10-29-2015, 00:24 | #5463 (permalink) |
Junior Member Join Date: Oct 2015
Member: 2479385 Status: Offline Thanks Meter: 0 | i phone woes i have a iphone 5c that has the screen not completely seated in the case of phone and when i try to swipe to turn on sometimes it wont work and also if trying to do something like type it just sterts adding random letters or may change to different sub pages like from general to sounds in settings on its own . |
11-02-2015, 00:33 | #5464 (permalink) | |
No Life Poster Join Date: Mar 2012 Location: Amsterdam, Netherlands
Member: 1732818 Status: Offline Thanks Meter: 532 | Quote:
Its better to replace the IC. You can heat it from under the board at 400 degrees celcius. Lift the ic slowly with a small knife blade. No need to remove all the black. Just make sure there are no hills. | |
11-02-2015, 07:36 | #5465 (permalink) |
Insane Poster Join Date: Mar 2014 Location: Cambodia
Member: 2157777 Status: Offline Thanks Meter: 4 | iPhone 6+ Grayed Wifi iPhone 6 Plus have wifi MAC Address but it show gray color can't turn on i was change IC WIFI already but still not work please Kindly help thank all mate |
11-02-2015, 08:55 | #5466 (permalink) |
Junior Member Join Date: Nov 2013
Member: 2061671 Status: Offline Thanks Meter: 0 | Removed Wifi IC Chip the IT guy has removed my iphone 4s wifi IC as it was not working.. Now i am unable to use WIFI. Is it possible that i can get a new Wifi chip and paste it myself? or any easy to apply technique.. pls help |
11-03-2015, 18:47 | #5467 (permalink) |
Junior Member Join Date: Jun 2015
Member: 2416265 Status: Offline Thanks Meter: 0 | Hello, I have a problem with an iPhone 6 (a1549 64g). The display shows purble horizontal lines on the screen, but the display works fine (I test it in other iPhone 6). The device don't show trace of wet or hits. Thank you! |
11-04-2015, 23:15 | #5469 (permalink) |
Junior Member Join Date: Nov 2015
Member: 2482595 Status: Offline Thanks Meter: 0 | iphone 5 : reboots when syncing or trying to backup Whenever i try to update or backup the phone , it reboots. at first the screen fades into green or red or what not color. and then goes black - and the phone restarts. (I have a video of it on youtube, but can't link cause i'd need more forum points) It doesn't matter if i backup using the lightning cable, or over WiFi. I replaced the display since the glass was cracked. but I had the same problem before. Interestingly I managed to download iOS 9 without a single reboot (which took more than an hour), but when i try to install it , the phone dies after some 15 seconds. any clue what could be the reason? |
11-05-2015, 18:02 | #5470 (permalink) |
Freak Poster Join Date: Aug 2012
Member: 1796533 Status: Offline Thanks Meter: 18 | I Have iPhone 4 working Good On Itunes There Are Charging Sound When I Plugin I Try Restore It Restored 100% And Replace Screen The Screen Is Black There Are No Thing And Iphone Is Work What I Do ???? |
11-06-2015, 16:53 | #5472 (permalink) |
Junior Member Join Date: Sep 2014
Member: 2255949 Status: Offline Thanks Meter: 1 | hello, i have several iphones 6 that continuously fall to itunes with error 53, this is because they all have non-native touch id button, only one iphone 6 has been repaired by changing touch id button. I am confused, can someone please provide an explanation? |
11-07-2015, 22:17 | #5473 (permalink) | |
Itunes will show error 53. In other words. Your phone will never work again. There is no way to go around this check. Best thing is to put the original button and screen back and bring it to the official apple store and let them replace it. | |
11-14-2015, 11:53 | #5474 (permalink) |
Member: 2486767 Status: Offline Thanks Meter: 0 | I have a good condition iphone 6 that has water damaged and will not power up no more. I have done everything I can to bring it back but I am afraid the logic board is garbage. I am going to try and replace the IC power supply chip to it and see if that will do the trick. If that doesnt work I will need to replace the whole logic board. Can this be done on the iphone 6? I read that I need to remove 3 chips of the old board and put them on the new board. Can anyone confirm this please and if so what are the chips called that I need to remove? |
11-14-2015, 14:10 | #5475 (permalink) | |
No Life Poster Join Date: Mar 2012 Location: cambridgeshire, England Age: 55
Member: 1728699 Status: Offline Thanks Meter: 212 | Quote:
All Blackberry Hardware and Software Solution | youssef01 | BlackBerry (RIM) | 34 | 11-01-2012 17:31 |
I need DVD player hardware and software solution site | ..::MOBILES::.. | GSM Mobile Links | 0 | 04-05-2009 15:49 |
O2 Hardware and Software solutions | Eagle7 | Various | 2 | 04-14-2006 12:47 |
