06-14-2009, 23:28 | #16 (permalink) |
No Life Poster Join Date: May 2005 Location: Tunisia Age: 46
Member: 145648 Status: Offline Sonork: 100.100487 The_Gorr Thanks Meter: 23,034 | IMEI REPAIR BUTTON WAS HIDDEN CAUSE IN SOME COUNTRY THIS OPTION IS NOT ALLOWED TO ACTIVATE IT JUST FALLOW THIS KEYBOARD COMBINATION |
The Following 12 Users Say Thank You to The_Gorr For This Useful Post: |
06-14-2009, 23:39 | #17 (permalink) |
Member: 145648 Status: Offline Sonork: 100.100487 The_Gorr Thanks Meter: 23,034 | I CAN'T ENTER SUPPORT, I CAN'T USE MY LG ACTIVATION, MY LOGIN AND PASS IN SAT WE SAVED CORRECTLY BUT STILL HAVE PROBLEM U HAVE TO KNOW THAT OLD UPDATES STOP TO ACCESS SERVER AND SUPPORT IF A NEW UPDATE WAS ANNONCED SO JUST DOWNLOAD LAST ONE AND ALL WILL BE OK IF U CAN'T ACCESS TO SUPPORT TO DOWNLOAD LAST UPDATE JUST VISIT THIS LINK here |
The Following 3 Users Say Thank You to The_Gorr For This Useful Post: |
06-14-2009, 23:43 | #18 (permalink) |
Member: 145648 Status: Offline Sonork: 100.100487 The_Gorr Thanks Meter: 23,034 | POLAR GIVE ME TWO WAYS TO CONNECT MY SUMSUNG PHONE (HYBRID AND ORIGINAL USB CABLE) BUT I CAN'T FIND NEEDED DRIVERS FOR BOTH METHODE JUST ENTER SUPPORT AREA, GO TO DRIVERS SECTION AND FALLWO THIS IMAGE |
The Following 4 Users Say Thank You to The_Gorr For This Useful Post: |
06-14-2009, 23:46 | #19 (permalink) |
Member: 145648 Status: Offline Sonork: 100.100487 The_Gorr Thanks Meter: 23,034 | I SEE THAT POLAR SUPPORT OLD ALCATELS MODELS BUT CAN'T FIND THEM IN POLAR SUITE !!!! JUST GO TO POLAR MAIN DIRECTORY, U'LL FIND ALL NEEDED SOFTWARE FOR OLD ALCATELS PS: U NEED TO USE VIRTUAL COM TO CONNECT UR OLD ALCATEL, USING POLAR RJ45 WILL NOT WORK Last edited by The_Gorr; 06-14-2009 at 23:53. |
The Following 13 Users Say Thank You to The_Gorr For This Useful Post: |
06-15-2009, 00:16 | #20 (permalink) |
Member: 145648 Status: Offline Sonork: 100.100487 The_Gorr Thanks Meter: 23,034 | I CAN'T UNLOCK LG 3G PHONES, ALWAYS GET THIS ERROR : USB SHARING IS NOT ALLOWED, UR BOX CAN BE BLACK LISTED ALL WHAT U HAVE TO DO IS TO REMOVE COMPLITLY ANY USB SHARING PROGRAM FROM UR COMPUTER, REBOOT, AND USE UR POLAR WITHOUT ANY PROBLEM |
06-15-2009, 19:56 | #21 (permalink) |
Member: 145648 Status: Offline Sonork: 100.100487 The_Gorr Thanks Meter: 23,034 | I HAVE PROBLEM TO IDENTIFY MY SAGEM IF IT'S A NEW SECURED ONE, NOT SUPPORTED BY ANY TOOL JUST CHECK THIS IMAGE, IF UR PHONE HAVE V2 mcu, THEN IT'S NOT SUPPORTED BY ANY TOOL |
The Following 8 Users Say Thank You to The_Gorr For This Useful Post: |
06-17-2009, 23:28 | #22 (permalink) |
Member: 145648 Status: Offline Sonork: 100.100487 The_Gorr Thanks Meter: 23,034 | WHEN I CONNECT X PHONE TO USB I GET THIS ERROR AND CAN'T INSTALL DRIVERS THIS ERROR CAN BE CAUSED BY : PC SUITE (DESABLE IT) BAD CABLE (CHANGE IT), DAMAGED PHONE CONNECTOR (CHANGE IT), LOW USB POWER (USE USB HUB) Last edited by The_Gorr; 06-18-2009 at 00:12. |
The Following 6 Users Say Thank You to The_Gorr For This Useful Post: |
07-11-2009, 22:09 | #23 (permalink) |
Member: 145648 Status: Offline Sonork: 100.100487 The_Gorr Thanks Meter: 23,034 | when i try to unlock lg 3g i get always this error : Server desabled 1- this mean, no connexion with server 2- check if u are using last update 3- desable firwall 4- desable antivirus |
The Following 5 Users Say Thank You to The_Gorr For This Useful Post: |
08-03-2009, 01:51 | #24 (permalink) | |
Banned Join Date: Jul 2005 Location: Philippines Age: 53
Member: 161739 Status: Offline Sonork: 100.1584054 Thanks Meter: 3,338 | Problem unlocking all Moto phones? solution: Quote:
The Following 4 Users Say Thank You to FullFLASHgSMPH For This Useful Post: |
08-04-2009, 09:10 | #25 (permalink) |
Cheater -Don't Deal with him- Join Date: Jan 2005 Location: U S A / GOA /CHINA Age: 44
Member: 106367 Status: Offline Sonork: 100.1577436 Thanks Meter: 2,452 | ★★★★★★ Polar box2 FAQS & HELP ★★★★★★ HERE IS THE EASY WAY TO FIND UR POLAR BOX SERIAL NO. REGARDS |
The Following 4 Users Say Thank You to chiragp For This Useful Post: |
08-05-2009, 15:25 | #26 (permalink) |
Member: 145648 Status: Offline Sonork: 100.100487 The_Gorr Thanks Meter: 23,034 | i have credits in my polar account, what models can i unlock with these credits !!!!! with polar credits u can unlock absolutly all phones that need credits (sagem, vodafone, modems, pcmcia, blackberry and any future service that will need credits) Last edited by The_Gorr; 08-05-2009 at 15:31. |
08-05-2009, 15:25 | #27 (permalink) |
Member: 145648 Status: Offline Sonork: 100.100487 The_Gorr Thanks Meter: 23,034 | FOR UNLOCK BLACKBERRY I NEED CREDITS OR ACTIVATION !!!! for unlock blackberry u can use credits (each phone will need 20 credits) or make activation for unlimited unlock (without credits) Last edited by The_Gorr; 08-05-2009 at 15:35. |
08-06-2009, 02:32 | #28 (permalink) | |
Member: 161739 Status: Offline Sonork: 100.1584054 Thanks Meter: 3,338 | How to know when BB activation is ready solution: Quote:
The Following 3 Users Say Thank You to FullFLASHgSMPH For This Useful Post: |
08-16-2009, 06:40 | #29 (permalink) | |
Member: 161739 Status: Offline Sonork: 100.1584054 Thanks Meter: 3,338 | Problem: Quote:
2 posible reason LG not activated/phone not supported Br. | |
08-20-2009, 02:38 | #30 (permalink) |
Member: 161739 Status: Offline Sonork: 100.1584054 Thanks Meter: 3,338 | How to Disable Phone code protection on Blackberry phones. Download the file policy.bin and save it in your Blackberry installation directory (C:\Program Files\Research In Motion\BlackBerry). From the Windows XP Start Menu select Run..., and at the prompt type regedit. In the tree on the left hand side, navigate to: HKEY_Current_Users\Software\Research In Motion\BlackBerry\PolicyManager Right-Click the Policy Manager Folder and select New/String Value. Name the value Path. Now, Double-Click the Path Subkey and set Value Data to: C:\Program Files\Research In Motion\BlackBerry\policy.bin Step 6 : Open the Desktop Manager. Step 7 : Connect the Device. Verification Once complete, the Options/Security screen on your Blackberry should not contain references to an IT Policy, you should now be able to change all settings (including password prompts), and install Third Party Applications. Tested also From old : 71xx Series : 7100g,7100g,7100i,7100r,7100t,7100v,7105t,7130e 72xx Series : 7230, 7250, 7280, 7290, 75xx Series : 7520, 77xx Series : 7730, 7750, 7780 Blackberry Password How!!!!! [SOLUTION] Many friends facing problem while unlocking the phone with BB server (phone lock) So let start from here if you know the password please insert it before unlocking or try to enter wrong password 10 time it will format the user area of the phone automatically and asking to enter new password , so insert new password and press enter : Now do the fallowing: 1) unplug usb cable 2) go to phone MENU , SETTING,OPTION,SECURITY 3) press the wheel inside and press WIPE HANHELD 4) wait until formatting complete and phone will restart again 5) it should now asking to enter new password , so ignore it 6) plug your USB cable and run BB server unlocking software 7) press read codes ( taking almost 1 to 2 min) 8) now unplug the phone and enter any password 9) go to phone menu and setting, option , sim card 10) pres shift key and enter MEPD, 11) now pres shift and enter MEP2 12) release shift key and enter the code which you got it from BB SERVER now phone should be unlocked Test 1 Test 2 DONE Phone readed in easy WAY!!!!!!!!!!!! http://forum.gsmhosting.com/vbb/6597136-post13.html Last edited by FullFLASHgSMPH; 12-01-2010 at 00:11. |
Upload & Download Eprom | Lousangeles | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 06-24-1999 05:45 |
