S-Gold Based Phones This is the section for all S-Gold based phones like: C65,C72,C75,C81,CF75,CX65,CX70,CX75,M65,M75,ME75, S65,S68,S75,S81,S82,S88,SK65,SP65,SL65,SL75 All about Papua Utils and x65 Flashers you can get it from here. |
12-23-2005, 18:29 | #31 (permalink) | |
Freak Poster Join Date: Mar 2004 Age: 53
Member: 58120 Status: Offline Thanks Meter: 4 | Quote:
c72 unlocked with same metode like c65 ...tested and 100% work... Last edited by GORAN_CRO; 05-16-2006 at 22:10. | |
12-23-2005, 20:01 | #32 (permalink) | |
Junior Member Join Date: Dec 2005
Member: 208662 Status: Offline Thanks Meter: 0 | Quote:
Tell me, please, if you do unlock with or without the sim(=phone card) inside the phone. Did you used usb cable DCA 510 Siemens original? Thank you for your replies and merry christmas! | |
12-26-2005, 20:08 | #34 (permalink) | |
Thanks for your help. | |
12-27-2005, 19:59 | #37 (permalink) |
Member: 208662 Status: Offline Thanks Meter: 0 | My C72 is all unbarred: i know this after *#0606# test. My problem is display whit Vodafone layout (I paste a image). I want change this layout: vodafone live and other vodafone's settings are not for me. I want a original Siemens C72 not a branding Vodafone Siemens... I must unlock my phone with tp and Papua tools or i can change layout only with a new firmware? Thanks for your replies! |
12-29-2005, 02:26 | #38 (permalink) |
Freak Poster Join Date: Jul 2001 Location: macedonija skopje Age: 55
Member: 5292 Status: Offline Thanks Meter: 5 | And >>>> En The End I Make All But How To Write Map File In The Phone? I Find All Data (esn Skey Bkey ) Make Map From Log But In This Russian Program I Can't Find "upload Map" Which Buton To Press For Finnis Unlocking? Thanks |
12-29-2005, 03:18 | #39 (permalink) |
No Life Poster Join Date: Nov 2004
Member: 92326 Status: Offline Thanks Meter: 205 | here i go ONCE again........ NO TP - NO OPEN - NO CUTS ....100% secure -USE DATA CABLE- with SiMoCoSetup225.exe ..and never disconect the cable! - Copy PX65V4(px65v4.jar to phone in: "Data\Java\jam\Applications" - start aplication (into phone) -» Data\Applications-»px65v4 - Confirm local conexion 'By Session'. - Confirm acess aplication java to data cable. -Wait 10 / 20 minutes. - wait for a 'beep' and the IMEI/ESN/HASH should in phone. -dont touch nothing and run x65flasher-1072. -click connect, so the 'keys' calculate starts. wait the calculate. - start x65PapuaUtils and click button 'PX65V4' - program starts receiving imei/esn/hash from java aplication. - Click "Calculate Skey and Bkey' and wait skey e a bkey to be calculated - turn off the phone -USE UNLOCK CABLE - GO 'ServiceMode'. - click'Enter Skey to phone' (5º button left).now all keys are saved -Enter Skey to phone', should appear 'FactoryMode'. - Cick'Freia.log'. dont save the log, CANCEL. after that the prog ask if you want write blocks directly to phone. click Yes. - Program write the blocks and voilá . -------> your phone is UNLOCKED <------- [356909002651398] SKEY=86725563 BKEY=85B309894FD9770788C5F5AD3F104678 HASH=00DFEF2C7EF29E82DED9F99E6EBBEB48 ESN=7952248E Phone=SIEMENS CF75 10 lg1 HWID=5003 -------> your phone is UNLOCKED <------- enjoy again and post results sm4rtboy Last edited by SM4RTBOY; 12-29-2005 at 03:44. |
12-29-2005, 11:06 | #40 (permalink) |
Member: 5292 Status: Offline Thanks Meter: 5 | I finaly find solution with test point and with x65PapuaUtils First find ESN SKEY BKEY same as old C65 and after go in FLASH meni and check REPLACE 76,5008,5009,5077 press DO JOB and phone unlocked |
12-29-2005, 20:00 | #41 (permalink) | |
There is something that don't go very well. My questions i think are very simply and the answers are very difficult. How many cables i must get? -Data cable... Usb cable? Serial cable? Original Siemens cable or any? -Unlock cable... Where can i found it? -Sim card... phone is with or without sim card inside? In C65 unlock step by step, i can't found answer for this item. -SimocoSetup225.exe... Can you write a link (without virus inside) for download it? Thanks for your replies and Happy new year! | |
01-01-2006, 08:44 | #43 (permalink) | |
No Life Poster Join Date: Jun 2004 Location: Azerbaijan Age: 38
Member: 68498 Status: Offline Thanks Meter: 152 | Quote:
Then use test point | |
01-05-2006, 03:58 | #44 (permalink) |
Freak Poster Join Date: Jan 2005
Member: 104999 Status: Offline Thanks Meter: 5 | When finally I upload the java patch px65v4 (with a original data cable from Siemens tested) It can never run the aplication. says: Wrong Aplication... it happens exactly the same ina S65... but in goes well on SL65 and others... I´m triying via TP.. please could everybody can tell me the exactly TP cus I can get ESN & HASH... resisitor? same brige? NEVER IT CONECTS! With TP.. without it reads the IMEI etc etc but of course.. no TP.. no esn & Hash... Please anybody have a steep by steep solution from the beginin? Thanks! Last edited by unlockteam; 01-05-2006 at 04:10. |
01-05-2006, 14:32 | #45 (permalink) |
Freak Poster Join Date: Sep 2002 Location: Slovenia Age: 48
Member: 15385 Status: Offline Thanks Meter: 9 | try but no luck Hey! I try to unlock c72 ver. 16 vith method like c65 with papua. I made a test point, start program, Autoignition OK, I push power ON, Transmit Boot... Boot Loaded Pause 2 sec.... I remove test point and do nothing after that Retrieve information No answer to boot Boot unlock. and here ends everything Did I need to push anything when I remove test point after "Pause 2sec" ? Do I need to do anything else? Please help me. Regards, Dejan |
C72 Unlock Tutorial (all X65, X75 Too) | andrija | S-Gold Based Phones | 125 | 05-30-2007 08:43 |
benq C72 unlock and dead ??????? | Gsm Lab | DreamBox | 26 | 02-05-2007 19:14 |
c72 unlock problem | shruti | SST-Dongle | 2 | 04-30-2006 09:58 |
C72 Unlock !! Test Point Cable | Mierdita | DreamBox | 3 | 02-03-2006 20:37 |
C72 unlock? | ecs-gsm | SST-Dongle | 11 | 12-24-2005 03:25 |
