01-28-2010, 18:39 | #1 (permalink) |
Registered User Join Date: Feb 2004 Location: morocco Age: 52
Member: 54024 Status: Offline Thanks Meter: 34 | usb supply voltage test failed 4.02v box has failed one or more self diagnostics.this maybe temporary failure or permanent hadware damaged. box self test failure usb supply voltage test failed 4.02v is out of valid range thanks in advance. |
01-28-2010, 19:07 | #2 (permalink) |
Freak Poster Join Date: Dec 2006
Member: 417512 Status: Offline Thanks Meter: 46 | This is a problem with your USB port, or you have you phone conected, maybe is a laptop? You can try: 1. Connect to other usb, 2. connect and disconnect and try again 3. use a power HUB. 4. Connect only box and star the program. BR |
VBAT Supply Voltage test failed!? | hrco | Cyclonebox | 10 | 03-22-2010 14:45 |
Help, USB suply voltage test failed. | ELWAN | Cyclonebox | 19 | 12-09-2009 18:43 |
Box Selftests Failed -> VBAT Supply Voltage test failed, 4.17v is out of valid range | kosta25 | Cyclonebox | 2 | 11-04-2009 13:40 |
Box Selftests Failed -> VBAT Supply Voltage test failed, 4.08v is out of valid range | azad4u | Cyclonebox | 7 | 07-08-2009 14:48 |
DCT3-4 Power supply voltage emissions values | BesTCooL | Nokia Hardware & Hardware Repair | 2 | 03-30-2005 03:57 |
