Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Saras Boxes > HWK
Old 08-11-2005, 08:43   #1 (permalink)
jala's Avatar
Member: 17324
Thanks Meter: 40
HWK don't work with some boxes???
I have 3 boxes here, original tornado with support on usfxsupport site, after put HWK inside module not found. HWK is 100% ok....
any solution pls...
Best Regards
Old 08-11-2005, 09:20   #2 (permalink)
Odia The Ultimate's Avatar
Member: 4042
Thanks Meter: 24,043
any solution pls...
Best Regards
How you know HWK is 100%, you test with another box?
Odia.
The Following User Says Thank You to Odia The Ultimate For This Useful Post:
Old 08-11-2005, 09:27   #3 (permalink)
jala's Avatar
Member: 17324
Thanks Meter: 40
of course, I was sent You message on PM some days ago....
HWK module is 100% works with another box (twister, tornado), but with some tornado (3 pcs I have here) don't work.
Old 08-11-2005, 09:39   #4 (permalink)
Member: 4042
Ok, so maybe there is broken lines from the 16 lines from 16 pin header, you can compare with another box and check for this?
Odia.
Old 08-11-2005, 09:53   #5 (permalink)
Member: 34760
Thanks Meter: 2
Also please check the DCD line on the connector (pin 3?), it goes directly to the Xilinx.
This must be ON THE GROUND! So try to get a multimeter and measure this line. If you measure something (i.e. non zero) on the DCD line while the HWK is attached, then
there is something wrong. If DCD is on the ground, then try to measure pin 19 of the FTDI chip (it is also the DCD). Surely you must measure GND there as well!
Old 08-11-2005, 09:58   #6 (permalink)
jala's Avatar
Member: 17324
Thanks Meter: 40
I was check all , and all looks fine... all lines are mensured and I can't find any bug.
maybe any scheme for make some changes?
Also I changed full module in box from 100% correct box and no result too.
Old 08-11-2005, 10:04   #7 (permalink)
Member: 34760
Thanks Meter: 2
Please try to execute all 3 application, i.e. Nokia, Samsung and SonyEriccson as
well. They are different in terms of how they communicate towards the HWK.
Old 08-11-2005, 10:28   #8 (permalink)
jala's Avatar
Member: 17324
Thanks Meter: 40
I checked all, I have massage :
UFxBoot V2.2 (c) SarasSoft 2003. Id: 62 CF 1
UFS_USB V2.5 (c) SarasSoft 2003. S/n: xxxxx
HWK: not Attached
Licence: True
Selected Device, not Compatible with Software
Old 08-11-2005, 10:32   #9 (permalink)
Member: 34760
Thanks Meter: 2
WOW. HWK only works with V2.6 and above.
Don't you have a question about upgrading your box when you try to connect??
You must upgrade to 2.6
Old 08-11-2005, 10:35   #10 (permalink)
jala's Avatar
Member: 17324
Thanks Meter: 40
eh, this is customer box... but there is no massage about update....
Old 08-11-2005, 10:40   #11 (permalink)
Member: 34760
Thanks Meter: 2
Well then you must do the following.
1. Try to find out who is your reseller, since you will need .FBIs (i.e. reactivating
your box). If you do not know who is your reseller, or you cannot reach your
reseller, DO NOT DO THIS REACTIVATION OTHERWISE YOU WILL NOT BE ABLE TO
USE YOUR BOX!
2. Connect with 1.3k
3. Click Upgrade firmware
4. Try to get a REQ.FBI from somewhere (twister support area for example)
5. Upload REQ.FBI to your box, it will automatically upgrade the firmware of the box
to 2.6
6. Send the generated .REQ file (0000XXXX.REQ, where XXXX is your serial number)
to your reseller so that he can generate you a reply .FBI file
7. Connect again
8. Click on upgrade firmware
9. Select the generated 0000XXXX.FBI file
Hopefully your box shall be working from now on with your HWKs
Old 08-11-2005, 10:43   #12 (permalink)
jala's Avatar
Member: 17324
Thanks Meter: 40
thx for info, I know who is reseller and I know how to make update, but I did not know, that HWK works only on 2.6 and above...
I am greatefull for Your help. I will test this.
Thx one more time and regards.
Old 08-11-2005, 10:48   #13 (permalink)
jala's Avatar
Member: 17324
Thanks Meter: 40
I have this box here, and I have the newest version, I will make update box and post result here.
Old 08-16-2005, 10:03   #14 (permalink)
jala's Avatar
Member: 17324
Thanks Meter: 40
after update:
UFS_USB V2.6 (c) SarasSoft 2005. S/n: xxxxx
HWK: not Attached
Licence: True
my hwk don't work tahernike HWK 2 10-29-2007 19:46
hwk only working on some modules OKOKO HWK 1 10-09-2006 20:33
Redbox works with some of my pc's and don't work with others !!! makroud Redbox 5 04-25-2006 09:26
DCT4 free don't work with me rolko_mobile Nokia Digital Core Technology 4 ( DCT-4 ) 6 08-08-2002 22:54
Page generated in 0.19338 seconds with 9 queries
