Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 08-22-2009, 00:01   #16 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
Thanks Meter: 22,689
Then,
let's update firmware again,
and again
Old 08-24-2009, 22:53   #17 (permalink)
Member: 267789
Thanks Meter: 5
Facoly
Moulnisky
I tried several times unsuccessfully I think you want a good solution to problem
Did you update the firmware of your box again?
Alex
how to give me the tutorial
Just click on box maintance and afterward on the "spanner" for maintance box
Alex
This is the answer
Box Maintenance procedure started at 00:09:25
Box Open Error -> Security problem #1
Box Maintenance Error -> No connection was established, or box is not in needed mode
Before doing click on box maintance unplug the box and plug it again on the usb cable.
Alex
same error you showed the logs before or different?
before AND different
Did the software see the box or not?
The Following User Says Thank You to facoly For This Useful Post:
Old 08-26-2009, 12:30   #18 (permalink)
Member: 267789
Thanks Meter: 5
yes the software see the box
Old 08-26-2009, 18:59   #19 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
Contact me on sonork then
Old 08-27-2009, 07:19   #20 (permalink)
Member: 48936
Thanks Meter: 20
Hi
i have the same problem too, but when i execute cyclone from another location, for example where i have extract cyclone 7828nck, i run cyclone box main module from here, the soft detects the box in main mode and beguin the self test, but when i try to unlock, always error
BB5 Unlock Failed -> Failed to Boot / Prepare Phone
What is the problem?
The Following User Says Thank You to rmarratia For This Useful Post:
Old 08-27-2009, 11:18   #21 (permalink)
Member: 48936
Thanks Meter: 20
Finally solved.
The problem was, after uninstall cyclone, donīt delete cyclone folder
First uninstall cyclone.
Second delete folder c:archivos de programa/cyclone
after that, follow exactly instructions from here:
http://forum.gsmhosting.com/vbb/showthread.php?t=705358
And now cyclone is working OK.
Old 08-27-2009, 23:50   #22 (permalink)
Member: 267789
Thanks Meter: 5
ok now thank you for you help
Old 09-12-2009, 08:22   #23 (permalink)
Member: 178616
Thanks Meter: 90
Arrow cyclone box give this error after upgrading
hi plz help me yesterday i upgrade my box to new active super dct4 .activate ok and used 50 credits and after that my box not connecting for rpl service and always give eror when check credits....
this error
Cyclone Server Send Command Error -> Code: 500, Box is not registered, support is not allowed then
Failed to Check Credits -> Server transaction failed
plz help me how to solve this problem
Old 09-12-2009, 08:59   #24 (permalink)
NADEEM GONDAL's Avatar
Member: 575900
Thanks Meter: 3,177
this error
Server iS In Maintenance Try After Short time.
Old 09-26-2009, 16:27   #25 (permalink)
mediaextensions's Avatar
Member: 1123079
Sonork: 100.1586814
Thanks Meter: 439
Great support , keep on keeping.
Old 09-26-2009, 17:12   #26 (permalink)
Member: 635202
Thanks Meter: 10
i have instal reinstal it's no work
Old 09-27-2009, 07:53   #27 (permalink)
Member: 575900
Thanks Meter: 3,177
Explain Here More About Your Problem,Then Any Can Help You.
Old 09-28-2009, 11:17   #28 (permalink)
Member: 267789
Thanks Meter: 5
here are the instructions for your box step
1-uninstall the program and the pilot
2 - remove the core of your program file
3 - reinstall the program and drivers
Old 09-28-2009, 11:18   #29 (permalink)
Member: 267789
Thanks Meter: 5
Old 10-02-2009, 12:44   #30 (permalink)
SAHEB's Avatar
Member: 173509
Sonork: 100.1584320
Thanks Meter: 96
hi supporter pls solve this,:::Initializing security card...
Security Card Reset Error -> Possible error: Unknown error 0x4E
Initialization has failed -> Security card was not found!""
i always get this error.when try for 10-15 times its start sometime.sometime after get info from the phone when try to flash suddenly it gives this error.i follow all instruction.now im tired with this box.i dont understand where is problem.so pls give me some accurate guideline to solve this problem.
anyway thanx.
br:shabbir-cellcare.
problem with my cyclone box.box is not in needed mode samih127 Cyclonebox 18 06-12-2010 06:05
Box is not in needed mode [SOLVED] renren Cyclonebox 2 01-19-2010 22:38
::solve:: box is not in needed mode mr khalid Cyclonebox 6 09-15-2009 08:36
Cyclone team (not connected) box is not in needed mode tims Cyclonebox 17 06-29-2009 03:54
Box is not in needed mode. masterunlock Cyclonebox 5 03-24-2009 16:44
Page generated in 0.23122 seconds with 10 queries
