04-23-2019, 22:47 | #3 (permalink) | |
No Life Poster Join Date: Oct 2010 Location: .::: Madina :::.
Member: 1427732 Status: Offline Sonork: ˙·٠•● Thanks Meter: 1,061 | Quote:
Iam trying to flash with sony flash tool flashing start 2sec and stop after that cell gone sleep When i put charger pin cell show just red light blinking trying to again flash but flashing not start When i put usb cable in device manager show unkown device | |
04-24-2019, 07:41 | #4 (permalink) | |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
The Following User Says Thank You to layder For This Useful Post: |
04-24-2019, 08:18 | #5 (permalink) | |
Code: RUNNING v 1.1433/01.15/UNI CARD SERIAL xxxxx USBFLASH DRIVER VERSION 03.02.00.00 CFG:000000000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ... S1BOOT NOT DETECTED FAILED TO SETUP PHONE Elapsed: 5 seconds | |
04-24-2019, 08:27 | #6 (permalink) |
No Life Poster Join Date: Aug 2011 Location: bagmati pradesh
Member: 1626780 Status: Offline Thanks Meter: 1,275 | g series cannot be repaired by setool according to the_laser Code: - added support for boot recovery of MT6582,MT6732,MT6735,MT6752,MT6755,MT6795-based phones this is all sony MTK-based models, except G-series instructions : install latest usbflash drivers ( ggsetup-3.1.0.11.exe ) select proper phone model, add to FW area required firmware, check signed mode + altbypass, press "flash" if phone has damaged boot, just connect phone and press "ready", setool2 will do all other job if phone has damaged security units or "stucked" boot ( no device appears, when phone connected to PC ) - you need to open phone, connect testpoint to GND, connect USB cable to PC, release testpoint and then press "ready" |
The Following User Says Thank You to malka4u For This Useful Post: |
04-24-2019, 08:32 | #7 (permalink) | |
you can share test point picture plz Last edited by ::SYED MOBILE::; 04-24-2019 at 08:39. | |
