05-16-2002, 21:48 | #31 (permalink) |
Junior Member Join Date: Nov 2001 Location: uk
Member: 7664 Status: Offline Thanks Meter: 0 | Hi Alf , Thanks for the info got it working now simple when you know how just got to figue out how to switch cards without switching off then everthing is great Once again thanks Malcolm |
05-16-2002, 22:56 | #32 (permalink) |
Freak Poster Join Date: Apr 2002 Age: 44
Member: 10579 Status: Offline Thanks Meter: 0 | plz i need help i want to use sim_emu with sliver card but i want the rigth way to cut it and use it with 6210 coz it differ from the gold and funcard , the gold one and fun it's chip appers longtudinaly but the sliver gose horizntal. pls help this is the gold and this the sliver with regards Last edited by ][No_WaY; 06-06-2002 at 09:22. |
05-17-2002, 00:37 | #33 (permalink) |
Junior Member Join Date: Apr 2002 Location: Australia Age: 41
Member: 11334 Status: Offline Thanks Meter: 0 | Mate its easy as to cutout... Just trace around ur old sim with a sharp object and grab some sharp scissors... Thats all I did Takes 1 minute max and the cards arnt easy to crack if u are careful, I cut my mates out for him and its easy, just take it one small piece at a time (dont chop it right in half work ur way down to it) Happy cutting mate |
05-17-2002, 04:15 | #35 (permalink) |
Junior Member Join Date: Jan 2000 Location: Madrid, Spain Age: 69
Member: 866 Status: Offline Thanks Meter: 0 | ][No_WaY goes cutting ... There are two types of silver cards: some with normal contacts (maybe 16F876) and others with extended contacts (maybe 16F877). Both work well. Of course, the template of cuts are the same for both models, and the size of the microsims (after the cuts) obviously it is the same one. For your model, the long cuts coincide exactly with the limit of the golden area of contacts. This is a problem in a few telephones that have a microsim connector with a metallic frame. Here, there is a short-circuit risk. |
05-17-2002, 08:27 | #37 (permalink) |
Insane Poster Join Date: Apr 2001 Location: UK
Member: 4228 Status: Offline Thanks Meter: 0 | Use this guide: http://www.mobileshop.org/usertech/simcutting.htm Don't worry about the size of the contact area being larger than a normal SIM. If you're careful and follow the guide exactly it will work fine. |
05-18-2002, 01:00 | #38 (permalink) |
Member: 10579 Status: Offline Thanks Meter: 0 | thanx paul i make it as the manual but after insertion in motorola it gives me check card but it was work before cutting . i try to program it agin but win i use twoprog as i did before it gives me error while uploding eeprom loder! that's the card is dameged? |
05-20-2002, 22:58 | #39 (permalink) |
Member: 7664 Status: Offline Thanks Meter: 0 | To Simemu Hi wonder if you could help me .Is there a way of switching between cards/providers without switching the phone off and back on then entering new pin. I have a nokia 3330 and the command *3370# doesn't seem to work on ver 4.01 if I remember correctly *3370# worked on ver 4.0. Thanks in advance regards Malcolm |
05-21-2002, 00:04 | #40 (permalink) | |
Member: 4228 Status: Offline Thanks Meter: 0 | Quote:
When cutting you have to be very careful, and use a sharp knife to avoid putting too much stress on the card. You're cutting quite close to the die so if there's too much bending you can damage it. The first card I cut using those instructions no longer worked, but I have since done two more and both work fine. It is a risky process but unfortunately unless someone makes SIM-sized gold or silver cards (which is unlikely) there's no other option. | |
05-21-2002, 05:21 | #41 (permalink) |
Freak Poster Join Date: May 2002 Location: CUT_R Age: 52
Member: 11641 Status: Offline Thanks Meter: 3 | SIM-EMU 4.01 hi there dose any one can tell me how can i use SIM-EMU 4.01 or how can i downloaded to my handy(my handy is nokia 6310i) and what the hardeware do i need to use it with SIM-EMU 4.01. note i have multiprogramer2001xl is this can work? thanks for all cut_r2000 Last edited by cut_r2000; 05-21-2002 at 11:34. |
05-21-2002, 05:27 | #42 (permalink) | |
No Life Poster Join Date: Apr 2002 Location: Spain Age: 62
Member: 10582 Status: Offline Thanks Meter: 99 | Quote:
If *3370# does not to work in 4.00 in your phone, then in the 4.01 does not work too. This is a general problem of all Nokia, the Refresh command is not correctly implemented in the soft of the phones, sorry. Switch from the menu and then force the find of the network again. Regards | |
06-05-2002, 14:27 | #43 (permalink) | |
Member: 11641 Status: Offline Thanks Meter: 3 | ????? Quote:
06-06-2002, 07:36 | #44 (permalink) |
Member: 10582 Status: Offline Thanks Meter: 99 | To use SIM-EMU, you need a SilverCard/GreenCard to write in it the SIM-EMU soft. To write the soft in the card, you need a TE-20 to program the flash and a Phoenix to program the external EEPROM. I don't know if your programmer is able to do this task. Regards |
Revision SIM-EMU 6.01 (AVAILABLE) | simemu | Sim Cloning and Scaning | 175 | 04-20-2024 07:03 |
Sim Emu 4.01-Silver Card on Ericsson T39??? | headeye | Sim Cloning and Scaning | 3 | 10-14-2002 23:50 |
Sim Emu 4.01 - problem with what...??? | bontek | Sim Cloning and Scaning | 4 | 08-02-2002 23:39 |
New revision Sim-Emu 4.10 (Available in a few days) | simemu | Sim Cloning and Scaning | 59 | 07-18-2002 21:07 |
Problem with SIM-emu 4.01 | Paul M | Sim Cloning and Scaning | 10 | 05-20-2002 04:57 |
