10-20-2015, 18:41 | #5446 (permalink) |
Junior Member Join Date: Oct 2009
Member: 1139080 Status: Offline Sonork: juniorr Thanks Meter: 1 | however the iPhone only boots up to the apple logo and then black screen I've taken the motherboard out and put it in a new casing and still same thing how can i fix this replace ic ship ?? also i have a iPhone 5s that appears to be dead no sing of life until you put it to iTunes even if you disconnect battery iTunes sees it ....? and it does a full restore successfully but is instantly in recovery mode again after no errors I've tried du mode and tinny umbrella no luck think it ay have to do with missing shsh blobs i done any suggestions thanks guys in advance pm me please and thank you to NYONE WHO CAN HELP ME |
10-23-2015, 09:23 | #5449 (permalink) |
Junior Member Join Date: Aug 2014
Member: 2240605 Status: Offline Thanks Meter: 0 | hello sir im new user of apple...and i have a problem about my iPhone 5...there is no earpiece...i already replace the charging pin...the earpiece..but still there is no response |
10-23-2015, 11:45 | #5450 (permalink) |
Junior Member Join Date: Oct 2015 Location: china,europe
Member: 2470111 Status: Offline Thanks Meter: 3 | hello every one.i have iphone 6 plus .i changed display .but after that no phone power on only vibrate 4 sec and vibrate 4sec..please help me any advanced person. |
10-25-2015, 22:22 | #5456 (permalink) | |
No Life Poster Join Date: Mar 2012 Location: Amsterdam, Netherlands
Member: 1732818 Status: Offline Thanks Meter: 532 | Quote:
There are a few ways to check and fix the problem Here is one of them.. Search in the forum for the rest http://forum.gsmhosting.com/vbb/f631...ne-4s-1713522/ | |
10-25-2015, 22:27 | #5457 (permalink) | |
When you mix the screws up, you damage the board under the screw hole. It will Shortcut the board and damageing the tracks under there. If you are lucky, your phone will start when you take out the screws. | |
10-26-2015, 01:16 | #5458 (permalink) |
Junior Member Join Date: Oct 2015 Location: Miami,FL
Member: 2477961 Status: Offline Thanks Meter: 0 | LCD refurbishing Hello and thank you for your help!! I started an small LCD refurbishing business and after so many trial and error I am heading into the right direction to have a good understanding on how to do this the right way, however I still have a few issues that I just can't figure out what I am doing wrong, allow me to post this one for now... When I remove the glass on the LCD, I usually try to remove the rest of the Glue from the LCD and when I scratch the polarizer I removed it, but then I have the painful task of cleaning the LCD and here is where my problem is, regardless I do my best not to press the LCD too hard during my cleaning process sometimes after cleaning and testing everything is ok with the polarizer I realized I have some marks on the LCD, I don't know how to explain myself correctly when I say "marks" but it seems to me that maybe some of the dissolver gets between the LCD and the backlight, I don't know if this makes sense but I really don't know what I am doing wrong, please help me.. Thank you. PS: Any suggestion on a good OCA cleaning liquid??? Last edited by roanchasan; 10-26-2015 at 01:18. Reason: Forgot something. |
10-26-2015, 11:15 | #5459 (permalink) |
Member: 2478113 Status: Offline Thanks Meter: 0 | iPhone 4S WiFi greyed out bad component ? Help I have an iPhone 4S the WiFi is greyed out And no mac address but the bluetooth have address I tried reflowing the ic I need help fixing it should i reball it or change it to a new one please help picture with explanation message me on gmail samsamhightech then add at gmail dot com I have VBAT 3.7v but no reset its 0v instead of 1.8v and the white compnent is missing the one with three pins under it |
All Blackberry Hardware and Software Solution | youssef01 | BlackBerry (RIM) | 34 | 11-01-2012 17:31 |
I need DVD player hardware and software solution site | ..::MOBILES::.. | GSM Mobile Links | 0 | 04-05-2009 15:49 |
O2 Hardware and Software solutions | Eagle7 | Various | 2 | 04-14-2006 12:47 |
