continuity green fuse. http://img854.imageshack.us/img854/9...erycompone.jpg By wites13 at 2011-10-25 |
Components are all there and OK. Battery is draining very fast. When charger connected PMIC is getting very hot.:eek: |
If short,remove black diode & check again. |
PMIC still getting hot, and the voltage on the diode is only 1.2V. ?? When diode removed this is also only 1.2V |
replace PMIC! i can do this! |
Can you also supply the chip so i can put it in myself |
yes, i have good chips. i can give you a trustable adress, most chips are fake on the market i know..... seller msn: [email protected] his name is tyson. tell him that you know him from me, my name is Matthias. |
Bro Matthias is right. |
Any Solutions for greyed Wi-Fi in 3GS? (Water Damage).....+4V are ok on Wi-Fi Module.... |
Voltage or CLK problem. |
Located between the module and the 2 coils |
@wites: 1.8V (VSD2) comes from BB-PMU and this is ok. The VSD2 is only a pullup voltage for some signals i think, not? L15 and L20 is this for internal Power-Supply from the WLAN-Module? @X10robin: I checked this parts already....there is all ok, i know this problem also. Fact is: The WLAN-Module becomes +BAT Voltage (about 4V). i see some corrosions on the WLAN-Board, but not that strong. Maybe bad solders under a Chip on the WLAN-Module?? |
I just send him an email. |
other prbolem: iPhone 4: All sounds are very loud biased (sounds like too high gain). when i reduce volume becomes better, but still biased. when i connect earphone, the same there. when i try to make a call, the mic makes a backcoupling and i hear only a loud beeeeeeeeeeeep. in the earphone also the same! it was an water damage. i removed the metal shield around the NAND-Flash for cleaning. before i had no backligt, sound was ok i think, i can't say! which ic should i try to reball first?? what can that be? if somebody can help me, you get my greatest respect!!! |
hi, i was updating my iphone on itune the suddenly it battery gets low n it turned off , now the situation is when i put it on charging it charge for 3to 4 but still battery low show itune cable sign n when it wanted to restore it in this condtion it turned off again saying battery low , i changed the dock and the cable but still same i even chaged the battery but no use |
