06-19-2016, 16:45 | #5748 (permalink) |
Freak Poster Join Date: Jan 2008 Location: punjab ,jalandher
Member: 672494 Status: Offline Thanks Meter: 109 | iphone 6 puls not charging when its on its charging only that time i put it off any idea..???????????????????????????????????????????? ????????????????/ |
06-20-2016, 10:56 | #5750 (permalink) | ||
Freak Poster Join Date: Mar 2013 Location: Greece Age: 35
Member: 1903358 Status: Offline Thanks Meter: 146 | Quote:
FL12??? Where is those components? Read schematics before post. You need check first of all the backlight filters, FL4211-FL4212-FL4213 Next C4211-C4212-C4213 Next check the two diodes D4020-D4021 Next Resistant L4020-L4021 Next C4022-C4023 Next U4020 | ||
06-25-2016, 17:55 | #5757 (permalink) |
Junior Member Join Date: Feb 2011
Member: 1524789 Status: Offline Thanks Meter: 0 | Hello, I have a 6 Plus with iTunes error 21. The phone had the screen replaced & no water damage & Date/Time settings are correct. I've done the following: - Replaced battery & tried to restore...same result - Replaced screen & tried restore...same result - Put mobo in good housing (for different dock port flex)...same result So with mobo in different housing & different screen...I believe it's a hardware issue isolated to mobo. Could this be a U2 issue? If you could help point me in the direction of what ic or component might be causing it, that would be much appreciated. |
06-28-2016, 15:33 | #5759 (permalink) |
Junior Member Join Date: Jun 2016
Member: 2582471 Status: Offline Thanks Meter: 0 | i mistakenly removed a small ic components on a lumia board during jumpering. this nonetheless is causing a malfunctioning in the network. is it possible to fix back the ic and how |
All Blackberry Hardware and Software Solution | youssef01 | BlackBerry (RIM) | 34 | 11-01-2012 17:31 |
I need DVD player hardware and software solution site | ..::MOBILES::.. | GSM Mobile Links | 0 | 04-05-2009 15:49 |
O2 Hardware and Software solutions | Eagle7 | Various | 2 | 04-14-2006 12:47 |
