Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus Samsung/Octoplus Samsung
Old 12-08-2014, 02:02   #16 (permalink)
Member: 2171244
Need help to use my Octoplus box UART, win7 64 bits, i tried everything but cant use it, thanks
Old 12-18-2014, 19:46   #17 (permalink)
Member: 2210735
worked perfect
great job. thank you.
Old 12-19-2014, 02:23   #18 (permalink)
Member: 2271190
Thanks Meter: 4
thank you! got it to work. .
Old 02-23-2015, 07:17   #19 (permalink)
Member: 2165370
thank's for your kind help<<<<<<<<<<
Old 05-03-2015, 05:39   #20 (permalink)
Member: 1024748
Thanks Meter: 53
brooo i have another problem... every time i plugged box its ask for usb serial .... need solution for this
Old 05-03-2015, 08:14   #21 (permalink)
Member: 2343995
Sonork: 100.1662555
The application failed to initialize properly (0xc0150002).cleck on ok to terminte the applicatin.
please help me
Old 05-03-2015, 10:15   #22 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 27,413
@ noormohammed
Please look here:
http://forum.gsmhosting.com/vbb/f684.../#post10510863,
http://forum.gsmhosting.com/vbb/f684.../#post10741060,
http://forum.gsmhosting.com/vbb/f684.../#post10020742.
Old 07-22-2015, 18:13   #23 (permalink)
Member: 1900730
Thanks Meter: 188
Work in Windows 10 RTM X64,
Bienvenido en Octoplus/Octopus Box Samsung software versión 2.0.1
To connect SM-G360GY phone you have to perform the following
steps:
1. Disconnect USB cable from phone.
2. Go to Menu->Settings->More->About Device.
3.Tap on "Build number" 7 times to enable developer options.
4. Go to Menu->Settings->More->Developer options.
5. Turn on "USB Debugging" option.
6. Go to dial window.
7. Enter "*#0808#" number.
8. Select "DM+Modem+ADB".
9. Press Home button.
10. Press "Read Info" in software.
Plataforma: Samsung Android
Puerto seleccionado: COM1
Modelo seleccionado: SM-G360GY
Searching for a phone. Please wait...
Found phone on COM3
Reading info...
Modelo del teléfono: SM-G360GY
IMEI del teléfono: 3581890-------
MSL address: R28G30RQNS
Phone KeyID: 0209
KeyID read successfully
The Following 2 Users Say Thank You to Maurioski For This Useful Post:
Old 07-23-2015, 05:09   #24 (permalink)
Member: 785465
Thanks Meter: 7
You was able to install all the drivers? Thanks for the advice. I need to upgrade my PC because some app wont work with Win 7 anymore, and i cant use windows 8. Thanks!
Old 07-25-2015, 10:01   #25 (permalink)
Member: 1904364
Windows Update Okkk working
Old 09-02-2015, 21:21   #26 (permalink)
Member: 1790220
connecting to phone, please wait
I have install and try everything on the internet about FTDI drivers, the driver is installing on my windows 7 32 bits without any problems, at least it's not showing any yellow sign in the device manager, but every time I'm trying network repair, the box stops on:
connecting to phone, please wait...
I've tried both uart cables, micro uart C3300k for z3x and micro uart 530k that came with my octopus box
the result is the same.
plz help
Old 09-03-2015, 09:43   #27 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 12,343
Use alway LAST SW Version and Ceck carefully from "Task Manager" if other "Process" like KIES itc...are running at the same time.
allumts
Old 09-03-2015, 10:46   #28 (permalink)
Member: 1790220
I'm using Octopus Samsung 2.0.4 and I don't have kies installed on my pc
I have test the uart port and it's working.
but it seems to me like the octopus can't figure out the phone com port even it's set to automatically, I really spend lot of money on octopus box and activations and I don't want to give up this box cause I love its color
Old 09-03-2015, 13:40   #29 (permalink)
allumts's Avatar
Member: 1564612
@jean1978, first of all you are posting in WRONG thread, you are using Wi7 SO and here is for Win8/8.1....please if have specific issue, open you own thread and post all action done with FULL LOG and Screnshoot if the problem requiere...only in this mode you can receive Full Help...also seem you not have any real problem...Open you hown thread.
allumts
Old 09-14-2015, 11:03   #30 (permalink)
Member: 97242
Thanks Meter: 14
for windows 8.1 64 bit is important to disable signature driver, otherwise no way to install any driver
The Following User Says Thank You to Mirken For This Useful Post:
Page generated in 0.27413 seconds with 8 queries
