Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SRS (Simlock Remote Server)
Old 03-10-2010, 14:14   #1 (permalink)
sebaelpotro's Avatar
Member: 472354
Sonork: 1580747
Thanks Meter: 67
Warning: Crypto block not found m2510
Hy Srs team, i have a problem with one M2510
I try to read codes with sim inside and i have this problem:
10:11:03 - SET TESTMODE DONE
10:11:03 - IMEI: 35302503******
10:11:04 - FIRMWARE: M2510URIE (September R)
10:11:06 - MSL ADDRESS: RPISB59722
10:11:07 - ADVANCED MSL DETECTED BYPASSING...
10:11:47 - WARNING: CRYPTO BLOCK NOT FOUND
10:11:47 - MSL BYPASS: FAILED
The some problem with direct unlock.
Can you solve this?
B.R.
SEBAELPOTRO!
sorry for my bad english I speek only spanish
Old 03-10-2010, 15:20   #2 (permalink)
ssa
ssa's Avatar
Member: 23420
Thanks Meter: 3,080
Can you solve this?
B.R.
SEBAELPOTRO!
can you send me the dump file located in c:\program files\simlock remote client\dump
then we can analyse it
btw try also by selecting m2520 as model
The Following User Says Thank You to ssa For This Useful Post:
Old 03-10-2010, 15:39   #3 (permalink)
Member: 472354
Sonork: 1580747
Thanks Meter: 67
Whit m2520 model the some error crypto block not found
This is the dump folder
http://www.megaupload.com/?d=J4JJIA7I
And the imei is:
35401303314071/1
Old 03-10-2010, 15:53   #4 (permalink)
Member: 472354
Sonork: 1580747
Thanks Meter: 67
This is the original LOG
Booting Trident Phone...
11:53:09 - SET TESTMODE DONE
11:53:10 - IMEI: 35401303314071
11:53:11 - FIRMWARE: M2510VCIE (May 2009)
11:53:13 - MSL ADDRESS: RS5SB33001
11:53:14 - ADVANCED MSL DETECTED BYPASSING...
11:53:54 - WARNING: CRYPTO BLOCK NOT FOUND
11:53:54 - MSL BYPASS: FAILED
Old 03-10-2010, 16:23   #5 (permalink)
ssa
ssa's Avatar
Member: 23420
Thanks Meter: 3,080
I checked it, and found a strange issue, will make an update for this so you can re-test
Old 03-10-2010, 16:45   #6 (permalink)
ssa
ssa's Avatar
Member: 23420
Thanks Meter: 3,080
Press in the client ALT+R to relead phone data
then shutdown client, and restart, now try again
there was some security change in your firmware but hope it will be fine now
The Following 2 Users Say Thank You to ssa For This Useful Post:
Old 03-10-2010, 22:15   #7 (permalink)
Member: 472354
Sonork: 1580747
Thanks Meter: 67
This is the best support!!!
Very Thanks SRS TEAM!!!
Now its all ok!
B.R.
SEBAELPOTRO!
Alcatel S120 Flash File not found in support [SOLVED] surin PolarBox 3 16 03-30-2010 10:57
WARNING: Apple blocks downgrade to OS 3.0 or 3.0.1 TheTelecomShop iPhone 2 / iPhone 3G / iPhone 3GS 3 09-13-2009 13:36
i still not use it apple not found and license not found ABDULLAHI MUHD FuriousGold 2 06-16-2009 12:57
CRYPTO-BOX not found or contains not valid data Dayratel NSPRO 2 05-11-2006 13:09
Page generated in 0.24605 seconds with 9 queries
