Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 09-22-2010, 12:47   #751 (permalink)
Member: 1278248
Hi
I have 2 iphone 3gs 16gb.
First problem is Not charging After Water Damage. Every thing else works Fine. I replaced The battery which was fully charged Any solution for it.
Second no display after water damage it dose sync with itunes. But no display.
Best regards
Zeeg
Old 09-22-2010, 13:21   #752 (permalink)
Member: 656489
Thanks Meter: 4
Hello
I have received a 16GB Iphone 3G that sometimes the screen goes blank and sometimes nothing comes on screen.
The phone makes its function, because itunes recognizes it, it vibrates.
But nothing comes on screen.
What could be?
Thanks
Old 09-22-2010, 14:42   #753 (permalink)
Member: 237670
Sonork: 1604787
Thanks Meter: 13
hi
Originally Posted by mobitech servic View Post
the end pin is gnd,and the other ur getting gnd is due to capacitor damage,just remove the pin linking capacitor.
can show me on the picture sir...
Old 09-22-2010, 21:41   #754 (permalink)
Member: 968616
How to know that Iphone is blocked by operator ? is "No Service" can be issue of IMEI blocked?
What comes on write on blocked iPhone when instert sim card?
Old 09-23-2010, 00:04   #755 (permalink)
Member: 201316
Thanks Meter: 34
Originally Posted by Benalchi View Post
Hello
What could be?
Thanks
change speaker flex sometimes it happen bcoz of it
Old 09-23-2010, 11:11   #756 (permalink)
Member: 1328701
i want to download winterboard via cydia but everytime i try to dwnld it cannt connect with saurik.pls advise.
i jailbroke my iphone 3gs with hackhullos
Old 09-24-2010, 06:13   #757 (permalink)
Member: 558946
Thanks Meter: 2
Originally Posted by nitant View Post
I have a small problem. Whenever my iPhone 3G goes to sleep, it will just shut off. Wont come back on. I have to hold home and power for 10 secs to revive it. This problem will not happen if connected to charger/USB.
This had been dropped from height and thus this happened. Any solutions?
I fixed this problem. The phone used to just reboot as soon as I switched on the camera. I removed the camera and the shutdown problem went away. Go figure.
Old 09-24-2010, 21:59   #758 (permalink)
Member: 819111
Question Dfu stuck
Hello
my iphone stuck in DFU mode not restoring even to 4.1 my iphone have 4.0.1
the itunes shows me the error 28, and while I restore to any version the iphone screen changes to yellow, please help me??
my iPhone is 3GS 32GB.
Old 09-24-2010, 23:33   #759 (permalink)
Crazy Poster
Member: 1318122
Thanks Meter: 37
Flickering Brightness
I have a 3g that flickers in brightness. It was water damaged, but I have cleaned the board well, and all other functions of the phone are OK.
Does anyone where the brightness control comes from or goes to? (it is a software function, but it is digitally programmed to a voltage converter or analog level control line to converter?)
I have tried a different LCD display module, same result.
Old 09-25-2010, 13:45   #760 (permalink)
Member: 1402064
Thumbs up Found Iphone 3Gs
I would like to know whether or not, is it possible to un-block iphone so that I could get a service from any network? I have unlocked and jailbroke, but it appears O2 may have blocked the imei. Is there anyway possible to over come this problem? change imei or something! Thanking you in advance.
Old 09-27-2010, 13:40   #761 (permalink)
JUGNUGSMLAB1's Avatar
Member: 667762
Sonork: 100.1576963
Thanks Meter: 9
brother i have iphone 3g charging not save
plz help me
Old 09-28-2010, 11:09   #762 (permalink)
Member: 1319763
iphone only bsnl network alows please help
i have iphone 3g 8gb .Only bsnkl sim card network is alows please help if u have any solution
Old 09-28-2010, 23:19   #763 (permalink)
Member: 1183523
MYWI 4.0
HI,
I have installed mywi 4.0 for the iphone 3gs is04 but when i try to view youtube pages it opens up the mobile website and wont play videos???????
please can somebody help?
Old 10-02-2010, 18:25   #764 (permalink)
Member: 1408599
We're sorry, the iphone you connected is not recognized and cannot be activated
after i did update by itunes>> my iphone just let me to call only i have not main menu only message in many languages and on the top of screen there is emergency call and under that the numers board only .. i can recieve call and dialing but when i try to restore the firmware by connected usb to itunes i see this message :
We're sorry, the iphone you connected is not recognized and cannot be activated for service. We recommend you visit your nearest apple store
plzzzzz help me ...
model:A1203
serial no:7R728KKXVRO
Old 10-02-2010, 18:58   #765 (permalink)
Member: 969953
Thanks Meter: 3
iphone 4 inster sim
i have iphone 4 which is cracking my head with insert sim problem, sometimes it works fine, and sometimes it shows insertsim card, so i have to pull out my sim and put it back, and it work for maybe 5mins or sometimes 1hour, i have changed may sim cards. but same.
All Blackberry Hardware and Software Solution youssef01 BlackBerry (RIM) 34 11-01-2012 17:31
I need DVD player hardware and software solution site ..::MOBILES::.. GSM Mobile Links 0 04-05-2009 15:49
O2 Hardware and Software solutions Eagle7 Various 2 04-14-2006 12:47
Page generated in 0.29474 seconds with 10 queries
