Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 12-14-2008, 08:10   #31 (permalink)
GSM WIZARD's Avatar
Member: 217604
Thanks Meter: 12
can anyone help me with iphone 2g charging problem?my iphone cant charge and is not detected on computers.help me direct me what to do guys.
The Following User Says Thank You to GSM WIZARD For This Useful Post:
Old 12-15-2008, 00:37   #32 (permalink)
Member: 261323
Thanks Meter: 3
Originally Posted by lxa786 View Post
Turbo sim card wont work (iphone 3g) with 2.2 please need help what should I do? i did downgrade 2.0.1 but didnt get any signal no network?
please help me out
You downgrade the iPhone firmware but not the the modem firmware. it is 2.28.xx instead of 2.01.xx
You should try a universal sim which is 2.2 capable.
Thanks!
Old 12-15-2008, 01:09   #33 (permalink)
Member: 50272
Thanks Meter: 37
All tested, 3 different pc and each pc different version of itunes
i will test with any other usb cable but this cable i use everyday for other iphones..
i will test with other usb cable.
Originally Posted by malikkk View Post
use DFU MODE for restore
0R
upgrade itune
reinstall itune
change usb cable or usb port
restart pc
change pc
Old 12-15-2008, 19:38   #34 (permalink)
udai's Avatar
Member: 4798
Sonork: 100.1617239
Thanks Meter: 5
@mobitech service...friend i have no light in my lcd...lcd ok..i checked...water piece...board problem...any ways fr lighting...thanks
Old 12-15-2008, 20:00   #35 (permalink)
cdma-india's Avatar
Member: 98139
Thanks Meter: 126
i have iphone 2g having problem of battery storage, change 3 battery same , no water damage
any solution
Old 12-16-2008, 08:39   #36 (permalink)
Member: 63691
Thanks Meter: 114
please help me out
torbo-sim won't work for 3g,use universal sim,its good
Old 12-16-2008, 08:42   #37 (permalink)
Member: 63691
Thanks Meter: 114
which lcd,iphone 2g or 3g
Old 12-16-2008, 08:47   #38 (permalink)
Member: 63691
Thanks Meter: 114
any solution
it is not the problem of battery,where there is low network the battery gets discharged.in china iphone battery gives 2-3 days backup and in some contries it is 20 hours backup,update to 2.2 it will fix to some extent.
Old 12-16-2008, 08:53   #39 (permalink)
Member: 63691
Thanks Meter: 114
change the charging connector,there may be some liquid in the inner portion of the c/c
Old 12-17-2008, 09:22   #40 (permalink)
Member: 372599
Thanks Meter: 41
hi.. i have Iphone 3g 16GB.. first i had problem of no sim card inserted.. i upgrade software now it accepet sim card but there is no service.. can u help me please..
Old 12-17-2008, 16:48   #41 (permalink)
Member: 712684
I have a problem with an iphone 2g, it was charged with an chinese charger and when I try to connect him to the computer was not reconized by him, I try to connect him with 2 difrent original cables but noting, so I tod that the charging connector is the problem I open the iphone change the conector but still noting, before using the chinese charger it works fine, had someone this problem til now? Can you help me fix it?? Any sugestion can be useful.
Old 12-17-2008, 17:09   #42 (permalink)
Crazy Poster
Member: 39468
Originally Posted by dienson View Post
Hi bro
I have 3G iphone AT&T, V2.1, Jail break = Quickpwn
I used unlock sim GEVEY-3G, all are okie,
just when plug iTunes to sync, always say "the sim card inserted in this iphone does not appear to be supported
can you help me to pass this problem
thank you
Dienson
just put it in flight mode and connect 100% works
Old 12-29-2008, 13:45   #43 (permalink)
Member: 801383
Thanks Meter: 35
iphone lcd replacment
Hi lads i wondering if you can help me with iphone 3g lcd replacment
I need to know if is possible to change only touch part <lens> because lcd is ok ...
Br dawid
Old 12-30-2008, 01:48   #44 (permalink)
Member: 714081
Thanks Meter: 8
no sim accepting
i have 3g iphone with universal sim ,its working for fido but when i insert other fido sim its not accepting.plz help me solve this problem
The Following User Says Thank You to celltech01 For This Useful Post:
Old 12-30-2008, 04:10   #45 (permalink)
ll1221's Avatar
Member: 157800
Thanks Meter: 32
In China already someone or other a 3 Gs 2.2 of the solution locks, after he is the edition of Hong Kong, at also have no the network target!!!!!!!!!
The Following User Says Thank You to ll1221 For This Useful Post:
All Blackberry Hardware and Software Solution youssef01 BlackBerry (RIM) 34 11-01-2012 17:31
I need DVD player hardware and software solution site ..::MOBILES::.. GSM Mobile Links 0 04-05-2009 15:49
O2 Hardware and Software solutions Eagle7 Various 2 04-14-2006 12:47
Page generated in 0.20725 seconds with 10 queries
