11-15-2015, 14:49 | #5476 (permalink) |
Registered User Join Date: Feb 2008 Location: India
Member: 714467 Status: Offline Sonork: 100.1641520 Thanks Meter: 46 | IPhone 5 LCD Blue problem i got iphone 5 lcd broken condition i changed lcd set is file and try to refix lcd its show apple logo and came blue screen or red screen and getting restart i changed 5 more lcd same even same issue came in orginal lcd also experts plz help me Br Edward C |
11-20-2015, 23:16 | #5479 (permalink) |
Freak Poster Join Date: Mar 2008 Location: India, Punjab, Phagwara
Member: 731127 Status: Offline Thanks Meter: 26 | my iPhone 5 stuck in black screen & shows iPhone detected ad recovery mode in iTunes. when tried to restore it its stuck in waiting for iPhone. tried power + home button but none worked. |
11-21-2015, 22:37 | #5481 (permalink) |
Junior Member Join Date: Dec 2010
Member: 1480729 Status: Offline Thanks Meter: 0 | Iphone 6 NO DETECT DISPLAY (LCD) First the cases fell into the infinite loop and restore with iTunes and out of the problem. Then I wanted to build it on and the screen gave no picture or video, and connect it to itunes detects and sincoriniza, means that if this power correctly. in short, it does not detect or does not display video. HELP ME!! PLEASE PD. check connectors and LCD touch, also tried with other screens. |
11-22-2015, 22:53 | #5482 (permalink) |
Junior Member Join Date: Nov 2014
Member: 2296057 Status: Offline Thanks Meter: 1 | I have an iphone 6 with an icloud lock on it. I can not pay for icloud remove because it has a lost imei. Someone told me that by switching out the logic board I erase the icloud lock... IS this true or do I also have to switch the chips.? |
11-23-2015, 09:27 | #5484 (permalink) |
Junior Member Join Date: Nov 2015
Member: 2490750 Status: Offline Thanks Meter: 0 | I fix phones for money. it's my business. I had a customer with a broken iphone 6 screen. I moved the home button and camera to new lcd and connected that lcd to phone making sure all the cables were connected correctly and for some reason digitizer was not working. I disconnected and reconnected cables again, turned phone off and back on a couple of times, and even disconnected and reconnected battery. The weird thing is digitizer would work at first when I did those actions but then it would stop working seconds later. I though that it was a bad lcd so i tried a different lcd and still had same problem. Even put on first broken lcd back and digitizer was still not working. Everything else was working fine. if the problem is not with the LCD part, then what is it? |
All Blackberry Hardware and Software Solution | youssef01 | BlackBerry (RIM) | 34 | 11-01-2012 17:31 |
I need DVD player hardware and software solution site | ..::MOBILES::.. | GSM Mobile Links | 0 | 04-05-2009 15:49 |
O2 Hardware and Software solutions | Eagle7 | Various | 2 | 04-14-2006 12:47 |
