RE-7500 Reworking System & iSolder the Infrared Reworking System - Product By Jovy Systems. & iSolder the intelligent soldering machine |
01-03-2009, 03:32 | #16 (permalink) |
Junior Member Join Date: Apr 2003 Age: 49
Member: 27509 Status: Offline Thanks Meter: 0 | I'm trying to Trion's method with RE-7500 but no luck - Place 360 motherboard on XY tabel and set L.H to Preheat mode (machine in park mode) - Wait to 75 degrees and set machine to normal mode - Turn off L.H. and turn on U.H. in fast reflow mode - Waiting for 105 degrees and turn off U.H. - After 30 seconds, cool down the pcb with fan Is this method correct, or where is the mistake ? Please help me because I'm very despondent... Last edited by dusan75; 01-03-2009 at 03:38. |
03-02-2009, 20:08 | #17 (permalink) | |
Junior Member Join Date: Nov 2008 Location: UK
Member: 905777 Status: Offline Thanks Meter: 3 | Quote:
03-02-2009, 20:17 | #18 (permalink) | |
No Life Poster Join Date: Mar 2007 Location: Dominican Republic
Member: 469532 Status: Offline Sonork: TG: CodebUnlocks Thanks Meter: 868 | Quote:
chek this also this metod work fine for me /... youtube part 1 youtube part 2 | |
The Following User Says Thank You to Mr_F10ch3 For This Useful Post: |
03-09-2009, 20:16 | #19 (permalink) |
Freak Poster Join Date: Nov 2003
Member: 44625 Status: Offline Thanks Meter: 36 | My friends, am sorry i haven't posted here in a while. The heating method as i had shown here way back is a temporary fix. As Raheeeb said, its better to reflow the joints rather than just heating the parts as i was doing. This requires higher temperatures and the process is different. In some cases its even better to reball the CPU and GPU. Kits are now available on the net for doing this. The best solution would be to remove the ICs and reball them with leaded solder paste (yes i did say lead based solder and NOT ROHS solders that cause the problem). This along with improving the cooling as give on the Llama forums besides other forums will be a more lasting solution. Please be warned that the methods mentioned in the post above this one on the You tube videos are temporary fixes too and mainly work by putting pressure on the balls. Then as the borad starts heating and warping the board starts giving problems again that get progressively worse. The you tube works only for short periods. |
03-10-2009, 10:15 | #20 (permalink) |
No Life Poster Join Date: Oct 2001 Location: -------- Age: 55
Member: 7062 Status: Offline Thanks Meter: 126 | @all I found these video i think it is helpful http://www.jovy-sys.com/videos/Latest/ Hope to get some feedback from the ppl here |
The Following User Says Thank You to Raheeeeb For This Useful Post: |
03-10-2009, 10:15 | #21 (permalink) |
03-10-2009, 16:20 | #22 (permalink) |
No Life Poster Join Date: May 2002 Location: Wolverhampton UK Age: 54
Member: 12296 Status: Offline Thanks Meter: 9 | I think the easiest way is to change the X-clamps with proper screws ..just find the right thickness metal washers for mounting the heatsinks on top....bottom i normally use fiber washers . same way i fixed many and none of them came back...quick and easy fix...cost you less than 5 £... WBR Surej |
03-11-2009, 21:23 | #23 (permalink) |
Member: 44625 Status: Offline Thanks Meter: 36 | Dear Raheeeeb, Thanks for the link as its useful for us to know the temperatures for ******* a reballed GPU. Could you kindly give some tips here for those who wish to reflow their 360 GPU and other Chips? Thanks again. Best regards! |
05-03-2009, 09:49 | #24 (permalink) |
Insane Poster Join Date: Sep 2008
Member: 869567 Status: Offline Thanks Meter: 3 | Xbox 360 profiles wanted Found this on avrepair. http://www.jovy.avrepair.com/product/xbox/index.htm The XBox360 RRoD Solution : Upwards of 70% of all XBox360’s only need to have the GPU reflowed, to restore the unit to proper operating condition. This can be accomplished quickly and easily by using the Jovy Systems’ RE-7500 Rework Station. System comes complete with X-Y table included. Everything you need to start servicing the XBox 360 is included. You’re ready to go, right out of the box. (Includes 3 downloadable xbox specific profiles) Especially this interested me: (Includes 3 downloadable xbox specific profiles) Checked jovy site to see if they have the profiles on their site also. Horror, couldn't login anymore. Been trying for 2 days now, no luck. Has someone else those profiles and want to share them please? Put it up somewhere for download, or mail them? Or is there maybe a "generic" or "public" login for jovy site? Hope someone helps, would be very much appreciated. Thanks in advance. Regards. |
05-05-2009, 20:52 | #25 (permalink) |
Member: 44625 Status: Offline Thanks Meter: 36 | Thanks to Raheeeeb's links to the new videos we can easily see the process to fit a reballed GPU on the 360 motherboard. Its in the video called "GPU XBOXLIVE". The best solution is to reball the GPU . If we watch carefully we can see the temperatures, the heater settings and the duration of the process which is around 3 minutes. To learn how to reball ICs with the machine, we need to watch older videos whose links have been provided by Raheeeeb. Just look in the sticky posts in this forum. For reflowing we could use similar settings. @Deusjevoo, When you buy a machine, you can make a user profile on the site. B.R. Trion |
05-05-2009, 21:30 | #26 (permalink) | |
Member: 869567 Status: Offline Thanks Meter: 3 | Quote:
Bought the machine second hand. Asked for a login long time ago, never got an answer. Used the login from the first buyer for now. Looks like that has been disabled. So, if someone wants to help me out .... For the profiles, was thinking there was maybe a sort of reflow only profile or so for the gpu among them, as that is often enough. Would very much like to have them all as they are probably "right" profiles that make me more comfortable to use than experimenting myself. That "GPU XBOXLIVE" video is for the old xbox I think. Don't think that was lead-free ? Making profiles is not that easy for someone unexperienced in my opinion Not enough info on the working of the machine. Like, what do the different settings do? What is the difference between reflow and fast reflow? I mean this more technically. What is the power used? How fast should temperature go up with different settings? For working on top of the board, is it necessary to fast reflow bottom side? Does kapton tape have influence on temp of the board? Or does it only components at place? Those things are not explained anywhere. Using FR on bottom, components can fall of. Happened to me allready, and I did use kapton tape on the bottom to cover most of the bottom surface. Offcousre, lost some that where not covered. It is offcourse a technique I still have to learn. Thanks anyway for your reaction. And this is a great site, found lots of info on it. Want to thank all of you guys. And offcourse, especially Raheeb. Regards. | |
05-05-2009, 22:39 | #27 (permalink) |
Member: 44625 Status: Offline Thanks Meter: 36 | @Deusjevoo, The old Xbox had no issues with its GPU, CPU or almost any component besides the DVD drive. If u modchipped it and put in a large Hard disk, it can run for years without any problems, provided u ensure good power and that its little cooling fan is free of dust. Its one of the best consoles ever designed. At one time i had 4 as i was running a game parlour. I still have 2 and its over 8 years for the oldest and it still runs. The other is around 7 years old and running. The video is for the 360, no mistake about this. See, its possible to do work with absolutely no profile whatsoever. profiles are needed when u have repetitive jobs. If u watch the videos Raheeeeb has posted and the video links carefully at least 2-3 times each u will learn more than u could if u were give a 500 page manual. He's even shown how to make profiles. You can manually control settings. Don't be afraid to experiment. You can do this on dead or scrap phones or computer motherboards. Surely u can find some of those for a start. While you are learning, pretend that there is no info out there except for what's available in this forum. Learn to make profiles if needed. Besides net based support, there are phone numbers listed listed on the Jovy site. Try those if you need. Overall the best technical tips you can get are here. Only in certain cases do we need to contact Jovy. In my case i had a problem due to my machine firmware getting corrupted due to faulty power. Jovy helped me out for free even though it was well beyond the 1 year warranty. See the reflow settings are different power levels of the IR heaters with preheat being lowest for the lower one and fast reflow being the highest for both the lower and upper heaters. The exact power output given by these heaters under the specific settings isn't known by me and this knowledge isn't necessary if one learns how to use the machine. To learn, go through all the posts in this RE-7500 forum section starting with the oldest. Read everything, watch every video (at least 2-3 times), make your own notes and try out what you learn. Pretend that you got the machine from a dead alien civilization and that what info is here is all there is . As long as the machine works fine and communicates with a PC, you can use it fully. Avoid fast reflow on lower side of PCB for mobile phones. Again i repeat, watch the videos whose links were given by Raheeeeb very carefully. he's one of the most experienced SMD rework professionals on this website and has lots of experience. He's very busy and yet took time to share his knowledge for free. Make use of this. There are many others who know a lot, but don't share info. You may PM me if all efforts to contact Jovy fail. I have some email addresses that i used to communicate. I find calling Jovy on the numbers on their site is useful. They may then ask you to email them the details of any problems. There don't seem to be any new profiles on the website. The only real forum with useful info for this machine is right here on GSM-forum. We all learn by making mistakes. The first time i used the machine on a scrap PC motherboard, i used too much heat and cracked an I/O chip. Now i know the limits I'm certain you like most others who are using this machine are quite intelligent. Don't be shy to use your intelligence. Good luck! Trion |
05-05-2009, 23:04 | #28 (permalink) |
Member: 44625 Status: Offline Thanks Meter: 36 | One thing i forgot to mention, read the manual. If need be, you can download it from the Jovy website. Here's a useful link for those who need stencils for the Xbox 360 Chips reballing: http://stores.shop.ebay.com/Summers-...__W0QQ_armrsZ1 Last edited by Trion; 05-05-2009 at 23:09. |
05-06-2009, 01:05 | #29 (permalink) |
Member: 869567 Status: Offline Thanks Meter: 3 | @Trion Thanks again very much for your info and the pep-talk. Indeed, I maybe should experiment more myself. I read all the forum and saw think all the movies. They are indeed very informative. Gonna have a look again and filter out what I need. Working by hand, my machine has a problem however. Often the led goes blank. All text disappears. The machine still keeps working though. Any idea maybe? Also, a kid of the family accidentally broke the original temperature probe. Had to replace it, but I think that is not a problem? Suppose it are standard probes? Those xbox 360 profiles, whas on AVRepair, with the xbox 360 bga kit. http://www.jovy.avrepair.com/product/xbox/index.htm Thought they would be on jovy's site to. If you should come across them sometime maybe you let me know...? I'll see to contact jovy and try to get a login again. Agree with you this a great site to find about the jovy rework. It is my 2nd most read. Check it every day. Regards. |
05-06-2009, 12:49 | #30 (permalink) |
Member: 869567 Status: Offline Thanks Meter: 3 | @Trion Just letting you know, nothing ment by it. Looked at that "GPU XBOXLIVE" video again. It is an old xbox 1, surely not a 360. The chip is an nvidia, which was on the old xbox, 360 is ATI gpu. See also the IDE connector in front. Xbox 1 was IDE, Xbox 360 is sata. Regards. |
Tutorial of Remove Glued rap and flash chip by Jovy RE 7500 | Raheeeeb | RE-7500 Reworking System & iSolder | 39 | 02-26-2009 11:33 |
PLEASE HELP! NEED MY K850i FLASHED - GOT THE BLUE RING OF DEATH 'BROD' BUG! | vickylee2008 | KULANKENDI Server | 5 | 04-28-2008 14:18 |
Tutorial of de-soldring by Jovy RE 7500 | Raheeeeb | RE-7500 Reworking System & iSolder | 4 | 06-25-2007 00:48 |
killed 3 fones with re 7500 | farry | RE-7500 Reworking System & iSolder | 5 | 05-03-2007 22:28 |
didnt able to fix white screen of W850 with infinity SE-DB2020 client | Softway | Infinity-Box | 5 | 04-22-2007 11:09 |
