04-21-2014, 11:48 | #18 (permalink) |
Freak Poster Join Date: Mar 2014
Member: 2157134 Status: Offline Thanks Meter: 8 | Ok I got it unlocked the N900T,, Now How can I add a new imei without using the service imei drop down selection.. Plus if I change the imei will the unlock go away.. Sent from my iPhone using Tapatalk Last edited by mrdnice88347; 04-21-2014 at 14:05. |
04-21-2014, 16:10 | #19 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,420 | Quote:
04-22-2014, 07:05 | #25 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,420 | @ ernietech To connect SM-N900T, do the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software and post here Software log with this info. |
04-22-2014, 15:31 | #26 (permalink) |
Junior Member Join Date: Dec 2009
Member: 1179274 Status: Offline Thanks Meter: 1 | fallow instructions that's I I hear listen the question is on the not 3 n900t how to put diag option on thas what the instruction say but on tmobile n900t 4.3 *#9090# its not supported any options to change that ..... so I did the steps now I have 2 notes /00 imei... |
04-22-2014, 15:43 | #27 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,420 | Carefully and attentively perform all the steps 1-10 to connect the phone. Then write here, what device appears in PC Device Manager, when You perform these steps and connect the phone to PC. Look, whether You have installed driver for this device. Also look here: Samsung SM-N900T Unlock with Octoplus Box - YouTube. |
05-03-2014, 07:35 | #30 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,420 | @ mrdnice88347 Yes, You can write any service IMEI from the list for this device and the phone will remains unlocked. |
