07-28-2010, 15:26 | #1186 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Bulgaria Asenovgrad Age: 42
Member: 239176 Status: Offline Sonork: 100.1602815 Thanks Meter: 851 | nokia 1616 successfull flashing Code: Handling device: [Cyclone Team], [Cyclone Bootloader] Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v01.46, (Jul 24 2010 23:54:36, gcc v4.3.2, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2010 wk27 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: C0001AD2 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk19 Initializing security card... Card Serial Number: D0000463 Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 5,06v PASSED MCU Voltage 3,28v PASSED Core Voltage 1,79v PASSED VBAT Voltage 0,01v PASSED VBAT Voltage 5,02v PASSED Box VPP disabled VPP Voltage 0,02v PASSED Internal Box VPP Enabled VPP Voltage 5,01v PASSED Box VPP disabled VPP Voltage 0,04v PASSED External Box VPP Enabled VPP Voltage 0,04v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work Scanning avaiable products... Processing C:\Program Files\Nokia\Phoenix\Products\... Found 63 products, Filtering DCT4 Products - wait... 13 Products left after filtering. Ready. Retrieving Variants for Product RH-125 - wait... 29 Variants Retrieved Processing pre-flash tasks... Pre-flash tasks finished Checking rh125_005.050... 28 Blocks Parsed Flash file sorted Okay. Booting X-Gold (press power-on if used non-battery cable)... X-Gold: Ready, MCU ID: 0x3400 [PBL] : Ready [EBL] : Mode CC [EBL] : Default_RAM_Bootloader [EBL] : Ready Setting Baudrate to 921600bps... Baudrate Accepted (921600bps) Flash Chip 0x00EC2254, Samsung, Size: 8MBytes 1 file(s) embedded into image. Processing "hw_f11_rh125_r05.050.fls"... Sending Certificate... Certificate Accepted Erasing 0x00800000-0x00A0FFFF... Erasing 0x00C60000-0x00EAFFFF... Erasing 0x00FFC000-0x00FFFFFF... Flashing at 0x00800000... Flashed 2162688 bytes OK Flashing at 0x00C60000... Flashed 2119680 bytes OK Flashing at 0x00FFC000... Flashed 64 bytes OK Box VPP disabled Checking rh1250_nai05.05ek... 26 Blocks Parsed Flash file sorted Okay. Booting X-Gold (press power-on if used non-battery cable)... X-Gold: Ready, MCU ID: 0x3400 [PBL] : Ready [EBL] : Mode CC [EBL] : Default_RAM_Bootloader [EBL] : Ready Setting Baudrate to 921600bps... Baudrate Accepted (921600bps) Flash Chip 0x00EC2254, Samsung, Size: 8MBytes 1 file(s) embedded into image. Processing "hw_f11_rh1250_nai05.05ek.fls"... Sending Certificate... Certificate Accepted Erasing 0x00EB0000-0x00F7FFFF... Flashing at 0x00EB0000... Flashed 318592 bytes OK Box VPP disabled Checking rh125_005.05ek... 26 Blocks Parsed Flash file sorted Okay. Booting X-Gold (press power-on if used non-battery cable)... X-Gold: Ready, MCU ID: 0x3400 [PBL] : Ready [EBL] : Mode CC [EBL] : Default_RAM_Bootloader [EBL] : Ready Setting Baudrate to 921600bps... Baudrate Accepted (921600bps) Flash Chip 0x00EC2254, Samsung, Size: 8MBytes 1 file(s) embedded into image. Processing "hw_f11_rh125_005.05ek.fls"... Sending Certificate... Certificate Accepted Erasing 0x00210000-0x0045FFFF... Flashing at 0x00210000... Flashed 1810176 bytes OK Box VPP disabled Processing post-flash tasks... Setting Factory Defaults... Factory defaults OK Post-flash tasks finished... Flash successfully finished!Flash successfully finished! MCU Version V 05.05 MCU Date 24-05-10 Product RH-125 Manufacturer (c) Nokia IMEI 352704041709123 Mastercode 5112174552 IMEI Spare 3A25070414071902 IMEI SV 3325070414071942F2000000 PPM V 05.05, 24-05-10, RH-125, (c) Nokia, EK PSN I8A361080 Product Code 0587410 Module Code 0204343 Basic Product Code 0583104 PSD 0000000D00000000 HW 1000 UEM 1328 UPP 2292 LCD INNO:BOHAIv93, NT39121 ADSP Sw p'V 05.05\n24-05-10\nRH-125\n(c) NMP\nek Asic 11 HW Signature C6DA02E7BACC708E Simlock Server Simlock Key 0010100000000000 Simlock Profile 0000000000030002 Simlock Aux 000B0000 Simlock IMEI 00003527040417091200 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [1,2] State: OPENED Type: GID Data: FFFF Simlock [1,3] State: OPENED Type: GID Data: FFFF Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [2,2] State: OPENED Type: GID Data: FFFF Simlock [2,3] State: OPENED Type: GID Data: FFFF Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [3,2] State: OPENED Type: GID Data: FFFF Simlock [3,3] State: OPENED Type: GID Data: FFFF Simlock [3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [4,2] State: OPENED Type: GID Data: FFFF Simlock [4,3] State: OPENED Type: GID Data: FFFF Simlock [4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [5,2] State: OPENED Type: GID Data: FFFF Simlock [5,3] State: OPENED Type: GID Data: FFFF Simlock [5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [6,2] State: OPENED Type: GID Data: FFFF Simlock [6,3] State: OPENED Type: GID Data: FFFF Simlock [6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [7,2] State: OPENED Type: GID Data: FFFF Simlock [7,3] State: OPENED Type: GID Data: FFFF Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF BR. Last edited by ptt; 07-28-2010 at 15:44. Reason: add code tag |
The Following User Says Thank You to delchoni For This Useful Post: |
07-29-2010, 14:59 | #1187 (permalink) |
Crazy Poster Join Date: Oct 2005 Age: 46
Member: 188105 Status: Offline Thanks Meter: 5 | NOKIA 3720c RM-518 USB FLASH Code: [Nokia 3720 classic USB Generic]: Opening Connection [Nokia 3720 classic USB Generic]: Port opened OK! MCU Version V 10.16 MCU Date 07-12-09 Product RM-518 Manufacturer (c) Nokia IMEI 35153xxxxxxxxxx Mastercode 627435547 Simlock backup OK, saved to RM-518_35153xxxxxxxxxx_2010-07-29_154517.SLBackup.PM Backup simlock thread finished, continuing... Pre flash tasks finished, continuing... Selecting USB Flashing Method... [BB5 ADL Server]: Found 0 active devices [BB5 ADL Server]: Not Found! [BB5 NMWCD]: Found 1 active devices [Nokia 3720 classic USB Generic]: Opening Connection [Nokia 3720 classic USB Generic]: Port opened OK! Proceeding with Alive USB Mode CMT FlashChip: 0x00898982FFFF0000, Intel IMEI: 35153xxxxxxxxxx CMT Public ID: 0D60010A7B080156B894FD769CD355EBBF1536A5 ROOTKEY Hash for CMT: 9DDBFCFE6E73CED7D8C6268C8EB85723 PAPUBKEYS Hash for CMT: 649FB9FA3B26D5538A86100744A489436F78B693 Sending CMT UPDAPP Certificate and Data... Waiting for ADL Server Startup... [BB5 ADL Server]: Found 1 active devices [Nokia BB5 ADL Loader USB Generic]: Opening Connection [Nokia BB5 ADL Loader USB Generic]: Port opened OK! ADL Server Startup Confirmed OK! Processing rm518__10.16.mcusw (CMT)... rm518__10.16.mcusw, Type: Flash Image, Algo: BB5, BB5 ALGORITHM Started flash erase EraseArea[0,CMT]: 0x00000000-0x0001FFFF, NOR EraseArea[0,CMT]: 0x00040000-0x0005FFFF, NOR EraseArea[0,CMT]: 0x00060000-0x0007FFFF, NOR EraseArea[0,CMT]: 0x00080000-0x0015FFFF, NOR EraseArea[0,CMT]: 0x00160000-0x0023FFFF, NOR EraseArea[0,CMT]: 0x01540000-0x0171FFFF, NOR EraseArea[0,CMT]: 0x00240000-0x0153FFFF, NOR EraseArea[0,CMT]: 0x020E0000-0x0241FFFF, NOR Erase taken 116.672s Writing all blocks... Writing CMT NOLO Certificate... Writing CMT KEYS Certificate... Writing CMT PRIMAPP Certificate... Writing CMT PASUBTOC Certificate... Writing CMT PAPUBKEYS Certificate... Writing CMT UPDAPP Certificate... Writing CMT DSP0 Certificate... Writing CMT MCUSW Certificate... Writing CMT ISA+DYNSW Certificate... All blocks written OK! Time taken 57.938s Flashing Speed: 3325,96 kBit/S Processing rm518__10.16.ppm_b (CMT)... rm518__10.16.ppm_b, Type: Flash Image, Algo: BB5, BB5 ALGORITHM Started flash erase EraseArea[0,CMT]: 0x01720000-0x020DFFFF, NOR Erase taken 44.797s Writing all blocks... All blocks written OK! Time taken 15.328s Flashing Speed: 3336,64 kBit/S Processing rm518__10.16.image_b_grey (CMT)... rm518__10.16.image_b_grey, Type: Flash Image, Algo: BB5, BB5 ALGORITHM Started flash erase EraseArea[0,CMT]: 0x02420000-0x027BFFFF, NOR EraseArea[0,CMT]: 0x027C0000-0x03FBFFFF, NOR Erase taken 141.547s Writing all blocks... All blocks written OK! Time taken 23.594s Flashing Speed: 3381,61 kBit/S Restarting CMT... All images processed OK! Processing post flash tasks... Setting Factory Defaults... [BB5 NMWCD]: Found 0 active devices [BB5 NMWCD]: Not Found! [BB5 NMWCD]: Found 0 active devices [BB5 NMWCD]: Not Found! [BB5 NMWCD]: Found 0 active devices [BB5 NMWCD]: Not Found! [BB5 NMWCD]: Found 0 active devices [BB5 NMWCD]: Not Found! [BB5 NMWCD]: Found 0 active devices [BB5 NMWCD]: Not Found! Factory defaults OK Reading info... [BB5 NMWCD]: Found 0 active devices [BB5 NMWCD]: Not Found! Failed to read info -> Phone not detected Read info thread finished, continuing... Post flash tasks finished! Flashing successfully finished! |
07-30-2010, 14:22 | #1188 (permalink) |
Registered User Join Date: Dec 2009 Location: p A k I s T a N
Member: 1178981 Status: Offline Sonork: 100.1596342 Thanks Meter: 500 | 5130c flashing done Code: Scanning avaiable products... Processing C:\Program Files\Nokia\Phoenix\Products\... Found 44 products, Filtering BB5 Products - wait... 4 Products left after filtering. Ready. Retrieving Variants for Product RM-495 - wait... 419 Variants Retrieved Processing pre flash tasks... Pre flash tasks finished, continuing... Processing rm495__07.95.mcusw (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006030C192101033000 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1A200010569D7D569C345B36680184D41672A54B CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! rm495__07.95.mcusw, Type: Flash Image, Algo: BB5, BB5 ALGORITHM Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.6.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL FlashChip[0,CMT]: 0x0089898200008A31, Intel, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x00898982 (Intel), Size: 64MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.6.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 0C917F11196FDB7378C18EF7260698CA4489DCA0 Flashbus Write baud set to 5.0Mbits Sending Certificates... Certificates OK Started group flash erase EraseArea[0,CMT]: 0x00000000-0x000006BF, NOR EraseArea[0,CMT]: 0x000006C0-0x0001FFFF, NOR EraseArea[0,CMT]: 0x00040000-0x000BFFFF, NOR EraseArea[0,CMT]: 0x000C0000-0x0013FFFF, NOR EraseArea[0,CMT]: 0x00140000-0x0137FFFF, NOR EraseArea[0,CMT]: 0x01380000-0x0151FFFF, NOR Waiting 320s for erasure finish... Erase taken 88.125s Writing all blocks... Writing CMT NOLO Certificate... Writing CMT KEYS Certificate... Writing CMT PRIMAPP Certificate... Writing CMT PASUBTOC Certificate... Writing CMT PAPUBKEYS Certificate... Writing CMT UPDAPP Certificate... Writing CMT DSP0 Certificate... Writing CMT MCUSW Certificate... Programming Status OK! All blocks written OK! Time taken 50.531s Flashing Speed: 3020.85 kBit/S Restarting MCU... Processing rm495__07.95.mcusw (APE)... Processing rm495__07.95.ppm_mena_b (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006030C192101033000 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1A200010569D7D569C345B36680184D41672A54B CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! rm495__07.95.ppm_mena_b, Type: Flash Image, Algo: BB5, BB5 ALGORITHM Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.6.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL FlashChip[0,CMT]: 0x0089898200008A31, Intel, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x00898982 (Intel), Size: 64MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.6.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 0C917F11196FDB7378C18EF7260698CA4489DCA0 Flashbus Write baud set to 5.0Mbits Started group flash erase EraseArea[0,CMT]: 0x01520000-0x01DBFFFF, NOR Waiting 320s for erasure finish... Erase taken 29.500s Writing all blocks... Programming Status OK! All blocks written OK! Time taken 15.765s Flashing Speed: 3357.47 kBit/S Restarting MCU... Processing rm495__07.95.ppm_mena_b (APE)... Processing rm495__07.95.image_mena_b_red (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006030C192101033000 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1A200010569D7D569C345B36680184D41672A54B CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! rm495__07.95.image_mena_b_red, Type: Flash Image, Algo: BB5, BB5 ALGORITHM Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.6.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL FlashChip[0,CMT]: 0x0089898200008A31, Intel, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x00898982 (Intel), Size: 64MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.6.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 0C917F11196FDB7378C18EF7260698CA4489DCA0 Flashbus Write baud set to 5.0Mbits Started group flash erase EraseArea[0,CMT]: 0x01DC0000-0x0215FFFF, NOR EraseArea[0,CMT]: 0x02160000-0x03FBFFFF, NOR Waiting 320s for erasure finish... Erase taken 220.766s Writing all blocks... Programming Status OK! All blocks written OK! Time taken 20.843s Flashing Speed: 3324.28 kBit/S Restarting MCU... Processing rm495__07.95.image_mena_b_red (APE)... All images processed OK! Processing post flash tasks... Setting Factory Defaults... Factory defaults OK Post flash tasks finished! Flashing successfully finished! |
07-30-2010, 14:59 | #1189 (permalink) |
No Life Poster Join Date: Apr 2009 Location: HM unlock fone mandi bahauddin
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | 2760 unlock done Code: Handling device: [Cyclone Team], [Cyclone Bootloader] Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v01.45, (Jul 6 2010 19:20:51, gcc v4.3.2, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2010 wk27 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: C0000037 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2008, wk32 Initializing security card... Card Serial Number: D000028C Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 4.61v PASSED MCU Voltage 3.28v PASSED Core Voltage 1.84v PASSED VBAT Voltage 0.96v PASSED VBAT Voltage 4.52v PASSED Box VPP disabled VPP Voltage 0.04v PASSED Internal Box VPP Enabled VPP Voltage 4.57v PASSED Box VPP disabled VPP Voltage 0.02v PASSED External Box VPP Enabled VPP Voltage 0.00v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work Booting UPP... UPP ID: 3162 [HW_UNKNOWN] Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 PLL Factor: 3 FlashChip[0]: 0x00EC2208 @ 0x01000000, Samsung, SectorSize: 128kB, Ext: 00009121 Signature: AD7EB61B00FF10400000000000000000 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 4Kbits u3_amd.fia, Type: Algorithm, Target: FlashChip[0] 0x00EC2208 (256Mbits), Rev: 7.4.79.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.02V Terminating flash session Boot operation took 6.766s Check Flashing Bus finished MCU Version V 07.60 MCU Date 10-04-09 Product RM-258 Manufacturer (c) Nokia IMEI 356923037282814 Mastercode 5241675343 Proceeding with RSA Unlock... Setting Local Mode... Failed to set Local Mode, Trying to unlock anyway... Asic 11 HW Signature 759F68C06A2A1A6A Simlock Server SIMLOCK SERVER Simlock Key 2140700000000000 Simlock Profile 800000000001000B Simlock Aux 000B5555 Simlock IMEI 00553569230372828100 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 21407F Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 21402F Asking card to sign HW Signature... Signed OK (C6870AFDC247EBCB03B430ADC7525BFD40EED970) Calculating SP... Writing SP... New SP Accepted OK! Phone unlocked OK! Last edited by ptt; 07-30-2010 at 22:15. Reason: add code tag |
07-31-2010, 12:37 | #1190 (permalink) |
Member: 1178981 Status: Offline Sonork: 100.1596342 Thanks Meter: 500 | 2730c flashing done Code: Scanning avaiable products... Processing C:\Program Files\Nokia\Phoenix\Products\... Found 46 products, Filtering BB5 Products - wait... 5 Products left after filtering. Ready. Retrieving Variants for Product RM-578 - wait... 251 Variants Retrieved Processing pre flash tasks... Backing up RPL... RPL Creation started... Processing CMT Part... Storing Product Code... Storing PSN... Storing HWID... Trying to store Simlock... Reading Configuration Key... Hashing... Reading SHA1-RSA Signature... Reading SHA1-HMAC Signature... Storing Simlock... Trying to store WMDRM RPL... Reading Keys... Storing WMDRM PD... Reading Security Block... Security block OK and saved to "RM-578_356057038857652_812010_121531 AM.SecurityBlock.PM" WARNING: "0BC000055CA28C560D52D2F44D80F1535B9C927F.C0000B78" Not Exists, Will read it... Reading CYC file from phone... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006030C192101023000 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 0BC000055CA28C560D52D2F44D80F1535B9C927F CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL Exploiting - running preloader... Preloader running OK, Running Custom Loader... Custom loader running OK! Working... Readed OK, Saving to "0BC000055CA28C560D52D2F44D80F1535B9C927F.C0000B78" Storing Additional Data... Checking Superdongle Key... Encrypting Superdongle Key... Storing Superdongle Key... Checking CMLA Key... Storing CMLA Key... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006030C192101023000 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 0BC000055CA28C560D52D2F44D80F1535B9C927F CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.6.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL FlashChip[0,CMT]: 0x0089898200008A31, Intel, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x00898982 (Intel), Size: 64MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.6.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 8669C77551AE1280331BBAE6FD0C7CB3D3F44CC1 APE Subsystem Not Found Flashbus Write baud set to 5.0Mbits Storing NPC... Storing CCC... Storing HWC... CMT VARIANT Not Found Restarting MCU... RPL Saved OK RPL backup thread finished, continuing... Backing up simlock... MCU Version V 07.70 MCU Date 18-09-09 Product RM-578 Manufacturer (c) Nokia IMEI 356057038857652 Mastercode 2217272260 Simlock backup OK, saved to RM-578_356057038857652_812010_121600 AM.SLBackup.PM Backup simlock thread finished, continuing... Pre flash tasks finished, continuing... Processing rm578__09.41.mcusw (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006030C192101023000 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 0BC000055CA28C560D52D2F44D80F1535B9C927F CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! rm578__09.41.mcusw, Type: Flash Image, Algo: BB5, BB5 ALGORITHM Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.6.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL FlashChip[0,CMT]: 0x0089898200008A31, Intel, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x00898982 (Intel), Size: 64MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.6.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 8669C77551AE1280331BBAE6FD0C7CB3D3F44CC1 Flashbus Write baud set to 5.0Mbits Sending Certificates... Certificates OK Started group flash erase EraseArea[0,CMT]: 0x00000000-0x000006BF, NOR EraseArea[0,CMT]: 0x000006C0-0x0001FFFF, NOR EraseArea[0,CMT]: 0x00040000-0x000BFFFF, NOR EraseArea[0,CMT]: 0x000C0000-0x0013FFFF, NOR EraseArea[0,CMT]: 0x00140000-0x0155FFFF, NOR EraseArea[0,CMT]: 0x01560000-0x0175FFFF, NOR Waiting 320s for erasure finish... Erase taken 107.281s Writing all blocks... Writing CMT NOLO Certificate... Writing CMT KEYS Certificate... Writing CMT PRIMAPP Certificate... Writing CMT PASUBTOC Certificate... Writing CMT PAPUBKEYS Certificate... Writing CMT UPDAPP Certificate... Writing CMT DSP0 Certificate... Writing CMT MCUSW Certificate... Programming Status OK! All blocks written OK! Time taken 57.875s Flashing Speed: 3134.81 kBit/S Restarting MCU... Processing rm578__09.41.mcusw (APE)... Processing rm578__09.41.ppm_m_c (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006030C192101023000 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 0BC000055CA28C560D52D2F44D80F1535B9C927F CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! rm578__09.41.ppm_m_c, Type: Flash Image, Algo: BB5, BB5 ALGORITHM Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.6.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL FlashChip[0,CMT]: 0x0089898200008A31, Intel, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x00898982 (Intel), Size: 64MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.6.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 8669C77551AE1280331BBAE6FD0C7CB3D3F44CC1 Flashbus Write baud set to 5.0Mbits Started group flash erase EraseArea[0,CMT]: 0x01760000-0x01FFFFFF, NOR Waiting 320s for erasure finish... Erase taken 26.812s Writing all blocks... Programming Status OK! All blocks written OK! Time taken 12.875s Flashing Speed: 3486.40 kBit/S Restarting MCU... Processing rm578__09.41.ppm_m_c (APE)... Processing rm578__09.41.image_m_c_red (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006030C192101023000 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 0BC000055CA28C560D52D2F44D80F1535B9C927F CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! rm578__09.41.image_m_c_red, Type: Flash Image, Algo: BB5, BB5 ALGORITHM Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.6.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL FlashChip[0,CMT]: 0x0089898200008A31, Intel, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x00898982 (Intel), Size: 64MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.6.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 8669C77551AE1280331BBAE6FD0C7CB3D3F44CC1 Flashbus Write baud set to 5.0Mbits Started group flash erase EraseArea[0,CMT]: 0x02000000-0x0245FFFF, NOR EraseArea[0,CMT]: 0x02460000-0x03FBFFFF, NOR Waiting 320s for erasure finish... Erase taken 186.625s Writing all blocks... Programming Status OK! All blocks written OK! Time taken 28.812s Flashing Speed: 3534.34 kBit/S Restarting MCU... Processing rm578__09.41.image_m_c_red (APE)... All images processed OK! Processing post flash tasks... Setting Factory Defaults... Factory defaults OK Post flash tasks finished! Flashing successfully finished! |
07-31-2010, 15:25 | #1191 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Pakistan
Member: 226457 Status: Offline Sonork: No more used Thanks Meter: 14,934 | 2760h sucessfully unlock with cyclone box Code: UPP ID: 3168 [HW_UNKNOWN] Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 PLL Factor: 3 FlashChip[0]: 0x0020883C @ 0x01000000, ST, SectorSize: 128kB, Ext: 00009321 Signature: AD7EB61B00FF10400000000000000000 Booting UPP... UPP ID: 3168 [HW_UNKNOWN] Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 PLL Factor: 3 FlashChip[0]: 0x0020883C @ 0x01000000, ST, SectorSize: 128kB, Ext: 00009321 Signature: AD7EB61B00FF10400000000000000000 u3_intel.fia, Type: Algorithm, Target: FlashChip[0] 0x0020883C (256Mbits), Rev: 7.4.80.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 1.48V Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 4Kbits Flashbus Write baud set to 1.0Mbits Erasing NOR Region [0x01000000-0x02FFFFFF] Flash Erase Failed -> Failed at 0x02000000:0x00020000 Failed to Erase All Chips -> Flash Chip erase failed Processing pre-flash tasks... Pre-flash tasks finished Booting UPP... UPP ID: 3168 [HW_UNKNOWN] rm391__06.83.mcusw, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 Box VPP disabled Internal Phone VPP Selected PLL Factor: 3 FlashChip[0]: 0x0020883C @ 0x01000000, ST, SectorSize: 128kB, Ext: 00009321 FlashChip[1]: 0x0020883C @ 0x02000000, ST, SectorSize: 128kB, Ext: 00009321 Signature: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 51Kbits u3_intel.fia, Type: Algorithm, Target: FlashChip[0] 0x0020883C (256Mbits), Rev: 7.4.80.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 1.48V MSID-Crypted: 8434D0309A0F6692F86A39529C MSID-Plain: 2C40BAE900122514A9000000 FAID-Crypted: 99E0D346A5712516938B64B3 Flashbus Write baud set to 6.50Mbits 2 Region(s) to erase Erasing NOR Region [0x01000000-0x0101FFFF] Erasing NOR Region [0x01020000-0x01C3FFFF] Erase taken 109.672s Writing 346 blocks... All blocks written OK! Time taken 67.125s Terminating flash session Box VPP disabled Booting UPP... UPP ID: 3168 [HW_UNKNOWN] rm391__06.83_ISM_007.image_tmobusa_v1, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 Box VPP disabled Internal Phone VPP Selected PLL Factor: 3 FlashChip[0]: 0x0020883C @ 0x01000000, ST, SectorSize: 128kB, Ext: 00009321 FlashChip[1]: 0x0020883C @ 0x02000000, ST, SectorSize: 128kB, Ext: 00009321 Signature: AD7EB61B23100340C605E40120A20000 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 51Kbits u3_intel.fia, Type: Algorithm, Target: FlashChip[0] 0x0020883C (256Mbits), Rev: 7.4.80.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 1.52V MSID-Crypted: 8497C9D8854299ABF03DF4A2B8 MSID-Plain: D26EBAF100122514AA000610 FAID-Crypted: BD4ACF5A5C63375CBF298DC6 Flashbus Write baud set to 6.50Mbits 2 Region(s) to erase Erasing NOR Region [0x02000000-0x02DBFFFF] Erasing NOR Region [0x02DC0000-0x02F9FFFF] Erase taken 140.250s File Sector Size: 128kB, Flash Chip Sector Size: 128kB CNT Convertion not needed Writing 408 blocks... All blocks written OK! Time taken 55.187s Terminating flash session Extracting Content Package... CP Extract Failed -> CP Server not exists WARNING: Failed to extract CP Box VPP disabled Booting UPP... UPP ID: 3168 [HW_UNKNOWN] rm391__06.83.ppm_mtm, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 Box VPP disabled Internal Phone VPP Selected PLL Factor: 3 FlashChip[0]: 0x0020883C @ 0x01000000, ST, SectorSize: 128kB, Ext: 00009321 FlashChip[1]: 0x0020883C @ 0x02000000, ST, SectorSize: 128kB, Ext: 00009321 Signature: AD7EB61B23100340C605E40120A20000 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 51Kbits u3_intel.fia, Type: Algorithm, Target: FlashChip[0] 0x0020883C (256Mbits), Rev: 7.4.80.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 1.45V MSID-Crypted: 84302D9EC1A117817517C14BDA MSID-Plain: 3E4EBAE900122514A8000000 FAID-Crypted: ED5D0198577378467E4F3350 Flashbus Write baud set to 6.50Mbits 1 Region(s) to erase Erasing NOR Region [0x01C40000-0x01FFFFFF] Erase taken 34.359s Writing 95 blocks... All blocks written OK! Time taken 18.297s Terminating flash session Box VPP disabled Processing post-flash tasks... Setting Factory Defaults... Factory defaults OK Post-flash tasks finished... Flash successfully finished! [1,0] Written, Length: 120 bytes, Status: OK [1,2] Written, Length: 90 bytes, Status: OK [1,4] Written, Length: 110 bytes, Status: OK [1,5] Written, Length: 2 bytes, Status: OK [1,6] Written, Length: 90 bytes, Status: OK [1,11] Written, Length: 2 bytes, Status: OK [1,12] Written, Length: 2 bytes, Status: OK [2,0] Written, Length: 432 bytes, Status: OK [3,0] Written, Length: 2 bytes, Status: OK [4,1] Written, Length: 800 bytes, Status: OK [4,3] Written, Length: 10 bytes, Status: OK [4,4] Written, Length: 8 bytes, Status: OK [4,5] Written, Length: 8 bytes, Status: OK [4,6] Written, Length: 8 bytes, Status: OK [4,9] Written, Length: 5 bytes, Status: OK [4,16] Written, Length: 4 bytes, Status: OK [4,17] Written, Length: 8 bytes, Status: OK [4,18] Written, Length: 80 bytes, Status: OK [4,19] Written, Length: 4 bytes, Status: OK [4,28] Written, Length: 2 bytes, Status: OK [7,0] Written, Length: 4 bytes, Status: OK [7,1] Written, Length: 32 bytes, Status: OK [7,2] Written, Length: 4 bytes, Status: OK [8,0] Written, Length: 12 bytes, Status: OK [8,1] Written, Length: 12 bytes, Status: OK [8,2] Written, Length: 128 bytes, Status: OK [8,3] Written, Length: 128 bytes, Status: OK [8,4] Written, Length: 8 bytes, Status: OK [8,6] Written, Length: 4 bytes, Status: OK [8,7] Written, Length: 8 bytes, Status: OK [8,8] Written, Length: 8 bytes, Status: OK [8,9] Written, Length: 24 bytes, Status: OK [11,0] Written, Length: 4 bytes, Status: OK [11,1] Written, Length: 4 bytes, Status: OK [11,2] Written, Length: 4 bytes, Status: OK [11,3] Written, Length: 4 bytes, Status: OK [11,4] Written, Length: 1 bytes, Status: OK [11,5] Written, Length: 6 bytes, Status: OK [11,6] Written, Length: 2 bytes, Status: OK [11,7] Written, Length: 1 bytes, Status: OK [11,8] Written, Length: 1 bytes, Status: OK [11,9] Written, Length: 1 bytes, Status: OK [11,10] Written, Length: 1 bytes, Status: OK [11,11] Written, Length: 1 bytes, Status: OK [11,12] Written, Length: 1 bytes, Status: OK [11,13] Written, Length: 1 bytes, Status: OK [11,14] Written, Length: 2 bytes, Status: OK [11,15] Written, Length: 2 bytes, Status: OK [11,16] Written, Length: 2 bytes, Status: OK [11,17] Written, Length: 2 bytes, Status: OK [11,18] Written, Length: 16 bytes, Status: OK [11,19] Written, Length: 32 bytes, Status: OK [11,20] Written, Length: 32 bytes, Status: OK [11,21] Written, Length: 2 bytes, Status: OK [11,22] Written, Length: 2 bytes, Status: OK [11,23] Written, Length: 2 bytes, Status: OK [11,24] Written, Length: 2 bytes, Status: OK [11,25] Written, Length: 2 bytes, Status: OK [11,26] Written, Length: 2 bytes, Status: OK [11,27] Written, Length: 2 bytes, Status: OK [11,28] Written, Length: 2 bytes, Status: OK [11,29] Written, Length: 2 bytes, Status: OK [11,30] Written, Length: 2 bytes, Status: OK [11,31] Written, Length: 2 bytes, Status: OK [11,32] Written, Length: 2 bytes, Status: OK [11,33] Written, Length: 2 bytes, Status: OK [11,34] Written, Length: 2 bytes, Status: OK [11,35] Written, Length: 2 bytes, Status: OK [11,36] Written, Length: 2 bytes, Status: OK [11,37] Written, Length: 2 bytes, Status: OK [11,38] Written, Length: 2 bytes, Status: OK [11,39] Written, Length: 2 bytes, Status: OK [11,40] Written, Length: 2 bytes, Status: OK [11,41] Written, Length: 2 bytes, Status: OK [11,42] Written, Length: 2 bytes, Status: OK [11,43] Written, Length: 2 bytes, Status: OK [11,44] Written, Length: 2 bytes, Status: OK [11,45] Written, Length: 2 bytes, Status: OK [11,46] Written, Length: 2 bytes, Status: OK [11,47] Written, Length: 2 bytes, Status: OK [11,48] Written, Length: 2 bytes, Status: OK [11,49] Written, Length: 2 bytes, Status: OK [11,50] Written, Length: 2 bytes, Status: OK [11,51] Written, Length: 2 bytes, Status: OK [11,52] Written, Length: 2 bytes, Status: OK [11,53] Written, Length: 2 bytes, Status: OK [11,54] Written, Length: 2 bytes, Status: OK [11,55] Written, Length: 2 bytes, Status: OK [11,56] Written, Length: 2 bytes, Status: OK [11,57] Written, Length: 2 bytes, Status: OK [11,58] Written, Length: 2 bytes, Status: OK [11,59] Written, Length: 2 bytes, Status: OK [11,60] Written, Length: 2 bytes, Status: OK [11,61] Written, Length: 2 bytes, Status: OK [11,62] Written, Length: 2 bytes, Status: OK [11,63] Written, Length: 2 bytes, Status: OK [11,64] Written, Length: 2 bytes, Status: OK [11,65] Written, Length: 4 bytes, Status: OK [11,66] Written, Length: 1 bytes, Status: OK [11,67] Written, Length: 4 bytes, Status: OK [11,68] Written, Length: 4 bytes, Status: OK [11,69] Written, Length: 4 bytes, Status: OK [11,70] Written, Length: 4 bytes, Status: OK [11,71] Written, Length: 16 bytes, Status: OK [11,72] Written, Length: 4 bytes, Status: OK [11,73] Written, Length: 2 bytes, Status: OK [11,74] Written, Length: 13 bytes, Status: OK [12,0] Written, Length: 102 bytes, Status: OK [13,0] Written, Length: 1 bytes, Status: OK [13,1] Written, Length: 60 bytes, Status: OK [13,2] Written, Length: 1 bytes, Status: OK [13,3] Written, Length: 2 bytes, Status: OK [13,4] Written, Length: 1 bytes, Status: OK [13,5] Written, Length: 1 bytes, Status: OK [13,6] Written, Length: 1 bytes, Status: OK [13,7] Written, Length: 1 bytes, Status: OK [13,8] Written, Length: 2 bytes, Status: OK [13,9] Written, Length: 1 bytes, Status: OK [13,10] Written, Length: 1 bytes, Status: OK [13,11] Written, Length: 48 bytes, Status: OK [13,12] Written, Length: 4 bytes, Status: OK [13,13] Written, Length: 1 bytes, Status: OK [13,14] Written, Length: 1 bytes, Status: OK [13,15] Written, Length: 886 bytes, Status: OK [13,16] Written, Length: 2 bytes, Status: OK [13,17] Written, Length: 1 bytes, Status: OK [13,18] Written, Length: 1 bytes, Status: OK [13,19] Written, Length: 8 bytes, Status: OK [13,20] Written, Length: 1 bytes, Status: OK [13,21] Written, Length: 1 bytes, Status: OK [13,22] Written, Length: 1 bytes, Status: OK [13,23] Written, Length: 1 bytes, Status: OK [13,24] Written, Length: 1 bytes, Status: OK [13,25] Written, Length: 2 bytes, Status: OK [13,26] Written, Length: 1 bytes, Status: OK [13,27] Written, Length: 1 bytes, Status: OK [13,28] Written, Length: 1 bytes, Status: OK [13,29] Written, Length: 1 bytes, Status: OK [13,30] Written, Length: 1 bytes, Status: OK [13,31] Written, Length: 1 bytes, Status: OK [13,32] Written, Length: 1 bytes, Status: OK [13,33] Written, Length: 1 bytes, Status: OK [13,34] Written, Length: 1 bytes, Status: OK [13,35] Written, Length: 1 bytes, Status: OK [13,36] Written, Length: 1 bytes, Status: OK [13,37] Written, Length: 4 bytes, Status: OK [13,38] Written, Length: 1 bytes, Status: OK [13,39] Written, Length: 1 bytes, Status: OK [13,40] Written, Length: 1 bytes, Status: OK [13,41] Written, Length: 1 bytes, Status: OK [13,42] Written, Length: 4 bytes, Status: OK [13,43] Written, Length: 4 bytes, Status: OK [13,44] Written, Length: 1 bytes, Status: OK [13,45] Written, Length: 4 bytes, Status: OK [13,46] Written, Length: 4 bytes, Status: OK [13,47] Written, Length: 1 bytes, Status: OK [13,48] Written, Length: 4 bytes, Status: OK [13,49] Written, Length: 1 bytes, Status: OK [13,50] Written, Length: 1 bytes, Status: OK [13,51] Written, Length: 1 bytes, Status: OK [13,52] Written, Length: 2 bytes, Status: OK [13,53] Written, Length: 4 bytes, Status: OK [13,54] Written, Length: 4 bytes, Status: OK [13,55] Written, Length: 1 bytes, Status: OK [13,56] Written, Length: 1 bytes, Status: OK [13,57] Written, Length: 1 bytes, Status: OK [13,58] Written, Length: 2 bytes, Status: OK [13,59] Written, Length: 1 bytes, Status: OK [13,60] Written, Length: 4 bytes, Status: OK [13,61] Written, Length: 4 bytes, Status: OK [13,62] Written, Length: 1 bytes, Status: OK [13,63] Written, Length: 4 bytes, Status: OK [13,64] Written, Length: 4 bytes, Status: OK [13,65] Written, Length: 1 bytes, Status: OK [13,66] Written, Length: 4 bytes, Status: OK [13,67] Written, Length: 4 bytes, Status: OK [13,68] Written, Length: 1 bytes, Status: OK [13,69] Written, Length: 1 bytes, Status: OK [13,70] Written, Length: 1 bytes, Status: OK [13,71] Written, Length: 4 bytes, Status: OK [13,72] Written, Length: 4 bytes, Status: OK [13,73] Written, Length: 1 bytes, Status: OK [13,74] Written, Length: 4 bytes, Status: OK [13,75] Written, Length: 2 bytes, Status: OK [13,76] Written, Length: 2 bytes, Status: OK [13,77] Written, Length: 2 bytes, Status: OK [13,78] Written, Length: 1 bytes, Status: OK [13,79] Written, Length: 1 bytes, Status: OK [13,80] Written, Length: 1 bytes, Status: OK [13,81] Written, Length: 1 bytes, Status: OK [13,82] Written, Length: 1 bytes, Status: OK [13,83] Written, Length: 2 bytes, Status: OK [13,84] Written, Length: 1 bytes, Status: OK [13,85] Written, Length: 4 bytes, Status: OK [13,86] Written, Length: 4 bytes, Status: OK [13,87] Written, Length: 2 bytes, Status: OK [13,88] Written, Length: 1 bytes, Status: OK [13,89] Written, Length: 4 bytes, Status: OK [13,90] Written, Length: 4 bytes, Status: OK [13,91] Written, Length: 2 bytes, Status: OK [13,92] Written, Length: 1 bytes, Status: OK [13,93] Written, Length: 4 bytes, Status: OK [13,94] Written, Length: 4 bytes, Status: OK [13,95] Written, Length: 2 bytes, Status: OK [13,96] Written, Length: 1 bytes, Status: OK [13,97] Written, Length: 4 bytes, Status: OK [13,98] Written, Length: 4 bytes, Status: OK [13,99] Written, Length: 2 bytes, Status: OK [13,100] Written, Length: 4 bytes, Status: OK [13,101] Written, Length: 2 bytes, Status: OK [13,102] Written, Length: 1 bytes, Status: OK [13,103] Written, Length: 4 bytes, Status: OK [13,104] Written, Length: 4 bytes, Status: OK [13,105] Written, Length: 4 bytes, Status: OK [13,106] Written, Length: 4 bytes, Status: OK [13,107] Written, Length: 4 bytes, Status: OK [13,108] Written, Length: 2 bytes, Status: OK [13,109] Written, Length: 4 bytes, Status: OK [13,110] Written, Length: 4 bytes, Status: OK [13,111] Written, Length: 4 bytes, Status: OK [13,112] Written, Length: 2 bytes, Status: OK [13,113] Written, Length: 4 bytes, Status: OK [13,114] Written, Length: 4 bytes, Status: OK [13,115] Written, Length: 1 bytes, Status: OK [13,116] Written, Length: 1 bytes, Status: OK [13,117] Written, Length: 1 bytes, Status: OK [13,118] Written, Length: 4 bytes, Status: OK [13,119] Written, Length: 4 bytes, Status: OK [13,120] Written, Length: 1 bytes, Status: OK [13,121] Written, Length: 1 bytes, Status: OK [13,122] Written, Length: 1 bytes, Status: OK [13,123] Written, Length: 8 bytes, Status: OK [13,124] Written, Length: 1 bytes, Status: OK [13,125] Written, Length: 1 bytes, Status: OK [13,126] Written, Length: 1 bytes, Status: OK [13,127] Written, Length: 1 bytes, Status: OK [13,128] Written, Length: 1 bytes, Status: OK [13,129] Written, Length: 4 bytes, Status: OK [13,130] Written, Length: 4 bytes, Status: OK [13,131] Written, Length: 1 bytes, Status: OK [13,132] Written, Length: 1 bytes, Status: OK [13,133] Written, Length: 2 bytes, Status: OK [13,134] Written, Length: 1 bytes, Status: OK [13,135] Written, Length: 2 bytes, Status: OK [13,136] Written, Length: 1 bytes, Status: OK [13,137] Written, Length: 1 bytes, Status: OK [13,138] Written, Length: 4 bytes, Status: OK [13,139] Written, Length: 4 bytes, Status: OK [13,140] Written, Length: 1 bytes, Status: OK [13,141] Written, Length: 1 bytes, Status: OK [13,142] Written, Length: 1 bytes, Status: OK [13,143] Written, Length: 1 bytes, Status: OK [13,144] Written, Length: 4 bytes, Status: OK [13,145] Written, Length: 8 bytes, Status: OK [13,146] Written, Length: 4 bytes, Status: OK [13,147] Written, Length: 4 bytes, Status: OK [13,148] Written, Length: 1 bytes, Status: OK [13,149] Written, Length: 1 bytes, Status: OK [13,150] Written, Length: 1 bytes, Status: OK [13,151] Written, Length: 1 bytes, Status: OK [13,152] Written, Length: 1 bytes, Status: OK [13,153] Written, Length: 1 bytes, Status: OK [13,154] Written, Length: 1 bytes, Status: OK [13,155] Written, Length: 1 bytes, Status: OK [13,156] Written, Length: 1 bytes, Status: OK [13,157] Written, Length: 1 bytes, Status: OK [13,158] Written, Length: 1 bytes, Status: OK [13,159] Written, Length: 2 bytes, Status: OK [13,160] Written, Length: 2 bytes, Status: OK [13,161] Written, Length: 1 bytes, Status: OK [13,162] Written, Length: 1 bytes, Status: OK [13,163] Written, Length: 1 bytes, Status: OK [13,164] Written, Length: 1 bytes, Status: OK [13,165] Written, Length: 1 bytes, Status: OK [13,166] Written, Length: 1 bytes, Status: OK [13,167] Written, Length: 8 bytes, Status: OK [13,168] Written, Length: 4 bytes, Status: OK [13,169] Written, Length: 1 bytes, Status: OK [13,170] Written, Length: 1 bytes, Status: OK [13,171] Written, Length: 1 bytes, Status: OK [13,172] Written, Length: 1 bytes, Status: OK [13,173] Written, Length: 1 bytes, Status: OK [13,174] Written, Length: 1 bytes, Status: OK [13,175] Written, Length: 1 bytes, Status: OK [13,176] Written, Length: 1 bytes, Status: OK [13,177] Written, Length: 4 bytes, Status: OK [13,178] Written, Length: 2 bytes, Status: OK [13,179] Written, Length: 1 bytes, Status: OK [13,180] Written, Length: 1 bytes, Status: OK [13,181] Written, Length: 1 bytes, Status: OK [13,182] Written, Length: 1 bytes, Status: OK [13,183] Written, Length: 1 bytes, Status: OK [13,184] Written, Length: 1 bytes, Status: OK [13,185] Written, Length: 1 bytes, Status: OK [13,186] Written, Length: 1 bytes, Status: OK [13,187] Written, Length: 1 bytes, Status: OK [13,188] Written, Length: 1 bytes, Status: OK [13,189] Written, Length: 1 bytes, Status: OK [13,190] Written, Length: 4 bytes, Status: OK [13,191] Written, Length: 2 bytes, Status: OK [13,192] Written, Length: 1 bytes, Status: OK [13,193] Written, Length: 4 bytes, Status: OK [13,194] Written, Length: 1 bytes, Status: OK [13,195] Written, Length: 1 bytes, Status: OK [13,196] Written, Length: 10 bytes, Status: OK [13,197] Written, Length: 1 bytes, Status: OK [13,198] Written, Length: 18 bytes, Status: OK [13,199] Written, Length: 2 bytes, Status: OK [42,0] Written, Length: 2 bytes, Status: OK [42,1] Written, Length: 12 bytes, Status: OK [42,2] Written, Length: 36 bytes, Status: OK [42,3] Written, Length: 36 bytes, Status: OK [42,4] Written, Length: 36 bytes, Status: OK [42,5] Written, Length: 36 bytes, Status: OK [42,6] Written, Length: 36 bytes, Status: OK [42,7] Written, Length: 40 bytes, Status: OK [42,8] Written, Length: 40 bytes, Status: OK [42,9] Written, Length: 40 bytes, Status: OK [42,10] Written, Length: 40 bytes, Status: OK [42,11] Written, Length: 40 bytes, Status: OK [42,12] Written, Length: 40 bytes, Status: OK [42,13] Written, Length: 40 bytes, Status: OK [42,14] Written, Length: 40 bytes, Status: OK [46,0] Written, Length: 8 bytes, Status: OK [49,2] Written, Length: 4 bytes, Status: OK [49,5] Written, Length: 1 bytes, Status: OK [50,0] Written, Length: 2 bytes, Status: OK [51,0] Written, Length: 130 bytes, Status: OK [51,2] Written, Length: 86 bytes, Status: OK [51,3] Written, Length: 86 bytes, Status: OK [54,0] Written, Length: 2 bytes, Status: OK [54,2] Written, Length: 24 bytes, Status: OK [55,0] Written, Length: 72 bytes, Status: OK [55,1] Written, Length: 2 bytes, Status: OK [55,2] Written, Length: 72 bytes, Status: OK [56,0] Written, Length: 4 bytes, Status: OK [56,1] Written, Length: 4 bytes, Status: OK [58,0] Written, Length: 31 bytes, Status: OK [58,1] Written, Length: 38 bytes, Status: OK [58,2] Written, Length: 38 bytes, Status: OK [58,3] Written, Length: 38 bytes, Status: OK [58,4] Written, Length: 44 bytes, Status: OK [58,5] Written, Length: 34 bytes, Status: OK [58,6] Written, Length: 30 bytes, Status: OK [58,7] Written, Length: 54 bytes, Status: OK [58,8] Written, Length: 28 bytes, Status: OK [58,9] Written, Length: 30 bytes, Status: OK [58,10] Written, Length: 30 bytes, Status: OK [58,11] Written, Length: 46 bytes, Status: OK [58,12] Written, Length: 41 bytes, Status: OK [58,13] Written, Length: 28 bytes, Status: OK [58,14] Written, Length: 43 bytes, Status: OK [58,15] Written, Length: 43 bytes, Status: OK [58,16] Written, Length: 32 bytes, Status: OK [58,17] Written, Length: 31 bytes, Status: OK [58,18] Written, Length: 40 bytes, Status: OK [58,19] Written, Length: 28 bytes, Status: OK [58,20] Written, Length: 29 bytes, Status: OK [58,21] Written, Length: 46 bytes, Status: OK [58,22] Written, Length: 52 bytes, Status: OK [58,23] Written, Length: 60 bytes, Status: OK [58,24] Written, Length: 42 bytes, Status: OK [59,0] Written, Length: 33 bytes, Status: OK [59,1] Written, Length: 52 bytes, Status: OK [59,2] Written, Length: 88 bytes, Status: OK [59,3] Written, Length: 101 bytes, Status: OK [59,4] Written, Length: 101 bytes, Status: OK [59,5] Written, Length: 63 bytes, Status: OK [59,6] Written, Length: 69 bytes, Status: OK [59,7] Written, Length: 65 bytes, Status: OK [59,8] Written, Length: 33 bytes, Status: OK [59,9] Written, Length: 73 bytes, Status: OK [59,10] Written, Length: 83 bytes, Status: OK [59,11] Written, Length: 59 bytes, Status: OK [59,12] Written, Length: 101 bytes, Status: OK [59,13] Written, Length: 44 bytes, Status: OK [59,14] Written, Length: 75 bytes, Status: OK [60,0] Written, Length: 46 bytes, Status: OK [60,1] Written, Length: 28 bytes, Status: OK [60,2] Written, Length: 52 bytes, Status: OK [60,3] Written, Length: 13 bytes, Status: OK [61,0] Written, Length: 54 bytes, Status: OK [61,1] Written, Length: 116 bytes, Status: OK [61,2] Written, Length: 58 bytes, Status: OK [61,3] Written, Length: 43 bytes, Status: OK [61,4] Written, Length: 139 bytes, Status: OK [65,0] Written, Length: 11 bytes, Status: OK [65,1] Written, Length: 11 bytes, Status: OK [65,2] Written, Length: 11 bytes, Status: OK [65,3] Written, Length: 11 bytes, Status: OK [65,4] Written, Length: 11 bytes, Status: OK [66,0] Written, Length: 2050 bytes, Status: OK [66,1] Written, Length: 240 bytes, Status: OK [66,2] Written, Length: 240 bytes, Status: OK [66,3] Written, Length: 1 bytes, Status: OK [66,4] Written, Length: 1 bytes, Status: OK [66,5] Written, Length: 240 bytes, Status: OK [66,6] Written, Length: 4 bytes, Status: OK [66,7] Written, Length: 4 bytes, Status: OK [66,8] Written, Length: 4 bytes, Status: OK [66,9] Written, Length: 4 bytes, Status: OK [66,10] Written, Length: 240 bytes, Status: OK [66,11] Written, Length: 240 bytes, Status: OK [66,12] Written, Length: 1 bytes, Status: OK [66,16] Written, Length: 52 bytes, Status: OK [66,17] Written, Length: 2 bytes, Status: OK [66,20] Written, Length: 2 bytes, Status: OK [66,21] Written, Length: 2 bytes, Status: OK [66,22] Written, Length: 52 bytes, Status: OK [66,23] Written, Length: 52 bytes, Status: OK [66,24] Written, Length: 52 bytes, Status: OK [66,25] Written, Length: 2 bytes, Status: OK [66,27] Written, Length: 2 bytes, Status: OK [66,29] Written, Length: 2 bytes, Status: OK [66,31] Written, Length: 2 bytes, Status: OK [66,33] Written, Length: 2 bytes, Status: OK [66,35] Written, Length: 2 bytes, Status: OK [66,37] Written, Length: 2 bytes, Status: OK [66,39] Written, Length: 2 bytes, Status: OK [66,41] Written, Length: 2 bytes, Status: OK [66,48] Written, Length: 126 bytes, Status: OK [66,52] Written, Length: 2 bytes, Status: OK [66,53] Written, Length: 1 bytes, Status: OK [66,64] Written, Length: 8 bytes, Status: OK [66,65] Written, Length: 8 bytes, Status: OK [66,66] Written, Length: 8 bytes, Status: OK [66,67] Written, Length: 9 bytes, Status: OK [66,69] Written, Length: 8 bytes, Status: OK [66,81] Written, Length: 8 bytes, Status: OK [66,82] Written, Length: 8 bytes, Status: OK [66,83] Written, Length: 8 bytes, Status: OK [66,85] Written, Length: 80 bytes, Status: OK [66,86] Written, Length: 6400 bytes, Status: OK [66,87] Written, Length: 400 bytes, Status: OK [66,88] Written, Length: 60 bytes, Status: OK [66,89] Written, Length: 156 bytes, Status: OK [66,90] Written, Length: 4 bytes, Status: OK [66,91] Written, Length: 125 bytes, Status: OK [66,94] Written, Length: 125 bytes, Status: OK [66,95] Written, Length: 125 bytes, Status: OK [66,96] Written, Length: 62700 bytes, Status: Not accepted, Code: 48879 [66,100] Written, Length: 50 bytes, Status: OK [66,101] Written, Length: 3 bytes, Status: OK [66,102] Written, Length: 3 bytes, Status: OK [66,103] Written, Length: 3 bytes, Status: OK [66,105] Written, Length: 3 bytes, Status: OK [66,106] Written, Length: 3 bytes, Status: OK [66,107] Written, Length: 3 bytes, Status: OK [66,108] Written, Length: 2 bytes, Status: OK [66,109] Written, Length: 2 bytes, Status: OK [66,117] Written, Length: 160 bytes, Status: OK [66,121] Written, Length: 40 bytes, Status: OK [66,123] Written, Length: 1 bytes, Status: OK [66,127] Written, Length: 10478 bytes, Status: OK [66,131] Written, Length: 8446 bytes, Status: OK [67,0] Written, Length: 24 bytes, Status: OK [76,0] Written, Length: 534 bytes, Status: OK [87,0] Written, Length: 4 bytes, Status: OK [88,0] Written, Length: 36 bytes, Status: OK [91,0] Written, Length: 2048 bytes, Status: OK [96,0] Written, Length: 24 bytes, Status: OK [107,0] Written, Length: 21 bytes, Status: OK [107,1] Written, Length: 153 bytes, Status: OK [107,2] Written, Length: 133 bytes, Status: OK [107,3] Written, Length: 134 bytes, Status: OK [107,24] Written, Length: 152 bytes, Status: OK [107,25] Written, Length: 132 bytes, Status: OK [107,26] Written, Length: 16 bytes, Status: OK [110,0] Written, Length: 6 bytes, Status: OK [111,0] Written, Length: 200 bytes, Status: OK [111,1] Written, Length: 20 bytes, Status: OK [111,2] Written, Length: 20 bytes, Status: OK [111,126] Written, Length: 20 bytes, Status: OK [111,127] Written, Length: 20 bytes, Status: OK [111,150] Written, Length: 8 bytes, Status: OK [111,151] Written, Length: 4 bytes, Status: OK [111,152] Written, Length: 40 bytes, Status: OK [116,0] Written, Length: 2 bytes, Status: OK [116,1] Written, Length: 12 bytes, Status: OK [116,2] Written, Length: 36 bytes, Status: OK [116,3] Written, Length: 36 bytes, Status: OK [116,4] Written, Length: 36 bytes, Status: OK [116,5] Written, Length: 36 bytes, Status: OK [116,6] Written, Length: 36 bytes, Status: OK [116,7] Written, Length: 40 bytes, Status: OK [116,8] Written, Length: 40 bytes, Status: OK [116,9] Written, Length: 40 bytes, Status: OK [116,10] Written, Length: 40 bytes, Status: OK [116,11] Written, Length: 40 bytes, Status: OK [116,12] Written, Length: 40 bytes, Status: OK [116,13] Written, Length: 40 bytes, Status: OK [116,14] Written, Length: 40 bytes, Status: OK [116,15] Written, Length: 40 bytes, Status: OK [116,16] Written, Length: 40 bytes, Status: OK [117,0] Written, Length: 4 bytes, Status: OK [117,1] Written, Length: 3 bytes, Status: OK [117,2] Written, Length: 6 bytes, Status: OK [117,3] Written, Length: 1 bytes, Status: OK [117,4] Written, Length: 9 bytes, Status: OK [117,5] Written, Length: 10 bytes, Status: OK [117,6] Written, Length: 8 bytes, Status: OK [117,13] Written, Length: 3 bytes, Status: OK [117,14] Written, Length: 3 bytes, Status: OK [117,16] Written, Length: 40 bytes, Status: OK [120,0] Written, Length: 2550 bytes, Status: Not accepted, Code: 19 [120,1] Written, Length: 510 bytes, Status: Not accepted, Code: 19 [120,2] Written, Length: 510 bytes, Status: Not accepted, Code: 19 [120,3] Written, Length: 510 bytes, Status: Not accepted, Code: 19 [123,0] Written, Length: 3 bytes, Status: OK [123,4] Written, Length: 3 bytes, Status: OK [123,5] Written, Length: 3 bytes, Status: OK [163,0] Written, Length: 8 bytes, Status: OK [181,0] Written, Length: 8 bytes, Status: OK [181,1] Written, Length: 10 bytes, Status: OK [181,2] Written, Length: 1 bytes, Status: OK [182,0] Written, Length: 1 bytes, Status: OK [182,1] Written, Length: 1 bytes, Status: OK [182,2] Written, Length: 1 bytes, Status: OK [182,3] Written, Length: 8 bytes, Status: OK [182,4] Written, Length: 1 bytes, Status: OK [182,5] Written, Length: 1 bytes, Status: OK [182,6] Written, Length: 1 bytes, Status: OK [182,7] Written, Length: 1 bytes, Status: OK [182,8] Written, Length: 1 bytes, Status: OK [182,9] Written, Length: 1 bytes, Status: OK [182,10] Written, Length: 1 bytes, Status: OK [182,13] Written, Length: 8 bytes, Status: OK [182,17] Written, Length: 1 bytes, Status: OK [182,18] Written, Length: 8 bytes, Status: OK [182,19] Written, Length: 8 bytes, Status: OK [182,22] Written, Length: 8 bytes, Status: OK [182,23] Written, Length: 1 bytes, Status: OK [182,24] Written, Length: 8 bytes, Status: OK [182,25] Written, Length: 1 bytes, Status: OK [183,0] Written, Length: 1 bytes, Status: OK [183,1] Written, Length: 1 bytes, Status: OK [183,2] Written, Length: 1 bytes, Status: OK [183,3] Written, Length: 8 bytes, Status: OK [183,4] Written, Length: 1 bytes, Status: OK [183,5] Written, Length: 1 bytes, Status: OK [183,6] Written, Length: 1 bytes, Status: OK [183,7] Written, Length: 1 bytes, Status: OK [183,8] Written, Length: 1 bytes, Status: OK [183,9] Written, Length: 1 bytes, Status: OK [183,10] Written, Length: 1 bytes, Status: OK [183,13] Written, Length: 8 bytes, Status: OK [183,17] Written, Length: 1 bytes, Status: OK [183,18] Written, Length: 8 bytes, Status: OK [183,19] Written, Length: 8 bytes, Status: OK [183,22] Written, Length: 8 bytes, Status: OK [183,23] Written, Length: 1 bytes, Status: OK [183,24] Written, Length: 8 bytes, Status: OK [183,25] Written, Length: 1 bytes, Status: OK [184,0] Written, Length: 1 bytes, Status: OK [184,1] Written, Length: 1 bytes, Status: OK [184,2] Written, Length: 1 bytes, Status: OK [184,3] Written, Length: 8 bytes, Status: OK [184,4] Written, Length: 1 bytes, Status: OK [184,5] Written, Length: 8 bytes, Status: OK [184,6] Written, Length: 1 bytes, Status: OK [184,7] Written, Length: 1 bytes, Status: OK [184,8] Written, Length: 1 bytes, Status: OK [184,9] Written, Length: 1 bytes, Status: OK [184,10] Written, Length: 1 bytes, Status: OK [184,12] Written, Length: 24 bytes, Status: OK [184,13] Written, Length: 8 bytes, Status: OK [184,17] Written, Length: 1 bytes, Status: OK [184,18] Written, Length: 8 bytes, Status: OK [184,19] Written, Length: 8 bytes, Status: OK [184,22] Written, Length: 8 bytes, Status: OK [184,23] Written, Length: 1 bytes, Status: OK [184,24] Written, Length: 8 bytes, Status: OK [184,25] Written, Length: 1 bytes, Status: OK [185,0] Written, Length: 1 bytes, Status: OK [185,1] Written, Length: 1 bytes, Status: OK [185,2] Written, Length: 1 bytes, Status: OK [185,3] Written, Length: 8 bytes, Status: OK [185,4] Written, Length: 1 bytes, Status: OK [185,5] Written, Length: 8 bytes, Status: OK [185,6] Written, Length: 1 bytes, Status: OK [185,7] Written, Length: 1 bytes, Status: OK [185,8] Written, Length: 1 bytes, Status: OK [185,9] Written, Length: 1 bytes, Status: OK [185,10] Written, Length: 1 bytes, Status: OK [185,12] Written, Length: 28 bytes, Status: OK [185,13] Written, Length: 8 bytes, Status: OK [185,17] Written, Length: 1 bytes, Status: OK [185,18] Written, Length: 8 bytes, Status: OK [185,19] Written, Length: 8 bytes, Status: OK [185,22] Written, Length: 8 bytes, Status: OK [185,23] Written, Length: 1 bytes, Status: OK [185,24] Written, Length: 8 bytes, Status: OK [185,25] Written, Length: 1 bytes, Status: OK [186,0] Written, Length: 1 bytes, Status: OK [186,1] Written, Length: 1 bytes, Status: OK [186,2] Written, Length: 1 bytes, Status: OK [186,3] Written, Length: 8 bytes, Status: OK [186,4] Written, Length: 1 bytes, Status: OK [186,5] Written, Length: 1 bytes, Status: OK [186,6] Written, Length: 1 bytes, Status: OK [186,7] Written, Length: 1 bytes, Status: OK [186,8] Written, Length: 1 bytes, Status: OK [186,9] Written, Length: 1 bytes, Status: OK [186,10] Written, Length: 1 bytes, Status: OK [186,12] Written, Length: 22 bytes, Status: OK [186,13] Written, Length: 8 bytes, Status: OK [186,17] Written, Length: 1 bytes, Status: OK [186,18] Written, Length: 8 bytes, Status: OK [186,19] Written, Length: 8 bytes, Status: OK [186,22] Written, Length: 8 bytes, Status: OK [186,23] Written, Length: 1 bytes, Status: OK [186,24] Written, Length: 8 bytes, Status: OK [186,25] Written, Length: 1 bytes, Status: OK [187,0] Written, Length: 1 bytes, Status: OK [187,1] Written, Length: 1 bytes, Status: OK [187,2] Written, Length: 1 bytes, Status: OK [187,3] Written, Length: 8 bytes, Status: OK [187,4] Written, Length: 1 bytes, Status: OK [187,5] Written, Length: 1 bytes, Status: OK [187,6] Written, Length: 1 bytes, Status: OK [187,7] Written, Length: 1 bytes, Status: OK [187,8] Written, Length: 1 bytes, Status: OK [187,9] Written, Length: 1 bytes, Status: OK [187,10] Written, Length: 1 bytes, Status: OK [187,12] Written, Length: 16 bytes, Status: OK [187,13] Written, Length: 8 bytes, Status: OK [187,17] Written, Length: 1 bytes, Status: OK [187,18] Written, Length: 8 bytes, Status: OK [187,19] Written, Length: 8 bytes, Status: OK [187,22] Written, Length: 8 bytes, Status: OK [187,23] Written, Length: 1 bytes, Status: OK [187,24] Written, Length: 8 bytes, Status: OK [187,25] Written, Length: 1 bytes, Status: OK [190,0] Written, Length: 355 bytes, Status: OK [191,0] Written, Length: 5 bytes, Status: OK [193,2] Written, Length: 8 bytes, Status: OK [193,3] Written, Length: 32 bytes, Status: OK [193,4] Written, Length: 32 bytes, Status: OK [193,9] Written, Length: 64 bytes, Status: OK [202,0] Written, Length: 1 bytes, Status: OK [202,1] Written, Length: 1 bytes, Status: OK [202,3] Written, Length: 1 bytes, Status: OK [202,4] Written, Length: 42 bytes, Status: OK [208,0] Written, Length: 40 bytes, Status: OK [213,0] Written, Length: 20 bytes, Status: OK [215,0] Written, Length: 84 bytes, Status: OK [217,0] Written, Length: 32 bytes, Status: OK [218,0] Written, Length: 2 bytes, Status: OK [225,0] Written, Length: 1 bytes, Status: OK [225,1] Written, Length: 6 bytes, Status: OK [225,2] Written, Length: 6 bytes, Status: OK [232,0] Written, Length: 20 bytes, Status: OK [232,1] Written, Length: 1 bytes, Status: OK [232,3] Written, Length: 1 bytes, Status: OK [232,4] Written, Length: 1 bytes, Status: OK [232,5] Written, Length: 1 bytes, Status: OK [232,6] Written, Length: 1 bytes, Status: OK [232,7] Written, Length: 1 bytes, Status: OK [232,8] Written, Length: 1 bytes, Status: OK [232,9] Written, Length: 4 bytes, Status: OK [232,10] Written, Length: 1 bytes, Status: OK [238,1] Written, Length: 1 bytes, Status: OK [239,0] Written, Length: 2 bytes, Status: OK [239,1] Written, Length: 2314 bytes, Status: OK [239,2] Written, Length: 2314 bytes, Status: OK [239,3] Written, Length: 2314 bytes, Status: OK [239,4] Written, Length: 2314 bytes, Status: OK [239,5] Written, Length: 2314 bytes, Status: OK [250,1] Written, Length: 1840 bytes, Status: OK [250,2] Written, Length: 128 bytes, Status: OK [250,3] Written, Length: 600 bytes, Status: OK [250,4] Written, Length: 32 bytes, Status: OK Write PM Finished, Record written OK: 667, Record written NOT OK: 5 MCU Version V 06.83 MCU Date 27-09-08 Product RM-391 Manufacturer (c) Nokia IMEI 01179 Mastercode 4170743443 Proceeding with RSA Unlock... Setting Local Mode... Local mode Set Asic 11 HW Signature BAB1E4429F64183D Simlock Server SIMLOCK SERVER Simlock Key 0010100000000000 Simlock Profile 800000000003000B Simlock Aux 000B5555 Simlock IMEI 00550117960010013800 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [1,2] State: OPENED Type: GID Data: FFFF Simlock [1,3] State: OPENED Type: GID Data: FFFF Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [2,2] State: OPENED Type: GID Data: FFFF Simlock [2,3] State: OPENED Type: GID Data: FFFF Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [3,2] State: OPENED Type: GID Data: FFFF Simlock [3,3] State: OPENED Type: GID Data: FFFF Simlock [3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [4,2] State: OPENED Type: GID Data: FFFF Simlock [4,3] State: OPENED Type: GID Data: FFFF Simlock [4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [5,2] State: OPENED Type: GID Data: FFFF Simlock [5,3] State: OPENED Type: GID Data: FFFF Simlock [5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [6,2] State: OPENED Type: GID Data: FFFF Simlock [6,3] State: OPENED Type: GID Data: FFFF Simlock [6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [7,2] State: OPENED Type: GID Data: FFFF Simlock [7,3] State: OPENED Type: GID Data: FFFF Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Asking card to sign HW Signature... Signed OK (2FC5BD8E5312540A936681FA31A0D65385861880) Calculating SP... Writing SP... New SP Accepted OK! Phone unlocked OK! Setting factory defaults of: Factory set full Factory defaults set OK Last edited by ptt; 07-31-2010 at 22:31. Reason: add Code Tag |
07-31-2010, 21:04 | #1192 (permalink) |
Freak Poster Join Date: Oct 2006 Location: Santiago de Chile
Member: 370221 Status: Offline Sonork: 1592059 Thanks Meter: 97 | Unlock nokia 5800 Code: Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v01.45, (Jul 6 2010 19:20:51, gcc v4.3.2, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2010 wk27 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk40 Initializing security card... Card Serial Number: Card Firmware Revision: 0109 Card is activated Box is activated All initialized - Ready to work MCU Version V ICPR72_09w02.3 MCU Date 26-01-09 Product RM-428 Manufacturer (c) Nokia IMEI :):):) Mastercode 71473310 IMEI Spare IMEI SV CNT V 20.0.012 PSN GAK163071 Product Code 0582176 Basic Product Code 0559231 PSD 0000000000000000 LPSN 0 WLAN MAC 0025CFF65ADC APE SW V 20.2.014 APE Variant V 20.2.014V 52.50.2009.20.2.012 20.2.014.367.02 APE Test 2008wk50v0.013 APE HW 256 APE ADSP 256 RETU 16 TAHVO 22 AHNE 11 HW 1101 RFIC 17141715 DSP sangalo_ICPR72_09w02 Simlock Server SIMLOCK SERVER Simlock Key 7300300036615151 Simlock Profile 0000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 73003F Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 73003F BB5 Unlock Started... MCU Version V ICPR72_09w02.3 MCU Date 26-01-09 Product RM-428 Manufacturer (c) Nokia IMEI 359348022649842 Mastercode 71473310 Simlock Server SIMLOCK SERVER Simlock Key 7300300036615151 Simlock Profile 0000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 73003F Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 73003F Reading Security Block... Security block OK and saved to "RM-428_359348022649842_01082010_150634.SecurityBlock.PM" WARNING: "0EA00107467C00526871BCDFDE88191C6002D167.C0003929" Not Exists, Will read it... Reading CYC file from phone... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 0EA00107467C00526871BCDFDE88191C6002D167 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL Exploiting - running preloader... Preloader running OK, Running Custom Loader... Custom loader running OK! Working... Readed OK, Saving to "0EA00107467C00526871BCDFDE88191C6002D167.C0003929" Checking for Rootkey Hash support with selected Unlock Method... Selected Unlock Method: RPL Calculation Asking box to calculate RPL... Received RPL from Box OK! Writing Simlock... Simlock ACCEPTED OK ! MCU Version V ICPR72_09w02.3 MCU Date 26-01-09 Product RM-428 Manufacturer (c) Nokia Simlock [7,2] State: OPENED Type: GID Data: FFFF Simlock [7,3] State: OPENED Type: GID Data: FFFF Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Unlock finished! Time taken 18.807s Last edited by ptt; 07-31-2010 at 22:31. Reason: add Code Tag |
08-02-2010, 10:54 | #1193 (permalink) |
Freak Poster Join Date: Feb 2009 Location: I LOVE PAKISTAN Age: 38
Member: 977491 Status: Offline Thanks Meter: 82 | nokia 2220s unlock done Last edited by ptt; 08-02-2010 at 11:24. Reason: You can post the TXT Log instead the big screenshot, as all others do |
The Following User Says Thank You to themobileshop For This Useful Post: |
08-02-2010, 11:47 | #1194 (permalink) |
Member: 1178981 Status: Offline Sonork: 100.1596342 Thanks Meter: 500 | 2330c flashing done Code: Processing C:\Program Files\Nokia\Phoenix\Products\... Found 46 products, Filtering DCT4 Products - wait... 11 Products left after filtering. Ready. Retrieving Variants for Product RM-512 - wait... 318 Variants Retrieved Processing pre-flash tasks... Pre-flash tasks finished Booting UPP... UPP ID: 3168 [HW_UNKNOWN] rm512__09.55.mcusw, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 Box VPP disabled Internal Phone VPP Selected PLL Factor: 3 FlashChip[0]: 0x00EC2600 @ 0x01000000, Samsung, SectorSize: 128kB, Ext: 00009221 FlashChip[1]: 0x00EC2600 @ 0x02000000, Samsung, SectorSize: 128kB, Ext: 00009221 Signature: AD7EB61B23100340C605E40120A20000 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 51Kbits u3_amd.fia, Type: Algorithm, Target: FlashChip[0] 0x00EC2600 (256Mbits), Rev: 7.4.79.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.02V MSID-Crypted: 841038D446012C1DA57D1F3EB9 MSID-Plain: 2C40BAE9000584DDA8000000 FAID-Crypted: 7641836F2DD792C3EDE74C6C Flashbus Write baud set to 6.50Mbits 2 Region(s) to erase Erasing NOR Region [0x01000000-0x0101FFFF] Erasing NOR Region [0x01020000-0x01CFFFFF] Erase taken 54.937s Writing 191 blocks... All blocks written OK! Time taken 564.657s Terminating flash session Box VPP disabled Booting UPP... UPP ID: 3168 [HW_UNKNOWN] rm512__09.55.image_mena_b_bla, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 Box VPP disabled Internal Phone VPP Selected PLL Factor: 3 FlashChip[0]: 0x00EC2600 @ 0x01000000, Samsung, SectorSize: 128kB, Ext: 00009221 FlashChip[1]: 0x00EC2600 @ 0x02000000, Samsung, SectorSize: 128kB, Ext: 00009221 Signature: AD7EB61B23100340C605E40120A20000 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 51Kbits u3_amd.fia, Type: Algorithm, Target: FlashChip[0] 0x00EC2600 (256Mbits), Rev: 7.4.79.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.04V MSID-Crypted: 8457CC1C8F7613D7018D3E773B MSID-Plain: D26EBAF1000584DDAA000610 FAID-Crypted: CB690F0B916036D71D5CDBA3 Flashbus Write baud set to 6.50Mbits 2 Region(s) to erase Erasing NOR Region [0x02180000-0x02E7FFFF] Erasing NOR Region [0x02E80000-0x02FBFFFF] Erase taken 58.781s File Sector Size: 128kB, Flash Chip Sector Size: 128kB CNT Convertion not needed Writing 224 blocks... All blocks written OK! Time taken 138.593s Terminating flash session Extracting Content Package... CP Extract Failed -> CP Server not exists WARNING: Failed to extract CP Box VPP disabled Booting UPP... UPP ID: 3168 [HW_UNKNOWN] rm512__09.55.ppm_mena_b, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 Box VPP disabled Internal Phone VPP Selected PLL Factor: 3 FlashChip[0]: 0x00EC2600 @ 0x01000000, Samsung, SectorSize: 128kB, Ext: 00009221 FlashChip[1]: 0x00EC2600 @ 0x02000000, Samsung, SectorSize: 128kB, Ext: 00009221 Signature: AD7EB61B23100340C605E40120A20000 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 51Kbits u3_amd.fia, Type: Algorithm, Target: FlashChip[0] 0x00EC2600 (256Mbits), Rev: 7.4.79.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.04V MSID-Crypted: 844297646C9FB5FDDA468643B8 MSID-Plain: 3E4EBAE9000584DDA8000000 FAID-Crypted: 0A01245F7897AE7507EFEA46 Flashbus Write baud set to 6.50Mbits 1 Region(s) to erase Erasing NOR Region [0x01D00000-0x0217FFFF] Erase taken 18.766s Writing 34 blocks... All blocks written OK! Time taken 86.78s Terminating flash session Box VPP disabled Processing post-flash tasks... Setting Factory Defaults... Factory defaults OK Post-flash tasks finished... Flash successfully finished! |
The Following User Says Thank You to RAVI_SINGH For This Useful Post: |
08-02-2010, 11:49 | #1195 (permalink) |
Registered User Join Date: Dec 2009 Location: p A k I s T a N
Member: 1178981 Status: Offline Sonork: 100.1596342 Thanks Meter: 500 | 1112 flashing done Code: Processing C:\Program Files\Nokia\Phoenix\Products\... Found 46 products, Filtering DCT4 Products - wait... 10 Products left after filtering. Ready. Retrieving Variants for Product RH-93 - wait... 511 Variants Retrieved Processing pre-flash tasks... Pre-flash tasks finished Booting UPP... UPP ID: 2201 [HW_UPP2M_v2] rh93_06.930, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM Flashbus Write baud set to 100Kbits u_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 Box VPP disabled Internal Phone VPP Selected PLL Factor: 3 FlashChip[0]: 0x00EC2268 @ 0x01000000, Samsung, SectorSize: 64kB, Ext: 00000121 Signature: AD7EB61A1BBE0BE27D586BE4DBEE6514 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 51Kbits u_amd.fia, Type: Algorithm, Target: FlashChip[0] 0x00EC2268 (32Mbits), Rev: 7.4.79.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.04V MSID-Crypted: 8492342C34614960246D4C59B3 MSID-Plain: 3E4EBAE9009FF6B3AA000000 FAID-Crypted: BA3CB8A1B93C866794721B1F Flashbus Write baud set to 6.50Mbits 5 Region(s) to erase Erasing NOR Region [0x01000000-0x0100FFFF] Erasing NOR Region [0x01010000-0x013BFFFF] Erasing NOR Region [0x013C0000-0x013EFFFF] Erasing NOR Region [0x017C0000-0x017EFFFF] Erasing NOR Region [0x01FC0000-0x01FEFFFF] Erase taken 23.156s Writing 122 blocks... All blocks written OK! Time taken 8.844s Terminating flash session Box VPP disabled Booting UPP... UPP ID: 2201 [HW_UPP2M_v2] rh930_nai6.93ia, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM Flashbus Write baud set to 100Kbits u_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 Box VPP disabled Internal Phone VPP Selected PLL Factor: 3 FlashChip[0]: 0x00EC2268 @ 0x01000000, Samsung, SectorSize: 64kB, Ext: 00000121 Signature: AD7EB61A1BBE0BE27D586BE4DBEE6514 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 51Kbits u_amd.fia, Type: Algorithm, Target: FlashChip[0] 0x00EC2268 (32Mbits), Rev: 7.4.79.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.04V MSID-Crypted: 840CF86751396AC686C6805DEB MSID-Plain: 3E4EBAE9009FF6B3A8000000 FAID-Crypted: 3A55D81766E8E39B8C459612 Flashbus Write baud set to 6.50Mbits 1 Region(s) to erase Erasing NOR Region [0x01380000-0x013BFFFF] Erase taken 1.532s Writing 10 blocks... All blocks written OK! Time taken 0.735s Terminating flash session Extracting Content Package... CP Server: File Server fake reply for CUI phone. CP Extract Failed -> CP Not Extracted, Code: 1 WARNING: Failed to extract CP Box VPP disabled Booting UPP... UPP ID: 2201 [HW_UPP2M_v2] rh93_06.93ia, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM Flashbus Write baud set to 100Kbits u_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 Box VPP disabled Internal Phone VPP Selected PLL Factor: 3 FlashChip[0]: 0x00EC2268 @ 0x01000000, Samsung, SectorSize: 64kB, Ext: 00000121 Signature: AD7EB61A1BBE0BE27D586BE4DBEE6514 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 51Kbits u_amd.fia, Type: Algorithm, Target: FlashChip[0] 0x00EC2268 (32Mbits), Rev: 7.4.79.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.04V MSID-Crypted: 840CF86751396AC686C6805DEB Using MSID-FAID Cache, Not wasting card FAID-Crypted: 3A55D81766E8E39B8C459612 Flashbus Write baud set to 6.50Mbits 2 Region(s) to erase Erasing NOR Region [0x011E0000-0x011EFFFF] Erasing NOR Region [0x011F0000-0x0137FFFF] Erase taken 9.594s Writing 82 blocks... All blocks written OK! Time taken 6.0s Terminating flash session Box VPP disabled Processing post-flash tasks... Setting Factory Defaults... Factory defaults OK Post-flash tasks finished... Flash successfully finished! |
08-03-2010, 08:33 | #1196 (permalink) |
Freak Poster Join Date: Jul 2010
Member: 1354740 Status: Offline Thanks Meter: 91 | **Nokia 6303c SL3 Unlocked By Cyclone ** Code: BB5 Unlock Started... MCU Version V 08.55 MCU Date 15-06-09 Product RM-443 Manufacturer (c) Nokia IMEI 359333032352377 Mastercode 5699452388 Simlock Server SIMLOCK SERVER Simlock Key 2342000000000000 Simlock Profile 0000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 23420F Connecting to Cyclone Server... Cyclone Server (1.0.0.632), Cyclone Box Team 2008, 2009, 2010 - Ready. Checking job status... Code Ready, Code: #pw+077345165676687+7# Sending code via FBUS... NCK[7] - ACCEPTED Code Accepted! Unlocking Finished! Best Regards..>- THANKS TO NONOYXP CEBU Last edited by ptt; 08-03-2010 at 15:43. Reason: add code tag |
08-03-2010, 09:25 | #1197 (permalink) |
Member: 1178981 Status: Offline Sonork: 100.1596342 Thanks Meter: 500 | 2310 Successfull Flashed Code: Processing C:\Program Files\Nokia\Phoenix\Products\... Found 47 products, Filtering DCT4 Products - wait... 12 Products left after filtering. Ready. Retrieving Variants for Product RM-189 - wait... 335 Variants Retrieved Processing pre-flash tasks... Pre-flash tasks finished Booting UPP... UPP ID: 2201 [HW_UPP2M_v2] rm189_06.520, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM Flashbus Write baud set to 100Kbits u_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 Box VPP disabled Internal Phone VPP Selected PLL Factor: 3 FlashChip[0]: 0x00898872 @ 0x01000000, Intel, SectorSize: 64kB, Ext: 00000121 Signature: AD7EB61A1BBE0BE27D586BE4DBEE6514 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 51Kbits u_intel.fia, Type: Algorithm, Target: FlashChip[0] 0x00898872 (32Mbits), Rev: 7.4.80.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.04V MSID-Crypted: 84AC3804634BAA3E46550D1BC0 MSID-Plain: 3E4EBAE9004F0ACDAA000000 FAID-Crypted: 2F971CDB9B2E5CCC1D120066 Flashbus Write baud set to 6.50Mbits 5 Region(s) to erase Erasing NOR Region [0x01000000-0x0100FFFF] Erasing NOR Region [0x01010000-0x013BFFFF] Erasing NOR Region [0x013C0000-0x013EFFFF] Erasing NOR Region [0x017C0000-0x017EFFFF] Erasing NOR Region [0x01FC0000-0x01FEFFFF] Erase taken 33.859s Writing 123 blocks... All blocks written OK! Time taken 15.828s Terminating flash session Box VPP disabled Booting UPP... UPP ID: 2201 [HW_UPP2M_v2] rm1890_nai6.52ic, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM Flashbus Write baud set to 100Kbits u_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 Box VPP disabled Internal Phone VPP Selected PLL Factor: 3 FlashChip[0]: 0x00898872 @ 0x01000000, Intel, SectorSize: 64kB, Ext: 00000121 Signature: AD7EB61A1BBE0BE27D586BE4DBEE6514 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 51Kbits u_intel.fia, Type: Algorithm, Target: FlashChip[0] 0x00898872 (32Mbits), Rev: 7.4.80.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.04V MSID-Crypted: 84AC3804634BAA3E46550D1BC0 Using MSID-FAID Cache, Not wasting card FAID-Crypted: 2F971CDB9B2E5CCC1D120066 Flashbus Write baud set to 6.50Mbits 1 Region(s) to erase Erasing NOR Region [0x01380000-0x013BFFFF] Erase taken 2.203s Writing 12 blocks... All blocks written OK! Time taken 1.500s Terminating flash session Extracting Content Package... CP Server: File Server fake reply for CUI phone. CP Extract Failed -> CP Not Extracted, Code: 1 WARNING: Failed to extract CP Box VPP disabled Booting UPP... UPP ID: 2201 [HW_UPP2M_v2] rm189_06.52ic, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM Flashbus Write baud set to 100Kbits u_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 Box VPP disabled Internal Phone VPP Selected PLL Factor: 3 FlashChip[0]: 0x00898872 @ 0x01000000, Intel, SectorSize: 64kB, Ext: 00000121 Signature: AD7EB61A1BBE0BE27D586BE4DBEE6514 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 51Kbits u_intel.fia, Type: Algorithm, Target: FlashChip[0] 0x00898872 (32Mbits), Rev: 7.4.80.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.02V MSID-Crypted: 84AC3804634BAA3E46550D1BC0 Using MSID-FAID Cache, Not wasting card FAID-Crypted: 2F971CDB9B2E5CCC1D120066 Flashbus Write baud set to 6.50Mbits 2 Region(s) to erase Erasing NOR Region [0x011E0000-0x011EFFFF] Erasing NOR Region [0x011F0000-0x0137FFFF] Erase taken 13.843s Writing 81 blocks... All blocks written OK! Time taken 10.516s Terminating flash session Box VPP disabled Processing post-flash tasks... Setting Factory Defaults... Factory defaults OK Post-flash tasks finished... Flash successfully finished! |
08-03-2010, 15:16 | #1198 (permalink) |
No Life Poster Join Date: Apr 2003 Location: INTERNET-INDIA
Member: 26488 Status: Offline Sonork: 100.1581233 Thanks Meter: 151 | 6210s-1 flashed successfully. Code: Initializing FBUS... All initialized - Ready to work Scanning avaiable products... Processing C:\Program Files\Nokia\Phoenix\Products\... Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\... Found 161 products, Filtering BB5 Products - wait... 60 Products left after filtering. Ready. Retrieving Variants for Product RM-367 - wait... 1 Variants Retrieved Processing pre flash tasks... Backing up RPL... RPL Creation started... Processing CMT Part... Storing Product Code... Storing PSN... Storing HWID... Trying to store Simlock... Reading Configuration Key... Hashing... Reading SHA1-RSA Signature... Reading SHA1-HMAC Signature... Storing Simlock... Trying to store WMDRM RPL... Reading Keys... Storing WMDRM PD... Reading Security Block... Security block OK and saved to "RM-367_354199022503363_832010_73937 PM.SecurityBlock.PM" WARNING: "0F000113FB9F015866DED8E8F52645A55A0A587C.C0004566" Not Exists, Will read it... Reading CYC file from phone... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 0F000113FB9F015866DED8E8F52645A55A0A587C CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL Exploiting - running preloader... Preloader running OK, Running Custom Loader... Custom loader running OK! Working... Readed OK, Saving to "0F000113FB9F015866DED8E8F52645A55A0A587C.C0004566" Storing Additional Data... Checking Superdongle Key... Encrypting Superdongle Key... Storing Superdongle Key... Checking CMLA Key... Storing CMLA Key... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 0F000113FB9F015866DED8E8F52645A55A0A587C CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! Searching for BootCode: DualLine 32Bit RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.10.16.2, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0400000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC004000000121, Samsung, ONENAND Requested Algorithm: XSR 1.5 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0040 (Samsung), Size: 256MBytes, VPP: Not Supported RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.10.22.0, Algo: XSR 1.5 Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 4AA07663215C623237BF8A43EC71D55819B7DC6E APE Subsystem Not Found Flashbus Write baud set to 5.0Mbits Storing NPC... Storing CCC... Storing HWC... CMT VARIANT Not Found Restarting MCU... RPL Saved OK RPL backup thread finished, continuing... Backing up simlock... MCU Version V ICPR71_09w12.9 MCU Date 14-09-09 Product RM-367 Manufacturer (c) Nokia IMEI 354199022503363 Mastercode 465454032 Simlock backup OK, saved to RM-367_354199022503363_832010_73950 PM.SLBackup.PM Backup simlock thread finished, continuing... Pre flash tasks finished, continuing... Processing rm367_05.501_prd_core.fpsx (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 0F000113FB9F015866DED8E8F52645A55A0A587C CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! rm367_05.501_prd_core.fpsx, Type: Flash Image, Algo: XSR 1.5, BB5 Searching for BootCode: DualLine 32Bit RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.10.16.2, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0400000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC004000000121, Samsung, ONENAND Requested Algorithm: XSR 1.5 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0040 (Samsung), Size: 256MBytes, VPP: Not Supported RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.10.22.0, Algo: XSR 1.5 Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 4AA07663215C623237BF8A43EC71D55819B7DC6E Flashbus Write baud set to 5.0Mbits Sending Certificates... Certificates OK Partitioning... Partitioning OK Started group flash erase EraseArea[0,CMT]: 0x00040000-0x00082FFF, ONENAND EraseArea[0,CMT]: 0x00083400-0x0087FFFF, ONENAND EraseArea[0,CMT]: 0x00B80000-0x080FFFFF, ONENAND Erase Partition (CMT) Waiting 320s for erasure finish... Erase taken 0.735s Writing all blocks... Writing CMT ADA Certificate... Writing CMT KEYS Certificate... Writing CMT PRIMAPP Certificate... Writing CMT RAP3NAND Certificate... Writing CMT PASUBTOC Certificate... Writing CMT PAPUBKEYS Certificate... Writing CMT SOS*UPDAPP Certificate... Writing CMT SOS*DSP0 Certificate... Writing CMT SOS*ISASW Certificate... Writing CMT SOS+CORE Certificate... Writing CMT SOS+ROFS1 Certificate... Programming Status OK! All blocks written OK! Time taken 89.62s Flashing Speed: 7052.04 kBit/S Restarting MCU... Processing rm367_05.501_prd_core.fpsx (APE)... Processing rm367_05.501_prd_v02_01_euro2.fpsx (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 0F000113FB9F015866DED8E8F52645A55A0A587C CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! rm367_05.501_prd_v02_01_euro2.fpsx, Type: Flash Image, Algo: XSR 1.5, BB5 Searching for BootCode: DualLine 32Bit RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.10.16.2, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0400000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC004000000121, Samsung, ONENAND Requested Algorithm: XSR 1.5 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0040 (Samsung), Size: 256MBytes, VPP: Not Supported RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.10.22.0, Algo: XSR 1.5 Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 4AA07663215C623237BF8A43EC71D55819B7DC6E Flashbus Write baud set to 5.0Mbits Started group flash erase EraseArea[0,CMT]: 0x053E0000-0x078FFFFF, ONENAND Waiting 320s for erasure finish... Erase taken 0.203s Writing all blocks... Writing CMT SOS+ROFS2 Certificate... Programming Status OK! All blocks written OK! Time taken 39.922s Flashing Speed: 6928.41 kBit/S Restarting MCU... Processing rm367_05.501_prd_v02_01_euro2.fpsx (APE)... Processing rm367_05.501_prd_vc00_01_Navigator.fpsx (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 0F000113FB9F015866DED8E8F52645A55A0A587C CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! rm367_05.501_prd_vc00_01_Navigator.fpsx, Type: Flash Image, Algo: XSR 1.5, BB5 Searching for BootCode: DualLine 32Bit RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.10.16.2, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0400000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC004000000121, Samsung, ONENAND Requested Algorithm: XSR 1.5 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0040 (Samsung), Size: 256MBytes, VPP: Not Supported RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.10.22.0, Algo: XSR 1.5 Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 4AA07663215C623237BF8A43EC71D55819B7DC6E Flashbus Write baud set to 5.0Mbits Started group flash erase EraseArea[0,CMT]: 0x07900000-0x080FFFFF, ONENAND Waiting 320s for erasure finish... Erase taken 0.63s Writing all blocks... Writing CMT SOS+ROFS3 Certificate... Programming Status OK! All blocks written OK! Time taken 0.78s Flashing Speed: 504.21 kBit/S Restarting MCU... Processing rm367_05.501_prd_vc00_01_Navigator.fpsx (APE)... Processing rm367_05.501_prd_uda.fpsx (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 0F000113FB9F015866DED8E8F52645A55A0A587C CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! rm367_05.501_prd_uda.fpsx, Type: Flash Image, Algo: XSR 1.5, BB5 Searching for BootCode: DualLine 32Bit RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.10.16.2, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0400000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC004000000121, Samsung, ONENAND Requested Algorithm: XSR 1.5 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0040 (Samsung), Size: 256MBytes, VPP: Not Supported RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.10.22.0, Algo: XSR 1.5 Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 4AA07663215C623237BF8A43EC71D55819B7DC6E Flashbus Write baud set to 5.0Mbits Started group flash erase EraseArea[0,CMT]: 0x08100000-0x0F8BFFFF, ONENAND Waiting 320s for erasure finish... Erase taken 0.641s Writing all blocks... Programming Status OK! All blocks written OK! Time taken 1.500s Flashing Speed: 411.00 kBit/S Restarting MCU... Processing rm367_05.501_prd_uda.fpsx (APE)... All images processed OK! Processing post flash tasks... Setting Factory Defaults... Factory defaults OK Reading info... MCU Version V ICPR71_09w12.9 MCU Date 14-09-09 Product RM-367 Manufacturer (c) Nokia IMEI 354199022503363 Mastercode 465454032 IMEI Spare 3A45910922053306 IMEI SV 3345910922053356F5000000 PSN C3A464379 Product Code 0565865 Basic Product Code 0553370 PSD 0000000000000000 LPSN 0 RETU 15 TAHVO 22 AHNE 11 HW 0701 RFIC 17141715 DSP ICPR71_09w10 Simlock Server SIMLOCK SERVER Simlock Key 2440700000000000 Simlock Profile 0000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [1,2] State: OPENED Type: GID Data: FFFF Simlock [1,3] State: OPENED Type: GID Data: FFFF Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [2,2] State: OPENED Type: GID Data: FFFF Simlock [2,3] State: OPENED Type: GID Data: FFFF Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [3,2] State: OPENED Type: GID Data: FFFF Simlock [3,3] State: OPENED Type: GID Data: FFFF Simlock [3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [4,2] State: OPENED Type: GID Data: FFFF Simlock [4,3] State: OPENED Type: GID Data: FFFF Simlock [4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [5,2] State: OPENED Type: GID Data: FFFF Simlock [5,3] State: OPENED Type: GID Data: FFFF Simlock [5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [6,2] State: OPENED Type: GID Data: FFFF Simlock [6,3] State: OPENED Type: GID Data: FFFF Simlock [6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [7,2] State: OPENED Type: GID Data: FFFF Simlock [7,3] State: OPENED Type: GID Data: FFFF Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Read info thread finished, continuing... Post flash tasks finished! Flashing successfully finished! Saif. Last edited by saif@cellplus; 08-03-2010 at 15:18. Reason: code |
08-03-2010, 15:51 | #1199 (permalink) |
No Life Poster Join Date: Mar 2006 Location: World wide
Member: 252975 Status: Offline Thanks Meter: 146 | Nokia N97 UnlockSucessfully with Cyclonebox Code: Handling device: [Cyclone Team], [Cyclone Bootloader] Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v01.46, (Jul 24 2010 23:54:36, gcc v4.3.2, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2010 wk27 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: C0------ HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2008, wk27 Initializing security card... Card Serial Number: D200000 Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 5.13v PASSED MCU Voltage 3.30v PASSED Core Voltage 1.80v PASSED VBAT Voltage 1.18v PASSED VBAT Voltage 4.96v PASSED Box VPP disabled VPP Voltage 0.04v PASSED Internal Box VPP Enabled VPP Voltage 4.92v PASSED Box VPP disabled VPP Voltage 0.00v PASSED External Box VPP Enabled VPP Voltage 0.02v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work BB5 Unlock Started... MCU Version V ICPR72_09w17.5 MCU Date 05-06-09 Product RM-505 Manufacturer (c) Nokia IMEI 35606403------- Mastercode 421373614 Simlock Server SIMLOCK SERVER Simlock Key 2342000000000000 Simlock Profile 0000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 23420F Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 23594F Simlock [3,1] State: CLOSED Type: MCC-MNC Data: 23420F Simlock [4,1] State: CLOSED Type: MCC-MNC Data: 23594F Connecting to Cyclone Server... Cyclone Server (1.0.0.633), Cyclone Box Team 2008, 2009, 2010 - Ready. Checking job status... Code Ready, Code: #pw+793294752648061+7# Sending code via FBUS... NCK[7] - ACCEPTED Code Accepted! Unlocking Finished! Sending BB5 NCK Code... NCK[7] - Unlocked Already MCU Version V ICPR72_09w17.5 MCU Date 05-06-09 Product RM-505 Manufacturer (c) Nokia IMEI 356064034271664 Mastercode 421373614 IMEI Spare 3A6560044-------- IMEI SV 3365600443726106F3000000 CNT 11.0.021_006_U235r RM505_RM507_002_000_M001, PSN CUC747942 Product Code 0586308 Basic Product Code 0570816 PSD 0000000000000000 LPSN 0 WLAN MAC 0026CCBF809E APE SW V 11.0.021 APE Variant V 11.0.02111.0.02111.0.021.235.07 APE Test rm505ENO_09w23v0.010 APE HW 256 APE ADSP 256 RETU 16 TAHVO 22 AHNE 11 HW 4001 RFIC |Vapaus_5.1 | ??? DSP ivalo_ICPR72_09w17_p2 Simlock Server SIMLOCK SERVER Simlock Key 2342000000000000 Simlock Profile 0000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: 23420F Simlock [2,1] State: OPENED Type: MCC-MNC Data: 23594F Simlock [3,1] State: OPENED Type: MCC-MNC Data: 23420F Simlock [4,1] State: OPENED Type: MCC-MNC Data: 23594F Simlock NCK #pw+7aoZ94752648061+7# Last edited by saajith; 09-12-2011 at 20:18. |
The Following 3 Users Say Thank You to saajith For This Useful Post: |
08-04-2010, 03:19 | #1200 (permalink) |
Banned Join Date: Jul 2005 Location: Philippines Age: 53
Member: 161739 Status: Offline Sonork: 100.1584054 Thanks Meter: 3,338 | n95 rm-320 fast unlock using latest update Code: Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v01.46, (Jul 24 2010 23:54:36, gcc v4.3.2, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2010 wk27 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: C0000366 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2008, wk32 Initializing security card... Card Serial Number: D1000013 Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 5.03v PASSED MCU Voltage 3.27v PASSED Core Voltage 1.82v PASSED VBAT Voltage 0.01v PASSED VBAT Voltage 4.96v PASSED Box VPP disabled VPP Voltage 0.00v PASSED Internal Box VPP Enabled VPP Voltage 4.97v PASSED Box VPP disabled VPP Voltage 0.02v PASSED External Box VPP Enabled VPP Voltage 0.04v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work Booting CMT... APE_SYSTEM_ASIC_ID: 24200705 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: 826B9E12141324730C4AD8ADE99FE4CE3FE7037A APE_ROOT_KEY_HASH: BA8710A7E1CD5A2909B9A875DB27AA2400000000 CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101021103 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 0F60001937BE00581D6EAC5666A972B8CC39E794 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_BOOT_ROM_CRC: A8C1D671 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! Searching for BootCode: DualLine 32Bit (Forcing OLD Protocol) RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL FlashChip[0,CMT]: 0x0001003500006921, AMD, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit (Forcing OLD Protocol) FlashChip 0x00010035 (AMD), Size: 16MBytes, VPP: 9V RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: XSR 1.5 Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 9C5EA53A1F6DBD7DF955715E780159991B4B6EA4 APE Boot skipped on user request Flashbus Write baud set to 5.0Mbits Restarting MCU... RPL Creation started... Processing CMT Part... Storing Product Code... Storing PSN... Storing HWID... Trying to store Simlock... Reading Configuration Key... Hashing... Reading SHA1-RSA Signature... Reading SHA1-HMAC Signature... Storing Simlock... Trying to store WMDRM RPL... Reading Keys... Storing WMDRM PD... Reading Security Block... Security block OK and saved to "RM-320_359542016816710_842010_101653 AM.SecurityBlock.PM" WARNING: "0F60001937BE00581D6EAC5666A972B8CC39E794.C0000366" Not Exists, Will read it... Reading CYC file from phone... Booting CMT... APE_SYSTEM_ASIC_ID: 24200705 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: 826B9E12141324730C4AD8ADE99FE4CE3FE7037A APE_ROOT_KEY_HASH: BA8710A7E1CD5A2909B9A875DB27AA2400000000 CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101021103 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 0F60001937BE00581D6EAC5666A972B8CC39E794 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_BOOT_ROM_CRC: A8C1D671 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL Exploiting - running preloader... Preloader running OK, Running Custom Loader... Custom loader running OK! Working... Readed OK, Saving to "0F60001937BE00581D6EAC5666A972B8CC39E794.C0000366" Storing Additional Data... Checking Superdongle Key... Encrypting Superdongle Key... Storing Superdongle Key... Checking CMLA Key... Storing CMLA Key... Booting CMT... APE_SYSTEM_ASIC_ID: 24200705 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: 826B9E12141324730C4AD8ADE99FE4CE3FE7037A APE_ROOT_KEY_HASH: BA8710A7E1CD5A2909B9A875DB27AA2400000000 CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101021103 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 0F60001937BE00581D6EAC5666A972B8CC39E794 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_BOOT_ROM_CRC: A8C1D671 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! Searching for BootCode: DualLine 32Bit (Forcing OLD Protocol) RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL FlashChip[0,CMT]: 0x0001003500006921, AMD, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit (Forcing OLD Protocol) FlashChip 0x00010035 (AMD), Size: 16MBytes, VPP: 9V RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: XSR 1.5 Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 9C5EA53A1F6DBD7DF955715E780159991B4B6EA4 Searching for BootCode: DualLine 32Bit (Forcing OLD Protocol) omap2420_m1_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.41.0, Algo: BB5 FlashChip[0,APE]: 0x00EC004000220000, Samsung, NAND Requested Algorithm: OMAP2420 UNISTORE-II-1.5.1 ALG (APE) FlashChip[0,APE]: 0xFFFF000000000000, Unknown, MMC Searching for BootCode: DualLine 32Bit (Forcing OLD Protocol) FlashChip 0x00EC0040 (Samsung), Size: 256MBytes, VPP: Not Supported teflon_sam_nand_xsr151_m1.fg, Type: Algorithm, Rev: 0.1.57.0, Algo: OMAP2420 UNISTORE-II-1.5.1 ALG Box VPP disabled Internal APE Phone VPP Enabled PAPUBKEYS Hash for APE: 9C5EA53A1F6DBD7DF955715E780159991B4B6EA4 Flashbus Write baud set to 5.0Mbits Storing NPC... Storing CCC... Storing HWC... Storing VARIANT... Processing APE Part... Storing Product Code... Storing PSN... Storing HWID... Storing NPC... Storing CCC... Storing HWC... APE VARIANT Not Found Restarting MCU... RPL Saved OK BB5 Unlock Started... MCU Version V 06wk41v51.3 MCU Date 13-02-08 Product RM-320 Manufacturer (c) Nokia IMEI 359542016816710 Mastercode 5335363561 Simlock Server SIMLOCK SERVER Simlock Key 5050600042465540 Simlock Profile 0000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 50506F Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 50599F Simlock [3,1] State: CLOSED Type: MCC-MNC Data: 50506F Simlock [4,1] State: CLOSED Type: MCC-MNC Data: 50599F Simlock [5,1] State: CLOSED Type: MCC-MNC Data: 00101F Simlock [6,1] State: CLOSED Type: MCC-MNC Data: 00101F Reading Security Block... Security block OK and saved to "RM-320_359542016816710_842010_101746 AM.SecurityBlock.PM" "0F60001937BE00581D6EAC5666A972B8CC39E794.C0000366" Exists, That is good... Checking for Rootkey Hash support with selected Unlock Method... Selected Unlock Method: RPL Calculation Asking box to calculate RPL... Received RPL from Box OK! Writing Simlock... Simlock ACCEPTED OK ! MCU Version V 06wk41v51.3 MCU Date 13-02-08 Product RM-320 Manufacturer (c) Nokia IMEI 359542016816710 Mastercode 5335363561 Simlock Server SIMLOCK SERVER Simlock Key 2440700000000000 Simlock Profile 8000000000000006 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [1,2] State: OPENED Type: GID Data: FFFF Simlock [1,3] State: OPENED Type: GID Data: FFFF Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [2,2] State: OPENED Type: GID Data: FFFF Simlock [2,3] State: OPENED Type: GID Data: FFFF Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [3,2] State: OPENED Type: GID Data: FFFF Simlock [3,3] State: OPENED Type: GID Data: FFFF Simlock [3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [4,2] State: OPENED Type: GID Data: FFFF Simlock [4,3] State: OPENED Type: GID Data: FFFF Simlock [4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [5,2] State: OPENED Type: GID Data: FFFF Simlock [5,3] State: OPENED Type: GID Data: FFFF Simlock [5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [6,2] State: OPENED Type: GID Data: FFFF Simlock [6,3] State: OPENED Type: GID Data: FFFF Simlock [6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [7,2] State: OPENED Type: GID Data: FFFF Simlock [7,3] State: OPENED Type: GID Data: FFFF Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Unlock finished! Time taken 3.656s Last edited by ptt; 08-04-2010 at 11:21. Reason: add code tag |
POST HERE all Successfull Report with Micro-Box, HTC cable, etc.. | hitibiti | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 2837 | 07-05-2020 10:10 |
Put in this thread all successfull story of Dct4 Imei???? with Mxkey | mobilecitycbk | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 06-17-2009 21:28 |
Put in this thread all successfull UNLOCK AND NOT with Cyclone-box | FullFLASHgSMPH | Cyclonebox | 2 | 04-13-2009 14:00 |
