g7102 network problem after imei repair [Solved] Welcome to Octoplus/Octopus Box Samsung software version 1.7.5 ----------------------------------------------------------------------------------- To connect GT-I9505 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G7102 Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-G7102 Firmware compiled date: Tue Dec 16 18:46:16 KST 2014 PDA version: G7102ZTUANL1 CSC version: G7102ZZTANL1 SW version: G7102ZTUANG1 Phone IMEI: Unknown Android version: 4.3 (JLS36C) Checking Root: Phone is Rooted. Old IMEI: Unknown New IMEI: 352309-06-126655-6 Repairing IMEI A... Phone will restart now IMEI successfully repaired. Please, restart the phone to apply changes ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G7102 Detected phone model: SM-G7102 Firmware compiled date: Tue Dec 16 18:46:16 KST 2014 PDA version: G7102ZTUANL1 CSC version: Unknown SW version: G7102ZTUANG1 Phone IMEI: 352309061266556 Phone SN: 00000000000 Android version: 4.3 (JLS36C) Checking Root: Phone is Rooted. Old IMEI: 352309-06-126655-6 New IMEI: 352310-06-126660-4 Repairing IMEI B... Phone will restart now IMEI successfully repaired. Please, restart the phone to apply changes no network only no service help me |
At first, install the latest Software version (http://octoplusbox.com/en/download/software/). If You want to write any IMEI, do the next: 1. Make Factory data reset and wipe cache partition. 2. Install the latest Software version (Software). 3. Root the phone. 4. Write the special firmware from the Support Area ("sm-g7102_special_modem_to_repair_any_imei_4_3"). 5. Ennet IMEI and repair it. 6. Post here full Software log with all of these actions. Also, You can try to write Cervices IMEIs from the Software list. The procedire is the next: 1. Make Factory data reset and wipe cache partitoin. 2. Write firmware ("SM-G7102_for_Unlock_and_Repair_IMEI_4.4.2.oct") from the Support Area. 3. Select service IMEI from the Software list. 4. Connect powered-on phone to PC via USB cable. 5. Install the necessary driver. 6. Click "IMEI fix" button. 7. Follow software instructions (prompts). Also, if You have IMEI Certificate for this device, You can write it. Look here: http://forum.gsmhosting.com/vbb/f684.../#post10690374, http://forum.gsmhosting.com/vbb/f684.../#post10690142, http://forum.gsmhosting.com/vbb/f684.../#post10756089, http://forum.gsmhosting.com/vbb/f684.../#post10742528, http://forum.gsmhosting.com/vbb/f684.../#post10724579. |
again restart and stuck i do wipe again but not success plz help |
Try to write firmware "SM-G7102_for_Unlock_and_Repair_IMEI_4.4.2.oct". |
----------------------------------------------------------------------------------- To connect SM-G7102 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM280 Selected model: SM-G7102 Reading info... Mode: Normal Firmware compiled date: Jun 03 2014 Firmware compiled time: 00:00:00 Firmware released date: Jul 19 2014 Firmware released time: 00:45:25 SW Version: M8626A-AAAANAZM-1.0.4061 Send SPC... SPC send successfully Writing QCN... Writing NV items... NV items write successfully Writing NV SIM1 items... NV SIM1 items write successfully Writing NV SIM2 items... NV SIM2 items write successfully Wrting EFS... EFS write successfully Writing provisioning items... Provisioning items write successfully. Writing QCN done QCN write successfully Please, restart the phone to apply changes successfully repair thanks octopus great team great work |
