Freak Poster Join Date: Dec 2009 Location: India
Member: 1191805 Status: Offline Thanks Meter: 58 | Huwai C2808 Unlock Sucessfully Log; checking version... Nov 17 2010C2808C02B213 Nov 17 2010C2808C02B213 Huawei C2808 version B213 selected.. Downloading mode... patching in progress... patching in progress 33%... patching in progress 66%... patching in progress 99%... patching in progress 100%... done... Finished, time used: 29 sec Thanks Infinity. |
The Following 3 Users Say Thank You to mick12 For This Useful Post: |
03-11-2011, 10:50 | #9761 (permalink) |
No Life Poster Join Date: Mar 2009 Location: Jainagar Bihar
Member: 992600 Status: Offline Thanks Meter: 1,670 | samsung b209 succssesfully unlock by infinity cdma tool thanx again COM2 [VSerial0] selected module v1.46 Device: Samsung-SCH-B209, B309, B319, B619, B339FM operation: SP-unlock Phone should be Switched ON ! connecting... Connecting, wait... Phone detected, wait... step-1/1 done step-1/2 done step-1/3 done step-1/4 done step-1/5 done step-2 done step-3 done operation finished Finished, time used: 24 sec |
The Following 4 Users Say Thank You to jawedakht For This Useful Post: |
03-11-2011, 10:54 | #9762 (permalink) |
Member: 1004995 Status: Offline Thanks Meter: 230 | n 6300 successfully flashed card found: registered to: narendrasingh Connect phone on selected interface... Core version : 1.17 , Rev : 2.3 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm217__07.30.mcusw PPM : rm217__07.30.ppm_r CNT : rm217__07.30.image_ctv_cn Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. [BB5 FLASH]: Bootrom Ok! RAP_PUB: 10000115A6627E56EF91D29D98AE838B6FB70C60 CMT_ROOT: BAF3A9C3DBFA8454937DB77F2B8852B1 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:00 Reopening the connection... Waiting for response: 30 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm217__07.30.mcusw Found 9 areas to erase Erasing area 0x00000000 - 0x000006BF, NOR, CMT Result: 0000 Erasing area 0x000006C0 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00020000 - 0x0007FFFF, NOR, CMT Result: 0000 Erasing area 0x00080000 - 0x000DFFFF, NOR, CMT Result: 0000 Erasing area 0x00100000 - 0x001FFFFF, NOR, CMT Result: 0000 Erasing area 0x00200000 - 0x0031FFFF, NOR, CMT Result: 0000 Erasing area 0x00320000 - 0x0105FFFF, NOR, CMT Result: 0000 Erasing area 0x01060000 - 0x01067FFF, NOR, CMT Result: 0000 Erasing area 0x01068000 - 0x0107FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:43 Write : Processing rm217__07.30.mcusw Total 944 [944/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] CMT : Writing Hash CERT [PMM_CONF] CMT : Writing Hash CERT [SBIF_CONF] TIME : Write time : 00:01:25 MCU Write done ===Flashing [PPM]=== Erase : Processing rm217__07.30.ppm_r Found 1 areas to erase Erasing area 0x01080000 - 0x015FFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:13 Write : Processing rm217__07.30.ppm_r Total 329 [329/0/0] blocks to write, writing... TIME : Write time : 00:00:31 PPM Write done ===Flashing [CNT]=== Erase : Processing rm217__07.30.image_ctv_cn Found 1 areas to erase Erasing area 0x01600000 - 0x01FDFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:28 Checking content info... Resetting phone... Checking CNT sector PN<>FL PN CNT sector : 128 kb ConvertImage: Processing rm217__07.30.image_ctv_cn ConvertImage: Page Size is 64K, converting... ConvertImage: File converted Loader len: 248320, CHK: 36E3 ADL -> Sending loader... Reset connection... ADL : Check data ADL : Data accepted ADL : ASIC CMT select Ok Write : Processing rm217__07.30.image_ctv_cn_128 Total 296 [296/0/0] blocks to write, writing... TIME : Write time : 00:00:26 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:03:49 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 6300 Software Info: V 07.30 07-05-09 RM-217 (c) Nokia. IMEI: PPM version : V 07.30 07-05-09 RM-217 (c) Nokia. R Product code: 0515596 AfterFlash operations done... Reconnect, wait... Elapsed: 00:04:53 |
03-11-2011, 12:41 | #9763 (permalink) |
No Life Poster Join Date: May 2007 Location: uk
Member: 508072 Status: Offline Thanks Meter: 1,621 | COM37 [Serial2] selected module v3.27 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: "repair imei" imei write channel: imei #1 (default imei inside firmware) new imei: 353923035446133 ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001103:0003 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 detecting chip #02 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 detecting chip #03 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent rom info detection finished rom info ver: 04 sw version: GINWAVE25_06B_PCB01_GPRS_MT6225_S00.FXD-S3_FOREIGN_MR106_004_S5T24T-MC-C01-RF3198_V1_0_019_080605.BIN project-id: FXD-S3_FOREIGN_MR106_004_S5T24T-MC-C01-RF3198_V1.0.019_080605, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [standard] type (04) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF firmware area: 00000000-00DFFFFF detecting startup code area #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... startup code area #2 is absent sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 01227E22202200:18E59F00000000 Backup required data Done ====> Patch required data ... detecting ffs/eeprom structure pass 2... ................. ffs/eeprom: detect std location pass #1... .................................................. .. ffs/eeprom: detect standard offset pass #1... ffs/eeprom record offset detected ffs/eeprom: detect standard data... ffs/eeprom record size detected ffs/eeprom layout detection complete ffs/eeprom detected ok element #2 imei default found: 13579024681122 Patch required data Done ====> Special operation ... Special operation Done ====> Write ... flash: 01227E22202200:18E59F00000000 flash: 01227E22202200:18E59F00000000 Write: imei Write Done ====> Finalization ... ffs formatting... flash: 01227E22202200:18E59F00000000 Finalization Done Finished, time used: 2 min 5 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following 2 Users Say Thank You to joni_rajpura For This Useful Post: |
03-11-2011, 13:23 | #9764 (permalink) |
No Life Poster Join Date: Apr 2009 Location: HM unlock fone mandi bahauddin
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | motorola wx295 unlock done COM3 [VCP0] selected module v3.78 Device: Motorola-WX295 Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:8479:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (05), 1 record(s) TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: c:\InfinityBox\MModule\backup_security\id.04769843 .[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V40_F5.BIN_3EFC4B46].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: 04769843 rom info ver: 05 sw version: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V40_F5.BIN project-id: MAUI.08A.W08.36.SP1.V40.F5, 464BFC3E code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 TCL-ID identification version: 566 provider: M295X-2BRGFR1 customization: CP56EK21 customization: XP56EK21 TCL-ID identification done rom info structure: [protected] type (05), 1 record(s) TCL-ID is present ffs/eeprom address assigned: 00C00000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization: XP56EK21 customization name adjusted flash: 98000300000001:2BEA0000000000 flash: 98000300000001:2BEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98000300000001:2BEA0000000000 flash: 98000300000001:2BEA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35835003325576 flash: 98000300000001:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98000300000001:2BEA0000000000 Finalization Done file saved: c:\InfinityBox\MModule\backup_security\Motorola-WX295_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W0 8_36_SP1_V40_F5__system_log_04769843_3EFC4B46_2011 0311-161444.B0X.bin Finished, time used: 4 min 16 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following 2 Users Say Thank You to naveedbutt For This Useful Post: |
03-11-2011, 13:25 | #9765 (permalink) |
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | n95 8gb done COM3 [VCP0] selected module v3.27 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:69BE:1FD4 status: FF high speed boot Off boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:2CEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC257E25082501:2CEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #02 in region #00... flash: EC257E25082501:2CEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #03 in region #00... flash: EC257E25082501:2CEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: EC257E25082501:2CEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC257E25082501:2CEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 it's time to stop: 2C0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (04), 1 record(s) TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: c:\InfinityBox\ChineseMiracle\backup_security\id.6 A09447D.[N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32.B IN_0188D56D].rpl ==================== New firmware found (v.3.27, database date: 03.03.2011): N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32.B IN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished device-id: 6A09447D rom info ver: 04 sw version: N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32.B IN project-id: MAUI.06B.W07.04.MP.V32, 6DD58801 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [protected] type (04), 1 record(s) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: EC257E25082501:2CEA0000000000 checking area [00000000]: 00080000-00FFFFFF... ffs/eeprom found near: 00BA0000 Detected ffs/eeprom address is non-standard: 00BA0000 Posible reasons: 1. ffs/eeprom is Ok but address is non-standard 2. ffs/eeprom is damaged and can't be detected 3. ffs/eeprom is Ok but detected incorrectly (f.e. unknown ffs/eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make full flash backup for emergency case 3. repeat required operation Are you sure that detected ffs/eeprom address is correct ? autodetected ffs/eeprom address confirmed by user: 00BA0000 detecting ffs/eeprom size... ffs/eeprom size: 00460000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00BA0000-00FFFFFF firmware area: 00000000-00B9FFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32__ ffs... file saved: C:\Documents and Settings\Administrator\Desktop\N95_PCB01_GPRS_MT62 26_S01.MAUI_06B_W07_04_MP_V32__ffs_20110311-123103.B0E.bin flash: EC257E25082501:2CEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: EC257E25082501:2CEA0000000000 Finalization Done file saved: c:\InfinityBox\ChineseMiracle\backup_security\N95_ PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32__syst em_log_6A09447D_0188D56D_20110311-123150.B0X.bin Finished, time used: 11 min 21 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
