10-23-2020, 10:36 | #31 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | Ensure that you have free disk space on your PC and repeat operation once again. Best Regards GSMServer team |
10-30-2020, 12:21 | #33 (permalink) |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ teslakemal, Please explain in more details what an issue exactly you are dealing with. Also, post here full log file, it would spread some light at your case. Best Regards GSMServer team |
07-13-2021, 09:02 | #34 (permalink) |
Junior Member Join Date: Jun 2017 Location: Malawi
Member: 2728997 Status: Offline Thanks Meter: 3 | this is caused by corrupt system files, this is an old post but some may face this problem later like i did i 2021, follow this, 1. install and update antivirus ( i recommend Escan) and run full scan ( this is to prevent any malware from coming back after fix (step 2). 2. Run cmd as Admin, type command ( sfc /scannow). wait until all is done. this fixes all corrupt file and you are good to go. if this helps, thanks meter. |
07-17-2023, 09:29 | #36 (permalink) |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ naeem9, Check free space at your PC. In most cases such an issue may appear due to low disk space. Best Regards GSMServer team |
