ipod 4 restore error 3194 in all files any solution [email protected] plllzzzzzzzzzzz mail us THANKS in advance.............::confused::confused::confused ::confused::confused::confused::confused::confused ::confused::confused::confused::confused: |
If you're not sure download tiny umbrella from here Once downloaded connect your ipod to the pc and open the tiny umbrella application (you need java installed first) Then go to advnaced and tick request SHSH from cydia checkbox Then push save SHSH. This will show you what firmwares you are eligible to restore to |
Hey Wites, I have this rather odd problem on an iPhone 3GS. It only powers on using usb (either connected to PC or wall charger) but doesn't power on on battery When it powers on will restart every 10 seconds. If you try to restore the phone gives error 20 but this is not important for now I think. I checked continuity on Battery Fuse (R35) and it shows closed however on top of the fuse was missing C11 (27pF) I replaced it, on schema it looks like it's coming from Batt SWI line? Nothing is getting hot (I checked with lips the SMP3i and PMIC) Any ideas? |
Phone not see battery,is battery charged? How much omh show fuse? Check between Vbat and GND if not short. |
Here are the answers: Battery fully charged shows 3.9V Fuse show 0.03 ohm And vbat to gnd not shorting Red vbat, black gnd: 1750ohm Black vbat, red gnd: 450ohm Yes the phone is sort of not seeing the battery, as I said capacitor C11 on battery SWI line was missing but now I replaced with a 27pF Cap Some more checks: No cracks and no heat and no water corrosion All quartz seems soldered good Should I check with power supply for any current? |
Can you show please what cap you replaced? |
1 Attachment(s) Quote:
Attachment 1 shows the C11 capacitor replaced (it is not soldered straight but the connection is good checked with fuse and TP43) |
Check with battery if at fuse present 3.7V. |
But I checked with multimeter both testing batteries and they are showing 0.09V :confused:. Could you please show me how to charge with the dc power supply? Also when tried to put now again the logicboard back into the case and tightened the battery screw of the board white smoke came out:confused: Did it fry the C11 capacitor since now it is shorting |
What screw you tighten show please? Remove cap is not needed. |
The short happened because for some reason the vbat and gnd board terminals are shorting (0 ohm). (The vbat and gnd werent shorting before I tried to charge the battery) Any idea how to remove short between vbat and gnd? What could have gone wrong during charging? I made sure not to exceed 3.7V |
I told remove that cap if short remain search for heat. And don't solder back any cap. |
The cap is removed but short still remain on the cap solder prints even on the vbat and gnd terminals. Also short between both green fuse terminals and gnd :confused: does this mean fuse dead? I noticed heat near the battery terminals Please tell me that the board is not dead completely :( |
I hope its not a burnt SMP3i IC? :confused: What should I set maximum current (Amps) on the power supply? |
